Hello
Above image has all burst read data and 16 and 17 index has CRC values. Adis16495 has an example , when i calculate that data i got right CRC and when i calculate above image data i am getting wrong calculated CRC.
And i am using below function to calculate CRC. From this i getting right CRC if i take example data which is present ADIS16495 datasheet. If i calculate above image data i am getting wrong calculated CRC.
uint32_t rc_crc32(uint32_t crc, const char *buf, size_t len){static uint32_t table[256];static int have_table = 0;uint32_t rem;uint8_t octet;int i, j;const char *p, *q;/* This check is not thread safe; there is no mutex. */if (have_table == 0) {/* Calculate CRC table. */for (i = 0; i < 256; i++) {rem = i; /* remainder from polynomial division */for (j = 0; j < 8; j++) {if (rem & 1) {rem >>= 1;rem ^= 0xedb88320;} elserem >>= 1;}table[i] = rem;}have_table = 1;}crc = ~crc;q = buf + len;for (p = buf; p < q; p++) {octet = *p; /* Cast to unsigned octet. */crc = (crc >> 8) ^ table[(crc & 0xff) ^ octet];}return ~crc;}
