Integrating ADRV9002 with ZC702 on PetaLinux 2023.2 (meta-adi 2023_R2) – Boot Crash & IIO Device Setup
Software Version: 2023.2
Hello everyone,
I’m currently trying to integrate the ADRV9001/2(wiki.analog.com/.../adrv9001) with a ZC702 board(www.xilinx.com/.../ek-z7-zc702-g.html) using PetaLinux 2023.2 and the 2023_R2 branch of meta-adi. Below are the main steps I followed so far:
1) Project Setup:
- Created a PetaLinux 2023.2 project for ZC702.
- Added the Analog Devices Yocto layer (meta-adi) to the project, following the instructions in the meta-adi-xilinx repository (github.com/.../meta-adi-xilinx).
- Used an XSA (hardware design) also generated from /projects/common/zc702 and additionally adrv9001/common/ in Vivado 2023_2.
2) Device Tree Configuration:
- Since there is no built-in ZC702 template in meta-adi for the ADRV9002, I started with
KERNEL_DTB = "zynq-zed-adv7511-adrv9002-rx2tx2"
in petalinuxbsp.conf.
- I then edited the zynq-zed-adv7511-adrv9002-rx2tx2.dts file’s includes (shown as diff):
- #include "zynq-zed.dtsi"
- #include "zynq-zed-adv7511.dtsi"
+ #include "zynq-zc702.dtsi"
+ #include "zynq-zc702-adv7511.dtsi"
#include "zynq-adrv9002-rx2tx2.dtsi"
The kernel sees the ADRV9002 driver (it is visible in menuconfig), but the boot process crashes right after loading the Linux kernel.
My goal is to make ADRV9002 appear as an IIO device so that I can interact with it using the IIO Oscilloscope.
Here are my questions:
1) What might I be missing or doing incorrectly when switching from the ZED-based device tree to the ZC702-based device tree? Are there additional patches, clock configurations, or pin muxing settings required for ZC702 that I haven’t accounted for?
2) Could someone provide a step-by-step guide or best practices on how to properly integrate the ADRV9002 driver into the ZC702 device tree and ensure that it is recognized as an IIO device?
3) Are there any known hardware constraints (e.g., SPI bus, clock routing, etc.) or kernel configuration details (e.g., specific defconfig fragments) that are crucial for the ADRV9002 to function on ZC702? Last but not least, the log in the boot process is attached.
U-Boot 2023.01 (Sep 21 2023 - 11:02:37 +0000)
CPU:   Zynq 7z020
Silicon: v3.1
Model: Xilinx Zynq ZED
DRAM:  ECC disabled 512 MiB
Core:  35 devices, 17 uclasses, devicetree: board
Flash: 0 Bytes
NAND:  0 MiB
MMC:   mmc@e0100000: 0
Loading Environment from FAT... *** Error - No Valid Environment Area found
*** Warning - bad env area, using default environment
In:    serial@e0001000
Out:   serial@e0001000
Err:   serial@e0001000
Net:   Could not get PHY for eth0: addr 0
No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
3473 bytes read in 13 ms (260.7 KiB/s)
## Executing script at 03000000
Trying to load boot images from mmc0
8470784 bytes read in 475 ms (17 MiB/s)
## Loading kernel from FIT Image at 10000000 ...
   Using 'conf-system-top.dtb' configuration
   Verifying Hash Integrity ... OK
   Trying 'kernel-1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x10000108
     Data Size:    8441872 Bytes = 8.1 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x00200000
