ADXL362 FIFO Contents Miss Activity Capture in Triggered Mode
I am using ADXL362 in triggered mode and goal is to capture an impact event (may bump up to 372 but first want to undertand interface on 362). Like many posters here I am seeing a delay in the capture that I am having difficulty correcting for. Unfortunately the forums often seem to address this off line or the Analog support response is missing so I cant see clearly how others have resolved this.
Issue is when we capture data to FIFO triggered mode with linked mode set that I expect it to be like oscilloscope single trigger such that ON ACT interrupt (Or Awake bit) I can read FIFO then or slightly later to see the impact event in FIFO. I assume trigger is AWAKE and one it fills up to level in SAMPLES it holds until next event.
What actually happens is the data in the immediate FIFO read and slight delayed read appears flat however a FIFO read for the next subsequent activity interrupt often shows the imapct event ( I can make to sequetial events very differnt like tip over vs light tap).
I have tried waiting a fixed time after interrupt between 100-500ms. I have looked for overrun bit before reading FIFO, I have currently wait for inact bit after act bit to wait to read fifo but never a consistent capture of impact.
What is the correct way to configure this?
A couple of things to note about my output below:
1.) this Arduino sketch prints fifo on awake even but waits to read unttil inact bit after the act. There are verbose notes throughout
2.) 2 impacts here....note 1st one tips the unit over and 2nd one is just a tap ...you can see real time reads of xyz on wither side of event to see what oritentation it was in pere and post fifo read.
3.) the fifo since its running 6 byes per sample will be misaligned for first read or 2 but then seems to find steady alignment such that sample one is x (00) next is y (01) next is z (02) but thats not true until we roll over.
4.) strangely the number of FIFO entries comes out to 513 at times...is this correct?
5.) note in 2nd event...buffer entry 169 caught one sample of tip over event but why does it appear at end and where is event samples on either side and why second capture?
Here is my output from the adxl362:
STARTUP REGISTER READ JUST PRE MEASUREMENT MODE
_____________________________________________________________________________
X/Y/Z= 0.00/0.00/0.00 Temp:107.69 Pin 13:1 STAT:40 FLTER_CTL:5 PWR_CTL:0 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:0 loop:0 millis():56
STARTUP REGISTER READ JUST POST MEASUREMENT MODE
X/Y/Z= -0.02/-1.16/0.14 Temp:73.18 Pin 13:1 STAT:42 FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:63 loop:0 millis():82
0
1
JUST_MOTION is true.
loop iteration= 0
0
X/Y/Z= -0.03/-1.13/0.14 Temp:73.41 Pin 13:1 STAT:42 FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:87 loop:0 millis():100
Waiting for Inact bit to set
X/Y/Z= -0.03/-1.16/0.13 Temp:73.53 Pin 13:1 STAT:42 FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:114 loop:0 millis():117
X/Y/Z= -0.01/-1.14/0.16 Temp:73.41 Pin 13:0 STAT:26 FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:512 loop:0 millis():682
Read 512 (2-byte) samples, after reading that out into an array shift out any samples not part of a triplet measurement set off the front of the array (oldest)
X/Y/Z= -0.03/-1.15/0.12 Temp:73.06 Pin 13:0 STAT:2 FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:3 loop:0 millis():710
Print buffer also looking at axis identificaiton bits
0 02 00 01
x=;+0100;y=;-0020;z=;-1153;FIFO_BUFF PLACE:;00
6 02 00 01
x=;+0120;y=;-0029;z=;-1156;FIFO_BUFF PLACE:;01
12 02 00 01
x=;+0136;y=;-0025;z=;-1128;FIFO_BUFF PLACE:;02
18 02 00 01
x=;+0142;y=;-0024;z=;-1162;FIFO_BUFF PLACE:;03
24 02 00 01
x=;+0140;y=;-0025;z=;-1154;FIFO_BUFF PLACE:;04
30 02 00 01
x=;+0136;y=;-0025;z=;-1165;FIFO_BUFF PLACE:;05
36 02 00 01
x=;+0115;y=;-0036;z=;-1154;FIFO_BUFF PLACE:;06
42 02 00 01
x=;+0113;y=;-0032;z=;-1133;FIFO_BUFF PLACE:;07
48 02 00 01
x=;+0135;y=;-0023;z=;-1128;FIFO_BUFF PLACE:;08
54 02 00 01
x=;+0144;y=;-0025;z=;-1137;FIFO_BUFF PLACE:;09
60 02 00 01
x=;+0131;y=;-0025;z=;-1149;FIFO_BUFF PLACE:;010
66 02 00 01
x=;+0116;y=;-0029;z=;-1157;FIFO_BUFF PLACE:;011
72 02 00 01
