Product Number: zcu102
Software Version: 2021.2
Dear Sir/Madam
We are able to enable the SFP1 in zcu102 board. While doing test it is fine for either link down or UP & assign ip address to eth1 , link detected.
link is detected while running below command
Ethtool -s eth1 speed 1000 duplex full autoneg off .
When autoneg is on link detected shown no.
pinging between zcu102 to pc not happening. How to resolve this issue. Please provide provide proper test procedure to test sfp.
/dts-v1/;
compatible = "xlnx,zynqmp-zcu102-rev1.0\0xlnx,zynqmp-zcu102\0xlnx,zynqmp";
#address-cells = <0x02>;
#size-cells = <0x02>;
model = "ZynqMP ZCU102 Rev1.0";
cpus {
#address-cells = <0x01>;
#size-cells = <0x00>;
cpu@0 {
compatible = "arm,cortex-a53";
device_type = "cpu";
enable-method = "psci";
operating-points-v2 = <0x01>;
reg = <0x00>;
cpu-idle-states = <0x02>;
clocks = <0x03 0x0a>;
phandle = <0x3d>;
cpu@1 {
reg = <0x01>;
phandle = <0x3e>;
cpu@2 {
reg = <0x02>;
phandle = <0x3f>;
cpu@3 {
reg = <0x03>;
phandle = <0x40>;
idle-states {
entry-method = "psci";
cpu-sleep-0 {
compatible = "arm,idle-state";
arm,psci-suspend-param = <0x40000000>;
local-timer-stop;
entry-latency-us = <0x12c>;
exit-latency-us = <0x258>;
min-residency-us = <0x2710>;
phandle = <0x02>;
cpu-opp-table {
compatible = "operating-points-v2";
opp-shared;
phandle = <0x01>;
opp00 {
opp-hz = <0x00 0x47868bf4>;
opp-microvolt = <0xf4240>;
clock-latency-ns = <0x7a120>;
opp01 {
opp-hz = <0x00 0x23c345fa>;
opp02 {
opp-hz = <0x00 0x17d783fc>;
opp03 {
opp-hz = <0x00 0x11e1a2fd>;
zynqmp_ipi {
u-boot,dm-pre-reloc;
compatible = "xlnx,zynqmp-ipi-mailbox";
interrupt-parent = <0x04>;
interrupts = <0x00 0x23 0x04>;
xlnx,ipi-id = <0x00>;
ranges;
phandle = <0x41>;
mailbox@ff990400 {
reg = <0x00 0xff9905c0 0x00 0x20 0x00 0xff9905e0 0x00 0x20 0x00 0xff990e80 0x00 0x20 0x00 0xff990ea0 0x00 0x20>;
reg-names = "local_request_region\0local_response_region\0remote_request_region\0remote_response_region";
#mbox-cells = <0x01>;
xlnx,ipi-id = <0x04>;
phandle = <0x05>;
dcc {
compatible = "arm,dcc";
status = "disabled";
phandle = <0x42>;
pmu {
compatible = "arm,armv8-pmuv3";
interrupts = <0x00 0x8f 0x04 0x00 0x90 0x04 0x00 0x91 0x04 0x00 0x92 0x04>;
psci {
compatible = "arm,psci-0.2";
method = "smc";
firmware {
zynqmp-firmware {
compatible = "xlnx,zynqmp-firmware";
method = "smc";
#power-domain-cells = <0x01>;
phandle = <0x0c>;
zynqmp-power {
compatible = "xlnx,zynqmp-power";
mboxes = <0x05 0x00 0x05 0x01>;
mbox-names = "tx\0rx";
phandle = <0x43>;
nvmem_firmware {
compatible = "xlnx,zynqmp-nvmem-fw";
#size-cells = <0x01>;
soc_revision@0 {
reg = <0x00 0x04>;
phandle = <0x44>;
efuse_dna@c {
reg = <0x0c 0x0c>;
phandle = <0x45>;
efuse_usr0@20 {
reg = <0x20 0x04>;
phandle = <0x46>;
efuse_usr1@24 {
reg = <0x24 0x04>;
phandle = <0x47>;
efuse_usr2@28 {
reg = <0x28 0x04>;
phandle = <0x48>;
efuse_usr3@2c {
reg = <0x2c 0x04>;
phandle = <0x49>;
efuse_usr4@30 {
reg = <0x30 0x04>;
phandle = <0x4a>;
efuse_usr5@34 {
reg = <0x34 0x04>;
phandle = <0x4b>;
efuse_usr6@38 {
reg = <0x38 0x04>;
phandle = <0x4c>;
efuse_usr7@3c {
reg = <0x3c 0x04>;
phandle = <0x4d>;
efuse_miscusr@40 {
reg = <0x40 0x04>;
phandle = <0x4e>;
efuse_chash@50 {
reg = <0x50 0x04>;
phandle = <0x4f>;
efuse_pufmisc@54 {
reg = <0x54 0x04>;
phandle = <0x50>;
efuse_sec@58 {
reg = <0x58 0x04>;
phandle = <0x51>;
efuse_spkid@5c {
reg = <0x5c 0x04>;
phandle = <0x52>;
efuse_ppk0hash@a0 {
reg = <0xa0 0x30>;
phandle = <0x53>;
efuse_ppk1hash@d0 {
reg = <0xd0 0x30>;
phandle = <0x54>;
pcap {
compatible = "xlnx,zynqmp-pcap-fpga";
clock-names = "ref_clk";
clocks = <0x03 0x29>;
phandle = <0x0b>;
zynqmp-aes {
compatible = "xlnx,zynqmp-aes";
phandle = <0x55>;
reset-controller {
compatible = "xlnx,zynqmp-reset";
#reset-cells = <0x01>;
phandle = <0x1d>;
pinctrl {
compatible = "xlnx,zynqmp-pinctrl";
status = "okay";
phandle = <0x56>;
i2c0-default {
phandle = <0x14>;
mux {
groups = "i2c0_3_grp";
function = "i2c0";
conf {
bias-pull-up;
slew-rate = <0x01>;
power-source = <0x01>;
i2c0-gpio {
phandle = <0x15>;
mux {
groups = "gpio0_14_grp\0gpio0_15_grp";
function = "gpio0";
conf {
slew-rate = <0x01>;
i2c1-default {
phandle = <0x16>;
mux {
groups = "i2c1_4_grp";
function = "i2c1";
conf {
bias-pull-up;
slew-rate = <0x01>;
i2c1-gpio {
phandle = <0x17>;
mux {
groups = "gpio0_16_grp\0gpio0_17_grp";
function = "gpio0";
conf {
slew-rate = <0x01>;
uart0-default {
phandle = <0x20>;
mux {
groups = "uart0_4_grp";
function = "uart0";
conf {
slew-rate = <0x01>;
conf-rx {
pins = "MIO18";
bias-high-impedance;
conf-tx {
pins = "MIO19";
bias-disable;
uart1-default {
phandle = <0x21>;
mux {
groups = "uart1_5_grp";
function = "uart1";
conf {
slew-rate = <0x01>;
conf-rx {
pins = "MIO21";
conf-tx {
pins = "MIO20";
bias-disable;
usb0-default {
phandle = <0x23>;
mux {
groups = "usb0_0_grp";
function = "usb0";
conf {
slew-rate = <0x01>;
conf-rx {
pins = "MIO52\0MIO53\0MIO55";
conf-tx {
pins = "MIO54\0MIO56\0MIO57\0MIO58\0MIO59\0MIO60\0MIO61\0MIO62\0MIO63";
bias-disable;
gem3-default {
phandle = <0x12>;
mux {
function = "ethernet3";
groups = "ethernet3_0_grp";
conf {
slew-rate = <0x01>;
conf-rx {
pins = "MIO70\0MIO71\0MIO72\0MIO73\0MIO74\0MIO75";
low-power-disable;
conf-tx {
pins = "MIO64\0MIO65\0MIO66\0MIO67\0MIO68\0MIO69";
bias-disable;
low-power-enable;
mux-mdio {
function = "mdio3";
groups = "mdio3_0_grp";
conf-mdio {
slew-rate = <0x01>;
bias-disable;
can1-default {
phandle = <0x0d>;
mux {
function = "can1";
groups = "can1_6_grp";
conf {
slew-rate = <0x01>;
conf-rx {
pins = "MIO25";
conf-tx {
pins = "MIO24";
bias-disable;
sdhci1-default {
phandle = <0x1f>;
mux {
groups = "sdio1_0_grp";
function = "sdio1";
conf {
slew-rate = <0x01>;
bias-disable;
mux-cd {
groups = "sdio1_cd_0_grp";
function = "sdio1_cd";
conf-cd {
bias-pull-up;
slew-rate = <0x01>;
mux-wp {
groups = "sdio1_wp_0_grp";
function = "sdio1_wp";
conf-wp {
bias-pull-up;
slew-rate = <0x01>;
gpio-default {
phandle = <0x13>;
mux-sw {
function = "gpio0";
groups = "gpio0_22_grp\0gpio0_23_grp";
conf-sw {
slew-rate = <0x01>;
mux-msp {
function = "gpio0";
groups = "gpio0_13_grp\0gpio0_38_grp";
conf-msp {
slew-rate = <0x01>;
conf-pull-up {
pins = "MIO22\0MIO23";
bias-pull-up;
conf-pull-none {
pins = "MIO13\0MIO38";
bias-disable;
sha384 {
compatible = "xlnx,zynqmp-keccak-384";
phandle = <0x57>;
zynqmp-rsa {
compatible = "xlnx,zynqmp-rsa";
phandle = <0x58>;
gpio {
compatible = "xlnx,zynqmp-gpio-modepin";
gpio-controller;
#gpio-cells = <0x02>;
phandle = <0x22>;
clock-controller {
#clock-cells = <0x01>;
compatible = "xlnx,zynqmp-clk";
clocks = <0x06 0x07 0x08 0x09 0x0a>;
clock-names = "pss_ref_clk\0video_clk\0pss_alt_ref_clk\0aux_ref_clk\0gt_crx_ref_clk";
phandle = <0x03>;
timer {
compatible = "arm,armv8-timer";
interrupts = <0x01 0x0d 0xf08 0x01 0x0e 0xf08 0x01 0x0b 0xf08 0x01 0x0a 0xf08>;
edac {
compatible = "arm,cortex-a53-edac";
fpga-full {
compatible = "fpga-region";
fpga-mgr = <0x0b>;
ranges;
phandle = <0x59>;
axi {
compatible = "simple-bus";
ranges;
phandle = <0x5a>;
can@ff060000 {
compatible = "xlnx,zynq-can-1.0";
clock-names = "can_clk\0pclk";
reg = <0x00 0xff060000 0x00 0x1000>;
interrupts = <0x00 0x17 0x04>;
tx-fifo-depth = <0x40>;
rx-fifo-depth = <0x40>;
power-domains = <0x0c 0x2f>;
clocks = <0x03 0x3f 0x03 0x1f>;
phandle = <0x5b>;
can@ff070000 {
status = "okay";
reg = <0x00 0xff070000 0x00 0x1000>;
interrupts = <0x00 0x18 0x04>;
power-domains = <0x0c 0x30>;
clocks = <0x03 0x40 0x03 0x1f>;
pinctrl-names = "default";
pinctrl-0 = <0x0d>;
phandle = <0x5c>;
cci@fd6e0000 {