     Entry Point:  0x00200000
     Hash algo:    sha256
     Hash value:   266f7a8a6255cb117cec3b2de1fcfb54b95aa914623d7db6cb65e777c5e51383
   Verifying Hash Integrity ... sha256+ OK
## Loading fdt from FIT Image at 10000000 ...
   Trying 'fdt-system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x1080d224
     Data Size:    26997 Bytes = 26.4 KiB
     Architecture: ARM
     Hash algo:    sha256
     Hash value:   4107a73dd5b04591bffa47dc0b93511e46005d66911d59342cd69e80fda3c365
   Booting using the fdt blob at 0x1080d224
Working FDT set to 1080d224
   Loading Kernel Image
   Loading Device Tree to 1eac4000, end 1eacd974 ... OK
Working FDT set to 1eac4000
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 6.1.70adi-v2023.2 (oe-user@oe-host) (arm-xilinx-linux-gnueabi-gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0.20220819) #1 SMP PREEMPT Wed Jan  8 08:42:31 UTC 2025
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt: Machine model: Xilinx Zynq ZED
earlycon: cdns0 at MMIO 0xe0001000 (options '115200n8')
printk: bootconsole [cdns0] enabled
Memory policy: Data cache writealloc
cma: Reserved 128 MiB at 0x16800000
Zone ranges:
  Normal   [mem 0x0000000000000000-0x000000001fffffff]
  HighMem  empty
Movable zone start for each node
Early memory node ranges
  node   0: [mem 0x0000000000000000-0x000000001fffffff]
Initmem setup node 0 [mem 0x0000000000000000-0x000000001fffffff]
percpu: Embedded 11 pages/cpu s14420 r8192 d22444 u45056
Built 1 zonelists, mobility grouping on.  Total pages: 130048
Kernel command line: console=ttyPS0,115200 earlycon root=/dev/mmcblk0p2 ro rootwait
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
mem auto-init: stack:all(zero), heap alloc:off, heap free:off
Memory: 361888K/524288K available (12288K kernel code, 819K rwdata, 10388K rodata, 1024K init, 469K bss, 31328K reserved, 131072K cma-reserved, 0K highmem)
rcu: Preemptible hierarchical RCU implementation.
rcu:    RCU event tracing is enabled.
rcu:    RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
efuse mapped to (ptrval)
slcr mapped to (ptrval)
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
rcu: srcu_init: Setting srcu_struct sizes based on contention.
zynq_clock_init: clkc starts at (ptrval)
Zynq clock init
sched_clock: 64 bits at 167MHz, resolution 6ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x26703d7dd8, max_idle_ns: 440795208065 ns
Switching to timer-based delay loop, resolution 6ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at (ptrval), irq=25
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 333.33 BogoMIPS (lpj=1666666)
CPU: Testing write buffer coherency: ok
CPU0: Spectre v2: using BPIALL workaround
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x100000 - 0x100060
rcu: Hierarchical SRCU implementation.
rcu:    Max phase no-delay instances is 1000.
smp: Bringing up secondary CPUs ...
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU1: Spectre v2: using BPIALL workaround
smp: Brought up 1 node, 2 CPUs
SMP: Total of 2 processors activated (666.66 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes, linear)
pinctrl core: initialized pinctrl subsystem
NET: Registered PF_NETLINK/PF_ROUTE protocol family
DMA: preallocated 256 KiB pool for atomic coherent allocations
thermal_sys: Registered thermal governor 'step_wise'
cpuidle: using governor ladder
platform axi: Fixed dependency cycle(s) with /axi/interrupt-controller@f8f01000
amba f8801000.etb: Fixed dependency cycle(s) with /replicator/out-ports/port@1/endpoint
amba f8803000.tpiu: Fixed dependency cycle(s) with /replicator/out-ports/port@0/endpoint
amba f8804000.funnel: Fixed dependency cycle(s) with /replicator/in-ports/port/endpoint
amba f889c000.ptm: Fixed dependency cycle(s) with /axi/funnel@f8804000/in-ports/port@0/endpoint
amba f889d000.ptm: Fixed dependency cycle(s) with /axi/funnel@f8804000/in-ports/port@1/endpoint
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 27, base_baud = 3125000) is a xuartps
printk: console [ttyPS0] enabled
printk: bootconsole [cdns0] disabled
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
mc: Linux media interface: v0.10
videodev: Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
jesd204: found 0 devices and 0 topologies
FPGA manager framework
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
NET: Registered PF_INET protocol family
IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
NET: Registered PF_UNIX/PF_LOCAL protocol family
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
armv7-pmu f8891000.pmu: hw perfevents: no interrupt-affinity property, guessing.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
workingset: timestamp_bits=30 max_order=17 bucket_order=0
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
fuse: init (API version 7.37)
io scheduler mq-deadline registered
io scheduler kyber registered
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
dma-pl330 f8003000.dma-controller: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dma-controller:      DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
brd: module loaded
loop: module loaded
Registered mathworks_ip class
SPI driver spidev has no spi_device_id for adi,swspi
spi-nor spi1.0: SPI-NOR-UniqueID 100000237020412400270039040317375b
spi-nor spi1.0: n25q128a11 (16384 Kbytes)
5 fixed-partitions partitions found on MTD device spi1.0
Creating 5 MTD partitions on "spi1.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000540000 : "config"
0x000000540000-0x000000fc0000 : "image"
0x000000fc0000-0x000001000000 : "spare"
MACsec IEEE 802.1AE
tun: Universal TUN/TAP device driver, 1.6
macb e000b000.ethernet: invalid hw address, using random
mdio_bus e000b000.ethernet-ffffffff: MDIO device at address 0 is missing.
