ADRV9002
Recommended for New Designs
The ADRV9002 is a highly integrated RF transceiver that has dual-channel transmitters, dual-channel receivers, integrated synthesizers, and digital signal...
Datasheet
ADRV9002 on Analog.com
I have a ZCU102 Evaluation Kit with an ADRV9002 transceiver.
I have CMOS profile which allows me to have different sample rates for RX and TX.
I now want to upload a custom FIR filter for both RX channels. I have done so in TES, the filter response is as expected and i've managed to generate stream and config files.
However, when i load then via libiio and plot the live spectra I don't see any sign of an RX filter being applied.
Do you need to enable it at runtime using libiio? Or is there something else I'm doing wrong?
Also, are custom FIR filters even allowed in CMOS?
Any help would be greatly appreciated. Thank you.
RahulMushini - Moved from TES GUI & Software Support ADRV9001 – ADRV9007 to Linux Software Drivers. Post date updated from Thursday, March 13, 2025 11:17 AM UTC to Thursday, March 13, 2025 11:58 AM UTC to reflect the move.
Hi Peter, yes FIR filter works with both SSI types. You may not be able to observe this filter's effect. Please see here: (+) ADRV9002 Analog Filter Response - Q&A - TES GUI & Software Support ADRV9001 – ADRV9007 - EngineerZone Best, -Stefan
Hi Stefan. I'm still not quite sure I understand after reading that post. do you mind explaining? So is it that applying a custom FIR in TES won't do anything ? I should also say i have NCO enabled. I don't know if that has any effect.
The post mentions "magnitude compensation filters applied". Does that mean it tries to flatten the response? Is that what i want? I want to band reject inbound blockers near my signal.
Hi Peter, my apologies I thought you meant analog filter. Please send us your TES profile and describe exactly what you're testing and what observation is not expected?
"Version": "v0.26.0",
"IpAddress": "192.168.1.10",
"PortNumber": "8080",
"UserName": "root",
"Password": "analog",
"DeviceClockFrequency_Hz": "38400000",
"DeviceClockDivisor": "ADRV9001_DEVICECLOCKDIVISOR_2",
"ProcessorClockDivisor": "DIVISOR_1",
"GainTableType": "ADRV9001_RX_GAIN_CORRECTION_TABLE",
"Duplex": "FDD",
"Setup": "Custom",
"Channels": "Custom",
"Diversity": "True",
"ClockPllMode": "HIGH_PERFORMANCE",
"AdcRate": "LOW",
"ArmPowerSavingClockDiv": "1",
"Rssi.DetectionThreshold_mdBFS": "-80000",
"Rssi.MeasurementDuration_samples": "10",
"Rssi.MeasurementsStartPeriod_ms": "1",
"Rssi.NumberOfMeasurementsToAverage": "4",
"MonitorMode.DetectionTime_us": "30000",
"MonitorMode.SleepTime_us": "30000",
"Channel1.FrequencyDeviation_Hz": "1500",
"Channel2.FrequencyDeviation_Hz": "1500",
"Rx1.LockTollgate": "LockTollgate",
"Tx1.LockTollgate": "LockTollgate",
"Rx2.LockTollgate": "LockTollgate",
"Tx2.LockTollgate": "LockTollgate",
"Rx1.RfPortId": "Rx1A",
"Rx2.RfPortId": "Rx2A",
"Tx1.RfPortId": "Tx1",
"Tx2.RfPortId": "Tx2",
"Tx1.SignalType": "ADRV9001_TX_IQ",
"Tx2.SignalType": "ADRV9001_TX_IQ",
"LO1.Divisor": "2",
"LO2.Divisor": "2",
"Tx1.Attenuation.AttenuationControlMode": "ADRV9001_TX_ATTENUATION_CONTROL_MODE_SPI",
"Tx2.Attenuation.AttenuationControlMode": "ADRV9001_TX_ATTENUATION_CONTROL_MODE_SPI",
"Tx1.Attenuation.InitTxAtten_dB": "10",
"Tx2.Attenuation.InitTxAtten_dB": "10",
"Tx1.Attenuation.AttenuationControlPinConfiguration.IncrementStepSize_dB": "0.05",
"Tx2.Attenuation.AttenuationControlPinConfiguration.IncrementStepSize_dB": "0.05",
"Rx1.InterfaceGain.ControlMode": "ADRV9001_RX_INTERFACE_GAIN_CONTROL_MANUAL",
"Rx1.InterfaceGain.UpdateTiming": "ADRV9001_RX_INTERFACE_GAIN_UPDATE_TIMING_NOW",
"Rx1.InterfaceGain.Gain_dB": "ADRV9001_RX_INTERFACE_GAIN_0_DB",
"Rx2.InterfaceGain.ControlMode": "ADRV9001_RX_INTERFACE_GAIN_CONTROL_MANUAL",
"Rx2.InterfaceGain.UpdateTiming": "ADRV9001_RX_INTERFACE_GAIN_UPDATE_TIMING_NOW",
"Rx2.InterfaceGain.Gain_dB": "ADRV9001_RX_INTERFACE_GAIN_0_DB",
"Rx1.Gain.GainControlMode": "ADRV9001_RX_GAIN_CONTROL_MODE_SPI",
"Rx2.Gain.GainControlMode": "ADRV9001_RX_GAIN_CONTROL_MODE_SPI",
"Rx1.Gain.GainControlPinConfiguration.IncrementStepSize": "2",
"Rx1.Gain.GainControlPinConfiguration.DecrementStepSize": "2",
"Rx2.Gain.GainControlPinConfiguration.IncrementStepSize": "2",
"Rx2.Gain.GainControlPinConfiguration.DecrementStepSize": "2",
"Rx1.Gain.GainControl.Mode": "ADRV9001_RX_GAIN_CONTROL_DETECTION_MODE_PEAK",
"Rx1.Gain.GainControl.PeakOverloadThreshold": "-6.0206",
"Rx1.Gain.GainControl.PeakUnderloadThreshold": "-9",
"Rx1.Gain.GainControl.PowerOverloadThreshold": "-7",
"Rx1.Gain.GainControl.PowerUnderloadThreshold": "-12",
"Rx1.Gain.GainControl.OverloadGainStep": "2",
"Rx1.Gain.GainControl.UnderloadGainStep": "2",
"Rx1.Gain.GainControl.GainRefreshPeriod_us": "62.5",
"Rx1.Gain.GainControl.MeasurementDelay_us": "0.5",
"Rx1.Gain.GainControl.MeasurementDuration_us": "50",
"Rx2.Gain.GainControl.Mode": "ADRV9001_RX_GAIN_CONTROL_DETECTION_MODE_PEAK",
"Rx2.Gain.GainControl.PeakOverloadThreshold": "-6.0206",
"Rx2.Gain.GainControl.PeakUnderloadThreshold": "-9",
"Rx2.Gain.GainControl.PowerOverloadThreshold": "-7",
"Rx2.Gain.GainControl.PowerUnderloadThreshold": "-12",
"Rx2.Gain.GainControl.OverloadGainStep": "2",
"Rx2.Gain.GainControl.UnderloadGainStep": "2",
"Rx2.Gain.GainControl.GainRefreshPeriod_us": "62.5",
"Rx2.Gain.GainControl.MeasurementDelay_us": "0.5",
"Rx2.Gain.GainControl.MeasurementDuration_us": "50",
"Tx1.ElbType": "DISABLED",
"Tx2.ElbType": "DISABLED",
"Tx1.PeakLoopbackPower_dBm": "-18",
"Tx2.PeakLoopbackPower_dBm": "-18",
"Tx1.DPD.AmplifierType": "ADRV9001_DPDAMPLIFIER_DEFAULT",
