TX_baseband
Product Number: adrv9361
Software Version: petalinux2023.2
I am using petalinux2023.2 on adrv9361 board.
I added meta-adi-2023_r2 layer and used
KERNEL_DTB="zynq-adrv9361-z7035-bob-cmos"
and build successfully project, with this image I am able to configure TX LO and RX LO
I observer ADC baseband signal in ILA.
now I am forcing DDS SIgnal to IQ DAC FIFO to mix with TX LO, but TX LO is not shifting. and observer DAC_EN pin in ILA DAC_EN pin is also low.
do I need to add a different DTB file for TX path?
    what are you trying to accomplish? Do you just want to send a test tone using the internal DDS? Note that DAC_EN only goes high when the DAC channel data source register is set to DMA. How are you trying to send the DDS signal? Are you using osc? libiio? raw sysfs writes?
    AFAICT, You should not need a different DT
    - Nuno Sá
  • I connected 32 bit DDS in block diagram. And used slicer fed 16 16 bits to dac_fifo din_data_0 and din_data_1. connected constant 1 to din_valid_in<0:3>. and observing dac_fifo output parameters like dout_valid and dout_data in ILA. I am getting no data at dac_fifo output also dout_valid is also low. Later a custom IP has to provide data to dac_fifo.DDS_DAC_interface
  • in this link i see similar issue in https://ez.analog.com/linux-software-drivers/f/q-a/87426/set-dds-driver-to-dma-mode.
    as suggested in this post I set /sys/bus/iio/devices/iio:device2/scan_elements/out_voltage0_en = 1
    and /sys/bus/iio/devices/iio:device2/buffer/enable =1
    but I am not getting dac_enable 1
    in baremetal code I set DAC data source as DMA as
    dac_init(ad9361_phy. DATA_SEL_DMA,1)
    with this change I saw dac_enable 1 in ILA.
    now I need to fugure out how to set dac_enable 1 in petalinux2023.2
  • now I need to fugure out how to set dac_enable 1 in petalinux2023.2
    I don't think that's nothing to do with petalinux. AFAIK, that signal should go high when you set DMA as the source. How many txs do you have and buffers? Are you sure you doing the buffer enabled in the proper place? Can you run `iio_info` on the board?
    Can you also check `dmesg` to see if any error comes out of those commands?
    - Nuno Sá
  • iio_info version: 0.26 (git tag:5e1e9cb5)
    Libiio version: 0.26 (git tag: 5e1e9cb) backends: local xml ip usb serial
    IIO context created with local backend.
    Backend version: 0.26 (git tag: 5e1e9cb)
    Backend description string: Linux adrv1 6.1.70adi-v2023.2 #1 SMP PREEMPT Fri Oct 10 09:16:22 UTC 2025 armv7l
    IIO context has 2 attributes:
    	local,kernel: 6.1.70adi-v2023.2
    	uri: local:
    IIO context has 5 devices:
    	hwmon0: e000b000ethernetffffffff00
    		1 channels found:
    			temp1:  (input)
    			3 channel-specific attributes found:
    				attr  0: crit value: 100000
    				attr  1: input value: 47000
    				attr  2: max_alarm value: 0
    		No trigger on this device
    	iio:device0: ad9361-phy
    		11 channels found:
    			altvoltage1: TX_LO (output)
    			9 channel-specific attributes found:
    				attr  0: external value: 0
    				attr  1: fastlock_load value: 0
    				attr  2: fastlock_recall ERROR: Invalid argument (22)
    				attr  3: fastlock_save value: 0 175,143,231,151,159,135,135,7,135,135,135,143,143,135,167,223
    				attr  4: fastlock_store value: 0
    				attr  5: frequency value: 2450000000
    				attr  6: frequency_available value: [46875001 1 6000000000]
    				attr  7: label value: TX_LO
    				attr  8: powerdown value: 0
    			voltage1:  (output)
    			10 channel-specific attributes found:
    				attr  0: filter_fir_en value: 0
    				attr  1: hardwaregain value: -10.000000 dB
    				attr  2: hardwaregain_available value: [-89.750000 0.250000 0.000000]
    				attr  3: rf_bandwidth value: 18000000
    				attr  4: rf_bandwidth_available value: [200000 1 40000000]
    				attr  5: rf_port_select value: A
    				attr  6: rf_port_select_available value: A B
    				attr  7: rssi value: 0.00 dB
    				attr  8: sampling_frequency value: 30720000
    				attr  9: sampling_frequency_available value: [2083333 1 30720000]
    			voltage0:  (input)
    			15 channel-specific attributes found:
    				attr  0: bb_dc_offset_tracking_en value: 1
    				attr  1: filter_fir_en value: 0
    				attr  2: gain_control_mode value: slow_attack
    				attr  3: gain_control_mode_available value: manual fast_attack slow_attack hybrid
    				attr  4: hardwaregain value: 71.000000 dB
    				attr  5: hardwaregain_available value: [-3 1 71]
    				attr  6: quadrature_tracking_en value: 1
    				attr  7: rf_bandwidth value: 18000000
    				attr  8: rf_bandwidth_available value: [200000 1 56000000]
    				attr  9: rf_dc_offset_tracking_en value: 1
    				attr 10: rf_port_select value: A_BALANCED
    				attr 11: rf_port_select_available value: A_BALANCED B_BALANCED C_BALANCED A_N A_P B_N B_P C_N C_P TX_MONITOR1 TX_MONITOR2 TX_MONITOR1_2
    				attr 12: rssi value: 117.00 dB
    				attr 13: sampling_frequency value: 30720000
    				attr 14: sampling_frequency_available value: [2083333 1 30720000]
    			voltage1:  (input)
    				attr 12: rssi value: 116.75 dB
    			voltage3:  (output)
    			8 channel-specific attributes found:
    				attr  1: raw value: 306
    				attr  2: rf_bandwidth value: 18000000