compatible = "arm,cci-400";
status = "okay";
reg = <0x00 0xfd6e0000 0x00 0x9000>;
ranges = <0x00 0x00 0xfd6e0000 0x10000>;
phandle = <0x5d>;
pmu@9000 {
compatible = "arm,cci-400-pmu,r1";
reg = <0x9000 0x5000>;
interrupts = <0x00 0x7b 0x04 0x00 0x7b 0x04 0x00 0x7b 0x04 0x00 0x7b 0x04 0x00 0x7b 0x04>;
dma@fd500000 {
status = "okay";
compatible = "xlnx,zynqmp-dma-1.0";
reg = <0x00 0xfd500000 0x00 0x1000>;
interrupts = <0x00 0x7c 0x04>;
clock-names = "clk_main\0clk_apb";
xlnx,bus-width = <0x80>;
#stream-id-cells = <0x01>;
iommus = <0x0e 0x14e8>;
power-domains = <0x0c 0x2a>;
clocks = <0x03 0x13 0x03 0x1f>;
phandle = <0x5e>;
dma@fd510000 {
status = "okay";
reg = <0x00 0xfd510000 0x00 0x1000>;
interrupts = <0x00 0x7d 0x04>;
iommus = <0x0e 0x14e9>;
phandle = <0x5f>;
dma@fd520000 {
status = "okay";
reg = <0x00 0xfd520000 0x00 0x1000>;
interrupts = <0x00 0x7e 0x04>;
iommus = <0x0e 0x14ea>;
phandle = <0x60>;
dma@fd530000 {
status = "okay";
reg = <0x00 0xfd530000 0x00 0x1000>;
interrupts = <0x00 0x7f 0x04>;
iommus = <0x0e 0x14eb>;
phandle = <0x61>;
dma@fd540000 {
status = "okay";
reg = <0x00 0xfd540000 0x00 0x1000>;
interrupts = <0x00 0x80 0x04>;
iommus = <0x0e 0x14ec>;
phandle = <0x62>;
dma@fd550000 {
status = "okay";
reg = <0x00 0xfd550000 0x00 0x1000>;
interrupts = <0x00 0x81 0x04>;
iommus = <0x0e 0x14ed>;
phandle = <0x63>;
dma@fd560000 {
status = "okay";
reg = <0x00 0xfd560000 0x00 0x1000>;
interrupts = <0x00 0x82 0x04>;
iommus = <0x0e 0x14ee>;
phandle = <0x64>;
dma@fd570000 {
status = "okay";
reg = <0x00 0xfd570000 0x00 0x1000>;
interrupts = <0x00 0x83 0x04>;
iommus = <0x0e 0x14ef>;
phandle = <0x65>;
interrupt-controller@f9010000 {
compatible = "arm,gic-400";
#interrupt-cells = <0x03>;
reg = <0x00 0xf9010000 0x00 0x10000 0x00 0xf9020000 0x00 0x20000 0x00 0xf9040000 0x00 0x20000 0x00 0xf9060000 0x00 0x20000>;
interrupt-controller;
interrupts = <0x01 0x09 0xf04>;
num_cpus = <0x02>;
num_interrupts = <0x60>;
phandle = <0x04>;
gpu@fd4b0000 {
status = "okay";
compatible = "arm,mali-400\0arm,mali-utgard";
reg = <0x00 0xfd4b0000 0x00 0x10000>;
interrupts = <0x00 0x84 0x04 0x00 0x84 0x04 0x00 0x84 0x04 0x00 0x84 0x04 0x00 0x84 0x04 0x00 0x84 0x04>;
interrupt-names = "IRQGP\0IRQGPMMU\0IRQPP0\0IRQPPMMU0\0IRQPP1\0IRQPPMMU1";
clock-names = "gpu\0gpu_pp0\0gpu_pp1";
power-domains = <0x0c 0x3a>;
clocks = <0x03 0x18 0x03 0x19 0x03 0x1a>;
xlnx,tz-nonsecure = <0x01>;
phandle = <0x66>;
dma@ffa80000 {
status = "okay";
reg = <0x00 0xffa80000 0x00 0x1000>;
interrupts = <0x00 0x4d 0x04>;
xlnx,bus-width = <0x40>;
power-domains = <0x0c 0x2b>;
clocks = <0x03 0x44 0x03 0x1f>;
phandle = <0x67>;
dma@ffa90000 {
status = "okay";
reg = <0x00 0xffa90000 0x00 0x1000>;
interrupts = <0x00 0x4e 0x04>;
phandle = <0x68>;
dma@ffaa0000 {
status = "okay";
reg = <0x00 0xffaa0000 0x00 0x1000>;
interrupts = <0x00 0x4f 0x04>;
phandle = <0x69>;
dma@ffab0000 {
status = "okay";
reg = <0x00 0xffab0000 0x00 0x1000>;
interrupts = <0x00 0x50 0x04>;
phandle = <0x6a>;
dma@ffac0000 {
status = "okay";
reg = <0x00 0xffac0000 0x00 0x1000>;
interrupts = <0x00 0x51 0x04>;
phandle = <0x6b>;
dma@ffad0000 {
status = "okay";
reg = <0x00 0xffad0000 0x00 0x1000>;
interrupts = <0x00 0x52 0x04>;
phandle = <0x6c>;
dma@ffae0000 {
status = "okay";
reg = <0x00 0xffae0000 0x00 0x1000>;
interrupts = <0x00 0x53 0x04>;
phandle = <0x6d>;
dma@ffaf0000 {
status = "okay";
reg = <0x00 0xffaf0000 0x00 0x1000>;
interrupts = <0x00 0x54 0x04>;
phandle = <0x6e>;
memory-controller@fd070000 {
compatible = "xlnx,zynqmp-ddrc-2.40a";
reg = <0x00 0xfd070000 0x00 0x30000>;
interrupts = <0x00 0x70 0x04>;
phandle = <0x6f>;
nand-controller@ff100000 {
compatible = "xlnx,zynqmp-nand-controller\0arasan,nfc-v3p10";
reg = <0x00 0xff100000 0x00 0x1000>;
clock-names = "controller\0bus";
interrupts = <0x00 0x0e 0x04>;
iommus = <0x0e 0x872>;
power-domains = <0x0c 0x2c>;
clocks = <0x03 0x3c 0x03 0x1f>;
phandle = <0x70>;
ethernet@ff0b0000 {
compatible = "cdns,zynqmp-gem\0cdns,gem";
interrupts = <0x00 0x39 0x04 0x00 0x39 0x04>;
reg = <0x00 0xff0b0000 0x00 0x1000>;
clock-names = "pclk\0hclk\0tx_clk\0rx_clk\0tsu_clk";
iommus = <0x0e 0x874>;
power-domains = <0x0c 0x1d>;
clocks = <0x03 0x1f 0x03 0x68 0x03 0x2d 0x03 0x31 0x03 0x2c>;
phy-handle = <0x0f>;
phandle = <0x71>;
ethernet@ff0c0000 {
interrupts = <0x00 0x3b 0x04 0x00 0x3b 0x04>;
reg = <0x00 0xff0c0000 0x00 0x1000>;
iommus = <0x0e 0x875>;
power-domains = <0x0c 0x1e>;
clocks = <0x03 0x1f 0x03 0x69 0x03 0x2e 0x03 0x32 0x03 0x2c>;
phandle = <0x72>;
ethernet@ff0d0000 {
interrupts = <0x00 0x3d 0x04 0x00 0x3d 0x04>;
reg = <0x00 0xff0d0000 0x00 0x1000>;
iommus = <0x0e 0x876>;
power-domains = <0x0c 0x1f>;
clocks = <0x03 0x1f 0x03 0x6a 0x03 0x2f 0x03 0x33 0x03 0x2c>;
phandle = <0x73>;
ethernet@ff0e0000 {
status = "okay";
interrupts = <0x00 0x3f 0x04 0x00 0x3f 0x04>;
reg = <0x00 0xff0e0000 0x00 0x1000>;
iommus = <0x0e 0x877>;
power-domains = <0x0c 0x20>;
clocks = <0x03 0x1f 0x03 0x6b 0x03 0x30 0x03 0x34 0x03 0x2c>;
phy-handle = <0x11>;
pinctrl-0 = <0x12>;
phy-mode = "rgmii-id";
xlnx,ptp-enet-clock = <0x00>;
local-mac-address = [ff ff ff ff ff ff];
phandle = <0x74>;
ethernet-phy@c {
reg = <0x0c>;
ti,rx-internal-delay = <0x08>;
ti,tx-internal-delay = <0x0a>;
ti,fifo-depth = <0x01>;
ti,dp83867-rxctrl-strap-quirk;
phandle = <0x11>;
gpio@ff0a0000 {
compatible = "xlnx,zynqmp-gpio-1.0";
status = "okay";
gpio-controller;
interrupts = <0x00 0x10 0x04>;
#interrupt-cells = <0x02>;
reg = <0x00 0xff0a0000 0x00 0x1000>;
power-domains = <0x0c 0x2e>;
clocks = <0x03 0x1f>;
pinctrl-0 = <0x13>;
emio-gpio-width = <0x20>;
gpio-mask-high = <0x00>;
gpio-mask-low = <0x5600>;
phandle = <0x10>;
i2c@ff020000 {
compatible = "cdns,i2c-r1p14";
status = "okay";
interrupts = <0x00 0x11 0x04>;
reg = <0x00 0xff020000 0x00 0x1000>;
power-domains = <0x0c 0x25>;
clocks = <0x03 0x3d>;
pinctrl-names = "default\0gpio";
pinctrl-0 = <0x14>;
pinctrl-1 = <0x15>;
scl-gpios = <0x10 0x0e 0x00>;
sda-gpios = <0x10 0x0f 0x00>;
clock-frequency = <0x61a80>;
phandle = <0x75>;
gpio@20 {
compatible = "ti,tca6416";
reg = <0x20>;
gpio-controller;
gpio-line-names = "PS_GTR_LAN_SEL0\0PS_GTR_LAN_SEL1\0PS_GTR_LAN_SEL2\0PS_GTR_LAN_SEL3\0PCI_CLK_DIR_SEL\0IIC_MUX_RESET_B\0GEM3_EXP_RESET_B\0\0\0\0\0\0\0\0\0";
phandle = <0x76>;
gpio@21 {
reg = <0x21>;
gpio-controller;
gpio-line-names = "VCCPSPLL_EN\0MGTRAVCC_EN\0MGTRAVTT_EN\0VCCPSDDRPLL_EN\0MIO26_PMU_INPUT_LS\0PL_PMBUS_ALERT\0PS_PMBUS_ALERT\0MAXIM_PMBUS_ALERT\0PL_DDR4_VTERM_EN\0PL_DDR4_VPP_2V5_EN\0PS_DIMM_VDDQ_TO_PSVCCO_ON\0PS_DIMM_SUSPEND_EN\0PS_DDR4_VTERM_EN\0PS_DDR4_VPP_2V5_EN\0\0";
phandle = <0x77>;
i2c-mux@75 {
compatible = "nxp,pca9544";
reg = <0x75>;
i2c@0 {
reg = <0x00>;
ina226@40 {
compatible = "ti,ina226";
#io-channel-cells = <0x01>;
label = "ina226-u76";
reg = <0x40>;
shunt-resistor = <0x1388>;
phandle = <0x29>;
ina226@41 {
label = "ina226-u77";
reg = <0x41>;
phandle = <0x2a>;
ina226@42 {
label = "ina226-u78";
reg = <0x42>;
phandle = <0x2b>;
ina226@43 {
label = "ina226-u87";
reg = <0x43>;
phandle = <0x2c>;
ina226@44 {
label = "ina226-u85";
reg = <0x44>;
phandle = <0x2d>;
ina226@45 {
label = "ina226-u86";
reg = <0x45>;
phandle = <0x2e>;
ina226@46 {
label = "ina226-u93";
reg = <0x46>;
phandle = <0x2f>;
ina226@47 {
label = "ina226-u88";
reg = <0x47>;
phandle = <0x30>;
ina226@4a {
label = "ina226-u15";
reg = <0x4a>;
phandle = <0x31>;
ina226@4b {
label = "ina226-u92";
reg = <0x4b>;
phandle = <0x32>;
i2c@1 {
reg = <0x01>;
ina226@40 {
label = "ina226-u79";
reg = <0x40>;
shunt-resistor = <0x7d0>;
phandle = <0x33>;
ina226@41 {
label = "ina226-u81";