"Tx1.DPD.LutSize": "ADRV9001_DPDLUTSIZE_512",
"Tx1.DPD.DpdModel": "ADRV9001_DPDMODEL_4",
"Tx1.DPD.Tap0.TermsMask": "0x1F",
"Tx1.DPD.Tap1.TermsMask": "0x7F",
"Tx1.DPD.Tap2.TermsMask": "0x1F",
"Tx1.DPD.Tap3.TermsMask": "0x1E",
"Tx2.DPD.AmplifierType": "ADRV9001_DPDAMPLIFIER_DEFAULT",
"Tx2.DPD.LutSize": "ADRV9001_DPDLUTSIZE_512",
"Tx2.DPD.DpdModel": "ADRV9001_DPDMODEL_4",
"Tx2.DPD.Tap0.TermsMask": "0x1F",
"Tx2.DPD.Tap1.TermsMask": "0x7F",
"Tx2.DPD.Tap2.TermsMask": "0x1F",
"Tx2.DPD.Tap3.TermsMask": "0x1E",
"Tx1.DPD.NumberOfSamples": "4096",
"Tx1.DPD.RxTxNormalizationLowerThreshold": "3395470",
"Tx1.DPD.RxTxNormalizationUpperThreshold": "33954698",
"Tx1.DPD.ImmediateLutSwitching": "True",
"Tx2.DPD.RxTxNormalizationLowerThreshold": "3395470",
"Tx2.DPD.RxTxNormalizationUpperThreshold": "33954698",
"Tx2.DPD.ImmediateLutSwitching": "True",
"Initialized": "True",
"Product": "ADRV9001_PART_NUMBER_ADRV9002",
"AutomatedTddEnable": "False",
"CarrierConfigurationMode": "DefinedCarriers",
"NumDynamicProfiles": "ADRV9001_NUM_DYNAMIC_PROFILES_DISABLED",
"OutputStreamOverGpio": "False",
"McsMode": "ADRV9001_MCSMODE_ENABLED_WITH_RFPLL_PHASE",
"DmaMasterRx": "True",
"DmaMasterTx": "True",
"DmaMasterORx": "True",
"McsInterface": "ADRV9001_SSI_TYPE_CMOS",
"McsClock_kHz": "39532",
"ExpandedCustomSearch": "True",
"NumSamples": "4096",
"DeviceClockOutputEnabled": "True",
"AllowPllRetuning": "False",
"SwapLoMapping": "False",
"PllPowerConsumption": "ADRV9001_COMPONENT_POWER_LEVEL_HIGH",
"DataSource": "ThroughFpga",
"RequiresTwoStageInitCals": "False",
"RxSynchronousTransfer": "False",
"TxSynchronousTransfer": "False",
"WarmBootEnable": "False",
"WarmBootCoefficients": "",
"AuxADC0.Enabled": "False",
"AuxADC0.Voltage_mV": "0",
"AuxADC1.Enabled": "False",
"AuxADC1.Voltage_mV": "0",
"AuxADC2.Enabled": "False",
"AuxADC2.Voltage_mV": "0",
"AuxADC3.Enabled": "False",
"AuxADC3.Voltage_mV": "0",
"AuxDAC0.Enabled": "False",
"AuxDAC0.Code": "0",
"AuxDAC1.Enabled": "False",
"AuxDAC1.Code": "0",
"AuxDAC2.Enabled": "False",
"AuxDAC2.Code": "0",
"AuxDAC3.Enabled": "False",
"AuxDAC3.Code": "0",
"UnitPreference.ForFrequency": "Kilohertz",
"Channel1.SsiType": "ADRV9001_SSI_TYPE_CMOS",
"Channel1.SsiNumLanes": "ADRV9001_SSI_1_LANE",
"Channel1.SsiDataRate": "SINGLE",
"Channel1.SsiStrobeType": "ADRV9001_SSI_SHORT_STROBE",
"Channel1.ChannelEnableMode": "ADRV9001_SPI_MODE",
"Channel1.SsiPowerDown": "ADRV9001_SSI_POWER_DOWN_DISABLED",
"Channel1.ExternalPathDelay_ps": "0",
"Channel1.TxDacFullScaleBoostEnable": "False",
"Channel1.RxToTxLoopback": "False",
"Channel1.TxToRxLoopback": "False",
"Channel1.ChannelEnabled": "True",
"Tx1.DataportSampleRate_Hz": "1000000",
"Tx1.SsiRefClock": "ADRV9001_SSI_TX_REF_CLOCK_PIN_DCLK_OUT_ENABLED",
"Tx1.CarrierFrequency_Hz": "450000000",
"Tx1.Interpolation": "1",
"Tx1.ContinuousTransfer": "True",
"Tx1.RfBandwidth_Hz": "25000",
"Tx1.PowerConsumption": "ADRV9001_COMPONENT_POWER_LEVEL_LOW",
"Tx1.DesiredLoForDualHop": "ADRV9001_LOSEL_LO1",
"Tx1.SsiInterfaceRate_Hz": "1000000",
"Tx1.Lpf3dBCornerFrequency_Hz": "50000000",
"Tx1.Lpf1dBFrequency_Hz": "0",
"Tx1.WidebandFilter": "BW_80",
"Tx1.McsToStrobeLatency": "0",
"Tx1.ReadDelay": "5",
"Tx1.SampleDelay": "0",
"Tx1.Analysis": "None",
"Tx1.UDP.Enabled": "False",
"Tx1.UDP.Port": "11004",
"Tx1.UDP.Host0": "127",
"Tx1.UDP.Host1": "0",
"Tx1.UDP.Host2": "0",
"Tx1.UDP.Host3": "1",
"Tx1.UDP.Host": "127.0.0.1",
"Tx1.ChannelFilter0.Type": "DISABLED",
"Tx1.ChannelFilter0.FileName": "DISABLED",
"Tx1.ChannelFilter1.Type": "LOOK_UP",
"Tx1.ChannelFilter1.FileName": "LOOK_UP",
"Tx1.ChannelFilter2.Type": "LOOK_UP",
"Tx1.ChannelFilter2.FileName": "LOOK_UP",
"Tx1.ChannelFilter3.Type": "LOOK_UP",
"Tx1.ChannelFilter3.FileName": "LOOK_UP",
"Tx1.ChannelFilter4.Type": "LOOK_UP",
"Tx1.ChannelFilter4.FileName": "LOOK_UP",
"Tx1.ChannelFilter5.Type": "LOOK_UP",
"Tx1.ChannelFilter5.FileName": "LOOK_UP",
"Tx1.FrequencyCorrection.Enable": "True",
"Tx1.FrequencyCorrection.IsImmediate": "True",
"Tx1.FrequencyCorrection.Freq_Hz": "0",
"Tx1.DPD.ChangeModelTapOrders": "False",
"Tx1.DPD.PreLutScale": "8",
"Tx1.DPD.Enable": "False",
"Tx1.DPD.ClgcEnable": "False",
"Tx1.DPD.CaptureDelay_us": "0",
"Tx1.DPD.ClgcLoopOpen": "False",
"Tx1.DPD.ClgcGainTarget": "0",
"Tx1.DPD.ClgcFilterAlpha": "0.75",
"Tx1.DPD.ClgcLastGain_HundredthdB": "0",
"Tx1.DPD.ClgcFilteredGain_HundredthdB": "0",
"Tx1.DPD.AdditionalPowerScale": "4",
"Tx1.DPD.TimeFilterCoefficient": "0",
"Tx1.DPD.DetectionPowerThreshold": "53942350",
"Tx1.DPD.DetectionPeakThreshold": "214748365",
"Tx1.DPD.CountsGreaterThanPeakThreshold": "0",
"Tx1.DPD.CountsLessThanPowerThreshold": "4096",
"Tx1.DPD.Detection": "Peak",
"Tx1.DPD.EnableRepeatedEstimationInTDD": "False",
"Tx1.DPD.Region0.Enable": "False",
"Tx1.DPD.Region0.LowerBound_Hz": "0",
"Tx1.DPD.Region0.UpperBound_Hz": "0",
"Tx1.DPD.Region1.Enable": "False",
"Tx1.DPD.Region1.LowerBound_Hz": "0",
"Tx1.DPD.Region1.UpperBound_Hz": "0",
"Tx1.DPD.Region2.Enable": "False",
"Tx1.DPD.Region2.LowerBound_Hz": "0",
"Tx1.DPD.Region2.UpperBound_Hz": "0",
"Tx1.DPD.Region3.Enable": "False",
"Tx1.DPD.Region3.LowerBound_Hz": "0",
"Tx1.DPD.Region3.UpperBound_Hz": "0",
"Tx1.DPD.Region4.Enable": "False",
"Tx1.DPD.Region4.LowerBound_Hz": "0",
"Tx1.DPD.Region4.UpperBound_Hz": "0",
"Tx1.DPD.Region5.Enable": "False",
"Tx1.DPD.Region5.LowerBound_Hz": "0",
"Tx1.DPD.Region5.UpperBound_Hz": "0",
"Tx1.DPD.Region6.Enable": "False",
"Tx1.DPD.Region6.LowerBound_Hz": "0",
"Tx1.DPD.Region6.UpperBound_Hz": "0",
"Tx1.InitCals.Flags": "ADRV9001_INIT_CAL_TX_QEC, ADRV9001_INIT_CAL_TX_LO_LEAKAGE, ADRV9001_INIT_CAL_TX_LB_PD",