    				attr  3: rf_bandwidth_available value: [200000 1 40000000]
    				attr  4: rf_port_select_available value: A B
    				attr  5: sampling_frequency value: 30720000
    				attr  6: sampling_frequency_available value: [2083333 1 30720000]
    				attr  7: scale value: 1.000000
    			altvoltage0: RX_LO (output)
    				attr  3: fastlock_save value: 0 33,49,32,33,33,158,229,33,33,33,33,33,33,209,45,147
    				attr  5: frequency value: 2400000000
    				attr  6: frequency_available value: [70000000 1 6000000000]
    				attr  7: label value: RX_LO
    			voltage2:  (output)
    			temp0:  (input)
    			1 channel-specific attributes found:
    				attr  0: input value: 45614
    			voltage0:  (output)
    			voltage2:  (input)
    			13 channel-specific attributes found:
    				attr  2: gain_control_mode_available value: manual fast_attack slow_attack hybrid
    				attr  3: offset value: 57
    				attr  4: quadrature_tracking_en value: 1
    				attr  5: raw value: 197
    				attr  6: rf_bandwidth value: 18000000
    				attr  7: rf_bandwidth_available value: [200000 1 56000000]
    				attr  8: rf_dc_offset_tracking_en value: 1
    				attr  9: rf_port_select_available value: A_BALANCED B_BALANCED C_BALANCED A_N A_P B_N B_P C_N C_P TX_MONITOR1 TX_MONITOR2 TX_MONITOR1_2
    				attr 10: sampling_frequency value: 30720000
    				attr 11: sampling_frequency_available value: [2083333 1 30720000]
    				attr 12: scale value: 0.305250
    			out:  (input, WARN:iio_channel_get_type()=UNKNOWN)
    				attr  0: voltage_filter_fir_en value: 0
    		19 device-specific attributes found:
    				attr  0: calib_mode value: auto
    				attr  1: calib_mode_available value: auto manual manual_tx_quad tx_quad rf_dc_offs rssi_gain_step
    				attr  2: dcxo_tune_coarse ERROR: No such device (19)
    				attr  3: dcxo_tune_coarse_available value: [0 0 0]
    				attr  4: dcxo_tune_fine ERROR: No such device (19)
    				attr  5: dcxo_tune_fine_available value: [0 0 0]
    				attr  6: ensm_mode value: fdd
    				attr  7: ensm_mode_available value: sleep wait alert fdd pinctrl pinctrl_fdd_indep
    				attr  8: filter_fir_config value: FIR Rx: 0,0 Tx: 0,0
    				attr  9: gain_table_config value: <gaintable AD9361 type=FULL dest=3 start=1300000000 end=4000000000>
    -3, 0x00, 0x00, 0x20
    -3, 0x00, 0x00, 0x00
    -2, 0x00, 0x01, 0x00
    -1, 0x00, 0x02, 0x00
    0, 0x00, 0x03, 0x00
    1, 0x00, 0x04, 0x00
    2, 0x00, 0x05, 0x00
    3, 0x01, 0x03, 0x20
    4, 0x01, 0x04, 0x00
    5, 0x01, 0x05, 0x00
    6, 0x01, 0x06, 0x00
    7, 0x01, 0x07, 0x00
    8, 0x01, 0x08, 0x00
    9, 0x01, 0x09, 0x00
    10, 0x01, 0x0A, 0x00
    11, 0x01, 0x0B, 0x00
    12, 0x01, 0x0C, 0x00
    13, 0x01, 0x0D, 0x00
    14, 0x01, 0x0E, 0x00
    15, 0x02, 0x09, 0x20
    16, 0x02, 0x0A, 0x00
    17, 0x02, 0x0B, 0x00
    18, 0x02, 0x0C, 0x00
    19, 0x02, 0x0D, 0x00
    20, 0x02, 0x0E, 0x00
    21, 0x02, 0x0F, 0x00
    22, 0x02, 0x10, 0x00
    23, 0x02, 0x2B, 0x20
    24, 0x02, 0x2C, 0x00
    25, 0x04, 0x27, 0x20
    26, 0x04, 0x28, 0x00
    27, 0x04, 0x29, 0x00
    28, 0x04, 0x2A, 0x00
    29, 0x04, 0x2B, 0x00
    30, 0x24, 0x21, 0x20
    31, 0x24, 0x22, 0x00
    32, 0x44, 0x20, 0x20
    33, 0x44, 0x21, 0x00
    34, 0x44, 0x22, 0x00
    35, 0x44, 0x23, 0x00
    36, 0x44, 0x24, 0x00
    37, 0x44, 0x25, 0x00
    38, 0x44, 0x26, 0x00
    39, 0x44, 0x27, 0x00
    40, 0x44, 0x28, 0x00
    41, 0x44, 0x29, 0x00
    42, 0x44, 0x2A, 0x00
    43, 0x44, 0x2B, 0x00
    44, 0x44, 0x2C, 0x00
    45, 0x44, 0x2D, 0x00
    46, 0x44, 0x2E, 0x00
    47, 0x44, 0x2F, 0x00
    48, 0x44, 0x30, 0x00
    49, 0x44, 0x31, 0x00
    50, 0x64, 0x2E, 0x20
    51, 0x64, 0x2F, 0x00
    52, 0x64, 0x30, 0x00
    53, 0x64, 0x31, 0x00
    54, 0x64, 0x32, 0x00
    55, 0x64, 0x33, 0x00
    56, 0x64, 0x34, 0x00
    57, 0x64, 0x35, 0x00
    58, 0x64, 0x36, 0x00
    59, 0x64, 0x37, 0x00
    60, 0x64, 0x38, 0x00
    61, 0x65, 0x38, 0x20
    62, 0x66, 0x38, 0x20
    63, 0x67, 0x38, 0x20
    64, 0x68, 0x38, 0x20
    65, 0x69, 0x38, 0x20
    66, 0x6A, 0x38, 0x20
    67, 0x6B, 0x38, 0x20
    68, 0x6C, 0x38, 0x20
    69, 0x6D, 0x38, 0x20
    70, 0x6E, 0x38, 0x20
    71, 0x6F, 0x38, 0x20
    </gaintable>
    				attr 10: multichip_sync ERROR: Permission denied (13)
    				attr 11: rssi_gain_step_error value: lna_error: 0 0 0 0
    mixer_error: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    gain_step_calib_reg_val: 0 0 0 0 0
    				attr 12: rx_path_rates value: BBPLL:983040000 ADC:245760000 R2:122880000 R1:61440000 RF:30720000 RXSAMP:30720000
    				attr 13: trx_rate_governor value: nominal
    				attr 14: trx_rate_governor_available value: nominal highest_osr
    				attr 15: tx_path_rates value: BBPLL:983040000 DAC:245760000 T2:122880000 T1:61440000 TF:30720000 TXSAMP:30720000
    				attr 16: waiting_for_supplier value: 0
    				attr 17: xo_correction value: 40000000
    				attr 18: xo_correction_available value: [39992000 1 40008000]
    		183 debug attributes found:
    				debug attr  0: digital_tune value: 0
    				debug attr  1: calibration_switch_control value: 0
    				debug attr  2: multichip_sync value: 0
    				debug attr  3: gaininfo_rx2 value: 71 76 0 0 0 0 0 0
    				debug attr  4: gaininfo_rx1 value: 71 76 0 0 0 0 0 0
    				debug attr  5: bist_timing_analysis value: 0
