ADV7511 probe failed with error -110 on ZedBoard HDMI pipeline
The user encountered an error (-110) while probing the ADV7511 HDMI transmitter on a ZedBoard during boot. The issue was not resolved, and the thread was closed due to inactivity. The user's device tree and Vivado design were provided, but no specific solution was given. The ADV7511 was configured with dummy regulators for its power supplies, which might be relevant to the error.
Product Number: ADV7511
Hi everyone,
I am creating an HDMI video pipeline on a ZedBoard, but I am encountering the following error during boot: adv7511: probe of 0-0039 failed with error -110. I have attached my device tree, Vivado design, and boot log for reference. Thank You!
Booting Linux on physical CPU 0x0
Linux version 5.15.0-xilinx-v2022.2 (oe-user@oe-host) (arm-xilinx-linux-gnueabi-gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.37.20210721) #1 SMP PREEMPT Mon Dec 20 02:57:12 UTC 2021
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt: Machine model: xlnx,zynq-7000
Memory policy: Data cache writealloc
cma: Reserved 16 MiB at 0x1f000000
Zone ranges:
  Normal   [mem 0x0000000000000000-0x000000001fffffff]
  HighMem  empty
Movable zone start for each node
Early memory node ranges
  node   0: [mem 0x0000000000000000-0x000000001fffffff]
Initmem setup node 0 [mem 0x0000000000000000-0x000000001fffffff]
percpu: Embedded 12 pages/cpu s16588 r8192 d24372 u49152
pcpu-alloc: s16588 r8192 d24372 u49152 alloc=12*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists, mobility grouping on.  Total pages: 130048
Kernel command line: console=ttyPS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait uio_pdrv_genirq.of_id=generic-uio
Unknown command line parameters: earlyprintk
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
mem auto-init: stack:off, heap alloc:off, heap free:off
Memory: 478956K/524288K available (7168K kernel code, 251K rwdata, 1976K rodata, 1024K init, 130K bss, 28948K reserved, 16384K cma-reserved, 0K highmem)
rcu: Preemptible hierarchical RCU implementation.
rcu:    RCU event tracing is enabled.
rcu:    RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
        Trampoline variant of Tasks RCU enabled.
rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
efuse mapped to (ptrval)
slcr mapped to (ptrval)
GIC physical location is 0xf8f01000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
random: get_random_bytes called from start_kernel+0x364/0x5d0 with crng_init=0
zynq_clock_init: clkc starts at (ptrval)
Zynq clock init
sched_clock: 64 bits at 166MHz, resolution 6ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x26703d7dd8, max_idle_ns: 440795208065 ns
Switching to timer-based delay loop, resolution 6ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at (ptrval), irq=25
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 333.33 BogoMIPS (lpj=1666666)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
CPU: Testing write buffer coherency: ok
CPU0: Spectre v2: using BPIALL workaround
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x100000 - 0x100060
rcu: Hierarchical SRCU implementation.
smp: Bringing up secondary CPUs ...
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU1: Spectre v2: using BPIALL workaround
smp: Brought up 1 node, 2 CPUs
SMP: Total of 2 processors activated (666.66 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes, linear)
pinctrl core: initialized pinctrl subsystem
NET: Registered PF_NETLINK/PF_ROUTE protocol family
DMA: preallocated 256 KiB pool for atomic coherent allocations
i2c-core: driver [dummy] registered
thermal_sys: Registered thermal governor 'step_wise'
cpuidle: using governor menu
amba f8801000.etb: Fixing up cyclic dependency with replicator
amba f8803000.tpiu: Fixing up cyclic dependency with replicator
amba f8804000.funnel: Fixing up cyclic dependency with replicator
amba f889c000.ptm: Fixing up cyclic dependency with f8804000.funnel
amba f889d000.ptm: Fixing up cyclic dependency with f8804000.funnel
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 32, base_baud = 3125000) is a xuartps
printk: console [ttyPS0] enabled
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
usb_phy_generic usb-phy@0: supply vcc not found, using dummy regulator
mc: Linux media interface: v0.10
videodev: Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
FPGA manager framework
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
NET: Registered PF_INET protocol family
IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
NET: Registered PF_UNIX/PF_LOCAL protocol family
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
Trying to unpack rootfs image as initramfs...
