ADXL 363 external clock
Hi
In my current project, ADXL363 is used to measure 3-axis movement. I found that the internal clock is not accurate enough. The data sheet mentions that external clock can be used to improve the sampling timing accuracy. Pin INT1 can be set external clock input, my question is can I directly connect a crystal (for example, 40kHz) to that pin and other pin of crystal connects to GND?
Thanks