x=;+0102;y=;-0031;z=;-1149;FIFO_BUFF PLACE:;012
78 02 00 01
x=;+0131;y=;-0042;z=;-1145;FIFO_BUFF PLACE:;013
84 02 00 01
x=;+0144;y=;-0026;z=;-1138;FIFO_BUFF PLACE:;014
90 02 00 01
x=;+0156;y=;-0028;z=;-1160;FIFO_BUFF PLACE:;015
96 02 00 01
x=;+0132;y=;-0028;z=;-1160;FIFO_BUFF PLACE:;016
102 02 00 01
x=;+0135;y=;-0040;z=;-1153;FIFO_BUFF PLACE:;017
108 02 00 01
x=;+0147;y=;-0032;z=;-1140;FIFO_BUFF PLACE:;018
114 02 00 01
x=;+0124;y=;-0036;z=;-1145;FIFO_BUFF PLACE:;019
120 02 00 01
x=;+0145;y=;-0041;z=;-1140;FIFO_BUFF PLACE:;020
126 02 00 01
x=;+0120;y=;-0031;z=;-1160;FIFO_BUFF PLACE:;021
132 02 00 01
x=;+0112;y=;-0029;z=;-1152;FIFO_BUFF PLACE:;022
138 02 00 01
x=;+0131;y=;-0025;z=;-1169;FIFO_BUFF PLACE:;023
144 02 00 01
x=;+0137;y=;-0009;z=;-1136;FIFO_BUFF PLACE:;024
150 02 00 01
x=;+0156;y=;-0023;z=;-1162;FIFO_BUFF PLACE:;025
156 02 00 01
x=;+0160;y=;-0025;z=;-1169;FIFO_BUFF PLACE:;026
162 02 00 01
x=;+0121;y=;-0032;z=;-1154;FIFO_BUFF PLACE:;027
168 02 00 01
x=;+0112;y=;-0025;z=;-1145;FIFO_BUFF PLACE:;028
174 02 00 01
x=;+0131;y=;-0028;z=;-1137;FIFO_BUFF PLACE:;029
180 02 00 01
x=;+0135;y=;-0016;z=;-1136;FIFO_BUFF PLACE:;030
186 02 00 01
x=;+0127;y=;-0017;z=;-1144;FIFO_BUFF PLACE:;031
192 02 00 01
x=;+0140;y=;-0018;z=;-1138;FIFO_BUFF PLACE:;032
198 02 00 01
x=;+0147;y=;-0029;z=;-1157;FIFO_BUFF PLACE:;033
204 02 00 01
x=;+0111;y=;-0025;z=;-1149;FIFO_BUFF PLACE:;034
210 02 00 01
x=;+0129;y=;-0024;z=;-1135;FIFO_BUFF PLACE:;035
216 02 00 01
x=;+0144;y=;-0020;z=;-1137;FIFO_BUFF PLACE:;036
222 02 00 01
x=;+0148;y=;-0033;z=;-1143;FIFO_BUFF PLACE:;037
228 02 00 01
x=;+0123;y=;-0024;z=;-1152;FIFO_BUFF PLACE:;038
234 02 00 01
x=;+0102;y=;-0031;z=;-1152;FIFO_BUFF PLACE:;039
240 02 00 01
x=;+0102;y=;-0033;z=;-1138;FIFO_BUFF PLACE:;040
246 02 00 01
x=;+0111;y=;-0031;z=;-1144;FIFO_BUFF PLACE:;041
252 02 00 01
x=;+0167;y=;-0033;z=;-1149;FIFO_BUFF PLACE:;042
258 02 00 01
x=;+0156;y=;-0025;z=;-1161;FIFO_BUFF PLACE:;043
264 02 00 01
x=;+0135;y=;-0020;z=;-1156;FIFO_BUFF PLACE:;044
270 02 00 01
x=;+0143;y=;-0029;z=;-1160;FIFO_BUFF PLACE:;045
276 02 00 01
x=;+0127;y=;-0032;z=;-1138;FIFO_BUFF PLACE:;046
282 02 00 01
x=;+0143;y=;-0025;z=;-1153;FIFO_BUFF PLACE:;047
288 02 00 01
x=;+0124;y=;-0033;z=;-1146;FIFO_BUFF PLACE:;048
294 02 00 01
x=;+0113;y=;-0031;z=;-1153;FIFO_BUFF PLACE:;049
300 02 00 01
x=;+0111;y=;-0026;z=;-1156;FIFO_BUFF PLACE:;050
306 02 00 01
x=;+0131;y=;-0031;z=;-1157;FIFO_BUFF PLACE:;051
312 02 00 01
x=;+0135;y=;-0016;z=;-1133;FIFO_BUFF PLACE:;052
318 02 00 01
x=;+0135;y=;-0028;z=;-1136;FIFO_BUFF PLACE:;053
324 02 00 01
x=;+0145;y=;-0016;z=;-1133;FIFO_BUFF PLACE:;054
330 02 00 01
x=;+0127;y=;-0024;z=;-1161;FIFO_BUFF PLACE:;055
336 02 00 01
x=;+0127;y=;-0029;z=;-1154;FIFO_BUFF PLACE:;056
342 02 00 01
x=;+0119;y=;-0033;z=;-1152;FIFO_BUFF PLACE:;057
348 02 00 01
x=;+0124;y=;-0016;z=;-1145;FIFO_BUFF PLACE:;058
354 02 00 01
x=;+0135;y=;-0025;z=;-1168;FIFO_BUFF PLACE:;059
360 02 00 01
x=;+0121;y=;-0016;z=;-1146;FIFO_BUFF PLACE:;060
366 02 00 01
x=;+0159;y=;-0029;z=;-1167;FIFO_BUFF PLACE:;061
372 02 00 01
x=;+0144;y=;-0029;z=;-1161;FIFO_BUFF PLACE:;062
378 02 00 01
x=;+0120;y=;-0036;z=;-1162;FIFO_BUFF PLACE:;063
384 02 00 01
x=;+0104;y=;-0020;z=;-1137;FIFO_BUFF PLACE:;064
390 02 00 01
x=;+0137;y=;-0040;z=;-1133;FIFO_BUFF PLACE:;065
396 02 00 01
x=;+0143;y=;-0021;z=;-1128;FIFO_BUFF PLACE:;066
402 02 00 01
x=;+0111;y=;-0034;z=;-1137;FIFO_BUFF PLACE:;067
408 02 00 01
x=;+0100;y=;-0032;z=;-1153;FIFO_BUFF PLACE:;068
414 02 00 01
x=;+0134;y=;-0023;z=;-1161;FIFO_BUFF PLACE:;069
420 02 00 01
x=;+0116;y=;-0024;z=;-1143;FIFO_BUFF PLACE:;070
426 02 00 01
x=;+0152;y=;-0024;z=;-1146;FIFO_BUFF PLACE:;071
432 02 00 01
x=;+0158;y=;-0036;z=;-1160;FIFO_BUFF PLACE:;072
438 02 00 01
x=;+0152;y=;-0025;z=;-1169;FIFO_BUFF PLACE:;073
444 02 00 01
x=;+0132;y=;-0036;z=;-1145;FIFO_BUFF PLACE:;074
450 02 00 01
x=;+0135;y=;-0036;z=;-1140;FIFO_BUFF PLACE:;075
456 02 00 01
x=;+0152;y=;-0018;z=;-1129;FIFO_BUFF PLACE:;076
462 02 00 01
x=;+0148;y=;-0020;z=;-1150;FIFO_BUFF PLACE:;077
468 02 00 01
x=;+0153;y=;-0009;z=;-1165;FIFO_BUFF PLACE:;078
474 02 00 01
x=;+0140;y=;-0017;z=;-1154;FIFO_BUFF PLACE:;079
480 02 00 01
x=;+0135;y=;-0032;z=;-1141;FIFO_BUFF PLACE:;080
486 02 00 01
x=;+0135;y=;-0036;z=;-1145;FIFO_BUFF PLACE:;081
