ADXL375 how many data bits in fifo mode?
I'm having issues to use the adxl375 in fifo mode.
I'm using right justified data
I do get data which looks valid however, I seem to only receive 10bit of data instead of 13bit?
The range of the value I get is: +511 to -512 which is 10bit data and the sign
If I understand correct, the range of 200g/0.049 = 4081 which is approximately 12bits for the value and one for the sign thus i'd expect the actual data to be 13bit.
Any idea what I could be doing wrong. Or is this a sensor limitation that it only returns 10bit value in fifo mode?
