I have a question about ADF7023-J.
Are there any specifications regarding the voltage level required for the crystal oscillator used in the ADF7023-J?
Hi.
If you'll be using a crystal oscillator between XOSC26P and XOSC26N, which is what is recommended, then voltage level is not necessary. The parameters that need to be satisfied are provided below, which is in the datasheet.
edwinu
Thank you for your comment.
But my explanation wasn't enough.
I want to use the TCXO between the XOSC26P and XOSC26N, so I want to know the voltage level.
Best Regards,
There's no reference design that uses a TCXO with the ADF7023J. The only information available is to AC couple the TCXO before connecting to XOSC26N. XOSC26P must be left open or unconnected. Note that the recommendation is to use a crystal oscillator. If you have further queries, please contact our local ADI sales office.
edwinu
