IIO question with AD9361
I'm starting with the ad9361-iiostream.c example and am trying to get the receiver's RSSI and gain status, but seem to be unable to 'find' the attribute.
I've tried to get it a few ways and nothing seems to work
1) iio_device_attr_read_double () from the ad9361-phy and channel voltage 0 asking for attribute "rssi"
2) iio_device_attr_read_double () from the ad9361-phy and channel voltage 0 asking for attribute "rssi"
3) iio_channel_attr_read_double () from cf-ad9361-A and channel voltage 0 asking for attribute "rssi"
I've been trying to rely on iio_info to tell me what are the valid current device/channel/attribute combinations but it seems not to be helping.
What am I missing?  Is there a good primer that would help?
Thanks!
    1) and 2) look the same to me
    Here is some sample code that reads the IRSSI:
    #include <iio.h>
    #include <stdio.h>
    int main(void)
        double value;
        struct iio_context *ctx = iio_create_default_context();
        struct iio_device *dev = iio_context_find_device(ctx, "ad9361-phy");
        struct iio_channel *ch = iio_device_find_channel(dev, "voltage0", false);
        int ret = iio_channel_attr_read_double(ch, "rssi", &value);
        if (ret < 0)
            printf("Unable to read RSSI: %i\n", ret);
        else
            printf("RSSI: %f\n", value);
        iio_context_destroy(ctx);
        return 0;
    So 3) was right, but you used the wrong device (cf-ad9361-A instead of ad9361-phy).
    -Paul