492 02 00 01
x=;+0144;y=;-0009;z=;-1130;FIFO_BUFF PLACE:;082
498 02 00 01
x=;+0121;y=;-0012;z=;-1160;FIFO_BUFF PLACE:;083
504 02 00 01
x=;+0127;y=;-0027;z=;-1145;FIFO_BUFF PLACE:;084
510 02 00 01
x=;+0112;y=;-0041;z=;-1145;FIFO_BUFF PLACE:;085
516 02 00 01
x=;+0116;y=;-0025;z=;-1132;FIFO_BUFF PLACE:;086
522 02 00 01
x=;+0103;y=;-0015;z=;-1140;FIFO_BUFF PLACE:;087
528 02 00 01
x=;+0127;y=;-0012;z=;-1138;FIFO_BUFF PLACE:;088
534 02 00 01
x=;+0145;y=;-0020;z=;-1165;FIFO_BUFF PLACE:;089
540 02 00 01
x=;+0142;y=;-0031;z=;-1151;FIFO_BUFF PLACE:;090
546 02 00 01
x=;+0134;y=;-0031;z=;-1137;FIFO_BUFF PLACE:;091
552 02 00 01
x=;+0123;y=;-0029;z=;-1130;FIFO_BUFF PLACE:;092
558 02 00 01
x=;+0143;y=;-0034;z=;-1160;FIFO_BUFF PLACE:;093
564 02 00 01
x=;+0136;y=;-0015;z=;-1165;FIFO_BUFF PLACE:;094
570 02 00 01
x=;+0132;y=;-0032;z=;-1166;FIFO_BUFF PLACE:;095
576 02 00 01
x=;+0113;y=;-0040;z=;-1146;FIFO_BUFF PLACE:;096
582 02 00 01
x=;+0127;y=;-0024;z=;-1130;FIFO_BUFF PLACE:;097
588 02 00 01
x=;+0131;y=;-0025;z=;-1128;FIFO_BUFF PLACE:;098
594 02 00 01
x=;+0137;y=;-0031;z=;-1143;FIFO_BUFF PLACE:;099
600 02 00 01
x=;+0108;y=;-0024;z=;-1145;FIFO_BUFF PLACE:;0100
606 02 00 01
x=;+0110;y=;-0025;z=;-1152;FIFO_BUFF PLACE:;0101
612 02 00 01
x=;+0115;y=;-0025;z=;-1151;FIFO_BUFF PLACE:;0102
618 02 00 01
x=;+0128;y=;-0028;z=;-1153;FIFO_BUFF PLACE:;0103
624 02 00 01
x=;+0156;y=;-0025;z=;-1145;FIFO_BUFF PLACE:;0104
630 02 00 01
x=;+0140;y=;-0025;z=;-1165;FIFO_BUFF PLACE:;0105
636 02 00 01
x=;+0120;y=;-0039;z=;-1146;FIFO_BUFF PLACE:;0106
642 02 00 01
x=;+0147;y=;-0030;z=;-1136;FIFO_BUFF PLACE:;0107
648 02 00 01
x=;+0129;y=;-0029;z=;-1129;FIFO_BUFF PLACE:;0108
654 02 00 01
x=;+0140;y=;-0045;z=;-1143;FIFO_BUFF PLACE:;0109
660 02 00 01
x=;+0119;y=;-0045;z=;-1141;FIFO_BUFF PLACE:;0110
666 02 00 01
x=;+0124;y=;-0025;z=;-1159;FIFO_BUFF PLACE:;0111
672 02 00 01
x=;+0110;y=;-0024;z=;-1149;FIFO_BUFF PLACE:;0112
678 02 00 01
x=;+0127;y=;-0016;z=;-1143;FIFO_BUFF PLACE:;0113
684 02 00 01
x=;+0152;y=;-0016;z=;-1140;FIFO_BUFF PLACE:;0114
690 02 00 01
x=;+0174;y=;-0029;z=;-1154;FIFO_BUFF PLACE:;0115
696 02 00 01
x=;+0144;y=;-0032;z=;-1152;FIFO_BUFF PLACE:;0116
702 02 00 01
x=;+0131;y=;-0031;z=;-1149;FIFO_BUFF PLACE:;0117
708 02 00 01
x=;+0131;y=;-0016;z=;-1135;FIFO_BUFF PLACE:;0118
714 02 00 01
x=;+0134;y=;-0031;z=;-1137;FIFO_BUFF PLACE:;0119
720 02 00 01
x=;+0134;y=;-0025;z=;-1135;FIFO_BUFF PLACE:;0120
726 02 00 01
x=;+0121;y=;-0016;z=;-1145;FIFO_BUFF PLACE:;0121
732 02 00 01
x=;+0092;y=;-0021;z=;-1140;FIFO_BUFF PLACE:;0122
738 02 00 01
x=;+0112;y=;-0029;z=;-1152;FIFO_BUFF PLACE:;0123
744 02 00 01
x=;+0107;y=;-0024;z=;-1144;FIFO_BUFF PLACE:;0124
750 02 00 01
x=;+0120;y=;-0029;z=;-1152;FIFO_BUFF PLACE:;0125
756 02 00 01
x=;+0135;y=;-0028;z=;-1140;FIFO_BUFF PLACE:;0126
762 02 00 01
x=;+0120;y=;-0032;z=;-1150;FIFO_BUFF PLACE:;0127
768 02 00 01
x=;+0136;y=;-0028;z=;-1169;FIFO_BUFF PLACE:;0128
774 02 00 01
x=;+0097;y=;-0026;z=;-1149;FIFO_BUFF PLACE:;0129
780 02 00 01
x=;+0103;y=;-0025;z=;-1136;FIFO_BUFF PLACE:;0130
786 02 00 01
x=;+0151;y=;-0028;z=;-1140;FIFO_BUFF PLACE:;0131
792 02 00 01
x=;+0141;y=;-0026;z=;-1144;FIFO_BUFF PLACE:;0132
798 02 00 01
x=;+0127;y=;-0035;z=;-1168;FIFO_BUFF PLACE:;0133
804 02 00 01
x=;+0124;y=;-0040;z=;-1137;FIFO_BUFF PLACE:;0134
810 02 00 01
x=;+0118;y=;-0029;z=;-1156;FIFO_BUFF PLACE:;0135
816 02 00 01
x=;+0120;y=;-0025;z=;-1136;FIFO_BUFF PLACE:;0136
822 02 00 01
x=;+0127;y=;-0028;z=;-1140;FIFO_BUFF PLACE:;0137
828 02 00 01
x=;+0185;y=;-0032;z=;-1154;FIFO_BUFF PLACE:;0138
834 02 00 01
x=;+0152;y=;-0029;z=;-1165;FIFO_BUFF PLACE:;0139
840 02 00 01
x=;+0125;y=;-0035;z=;-1151;FIFO_BUFF PLACE:;0140
846 02 00 01
x=;+0119;y=;-0042;z=;-1128;FIFO_BUFF PLACE:;0141
852 02 00 01
x=;+0134;y=;-0016;z=;-1129;FIFO_BUFF PLACE:;0142
858 02 00 01
x=;+0115;y=;-0021;z=;-1144;FIFO_BUFF PLACE:;0143
864 02 00 01
x=;+0137;y=;-0015;z=;-1138;FIFO_BUFF PLACE:;0144
870 02 00 01
x=;+0131;y=;-0025;z=;-1169;FIFO_BUFF PLACE:;0145
876 02 00 01
x=;+0143;y=;-0029;z=;-1157;FIFO_BUFF PLACE:;0146
882 02 00 01
x=;+0134;y=;-0036;z=;-1147;FIFO_BUFF PLACE:;0147
888 02 00 01
x=;+0129;y=;-0025;z=;-1137;FIFO_BUFF PLACE:;0148
894 02 00 01
x=;+0135;y=;-0020;z=;-1144;FIFO_BUFF PLACE:;0149
900 02 00 01
