ADRV9029
Recommended for New Designs
The ADRV9029 is a highly integrated, radio frequency (RF) agile transceiver offering four independently controlled transmitters, dedicated observation...
Datasheet
ADRV9029 on Analog.com
ADRV9026
The ADRV9026 is a highly integrated, radio frequency (RF) agile transceiver offering four independently controlled transmitters, dedicated observation...
Datasheet
ADRV9026 on Analog.com
AD9528
The AD9528 is a two-stage PLL with an integrated JESD204B/JESD204C SYSREF generator for multiple device synchronization. The first stage phase-locked loop...
Datasheet
AD9528 on Analog.com
Hi
My hdl code is 2022R2, under zcu102->adrv9026. Meta-adi is 2022_R2 too, and device-tree is modified from zynqmp-zcu102-rev10-adrv9025.dts. I modified the HDL code with adding another adrv9029 on FMC0, and added a ad9528 and adrv9025-phy to spi1. But at the kernel boot, it showed spi2.1 probe fail
[ 5.227742] ad9528 spi1.1: supply vcc not found, using dummy regulator
[ 5.256753] jesd204: /axi/spi@ff040000/ad9528-1_0@1,jesd204:0,parent=spi1.1: Using as SYSREF provider
[ 5.273225] adrv9025 spi1.0: adrv9025 Rev 0, API version: 6.4.0.14 found
[ 5.281025] ad9528 spi2.1: supply vcc not found, using dummy regulator
[ 5.307321] ad9528: probe of spi2.1 failed with error -17
[ 5.313775] spi-nor spi0.0: SPI-NOR-UniqueID 64b311001602000f0041c0e6bf19
[ 5.320573] spi-nor spi0.0: found mt25qu512a, expected m25p80
[ 5.326629] spi-nor spi0.0: mt25qu512a (131072 Kbytes)
This is the boot log
This is my device-tree
// SPDX-License-Identifier: GPL-2.0 /* * Analog Devices ADRV9025 * https://wiki.analog.com/resources/eval/user-guides/adrv9025 * https://wiki.analog.com/resources/tools-software/linux-drivers/iio-transceiver/adrv9025 * * hdl_project: <adrv9026/zcu102> * board_revision: <> * * Copyright (C) 2020-2023 Analog Devices Inc. */ #include "zynqmp-zcu102-rev1.0.dts" #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/iio/adc/adi,adrv9025.h> #include <dt-bindings/iio/frequency/ad9528.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/jesd204/adxcvr.h> &spi0 { status = "okay"; clk0_ad9528_0: ad9528-1_0@1 { compatible = "adi,ad9528"; reg = <1>; #address-cells = <1>; #size-cells = <0>; spi-max-frequency = <10000000>; //adi,spi-3wire-enable; clock-output-names = "ad9528-1_out0", "ad9528-1_out1", "ad9528-1_out2", "ad9528-1_out3", "ad9528-1_out4", "ad9528-1_out5", "ad9528-1_out6", "ad9528-1_out7", "ad9528-1_out8", "ad9528-1_out9", "ad9528-1_out10", "ad9528-1_out11", "ad9528-1_out12", "ad9528-1_out13"; #clock-cells = <1>; label = "ad9528-1_0"; jesd204-device; #jesd204-cells = <2>; jesd204-sysref-provider; adi,vcxo-freq = <122880000>; adi,refa-enable; adi,refa-diff-rcv-enable; adi,refa-r-div = <1>; /* PLL1 config */ adi,pll1-feedback-div = <4>; adi,pll1-charge-pump-current-nA = <5000>; /* PLL2 config */ adi,pll2-vco-div-m1 = <3>; /* use 5 for 184320000 output device clock */ adi,pll2-n2-div = <10>; /* N / M1 */ adi,pll2-r1-div = <1>; adi,pll2-charge-pump-current-nA = <805000>; /* SYSREF config */ adi,sysref-src = <SYSREF_SRC_INTERNAL>; adi,sysref-pattern-mode = <SYSREF_PATTERN_NSHOT>; adi,sysref-k-div = <512>; adi,sysref-nshot-mode = <SYSREF_NSHOT_8_PULSES>; //adi,sysref-request-trigger-mode = <SYSREF_LEVEL_HIGH>; adi,jesd204-desired-sysref-frequency-hz = <3840000>; adi,rpole2 = <RPOLE2_900_OHM>; adi,rzero = <RZERO_1850_OHM>; adi,cpole1 = <CPOLE1_16_PF>; adi,status-mon-pin0-function-select = <1>; /* PLL1 & PLL2 Locked */ adi,status-mon-pin1-function-select = <7>; /* REFA Correct */ ad9528_0_c0: channel@0 { reg = <0>; adi,extended-name = "DEV_SYSREF"; adi,driver-mode = <DRIVER_MODE_LVDS>; adi,divider-phase = <0>; adi,channel-divider = <5>; adi,signal-source = <SOURCE_SYSREF_VCO>; //adi,output-dis; }; ad9528_0_c1: channel@1 { reg = <1>; adi,extended-name = "DEV_CLK"; adi,driver-mode = <DRIVER_MODE_LVDS>; adi,divider-phase = <0>; adi,channel-divider = <5>; adi,signal-source = <SOURCE_VCO>; adi,output-dis; }; ad9528_0_c3: channel@3 { reg = <3>; adi,extended-name = "CORE_CLK"; adi,driver-mode = <DRIVER_MODE_LVDS>; adi,divider-phase = <0>; adi,channel-divider = <5>; adi,signal-source = <SOURCE_VCO>; adi,output-dis; }; ad9528_0_c12: channel@12 { reg = <12>; adi,extended-name = "FMC_SYSREF"; adi,driver-mode = <DRIVER_MODE_LVDS>; adi,divider-phase = <0>; adi,channel-divider = <5>; adi,signal-source = <SOURCE_SYSREF_VCO>; //adi,output-dis; }; ad9528_0_c13: channel@13 { reg = <13>; adi,extended-name = "FMC_CLK"; adi,driver-mode = <DRIVER_MODE_LVDS>; adi,divider-phase = <0>; adi,channel-divider = <5>; adi,signal-source = <SOURCE_VCO>; adi,output-dis; }; }; trx0_adrv9025_0: adrv9025-phy_0@0 { compatible = "adrv9025"; reg = <0>; #address-cells = <1>; #size-cells = <0>; label = "trx0_adrv9025_0"; /* SPI Setup */ spi-max-frequency = <25000000>; interrupt-parent = <&gpio>; interrupts = <134 IRQ_TYPE_EDGE_RISING>; /* adrv9025_gpint1 */ /* Clocks */ clocks = <&clk0_ad9528_0 1>; clock-names = "dev_clk"; clock-output-names = "rx_sampl_clk", "tx_sampl_clk"; #clock-cells = <1>; jesd204-device; #jesd204-cells = <2>; jesd204-top-device = <0>; /* This is the TOP device */ jesd204-link-ids = <DEFRAMER0_LINK_TX FRAMER0_LINK_RX>; jesd204-inputs = <&axi_adrv9025_rx_jesd_0 0 FRAMER0_LINK_RX>, <&axi_adrv9025_core_tx_0 0 DEFRAMER0_LINK_TX>; adi,device-profile-name = "ActiveUseCase.profile"; adi,init-profile-name = "ActiveUtilInit.profile"; adi,arm-firmware-name = "ADRV9025_FW.bin;ADRV9025_DPDCORE_FW.bin"; adi,stream-firmware-name = "stream_image_6E3E00EFB74FE7D465FA88A171B81B8F.bin"; adi,rx-gaintable-names = "ADRV9025_RxGainTable.csv"; adi,rx-gaintable-channel-masks = <0xFF>; adi,tx-attntable-names = "ADRV9025_TxAttenTable.csv"; adi,tx-attntable-channel-masks = <0x0F>; }; }; &spi1 { status = "okay"; clk0_ad9528_1: ad9528-1_1@1 { compatible = "adi,ad9528"; reg = <1>; #address-cells = <1>; #size-cells = <0>; spi-max-frequency = <10000000>; //adi,spi-3wire-enable; clock-output-names = "ad9528-1_out0", "ad9528-1_out1", "ad9528-1_out2", "ad9528-1_out3", "ad9528-1_out4", "ad9528-1_out5", "ad9528-1_out6", "ad9528-1_out7", "ad9528-1_out8", "ad9528-1_out9", "ad9528-1_out10", "ad9528-1_out11", "ad9528-1_out12", "ad9528-1_out13"; #clock-cells = <1>; label = "ad9528-1_1"; jesd204-device; #jesd204-cells = <2>; jesd204-sysref-provider; adi,vcxo-freq = <122880000>; adi,refa-enable; adi,refa-diff-rcv-enable; adi,refa-r-div = <1>; /* PLL1 