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 45 (52:f0:9c:bf:b0:39)
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
usbcore: registered new interface driver r8153_ecm
usbcore: registered new interface driver uas
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver upd78f0730
usbserial: USB Serial support registered for upd78f0730
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 6.1.70adi-v2023.2 ehci_hcd
usb usb1: SerialNumber: ci_hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
SPI driver ads7846 has no spi_device_id for ti,tsc2046
SPI driver ads7846 has no spi_device_id for ti,ads7843
SPI driver ads7846 has no spi_device_id for ti,ads7845
SPI driver ads7846 has no spi_device_id for ti,ads7873
i2c_dev: i2c /dev entries driver
i2c 0-0039: Fixed dependency cycle(s) with /fpga-axi@0/axi_hdmi@70e00000/port/endpoint
adv7511 0-0039: supply avdd not found, using dummy regulator
adv7511 0-0039: supply dvdd not found, using dummy regulator
adv7511 0-0039: supply pvdd not found, using dummy regulator
adv7511 0-0039: supply bgvdd not found, using dummy regulator
adv7511 0-0039: supply dvdd-3v not found, using dummy regulator
adv7511: probe of 0-0039 failed with error -5
8<--- cut here ---
Unhandled fault: imprecise external abort (0x406) at 0x00000000
[00000000] *pgd=00000000
Internal error: : 406 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 1 PID: 1 Comm: swapper/0 Not tainted 6.1.70adi-v2023.2 #1
Hardware name: Xilinx Zynq Platform
PC is at xiic_i2c_probe+0x250/0x3f4
LR is at arm_heavy_mb+0x1c/0x38
pc : [<c06a8070>]    lr : [<c01135dc>]    psr: 60000013
sp : e0819e08  ip : 00000000  fp : c1fbb840
r10: c2415058  r9 : 00000000  r8 : 00000000
r7 : c1d5b810  r6 : c1d5b800  r5 : e09a0100  r4 : c2415040
r3 : dec0de1c  r2 : 00000730  r1 : 00000000  r0 : 00000000
Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
Control: 18c5387d  Table: 0000404a  DAC: 00000051
Register r0 information: NULL pointer
Register r1 information: NULL pointer
Register r2 information: non-paged memory
Register r3 information: non-slab/vmalloc memory
Register r4 information: slab kmalloc-1k start c2415000 pointer offset 64 size 1024
Register r5 information: 0-page vmalloc region starting at 0xe09a0000 allocated at __devm_ioremap_resource+0x168/0x1dc
Register r6 information: slab kmalloc-1k start c1d5b800 pointer offset 0 size 1024
Register r7 information: slab kmalloc-1k start c1d5b800 pointer offset 16 size 1024
Register r8 information: NULL pointer
Register r9 information: NULL pointer
Register r10 information: slab kmalloc-1k start c2415000 pointer offset 88 size 1024
Register r11 information: slab kmalloc-64 start c1fbb840 pointer offset 0 size 64
Register r12 information: NULL pointer
Process swapper/0 (pid: 1, stack limit = 0x(ptrval))
Stack: (0xe0819e08 to 0xe081a000)
9e00:                   00002000 c1d527c0 c2415040 24945212 c16b5650 00000000
9e20: c1d5b810 c1941028 00000000 c241d938 c183e834 c184a860 00000000 c051e7e8
9e40: c1d5b810 00000000 c1941028 c051c180 c1d5b810 c1941028 c1d5b810 00000000
9e60: c241d938 c051c42c 60000013 c183e834 c19e8fbc c1941028 c1d5b810 00000000
9e80: c241d938 c051c570 c1d5b810 c1941028 c1d5b854 c19352b0 c241d938 c051cc4c
9ea0: 00000000 c1941028 c051cbbc c051a2d4 e0819ed0 c1c1cd58 c1d55a34 24945212
9ec0: c1941028 c241d900 00000000 c051b69c c1618b88 00000000 c1941028 00000000
9ee0: 00000006 00000000 c19cd000 c051d6d0 c18227a8 c1c49140 00000006 c0101954
9f00: 00000000 c1724578 c1d04fb3 00000000 00000000 00000000 00000000 00000000
9f20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
9f40: 00000000 00000000 00000000 24945212 c1d04f80 0000012f c1d04f80 00000006
9f60: c19cd000 c183e854 c183e834 c18012f0 00000006 00000006 00000000 c18004d0
