Hello ADI Community,
I'm using the AD9467-FMC-250EBZ ADC with a Zynq-7000 SoC (ZedBoard, XC7Z020) for high-speed signal acquisition.
So far, I have successfully captured data from the AD9467 into DDR memory via DMA in bare-metal (Vitis standalone), and I validate the ADC signal using IIO Oscilloscope. This data is later exported to .csv files for offline ML-based processing in Python.
Now, I want to move to an embedded Linux environment (e.g., PYNQ or Petalinux) on the ZedBoard so I can run Python scripts directly on the board for real-time acquisition, preprocessing, and lightweight ML inference.
My Questions:
How can I enable ADC data acquisition via DMA in a Linux environment for the AD9467-FMC on ZedBoard?
Are there existing device tree overlays, IIO drivers, or reference designs from Analog Devices that support this setup?
Can I use IIO in Linux to continuously stream samples from AD9467 into DDR and log them to a file (e.g.,
.csv) using Python?-
If yes, are there recommended Python bindings (e.g.,
pyadi-iio) that support this?
Does Analog Devices provide a Petalinux BSP or prebuilt IIO support for the AD9467 on Zynq platforms like the ZedBoard or ZCU102?
Is it better to use PYNQ (for quick Python prototyping) or Petalinux (for full-featured embedded development) for this type of work?
My end goal is to:
Stream ADC samples via DMA
Store them to DDR
Use Python to extract features and run a small ML inference model (ideally in real-time)
Any guidance, references, or links to example designs would be hugely appreciated!
Thank you,
Abbas Ali