"Tx1.PaRamp.Enable": "False",
"Tx1.PaRamp.Trigger": "ADRV9001_TX_PA_RAMP_TRIGGER_SPI",
"Tx1.PaRamp.AsymmetricRamp": "False",
"Tx1.PaRamp.TriggerDelayFall": "5",
"Tx1.PaRamp.TriggerDelayRise": "5",
"Tx1.PaRamp.RampClock_kHz": "1000",
"Tx1.PaRamp.UpEndIndex": "0",
"Tx1.PaRamp.DownEndIndex": "0",
"Enabled": "False",
"FileName": "",
"Tx1.PaRamp.ADRV9001_GPIO_SIGNAL_TX1_PA_RAMP_CTRL.Pin": "ADRV9001_GPIO_UNASSIGNED",
"Tx1.Delay.PropagationDelay_ns": "214000",
"Tx1.Delay.RiseToAnalogOnDelay_ns": "206500",
"Tx1.Delay.RiseToOnDelay_ns": "214000",
"Tx1.Delay.HoldDelay_ns": "0",
"Tx1.Delay.FallToOffDelay_ns": "214000",
"Tx1.TxFrontEnd.Enabled": "False",
"Tx1.LoopGain": "65536",
"Tx1.Flags": "0",
"Tx1.Attenuation.AttenuationControlPinConfiguration.IncrementPin": "ADRV9001_GPIO_UNASSIGNED",
"Tx1.Attenuation.AttenuationControlPinConfiguration.DecrementPin": "ADRV9001_GPIO_UNASSIGNED",
"Rx1.SignalType": "IQ16",
"Rx1.RfInput": "ADRV9001_RX_A",
"Rx1.IntermediateFrequency_kHz": "950",
"Rx1.IntermediateFrequencyEnable": "True",
"Rx1.CarrierFrequency_Hz": "350000000",
"Rx1.AdcOptimization": "ADRV9001_ADC_HP",
"Rx1.AnalogFilterOrder": "ORDER_2",
"Rx1.RfBandwidth_Hz": "300000",
"Rx1.PowerConsumption": "ADRV9001_COMPONENT_POWER_LEVEL_HIGH",
"Rx1.DesiredLoForDualHop": "ADRV9001_LOSEL_LO2",
"Rx1.DataportSampleRate_Hz": "1000000",
"Rx1.SsiInterfaceRate_Hz": "1000000",
"Rx1.Lpf3dBCornerFrequency_Hz": "6702000",
"Rx1.Lpf1dBFrequency_Hz": "4740000",
"Rx1.WidebandFilter": "BW_80",
"Rx1.McsToStrobeLatency": "0",
"Rx1.ReadDelay": "1",
"Rx1.SampleDelay": "0",
"Rx1.Analysis": "SingleTone",
"Rx1.UDP.Enabled": "False",
"Rx1.UDP.Port": "11003",
"Rx1.UDP.Host0": "127",
"Rx1.UDP.Host1": "0",
"Rx1.UDP.Host2": "0",
"Rx1.UDP.Host3": "1",
"Rx1.UDP.Host": "127.0.0.1",
"Rx1.ChannelFilter0.Type": "CUSTOM",
"Rx1.ChannelFilter0.FileName": "..\\..\\..\\Users\\LocalAdmin\\Documents\\adrv9002\\250311\\fsk_fir_coefficients\\fskfir.csv",
"Rx1.ChannelFilter1.Type": "LOOK_UP",
"Rx1.ChannelFilter1.FileName": "LOOK_UP",
"Rx1.ChannelFilter2.Type": "LOOK_UP",
"Rx1.ChannelFilter2.FileName": "LOOK_UP",
"Rx1.ChannelFilter3.Type": "LOOK_UP",
"Rx1.ChannelFilter3.FileName": "LOOK_UP",
"Rx1.ChannelFilter4.Type": "LOOK_UP",
"Rx1.ChannelFilter4.FileName": "LOOK_UP",
"Rx1.ChannelFilter5.Type": "LOOK_UP",
"Rx1.ChannelFilter5.FileName": "LOOK_UP",
"Rx1.FrequencyCorrection.Enable": "True",
"Rx1.FrequencyCorrection.IsImmediate": "True",
"Rx1.FrequencyCorrection.Freq_Hz": "0",
"Rx1.BbdcRejection.BasebandDcRejection": "ADRV9001_BBDC_REJECTION_ENABLED",
"Rx1.Delay.PropagationDelay_ns": "2350000",
"Rx1.Delay.RiseToAnalogOnDelay_ns": "0",
"Rx1.Delay.RiseToOnDelay_ns": "8000",
"Rx1.Delay.HoldDelay_ns": "2350000",
"Rx1.Delay.FallToOffDelay_ns": "0",
"Rx1.Gain.InitRxGain": "247",
"Rx1.Gain.IsDirtyAgc": "False",
"Rx1.Gain.IsDirtyPinControl": "False",
"Rx1.Gain.MaxAgcGainIndex": "255",
"Rx1.Gain.MinAgcGainIndex": "195",
"Rx1.Gain.MaxExtantGainIndex": "255",
"Rx1.Gain.MinExtantGainIndex": "187",
"Rx1.Gain.GainControl.LowThreshPreventIncrement": "False",
"Rx1.Gain.GainControl.RxQecFreezeEnable": "True",
"Rx1.Gain.GainControl.HbDetectorEnable": "False",
"Rx1.Gain.GainControl.ApdDetectorEnable": "False",
"Rx1.Gain.GainControl.ResetOnRxOn": "False",
"Rx1.Gain.GainControl.OverrangeCrumb": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"Rx1.Gain.GainControl.UnderrangeCrumb": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"Rx1.Gain.GainControl.-1.Pin": "ADRV9001_GPIO_UNASSIGNED",
"Rx1.Gain.GainControlPinConfiguration.IncrementPin": "ADRV9001_GPIO_UNASSIGNED",
"Rx1.Gain.GainControlPinConfiguration.DecrementPin": "ADRV9001_GPIO_UNASSIGNED",
"Rx1.Gain.GainIndexReadout.Bits01And00": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"Rx1.Gain.GainIndexReadout.Bits03And02": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"Rx1.Gain.GainIndexReadout.Bits05And04": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"Rx1.Gain.GainIndexReadout.ChangeBitAndBit06": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"Rx1.InitCals.Flags": "ADRV9001_INIT_CAL_RX_QEC_FIC, ADRV9001_INIT_CAL_RX_RF_DC_OFFSET",
"Rx1.InterfaceGain.SeedGain_dB": "ADRV9001_RX_INTERFACE_GAIN_0_DB",
"Rx1.InterfaceGain.EndOfFrameGain_dB": "ADRV9001_RX_INTERFACE_GAIN_18_DB",
"Rx1.InterfaceGain.RssiDuration": "255",
"Rx1.InterfaceGain.RssiMovingAverageDuration": "10",
"Rx1.InterfaceGain.GainControlAutomaticThreshold_dBFS": "-2",
"Rx1.InterfaceGain.SignalPAR": "15",
"Rx1.InterfaceGain.EnableFastAttack": "False",
"Rx1.LoopGain": "65536",
"Rx1.Flags": "ADRV9001_TRACKING_CAL_RX_HD2, ADRV9001_TRACKING_CAL_RX_BBDC, ADRV9001_TRACKING_CAL_RX_RFDC, ADRV9001_TRACKING_CAL_RX_QEC_FIC, ADRV9001_TRACKING_CAL_RX_GAIN_CONTROL_DETECTORS",
"Rx1.RxFrontEnd.Enabled": "False",
"Rx1.GainBits.Select": "ADRV9001_RX_GAIN_INDEX_GAIN_CHANGE_ZEROES",
"Rx1.GainBits.AgcGainDelay": "0",
"Rx1.GainBits.InterfaceGainDelay": "0",
"ORx1.SignalType": "Disabled",
"ORx1.IntermediateFrequency_kHz": "490",
"ORx1.IntermediateFrequencyEnable": "True",
"ORx1.CarrierFrequency_Hz": "450000000",
"ORx1.AdcOptimization": "ADRV9001_ADC_LP",
"ORx1.AnalogFilterOrder": "ORDER_1",
"ORx1.RfInput": "ADRV9001_RX_B",
"ORx1.RfBandwidth_Hz": "12000",
"ORx1.PowerConsumption": "ADRV9001_COMPONENT_POWER_LEVEL_LOW",
"ORx1.DesiredLoForDualHop": "0",
"ORx1.DataportSampleRate_Hz": "24000",
"ORx1.SsiInterfaceRate_Hz": "24000",
"ORx1.Lpf3dBCornerFrequency_Hz": "0",
"ORx1.Lpf1dBFrequency_Hz": "20000000",
"ORx1.WidebandFilter": "BW_80",
"ORx1.McsToStrobeLatency": "0",
"ORx1.ReadDelay": "0",