reg = <0x41>;
phandle = <0x34>;
ina226@42 {
label = "ina226-u80";
reg = <0x42>;
phandle = <0x35>;
ina226@43 {
label = "ina226-u84";
reg = <0x43>;
phandle = <0x36>;
ina226@44 {
label = "ina226-u16";
reg = <0x44>;
phandle = <0x37>;
ina226@45 {
label = "ina226-u65";
reg = <0x45>;
phandle = <0x38>;
ina226@46 {
label = "ina226-u74";
reg = <0x46>;
phandle = <0x39>;
ina226@47 {
label = "ina226-u75";
reg = <0x47>;
phandle = <0x3a>;
i2c@2 {
reg = <0x02>;
max15301@a {
compatible = "maxim,max15301";
reg = <0x0a>;
max15303@b {
compatible = "maxim,max15303";
reg = <0x0b>;
max15303@10 {
reg = <0x10>;
max15301@13 {
reg = <0x13>;
max15303@14 {
reg = <0x14>;
max15303@15 {
reg = <0x15>;
max15303@16 {
reg = <0x16>;
max15303@17 {
reg = <0x17>;
max15301@18 {
reg = <0x18>;
max15303@1a {
reg = <0x1a>;
max15303@1b {
reg = <0x1b>;
max15303@1d {
reg = <0x1d>;
max20751@72 {
compatible = "maxim,max20751";
reg = <0x72>;
max20751@73 {
reg = <0x73>;
i2c@ff030000 {
status = "okay";
interrupts = <0x00 0x12 0x04>;
reg = <0x00 0xff030000 0x00 0x1000>;
power-domains = <0x0c 0x26>;
clocks = <0x03 0x3e>;
pinctrl-0 = <0x16>;
pinctrl-1 = <0x17>;
scl-gpios = <0x10 0x10 0x00>;
sda-gpios = <0x10 0x11 0x00>;
phandle = <0x78>;
i2c-mux@74 {
compatible = "nxp,pca9548";
reg = <0x74>;
i2c@0 {
reg = <0x00>;
eeprom@54 {
compatible = "atmel,24c08";
reg = <0x54>;
phandle = <0x79>;
board-sn@0 {
reg = <0x00 0x14>;
phandle = <0x7a>;
eth-mac@20 {
reg = <0x20 0x06>;
phandle = <0x7b>;
board-name@d0 {
reg = <0xd0 0x06>;
phandle = <0x7c>;
board-revision@e0 {
reg = <0xe0 0x03>;
phandle = <0x7d>;
i2c@1 {
reg = <0x01>;
clock-generator@36 {
compatible = "silabs,si5341";
reg = <0x36>;
#clock-cells = <0x02>;
clocks = <0x18>;
clock-names = "xtal";
clock-output-names = "si5341";
phandle = <0x1c>;
out@0 {
reg = <0x00>;
always-on;
phandle = <0x7e>;
out@2 {
reg = <0x02>;
always-on;
phandle = <0x7f>;
out@3 {
reg = <0x03>;
always-on;
phandle = <0x80>;
out@4 {
reg = <0x04>;
always-on;
phandle = <0x81>;
out@5 {
reg = <0x05>;
always-on;
phandle = <0x82>;
out@6 {
reg = <0x06>;
always-on;
phandle = <0x83>;
out@7 {
reg = <0x07>;
always-on;
phandle = <0x84>;
out@9 {
reg = <0x09>;
always-on;
phandle = <0x85>;
i2c@2 {
reg = <0x02>;
clock-generator@5d {
#clock-cells = <0x00>;
compatible = "silabs,si570";
reg = <0x5d>;
temperature-stability = <0x32>;
factory-fout = <0x11e1a300>;
clock-frequency = <0x11e1a300>;
clock-output-names = "si570_user";
phandle = <0x86>;
i2c@3 {
reg = <0x03>;
reg = <0x5d>;
factory-fout = <0x9502f90>;
clock-frequency = <0x9502f90>;
clock-output-names = "si570_mgt";
phandle = <0x87>;
i2c@4 {
reg = <0x04>;
clock-generator@69 {
compatible = "silabs,si5328";
reg = <0x69>;
clocks = <0x19>;
clock-output-names = "si5328";
phandle = <0x88>;
clk0@0 {
reg = <0x00>;
clock-frequency = <0x19bfcc0>;
phandle = <0x89>;
i2c-mux@75 {
reg = <0x75>;
i2c@0 {
reg = <0x00>;
i2c@1 {
reg = <0x01>;
i2c@2 {
reg = <0x02>;
i2c@3 {
reg = <0x03>;
i2c@4 {
reg = <0x04>;
i2c@5 {
reg = <0x05>;
i2c@6 {
reg = <0x06>;
eeprom@50 {
compatible = "atmel,24c02";
reg = <0x50>;
i2c@7 {
reg = <0x07>;
memory-controller@ff960000 {
compatible = "xlnx,zynqmp-ocmc-1.0";
reg = <0x00 0xff960000 0x00 0x1000>;
interrupts = <0x00 0x0a 0x04>;
phandle = <0x8a>;
perf-monitor@ffa00000 {
compatible = "xlnx,axi-perf-monitor";
reg = <0x00 0xffa00000 0x00 0x10000>;
interrupts = <0x00 0x19 0x04>;
xlnx,enable-profile = <0x00>;
xlnx,enable-trace = <0x00>;
xlnx,num-monitor-slots = <0x01>;
xlnx,enable-event-count = <0x01>;
xlnx,enable-event-log = <0x01>;
xlnx,have-sampled-metric-cnt = <0x01>;
xlnx,num-of-counters = <0x08>;
xlnx,metric-count-width = <0x20>;
xlnx,metrics-sample-count-width = <0x20>;
xlnx,global-count-width = <0x20>;
xlnx,metric-count-scale = <0x01>;
phandle = <0x8b>;
perf-monitor@fd0b0000 {
reg = <0x00 0xfd0b0000 0x00 0x10000>;
interrupts = <0x00 0x7b 0x04>;
xlnx,num-monitor-slots = <0x06>;
xlnx,enable-event-log = <0x00>;
xlnx,num-of-counters = <0x0a>;
clocks = <0x03 0x1c>;
phandle = <0x8c>;
perf-monitor@fd490000 {
reg = <0x00 0xfd490000 0x00 0x10000>;
phandle = <0x8d>;
perf-monitor@ffa10000 {
reg = <0x00 0xffa10000 0x00 0x10000>;
phandle = <0x8e>;
pcie@fd0e0000 {
compatible = "xlnx,nwl-pcie-2.11";
status = "okay";
#address-cells = <0x03>;
#interrupt-cells = <0x01>;
msi-controller;
device_type = "pci";
interrupts = <0x00 0x76 0x04 0x00 0x75 0x04 0x00 0x74 0x04 0x00 0x73 0x04 0x00 0x72 0x04>;
interrupt-names = "misc\0dummy\0intx\0msi1\0msi0";
msi-parent = <0x1a>;
reg = <0x00 0xfd0e0000 0x00 0x1000 0x00 0xfd480000 0x00 0x1000 0x80 0x00 0x00 0x1000000>;
reg-names = "breg\0pcireg\0cfg";
ranges = <0x2000000 0x00 0xe0000000 0x00 0xe0000000 0x00 0x10000000 0x43000000 0x06 0x00 0x06 0x00 0x02 0x00>;
interrupt-map-mask = <0x00 0x00 0x00 0x07>;
bus-range = <0x00 0xff>;
interrupt-map = <0x00 0x00 0x00 0x01 0x1b 0x01 0x00 0x00 0x00 0x02 0x1b 0x02 0x00 0x00 0x00 0x03 0x1b 0x03 0x00 0x00 0x00 0x04 0x1b 0x04>;
iommus = <0x0e 0x4d0>;
power-domains = <0x0c 0x3b>;
clocks = <0x03 0x17>;
xlnx,bar0-enable = <0x00>;
xlnx,bar1-enable = <0x00>;
xlnx,bar2-enable = <0x00>;
xlnx,bar3-enable = <0x00>;
xlnx,bar4-enable = <0x00>;
xlnx,bar5-enable = <0x00>;
xlnx,pcie-mode = "Root Port";
xlnx,tz-nonsecure = <0x00>;
phandle = <0x1a>;
legacy-interrupt-controller {
#address-cells = <0x00>;
phandle = <0x1b>;
spi@ff0f0000 {
compatible = "xlnx,zynqmp-qspi-1.0";
status = "okay";
clock-names = "ref_clk\0pclk";
interrupts = <0x00 0x0f 0x04>;
num-cs = <0x01>;
reg = <0x00 0xff0f0000 0x00 0x1000 0x00 0xc0000000 0x00 0x8000000>;
iommus = <0x0e 0x873>;
power-domains = <0x0c 0x2d>;
clocks = <0x03 0x35 0x03 0x1f>;
is-dual = <0x01>;
spi-rx-bus-width = <0x04>;
spi-tx-bus-width = <0x04>;
phandle = <0x8f>;
flash@0 {
compatible = "m25p80\0jedec,spi-nor";
reg = <0x00>;
spi-tx-bus-width = <0x01>;
spi-max-frequency = <0x66ff300>;
phandle = <0x90>;
partition@0 {
label = "boot";
reg = <0x00 0x100000>;
partition@1 {
label = "bootenv";
reg = <0x100000 0x40000>;
partition@2 {
label = "kernel";
reg = <0x140000 0x1600000>;
phy@fd400000 {
compatible = "xlnx,zynqmp-psgtr-v1.1";
status = "okay";
reg = <0x00 0xfd400000 0x00 0x40000 0x00 0xfd3d0000 0x00 0x1000>;
reg-names = "serdes\0siou";
#phy-cells = <0x04>;
clocks = <0x1c 0x00 0x05 0x1c 0x00 0x03 0x1c 0x00 0x02 0x1c 0x00 0x00>;
clock-names = "ref0\0ref1\0ref2\0ref3";
phandle = <0x1e>;
rtc@ffa60000 {
compatible = "xlnx,zynqmp-rtc";
status = "okay";
reg = <0x00 0xffa60000 0x00 0x100>;
interrupts = <0x00 0x1a 0x04 0x00 0x1b 0x04>;
interrupt-names = "alarm\0sec";
calibration = <0x7fff>;
phandle = <0x91>;
ahci@fd0c0000 {
compatible = "ceva,ahci-1v84";
status = "okay";
reg = <0x00 0xfd0c0000 0x00 0x2000>;
interrupts = <0x00 0x85 0x04>;
power-domains = <0x0c 0x1c>;
resets = <0x1d 0x10>;
#stream-id-cells = <0x04>;
clocks = <0x03 0x16>;
ceva,p0-cominit-params = <0x18401828>;
ceva,p0-comwake-params = <0x614080e>;
ceva,p0-burst-params = <0x13084a06>;
ceva,p0-retry-params = <0x96a43ffc>;
ceva,p1-cominit-params = <0x18401828>;
ceva,p1-comwake-params = <0x614080e>;
ceva,p1-burst-params = <0x13084a06>;
ceva,p1-retry-params = <0x96a43ffc>;
phy-names = "sata-phy";
phys = <0x1e 0x03 0x01 0x01 0x01>;
xlnx,tz-nonsecure-sata0 = <0x00>;
xlnx,tz-nonsecure-sata1 = <0x00>;
phandle = <0x92>;
mmc@ff160000 {
compatible = "xlnx,zynqmp-8.9a\0arasan,sdhci-8.9a";
interrupts = <0x00 0x30 0x04>;
reg = <0x00 0xff160000 0x00 0x1000>;
clock-names = "clk_xin\0clk_ahb";
xlnx,device_id = <0x00>;
iommus = <0x0e 0x870>;
power-domains = <0x0c 0x27>;
clock-output-names = "clk_out_sd0\0clk_in_sd0";
clocks = <0x03 0x36 0x03 0x1f>;
