Can't read data from AD7793 with Linux driver
I have a similar problem.
.modalias = "ad7793",
.max_speed_hz = 1000000,
.bus_num = 0,
.chip_select = 0,
.platform_data = &ad7793_pdata,
.mode = SPI_MODE_3,
.irq = gpio_to_irq(9), // Raspberry Pi SPI0_MISO is GPIO9.
cat /sys/bus/iio/devices/iio\:device0/name
I get "ad7793".
But
cat in_voltage0-voltage0_raw // connect 0.5v
cat in_voltage1-voltage1_raw // null
cat in_voltage2-voltage2_raw // null
I always get the same thing(7502040).
Parents
  • Raspberry Pi 2 B/Linux kernel 4.9.x:
    I use
    linux/ad7793.c at xcomm_zynq_4_9 · analogdevicesinc/linux · GitHub
    and ad7793-overlay.dts.
    * Device Tree overlay for ad7793
    /dts-v1/;
    /plugin/;
    compatible = "brcm,bcm2835", "brcm,bcm2708", "brcm,bcm2709";
    fragment@0 {
    target = <&spi0>;
    __overlay__ {
    status = "okay";
    fragment@1 {
    target = <&spidev0>;
    __overlay__ {
    status = "disabled";
    fragment@2 {
    target = <&spidev1>;
    __overlay__ {
    fragment@3 {
    target = <&gpio>;
    __overlay__ {
    ad7793_pins: ad7793_pins {
    brcm,pins = <25>;
    brcm,function = <0>;
    brcm,pull = <2>;
    fragment@4 {
    target = <&spi0>;
    __overlay__ {
    /* needed to avoid dtc warning */
    #address-cells = <1>;
    #size-cells = <0>;
    ad7793: ad-7793@0{
    compatible = "adi,ad7793";
    reg = <0>;
    pinctrl-names = "default";
    pinctrl-0 = <&ad7793_pins>;
    spi-max-frequency = <1000000>;
    interrupts = <25 2>; /* high-to-low edge triggered */
    interrupt-parent = <&gpio>;
    I get
    ad7793 spi0.0:device ID query failed
    ad7793 spi0.0:setup failed
    I don't know how to solve.
Reply
    I use
    /dts-v1/;
    /plugin/;
    fragment@0 {
    target = <&spi0>;
    __overlay__ {
    status = "okay";
    fragment@1 {
    __overlay__ {
    fragment@2 {
    __overlay__ {
    fragment@3 {
    target = <&gpio>;
    __overlay__ {
    brcm,pins = <25>;
    brcm,pull = <2>;
    fragment@4 {
    target = <&spi0>;
    __overlay__ {
    #size-cells = <0>;
    ad7793: ad-7793@0{
    reg = <0>;
    I get
Children
No Data