"ORx1.SampleDelay": "0",
"ORx1.Analysis": "SingleTone",
"ORx1.UDP.Enabled": "False",
"ORx1.UDP.Port": "11006",
"ORx1.UDP.Host0": "127",
"ORx1.UDP.Host1": "0",
"ORx1.UDP.Host2": "0",
"ORx1.UDP.Host3": "1",
"ORx1.UDP.Host": "127.0.0.1",
"ORx1.ChannelFilter0.Type": "LOOK_UP",
"ORx1.ChannelFilter0.FileName": "LOOK_UP",
"ORx1.ChannelFilter1.Type": "LOOK_UP",
"ORx1.ChannelFilter1.FileName": "LOOK_UP",
"ORx1.ChannelFilter2.Type": "LOOK_UP",
"ORx1.ChannelFilter2.FileName": "LOOK_UP",
"ORx1.ChannelFilter3.Type": "LOOK_UP",
"ORx1.ChannelFilter3.FileName": "LOOK_UP",
"ORx1.ChannelFilter4.Type": "LOOK_UP",
"ORx1.ChannelFilter4.FileName": "LOOK_UP",
"ORx1.ChannelFilter5.Type": "LOOK_UP",
"ORx1.ChannelFilter5.FileName": "LOOK_UP",
"ORx1.FrequencyCorrection.Enable": "False",
"ORx1.FrequencyCorrection.IsImmediate": "True",
"ORx1.FrequencyCorrection.Freq_Hz": "0",
"ORx1.BbdcRejection.BasebandDcRejection": "ADRV9001_BBDC_REJECTION_ENABLED",
"ORx1.Delay.PropagationDelay_ns": "0",
"ORx1.Delay.RiseToAnalogOnDelay_ns": "0",
"ORx1.Delay.RiseToOnDelay_ns": "8000",
"ORx1.Delay.HoldDelay_ns": "0",
"ORx1.Delay.FallToOffDelay_ns": "0",
"ORx1.Gain.InitRxGain": "12",
"ORx1.Gain.GainControlMode": "ADRV9001_RX_GAIN_CONTROL_MODE_SPI",
"ORx1.Gain.IsDirtyAgc": "True",
"ORx1.Gain.IsDirtyPinControl": "True",
"ORx1.Gain.MaxAgcGainIndex": "14",
"ORx1.Gain.MinAgcGainIndex": "2",
"ORx1.Gain.MaxExtantGainIndex": "14",
"ORx1.Gain.MinExtantGainIndex": "2",
"ORx1.Gain.GainControl.Mode": "ADRV9001_RX_GAIN_CONTROL_DETECTION_MODE_PEAK_AND_POWER",
"ORx1.Gain.GainControl.PeakOverloadThreshold": "0",
"ORx1.Gain.GainControl.PeakUnderloadThreshold": "0",
"ORx1.Gain.GainControl.PowerOverloadThreshold": "0",
"ORx1.Gain.GainControl.PowerUnderloadThreshold": "0",
"ORx1.Gain.GainControl.OverloadGainStep": "0",
"ORx1.Gain.GainControl.UnderloadGainStep": "0",
"ORx1.Gain.GainControl.GainRefreshPeriod_us": "0",
"ORx1.Gain.GainControl.MeasurementDelay_us": "0",
"ORx1.Gain.GainControl.MeasurementDuration_us": "0",
"ORx1.Gain.GainControl.LowThreshPreventIncrement": "False",
"ORx1.Gain.GainControl.RxQecFreezeEnable": "True",
"ORx1.Gain.GainControl.HbDetectorEnable": "False",
"ORx1.Gain.GainControl.ApdDetectorEnable": "False",
"ORx1.Gain.GainControl.ResetOnRxOn": "False",
"ORx1.Gain.GainControl.OverrangeCrumb": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"ORx1.Gain.GainControl.UnderrangeCrumb": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"ORx1.Gain.GainControl.-1.Pin": "ADRV9001_GPIO_UNASSIGNED",
"ORx1.Gain.GainControlPinConfiguration.DecrementStepSize": "0",
"ORx1.Gain.GainControlPinConfiguration.IncrementStepSize": "0",
"ORx1.Gain.GainControlPinConfiguration.IncrementPin": "ADRV9001_GPIO_UNASSIGNED",
"ORx1.Gain.GainControlPinConfiguration.DecrementPin": "ADRV9001_GPIO_UNASSIGNED",
"ORx1.Gain.GainIndexReadout.Bits01And00": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"ORx1.Gain.GainIndexReadout.Bits03And02": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"ORx1.Gain.GainIndexReadout.Bits05And04": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"ORx1.Gain.GainIndexReadout.ChangeBitAndBit06": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"ORx1.InitCals.Flags": "ADRV9001_INIT_CAL_RX_QEC_FIC, ADRV9001_INIT_CAL_RX_RF_DC_OFFSET",
"ORx1.InterfaceGain.Gain_dB": "ADRV9001_RX_INTERFACE_GAIN_0_DB",
"ORx1.InterfaceGain.SeedGain_dB": "ADRV9001_RX_INTERFACE_GAIN_18_DB",
"ORx1.InterfaceGain.EndOfFrameGain_dB": "ADRV9001_RX_INTERFACE_GAIN_18_DB",
"ORx1.InterfaceGain.UpdateTiming": "ADRV9001_RX_INTERFACE_GAIN_UPDATE_TIMING_NOW",
"ORx1.InterfaceGain.ControlMode": "ADRV9001_RX_INTERFACE_GAIN_CONTROL_MANUAL",
"ORx1.InterfaceGain.RssiDuration": "255",
"ORx1.InterfaceGain.RssiMovingAverageDuration": "10",
"ORx1.InterfaceGain.GainControlAutomaticThreshold_dBFS": "-2",
"ORx1.InterfaceGain.SignalPAR": "15",
"ORx1.InterfaceGain.EnableFastAttack": "False",
"ORx1.LoopGain": "65536",
"ORx1.Flags": "ADRV9001_TRACKING_CAL_RX_HD2, ADRV9001_TRACKING_CAL_RX_BBDC, ADRV9001_TRACKING_CAL_RX_RFDC, ADRV9001_TRACKING_CAL_RX_QEC_FIC, ADRV9001_TRACKING_CAL_RX_GAIN_CONTROL_DETECTORS",
"ORx1.ADRV9001_GPIO_SIGNAL_ORX_ENABLE_1.Pin": "ADRV9001_GPIO_UNASSIGNED",
"Channel1.PowerSavings.PinPowerDownMode": "ADRV9001_POWERSAVINGANDMONITORMODE_CHANNEL_MODE_DISABLED",
"Channel1.PowerSavings.RadioOffPowerDownMode": "ADRV9001_POWERSAVINGANDMONITORMODE_CHANNEL_MODE_DISABLED",
"Channel1.PowerSavings.ADRV9001_GPIO_SIGNAL_POWER_SAVING_CHANNEL1.Pin": "ADRV9001_GPIO_UNASSIGNED",
"Channel2.SsiType": "ADRV9001_SSI_TYPE_CMOS",
"Channel2.SsiNumLanes": "ADRV9001_SSI_1_LANE",
"Channel2.SsiDataRate": "SINGLE",
"Channel2.SsiStrobeType": "ADRV9001_SSI_SHORT_STROBE",
"Channel2.ChannelEnableMode": "ADRV9001_SPI_MODE",
"Channel2.SsiPowerDown": "ADRV9001_SSI_POWER_DOWN_DISABLED",
"Channel2.ExternalPathDelay_ps": "0",
"Channel2.TxDacFullScaleBoostEnable": "False",
"Channel2.RxToTxLoopback": "False",
"Channel2.TxToRxLoopback": "False",
"Channel2.ChannelEnabled": "True",
"Tx2.DataportSampleRate_Hz": "1000000",
"Tx2.SsiRefClock": "ADRV9001_SSI_TX_REF_CLOCK_PIN_DCLK_OUT_ENABLED",
"Tx2.CarrierFrequency_Hz": "450000000",
"Tx2.Interpolation": "1",
"Tx2.ContinuousTransfer": "True",
"Tx2.RfBandwidth_Hz": "25000",
"Tx2.PowerConsumption": "ADRV9001_COMPONENT_POWER_LEVEL_LOW",
"Tx2.DesiredLoForDualHop": "ADRV9001_LOSEL_LO1",
"Tx2.SsiInterfaceRate_Hz": "1000000",
"Tx2.Lpf3dBCornerFrequency_Hz": "50000000",
"Tx2.Lpf1dBFrequency_Hz": "0",
"Tx2.WidebandFilter": "BW_80",
"Tx2.McsToStrobeLatency": "65535",
"Tx2.ReadDelay": "5",
"Tx2.SampleDelay": "0",
"Tx2.Analysis": "None",