phandle = <0x93>;
mmc@ff170000 {
status = "okay";
interrupts = <0x00 0x31 0x04>;
reg = <0x00 0xff170000 0x00 0x1000>;
xlnx,device_id = <0x01>;
iommus = <0x0e 0x871>;
power-domains = <0x0c 0x28>;
clock-output-names = "clk_out_sd1\0clk_in_sd1";
clocks = <0x03 0x37 0x03 0x1f>;
pinctrl-0 = <0x1f>;
no-1-8-v;
clock-frequency = <0xb2cbcae>;
xlnx,mio-bank = <0x01>;
phandle = <0x94>;
smmu@fd800000 {
compatible = "arm,mmu-500";
reg = <0x00 0xfd800000 0x00 0x20000>;
#iommu-cells = <0x01>;
#global-interrupts = <0x01>;
interrupts = <0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04>;
phandle = <0x0e>;
spi@ff040000 {
compatible = "cdns,spi-r1p6";
interrupts = <0x00 0x13 0x04>;
reg = <0x00 0xff040000 0x00 0x1000>;
power-domains = <0x0c 0x23>;
clocks = <0x03 0x3a 0x03 0x1f>;
phandle = <0x95>;
spi@ff050000 {
interrupts = <0x00 0x14 0x04>;
reg = <0x00 0xff050000 0x00 0x1000>;
power-domains = <0x0c 0x24>;
clocks = <0x03 0x3b 0x03 0x1f>;
phandle = <0x96>;
timer@ff110000 {
compatible = "cdns,ttc";
interrupts = <0x00 0x24 0x04 0x00 0x25 0x04 0x00 0x26 0x04>;
reg = <0x00 0xff110000 0x00 0x1000>;
timer-width = <0x20>;
power-domains = <0x0c 0x18>;
phandle = <0x97>;
timer@ff120000 {
interrupts = <0x00 0x27 0x04 0x00 0x28 0x04 0x00 0x29 0x04>;
reg = <0x00 0xff120000 0x00 0x1000>;
power-domains = <0x0c 0x19>;
phandle = <0x98>;
timer@ff130000 {
interrupts = <0x00 0x2a 0x04 0x00 0x2b 0x04 0x00 0x2c 0x04>;
reg = <0x00 0xff130000 0x00 0x1000>;
power-domains = <0x0c 0x1a>;
phandle = <0x99>;
timer@ff140000 {
interrupts = <0x00 0x2d 0x04 0x00 0x2e 0x04 0x00 0x2f 0x04>;
reg = <0x00 0xff140000 0x00 0x1000>;
power-domains = <0x0c 0x1b>;
phandle = <0x9a>;
serial@ff000000 {
compatible = "cdns,uart-r1p12\0xlnx,xuartps";
status = "okay";
interrupts = <0x00 0x15 0x04>;
reg = <0x00 0xff000000 0x00 0x1000>;
clock-names = "uart_clk\0pclk";
power-domains = <0x0c 0x21>;
clocks = <0x03 0x38 0x03 0x1f>;
pinctrl-0 = <0x20>;
cts-override;
device_type = "serial";
port-number = <0x00>;
phandle = <0x9b>;
serial@ff010000 {
status = "okay";
interrupts = <0x00 0x16 0x04>;
reg = <0x00 0xff010000 0x00 0x1000>;
power-domains = <0x0c 0x22>;
clocks = <0x03 0x39 0x03 0x1f>;
pinctrl-0 = <0x21>;
cts-override;
port-number = <0x01>;
phandle = <0x9c>;
usb0@ff9d0000 {
status = "okay";
compatible = "xlnx,zynqmp-dwc3";
reg = <0x00 0xff9d0000 0x00 0x100>;
clock-names = "bus_clk\0ref_clk";
power-domains = <0x0c 0x16>;
resets = <0x1d 0x3b 0x1d 0x3d 0x1d 0x3f>;
reset-names = "usb_crst\0usb_hibrst\0usb_apbrst";
reset-gpio = <0x22 0x01 0x00>;
ranges;
clocks = <0x03 0x20 0x03 0x22>;
pinctrl-0 = <0x23>;
phy-names = "usb3-phy";
phys = <0x1e 0x02 0x04 0x00 0x02>;
xlnx,usb-polarity = <0x00>;
xlnx,usb-reset-mode = <0x00>;
phandle = <0x9d>;
dwc3@fe200000 {
compatible = "snps,dwc3";
status = "okay";
reg = <0x00 0xfe200000 0x00 0x40000>;
interrupt-names = "dwc_usb3\0otg\0hiber";
interrupts = <0x00 0x41 0x04 0x00 0x45 0x04 0x00 0x4b 0x04>;
iommus = <0x0e 0x860>;
snps,quirk-frame-length-adjustment = <0x20>;
snps,refclk_fladj;
snps,enable_guctl1_resume_quirk;
snps,enable_guctl1_ipd_quirk;
snps,xhci-stream-quirk;
dr_mode = "host";
snps,usb3_lpm_capable;
maximum-speed = "super-speed";
phandle = <0x9e>;
usb1@ff9e0000 {
reg = <0x00 0xff9e0000 0x00 0x100>;
power-domains = <0x0c 0x17>;
resets = <0x1d 0x3c 0x1d 0x3e 0x1d 0x40>;
ranges;
clocks = <0x03 0x21 0x03 0x22>;
phandle = <0x9f>;
dwc3@fe300000 {
reg = <0x00 0xfe300000 0x00 0x40000>;
interrupts = <0x00 0x46 0x04 0x00 0x4a 0x04 0x00 0x4c 0x04>;
iommus = <0x0e 0x861>;
snps,refclk_fladj;
phandle = <0xa0>;
watchdog@fd4d0000 {
compatible = "cdns,wdt-r1p2";
status = "okay";
interrupts = <0x00 0x71 0x01>;
reg = <0x00 0xfd4d0000 0x00 0x1000>;
timeout-sec = <0x3c>;
reset-on-timeout;
clocks = <0x03 0x4b>;
phandle = <0xa1>;
watchdog@ff150000 {
status = "okay";
interrupts = <0x00 0x34 0x01>;
reg = <0x00 0xff150000 0x00 0x1000>;
timeout-sec = <0x0a>;
clocks = <0x03 0x70>;
phandle = <0xa2>;
ams@ffa50000 {
compatible = "xlnx,zynqmp-ams";
status = "okay";
interrupts = <0x00 0x38 0x04>;
interrupt-names = "ams-irq";
reg = <0x00 0xffa50000 0x00 0x800>;
reg-names = "ams-base";
ranges;
clocks = <0x03 0x46>;
phandle = <0xa3>;
ams_ps@ffa50800 {
compatible = "xlnx,zynqmp-ams-ps";
status = "okay";
reg = <0x00 0xffa50800 0x00 0x400>;
phandle = <0xa4>;
ams_pl@ffa50c00 {
compatible = "xlnx,zynqmp-ams-pl";
status = "okay";
reg = <0x00 0xffa50c00 0x00 0x400>;
phandle = <0xa5>;
dma-controller@fd4c0000 {
compatible = "xlnx,zynqmp-dpdma";
status = "okay";
reg = <0x00 0xfd4c0000 0x00 0x1000>;
interrupts = <0x00 0x7a 0x04>;
clock-names = "axi_clk";
power-domains = <0x0c 0x29>;
dma-channels = <0x06>;
iommus = <0x0e 0xce4>;
#dma-cells = <0x01>;
clocks = <0x03 0x14>;
phandle = <0x24>;
display@fd4a0000 {
compatible = "xlnx,zynqmp-dpsub-1.7";
status = "okay";
reg = <0x00 0xfd4a0000 0x00 0x1000 0x00 0xfd4aa000 0x00 0x1000 0x00 0xfd4ab000 0x00 0x1000 0x00 0xfd4ac000 0x00 0x1000>;
reg-names = "dp\0blend\0av_buf\0aud";
interrupts = <0x00 0x77 0x04>;
iommus = <0x0e 0xce3>;
clock-names = "dp_apb_clk\0dp_aud_clk\0dp_vtc_pixel_clk_in";
resets = <0x1d 0x03>;
dma-names = "vid0\0vid1\0vid2\0gfx0";
dmas = <0x24 0x00 0x24 0x01 0x24 0x02 0x24 0x03>;
clocks = <0x25 0x03 0x11 0x03 0x10>;
phy-names = "dp-phy0";
phys = <0x1e 0x01 0x06 0x00 0x03>;
xlnx,max-lanes = <0x01>;
phandle = <0xa6>;
i2c-bus {
zynqmp_dp_snd_codec0 {
compatible = "xlnx,dp-snd-codec";
clock-names = "aud_clk";
clocks = <0x03 0x11>;
status = "okay";
phandle = <0x28>;
zynqmp_dp_snd_pcm0 {
compatible = "xlnx,dp-snd-pcm0";
dmas = <0x24 0x04>;
dma-names = "tx";
status = "okay";
phandle = <0x26>;
zynqmp_dp_snd_pcm1 {
compatible = "xlnx,dp-snd-pcm1";
dmas = <0x24 0x05>;
dma-names = "tx";
status = "okay";
phandle = <0x27>;
zynqmp_dp_snd_card {
compatible = "xlnx,dp-snd-card";
xlnx,dp-snd-pcm = <0x26 0x27>;
xlnx,dp-snd-codec = <0x28>;
status = "okay";
phandle = <0xa7>;
fclk0 {
status = "okay";
compatible = "xlnx,fclk";
clocks = <0x03 0x47>;
phandle = <0xa8>;
fclk1 {
status = "okay";
clocks = <0x03 0x48>;
phandle = <0xa9>;
fclk2 {
status = "okay";
clocks = <0x03 0x49>;
phandle = <0xaa>;
fclk3 {
status = "okay";
clocks = <0x03 0x4a>;
phandle = <0xab>;
pss_ref_clk {
compatible = "fixed-clock";
clock-frequency = <0x1fc9350>;
phandle = <0x06>;
video_clk {
clock-frequency = <0x1fc9f08>;
phandle = <0x07>;
pss_alt_ref_clk {
clock-frequency = <0x00>;
phandle = <0x08>;
gt_crx_ref_clk {
clock-frequency = <0x66ff300>;
phandle = <0x0a>;
aux_ref_clk {
phandle = <0x09>;
dp_aclk {
clock-frequency = <0x5f5e100>;
clock-accuracy = <0x64>;
phandle = <0x25>;
gpio-keys {
compatible = "gpio-keys";
autorepeat;
sw19 {
label = "sw19";
gpios = <0x10 0x16 0x00>;
linux,code = <0x6c>;
wakeup-source;
autorepeat;
leds {
compatible = "gpio-leds";
heartbeat-led {
label = "heartbeat";
gpios = <0x10 0x17 0x00>;
linux,default-trigger = "heartbeat";
chosen {
nvmem0 = "/axi/i2c@ff030000/i2c-mux@74/i2c@0/eeprom@54";
bootargs = " earlycon console=ttyPS0,115200 clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait";
stdout-path = "serial0:115200n8";
ina226-u76 {
compatible = "iio-hwmon";
io-channels = <0x29 0x00 0x29 0x01 0x29 0x02 0x29 0x03>;
ina226-u77 {
io-channels = <0x2a 0x00 0x2a 0x01 0x2a 0x02 0x2a 0x03>;
ina226-u78 {
io-channels = <0x2b 0x00 0x2b 0x01 0x2b 0x02 0x2b 0x03>;
ina226-u87 {
io-channels = <0x2c 0x00 0x2c 0x01 0x2c 0x02 0x2c 0x03>;
ina226-u85 {
io-channels = <0x2d 0x00 0x2d 0x01 0x2d 0x02 0x2d 0x03>;
ina226-u86 {
io-channels = <0x2e 0x00 0x2e 0x01 0x2e 0x02 0x2e 0x03>;
ina226-u93 {
