I would like to know what the tolerances are for the internal 400K pull-ups on the of OT and UT pins of the LTC2996.
I would like to tie these pins to the over-voltage pin of the LTC3351 but the pull-ups will affect the resistor divider setting my over-voltage threshold. If the tolerances of the pull-ups are small enough, I may be able to use this approach.
Also, the LTC2996 datasheet shows diodes in series with the pull-ups. Can you provide me with any information on their forward voltage drop and tolerance?
Wayne