"Tx2.UDP.Enabled": "False",
"Tx2.UDP.Port": "11006",
"Tx2.UDP.Host0": "127",
"Tx2.UDP.Host1": "0",
"Tx2.UDP.Host2": "0",
"Tx2.UDP.Host3": "1",
"Tx2.UDP.Host": "127.0.0.1",
"Tx2.ChannelFilter0.Type": "DISABLED",
"Tx2.ChannelFilter0.FileName": "DISABLED",
"Tx2.ChannelFilter1.Type": "LOOK_UP",
"Tx2.ChannelFilter1.FileName": "LOOK_UP",
"Tx2.ChannelFilter2.Type": "LOOK_UP",
"Tx2.ChannelFilter2.FileName": "LOOK_UP",
"Tx2.ChannelFilter3.Type": "LOOK_UP",
"Tx2.ChannelFilter3.FileName": "LOOK_UP",
"Tx2.ChannelFilter4.Type": "LOOK_UP",
"Tx2.ChannelFilter4.FileName": "LOOK_UP",
"Tx2.ChannelFilter5.Type": "LOOK_UP",
"Tx2.ChannelFilter5.FileName": "LOOK_UP",
"Tx2.FrequencyCorrection.Enable": "True",
"Tx2.FrequencyCorrection.IsImmediate": "True",
"Tx2.FrequencyCorrection.Freq_Hz": "0",
"Tx2.DPD.ChangeModelTapOrders": "False",
"Tx2.DPD.PreLutScale": "8",
"Tx2.DPD.Enable": "False",
"Tx2.DPD.ClgcEnable": "False",
"Tx2.DPD.CaptureDelay_us": "0",
"Tx2.DPD.ClgcLoopOpen": "False",
"Tx2.DPD.ClgcGainTarget": "0",
"Tx2.DPD.ClgcFilterAlpha": "0.75",
"Tx2.DPD.ClgcLastGain_HundredthdB": "0",
"Tx2.DPD.ClgcFilteredGain_HundredthdB": "0",
"Tx2.DPD.NumberOfSamples": "0",
"Tx2.DPD.AdditionalPowerScale": "4",
"Tx2.DPD.TimeFilterCoefficient": "0",
"Tx2.DPD.DetectionPowerThreshold": "53942350",
"Tx2.DPD.DetectionPeakThreshold": "214748365",
"Tx2.DPD.CountsGreaterThanPeakThreshold": "0",
"Tx2.DPD.CountsLessThanPowerThreshold": "4096",
"Tx2.DPD.Detection": "Peak",
"Tx2.DPD.EnableRepeatedEstimationInTDD": "False",
"Tx2.DPD.Region0.Enable": "False",
"Tx2.DPD.Region0.LowerBound_Hz": "0",
"Tx2.DPD.Region0.UpperBound_Hz": "0",
"Tx2.DPD.Region1.Enable": "False",
"Tx2.DPD.Region1.LowerBound_Hz": "0",
"Tx2.DPD.Region1.UpperBound_Hz": "0",
"Tx2.DPD.Region2.Enable": "False",
"Tx2.DPD.Region2.LowerBound_Hz": "0",
"Tx2.DPD.Region2.UpperBound_Hz": "0",
"Tx2.DPD.Region3.Enable": "False",
"Tx2.DPD.Region3.LowerBound_Hz": "0",
"Tx2.DPD.Region3.UpperBound_Hz": "0",
"Tx2.DPD.Region4.Enable": "False",
"Tx2.DPD.Region4.LowerBound_Hz": "0",
"Tx2.DPD.Region4.UpperBound_Hz": "0",
"Tx2.DPD.Region5.Enable": "False",
"Tx2.DPD.Region5.LowerBound_Hz": "0",
"Tx2.DPD.Region5.UpperBound_Hz": "0",
"Tx2.DPD.Region6.Enable": "False",
"Tx2.DPD.Region6.LowerBound_Hz": "0",
"Tx2.DPD.Region6.UpperBound_Hz": "0",
"Tx2.InitCals.Flags": "ADRV9001_INIT_CAL_TX_QEC, ADRV9001_INIT_CAL_TX_LO_LEAKAGE, ADRV9001_INIT_CAL_TX_LB_PD",
"Tx2.PaRamp.Enable": "False",
"Tx2.PaRamp.Trigger": "ADRV9001_TX_PA_RAMP_TRIGGER_SPI",
"Tx2.PaRamp.AsymmetricRamp": "False",
"Tx2.PaRamp.TriggerDelayFall": "5",
"Tx2.PaRamp.TriggerDelayRise": "5",
"Tx2.PaRamp.RampClock_kHz": "1000",
"Tx2.PaRamp.UpEndIndex": "0",
"Tx2.PaRamp.DownEndIndex": "0",
"Tx2.PaRamp.ADRV9001_GPIO_SIGNAL_TX2_PA_RAMP_CTRL.Pin": "ADRV9001_GPIO_UNASSIGNED",
"Tx2.Delay.PropagationDelay_ns": "926000",
"Tx2.Delay.RiseToAnalogOnDelay_ns": "918500",
"Tx2.Delay.RiseToOnDelay_ns": "926000",
"Tx2.Delay.HoldDelay_ns": "0",
"Tx2.Delay.FallToOffDelay_ns": "926000",
"Tx2.TxFrontEnd.Enabled": "False",
"Tx2.LoopGain": "65536",
"Tx2.Flags": "0",
"Tx2.Attenuation.AttenuationControlPinConfiguration.IncrementPin": "ADRV9001_GPIO_UNASSIGNED",
"Tx2.Attenuation.AttenuationControlPinConfiguration.DecrementPin": "ADRV9001_GPIO_UNASSIGNED",
"Rx2.SignalType": "IQ16",
"Rx2.RfInput": "ADRV9001_RX_A",
"Rx2.IntermediateFrequency_kHz": "950",
"Rx2.IntermediateFrequencyEnable": "True",
"Rx2.CarrierFrequency_Hz": "350000000",
"Rx2.AdcOptimization": "ADRV9001_ADC_HP",
"Rx2.AnalogFilterOrder": "ORDER_2",
"Rx2.RfBandwidth_Hz": "300000",
"Rx2.PowerConsumption": "ADRV9001_COMPONENT_POWER_LEVEL_HIGH",
"Rx2.DesiredLoForDualHop": "ADRV9001_LOSEL_LO2",
"Rx2.DataportSampleRate_Hz": "1000000",
"Rx2.SsiInterfaceRate_Hz": "1000000",
"Rx2.Lpf3dBCornerFrequency_Hz": "6702000",
"Rx2.Lpf1dBFrequency_Hz": "4740000",
"Rx2.WidebandFilter": "BW_80",
"Rx2.McsToStrobeLatency": "25",
"Rx2.ReadDelay": "1",
"Rx2.SampleDelay": "0",
"Rx2.Analysis": "SingleTone",
"Rx2.UDP.Enabled": "False",
"Rx2.UDP.Port": "11005",
"Rx2.UDP.Host0": "127",
"Rx2.UDP.Host1": "0",
"Rx2.UDP.Host2": "0",
"Rx2.UDP.Host3": "1",
"Rx2.UDP.Host": "127.0.0.1",
"Rx2.ChannelFilter0.Type": "CUSTOM",
"Rx2.ChannelFilter0.FileName": "..\\..\\..\\Users\\LocalAdmin\\Documents\\adrv9002\\250311\\fsk_fir_coefficients\\fskfir.csv",
"Rx2.ChannelFilter1.Type": "LOOK_UP",
"Rx2.ChannelFilter1.FileName": "LOOK_UP",
"Rx2.ChannelFilter2.Type": "LOOK_UP",
"Rx2.ChannelFilter2.FileName": "LOOK_UP",
"Rx2.ChannelFilter3.Type": "LOOK_UP",
"Rx2.ChannelFilter3.FileName": "LOOK_UP",
"Rx2.ChannelFilter4.Type": "LOOK_UP",
"Rx2.ChannelFilter4.FileName": "LOOK_UP",
"Rx2.ChannelFilter5.Type": "LOOK_UP",
"Rx2.ChannelFilter5.FileName": "LOOK_UP",
"Rx2.FrequencyCorrection.Enable": "True",
"Rx2.FrequencyCorrection.IsImmediate": "True",
"Rx2.FrequencyCorrection.Freq_Hz": "0",
"Rx2.BbdcRejection.BasebandDcRejection": "ADRV9001_BBDC_REJECTION_ENABLED",
"Rx2.Delay.PropagationDelay_ns": "2350000",
"Rx2.Delay.RiseToAnalogOnDelay_ns": "0",
"Rx2.Delay.RiseToOnDelay_ns": "8000",
"Rx2.Delay.HoldDelay_ns": "2350000",
"Rx2.Delay.FallToOffDelay_ns": "0",
"Rx2.Gain.InitRxGain": "247",
"Rx2.Gain.IsDirtyAgc": "False",
"Rx2.Gain.IsDirtyPinControl": "False",
"Rx2.Gain.MaxAgcGainIndex": "255",
"Rx2.Gain.MinAgcGainIndex": "195",
"Rx2.Gain.MaxExtantGainIndex": "255",
"Rx2.Gain.MinExtantGainIndex": "187",
"Rx2.Gain.GainControl.LowThreshPreventIncrement": "False",
"Rx2.Gain.GainControl.RxQecFreezeEnable": "True",
"Rx2.Gain.GainControl.HbDetectorEnable": "False",
"Rx2.Gain.GainControl.ApdDetectorEnable": "False",