armv7-pmu f8891000.pmu: hw perfevents: no interrupt-affinity property, guessing.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
workingset: timestamp_bits=30 max_order=17 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
io scheduler mq-deadline registered
io scheduler kyber registered
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
i2c-core: driver [si570] registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac:        DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
xilinx-vdma 43000000.dma: Xilinx AXI VDMA Engine Driver Probed!!
i2c-core: driver [adv7511] registered
brd: module loaded
loop: module loaded
i2c-core: driver [at24] registered
spi_master spi0: cannot find modalias for /axi/spi@e000d000/flash@0
spi_master spi0: Failed to create SPI device for /axi/spi@e000d000/flash@0
libphy: Fixed MDIO Bus: probed
CAN device driver interface
Freeing initrd memory: 12076K
libphy: MACB_mii_bus: probed
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 34 (00:0a:35:00:1e:53)
e1000e: Intel(R) PRO/1000 Network Driver
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
usbcore: registered new interface driver usb-storage
i2c-core: driver [rtc-pcf8563] registered
i2c_dev: i2c /dev entries driver
xiic-i2c 41600000.i2c: xiic_setclk entry, i2c->input_clk: 99999999, i2c->i2c_clk: 100000
i2c_dev: adapter [xiic-i2c 41600000.i2c] registered as minor 0
i2c i2c-0: adapter [xiic-i2c 41600000.i2c] registered
i2c i2c-0: of_i2c: walking child nodes
i2c i2c-0: of_i2c: register /amba_pl/i2c@41600000/adv7511@39
i2c 0-0039: Fixing up cyclic dependency with 43c10000.axi_hdmi_tx
adv7511 0-0039: probe
adv7511 0-0039: supply avdd not found, using dummy regulator
adv7511 0-0039: supply dvdd not found, using dummy regulator
adv7511 0-0039: supply pvdd not found, using dummy regulator
adv7511 0-0039: supply bgvdd not found, using dummy regulator
adv7511 0-0039: supply dvdd-3v not found, using dummy regulator
xiic-i2c 41600000.i2c: xiic_xfer entry SR: 0xc0
xiic-i2c 41600000.i2c: __xiic_start_xfer entry, msg: (ptrval), fifos space: 15
xiic-i2c 41600000.i2c: xiic_start_send entry, msg: (ptrval), len: 1
xiic-i2c 41600000.i2c: xiic_start_send entry, ISR: 0xd0, CR: 0x1
xiic-i2c 41600000.i2c: xiic_std_fill_tx_fifo entry, len: 1, fifo space: 15
xiic-i2c 41600000.i2c: xiic_start_recv entry, ISR: 0xc0, CR: 0xd
xiic-i2c 41600000.i2c: xiic_start_recv end, ISR: 0xc4, CR: 0x35
i2c i2c-0: client [adv7511] registered with bus id 0-0039
xiic-i2c 41600000.i2c: mmio 41600000 irq 53 scl clock frequency 100000
i2c-core: driver [pca954x] registered
i2c-core: driver [adv7604] registered
i2c-core: driver [pmbus] registered
i2c-core: driver [ucd9000] registered
i2c-core: driver [ucd9200] registered
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer with timeout 10s
EDAC MC: ECC not enabled
Xilinx Zynq CpuIdle Driver started
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
ledtrig-cpu: registered to indicate activity on CPUs
mmc0: Invalid maximum block size, assuming 512 bytes
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
i2c-core: driver [adau1761] registered
NET: Registered PF_INET6 protocol family
Segment Routing with IPv6
In-situ OAM (IOAM) with IPv6
mmc0: SDHCI controller on e0100000.mmc [e0100000.mmc] using ADMA
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered PF_PACKET protocol family
can: controller area network core
NET: Registered PF_CAN protocol family
can: raw protocol
can: broadcast manager protocol
can: netlink gateway - max_hops=1
Registering SWP/SWPB emulation handler
of-fpga-region fpga-full: FPGA Region probed
of_cfs_init
of_cfs_init: OK
ALSA device list:
  No soundcards found.
