Hi All!
I have a problems with add a new devices to the Linux system based on the BF532.
Now I want to add iio-sysfs-trigger for generate the clock for external IIO ADC.
I need to make the follow steps(as I see in the http://wiki.analog.com/software/linux/d ... trig-sysfs site):
1) Add "SYSFS trigger" in the kernel configuration by the "menuconfig"
2) Add follow code to the board device file (*.c) :
static struct platform_deviceiio_sysfs_trigger = {
.name = "iio_sysfs_trigger",
.id = 0,
.dev = {
.platform_data = NULL,
static struct platform_device *board_devices[] __initdata = {
&iio_sysfs_trigger,
static int __init board_init(void)
[--snip--]
platform_add_devices(board_devices, ARRAY_SIZE(board_devices));
[--snip--]
return 0;
But this is only example for abstract platform.
How I should change this code for BF532 for correct work the sysfs-trigger.
I mean what declarated function(for replace "platform_add_devices()" in example) and struct(for replace "platform device" in example) I should use for add new device to the system.
I think asnwer will helpfull for all peoples who has a problem to add any new devices to the platform.