"Rx2.Gain.GainControl.ResetOnRxOn": "False",
"Rx2.Gain.GainControl.OverrangeCrumb": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"Rx2.Gain.GainControl.UnderrangeCrumb": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"Rx2.Gain.GainControl.-1.Pin": "ADRV9001_GPIO_UNASSIGNED",
"Rx2.Gain.GainControlPinConfiguration.IncrementPin": "ADRV9001_GPIO_UNASSIGNED",
"Rx2.Gain.GainControlPinConfiguration.DecrementPin": "ADRV9001_GPIO_UNASSIGNED",
"Rx2.Gain.GainIndexReadout.Bits01And00": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"Rx2.Gain.GainIndexReadout.Bits03And02": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"Rx2.Gain.GainIndexReadout.Bits05And04": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"Rx2.Gain.GainIndexReadout.ChangeBitAndBit06": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"Rx2.InitCals.Flags": "ADRV9001_INIT_CAL_RX_QEC_FIC, ADRV9001_INIT_CAL_RX_RF_DC_OFFSET",
"Rx2.InterfaceGain.SeedGain_dB": "ADRV9001_RX_INTERFACE_GAIN_0_DB",
"Rx2.InterfaceGain.EndOfFrameGain_dB": "ADRV9001_RX_INTERFACE_GAIN_18_DB",
"Rx2.InterfaceGain.RssiDuration": "255",
"Rx2.InterfaceGain.RssiMovingAverageDuration": "10",
"Rx2.InterfaceGain.GainControlAutomaticThreshold_dBFS": "-2",
"Rx2.InterfaceGain.SignalPAR": "15",
"Rx2.InterfaceGain.EnableFastAttack": "False",
"Rx2.LoopGain": "65536",
"Rx2.Flags": "ADRV9001_TRACKING_CAL_RX_HD2, ADRV9001_TRACKING_CAL_RX_BBDC, ADRV9001_TRACKING_CAL_RX_RFDC, ADRV9001_TRACKING_CAL_RX_QEC_FIC, ADRV9001_TRACKING_CAL_RX_GAIN_CONTROL_DETECTORS",
"Rx2.RxFrontEnd.Enabled": "False",
"Rx2.GainBits.Select": "ADRV9001_RX_GAIN_INDEX_GAIN_CHANGE_ZEROES",
"Rx2.GainBits.AgcGainDelay": "0",
"Rx2.GainBits.InterfaceGainDelay": "0",
"ORx2.SignalType": "Disabled",
"ORx2.IntermediateFrequency_kHz": "490",
"ORx2.IntermediateFrequencyEnable": "True",
"ORx2.CarrierFrequency_Hz": "450000000",
"ORx2.AdcOptimization": "ADRV9001_ADC_LP",
"ORx2.AnalogFilterOrder": "ORDER_1",
"ORx2.RfInput": "ADRV9001_RX_B",
"ORx2.RfBandwidth_Hz": "12000",
"ORx2.PowerConsumption": "ADRV9001_COMPONENT_POWER_LEVEL_LOW",
"ORx2.DesiredLoForDualHop": "0",
"ORx2.DataportSampleRate_Hz": "24000",
"ORx2.SsiInterfaceRate_Hz": "24000",
"ORx2.Lpf3dBCornerFrequency_Hz": "0",
"ORx2.Lpf1dBFrequency_Hz": "20000000",
"ORx2.WidebandFilter": "BW_80",
"ORx2.McsToStrobeLatency": "0",
"ORx2.ReadDelay": "0",
"ORx2.SampleDelay": "0",
"ORx2.Analysis": "SingleTone",
"ORx2.UDP.Enabled": "False",
"ORx2.UDP.Port": "11008",
"ORx2.UDP.Host0": "127",
"ORx2.UDP.Host1": "0",
"ORx2.UDP.Host2": "0",
"ORx2.UDP.Host3": "1",
"ORx2.UDP.Host": "127.0.0.1",
"ORx2.ChannelFilter0.Type": "LOOK_UP",
"ORx2.ChannelFilter0.FileName": "LOOK_UP",
"ORx2.ChannelFilter1.Type": "LOOK_UP",
"ORx2.ChannelFilter1.FileName": "LOOK_UP",
"ORx2.ChannelFilter2.Type": "LOOK_UP",
"ORx2.ChannelFilter2.FileName": "LOOK_UP",
"ORx2.ChannelFilter3.Type": "LOOK_UP",
"ORx2.ChannelFilter3.FileName": "LOOK_UP",
"ORx2.ChannelFilter4.Type": "LOOK_UP",
"ORx2.ChannelFilter4.FileName": "LOOK_UP",
"ORx2.ChannelFilter5.Type": "LOOK_UP",
"ORx2.ChannelFilter5.FileName": "LOOK_UP",
"ORx2.FrequencyCorrection.Enable": "False",
"ORx2.FrequencyCorrection.IsImmediate": "True",
"ORx2.FrequencyCorrection.Freq_Hz": "0",
"ORx2.BbdcRejection.BasebandDcRejection": "ADRV9001_BBDC_REJECTION_ENABLED",
"ORx2.Delay.PropagationDelay_ns": "0",
"ORx2.Delay.RiseToAnalogOnDelay_ns": "0",
"ORx2.Delay.RiseToOnDelay_ns": "8000",
"ORx2.Delay.HoldDelay_ns": "0",
"ORx2.Delay.FallToOffDelay_ns": "0",
"ORx2.Gain.InitRxGain": "12",
"ORx2.Gain.GainControlMode": "ADRV9001_RX_GAIN_CONTROL_MODE_SPI",
"ORx2.Gain.IsDirtyAgc": "True",
"ORx2.Gain.IsDirtyPinControl": "True",
"ORx2.Gain.MaxAgcGainIndex": "14",
"ORx2.Gain.MinAgcGainIndex": "2",
"ORx2.Gain.MaxExtantGainIndex": "14",
"ORx2.Gain.MinExtantGainIndex": "2",
"ORx2.Gain.GainControl.Mode": "ADRV9001_RX_GAIN_CONTROL_DETECTION_MODE_PEAK_AND_POWER",
"ORx2.Gain.GainControl.PeakOverloadThreshold": "0",
"ORx2.Gain.GainControl.PeakUnderloadThreshold": "0",
"ORx2.Gain.GainControl.PowerOverloadThreshold": "0",
"ORx2.Gain.GainControl.PowerUnderloadThreshold": "0",
"ORx2.Gain.GainControl.OverloadGainStep": "0",
"ORx2.Gain.GainControl.UnderloadGainStep": "0",
"ORx2.Gain.GainControl.GainRefreshPeriod_us": "0",
"ORx2.Gain.GainControl.MeasurementDelay_us": "0",
"ORx2.Gain.GainControl.MeasurementDuration_us": "0",
"ORx2.Gain.GainControl.LowThreshPreventIncrement": "False",
"ORx2.Gain.GainControl.RxQecFreezeEnable": "True",
"ORx2.Gain.GainControl.HbDetectorEnable": "False",
"ORx2.Gain.GainControl.ApdDetectorEnable": "False",
"ORx2.Gain.GainControl.ResetOnRxOn": "False",
"ORx2.Gain.GainControl.OverrangeCrumb": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"ORx2.Gain.GainControl.UnderrangeCrumb": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"ORx2.Gain.GainControl.-1.Pin": "ADRV9001_GPIO_UNASSIGNED",
"ORx2.Gain.GainControlPinConfiguration.DecrementStepSize": "0",
"ORx2.Gain.GainControlPinConfiguration.IncrementStepSize": "0",
"ORx2.Gain.GainControlPinConfiguration.IncrementPin": "ADRV9001_GPIO_UNASSIGNED",
"ORx2.Gain.GainControlPinConfiguration.DecrementPin": "ADRV9001_GPIO_UNASSIGNED",
"ORx2.Gain.GainIndexReadout.Bits01And00": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"ORx2.Gain.GainIndexReadout.Bits03And02": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"ORx2.Gain.GainIndexReadout.Bits05And04": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"ORx2.Gain.GainIndexReadout.ChangeBitAndBit06": "ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED",
"ORx2.InitCals.Flags": "ADRV9001_INIT_CAL_RX_QEC_FIC, ADRV9001_INIT_CAL_RX_RF_DC_OFFSET",
