I've been experiencing an issue on adrv9009 with zcu102.
The problem involves LO leakage when adjusting the TX attenuation.
I'm operating at an LO frequency of 900 MHz. Initially, with a 10 dB attenuation setting, the LO leakage measured -74 dBm. After increasing the attenuation to 27 dB and recalibrating, the LO leakage increased to -65 dBm.
I've attached images showing the issue. Could you please help me understand why this is happening and how to address it?
This issue was happening on 2400MHz as well.
I wanted to ask if you can show me the scheme where the attenuation placed before the mixer or after?
10dB attenuation => lo leakage on 900MHz = -74dBm
27dB attenuation 900MHz lo leakage = -65dBm
