Extracting IMU data with hardware timestamp
The user encountered an 'RX mapping exceeds available channels' error when trying to access the timestamp channel (channel 7) on an ADIS16495 IMU using the pyadi-iio library on a Raspberry Pi 4B running Kuiper Linux. The final answer suggests moving the thread to the Linux Software Drivers forum for further assistance. The user confirmed the need to move the thread and requested guidance on how to proceed with the move or create a new request.
Product Number: ADIS16495
Software Version: lib_iio version 0.26
I am trying to access gyroscope data with its associated timestamp from my ADIS16495 IMU connected to a raspberry pi 4B running Kuiper Linux. I was able to get basic acceleration data using the pyadi-iio library (channels 0-6), but when trying to access channel 7 (timestamp), I received an error saying "Exception: RX mapping exceeds available channels." When running iio_info (see attached file), I verified that there was a timestamp channel (timestamp: (input, index: 7, format: le:S64/64>>0)). The code that produced this error is also below.
import adi
import time
# Connect to the imu
imu = adi.adis16495()
# Make the output a dictionary that shows field names
#imu.rx_annotated=True
imu.rx_enabled_channels = [7]
# Set buffer to sample rate to capture exactly one second of data
imu.rx_buffer_size=imu.sample_rate
#print(imu.rx_channel_names)
#print(imu.current_timestamp_clock)
print("Sample rate:", imu.sample_rate, "measurements per second")
for _ in range(60):
    # Get data
    data = imu.rx()
    # Get timestamp
    timestamp = time.gmtime()
    # Display information
    print(timestamp)
    print(data)
Is there a way to access this channel with the pyadi-iio or similar resource? Ideally I would like to be able to access the IMU data via python.
Thanks!
iio_info version: 0.26 (git tag:5e1e9cb5)
Libiio version: 0.26 (git tag: 5e1e9cb) backends: local xml ip usb serial
IIO context created with local backend.
Backend version: 0.26 (git tag: 5e1e9cb)
Backend description string: Linux analog 6.1.54-v7l+ #1 SMP Mon Dec  2 10:56:39 UTC 2024 armv7l
IIO context has 4 attributes:
	hw_carrier: Raspberry Pi 4 Model B Rev 1.1
	dtoverlay: adis16480,vc4-kms-v3d,dwc2
	local,kernel: 6.1.54-v7l+
	uri: local:
IIO context has 4 devices:
	hwmon0: cpu_thermal
		1 channels found:
			temp1:  (input)
			2 channel-specific attributes found:
				attr  0: crit value: 110000
				attr  1: input value: 42842
		No trigger on this device
	hwmon1: rpi_volt
		1 channels found:
			in0:  (input)
			1 channel-specific attributes found:
				attr  0: lcrit_alarm value: 0
	iio:device0: adis16495-1 (buffer capable)
		16 channels found:
			anglvel_x:  (input, index: 0, format: be:S32/32>>0)
			5 channel-specific attributes found:
				attr  0: calibbias value: 0
				attr  1: calibscale value: 0
				attr  2: filter_low_pass_3db_frequency value: 0
				attr  3: raw value: 728554
				attr  4: scale value: 0.000000001
			anglvel_y:  (input, index: 1, format: be:S32/32>>0)
				attr  3: raw value: 866767
			anglvel_z:  (input, index: 2, format: be:S32/32>>0)
				attr  3: raw value: 234102
			accel_x:  (input, index: 3, format: be:S32/32>>0)
				attr  3: raw value: 2059140
				attr  4: scale value: 0.000000037
			accel_y:  (input, index: 4, format: be:S32/32>>0)
				attr  3: raw value: -3379474
			accel_z:  (input, index: 5, format: be:S32/32>>0)
				attr  3: raw value: 262280035
			temp0:  (input, index: 10, format: be:S16/16>>0)
			3 channel-specific attributes found:
				attr  0: offset value: 2000
				attr  1: raw value: 103
				attr  2: scale value: 12.500000
			flags0:  (input, WARN:iio_channel_get_type()=UNKNOWN, index: 17, format: be:U16/16>>0)
			flags1: crc (input, WARN:iio_channel_get_type()=UNKNOWN, index: 18, format: be:U16/16>>0)
				attr  0: label value: crc
			deltavelocity_x:  (input, WARN:iio_channel_get_type()=UNKNOWN)
				attr  0: calibbias ERROR: Invalid argument (22)
				attr  1: raw value: 517
				attr  2: scale value: 0.000000046
			deltaangl_x:  (input, WARN:iio_channel_get_type()=UNKNOWN)
				attr  1: raw value: 2
				attr  2: scale value: 0.000000002
			deltavelocity_y:  (input, WARN:iio_channel_get_type()=UNKNOWN)
				attr  1: raw value: -658
			deltaangl_y:  (input, WARN:iio_channel_get_type()=UNKNOWN)
				attr  1: raw value: -23
			deltaangl_z:  (input, WARN:iio_channel_get_type()=UNKNOWN)
				attr  1: raw value: -65499
			deltavelocity_z:  (input, WARN:iio_channel_get_type()=UNKNOWN)
				attr  1: raw value: 49571
		3 device-specific attributes found:
				attr  0: current_timestamp_clock value: realtime
				attr  1: sampling_frequency value: 4250.000000
				attr  2: waiting_for_supplier value: 0
		2 buffer-specific attributes found:
				attr  0: data_available value: 179
				attr  1: direction value: in
		Current trigger: trigger0(adis16495-1-dev0)
	trigger0: adis16495-1-dev0
		0 channels found:
Thread Notes