Freeing unused kernel image (initmem) memory: 1024K
Run /init as init process
  with arguments:
    /init
    earlyprintk
  with environment:
    HOME=/
    TERM=linux
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa SL32G 29.7 GiB
 mmcblk0: p1 p2
random: fast init done
EXT4-fs (mmcblk0p2): recovery complete
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: disabled.
random: dd: uninitialized urandom read (512 bytes read)
macb e000b000.ethernet eth0: PHY [e000b000.ethernet-ffffffff:00] driver [Marvell 88E1510] (irq=POLL)
macb e000b000.ethernet eth0: configuring for phy/rgmii-id link mode
random: crng init done
#include "system-conf.dtsi"
/* Corrected device tree for Zynq-7000 with ADV7511 and ADI AXI HDMI TX
 * - Removed the non-standard xlnx,pl-disp pseudo node
 * - Added adi,axi-hdmi-tx node with proper DMA link to axi_vdma_0
 * - Fixed OF-graph endpoints between HDMI TX, ADV7511 and HDMI connector
 * - Marked controllers/IPs as "okay" so drivers probe
    #address-cells = <0x01>;
    #size-cells = <0x01>;
    compatible = "xlnx,zynq-7000";
    chosen {
        bootargs = "console=ttyPS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait uio_pdrv_genirq.of_id=generic-uio";
    usb_phy0: usb-phy@0 {
        compatible = "usb-nop-xceiv";
        #phy-cells = <0>;
        drv-vbus;
    amba_pl: amba_pl {
        adi_axi_hdmi_tx_0: axi_hdmi_tx@43c10000 {
            compatible = "adi,axi-hdmi-tx-1.00.a";
            reg = <0x43c10000 0x10000>;
            #address-cells = <1>;
            #size-cells = <0>;
            /* Link DMA from VDMA (your AXI VDMA instance phandle is &axi_vdma_0) */
            dmas = <&axi_vdma_0 0>;
            dma-names = "video_in";
            status = "okay";
            ports {
                #size-cells = <0>;
                port {
                    axi_hdmi_out: endpoint {
                        remote-endpoint = <&adv7511_in>;
        /* I2C controller - ensure label/phandle and status = "okay" so children get probed */
        axi_iic_0: i2c@41600000 {
            compatible = "xlnx,axi-iic-1.01.b", "xlnx,xps-iic-2.00.a";
            reg = <0x41600000 0x10000>;
            clock-frequency = <100000>;
            interrupts = <0 58 4>;
            interrupt-parent = <&intc>;
            clocks = <&clkc 15>;
            clock-names = "s_axi_aclk";
            #size-cells = <0>;
            status = "okay";
            /* ADV7511 HDMI transmitter on I2C bus */
            adv7511: adv7511@39 {
                compatible = "adi,adv7511";
                reg = <0x39>;
                /* ADV7511 input configuration */
                adi,input-depth = <8>;
                adi,input-colorspace = "rgb";
                adi,input-clock = "1x";
                adi,input-style = <1>;
                adi,input-justification = "right";
                adi,clock-delay = <0>;
                status = "okay";
                ports {
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				adv7511_in: endpoint {
					remote-endpoint = <&axi_hdmi_out>;
			port@1 {
				reg = <1>;
/* AXI VDMA configuration (phandle &axi_vdma_0 expected by dts) */
&axi_vdma_0 {
    dma-ranges = <0x00000000 0x00000000 0x40000000>;
    device-id = <0xaa02>;
    status = "okay";
    xlnx,vsize = <480>;
    xlnx,hsize = <640>;
    xlnx,stride = <1280>;
/* AXI dynamic clock - keep as in original but ensure status is okay */
&axi_dynclk_0 {
    compatible = "dglnt,axi-dynclk";
    #clock-cells = <0>;
    xlnx,krefclkfreqhz = <100000000>;
    xlnx,kversionminor = <2>;
    xlnx,rable = <0>;
    xlnx,ip-name = "axi_dynclk";
    clocks = <&clkc 15>, <&clkc 15>;
    clock-names = "REF_CLK_I", "s_axi_lite_aclk";
    clock-output-names = "clk";
    status = "okay";
    xlnx,name = "axi_dynclk_0";
&usb0 {
    xlnx,phy-reset-gpio = <&gpio0 85 0>;
Thread Notes
