AD5274 userspace driver
We are using the ad5274 device to control an LCD contrast pin. I have successfully instantiated the ad5274 linux driver. The driver exposes a couple of files in /sys/bus/i2c/devices/000-02c. The files of note are rdac0, otp0en, and otp0. I can't find any documentation that explains how someone is to use these files to program the ad5274 device. Any help?
  • The data read back is always the same. So when I send in via "echo 1 > rdac0" then cat rdac0 is get 4. If I then continue to "cat rdac0" I receive 4.
    At this point it is really not important because the hardware guys have design out this part.
    Thanks for the help.
    on Feb 22, 2016 8:53 AM
    Hi Michael,
    Sorry for the delay - we tested the AD5272/5274 support using a AD5272 which always worked flawless.
    In fact there is typo which caused the AD5274 read-back problems.
    A fix was send mainline:
    LKML: <michael.hennerich@analog ...: [PATCH] drivers/misc/ad525x_dpot: AD5274 fix RDAC read back errors
    Testing:
    root@linaro-ubuntu-desktop:~# cd /sys/bus/i2c/devices/0-002f/
    root@linaro-ubuntu-desktop:/sys/bus/i2c/devices/0-002f# ls -al
    total 0
    drwxr-xr-x 3 root root    0 Jan  1  1970 .
    drwxr-xr-x 6 root root    0 Jan  1  1970 ..
    lrwxrwxrwx 1 root root    0 Feb 22 09:36 driver -> ../../../../../../bus/i2c/drivers/ad_dpot
    -r--r--r-- 1 root root 4096 Feb 22 09:36 modalias
    -r--r--r-- 1 root root 4096 Feb 22 09:36 name
    lrwxrwxrwx 1 root root    0 Feb 22 09:36 of_node -> ../../../../../../firmware/devicetree/base/amba/i2c@e0004000/ad5172@2f
    -rw-r--r-- 1 root root 4096 Feb 22 09:36 otp0
    -rw-r--r-- 1 root root 4096 Feb 22 09:36 otp0en
    drwxr-xr-x 2 root root    0 Feb 22 09:36 power
    -rw-r--r-- 1 root root 4096 Feb 22 09:36 rdac0
    lrwxrwxrwx 1 root root    0 Jan  1  1970 subsystem -> ../../../../../../bus/i2c
    -rw-r--r-- 1 root root 4096 Jan  1  1970 uevent
    root@linaro-ubuntu-desktop:/sys/bus/i2c/devices/0-002f# grep "" *
    modalias:i2c:ad5274
    otp0:42
    otp0en:disabled
    rdac0:42
    uevent:DRIVER=ad_dpot
    uevent:OF_NAME=ad5172
    uevent:OF_FULLNAME=/amba/i2c@e0004000/ad5172@2f
    uevent:OF_COMPATIBLE_0=ad5274
    uevent:OF_COMPATIBLE_N=1
    uevent:MODALIAS=i2c:ad5274
    root@linaro-ubuntu-desktop:/sys/bus/i2c/devices/0-002f# for i in `seq 0 255`; do echo $i > rdac0;cat rdac0; done;
    0
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    [ --snip-- ]
    240
    241
    242
    243
    244
    245
    246
    247
    248
    249
    250
    251
    252
    253
    254
    255
    -Michael