    				debug attr  6: gpo_set value: 0
    				debug attr  7: bist_tone value: 0
    				debug attr  8: bist_prbs value: 0
    				debug attr  9: loopback value: 0
    				debug attr 10: initialize value: 0
    				debug attr 11: adi,bb-clk-change-dig-tune-enable value: 0
    				debug attr 12: adi,axi-half-dac-rate-enable value: 0
    				debug attr 13: adi,txmon-2-lo-cm value: 48
    				debug attr 14: adi,txmon-1-lo-cm value: 48
    				debug attr 15: adi,txmon-2-front-end-gain value: 2
    				debug attr 16: adi,txmon-1-front-end-gain value: 2
    				debug attr 17: adi,txmon-duration value: 8192
    				debug attr 18: adi,txmon-delay value: 511
    				debug attr 19: adi,txmon-one-shot-mode-enable value: 0
    				debug attr 20: adi,txmon-dc-tracking-enable value: 0
    				debug attr 21: adi,txmon-high-gain value: 24
    				debug attr 22: adi,txmon-low-gain value: 0
    				debug attr 23: adi,txmon-low-high-thresh value: 37000
    				debug attr 24: adi,gpo3-tx-delay-us value: 0
    				debug attr 25: adi,gpo3-rx-delay-us value: 0
    				debug attr 26: adi,gpo2-tx-delay-us value: 0
    				debug attr 27: adi,gpo2-rx-delay-us value: 0
    				debug attr 28: adi,gpo1-tx-delay-us value: 0
    				debug attr 29: adi,gpo1-rx-delay-us value: 0
    				debug attr 30: adi,gpo0-tx-delay-us value: 0
    				debug attr 31: adi,gpo0-rx-delay-us value: 0
    				debug attr 32: adi,gpo3-slave-tx-enable value: 0
    				debug attr 33: adi,gpo3-slave-rx-enable value: 0
    				debug attr 34: adi,gpo2-slave-tx-enable value: 0
    				debug attr 35: adi,gpo2-slave-rx-enable value: 0
    				debug attr 36: adi,gpo1-slave-tx-enable value: 0
    				debug attr 37: adi,gpo1-slave-rx-enable value: 0
    				debug attr 38: adi,gpo0-slave-tx-enable value: 0
    				debug attr 39: adi,gpo0-slave-rx-enable value: 0
    				debug attr 40: adi,gpo3-inactive-state-high-enable value: 0
    				debug attr 41: adi,gpo2-inactive-state-high-enable value: 0
    				debug attr 42: adi,gpo1-inactive-state-high-enable value: 0
    				debug attr 43: adi,gpo0-inactive-state-high-enable value: 0
    				debug attr 44: adi,gpo-manual-mode-enable-mask value: 0
    				debug attr 45: adi,gpo-manual-mode-enable value: 0
    				debug attr 46: adi,aux-dac2-tx-delay-us value: 0
    				debug attr 47: adi,aux-dac2-rx-delay-us value: 0
    				debug attr 48: adi,aux-dac2-active-in-alert-enable value: 0
    				debug attr 49: adi,aux-dac2-active-in-tx-enable value: 0
    				debug attr 50: adi,aux-dac2-active-in-rx-enable value: 0
    				debug attr 51: adi,aux-dac2-default-value-mV value: 0
    				debug attr 52: adi,aux-dac1-tx-delay-us value: 0
    				debug attr 53: adi,aux-dac1-rx-delay-us value: 0
    				debug attr 54: adi,aux-dac1-active-in-alert-enable value: 0
    				debug attr 55: adi,aux-dac1-active-in-tx-enable value: 0
    				debug attr 56: adi,aux-dac1-active-in-rx-enable value: 0
    				debug attr 57: adi,aux-dac1-default-value-mV value: 0
    				debug attr 58: adi,aux-dac-manual-mode-enable value: 1
    				debug attr 59: adi,aux-adc-decimation value: 256
    				debug attr 60: adi,aux-adc-rate value: 40000000
    				debug attr 61: adi,temp-sense-decimation value: 256
    				debug attr 62: adi,temp-sense-periodic-measurement-enable value: 1
    				debug attr 63: adi,temp-sense-offset-signed value: 206
    				debug attr 64: adi,temp-sense-measurement-interval-ms value: 1000
    				debug attr 65: adi,elna-gaintable-all-index-enable value: 0
    				debug attr 66: adi,elna-rx2-gpo1-control-enable value: 0
    				debug attr 67: adi,elna-rx1-gpo0-control-enable value: 0
    				debug attr 68: adi,elna-bypass-loss-mdB value: 0
    				debug attr 69: adi,elna-gain-mdB value: 0
    				debug attr 70: adi,elna-settling-delay-ns value: 0
    				debug attr 71: adi,ctrl-outs-enable-mask value: 255
    				debug attr 72: adi,ctrl-outs-index value: 0
    				debug attr 73: adi,rssi-duration value: 1000
    				debug attr 74: adi,rssi-wait value: 1
    				debug attr 75: adi,rssi-delay value: 1
    				debug attr 76: adi,rssi-unit-is-rx-samples-enable value: 0
    				debug attr 77: adi,rssi-restart-mode value: 3
    				debug attr 78: adi,fagc-adc-large-overload-inc-steps value: 2
    				debug attr 79: adi,fagc-power-measurement-duration-in-state5 value: 64
    				debug attr 80: adi,fagc-rst-gla-if-en-agc-pulled-high-mode value: 0
    				debug attr 81: adi,fagc-rst-gla-en-agc-pulled-high-enable value: 0
    				debug attr 82: adi,fagc-rst-gla-large-lmt-overload-enable value: 1
    				debug attr 83: adi,fagc-rst-gla-large-adc-overload-enable value: 1
    				debug attr 84: adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt value: 8
    				debug attr 85: adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll value: 10
    				debug attr 86: adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable value: 1
    				debug attr 87: adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable value: 1
    				debug attr 88: adi,fagc-rst-gla-stronger-sig-thresh-above-ll value: 10
    				debug attr 89: adi,fagc-optimized-gain-offset value: 5
    				debug attr 90: adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable value: 1
    				debug attr 91: adi,fagc-use-last-lock-level-for-set-gain-enable value: 1
    				debug attr 92: adi,fagc-gain-index-type-after-exit-rx-mode value: 0