"ORx2.InterfaceGain.Gain_dB": "ADRV9001_RX_INTERFACE_GAIN_0_DB",
"ORx2.InterfaceGain.SeedGain_dB": "ADRV9001_RX_INTERFACE_GAIN_18_DB",
"ORx2.InterfaceGain.EndOfFrameGain_dB": "ADRV9001_RX_INTERFACE_GAIN_18_DB",
"ORx2.InterfaceGain.UpdateTiming": "ADRV9001_RX_INTERFACE_GAIN_UPDATE_TIMING_NOW",
"ORx2.InterfaceGain.ControlMode": "ADRV9001_RX_INTERFACE_GAIN_CONTROL_MANUAL",
"ORx2.InterfaceGain.RssiDuration": "255",
"ORx2.InterfaceGain.RssiMovingAverageDuration": "10",
"ORx2.InterfaceGain.GainControlAutomaticThreshold_dBFS": "-2",
"ORx2.InterfaceGain.SignalPAR": "15",
"ORx2.InterfaceGain.EnableFastAttack": "False",
"ORx2.LoopGain": "65536",
"ORx2.Flags": "ADRV9001_TRACKING_CAL_RX_HD2, ADRV9001_TRACKING_CAL_RX_BBDC, ADRV9001_TRACKING_CAL_RX_RFDC, ADRV9001_TRACKING_CAL_RX_QEC_FIC, ADRV9001_TRACKING_CAL_RX_GAIN_CONTROL_DETECTORS",
"ORx2.ADRV9001_GPIO_SIGNAL_ORX_ENABLE_2.Pin": "ADRV9001_GPIO_UNASSIGNED",
"Channel2.PowerSavings.PinPowerDownMode": "ADRV9001_POWERSAVINGANDMONITORMODE_CHANNEL_MODE_DISABLED",
"Channel2.PowerSavings.RadioOffPowerDownMode": "ADRV9001_POWERSAVINGANDMONITORMODE_CHANNEL_MODE_DISABLED",
"Channel2.PowerSavings.ADRV9001_GPIO_SIGNAL_POWER_SAVING_CHANNEL2.Pin": "ADRV9001_GPIO_UNASSIGNED",
"LO1.Source": "INTERNAL",
"LO1.PowerConsumption": "ADRV9001_PLL_POWER_HIGH",
"LO1.LoopBandwidth_kHz": "300",
"LO1.PllCalibration": "ADRV9001_PLL_CALIBRATION_NORMAL",
"LO1.Optimization": "ADRV9001_LO_GEN_OPTIMIZATION_POWER_CONSUMPTION",
"LO2.Source": "INTERNAL",
"LO2.PowerConsumption": "ADRV9001_PLL_POWER_HIGH",
"LO2.LoopBandwidth_kHz": "300",
"LO2.PllCalibration": "ADRV9001_PLL_CALIBRATION_NORMAL",
"LO2.Optimization": "ADRV9001_LO_GEN_OPTIMIZATION_POWER_CONSUMPTION",
"TDD.DmaSync": "False",
"TDD.TddClock_Hz": "199309000",
"TDD.FileName": "..\\..\\..\\Users\\LocalAdmin\\Analog Devices\\ADRV9001 Transceiver Evaluation Software\\Examples\\Automated TDD Configurations\\DMR_24K_RX_ONLY.json",
"RadioStateLock": "False",
"MonitorMode.PowerDownMode": "0",
"MonitorMode.DetectionFirst": "0",
"MonitorMode.DetectionMode": "ADRV9001_POWERSAVINGANDMONITORMODE_MONITOR_DETECTION_MODE_RSSI",
"MonitorMode.FastBufferReadEnable": "False",
"MonitorMode.ExternalPllEnable": "False",
"MonitorMode.InitialBatterySaverDelay_us": "0",
"MonitorMode.BbicWakeupLevelEnable": "False",
"SystemPowerSavings.ADRV9001_GPIO_SIGNAL_MON_ENABLE_SPS.Pin": "ADRV9001_GPIO_UNASSIGNED",
"MonitorMode.Rssi.DetectionThreshold_mdBFS": "-80000",
"MonitorMode.Rssi.MeasurementDuration_samples": "10",
"MonitorMode.Rssi.MeasurementsStartPeriod_ms": "1",
"MonitorMode.Rssi.NumberOfMeasurementsToAverage": "4",
"MonitorMode.Vector.VectorMask": "1",
"MonitorMode.DmrPdCalibration.MayEnable": "False",
"MonitorMode.DmrPdCalibration.RunCal": "RUN_CAL",
"MonitorMode.DmrPdCalibration.Delay": "0",
"MonitorModeWakeup.ADRV9001_GPIO_SIGNAL_MON_BBIC_WAKEUP.Pin": "ADRV9001_GPIO_UNASSIGNED",
".LNA.ExternalLnaPinSel": "ADRV9001_EXTERNAL_LNA_PIN_RX1_LOWER_RX2_UPPER",
".LNA.SettlingDelay": "0",
".LNA.LnaType": "ADRV9001_EXTERNAL_LNA_TYPE_SINGLE",
".LNA.NumberLnaGainSteps": "4",
".LNA.LnaGainStep1": "0",
".LNA.LnaGainStep2": "0",
".LNA.LnaGainStep3": "0",
".LNA.LnaGainStep4": "0",
".LNA.LnaDigitalGainDelay": "0",
".LNA.Enabled": "ADRV9001_GPIO_ANALOG_PIN_NIBBLE_UNASSIGNED",
"FrequencyHopping.Mode": "ADRV9001_FHMODE_LO_MUX_REALTIME_PROCESS",
"FrequencyHopping.MinFrameDuration_us": "30000",
"FrequencyHopping.PllLockWait_us": "0",
"FrequencyHopping.PllPhaseSyncWait_us": "0",
"FrequencyHopping.TransitionTime_us": "2500",
"FrequencyHopping.DynamicTableLoad": "False",
"FrequencyHopping.NumberOfRowsToLoad": "ADRV9001_FH_HOP_PER_DYNAMIC_LOAD_ONE",
"FrequencyHopping.ZeroIf": "False",
"FrequencyHopping.MinOperatingFrequency_Hz": "0",
"FrequencyHopping.MaxOperatingFrequency_Hz": "0",
"FrequencyHopping.MaxRxGainIndex": "0",
"FrequencyHopping.MinRxGainIndex": "0",
"FrequencyHopping.GainSetupByPin": "False",
"FrequencyHopping.TableIndexCtrl": "ADRV9001_TABLEINDEXCTRL_AUTO_PING_PONG",
"FrequencyHopping.MinTxAtten_dB": "0",
"FrequencyHopping.MaxTxAtten_dB": "0",
"FrequencyHopping.GainSetupByPin1.GainTable.FileName": "Disabled",
"FrequencyHopping.GainSetupByPin1.AttenTable.FileName": "Disabled",
"FrequencyHopping.GainSetupByPin1.GainAttenIndex.FileName": "Disabled",
"FrequencyHopping.GainSetupByPin1.GAIN_ATTEN_INDEX_PIN_1": "ADRV9001_GPIO_UNASSIGNED",
"FrequencyHopping.GainSetupByPin1.GAIN_ATTEN_INDEX_PIN_2": "ADRV9001_GPIO_UNASSIGNED",
"FrequencyHopping.GainSetupByPin1.GAIN_ATTEN_INDEX_PIN_3": "ADRV9001_GPIO_UNASSIGNED",
"FrequencyHopping.GainSetupByPin2.GainTable.FileName": "Disabled",
"FrequencyHopping.GainSetupByPin2.AttenTable.FileName": "Disabled",
"FrequencyHopping.GainSetupByPin2.GainAttenIndex.FileName": "Disabled",
"FrequencyHopping.GainSetupByPin2.GAIN_ATTEN_INDEX_PIN_1": "ADRV9001_GPIO_UNASSIGNED",
"FrequencyHopping.GainSetupByPin2.GAIN_ATTEN_INDEX_PIN_2": "ADRV9001_GPIO_UNASSIGNED",
"FrequencyHopping.GainSetupByPin2.GAIN_ATTEN_INDEX_PIN_3": "ADRV9001_GPIO_UNASSIGNED",
"FrequencyHopping.ADRV9001_GPIO_SIGNAL_FH_HOP.Pin": "ADRV9001_GPIO_UNASSIGNED",
"FrequencyHopping.ADRV9001_GPIO_SIGNAL_FH_HOP_2.Pin": "ADRV9001_GPIO_UNASSIGNED",
"FfhTableA.Enabled": "False",
"FfhTableA.FileName": "",
"FfhTableB.Enabled": "False",
"FfhTableB.FileName": "",
"FrequencyHopping.TableIndexByPin.TableIndices": "[]",
"FrequencyHopping.TableIndexByPin.TableIndexSequence.FileName": "",
"FrequencyHopping.TableIndexByPin.TABLE_INDEX_PIN_1": "ADRV9001_GPIO_UNASSIGNED",
"FrequencyHopping.TableIndexByPin.TABLE_INDEX_PIN_2": "ADRV9001_GPIO_UNASSIGNED",