io-channels = <0x2f 0x00 0x2f 0x01 0x2f 0x02 0x2f 0x03>;
ina226-u88 {
io-channels = <0x30 0x00 0x30 0x01 0x30 0x02 0x30 0x03>;
ina226-u15 {
io-channels = <0x31 0x00 0x31 0x01 0x31 0x02 0x31 0x03>;
ina226-u92 {
io-channels = <0x32 0x00 0x32 0x01 0x32 0x02 0x32 0x03>;
ina226-u79 {
io-channels = <0x33 0x00 0x33 0x01 0x33 0x02 0x33 0x03>;
ina226-u81 {
io-channels = <0x34 0x00 0x34 0x01 0x34 0x02 0x34 0x03>;
ina226-u80 {
io-channels = <0x35 0x00 0x35 0x01 0x35 0x02 0x35 0x03>;
ina226-u84 {
io-channels = <0x36 0x00 0x36 0x01 0x36 0x02 0x36 0x03>;
ina226-u16 {
io-channels = <0x37 0x00 0x37 0x01 0x37 0x02 0x37 0x03>;
ina226-u65 {
io-channels = <0x38 0x00 0x38 0x01 0x38 0x02 0x38 0x03>;
ina226-u74 {
io-channels = <0x39 0x00 0x39 0x01 0x39 0x02 0x39 0x03>;
ina226-u75 {
io-channels = <0x3a 0x00 0x3a 0x01 0x3a 0x02 0x3a 0x03>;
ref48M {
clock-frequency = <0x2dc6c00>;
phandle = <0x18>;
refhdmi {
clock-frequency = <0x6cfd9c8>;
phandle = <0x19>;
amba_pl@0 {
status = "okay";
ranges;
phandle = <0xac>;
ethernet@a0000000 {
axistream-connected = <0x3b>;
axistream-control-connected = <0x3b>;
clock-names = "s_axi_lite_clk\0axis_clk\0ref_clk";
clocks = <0x03 0x47 0x03 0x47 0x03 0x48>;
compatible = "xlnx,axi-ethernet-7.2\0xlnx,axi-ethernet-1.00.a";
device_type = "network";
interrupt-names = "interrupt\0mm2s_introut\0s2mm_introut";
interrupts = <0x00 0x5b 0x04 0x00 0x59 0x04 0x00 0x5a 0x04>;
local-mac-address = [00 0a 35 00 00 00];
phy-handle = <0x3c>;
phy-mode = "sgmii";
reg = <0x00 0xa0000000 0x00 0x40000>;
xlnx = <0x00>;
xlnx,axiliteclkrate = <0x00>;
xlnx,axisclkrate = <0x00>;
xlnx,channel-ids = <0x01>;
xlnx,clockselection = <0x00>;
xlnx,enableasyncsgmii = <0x00>;
xlnx,gt-type = <0x00>;
xlnx,gtinex = <0x00>;
xlnx,gtlocation = <0x00>;
xlnx,gtrefclksrc = <0x00>;
xlnx,include-dre;
xlnx,instantiatebitslice0 = <0x00>;
xlnx,num-queues = [00 01];
xlnx,phyaddr = <0x02>;
xlnx,phyrst-board-interface-dummy-port = <0x00>;
xlnx,rable = <0x00>;
xlnx,rxcsum = <0x02>;
xlnx,rxlane0-placement = <0x00>;
xlnx,rxlane1-placement = <0x00>;
xlnx,rxmem = <0x8000>;
xlnx,rxnibblebitslice0used = <0x00>;
xlnx,tx-in-upper-nibble = <0x01>;
xlnx,txcsum = <0x02>;
xlnx,txlane0-placement = <0x00>;
xlnx,txlane1-placement = <0x00>;
xlnx,versal-gt-board-flow = <0x00>;
zclock-names = "NULL";
zclocks = "NULL";
phandle = <0xad>;
mdio {
phandle = <0xae>;
phy@2 {
device_type = "ethernet-phy";
reg = <0x01>;
phy-mode = "sgmii";
phandle = <0x3c>;
dma@a0040000 {
clock-names = "s_axi_lite_aclk\0m_axi_sg_aclk\0m_axi_mm2s_aclk\0m_axi_s2mm_aclk";
clocks = <0x03 0x47 0x03 0x47 0x03 0x47 0x03 0x47>;
compatible = "xlnx,eth-dma";
interrupt-names = "mm2s_introut\0s2mm_introut";
interrupts = <0x00 0x59 0x04 0x00 0x5a 0x04>;
reg = <0x00 0xa0040000 0x00 0x10000>;
xlnx,addrwidth = [20];
xlnx,include-dre;
phandle = <0x3b>;
timer@a0050000 {
clock-frequency = <0x5f5b9f5>;
clock-names = "s_axi_aclk";
compatible = "xlnx,axi-timer-2.0\0xlnx,xps-timer-1.00.a";
interrupt-names = "interrupt";
interrupts = <0x00 0x5c 0x04>;
reg = <0x00 0xa0050000 0x00 0x10000>;
xlnx,count-width = <0x20>;
xlnx,gen0-assert = <0x01>;
xlnx,gen1-assert = <0x01>;
xlnx,one-timer-only = <0x00>;
xlnx,trig0-assert = <0x01>;
xlnx,trig1-assert = <0x01>;
phandle = <0xaf>;
aliases {
ethernet0 = "/axi/ethernet@ff0e0000";
ethernet1 = "/amba_pl@0/ethernet@a0000000";
i2c0 = "/axi/i2c@ff020000";
i2c1 = "/axi/i2c@ff030000";
serial0 = "/axi/serial@ff000000";
serial1 = "/axi/serial@ff010000";
spi0 = "/axi/spi@ff0f0000";
memory {
device_type = "memory";
reg = <0x00 0x00 0x00 0x7ff00000 0x08 0x00 0x00 0x80000000>;
__symbols__ {
cpu0 = "/cpus/cpu@0";
cpu1 = "/cpus/cpu@1";
cpu2 = "/cpus/cpu@2";
cpu3 = "/cpus/cpu@3";
CPU_SLEEP_0 = "/cpus/idle-states/cpu-sleep-0";
cpu_opp_table = "/cpu-opp-table";
zynqmp_ipi = "/zynqmp_ipi";
ipi_mailbox_pmu1 = "/zynqmp_ipi/mailbox@ff990400";
dcc = "/dcc";
zynqmp_firmware = "/firmware/zynqmp-firmware";
zynqmp_power = "/firmware/zynqmp-firmware/zynqmp-power";
soc_revision = "/firmware/zynqmp-firmware/nvmem_firmware/soc_revision@0";
efuse_dna = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_dna@c";
efuse_usr0 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr0@20";
efuse_usr1 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr1@24";
efuse_usr2 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr2@28";
efuse_usr3 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr3@2c";
efuse_usr4 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr4@30";
efuse_usr5 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr5@34";
efuse_usr6 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr6@38";
efuse_usr7 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr7@3c";
efuse_miscusr = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_miscusr@40";
efuse_chash = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_chash@50";
efuse_pufmisc = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_pufmisc@54";
efuse_sec = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_sec@58";
efuse_spkid = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_spkid@5c";
efuse_ppk0hash = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_ppk0hash@a0";
efuse_ppk1hash = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_ppk1hash@d0";
zynqmp_pcap = "/firmware/zynqmp-firmware/pcap";
xlnx_aes = "/firmware/zynqmp-firmware/zynqmp-aes";
zynqmp_reset = "/firmware/zynqmp-firmware/reset-controller";
pinctrl0 = "/firmware/zynqmp-firmware/pinctrl";
pinctrl_i2c0_default = "/firmware/zynqmp-firmware/pinctrl/i2c0-default";
pinctrl_i2c0_gpio = "/firmware/zynqmp-firmware/pinctrl/i2c0-gpio";
pinctrl_i2c1_default = "/firmware/zynqmp-firmware/pinctrl/i2c1-default";
pinctrl_i2c1_gpio = "/firmware/zynqmp-firmware/pinctrl/i2c1-gpio";
pinctrl_uart0_default = "/firmware/zynqmp-firmware/pinctrl/uart0-default";
pinctrl_uart1_default = "/firmware/zynqmp-firmware/pinctrl/uart1-default";
pinctrl_usb0_default = "/firmware/zynqmp-firmware/pinctrl/usb0-default";
pinctrl_gem3_default = "/firmware/zynqmp-firmware/pinctrl/gem3-default";
pinctrl_can1_default = "/firmware/zynqmp-firmware/pinctrl/can1-default";
pinctrl_sdhci1_default = "/firmware/zynqmp-firmware/pinctrl/sdhci1-default";
pinctrl_gpio_default = "/firmware/zynqmp-firmware/pinctrl/gpio-default";
xlnx_keccak_384 = "/firmware/zynqmp-firmware/sha384";
xlnx_rsa = "/firmware/zynqmp-firmware/zynqmp-rsa";
modepin_gpio = "/firmware/zynqmp-firmware/gpio";
zynqmp_clk = "/firmware/zynqmp-firmware/clock-controller";
fpga_full = "/fpga-full";
amba = "/axi";
can0 = "/axi/can@ff060000";
can1 = "/axi/can@ff070000";
cci = "/axi/cci@fd6e0000";
fpd_dma_chan1 = "/axi/dma@fd500000";
fpd_dma_chan2 = "/axi/dma@fd510000";
fpd_dma_chan3 = "/axi/dma@fd520000";
fpd_dma_chan4 = "/axi/dma@fd530000";
fpd_dma_chan5 = "/axi/dma@fd540000";
fpd_dma_chan6 = "/axi/dma@fd550000";
fpd_dma_chan7 = "/axi/dma@fd560000";
fpd_dma_chan8 = "/axi/dma@fd570000";
gic = "/axi/interrupt-controller@f9010000";
gpu = "/axi/gpu@fd4b0000";
lpd_dma_chan1 = "/axi/dma@ffa80000";
lpd_dma_chan2 = "/axi/dma@ffa90000";
lpd_dma_chan3 = "/axi/dma@ffaa0000";
lpd_dma_chan4 = "/axi/dma@ffab0000";
lpd_dma_chan5 = "/axi/dma@ffac0000";
lpd_dma_chan6 = "/axi/dma@ffad0000";
lpd_dma_chan7 = "/axi/dma@ffae0000";
lpd_dma_chan8 = "/axi/dma@ffaf0000";
mc = "/axi/memory-controller@fd070000";
nand0 = "/axi/nand-controller@ff100000";
gem0 = "/axi/ethernet@ff0b0000";
phy2 = "/axi/ethernet@ff0b0000/phy@2";
gem1 = "/axi/ethernet@ff0c0000";
gem2 = "/axi/ethernet@ff0d0000";
gem3 = "/axi/ethernet@ff0e0000";
phyc = "/axi/ethernet@ff0e0000/ethernet-phy@c";