    				debug attr 93: adi,fagc-gain-increase-after-gain-lock-enable value: 0
    				debug attr 94: adi,fagc-final-overrange-count value: 3
    				debug attr 95: adi,fagc-lmt-final-settling-steps value: 1
    				debug attr 96: adi,fagc-lpf-final-settling-steps value: 1
    				debug attr 97: adi,fagc-lock-level-gain-increase-upper-limit value: 5
    				debug attr 98: adi,fagc-lock-level-lmt-gain-increase-enable value: 1
    				debug attr 99: adi,fagc-lp-thresh-increment-steps value: 1
    				debug attr 100: adi,fagc-lp-thresh-increment-time value: 5
    				debug attr 101: adi,fagc-allow-agc-gain-increase-enable value: 0
    				debug attr 102: adi,fagc-state-wait-time-ns value: 260
    				debug attr 103: adi,fagc-dec-pow-measurement-duration value: 64
    				debug attr 104: adi,agc-immed-gain-change-if-large-lmt-overload-enable value: 0
    				debug attr 105: adi,agc-immed-gain-change-if-large-adc-overload-enable value: 0
    				debug attr 106: adi,agc-gain-update-interval-us value: 1000
    				debug attr 107: adi,agc-sync-for-gain-counter-enable value: 0
    				debug attr 108: adi,agc-dig-gain-step-size value: 4
    				debug attr 109: adi,agc-dig-saturation-exceed-counter value: 3
    				debug attr 110: adi,agc-lmt-overload-large-inc-steps value: 2
    				debug attr 111: adi,agc-lmt-overload-small-exceed-counter value: 10
    				debug attr 112: adi,agc-lmt-overload-large-exceed-counter value: 10
    				debug attr 113: adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable value: 0
    				debug attr 114: adi,agc-adc-large-overload-inc-steps value: 2
    				debug attr 115: adi,agc-adc-large-overload-exceed-counter value: 10
    				debug attr 116: adi,agc-adc-small-overload-exceed-counter value: 10
    				debug attr 117: adi,agc-dig-sat-ovrg-enable value: 0
    				debug attr 118: adi,agc-outer-thresh-low-inc-steps value: 2
    				debug attr 119: adi,agc-outer-thresh-low value: 18
    				debug attr 120: adi,agc-inner-thresh-low-inc-steps value: 1
    				debug attr 121: adi,agc-inner-thresh-low value: 12
    				debug attr 122: adi,agc-inner-thresh-high-dec-steps value: 1
    				debug attr 123: adi,agc-inner-thresh-high value: 10
    				debug attr 124: adi,agc-outer-thresh-high-dec-steps value: 2
    				debug attr 125: adi,agc-outer-thresh-high value: 5
    				debug attr 126: adi,agc-attack-delay-extra-margin-us value: 1
    				debug attr 127: adi,mgc-split-table-ctrl-inp-gain-mode value: 0
    				debug attr 128: adi,mgc-dec-gain-step value: 2
    				debug attr 129: adi,mgc-inc-gain-step value: 2
    				debug attr 130: adi,mgc-rx2-ctrl-inp-enable value: 0
    				debug attr 131: adi,mgc-rx1-ctrl-inp-enable value: 0
    				debug attr 132: adi,gc-use-rx-fir-out-for-dec-pwr-meas-enable value: 0
    				debug attr 133: adi,gc-max-dig-gain value: 15
    				debug attr 134: adi,gc-dig-gain-enable value: 0
    				debug attr 135: adi,gc-low-power-thresh value: 24
    				debug attr 136: adi,gc-dec-pow-measurement-duration value: 8192
    				debug attr 137: adi,gc-lmt-overload-low-thresh value: 704
    				debug attr 138: adi,gc-lmt-overload-high-thresh value: 800
    				debug attr 139: adi,gc-adc-large-overload-thresh value: 58
    				debug attr 140: adi,gc-adc-small-overload-thresh value: 47
    				debug attr 141: adi,gc-adc-ovr-sample-size value: 4
    				debug attr 142: adi,gc-rx2-mode value: 2
    				debug attr 143: adi,gc-rx1-mode value: 2
    				debug attr 144: adi,update-tx-gain-in-alert-enable value: 0
    				debug attr 145: adi,tx-attenuation-mdB value: 10000
    				debug attr 146: adi,rf-tx-bandwidth-hz value: 18000000
    				debug attr 147: adi,rf-rx-bandwidth-hz value: 18000000
    				debug attr 148: adi,qec-tracking-slow-mode-enable value: 0
    				debug attr 149: adi,dc-offset-count-low-range value: 50
    				debug attr 150: adi,dc-offset-count-high-range value: 40
    				debug attr 151: adi,dc-offset-attenuation-low-range value: 5
    				debug attr 152: adi,dc-offset-attenuation-high-range value: 6
    				debug attr 153: adi,dc-offset-tracking-update-event-mask value: 5
    				debug attr 154: adi,clk-output-mode-select value: 0
    				debug attr 155: adi,external-rx-lo-enable value: 0
    				debug attr 156: adi,external-tx-lo-enable value: 0
    				debug attr 157: adi,xo-disable-use-ext-refclk-enable value: 1
    				debug attr 158: adi,tx-lo-powerdown-managed-enable value: 1
    				debug attr 159: adi,trx-synthesizer-target-fref-overwrite-hz value: 80008000
    				debug attr 160: adi,rx1-rx2-phase-inversion-enable value: 0
    				debug attr 161: adi,tx-rf-port-input-select-lock-enable value: 0
    				debug attr 162: adi,rx-rf-port-input-select-lock-enable value: 0
    				debug attr 163: adi,tx-rf-port-input-select value: 0
    				debug attr 164: adi,rx-rf-port-input-select value: 0
    				debug attr 165: adi,split-gain-table-mode-enable value: 0
    				debug attr 166: adi,1rx-1tx-mode-use-tx-num value: 1
    				debug attr 167: adi,1rx-1tx-mode-use-rx-num value: 1
    				debug attr 168: adi,2rx-2tx-mode-enable value: 1
    				debug attr 169: adi,digital-interface-tune-fir-disable value: 1
    				debug attr 170: adi,digital-interface-tune-skip-mode value: 0
    				debug attr 171: adi,tx-fastlock-pincontrol-enable value: 0