x=;+0131;y=;-0015;z=;-1137;FIFO_BUFF PLACE:;0150
906 02 00 01
x=;+0152;y=;-0036;z=;-1160;FIFO_BUFF PLACE:;0151
912 02 00 01
x=;+0135;y=;-0034;z=;-1154;FIFO_BUFF PLACE:;0152
918 02 00 01
x=;+0137;y=;-0032;z=;-1143;FIFO_BUFF PLACE:;0153
924 02 00 01
x=;+0134;y=;-0016;z=;-1141;FIFO_BUFF PLACE:;0154
930 02 00 01
x=;+0126;y=;-0036;z=;-1160;FIFO_BUFF PLACE:;0155
936 02 00 01
x=;+0135;y=;-0029;z=;-1145;FIFO_BUFF PLACE:;0156
942 02 00 01
x=;+0131;y=;-0047;z=;-1152;FIFO_BUFF PLACE:;0157
948 02 00 01
x=;+0112;y=;-0032;z=;-1152;FIFO_BUFF PLACE:;0158
954 02 00 01
x=;+0132;y=;-0029;z=;-1145;FIFO_BUFF PLACE:;0159
960 02 00 01
x=;+0124;y=;-0013;z=;-1144;FIFO_BUFF PLACE:;0160
966 02 00 01
x=;+0160;y=;-0026;z=;-1154;FIFO_BUFF PLACE:;0161
972 02 00 01
x=;+0152;y=;-0034;z=;-1158;FIFO_BUFF PLACE:;0162
978 02 00 01
x=;+0137;y=;-0031;z=;-1159;FIFO_BUFF PLACE:;0163
984 02 00 01
x=;+0152;y=;-0036;z=;-1145;FIFO_BUFF PLACE:;0164
990 02 00 01
x=;+0132;y=;-0036;z=;-1128;FIFO_BUFF PLACE:;0165
996 02 00 01
x=;+0135;y=;-0010;z=;-1136;FIFO_BUFF PLACE:;0166
1002 02 00 01
x=;+0103;y=;-0025;z=;-1137;FIFO_BUFF PLACE:;0167
1008 02 00 01
x=;+0136;y=;-0026;z=;-1137;FIFO_BUFF PLACE:;0168
1014 02 00 01
x=;+0135;y=;-0026;z=;-1154;FIFO_BUFF PLACE:;0169
Reading Status Now
X/Y/Z= -0.03/-1.14/0.13 Temp:73.41 Pin 13:0 STAT:6 FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:512 loop:0 millis():1708
1
0
JUST_STILL is true.
loop iteration= 1
X/Y/Z= -0.04/-1.14/0.14 Temp:73.18 Pin 13:0 STAT:6 FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:512 loop:1 millis():1727
Reading Status Now
X/Y/Z= -0.03/-1.16/0.12 Temp:73.06 Pin 13:0 STAT:6 FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:512 loop:10000000 millis():8420
Reading Status Now
X/Y/Z= 0.14/-1.22/0.01 Temp:73.06 Pin 13:0 STAT:6 FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:512 loop:20000000 millis():15113
0
1
loop iteration= 20000001
0
X/Y/Z= 0.20/-1.08/0.29 Temp:73.06 Pin 13:1 STAT:56 FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:272 loop:20000001 millis():15133
X/Y/Z= -0.07/-0.86/0.41 Temp:73.41 Pin 13:1 STAT:46 FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:302 loop:20000001 millis():15151
X/Y/Z= -0.05/-0.03/1.16 Temp:73.53 Pin 13:0 STAT:2E FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:513 loop:20000001 millis():16080
X/Y/Z= -0.05/-0.02/1.19 Temp:73.53 Pin 13:0 STAT:2 FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:4 loop:20000001 millis():16109
0 02 00 01
x=;+0116;y=;-0024;z=;-1124;FIFO_BUFF PLACE:;00
6 02 00 01
x=;+0137;y=;-0020;z=;-1128;FIFO_BUFF PLACE:;01
12 02 00 01
x=;+0127;y=;-0023;z=;-1146;FIFO_BUFF PLACE:;02
18 02 00 01
x=;+0134;y=;-0021;z=;-1159;FIFO_BUFF PLACE:;03
24 02 00 01
x=;+0137;y=;-0029;z=;-1149;FIFO_BUFF PLACE:;04
30 02 00 01
x=;+0126;y=;-0025;z=;-1149;FIFO_BUFF PLACE:;05
36 02 00 01
x=;+0143;y=;-0029;z=;-1156;FIFO_BUFF PLACE:;06
42 02 00 01
x=;+0132;y=;-0026;z=;-1165;FIFO_BUFF PLACE:;07
48 02 00 01
x=;+0120;y=;-0033;z=;-1152;FIFO_BUFF PLACE:;08
54 02 00 01
x=;+0112;y=;-0041;z=;-1145;FIFO_BUFF PLACE:;09
60 02 00 01
x=;+0105;y=;-0026;z=;-1141;FIFO_BUFF PLACE:;010
66 02 00 01
x=;+0115;y=;-0020;z=;-1140;FIFO_BUFF PLACE:;011
72 02 00 01
x=;+0135;y=;-0023;z=;-1136;FIFO_BUFF PLACE:;012
78 02 00 01
x=;+0158;y=;-0025;z=;-1124;FIFO_BUFF PLACE:;013
84 02 00 01
x=;+0148;y=;-0037;z=;-1141;FIFO_BUFF PLACE:;014
90 02 00 01
x=;+0143;y=;-0020;z=;-1151;FIFO_BUFF PLACE:;015
96 02 00 01
x=;+0148;y=;-0036;z=;-1136;FIFO_BUFF PLACE:;016
102 02 00 01
x=;+0161;y=;-0025;z=;-1152;FIFO_BUFF PLACE:;017
108 02 00 01
x=;+0139;y=;-0049;z=;-1133;FIFO_BUFF PLACE:;018
114 02 00 01
x=;+0108;y=;-0028;z=;-1160;FIFO_BUFF PLACE:;019
120 02 00 01
x=;+0084;y=;-0031;z=;-1151;FIFO_BUFF PLACE:;020
126 02 00 01
x=;+0084;y=;-0025;z=;-1160;FIFO_BUFF PLACE:;021
132 02 00 01
x=;+0096;y=;-0036;z=;-1159;FIFO_BUFF PLACE:;022
138 02 00 01
x=;+0112;y=;-0033;z=;-1160;FIFO_BUFF PLACE:;023
144 02 00 01
x=;+0135;y=;-0040;z=;-1164;FIFO_BUFF PLACE:;024
150 02 00 01
x=;+0131;y=;-0045;z=;-1165;FIFO_BUFF PLACE:;025
156 02 00 01
x=;+0108;y=;-0049;z=;-1145;FIFO_BUFF PLACE:;026
162 02 00 01
x=;+0120;y=;-0039;z=;-1138;FIFO_BUFF PLACE:;027
168 02 00 01
x=;+0139;y=;-0040;z=;-1120;FIFO_BUFF PLACE:;028
174 02 00 01