"FrequencyHopping.TableIndexByPin.TABLE_INDEX_PIN_3": "ADRV9001_GPIO_UNASSIGNED",
"FrequencyHopping.TableIndexByPin.TABLE_INDEX_PIN_4": "ADRV9001_GPIO_UNASSIGNED",
"FrequencyHopping.TableIndexByPin.TABLE_INDEX_PIN_5": "ADRV9001_GPIO_UNASSIGNED",
"FrequencyHopping.TableIndexByPin.TABLE_INDEX_PIN_6": "ADRV9001_GPIO_UNASSIGNED",
"FrequencyHopping.RuntimeFrameIndex": "0",
"FrequencyHopping.NumChannels": "0",
"FrequencyHopping.TableSwitchSequence1.MayEnable": "False",
"FrequencyHopping.TableSwitchSequence1.MayChoose": "False",
"FrequencyHopping.TableSwitchSequence1.Switches": "[]",
"FrequencyHopping.TableSwitchSequence1.FileName": "",
"FrequencyHopping.TableSwitchSequence1.ADRV9001_GPIO_SIGNAL_FH_HOP_TABLE_SELECT.Pin": "ADRV9001_GPIO_UNASSIGNED",
".PortSwitch.MinFreqPortA_Hz": "890000000",
".PortSwitch.MaxFreqPortA_Hz": "910000000",
".PortSwitch.MinFreqPortB_Hz": "1890000000",
".PortSwitch.MaxFreqPortB_Hz": "1910000000",
".PortSwitch.Enable": "False",
"SpiMain.Enabled": "False",
"SpiMain.NumBytes": "0",
"SpiMain.BaudRateDiv": "0",
"SpiMain.TransactionBytes": "0",
"SpiMain.TransferMode": "ADRV9001_SPI_MASTER_CS_TRANSFER_TRANSACTION_BYTES",
"SpiMain.SpiSlaveDevicesConnected": "ADRV9001_SPI_MASTER_SLAVE_SINGLE",
"SpiMain.CsSource": "ADRV9001_SPI_MASTER_CS_SOURCE_GPIO_ANALOG",
"SpiMain.Pin": "ADRV9001_GPIO_UNASSIGNED",
"SpiMain.TriggerSource": "ADRV9001_SPI_MASTER_TRIGGER_SOURCE_ARM",
"SpiMain.WakeupTimer_us": "0",
"SpiMain.Analog.ADRV9001_GPIO_NUM_SIGNALS.Pin": "ADRV9001_GPIO_UNASSIGNED",
"SpiMain.Digital.ADRV9001_GPIO_NUM_SIGNALS.Pin": "ADRV9001_GPIO_UNASSIGNED",
"SpiBytes.FileName": ""
)# @ @ P ` p @ 8@ @ @ 8B PC <B PC @B XC DB XC HB XC LB `C PB hC XB lC \B tC `B tC dB tC hB tC lB tC pB tC tB tC xB tC |B tC �B tC �B tC �B tC �B tC �B tC �B tC �B tC �B tC �B �C �B �C �B �C �B �C �B �C �B �C �B �C �B �C �B �C �B �C �B �C �B �C �B �C �B �C �B �C �B �C �B �C �B �C �B �C C �C C �C C �C C �C C �C C �C C �C C �C C �C $C �C (C �C ,C �C 0C �C 4C �C 8C �C <C �C @C �C DC �C HC �C LC �C � ��� � � ��� ��� �Q��� ��� � � � � � � � � � � � � � � � � �ϙ��H�Q����� �ϘQ����� � � � � � � � � � � � � � � � � � � � � � � � � � � � � � � � � � � � � � � � �w t~ { { ~ ������ ���� � ������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������B�o @ $ 0 @ @ \ L p P t X | ` � h � p � t � x � | � � � � � � � � � � � � � � � � � � � � � � � � , � 4 P h � $ � 4 � 8 � < � @ � D � H � L � P � T � X � \ � h � l � p � � � 8 � @ � X � p � t � x � � � � � � � � � � � � � � � � � � � � � �� �� ��������QRS��{jH������ QRS��{jH������ �����Q�ő����� ΘQ��� �Q��� �Q��� �Q���� � � � � Θ���� � � � � � ΘQ�ŘQ�����ŘŘŘŘ�� Θ�ĘQ���Ę�� �Q��� ������ ���Q�ŘH�H�����������ĘQ��Ϙ�� �Q��� ������������������� ���������� ��H������H�H�Q�H���� �� � � � � � � � P�� � ��Q�QyQi@�� ��� ��� ������Q�Ȫ�Q��H����Q�Ȫ�Q��H��Q�Ȫ�Q��H����Ƙ����� ��������������� �� �� �Q�ŢQ��� ���Q���Ę�H�� �� ��� �� �Q���H� �Q�Q�H� �H� �� � � // � ������ |� � ��� ���� � ��� ���� ��*��e� 85� � ��� � ; � � : ���95� ��� � .Q*��<�0�1�� ���4� (�,� 3 / - *00�= ��*��� ���� 8v 8~ 8 8 � PP Q � -�+ � 2 �� 8v �� 8 8 8��8 8688 8 �����',',,��, �,,, ���� ��* ��� ������ ���� / * �� O T T � � � � � �� � � )� �� � � � � �� � � � � ) �4( � ����� Ȁ � ����� Z Z 7 �� / /:�/ |� � �� /� �//� /�44 ��������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������5� @ $ 0 @ @ \ L p P t X | ` � h � p � t � x � | � � � � � � � � � � � � � � � � � � � � � � � � , � 4 P h � $ � 4 � 8 � < � @ � D � H � L � P � T � X � \ � h � l � p � � � 8 � @ � X � p � t � x � � � � � � � � � � � � � � � � � � � � � �� �� ��������QR��yjH������ QR��yjH������ �����Q�ő����� ΘQ��� �Q��� �Q��� �Q���� � � � � Θ���� � � � � � ΘQ�ŘQ�����ŘŘŘŘ�� Θ�ĘQ���Ę�� �Q��� ������ ���Q�ŘH�H�����������ĘQ��Ϙ�� �Q��� ������������������� ���������� ��H������H�H�Q�H���� �� � � � � � � � P�� � ��Q�QyQi@�� ��� ��� ������Q�Ȫ�Q��H����Q�Ȫ�Q��H��Q�Ȫ�Q��H����Ƙ����� ��������������� �� �� �Q�ŢQ��� ���Q���Ę�H�� �� ��� �� �Q���H� �Q�Q�H� �H� �� � � // � ������ |� � ��� ���� � ��� ���� ��*
��f� 85� � ��� � ; � � : ���95� ��� � .Q
00�= ��*
:v :~ : : �
P
P
Q
� -�+ � 2 �� :v �
� : : :��: :6:: : ���
/ * �� O T T
�4( � ������ Ȁ � ������ [ [ 7 �� / /:�/ |� � �� /� �//� /�4
4
����������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������l @ � � � $ 4 D 8 T P X T ` \ d \ l d p d t l x l � x � � � � � � � � � X � l 0 � P $ t | � � � � � � � � � � � � � � � � � � � � $ � @ � H � � � � � $ � 0 � < � @ � D � T h < p D x \ � t � x � | � � � � � � � � � � � � � � � � � � � � � � ��ŘŘ���� ��������QRS��{jH������ QRS��{jH������ �������Q�ő�� �� ΘQ��� � �Q��� � ����� Θ���� ����� � �Q��� ��������HQiQ�H�����������H�������W��Q����Q��W��������������������Q�ș�H������ ������� ���Q�ŘŘ�����Q��q���W��Q��������I�Q��W���Q��q�������ĘQ����������� ���ĘŘQ�ŘQ��q���Q��W����ĘŘ��������������Q�����Q��W��������H�����������Q���� �Q��� ������� ��� ������ ������ ����� ����� ������O�����������Q�HH����� ��� ����Q���Q��H������ȪPrH��Q���Q��H� ����� � ���H�����ȪPrH��Q����q���� P�� ��Q��H�� �Q�QyQi@�� ��� ��� ������Q�Ȫ�Q��H�������Q�Ȫ�Q��H��� ������ ��������������� �� �� �Q�ŢQ��� �R����H�����Ř��ŘQ��H��� �� ������ �� �� � � � � x�0�1� x � ������ |� � ��� ���� � ��� ���� ���c,, � 85� ��� � ���� ���95� ��x � 3 ��0@@.0@@� �����g cU0YU0 � �{d c{ 1 J�J J8� a� 0 � !�0� @ )� �{�� { 0 � � �0 @.0 @�t u �ut� ttu� YY h@@� YY h@@% ��x� .�4�:� a�� 0 < � !� �{� 0{ ��� @ )� �� � �{�� { � ( $x��, ��x ��"� #� 0� )�a � �;�+���0@@.0@@� ����c�" # 0� )�a � �� �J� ��� < ���;; < � - � 2 �!u t 0 � 0 � 00,0[0 000,0a0 00[00,0 0a00,0 �� �: `� : ���b � <�� � � � #=�� ���, , , ���: � � <