    				debug attr 172: adi,rx-fastlock-pincontrol-enable value: 0
    				debug attr 173: adi,rx-fastlock-delay-ns value: 0
    				debug attr 174: adi,tx-fastlock-delay-ns value: 0
    				debug attr 175: adi,tdd-skip-vco-cal-enable value: 0
    				debug attr 176: adi,tdd-use-dual-synth-mode-enable value: 0
    				debug attr 177: adi,debug-mode-enable value: 0
    				debug attr 178: adi,ensm-enable-txnrx-control-enable value: 0
    				debug attr 179: adi,ensm-enable-pin-pulse-mode-enable value: 0
    				debug attr 180: adi,frequency-division-duplex-independent-mode-enable value: 0
    				debug attr 181: adi,frequency-division-duplex-mode-enable value: 1
    				debug attr 182: direct_reg_access value: 0x0
    	iio:device1: xadc
    		9 channels found:
    			voltage5: vccoddr (input)
    				attr  0: label value: vccoddr
    				attr  1: raw value: 1819
    				attr  2: scale value: 0.732421875
    			voltage0: vccint (input)
    				attr  0: label value: vccint
    				attr  1: raw value: 1294
    			voltage4: vccpaux (input)
    				attr  0: label value: vccpaux
    				attr  1: raw value: 2434
    			temp0:  (input)
    				attr  0: offset value: -2219
    				attr  1: raw value: 2685
    				attr  2: scale value: 123.040771484
    			voltage7: vrefn (input)
    				attr  0: label value: vrefn
    				attr  1: raw value: -7
    			voltage1: vccaux (input)
    				attr  0: label value: vccaux
    				attr  1: raw value: 2437
    			voltage2: vccbram (input)
    				attr  0: label value: vccbram
    				attr  1: raw value: 1293
    			voltage3: vccpint (input)
    				attr  0: label value: vccpint
    				attr  1: raw value: 1342
    			voltage6: vrefp (input)
    				attr  0: label value: vrefp
    				attr  1: raw value: 1697
    		2 device-specific attributes found:
    				attr  0: sampling_frequency value: 961538
    				attr  1: waiting_for_supplier value: 0
    	iio:device2: cf-ad9361-dds-core-lpc (buffer capable)
    		12 channels found:
    			voltage0:  (output, index: 0, format: le:S16/16>>0)
    				attr  0: calibphase value: 0.000000
    				attr  1: calibscale value: 1.000000
    				attr  2: sampling_frequency value: 30720000
    			voltage1:  (output, index: 1, format: le:S16/16>>0)
    			voltage2:  (output, index: 2, format: le:S16/16>>0)
    			voltage3:  (output, index: 3, format: le:S16/16>>0)
    			altvoltage3: TX1_Q_F2 (output)
    			6 channel-specific attributes found:
    				attr  0: frequency value: 9279985
    				attr  1: label value: TX1_Q_F2
    				attr  2: phase value: 0
    				attr  3: raw value: 1
    				attr  4: sampling_frequency value: 30720000
    				attr  5: scale value: 0.250000
    			altvoltage1: TX1_I_F2 (output)
    				attr  1: label value: TX1_I_F2
    				attr  2: phase value: 90000
    			altvoltage0: TX1_I_F1 (output)
    				attr  1: label value: TX1_I_F1
    			altvoltage7: TX2_Q_F2 (output)
    				attr  1: label value: TX2_Q_F2
    			altvoltage6: TX2_Q_F1 (output)
    				attr  1: label value: TX2_Q_F1
    			altvoltage5: TX2_I_F2 (output)
    				attr  1: label value: TX2_I_F2
    			altvoltage2: TX1_Q_F1 (output)
    				attr  1: label value: TX1_Q_F1
    			altvoltage4: TX2_I_F1 (output)
    				attr  1: label value: TX2_I_F1
    		3 device-specific attributes found:
    				attr  0: sync_start_enable value: arm
    				attr  1: sync_start_enable_available value: arm
    				attr  2: waiting_for_supplier value: 0
    		3 buffer-specific attributes found:
    				attr  0: data_available value: 0
    				attr  1: direction value: out
    				attr  2: length_align_bytes value: 8
    		1 debug attributes found:
    				debug attr  0: direct_reg_access value: 0x90262
    	iio_sysfs_trigger:
    		0 channels found:
    				attr  0: add_trigger ERROR: Permission denied (13)
    				attr  1: remove_trigger ERROR: Permission denied (13)
    Booting Linux on physical CPU 0x0
    Linux version 6.1.70adi-v2023.2 (oe-user@oe-host) (arm-xilinx-linux-gnueabi-gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0.20220819) #1 SMP PREEMPT Fri Oct 10 09:16:22 UTC 2025
    CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
    CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    OF: fdt: Machine model: Analog Devices ADRV9361-Z7035 (Z7035/AD9361)
    earlycon: cdns0 at MMIO 0xe0001000 (options '115200n8')
    printk: bootconsole [cdns0] enabled
    Memory policy: Data cache writealloc
    cma: Reserved 128 MiB at 0x38000000
    Zone ranges:
      Normal   [mem 0x0000000000000000-0x000000002fffffff]
      HighMem  [mem 0x0000000030000000-0x000000003fffffff]
    Movable zone start for each node
    Early memory node ranges
      node   0: [mem 0x0000000000000000-0x000000003fffffff]
    Initmem setup node 0 [mem 0x0000000000000000-0x000000003fffffff]
    percpu: Embedded 11 pages/cpu s14420 r8192 d22444 u45056
    pcpu-alloc: s14420 r8192 d22444 u45056 alloc=11*4096
    pcpu-alloc: [0] 0 [0] 1
    Built 1 zonelists, mobility grouping on.  Total pages: 260608
    Kernel command line: console=ttyPS0,115200 earlycon
    Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    Memory: 794908K/1048576K available (12288K kernel code, 819K rwdata, 10388K rodata, 88064K init, 469K bss, 122596K reserved, 131072K cma-reserved, 131072K highmem)
    rcu: Preemptible hierarchical RCU implementation.