x=;+0124;y=;-0025;z=;-1136;FIFO_BUFF PLACE:;029
180 02 00 01
x=;+0118;y=;-0025;z=;-1137;FIFO_BUFF PLACE:;030
186 02 00 01
x=;+0143;y=;-0033;z=;-1149;FIFO_BUFF PLACE:;031
192 02 00 01
x=;+0124;y=;-0026;z=;-1167;FIFO_BUFF PLACE:;032
198 02 00 01
x=;+0131;y=;-0016;z=;-1162;FIFO_BUFF PLACE:;033
204 02 00 01
x=;+0140;y=;-0025;z=;-1157;FIFO_BUFF PLACE:;034
210 02 00 01
x=;+0140;y=;-0034;z=;-1156;FIFO_BUFF PLACE:;035
216 02 00 01
x=;+0123;y=;-0032;z=;-1156;FIFO_BUFF PLACE:;036
222 02 00 01
x=;+0099;y=;-0036;z=;-1161;FIFO_BUFF PLACE:;037
228 02 00 01
x=;+0099;y=;-0017;z=;-1160;FIFO_BUFF PLACE:;038
234 02 00 01
x=;+0095;y=;+0019;z=;-1165;FIFO_BUFF PLACE:;039
240 02 00 01
x=;+0073;y=;+0028;z=;-1181;FIFO_BUFF PLACE:;040
246 02 00 01
x=;+0102;y=;-0007;z=;-1181;FIFO_BUFF PLACE:;041
252 02 00 01
x=;+0079;y=;-0012;z=;-1184;FIFO_BUFF PLACE:;042
258 02 00 01
x=;+0088;y=;-0025;z=;-1177;FIFO_BUFF PLACE:;043
264 02 00 01
x=;+0076;y=;-0029;z=;-1177;FIFO_BUFF PLACE:;044
270 02 00 01
x=;+0103;y=;-0047;z=;-1208;FIFO_BUFF PLACE:;045
276 02 00 01
x=;+0120;y=;-0153;z=;-0986;FIFO_BUFF PLACE:;046
282 02 00 01
x=;+0039;y=;-0093;z=;-1361;FIFO_BUFF PLACE:;047
288 02 00 01
x=;+0060;y=;-0012;z=;-1016;FIFO_BUFF PLACE:;048
294 02 00 01
x=;+0105;y=;-0018;z=;-1308;FIFO_BUFF PLACE:;049
300 02 00 01
x=;+0054;y=;-0028;z=;-1049;FIFO_BUFF PLACE:;050
306 02 00 01
x=;+0159;y=;-0001;z=;-1272;FIFO_BUFF PLACE:;051
312 02 00 01
x=;+0073;y=;-0045;z=;-1098;FIFO_BUFF PLACE:;052
318 02 00 01
x=;+0108;y=;-0018;z=;-1250;FIFO_BUFF PLACE:;053
324 02 00 01
x=;+0102;y=;-0036;z=;-1130;FIFO_BUFF PLACE:;054
330 02 00 01
x=;+0071;y=;-0039;z=;-1192;FIFO_BUFF PLACE:;055
336 02 00 01
x=;+0124;y=;-0024;z=;-1137;FIFO_BUFF PLACE:;056
342 02 00 01
x=;+0078;y=;-0026;z=;-1178;FIFO_BUFF PLACE:;057
348 02 00 01
x=;+0088;y=;-0026;z=;-1140;FIFO_BUFF PLACE:;058
354 02 00 01
x=;+0140;y=;-0040;z=;-1185;FIFO_BUFF PLACE:;059
360 02 00 01
x=;+0126;y=;-0025;z=;-1145;FIFO_BUFF PLACE:;060
366 02 00 01
x=;+0160;y=;-0024;z=;-1160;FIFO_BUFF PLACE:;061
372 02 00 01
x=;+0147;y=;-0032;z=;-1156;FIFO_BUFF PLACE:;062
378 02 00 01
x=;+0176;y=;-0034;z=;-1161;FIFO_BUFF PLACE:;063
384 02 00 01
x=;+0159;y=;-0039;z=;-1177;FIFO_BUFF PLACE:;064
390 02 00 01
x=;+0147;y=;-0009;z=;-1232;FIFO_BUFF PLACE:;065
396 02 00 01
x=;+0126;y=;+0059;z=;-1118;FIFO_BUFF PLACE:;066
402 02 00 01
x=;+0080;y=;+0088;z=;-1133;FIFO_BUFF PLACE:;067
408 02 00 01
x=;+0119;y=;+0028;z=;-1184;FIFO_BUFF PLACE:;068
414 02 00 01
x=;+0135;y=;-0033;z=;-1249;FIFO_BUFF PLACE:;069
420 02 00 01
x=;+0083;y=;-0057;z=;-1216;FIFO_BUFF PLACE:;070
426 02 00 01
x=;+0048;y=;-0050;z=;-1210;FIFO_BUFF PLACE:;071
432 02 00 01
x=;+0057;y=;-0052;z=;-1220;FIFO_BUFF PLACE:;072
438 02 00 01
x=;+0057;y=;-0055;z=;-1224;FIFO_BUFF PLACE:;073
444 02 00 01
x=;+0024;y=;-0004;z=;-1175;FIFO_BUFF PLACE:;074
450 02 00 01
x=;-0004;y=;+0025;z=;-1213;FIFO_BUFF PLACE:;075
456 02 00 01
x=;-0017;y=;+0031;z=;-1236;FIFO_BUFF PLACE:;076
462 02 00 01
x=;-0005;y=;+0024;z=;-1257;FIFO_BUFF PLACE:;077
468 02 00 01
x=;-0017;y=;+0039;z=;-1265;FIFO_BUFF PLACE:;078
474 02 00 01
x=;+0007;y=;+0067;z=;-1264;FIFO_BUFF PLACE:;079
480 02 00 01
x=;-0001;y=;+0103;z=;-1245;FIFO_BUFF PLACE:;080
486 02 00 01
x=;+0009;y=;+0113;z=;-1229;FIFO_BUFF PLACE:;081
492 02 00 01
x=;-0025;y=;+0145;z=;-1215;FIFO_BUFF PLACE:;082
498 02 00 01
x=;+0012;y=;+0177;z=;-1232;FIFO_BUFF PLACE:;083
504 02 00 01
x=;+0028;y=;+0191;z=;-1224;FIFO_BUFF PLACE:;084
510 02 00 01
x=;+0049;y=;+0217;z=;-1208;FIFO_BUFF PLACE:;085
516 02 00 01
x=;+0071;y=;+0227;z=;-1201;FIFO_BUFF PLACE:;086
522 02 00 01
x=;+0143;y=;+0215;z=;-1160;FIFO_BUFF PLACE:;087
528 02 00 01
x=;+0191;y=;+0215;z=;-1136;FIFO_BUFF PLACE:;088
534 02 00 01
x=;+0248;y=;+0198;z=;-1081;FIFO_BUFF PLACE:;089
540 02 00 01
x=;+0287;y=;+0191;z=;-1088;FIFO_BUFF PLACE:;090
546 02 00 01
x=;+0277;y=;+0161;z=;-1021;FIFO_BUFF PLACE:;091
552 02 00 01
x=;+0248;y=;+0152;z=;-1017;FIFO_BUFF PLACE:;092
558 02 00 01
x=;+0283;y=;+0143;z=;-0945;FIFO_BUFF PLACE:;093
564 02 00 01
x=;+0392;y=;+0110;z=;-0968;FIFO_BUFF PLACE:;094
570 02 00 01
x=;+0420;y=;+0081;z=;-0903;FIFO_BUFF PLACE:;095
576 02 00 01
x=;+0441;y=;+0063;z=;-0776;FIFO_BUFF PLACE:;096
582 02 00 01
x=;+0502;y=;+0023;z=;-0817;FIFO_BUFF PLACE:;097
588 02 00 01
x=;+0452;y=;-0036;z=;-0669;FIFO_BUFF PLACE:;098
