EV-ADF70301-868BZ configured vs. 902 MHz to 928 MHz
Hi Community,
In ADF70301-1 Data Sheet Rev. 0,
Page 15:
863 MHz to 876 MHz
Unless otherwise noted, the configurations detailed in Table 12 are used to specify the performance of the ADF7030-1 in Table 13. All measurements are performed on the EV-ADF70301-868BZ evaluation board, unless otherwise noted. ...
Page 17:
902 MHz to 928 MHz section
Unless otherwise noted, the configurations detailed in Table 14 are used to specify the performance of the ADF7030-1 in Table 15. All measurements are performed on the EV-ADF70301-868BZ evaluation board, unless otherwise noted. ...
Question:
Why both 868 MHz and 915 MHz Configuration data are based on "EV-ADF70301-868BZ" board?  Does this mean that the EV-ADF70301-868BZ board design is good for both "863 MHz to 876 MHz" and "902 MHz to 928 MHz" band operations?
regards,
ping