gpio = "/axi/gpio@ff0a0000";
tca6416_u97 = "/axi/i2c@ff020000/gpio@20";
tca6416_u61 = "/axi/i2c@ff020000/gpio@21";
u76 = "/axi/i2c@ff020000/i2c-mux@75/i2c@0/ina226@40";
u77 = "/axi/i2c@ff020000/i2c-mux@75/i2c@0/ina226@41";
u78 = "/axi/i2c@ff020000/i2c-mux@75/i2c@0/ina226@42";
u87 = "/axi/i2c@ff020000/i2c-mux@75/i2c@0/ina226@43";
u85 = "/axi/i2c@ff020000/i2c-mux@75/i2c@0/ina226@44";
u86 = "/axi/i2c@ff020000/i2c-mux@75/i2c@0/ina226@45";
u93 = "/axi/i2c@ff020000/i2c-mux@75/i2c@0/ina226@46";
u88 = "/axi/i2c@ff020000/i2c-mux@75/i2c@0/ina226@47";
u15 = "/axi/i2c@ff020000/i2c-mux@75/i2c@0/ina226@4a";
u92 = "/axi/i2c@ff020000/i2c-mux@75/i2c@0/ina226@4b";
u79 = "/axi/i2c@ff020000/i2c-mux@75/i2c@1/ina226@40";
u81 = "/axi/i2c@ff020000/i2c-mux@75/i2c@1/ina226@41";
u80 = "/axi/i2c@ff020000/i2c-mux@75/i2c@1/ina226@42";
u84 = "/axi/i2c@ff020000/i2c-mux@75/i2c@1/ina226@43";
u16 = "/axi/i2c@ff020000/i2c-mux@75/i2c@1/ina226@44";
u65 = "/axi/i2c@ff020000/i2c-mux@75/i2c@1/ina226@45";
u74 = "/axi/i2c@ff020000/i2c-mux@75/i2c@1/ina226@46";
u75 = "/axi/i2c@ff020000/i2c-mux@75/i2c@1/ina226@47";
eeprom = "/axi/i2c@ff030000/i2c-mux@74/i2c@0/eeprom@54";
board_sn = "/axi/i2c@ff030000/i2c-mux@74/i2c@0/eeprom@54/board-sn@0";
eth_mac = "/axi/i2c@ff030000/i2c-mux@74/i2c@0/eeprom@54/eth-mac@20";
board_name = "/axi/i2c@ff030000/i2c-mux@74/i2c@0/eeprom@54/board-name@d0";
board_revision = "/axi/i2c@ff030000/i2c-mux@74/i2c@0/eeprom@54/board-revision@e0";
sfpeeprom = "/axi/i2c@ff030000/i2c-mux@75/i2c@6/eeprom@50";
si5341 = "/axi/i2c@ff030000/i2c-mux@74/i2c@1/clock-generator@36";
si5341_0 = "/axi/i2c@ff030000/i2c-mux@74/i2c@1/clock-generator@36/out@0";
si5341_2 = "/axi/i2c@ff030000/i2c-mux@74/i2c@1/clock-generator@36/out@2";
si5341_3 = "/axi/i2c@ff030000/i2c-mux@74/i2c@1/clock-generator@36/out@3";
si5341_4 = "/axi/i2c@ff030000/i2c-mux@74/i2c@1/clock-generator@36/out@4";
si5341_5 = "/axi/i2c@ff030000/i2c-mux@74/i2c@1/clock-generator@36/out@5";
si5341_6 = "/axi/i2c@ff030000/i2c-mux@74/i2c@1/clock-generator@36/out@6";
si5341_7 = "/axi/i2c@ff030000/i2c-mux@74/i2c@1/clock-generator@36/out@7";
si5341_9 = "/axi/i2c@ff030000/i2c-mux@74/i2c@1/clock-generator@36/out@9";
si570_1 = "/axi/i2c@ff030000/i2c-mux@74/i2c@2/clock-generator@5d";
si570_2 = "/axi/i2c@ff030000/i2c-mux@74/i2c@3/clock-generator@5d";
si5328 = "/axi/i2c@ff030000/i2c-mux@74/i2c@4/clock-generator@69";
si5328_clk = "/axi/i2c@ff030000/i2c-mux@74/i2c@4/clock-generator@69/clk0@0";
ocm = "/axi/memory-controller@ff960000";
perf_monitor_ocm = "/axi/perf-monitor@ffa00000";
perf_monitor_ddr = "/axi/perf-monitor@fd0b0000";
perf_monitor_cci = "/axi/perf-monitor@fd490000";
perf_monitor_lpd = "/axi/perf-monitor@ffa10000";
pcie = "/axi/pcie@fd0e0000";
pcie_intc = "/axi/pcie@fd0e0000/legacy-interrupt-controller";
qspi = "/axi/spi@ff0f0000";
flash0 = "/axi/spi@ff0f0000/flash@0";
psgtr = "/axi/phy@fd400000";
rtc = "/axi/rtc@ffa60000";
sata = "/axi/ahci@fd0c0000";
sdhci0 = "/axi/mmc@ff160000";
sdhci1 = "/axi/mmc@ff170000";
smmu = "/axi/smmu@fd800000";
spi0 = "/axi/spi@ff040000";
spi1 = "/axi/spi@ff050000";
ttc0 = "/axi/timer@ff110000";
ttc1 = "/axi/timer@ff120000";
ttc2 = "/axi/timer@ff130000";
ttc3 = "/axi/timer@ff140000";
uart0 = "/axi/serial@ff000000";
uart1 = "/axi/serial@ff010000";
usb0 = "/axi/usb0@ff9d0000";
dwc3_0 = "/axi/usb0@ff9d0000/dwc3@fe200000";
usb1 = "/axi/usb1@ff9e0000";
dwc3_1 = "/axi/usb1@ff9e0000/dwc3@fe300000";
watchdog0 = "/axi/watchdog@fd4d0000";
lpd_watchdog = "/axi/watchdog@ff150000";
xilinx_ams = "/axi/ams@ffa50000";
ams_ps = "/axi/ams@ffa50000/ams_ps@ffa50800";
ams_pl = "/axi/ams@ffa50000/ams_pl@ffa50c00";
zynqmp_dpdma = "/axi/dma-controller@fd4c0000";
zynqmp_dpsub = "/axi/display@fd4a0000";
zynqmp_dp_snd_codec0 = "/axi/display@fd4a0000/zynqmp_dp_snd_codec0";
zynqmp_dp_snd_pcm0 = "/axi/display@fd4a0000/zynqmp_dp_snd_pcm0";
zynqmp_dp_snd_pcm1 = "/axi/display@fd4a0000/zynqmp_dp_snd_pcm1";
zynqmp_dp_snd_card0 = "/axi/display@fd4a0000/zynqmp_dp_snd_card";
fclk0 = "/fclk0";
fclk1 = "/fclk1";
fclk2 = "/fclk2";
fclk3 = "/fclk3";
pss_ref_clk = "/pss_ref_clk";
video_clk = "/video_clk";
pss_alt_ref_clk = "/pss_alt_ref_clk";
gt_crx_ref_clk = "/gt_crx_ref_clk";
aux_ref_clk = "/aux_ref_clk";
dp_aclk = "/dp_aclk";
ref48 = "/ref48M";
refhdmi = "/refhdmi";
amba_pl = "/amba_pl@0";
axi_eth_0 = "/amba_pl@0/ethernet@a0000000";
axi_eth_0_mdio = "/amba_pl@0/ethernet@a0000000/mdio";
axi_eth_0phy2 = "/amba_pl@0/ethernet@a0000000/mdio/phy@2";
axi_eth_0_dma = "/amba_pl@0/dma@a0040000";
other_perph_axi_timer_1 = "/amba_pl@0/timer@a0050000";
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2025.04.02 18:17:24 =~=~=~=~=~=~=~=~=~=~=~=
Xilinx Zynq MP First Stage Boot Loader
Release 2021.2 Oct 13 2021 - 07:15:53
NOTICE: BL31: v2.4(release):xlnx_rebase_v2.4_2021.1_update1-23-g9188496b9
NOTICE: BL31: Built : 07:41:24, Oct 13 2021
U-Boot 2021.01 (Oct 12 2021 - 09:28:42 +0000)
CPU: ZynqMP
Silicon: v3
Model: ZynqMP ZCU102 Rev1.0
Board: Xilinx ZynqMP
DRAM: 4 GiB
PMUFW: v1.1
EL Level: EL2
Chip ID: zu9eg
NAND: 0 MiB
MMC: mmc@ff170000: 0
Loading Environment from FAT... OK
In: serial
Out: serial
Err: serial
Net:
ZYNQ GEM: ff0e0000, mdio bus ff0e0000, phyaddr 12, interface rgmii-id
Warning: ethernet@ff0e0000 (eth0) using random MAC address - 62:40:83:71:72:da
eth0: ethernet@ff0e0000
AXI EMAC: a0000000, phyaddr 2, interface sgmii, eth1: ethernet@a0000000
Hit any key to stop autoboot: 2 1 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
2710 bytes read in 13 ms (203.1 KiB/s)
## Executing script at 20000000
Trying to load boot images from mmc0
21586432 bytes read in 1436 ms (14.3 MiB/s)
## Flattened Device Tree blob at 00100000
Booting using the fdt blob at 0x100000
Loading Device Tree to 000000007dcfe000, end 000000007dd0e4b3 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.10.0-xilinx-v2021.2 (oe-user@oe-host) (aarch64-xilinx-linux-gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP Tue Oct 12 09:30:57 UTC 2021
[ 0.000000] Machine model: ZynqMP ZCU102 Rev1.0
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] printk: bootconsole [cdns0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 256 MiB at 0x000000006dc00000
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000000000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000007fefffff]
[ 0.000000] node 0: [mem 0x0000000800000000-0x000000087fffffff]
[ 0.000000] Zeroed struct page in unavailable ranges: 256 pages
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000087fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 22 pages/cpu s50968 r8192 d30952 u90112
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1031940
[ 0.000000] Kernel command line: earlycon console=ttyPS0,115200 clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000069c00000-0x000000006dc00000] (64MB)
[ 0.000000] Memory: 3762960K/4193280K available (13952K kernel code, 984K rwdata, 3928K rodata, 2112K init, 588K bss, 168176K reserved, 262144K cma-reserved)
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x31c/0x524 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8de2d3, max_idle_ns: 440795206112 ns
[ 0.000004] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[ 0.008321] Console: colour dummy device 80x25
[ 0.012394] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960)
[ 0.022756] pid_max: default: 32768 minimum: 301
[ 0.027484] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.034705] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.043547] rcu: Hierarchical SRCU implementation.