594 02 00 01
x=;+0412;y=;-0074;z=;-0861;FIFO_BUFF PLACE:;099
600 02 00 01
x=;+0414;y=;-0096;z=;-0555;FIFO_BUFF PLACE:;0100
606 02 00 01
x=;+0563;y=;-0148;z=;-0584;FIFO_BUFF PLACE:;0101
612 02 00 01
x=;+0515;y=;-0208;z=;-0554;FIFO_BUFF PLACE:;0102
618 02 00 01
x=;+0470;y=;-0265;z=;-0373;FIFO_BUFF PLACE:;0103
624 02 00 01
x=;+0448;y=;-0288;z=;-0367;FIFO_BUFF PLACE:;0104
630 02 00 01
x=;+0379;y=;-0284;z=;-0335;FIFO_BUFF PLACE:;0105
636 02 00 01
x=;+0425;y=;-0338;z=;-0241;FIFO_BUFF PLACE:;0106
642 02 00 01
x=;+0455;y=;-0353;z=;-0193;FIFO_BUFF PLACE:;0107
648 02 00 01
x=;+0527;y=;-0921;z=;-0071;FIFO_BUFF PLACE:;0108
654 02 00 01
x=;+0420;y=;-0242;z=;-0305;FIFO_BUFF PLACE:;0109
660 02 00 01
x=;+0252;y=;-0121;z=;-0344;FIFO_BUFF PLACE:;0110
666 02 00 01
x=;+0111;y=;-0564;z=;+0160;FIFO_BUFF PLACE:;0111
672 02 00 01
x=;+0200;y=;-0141;z=;-0390;FIFO_BUFF PLACE:;0112
678 02 00 01
x=;+0118;y=;-0052;z=;-0488;FIFO_BUFF PLACE:;0113
684 02 00 01
x=;+0326;y=;-0086;z=;-0225;FIFO_BUFF PLACE:;0114
690 02 00 01
x=;+0184;y=;-0114;z=;-0351;FIFO_BUFF PLACE:;0115
696 02 00 01
x=;+0023;y=;-0060;z=;-0324;FIFO_BUFF PLACE:;0116
702 02 00 01
x=;+0143;y=;-0104;z=;-0328;FIFO_BUFF PLACE:;0117
708 02 00 01
x=;+0248;y=;-0121;z=;-0273;FIFO_BUFF PLACE:;0118
714 02 00 01
x=;+0224;y=;-0074;z=;-0388;FIFO_BUFF PLACE:;0119
720 02 00 01
x=;+0223;y=;-0100;z=;-0215;FIFO_BUFF PLACE:;0120
726 02 00 01
x=;+0134;y=;-0104;z=;-0247;FIFO_BUFF PLACE:;0121
732 02 00 01
x=;+0084;y=;-0112;z=;-0253;FIFO_BUFF PLACE:;0122
738 02 00 01
x=;+0095;y=;-0103;z=;-0200;FIFO_BUFF PLACE:;0123
744 02 00 01
x=;+0190;y=;-0121;z=;-0289;FIFO_BUFF PLACE:;0124
750 02 00 01
x=;+0216;y=;-0076;z=;-0245;FIFO_BUFF PLACE:;0125
756 02 00 01
x=;+0255;y=;-0073;z=;-0144;FIFO_BUFF PLACE:;0126
762 02 00 01
x=;+0280;y=;-0097;z=;-0196;FIFO_BUFF PLACE:;0127
768 02 00 01
x=;+0228;y=;-0105;z=;-0124;FIFO_BUFF PLACE:;0128
774 02 00 01
x=;+0342;y=;-0409;z=;-0162;FIFO_BUFF PLACE:;0129
780 02 00 01
x=;+0422;y=;+0184;z=;+2047;FIFO_BUFF PLACE:;0130
786 02 00 01
x=;+2047;y=;+0368;z=;+0400;FIFO_BUFF PLACE:;0131
792 02 00 01
x=;+1854;y=;-2048;z=;+1008;FIFO_BUFF PLACE:;0132
798 02 00 01
x=;+2047;y=;-1068;z=;+0556;FIFO_BUFF PLACE:;0133
804 02 00 01
x=;+2047;y=;-0969;z=;+1670;FIFO_BUFF PLACE:;0134
810 02 00 01
x=;-1602;y=;-1137;z=;+1948;FIFO_BUFF PLACE:;0135
816 02 00 01
x=;+0369;y=;-0345;z=;-0032;FIFO_BUFF PLACE:;0136
822 02 00 01
x=;+1497;y=;-0144;z=;+0334;FIFO_BUFF PLACE:;0137
828 02 00 01
x=;+0833;y=;-0656;z=;+0352;FIFO_BUFF PLACE:;0138
834 02 00 01
x=;-0498;y=;-0148;z=;-0184;FIFO_BUFF PLACE:;0139
840 02 00 01
x=;-0688;y=;-0125;z=;-0034;FIFO_BUFF PLACE:;0140
846 02 00 01
x=;+0255;y=;+0439;z=;+0739;FIFO_BUFF PLACE:;0141
852 02 00 01
x=;+2047;y=;-1273;z=;+0968;FIFO_BUFF PLACE:;0142
858 02 00 01
x=;-2017;y=;-0084;z=;-0086;FIFO_BUFF PLACE:;0143
864 02 00 01
x=;-0199;y=;-0023;z=;+0135;FIFO_BUFF PLACE:;0144
870 02 00 01
x=;+1648;y=;+0086;z=;+0345;FIFO_BUFF PLACE:;0145
876 02 00 01
x=;+1129;y=;-0036;z=;+0099;FIFO_BUFF PLACE:;0146
882 02 00 01
x=;-0623;y=;-0121;z=;-0020;FIFO_BUFF PLACE:;0147
888 02 00 01
x=;-0628;y=;-0080;z=;-0018;FIFO_BUFF PLACE:;0148
894 02 00 01
x=;+0521;y=;-0082;z=;+0063;FIFO_BUFF PLACE:;0149
900 02 00 01
x=;-0241;y=;-1448;z=;+1031;FIFO_BUFF PLACE:;0150
906 02 00 01
x=;+2047;y=;-0921;z=;+0682;FIFO_BUFF PLACE:;0151
912 02 00 01
x=;+2047;y=;+0415;z=;+1833;FIFO_BUFF PLACE:;0152
918 02 00 01
x=;+2047;y=;-2048;z=;+0511;FIFO_BUFF PLACE:;0153
924 02 00 01
x=;+1380;y=;-1015;z=;+0595;FIFO_BUFF PLACE:;0154
930 02 00 01
x=;+1528;y=;+0004;z=;+0984;FIFO_BUFF PLACE:;0155
936 02 00 01
x=;+1796;y=;-1607;z=;+0746;FIFO_BUFF PLACE:;0156
942 02 00 01
x=;+1006;y=;-1972;z=;+1075;FIFO_BUFF PLACE:;0157
948 02 00 01
x=;+0676;y=;-0356;z=;+0234;FIFO_BUFF PLACE:;0158
954 02 00 01
x=;+0488;y=;-0136;z=;+0366;FIFO_BUFF PLACE:;0159
960 02 00 01
x=;+1087;y=;+0016;z=;+0411;FIFO_BUFF PLACE:;0160
966 02 00 01
x=;+0001;y=;-0047;z=;+0071;FIFO_BUFF PLACE:;0161
972 02 00 01
x=;+0443;y=;+0104;z=;+0416;FIFO_BUFF PLACE:;0162
978 02 00 01
x=;+1358;y=;+0185;z=;+0179;FIFO_BUFF PLACE:;0163
984 02 00 01
x=;+2047;y=;-0116;z=;+0223;FIFO_BUFF PLACE:;0164
990 02 00 01
x=;-0007;y=;+0120;z=;-0498;FIFO_BUFF PLACE:;0165
996 02 00 01
x=;+1536;y=;+0176;z=;+0568;FIFO_BUFF PLACE:;0166
1002 02 00 01