9f80: c1903ec0 c0c8af60 00000000 00000000 00000000 00000000 00000000 c0c8af78
9fa0: 00000000 c0c8af60 00000000 c010014c 00000000 00000000 00000000 00000000
9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
 xiic_i2c_probe from platform_probe+0x5c/0xb0
 platform_probe from really_probe+0xc8/0x2ec
 really_probe from __driver_probe_device+0x88/0x19c
 __driver_probe_device from driver_probe_device+0x30/0x104
 driver_probe_device from __driver_attach+0x90/0x174
 __driver_attach from bus_for_each_dev+0x7c/0xc4
 bus_for_each_dev from bus_add_driver+0x164/0x1f0
 bus_add_driver from driver_register+0x88/0x11c
 driver_register from do_one_initcall+0x58/0x23c
 do_one_initcall from kernel_init_freeable+0x194/0x1f0
 kernel_init_freeable from kernel_init+0x18/0x12c
 kernel_init from ret_from_fork+0x14/0x28
Exception stack(0xe0819fb0 to 0xe0819ff8)
9fa0:                                     00000000 00000000 00000000 00000000
Code: e5943004 e5933104 16bf3f33 f57ff04f (e3130080)
---[ end trace 0000000000000000 ]---
note: swapper/0[1] exited with irqs disabled
Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
CPU1: stopping
CPU: 1 PID: 0 Comm: swapper/1 Tainted: G      D            6.1.70adi-v2023.2 #1
 unwind_backtrace from show_stack+0x10/0x14
 show_stack from dump_stack_lvl+0x40/0x4c
 dump_stack_lvl from do_handle_IPI+0x118/0x140
 do_handle_IPI from ipi_handler+0x18/0x20
 ipi_handler from handle_percpu_devid_irq+0x78/0x134
 handle_percpu_devid_irq from generic_handle_domain_irq+0x28/0x38
 generic_handle_domain_irq from gic_handle_irq+0x74/0x88
 gic_handle_irq from generic_handle_arch_irq+0x34/0x44
 generic_handle_arch_irq from call_with_stack+0x18/0x20
 call_with_stack from __irq_svc+0x98/0xc8
Exception stack(0xe0849f50 to 0xe0849f98)
9f40:                                     00000005 00000000 000010c1 c0116780
9f60: c1c51240 c1903f10 00000001 c1903f58 c184df18 c1903f60 00000000 00000000
9f80: e0849f88 e0849fa0 c0107778 c010777c 60000113 ffffffff
 __irq_svc from arch_cpu_idle+0x38/0x3c
 arch_cpu_idle from default_idle_call+0x24/0x34
 default_idle_call from do_idle+0x1c4/0x258
 do_idle from cpu_startup_entry+0x28/0x2c
 cpu_startup_entry from secondary_start_kernel+0x11c/0x120
 secondary_start_kernel from 0x1016e0
---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
removed an attachment
[edited by: codeCrafter at 1:29 PM (GMT -5) on 22 Jan 2025]
  • Hi, it looks like adv7511 didn't initialize properly, if you can live without HDMI for now, could you please try removing that dtsi?
    Regards, Stefan
    Thank you for the response. I noticed you mentioned the possibility of removing the ADV7511 DTSI (“if I can live without HDMI”), but I would prefer to keep the HDMI support enabled. My primary goal is to get the ADRV9002 working on the ZC702 with IIO functionality. Could you provide insight into why the ADV7511 might be causing the crash on the ZC702?
  • Hi, it looks like 7511's driver isn't finding right power supply (e.g. adv7511 0-0039: supply avdd not found, using dummy regulator). I would double check which power supply chip is in use on zc702 vs zedboard, which dtsi defines these names (e.g. "avdd", "dvdd", "dvdd-3v") are they named correctly, if it's in seperate dtsi does your dtsi see it, etc.? Also note the preceding error (SPI driver ads7846 has no spi_device_id for ti,tsc2046...) - seems the SPI driver ads7846 doesn't recognize the specific devices ti,tsc2046, ti,ads7843, etc. (tsc2046 is touch screen controller, don't certain that it's part of zc702) Also note that some HDMI monitors may not be compatible.
    Good thing is that IIO functionality should work without HDMI monitor.
    Regards, Stefan