    rcu: 	RCU event tracing is enabled.
    rcu: 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
    rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    efuse mapped to (ptrval)
    slcr mapped to (ptrval)
    L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
    L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
    L2C-310 erratum 769419 enabled
    L2C-310 enabling early BRESP for Cortex-A9
    L2C-310 full line of zeros enabled for Cortex-A9
    L2C-310 ID prefetch enabled, offset 1 lines
    L2C-310 dynamic clock gating enabled, standby mode enabled
    L2C-310 cache controller enabled, 8 ways, 512 kB
    L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
    rcu: srcu_init: Setting srcu_struct sizes based on contention.
    zynq_clock_init: clkc starts at (ptrval)
    Zynq clock init
    sched_clock: 64 bits at 167MHz, resolution 6ns, wraps every 4398046511103ns
    clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x26703d7dd8, max_idle_ns: 440795208065 ns
    Switching to timer-based delay loop, resolution 6ns
    clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
    timer #0 at (ptrval), irq=25
    Console: colour dummy device 80x30
    Calibrating delay loop (skipped), value calculated using timer frequency.. 333.33 BogoMIPS (lpj=1666666)
    CPU: Testing write buffer coherency: ok
    CPU0: Spectre v2: using BPIALL workaround
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    Setting up static identity map for 0x100000 - 0x100060
    rcu: Hierarchical SRCU implementation.
    rcu: 	Max phase no-delay instances is 1000.
    smp: Bringing up secondary CPUs ...
    CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    CPU1: Spectre v2: using BPIALL workaround
    smp: Brought up 1 node, 2 CPUs
    SMP: Total of 2 processors activated (666.66 BogoMIPS).
    CPU: All CPU(s) started in SVC mode.
    devtmpfs: initialized
    VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    pinctrl core: initialized pinctrl subsystem
    NET: Registered PF_NETLINK/PF_ROUTE protocol family
    DMA: preallocated 256 KiB pool for atomic coherent allocations
    thermal_sys: Registered thermal governor 'step_wise'
    cpuidle: using governor ladder
    platform axi: Fixed dependency cycle(s) with /axi/interrupt-controller@f8f01000
    amba f8801000.etb: Fixed dependency cycle(s) with /replicator/out-ports/port@1/endpoint
    amba f8803000.tpiu: Fixed dependency cycle(s) with /replicator/out-ports/port@0/endpoint
    amba f8804000.funnel: Fixed dependency cycle(s) with /replicator/in-ports/port/endpoint
    amba f889c000.ptm: Fixed dependency cycle(s) with /axi/funnel@f8804000/in-ports/port@0/endpoint
    amba f889d000.ptm: Fixed dependency cycle(s) with /axi/funnel@f8804000/in-ports/port@1/endpoint
    sysfs: cannot create duplicate filename '/bus/platform/devices/79020000.cf-ad9361-lpc'
    CPU: 1 PID: 1 Comm: swapper/0 Not tainted 6.1.70adi-v2023.2 #1
    Hardware name: Xilinx Zynq Platform
     unwind_backtrace from show_stack+0x10/0x14
     show_stack from dump_stack_lvl+0x40/0x4c
     dump_stack_lvl from sysfs_warn_dup+0x58/0x64
     sysfs_warn_dup from sysfs_do_create_link_sd+0xdc/0xe0
     sysfs_do_create_link_sd from bus_add_device+0x5c/0xf4
     bus_add_device from device_add+0x324/0x7c8
     device_add from of_platform_device_create_pdata+0x94/0xc0
     of_platform_device_create_pdata from of_platform_bus_create+0x198/0x378
     of_platform_bus_create from of_platform_bus_create+0x1e4/0x378
     of_platform_bus_create from of_platform_populate+0x70/0xd4
     of_platform_populate from zynq_init_machine+0x148/0x158
     zynq_init_machine from customize_machine+0x20/0x30
     customize_machine from do_one_initcall+0x58/0x23c
     do_one_initcall from kernel_init_freeable+0x194/0x1f0
     kernel_init_freeable from kernel_init+0x18/0x12c
     kernel_init from ret_from_fork+0x14/0x28
    Exception stack(0xf081dfb0 to 0xf081dff8)
    dfa0:                                     00000000 00000000 00000000 00000000
    dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
    hw-breakpoint: maximum watchpoint size is 4 bytes.
    e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 27, base_baud = 6249999) is a xuartps
    printk: console [ttyPS0] enabled
    printk: bootconsole [cdns0] disabled
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    mc: Linux media interface: v0.10
    videodev: Linux video capture interface: v2.00
    pps_core: LinuxPPS API ver. 1 registered
    pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    PTP clock support registered
    jesd204: found 0 devices and 0 topologies
    FPGA manager framework
    Advanced Linux Sound Architecture Driver Initialized.