[ 0.047555] EFI services will not be available.
[ 0.051881] smp: Bringing up secondary CPUs ...
[ 0.056605] Detected VIPT I-cache on CPU1
[ 0.056644] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.057031] Detected VIPT I-cache on CPU2
[ 0.057054] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.057416] Detected VIPT I-cache on CPU3
[ 0.057439] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.057486] smp: Brought up 1 node, 4 CPUs
[ 0.091702] SMP: Total of 4 processors activated.
[ 0.096376] CPU features: detected: 32-bit EL0 Support
[ 0.101480] CPU features: detected: CRC32 instructions
[ 0.106617] CPU: All CPU(s) started at EL2
[ 0.110661] alternatives: patching kernel code
[ 0.116177] devtmpfs: initialized
[ 0.125034] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.129132] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.142567] pinctrl core: initialized pinctrl subsystem
[ 0.143084] DMI not present or invalid.
[ 0.146142] NET: Registered protocol family 16
[ 0.151432] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.157476] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.165289] audit: initializing netlink subsys (disabled)
[ 0.170755] audit: type=2000 audit(0.112:1): state=initialized audit_enabled=0 res=1
[ 0.178334] cpuidle: using governor menu
[ 0.182282] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.189010] ASID allocator initialised with 65536 entries
[ 0.194436] Serial: AMBA PL011 UART driver
[ 0.225898] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.226967] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.233622] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.240282] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.292233] cryptd: max_cpu_qlen set to 1000
[ 1.317048] DRBG: Continuing without Jitter RNG
[ 1.395738] raid6: neonx8 gen() 2141 MB/s
[ 1.463790] raid6: neonx8 xor() 1597 MB/s
[ 1.531862] raid6: neonx4 gen() 2188 MB/s
[ 1.599913] raid6: neonx4 xor() 1565 MB/s
[ 1.667992] raid6: neonx2 gen() 2078 MB/s
[ 1.736043] raid6: neonx2 xor() 1435 MB/s
[ 1.804122] raid6: neonx1 gen() 1779 MB/s
[ 1.872168] raid6: neonx1 xor() 1219 MB/s
[ 1.940234] raid6: int64x8 gen() 1437 MB/s
[ 2.008300] raid6: int64x8 xor() 771 MB/s
[ 2.076363] raid6: int64x4 gen() 1601 MB/s
[ 2.144420] raid6: int64x4 xor() 812 MB/s
[ 2.212498] raid6: int64x2 gen() 1398 MB/s
[ 2.280560] raid6: int64x2 xor() 750 MB/s
[ 2.348632] raid6: int64x1 gen() 1032 MB/s
[ 2.416686] raid6: int64x1 xor() 517 MB/s
[ 2.416724] raid6: using algorithm neonx4 gen() 2188 MB/s
[ 2.420675] raid6: .... xor() 1565 MB/s, rmw enabled
[ 2.425610] raid6: using neon recovery algorithm
[ 2.430735] iommu: Default domain type: Translated
[ 2.435264] SCSI subsystem initialized
[ 2.438900] usbcore: registered new interface driver usbfs
[ 2.444243] usbcore: registered new interface driver hub
[ 2.449518] usbcore: registered new device driver usb
[ 2.454558] mc: Linux media interface: v0.10
[ 2.458763] videodev: Linux video capture interface: v2.00
[ 2.464235] EDAC MC: Ver: 3.0.0
[ 2.467680] zynqmp-ipi-mbox mailbox@ff990400: Registered ZynqMP IPI mbox with TX/RX channels.
[ 2.475981] FPGA manager framework
[ 2.479298] Advanced Linux Sound Architecture Driver Initialized.
[ 2.485509] Bluetooth: Core ver 2.22
[ 2.488776] NET: Registered protocol family 31
[ 2.493176] Bluetooth: HCI device and connection manager initialized
[ 2.499493] Bluetooth: HCI socket layer initialized
[ 2.504337] Bluetooth: L2CAP socket layer initialized
[ 2.509360] Bluetooth: SCO socket layer initialized
[ 2.514458] clocksource: Switched to clocksource arch_sys_counter
[ 2.520400] VFS: Disk quotas dquot_6.6.0
[ 2.524185] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.535390] NET: Registered protocol family 2
[ 2.535771] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 2.543828] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 2.551858] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 2.559319] TCP: Hash tables configured (established 32768 bind 32768)
[ 2.565479] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 2.572147] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 2.579326] NET: Registered protocol family 1
[ 2.583782] RPC: Registered named UNIX socket transport module.
[ 2.589380] RPC: Registered udp transport module.
[ 2.594046] RPC: Registered tcp transport module.
[ 2.598722] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.605713] PCI: CLS 0 bytes, default 64
[ 2.634433] Initialise system trusted keyrings
[ 2.634571] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 2.640348] NFS: Registering the id_resolver key type
[ 2.644681] Key type id_resolver registered
[ 2.648826] Key type id_legacy registered
[ 2.652823] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.659476] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 2.703086] NET: Registered protocol family 38
[ 2.703129] xor: measuring software checksum speed
[ 2.710825] 8regs : 2363 MB/sec
[ 2.714492] 32regs : 2798 MB/sec
[ 2.719433] arm64_neon : 2380 MB/sec
[ 2.719623] xor: using function: 32regs (2798 MB/sec)
[ 2.724648] Key type asymmetric registered
[ 2.728712] Asymmetric key parser 'x509' registered
[ 2.733576] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 2.740910] io scheduler mq-deadline registered
[ 2.745407] io scheduler kyber registered
[ 2.751431] ps_pcie_dma init()
[ 2.778987] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.780845] Serial: AMBA driver
[ 2.785560] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 2.793429] brd: module loaded
[ 2.797844] loop: module loaded
[ 2.798803] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 2.803269] libphy: Fixed MDIO Bus: probed
[ 2.807174] tun: Universal TUN/TAP device driver, 1.6
[ 2.810935] CAN device driver interface
[ 2.815443] xilinx_axienet a0000000.ethernet: TX_CSUM 2
[ 2.819843] xilinx_axienet a0000000.ethernet: RX_CSUM 2
[ 2.825031] xilinx_axienet a0000000.ethernet (unnamed net_device) (uninitialized): xlnx,phy-type is deprecated, Please upgrade your device tree to use phy-mode
[ 2.839451] usbcore: registered new interface driver asix
[ 2.844615] usbcore: registered new interface driver ax88179_178a
[ 2.850650] usbcore: registered new interface driver cdc_ether
[ 2.856444] usbcore: registered new interface driver net1080
[ 2.862068] usbcore: registered new interface driver cdc_subset
[ 2.867958] usbcore: registered new interface driver zaurus
[ 2.873502] usbcore: registered new interface driver cdc_ncm
[ 2.880059] usbcore: registered new interface driver uas
[ 2.884400] usbcore: registered new interface driver usb-storage
[ 2.890983] rtc_zynqmp ffa60000.rtc: registered as rtc0
[ 2.895549] rtc_zynqmp ffa60000.rtc: setting system clock to 2018-03-15T20:01:16 UTC (1521144076)
[ 2.904410] i2c /dev entries driver
[ 2.909647] usbcore: registered new interface driver uvcvideo
[ 2.913523] USB Video Class driver (1.1.1)
[ 2.918660] Bluetooth: HCI UART driver ver 2.3
[ 2.921995] Bluetooth: HCI UART protocol H4 registered
[ 2.927106] Bluetooth: HCI UART protocol BCSP registered
[ 2.932393] Bluetooth: HCI UART protocol LL registered
[ 2.937482] Bluetooth: HCI UART protocol ATH3K registered
[ 2.942858] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 2.949113] Bluetooth: HCI UART protocol Intel registered
[ 2.954455] Bluetooth: HCI UART protocol QCA registered
[ 2.959653] usbcore: registered new interface driver bcm203x
[ 2.965277] usbcore: registered new interface driver bpa10x
[ 2.970812] usbcore: registered new interface driver bfusb
[ 2.976261] usbcore: registered new interface driver btusb
[ 2.981726] usbcore: registered new interface driver ath3k
[ 2.987218] EDAC MC: ECC not enabled
[ 2.990842] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[ 3.003221] sdhci: Secure Digital Host Controller Interface driver
[ 3.008939] sdhci: Copyright(c) Pierre Ossman
[ 3.013263] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.019278] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.024870] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 3.031294] zynqmp_firmware_probe Platform Management API v1.1
[ 3.037062] zynqmp_firmware_probe Trustzone version v1.0
[ 3.074619] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
[ 3.121604] securefw securefw: securefw probed
[ 3.121902] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[ 3.126059] zynqmp_aes firmware:zynqmp-firmware:zynqmp-aes: AES Successfully Registered
[ 3.134191] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[ 3.140330] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[ 3.145836] usbcore: registered new interface driver usbhid
[ 3.151214] usbhid: USB HID core driver
[ 3.157834] ARM CCI_400_r1 PMU driver probed
[ 3.158309] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 3.166150] usbcore: registered new interface driver snd-usb-audio
[ 3.172737] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 3.179960] Initializing XFRM netlink socket
[ 3.183638] NET: Registered protocol family 10
[ 3.188385] Segment Routing with IPv6
[ 3.191778] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.197832] NET: Registered protocol family 17
[ 3.201918] NET: Registered protocol family 15
[ 3.206329] can: controller area network core
[ 3.210671] NET: Registered protocol family 29
[ 3.215057] can: raw protocol
[ 3.217991] can: broadcast manager protocol
[ 3.222151] can: netlink gateway - max_hops=1
[ 3.226549] Bluetooth: RFCOMM TTY layer initialized
[ 3.231324] Bluetooth: RFCOMM socket layer initialized
[ 3.236432] Bluetooth: RFCOMM ver 1.11
[ 3.240150] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.245420] Bluetooth: BNEP filters: protocol multicast
[ 3.250612] Bluetooth: BNEP socket layer initialized
[ 3.255540] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.261426] Bluetooth: HIDP socket layer initialized
[ 3.266499] 9pnet: Installing 9P2000 support
[ 3.270610] Key type dns_resolver registered
[ 3.275027] registered taskstats version 1
[ 3.278905] Loading compiled-in X.509 certificates
[ 3.284597] Btrfs loaded, crc32c=crc32c-generic
[ 3.297049] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 55, base_baud = 6249375) is a xuartps
[ 3.306074] printk: console [ttyPS0] enabled
[ 3.310370] printk: bootconsole [cdns0] disabled
[ 3.320019] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 56, base_baud = 6249375) is a xuartps
[ 3.333223] of-fpga-region fpga-full: FPGA Region probed
[ 3.340111] nwl-pcie fd0e0000.pcie: host bridge /axi/pcie@fd0e0000 ranges:
[ 3.347008] nwl-pcie fd0e0000.pcie: MEM 0x00e0000000..0x00efffffff -> 0x00e0000000
[ 3.355010] nwl-pcie fd0e0000.pcie: MEM 0x0600000000..0x07ffffffff -> 0x0600000000
[ 3.363076] nwl-pcie fd0e0000.pcie: Link is DOWN
[ 3.367843] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
[ 3.374026] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.379509] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
[ 3.386374] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
[ 3.393883] pci 0000:00:00.0: [10ee:d021] type 01 class 0x060400
[ 3.399946] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
[ 3.410108] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
[ 3.415416] ps_pcie_dma 0000:00:00.0: PS PCIe DMA Driver probe