x=;+1471;y=;-0344;z=;+0939;FIFO_BUFF PLACE:;0167
1008 02 00 01
x=;+1748;y=;-0569;z=;+0699;FIFO_BUFF PLACE:;0168
1014 02 00 01
x=;+1831;y=;-2048;z=;+1734;FIFO_BUFF PLACE:;0169
1
0
JUST_STILL is true.
loop iteration= 20000002
X/Y/Z= -0.05/-0.02/1.21 Temp:73.18 Pin 13:0 STAT:E FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:513 loop:20000002 millis():17104
Reading Status Now
X/Y/Z= -0.03/-0.01/1.18 Temp:72.94 Pin 13:0 STAT:E FLTER_CTL:5 PWR_CTL:2 ACT_INACT_CTL:1F INTMAP2:40 FIFO_CTL:3 FIFO_SAMPLES:FF #FIFO:513 loop:30000000 millis():23797
typo
[edited by: iannecj at 10:51 AM (GMT -4) on 14 Oct 2020]
  • Here is code:
    #include <ADXL362.h>
    #define ADXL362_CS    5
    #define ADXL362_EINT  13
    volatile uint32_t i = 0;
    float x, y, z;
    int16_t  x16, y16, z16;
    float temp;
    unsigned char TEMP_L,TEMP_H;
    unsigned char ADXL_STATUS=0;
    unsigned char INTMAP2=0;
    unsigned char FILTER_CTL=0;
    unsigned char POWER_CTL=0;
    unsigned char ACT_INACT_CTL=0;
    unsigned char FIFO_CTL=0;
    unsigned char FIFO_SAMPLES=0;
    unsigned char FIFO_L=0;
    unsigned char FIFO_H=0;
    unsigned char FIFO_BUF[1024];
    unsigned char AWAKESTAT_LAST=0;
    unsigned char JUST_MOTION=0;
    unsigned char JUST_STILL=0;
    unsigned char pinStat=0;
    unsigned char watermark=3;
    uint16_t  FIFO_Total=0;
    void setup(void)
        Serial.begin(115200);
        SPI.begin();
        pinMode(13, INPUT); // esp32 pin connected to adxl362 INT2
        pinMode(16, OUTPUT); //esp32 led
        pinMode(17, OUTPUT); //esp32 led
        digitalWrite(16,HIGH);//low lights led
        digitalWrite(17,HIGH);
        adiAccelerometer.begin(ADXL362_CS, &SPI, ADXL362_EINT); //These should be pins on esp32 for CS and where interuppt is wired...
        adiAccelerometer.setRegisterValue(0x00, ADXL362_REG_FILTER_CTL, 1); //zero this out before it sets below
         // sets data rate.
        adiAccelerometer.setOutputRate(ADXL362_ODR_400_HZ); //Set 400Hz data rate
        // Activity threshold
        adiAccelerometer.setupActivityDetection(0x1F, 200, 2);
        //Configures inactivity detection.
        adiAccelerometer.setupInactivityDetection(0x1F, 175, 250);
        // map awake bit to Int2
        adiAccelerometer.setIntMap2(ADXL362_INTMAP2_AWAKE);
        adiAccelerometer.setRegisterValue(0x1F, ADXL362_REG_ACT_INACT_CTL, 1); //linked mode, referenced, act and inact enabled....means need to read status to clear
        //fifo setup...fifo status was default 0 before this command...now with this command it becomes 0x0B
        adiAccelerometer.fifoSetup(ADXL362_FIFO_TRIGGERED,0xFF,0);  //fifo triggered is enabled, middle number is waterMarkLvl - Specifies the number of samples to store in the FIFO., store temp ot nmo
        //adiAccelerometer.setRegisterValue(0x22, ADXL362_REG_POWER_CTL, 1); //ultra low noise mode, measurement mode
        // Waiting for the console to continue
        while (!Serial);
        Serial.println("STARTUP REGISTER READ JUST PRE MEASUREMENT MODE ");
        Serial.println("_____________________________________________________________________________ ");
        adxl362_info_status();
        Serial.println(" ");
        adiAccelerometer.setMeasurementMode();
        Serial.println("STARTUP REGISTER READ JUST POST MEASUREMENT MODE ");
    } // end setup
    void loop(void)
       // poll esp32 pin 13 which is wired to adxl362 INT2(Awake status)
       pinStat=digitalRead(13);
       //Light esp32 onboard light when awake
       if (pinStat) {
          digitalWrite(16,LOW);
        else {
    //look at awake pin state change...determine of just awoke (ACT) or just was still (INACT) based on AWAKE bit
    if (AWAKESTAT_LAST!=pinStat) {
       Serial.println(AWAKESTAT_LAST,DEC); //no state change
       Serial.println(pinStat,DEC); //no state change
       if (AWAKESTAT_LAST) {
                  JUST_MOTION=0;
                  JUST_STILL=1;
              else {
                    JUST_MOTION=1;
                    JUST_STILL=0;
       AWAKESTAT_LAST=pinStat;
        else {
    //we just went active, Awake just went one.  this section tries various timing and preconditions to read FIFO in order to catch motion trigger.
