I'm running pluto firmware v0.39 which has libiio v0.26 and libad9361 v0.3. I've compiled my app against pluto-0.39.sysroot.
Everything was working fine, but then I went to put the rx buffer into non-blocking mode via iio_buffer_set_blocking_mode( rxbuf, false ) and it returns -38 which is ENOSYS
On older versions of libiio, a call to iio_buffer_set_blocking_mode() checked to see if rxbuf->dev->ctx->ops->set_blocking_mode existed, and if not, return -ENOSYS.
I'm unsure if iio_buffer_set_blocking_mode() is supported in libiio v0.26. I thought that 0.26 was changes that were going to make it into v1,.0 and hence iio_buffer_set_blocking_mode() was removed but then supported through the compatibility layer?
Is it supported?