[ 3.421599] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[ 3.428778] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[ 3.435953] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[ 3.443131] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[ 3.450310] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[ 3.457488] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[ 3.464657] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[ 3.471827] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[ 3.479069] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[ 3.486244] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[ 3.493415] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[ 3.500590] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[ 3.507758] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[ 3.514929] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[ 3.522106] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[ 3.529276] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[ 3.536682] xilinx-zynqmp-dpdma fd4c0000.dma-controller: Xilinx DPDMA engine is probed
[ 3.545165] ahci-ceva fd0c0000.ahci: supply ahci not found, using dummy regulator
[ 3.552716] ahci-ceva fd0c0000.ahci: supply phy not found, using dummy regulator
[ 3.560911] spi-nor spi0.0: found mt25qu512a, expected m25p80
[ 3.567297] spi-nor spi0.0: trying to lock already unlocked area
[ 3.573303] spi-nor spi0.0: mt25qu512a (131072 Kbytes)
[ 3.578464] 3 fixed-partitions partitions found on MTD device spi0.0
[ 3.584807] Creating 3 MTD partitions on "spi0.0":
[ 3.589596] 0x000000000000-0x000000100000 : "boot"
[ 3.595247] 0x000000100000-0x000000140000 : "bootenv"
[ 3.601008] 0x000000140000-0x000001740000 : "kernel"
[ 3.609124] macb ff0e0000.ethernet: Not enabling partial store and forward
[ 3.616683] libphy: MACB_mii_bus: probed
[ 3.621323] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 38 (62:40:83:71:72:da)
[ 3.631497] xilinx_axienet a0000000.ethernet: TX_CSUM 2
[ 3.636724] xilinx_axienet a0000000.ethernet: RX_CSUM 2
[ 3.641957] xilinx_axienet a0000000.ethernet (unnamed net_device) (uninitialized): xlnx,phy-type is deprecated, Please upgrade your device tree to use phy-mode
[ 3.656588] libphy: Xilinx Axi Ethernet MDIO: probed
[ 3.662703] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[ 3.669269] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[ 3.675803] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[ 3.682326] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[ 3.691507] pca953x 0-0020: supply vcc not found, using dummy regulator
[ 3.698184] pca953x 0-0020: using no AI
[ 3.702725] pca953x 0-0021: supply vcc not found, using dummy regulator
[ 3.709396] pca953x 0-0021: using no AI
[ 3.722729] i2c i2c-0: Added multiplexed i2c bus 2
[ 3.734269] i2c i2c-0: Added multiplexed i2c bus 3
[ 3.749965] random: fast init done
[ 3.792024] i2c i2c-0: Added multiplexed i2c bus 4
[ 3.796929] i2c i2c-0: Added multiplexed i2c bus 5
[ 3.801725] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[ 3.809058] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 40
[ 3.816780] at24 6-0054: supply vcc not found, using dummy regulator
[ 3.823673] at24 6-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[ 3.830402] i2c i2c-1: Added multiplexed i2c bus 6
[ 3.836657] si5341 7-0036: Chip: 5341 Grade: 1 Rev: 3
[ 3.874426] i2c i2c-1: Added multiplexed i2c bus 7
[ 3.882074] si570 8-005d: registered, current frequency 300000000 Hz
[ 3.888464] i2c i2c-1: Added multiplexed i2c bus 8
[ 3.896094] si570 9-005d: registered, current frequency 156250000 Hz
[ 3.902484] i2c i2c-1: Added multiplexed i2c bus 9
[ 3.907509] si5324 10-0069: si5328 probed
[ 3.974747] si5324 10-0069: si5328 probe successful
[ 3.979662] i2c i2c-1: Added multiplexed i2c bus 10
[ 3.984661] i2c i2c-1: Added multiplexed i2c bus 11
[ 3.989656] i2c i2c-1: Added multiplexed i2c bus 12
[ 3.994653] i2c i2c-1: Added multiplexed i2c bus 13
[ 3.999536] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[ 4.007520] i2c i2c-1: Added multiplexed i2c bus 14
[ 4.012528] i2c i2c-1: Added multiplexed i2c bus 15
[ 4.017542] i2c i2c-1: Added multiplexed i2c bus 16
[ 4.022556] i2c i2c-1: Added multiplexed i2c bus 17
[ 4.027576] i2c i2c-1: Added multiplexed i2c bus 18
[ 4.032582] i2c i2c-1: Added multiplexed i2c bus 19
[ 4.037709] at24 20-0050: supply vcc not found, using dummy regulator
[ 4.044496] at24 20-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 4.051226] i2c i2c-1: Added multiplexed i2c bus 20
[ 4.056240] i2c i2c-1: Added multiplexed i2c bus 21
[ 4.061118] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[ 4.068709] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 41
[ 4.078844] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
[ 4.086340] cdns-wdt ff150000.watchdog: Xilinx Watchdog Timer with timeout 10s
[ 4.094042] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1199880 KHz, changing to: 1199999 KHz
[ 4.106594] zynqmp-display fd4a0000.display: vtc bridge property not present
[ 4.115708] xilinx-dp-snd-codec fd4a0000.display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[ 4.125853] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[ 4.133982] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[ 4.139013] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[ 4.142627] xilinx-dp-snd-card fd4a0000.display:zynqmp_dp_snd_card: ASoC: no DMI vendor name!
[ 4.158287] xilinx-dp-snd-card fd4a0000.display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[ 4.167880] OF: graph: no port node found in /axi/display@fd4a0000
[ 4.174387] xlnx-drm xlnx-drm.0: bound fd4a0000.display (ops 0xffff800010e7bbc8)
[ 4.186380] mmc0: new high speed SDHC card at address aaaa
[ 4.192222] mmcblk0: mmc0:aaaa SD32G 29.7 GiB
[ 4.198038] mmcblk0: p1 p2
[ 5.258494] zynqmp-display fd4a0000.display: [drm] Cannot find any crtc or sizes
[ 5.266132] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.display on minor 0
[ 5.273629] zynqmp-display fd4a0000.display: ZynqMP DisplayPort Subsystem driver probed
[ 5.282020] ahci-ceva fd0c0000.ahci: supply ahci not found, using dummy regulator
[ 5.289568] ahci-ceva fd0c0000.ahci: supply phy not found, using dummy regulator
[ 5.297026] ahci-ceva fd0c0000.ahci: supply target not found, using dummy regulator
[ 5.304863] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 5.313816] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 5.324227] scsi host0: ahci-ceva
[ 5.327845] scsi host1: ahci-ceva
[ 5.331282] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 53
[ 5.339201] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 53
[ 5.367127] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 5.372627] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 5.380389] xhci-hcd xhci-hcd.1.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000002010810
[ 5.389814] xhci-hcd xhci-hcd.1.auto: irq 67, io mem 0xfe200000
[ 5.395950] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.404210] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.411429] usb usb1: Product: xHCI Host Controller
[ 5.416298] usb usb1: Manufacturer: Linux 5.10.0-xilinx-v2021.2 xhci-hcd
[ 5.422990] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 5.428166] hub 1-0:1.0: USB hub found
[ 5.431939] hub 1-0:1.0: 1 port detected
[ 5.436049] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 5.441535] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 5.449186] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 5.455815] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 5.464074] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.471292] usb usb2: Product: xHCI Host Controller
[ 5.476161] usb usb2: Manufacturer: Linux 5.10.0-xilinx-v2021.2 xhci-hcd
[ 5.482855] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 5.487981] hub 2-0:1.0: USB hub found
[ 5.491747] hub 2-0:1.0: 1 port detected
[ 5.498836] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 5.505841] of_cfs_init
[ 5.508312] of_cfs_init: OK
[ 5.511280] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.646127] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.652667] clk: Not disabling unused clocks
[ 5.657188] ALSA device list:
[ 5.660152] #0: DisplayPort monitor
[ 5.664093] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.664666] ata2: SATA link down (SStatus 0 SControl 330)
[ 5.672702] cfg80211: failed to load regulatory.db
[ 5.682911] ata1: SATA link down (SStatus 0 SControl 330)
[ 5.783046] EXT4-fs (mmcblk0p2): recovery complete
[ 5.788853] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.796976] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 5.803583] devtmpfs: mounted
[ 5.807131] Freeing unused kernel memory: 2112K
[ 5.811717] Run /sbin/init as init process
INIT: version 2.97 booting
[ 6.135590] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Starting udev
[ 6.292603] udevd[265]: starting version 3.2.9
[ 6.307105] random: udevd: uninitialized urandom read (16 bytes read)
[ 6.314195] random: udevd: uninitialized urandom read (16 bytes read)
[ 6.320679] random: udevd: uninitialized urandom read (16 bytes read)
[ 6.355154] udevd[266]: starting eudev-3.2.9
[ 6.370501] zynqmp-display fd4a0000.display: [drm] Cannot find any crtc or sizes
[ 6.911559] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
bootlogd: /dev/ttyPS0
INIT: Entering runlevel: 5
Configuring network interfaces... udhcpc: started, v1.32.0
udhcpc: sending discover
udhcpc: no lease, forking to background
done.
Starting haveged: haveged: command socket is listening at fd 3
haveged: haveged starting up
Starting Dropbear SSH server: dropbear.
Starting internet superserver: inetd.
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2021.2 pl_eth_sgmii ttyPS0
7[r[999;999H[6n8root@pl_eth_sgmii:~# ifconfig -a
can0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:16 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:10
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:19
eth0 Link encap:Ethernet HWaddr 62:40:83:71:72:DA
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
Interrupt:38
eth1 Link encap:Ethernet HWaddr 00:0A:35:00:00:00
BROADCAST MTU:1500 Metric:1
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
root@pl_eth_sgmii:~# ifconfig eth1 up
Interrupt:38
UP BROADCAST MTU:1500 Metric:1
root@pl_eth_sgmii:~# ifconfig eth1 192.168.10.180
root@pl_eth_sgmii:~# ethtool -s eth1 autoneg off
root@pl_eth_sgmii:~# ethtool eth1
Settings for eth1:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: No
Advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Auto-negotiation: off
Port: MII
PHYAD: 2
Transceiver: external
Link detected: yes
root@pl_eth_sgmii:~# ip link show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/sit 0.0.0.0 brd 0.0.0.0
3: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN mode DEFAULT group default qlen 10
link/can
4: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN mode DEFAULT group default qlen 1000
link/ether 62:40:83:71:72:da brd ff:ff:ff:ff:ff:ff
5: eth1: <BROADCAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
link/ether 00:0a:35:00:00:00 brd ff:ff:ff:ff:ff:ff
ethtool eth1 | grep -i speed
Speed: 1000Mb/s
dmesg | grep -i eth
[ 8.157263] macb ff0e0000.ethernet eth0: PHY [ff0e0000.ethernet-ffffffff:0c] driver [TI DP83867] (irq=POLL)
[ 8.157275] macb ff0e0000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 36.041024] xilinx_axienet a0000000.ethernet eth1: Link is Down
[ 72.447397] xilinx_axienet a0000000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[ 72.447445] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
dmesg | grep -i phy
root@pl_eth_sgmii:~# ^C
Attached PUTTY log file and my device tree file .
Regards
P Prasanth