    if (JUST_MOTION) {
          Serial.println("JUST_MOTION is true.  ");
          printf("loop iteration= %d\n",i);
          Serial.println((ADXL_STATUS & ADXL362_STATUS_INACT),HEX);
          while (!(ADXL_STATUS & ADXL362_STATUS_INACT)) {
            adiAccelerometer.getRegisterValue(&ADXL_STATUS, ADXL362_REG_STATUS, 1);
            delay(10);
            Serial.println("Waiting for Inact bit to set ");
      Serial.println(" Read 512 (2-byte) samples, after reading that out into an array shift out any samples not part of a triplet measurement set off the front of the array (oldest)");
      //delay(500);
      adiAccelerometer.getFifoValue(FIFO_BUF,512);  // no shift in data read 512, AH set, fifosamples set to 00
    //we just went still (inact) and wake bit went to 0. clear out fifio buffer in esp32
    if (JUST_STILL) {
     Serial.println("JUST_STILL is true.  ");
     for (uint32_t k = 0; k < 1023; k++)   FIFO_BUF[k]=0; //clear all
    //if loop was just motion, print local fifo buffer inclusing looking at axes idnetifer bits at beginning to make sure we have comple 3 axis sample set and not any misalignment of samples
    if (JUST_MOTION ) {
        Serial.println("Print buffer also looking at axis identificaiton bits");
          for (uint32_t j = 0; j < 170 * 6; j+=6) {
                    //print a row of loop iteration number and the 3 samples for the following row axis identifiers
                    uint8_t xAddr = (FIFO_BUF[j+1] & 0xC0) >> 6;
                    uint8_t yAddr = (FIFO_BUF[j+3] & 0xC0) >> 6;
                    uint8_t zAddr = (FIFO_BUF[j+5] & 0xC0) >> 6;
                    printf("%u %02x %02x %02x\r\n", j, xAddr, yAddr, zAddr);
                    //now print row of values after stripping off axis identifers
                    int16_t x1 = convertFIFOdata(FIFO_BUF[j+1], FIFO_BUF[j]);
                    int16_t y1 = convertFIFOdata(FIFO_BUF[j+3], FIFO_BUF[j+2]);
                    int16_t z1 = convertFIFOdata(FIFO_BUF[j+5], FIFO_BUF[j+4]);
                    printf("x=;%+05d;y=;%+05d;z=;%+05d;FIFO_BUFF PLACE:;0%d\r\n",x1,y1,z1,j/6);
          if (!(i%10000000)) {
                  Serial.println(" Reading Status Now ");
    JUST_MOTION=0;
    JUST_STILL=0;
    ++i;
    ////End Main loop
    void adxl362_info() {
        adiAccelerometer.getGxyz(&x, &y, &z);
              adiAccelerometer.getXyz(&x16, &y16, &z16);
              temp = adiAccelerometer.readTemperature();
         //   adiAccelerometer.getRegisterValue(&ADXL_STATUS, ADXL362_REG_STATUS, 1);
              adiAccelerometer.getRegisterValue(&INTMAP2, ADXL362_REG_INTMAP2, 1);
              adiAccelerometer.getRegisterValue(&FILTER_CTL, ADXL362_REG_FILTER_CTL, 1);
              adiAccelerometer.getRegisterValue(&POWER_CTL, ADXL362_REG_POWER_CTL, 1);
              adiAccelerometer.getRegisterValue(&ACT_INACT_CTL, ADXL362_REG_ACT_INACT_CTL, 1);
              adiAccelerometer.getRegisterValue(&FIFO_CTL, ADXL362_REG_FIFO_CTL, 1);
              adiAccelerometer.getRegisterValue(&FIFO_SAMPLES, ADXL362_REG_FIFO_SAMPLES, 1);
              adiAccelerometer.getRegisterValue(&FIFO_H, ADXL362_REG_FIFO_H, 1);
              adiAccelerometer.getRegisterValue(&FIFO_L, ADXL362_REG_FIFO_L, 1);
              FIFO_Total=((FIFO_H & 0xFF) << 8) | FIFO_L;
              Serial.print(" X/Y/Z =  ");
              Serial.print(x);
              Serial.print(" / ");
              Serial.print(y);
              Serial.print(z);
              Serial.print(" Temp: ");
              Serial.print(temp);
              Serial.print(" Pin 13: ");
              Serial.print(digitalRead(13));
      //      Serial.print(" STAT: ");
      //      Serial.print(ADXL_STATUS,HEX);
              Serial.print(" FILTER_CTL: ");
              Serial.print(FILTER_CTL,HEX);
              Serial.print(" POWER_CTL: ");
              Serial.print(POWER_CTL,HEX);
              Serial.print(" ACT_INACT_CTL: ");
              Serial.print(ACT_INACT_CTL,HEX);
              Serial.print(" INTMAP2: ");
              Serial.print(INTMAP2,HEX);
              Serial.print(" FIFO_CTL: ");
              Serial.print(FIFO_CTL,HEX);
              Serial.print(" FIFO_SAMPLES: ");
              Serial.print(FIFO_SAMPLES,HEX);
              Serial.print(" # in FIFO: ");
              Serial.print(FIFO_Total,DEC);
              Serial.print(" loop: ");
              Serial.println(i,DEC);
    void adxl362_info_status() {
            Serial.print("X/Y/Z= ");
            Serial.print(x);
            Serial.print("/");
            Serial.print(y);
            Serial.print("/");
            Serial.print(z);
            Serial.print(" Temp:");
            Serial.print(temp);
            Serial.print(" Pin 13:");
            Serial.print(" STAT:");
            Serial.print(" FLTER_CTL:");
            Serial.print(" PWR_CTL:");
            Serial.print(" ACT_INACT_CTL:");
            Serial.print(" INTMAP2:");
            Serial.print(" FIFO_CTL:");
            Serial.print(" FIFO_SAMPLES:");
            Serial.print(" #FIFO:");
            Serial.print(" loop:");
            Serial.print(i,DEC);
            Serial.print(" millis():");
            Serial.println(millis(),DEC);
    // convert fifo sample to unsigned int
    int16_t convertFIFOdata(uint8_t hiByte, uint8_t loByte)
        //mask off id bits, combine low byte
        int16_t q = ((hiByte & 0x3F) << 8) | loByte;
        // get sign bits, copy into B15, B14, combine
        q = ((q & 0x3000) << 2) | q;
        return(q);
     * @brief Reads multiple bytes from the device's Ffifo buffer.
     * @param pBuffer     - Stores the read bytes.
     * @param samples - Number of sanmples to read to read.
     * @return None.
    void ADXL362::getFifoValue(unsigned char* pBuffer, uint16_t samples)
        unsigned char  buffer[1028];//Modifed by crhis this was 512 but thats not big enough since equal of 170 3 axis samples is 2 bytes.
        uint16_t index = 0;
        buffer[0] = ADXL362_WRITE_FIFO;
         for(index = 0; index < samples*2; index++)
             buffer[index + 1] = pBuffer[index];
        SPI_read(ADXL362_SLAVE_ID, buffer, samples*2);
            pBuffer[index] = buffer[index + 3];
