Unwanted output signal when Linux boots up
Hello everyone,
(PicoZed SDR + breakout carrier + kernel v4.6.0)
Every time I boot up the platform, when kernel is loading and until I execute my program, some signal appears at the TX output:
Why? How to solve it? I suspect it could be the oscilloscope application auto-starting up, maybe? (PicoZed doesnt allow to connect a monitor nor I cant see any oscilloscope related process using htop), if so.. where's the script that autoexecutes it?
And also: when I want to finish my custom program with CTRL+C, I've got a handler that destroys the iio_context, iio_buffers, etc. but when they are destroyed, the radio starts transmitting some undesired signal. I solved this configuring the TX attenuation ("out_voltage0_hardwaregain") to its maximum before exiting the program, but it does not look like the right way to do it. Any suggestion?
Leroy.
Parents Reply
  • I have built many time my uImage and Devicetree followig below steps:
    Note:
    Make sure all steps must perform in same terminal, if you will change the terminal that may cause error.
    Step 1:
    Download the available linux default folder from
    $ git clone https://github.com/analogdevicesinc/linux.git
    or
    https://wiki.analog.com/resources/tools-software/linux-build/generic/zynq?s[]=linux&s[]=image
    Step2 :
    $ cd linux
    $ git checkout 2018_R2
    Step3:
    Change the file according to your requirement for examples:
    I have changed:
    cf_axi_dds_datasel(st, -1, DATA_SEL_DDS); with cf_axi_dds_datasel(st, -1, DATA_SEL_DMA);
    Following the link:
    https://ez.analog.com/linux-device-drivers/linux-software-drivers/f/q-a/87443/unwanted-output-signal-when-linux-boots-up/157566#157566
    I have changed the default frequency and LO:
    Following:
    https://ez.analog.com/linux-device-drivers/linux-software-drivers/f/q-a/117841/how-to-change-default-power-up-value--ad9361
    Step3:
    export ARCH=arm
    export CROSS_COMPILE=arm-linux-gnueabihf-
    source /opt/Xilinx/Vivado/2018.2/settings64.sh
    Step4:
    Download the hopper.patch and keep this file outside to the linux file
    like :
    https://github.com/analogdevicesinc/MathWorks_tools/blob/master/targeting_models/frequency-hopping/hopper.patch
    Step5:
    $ cp ../hopper.patch .
    $ make zynq_xcomm_adv7511_defconfig
    $ make -j12 UIMAGE_LOADADDR=0x8000 uImage
    Note:
    If you are making for first time then you need to install :
    $ sudo apt-get install u-boot-tools
    Note:
    -j12 in my case:
    you can check number of processor by:
    $ grep -c ^processor /proc/cpuinfo
    Step6:
    Build devicetree.dtb file
    $ make zynq-adrv9361-z7035-fmc.dtb
    The device tree name will be according to your board but you can change it with devicetree.dtb
    make according to your board following the link below:
    Step7:
    Copy the devicetree.dtb and uImge to you SD Card.
    I have built devicetree.dtb and uImge but display never shows. Although I have check it thorugh serial terminal (putty) registers got updated correctly.
    When I change only default uImge with my updated uImge then display shows but register did not update.
    I thin my steps to build devicetree.dtb is not correct.
    I have build simply without changing the files from linux folder. and coped the devicetree.dtb and uImge to SD card but still no display. If I copy Only uImge it shows disply successfully. please help me how I can build devicetree.dtb successfully.?
Children
No Data
