ADIS16495-1, EVAL-ADISIMU1-RPIZ and Raspberry Pi 4b
The user was unable to see the ADIS16495 IMU using the IIO Oscilloscope on a Raspberry Pi with the EVAL-ADISIMU1-RPIZ Evaluation Board. The solution was to use the dtoverlay=adis16480,device=adis16495-1 configuration in the config.txt file. The user confirmed this worked.
Product Number: ADIS16495
Software Version: Kuiper Linux 2023_r2 Patch1, ADI Oscilliscope,
Using this IIO Oscilloscope [Analog Devices Wiki], I am not able to see the ADIS16495
Same with
The hardware setup is as follows:
References for software/hardware and avenues tried:
EVAL-ADISIMU1-RPIZ Evaluation Board | Analog Devices
From here ADIS16480 IIO Inertial Measurement Unit Linux Driver [Analog Devices Wiki], it looks like ADIS16480 driver should cover ADIS16495-1
Using 2023_r2 Patch1 from Kuiper Linux Release Notes [Analog Devices Wiki]
Pages I've referenced:
Analog Devices Kuiper Linux [Analog Devices Wiki]
Following directions in "Configuring the SD Card for Raspberry Pi Projects", in config.txt, I've added
dtoverlay=adis16480
I've also tried adding these, but, on startup, it says these overlays are not available.
dtoverlay=adis16495
dtoverlay=rpi-adis16495
dtoverlay=rpi-adis16480
Edit Notes
changed for accuracy description of dtoverlay failed efforts
[edited by: KJNelson at 4:09 PM (GMT -4) on 15 Apr 2025]
