ADXL185B SPI data output rate
hello,
In the datasheet, it is said that DATARDY status flag is designed to assist with synchronous data sampling at 32kHz. I am using SPI protocol and this device can communicate via both PSI5 v1.3 and SPI protocols. Does this 32 kHz data output rate is valid for both protocols? Because I could not find any specific data output rate for SPI protocol. Also I have another question. Datasheet says when interpolation is disabled data rate will be update to 32 kHz. Does this option only affect PSI5 because while I was using SPI, I tried both options (enabling and disabling interpolation) but my sampling speed did not change.
Any help will be appreciated.
