Want to use an ADXL103 and use a magnet to attach it. Will the field have any effect on the response?
ADXL103
Recommended for New Designs
The ADXL103 is a high precision, low power, complete single-axis accelerometer with signal conditioned voltage outputs, all on a single, monolithic IC...
Datasheet
ADXL103 on Analog.com
Hi dfl,
Thank you for your query. While we don't describe the accelerometer behaviors in magnetic fields, the feedback from our users suggest that they can withstand these environments. Even though that these not pose problems for the accelerometers, you may want to check its effects with the supplies, reference voltages and signal conditioning circuits. Hope this helps.
Best Regards,
John