    clocksource: Switched to clocksource arm_global_timer
    NET: Registered PF_INET protocol family
    IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
    tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
    Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
    TCP: Hash tables configured (established 8192 bind 8192)
    UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    NET: Registered PF_UNIX/PF_LOCAL protocol family
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    armv7-pmu f8891000.pmu: hw perfevents: no interrupt-affinity property, guessing.
    hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
    workingset: timestamp_bits=30 max_order=18 bucket_order=0
    NFS: Registering the id_resolver key type
    Key type id_resolver registered
    Key type id_legacy registered
    nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    fuse: init (API version 7.37)
    bounce: pool size: 64 pages
    io scheduler mq-deadline registered
    io scheduler kyber registered
    zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
    dma-pl330 f8003000.dma-controller: Loaded driver for PL330 DMAC-241330
    dma-pl330 f8003000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
    brd: module loaded
    loop: module loaded
    Registered mathworks_ip class
    mwipcore 43c00000.mwipcore: error -ENXIO: IRQ index 0 not found
    mwipcore 43c00000.mwipcore: Dev memory resource found at (ptrval) 0000FFFF.
    mwipcore 43c00000.mwipcore: 'mwipcore' device not found, creating
    mwipcore 43c00000.mwipcore: Char dev region registered: major num:245
    mwipcore 43c00000.mwipcore: 'mwipcore' device created
    SPI driver spidev has no spi_device_id for adi,swspi
    spi-nor spi1.0: SPI-NOR-UniqueID 1044730cca110008f7ff04004fd0f6ca67
    spi-nor spi1.0: found n25q256ax1, expected n25q256a
    spi-nor spi1.0: n25q256ax1 (32768 Kbytes)
    6 fixed-partitions partitions found on MTD device spi1.0
    Creating 6 MTD partitions on "spi1.0":
    0x000000000000-0x0000000e0000 : "qspi-fsbl-uboot"
    0x0000000e0000-0x000000100000 : "qspi-uboot-env"
    0x000000100000-0x000000600000 : "qspi-linux"
    0x000000600000-0x000000620000 : "qspi-device-tree"
    0x000000620000-0x000001300000 : "qspi-rootfs"
    0x000001300000-0x000002000000 : "qspi-bitstream"
    MACsec IEEE 802.1AE
    tun: Universal TUN/TAP device driver, 1.6
    hwmon hwmon0: temp1_input not attached to any thermal zone
    macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 44 (3e:c3:10:dd:9a:09)
    usbcore: registered new interface driver asix
    usbcore: registered new interface driver ax88179_178a
    usbcore: registered new interface driver cdc_ether
    usbcore: registered new interface driver net1080
    usbcore: registered new interface driver cdc_subset
    usbcore: registered new interface driver zaurus
    usbcore: registered new interface driver cdc_ncm
    usbcore: registered new interface driver r8153_ecm
    usbcore: registered new interface driver uas
    usbcore: registered new interface driver usb-storage
    usbcore: registered new interface driver usbserial_generic
    usbserial: USB Serial support registered for generic
    usbcore: registered new interface driver ftdi_sio
    usbserial: USB Serial support registered for FTDI USB Serial Device
    usbcore: registered new interface driver upd78f0730
    usbserial: USB Serial support registered for upd78f0730
    ULPI transceiver vendor/product ID 0x0424/0x0007
    Found SMSC USB3320 ULPI transceiver.
    ULPI integrity check: passed.
    ci_hdrc ci_hdrc.0: EHCI Host Controller
    ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
    ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
    usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
    usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    usb usb1: Product: EHCI Host Controller
    usb usb1: Manufacturer: Linux 6.1.70adi-v2023.2 ehci_hcd
    usb usb1: SerialNumber: ci_hdrc.0
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    SPI driver ads7846 has no spi_device_id for ti,tsc2046
    SPI driver ads7846 has no spi_device_id for ti,ads7843
    SPI driver ads7846 has no spi_device_id for ti,ads7845
    SPI driver ads7846 has no spi_device_id for ti,ads7873
    i2c_dev: i2c /dev entries driver
    at24 0-0050: supply vcc not found, using dummy regulator
    at24 0-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write
    gspca_main: v2.14.0 registered
    usbcore: registered new interface driver uvcvideo
    cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer with timeout 10s
    Xilinx Zynq CpuIdle Driver started
    sdhci: Secure Digital Host Controller Interface driver
    sdhci: Copyright(c) Pierre Ossman
    sdhci-pltfm: SDHCI platform and OF driver helper
    ledtrig-cpu: registered to indicate activity on CPUs
    hid: raw HID events driver (C) Jiri Kosina
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    SPI driver fb_seps525 has no spi_device_id for syncoam,seps525
    mmc0: SDHCI controller on e0100000.mmc [e0100000.mmc] using ADMA
    ad7291: probe of 0-002f failed with error -5
    ad9361 spi0.0: ad9361_probe : enter (ad9361)
    ad9361 spi0.0: No GPIOs defined for ext band ctrl
    mmc0: new high speed SDXC card at address 1388
    mmcblk0: mmc0:1388 SATC  57.7 GiB
     mmcblk0: p1 p2
    ad9361 spi0.0: ad9361_probe : AD936x Rev 0 successfully initialized
    cf_axi_dds 79024000.cf-ad9361-dds-core-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.02.b) at 0x79024000 mapped to 0x(ptrval), probed DDS AD9361
    SPI driver adis16475 has no spi_device_id for adi,adis16470
    SPI driver adis16475 has no spi_device_id for adi,adis16475-1
    SPI driver adis16475 has no spi_device_id for adi,adis16475-2
    SPI driver adis16475 has no spi_device_id for adi,adis16475-3
    SPI driver adis16475 has no spi_device_id for adi,adis16477-1
    SPI driver adis16475 has no spi_device_id for adi,adis16477-2
    SPI driver adis16475 has no spi_device_id for adi,adis16477-3
    SPI driver adis16475 has no spi_device_id for adi,adis16465-1
    SPI driver adis16475 has no spi_device_id for adi,adis16465-2
    SPI driver adis16475 has no spi_device_id for adi,adis16465-3
    SPI driver adis16475 has no spi_device_id for adi,adis16467-1
    SPI driver adis16475 has no spi_device_id for adi,adis16467-2
    SPI driver adis16475 has no spi_device_id for adi,adis16467-3
    SPI driver adis16475 has no spi_device_id for adi,adis16500
    SPI driver adis16475 has no spi_device_id for adi,adis16501
    SPI driver adis16475 has no spi_device_id for adi,adis16505-1
    SPI driver adis16475 has no spi_device_id for adi,adis16505-2
    SPI driver adis16475 has no spi_device_id for adi,adis16505-3
    SPI driver adis16475 has no spi_device_id for adi,adis16507-1
    SPI driver adis16475 has no spi_device_id for adi,adis16507-2
    SPI driver adis16475 has no spi_device_id for adi,adis16507-3
    SPI driver adis16475 has no spi_device_id for adi,adis16575-2
    SPI driver adis16475 has no spi_device_id for adi,adis16575-3
    SPI driver adis16475 has no spi_device_id for adi,adis16576-2
    SPI driver adis16475 has no spi_device_id for adi,adis16576-3
    SPI driver adis16475 has no spi_device_id for adi,adis16577-2
    SPI driver adis16475 has no spi_device_id for adi,adis16577-3
    axi_sysid 45000000.axi-sysid-0: AXI System ID core version (1.01.a) found
    axi_sysid 45000000.axi-sysid-0: [adrv9361z7035_ccbob] on [lvds] git branch <> git <0> dirty [2025-08-12 08:10:51] UTC
    fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
    usbcore: registered new interface driver snd-usb-audio
    NET: Registered PF_INET6 protocol family
    Segment Routing with IPv6
    In-situ OAM (IOAM) with IPv6
    sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    NET: Registered PF_PACKET protocol family
    NET: Registered PF_IEEE802154 protocol family
    Key type dns_resolver registered
    zynq_pm_remap_ocm: OCM pool is not available
    zynq_pm_suspend_init: Unable to map OCM.
