ERROR: fru-tools
Product Number: AD9361
Software Version: PetaLinux 2025.2
I am trying to build a custom PetaLinux(version 2025.2) for fmcomm2. I am following the instructions as per "github.com/.../README.md" .
When running PetaLinux build, I am facing this error
ERROR: fru-tools-0.8.1.5+git-r0 do_populate_lic: QA Issue: fru-tools: The LIC_FILES_CHKSUM does not match for file://license.txt;md5=b234ee4d69f5fce4486a80fdaf4a4263
fru-tools: The new md5 checksum is 600884d058742af4da113702ba4f0114
fru-tools: Here is the selected license text:
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
fru-tools — License Summary
The fru-tools source tree is dual-licensed:
* fru.c and fru.h are released under the ADI BSD-like license
reproduced at the end of this file. These two files can be reused
in non-GPL software under that license.
* All other files (including operating-system.c, which contains the
IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, NON-INFRINGEMENT,
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
IN NO EVENT SHALL ANALOG DEVICES BE LIABLE FOR ANY DIRECT, INDIRECT,
INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
BUT NOT LIMITED TO, INTELLECTUAL PROPERTY RIGHTS, PROCUREMENT OF
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
fru-tools: Check if the license information has changed in /home/sanyarkteam/Embedded/Petalinux/fmcomms2/fcomm2/build/tmp/work/cortexa72-cortexa53-amd-linux/fru-tools/0.8.1.5+git/git/license.txt to verify that the LICENSE value "GPL-2.0-only" remains valid [license-checksum]
ERROR: fru-tools-0.8.1.5+git-r0 do_populate_lic: Fatal QA errors were found, failing task.
ERROR: Logfile of failure stored in: /home/sanyarkteam/Embedded/Petalinux/fmcomms2/fcomm2/build/tmp/work/cortexa72-cortexa53-amd-linux/fru-tools/0.8.1.5+git/temp/log.do_populate_lic.1256365
ERROR: Task (/home/sanyarkteam/Embedded/Petalinux/fmcomms2/fcomm2/meta-adi/meta-adi-xilinx/recipes-support/fru-tools/fru-tools_0.8.1.5.bb:do_populate_lic) failed with exit code '1'
How can I solve this?
Thread Notes
