Does the ADF7024 provide support for an external LNA and PA?
Can I use an external LNA and PA  with the ADF7024? If so what support does the ADF7024 provide in terms of control signals for the external LNA and PA?
    on Jul 23, 2014 3:52 PM
    Yes,  the ADF7024 provides independent control signals for an external PA or LNA.
    If the EXT_PA_EN bit is set to 1 in the RADIO_CONTROL register (Address 0x11A), the external PA control signal is logic high while the ADF7024 is in the PHY_TX state and logic low while in any other state.
    If the EXT_LNA_EN bit is set to 1 in the RADIO_CONTROL register (Address 0x11A), the external LNA control signal is logic high while the ADF7024 is in the PHY_RX state and logic low while in any other state.
    The external PA and LNA control signals can be configured using the EXT_PA_LNA_ATB_CONFIG setting (Address 0x139, Bit[7]) as described below:
    EXT_PA_LNA_ ATB_CONFIG = 1:
    ADCIN_ATB3 and ATB4 used for control of external PA and external LNA, respectively (1.8 V logic outputs).
    EXT_PA_LNA_ ATB_CONFIG = 0:
    GP5_ATB1 and ATB2 used for control of external PA and external LNA, respectively (VDD logic outputs).
    on May 8, 2019 10:42 AM
    This question has been closed by the EZ team and is assumed answered.