    Registering SWP/SWPB emulation handler
    of-fpga-region fpga-full: FPGA Region probed
    SAMPL CLK: 30720000 tuning: RX
      0:1:2:3:4:5:6:7:8:9:a:b:c:d:e:f:
    0:# # # # # # # # # # # # # # # #
    1:# # # # # # # # # # # # # # # #
    ad9361 spi0.0: ad9361_dig_tune_delay: Tuning RX FAILED!
    cf_axi_adc: probe of 79020000.cf-ad9361-lpc failed with error -5
    input: gpio_keys as /devices/soc0/gpio_keys/input/input0
    of_cfs_init
    of_cfs_init: OK
    ALSA device list:
      No soundcards found.
    Freeing unused kernel image (initmem) memory: 88064K
    Run /init as init process
      with arguments:
        /init
      with environment:
        HOME=/
        TERM=linux
    systemd[1]: System time before build time, advancing clock.
    systemd[1]: systemd 251.8+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    systemd[1]: Detected architecture arm.
    systemd[1]: Hostname set to <adrv1>.
    systemd[1]: Initializing machine ID from random generator.
    systemd-sysv-generator[66]: SysV service '/etc/init.d/sshd' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    systemd-sysv-generator[66]: SysV service '/etc/init.d/nfsserver' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    systemd-sysv-generator[66]: SysV service '/etc/init.d/inetd.busybox' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    systemd[1]: Queued start job for default target Multi-User System.
    systemd[1]: Created slice Slice /system/getty.
    systemd[1]: Created slice Slice /system/modprobe.
    systemd[1]: Created slice Slice /system/serial-getty.
    systemd[1]: Created slice User and Session Slice.
    systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    systemd[1]: Reached target Path Units.
    systemd[1]: Reached target Remote File Systems.
    systemd[1]: Reached target Slice Units.
    systemd[1]: Reached target Swaps.
    systemd[1]: Listening on RPCbind Server Activation Socket.
    systemd[1]: Reached target RPC Port Mapper.
    systemd[1]: Listening on Syslog Socket.
    systemd[1]: Listening on initctl Compatibility Named Pipe.
    systemd[1]: Journal Audit Socket was skipped because of a failed condition check (ConditionSecurity=audit).
    systemd[1]: Listening on Journal Socket (/dev/log).
    systemd[1]: Listening on Journal Socket.
    systemd[1]: Listening on Network Service Netlink Socket.
    systemd[1]: Listening on udev Control Socket.
    systemd[1]: Listening on udev Kernel Socket.
    systemd[1]: Listening on User Database Manager Socket.
    systemd[1]: Huge Pages File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
    systemd[1]: POSIX Message Queue File System was skipped because of a failed condition check (ConditionPathExists=/proc/sys/fs/mqueue).
    systemd[1]: Mounting Kernel Debug File System...
    systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    systemd[1]: Mounting Temporary Directory /tmp...
    systemd[1]: Create List of Static Device Nodes was skipped because of a failed condition check (ConditionFileNotEmpty=/lib/modules/6.1.70adi-v2023.2/modules.devname).
    systemd[1]: Starting Load Kernel Module configfs...
    systemd[1]: Starting Load Kernel Module drm...
    systemd[1]: Starting Load Kernel Module fuse...
    systemd[1]: Starting RPC Bind...
    systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
    systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    systemd[1]: Starting Journal Service...
    systemd[1]: Load Kernel Modules was skipped because all trigger condition checks failed.
    systemd[1]: Mounting NFSD configuration filesystem...
    systemd[1]: Starting Generate network units from Kernel command line...
    systemd[1]: Starting Remount Root and Kernel File Systems...
    systemd[1]: Starting Apply Kernel Variables...
    systemd[1]: Starting Coldplug All udev Devices...
    systemd[1]: Started RPC Bind.
    systemd[1]: Started Journal Service.
    systemd-journald[74]: Received client request to flush runtime journal.
    random: crng init done
    macb e000b000.ethernet eth0: PHY [e000b000.ethernet-ffffffff:00] driver [Marvell 88E1510] (irq=POLL)
    macb e000b000.ethernet eth0: configuring for phy/rgmii-id link mode
    macb e000b000.ethernet eth0: Link is Up - 1Gbps/Full - flow control tx
    IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: disabled.
    I see in iio:device2 there are 2 buffers I tried enabling both buffers.