config */ adi,pll1-feedback-div = <4>; adi,pll1-charge-pump-current-nA = <5000>; /* PLL2 config */ adi,pll2-vco-div-m1 = <3>; /* use 5 for 184320000 output device clock */ adi,pll2-n2-div = <10>; /* N / M1 */ adi,pll2-r1-div = <1>; adi,pll2-charge-pump-current-nA = <805000>; /* SYSREF config */ adi,sysref-src = <SYSREF_SRC_INTERNAL>; adi,sysref-pattern-mode = <SYSREF_PATTERN_NSHOT>; adi,sysref-k-div = <512>; adi,sysref-nshot-mode = <SYSREF_NSHOT_8_PULSES>; //adi,sysref-request-trigger-mode = <SYSREF_LEVEL_HIGH>; adi,jesd204-desired-sysref-frequency-hz = <3840000>; adi,rpole2 = <RPOLE2_900_OHM>; adi,rzero = <RZERO_1850_OHM>; adi,cpole1 = <CPOLE1_16_PF>; adi,status-mon-pin0-function-select = <1>; /* PLL1 & PLL2 Locked */ adi,status-mon-pin1-function-select = <7>; /* REFA Correct */ ad9528_1_c0: channel@0 { reg = <0>; adi,extended-name = "DEV_SYSREF"; adi,driver-mode = <DRIVER_MODE_LVDS>; adi,divider-phase = <0>; adi,channel-divider = <5>; adi,signal-source = <SOURCE_SYSREF_VCO>; //adi,output-dis; }; ad9528_1_c1: channel@1 { reg = <1>; adi,extended-name = "DEV_CLK"; adi,driver-mode = <DRIVER_MODE_LVDS>; adi,divider-phase = <0>; adi,channel-divider = <5>; adi,signal-source = <SOURCE_VCO>; adi,output-dis; }; ad9528_1_c3: channel@3 { reg = <3>; adi,extended-name = "CORE_CLK"; adi,driver-mode = <DRIVER_MODE_LVDS>; adi,divider-phase = <0>; adi,channel-divider = <5>; adi,signal-source = <SOURCE_VCO>; adi,output-dis; }; ad9528_1_c12: channel@12 { reg = <12>; adi,extended-name = "FMC_SYSREF"; adi,driver-mode = <DRIVER_MODE_LVDS>; adi,divider-phase = <0>; adi,channel-divider = <5>; adi,signal-source = <SOURCE_SYSREF_VCO>; //adi,output-dis; }; ad9528_1_c13: channel@13 { reg = <13>; adi,extended-name = "FMC_CLK"; adi,driver-mode = <DRIVER_MODE_LVDS>; adi,divider-phase = <0>; adi,channel-divider = <5>; adi,signal-source = <SOURCE_VCO>; adi,output-dis; }; }; trx0_adrv9025_1: adrv9025-phy_1@0 { compatible = "adrv9025"; reg = <0>; #address-cells = <1>; #size-cells = <0>; label = "trx0_adrv9025_1"; /* SPI Setup */ spi-max-frequency = <25000000>; interrupt-parent = <&gpio>; interrupts = <134 IRQ_TYPE_EDGE_RISING>; /* adrv9025_gpint1 */ /* Clocks */ clocks = <&clk0_ad9528_1 1>; clock-names = "dev_clk"; clock-output-names = "rx_sampl_clk", "tx_sampl_clk"; #clock-cells = <1>; jesd204-device; #jesd204-cells = <2>; jesd204-top-device = <0>; /* This is the TOP device */ jesd204-link-ids = <DEFRAMER0_LINK_TX FRAMER0_LINK_RX>; jesd204-inputs = <&axi_adrv9025_rx_jesd_1 0 FRAMER0_LINK_RX>, <&axi_adrv9025_core_tx_1 0 DEFRAMER0_LINK_TX>; adi,device-profile-name = "ActiveUseCase.profile"; adi,init-profile-name = "ActiveUtilInit.profile"; adi,arm-firmware-name = "ADRV9025_FW.bin;ADRV9025_DPDCORE_FW.bin"; adi,stream-firmware-name = "stream_image_6E3E00EFB74FE7D465FA88A171B81B8F.bin"; adi,rx-gaintable-names = "ADRV9025_RxGainTable.csv"; adi,rx-gaintable-channel-masks = <0xFF>; adi,tx-attntable-names = "ADRV9025_TxAttenTable.csv"; adi,tx-attntable-channel-masks = <0x0F>; }; }; &i2c1 { i2c-mux@75 { i2c@1 { /* HPC1 */ #address-cells = <1>; #size-cells = <0>; reg = <1>; /* HPC0_IIC */ ad7291@2f { compatible = "adi,ad7291"; reg = <0x2f>; }; eeprom@50 { compatible = "at24,24c02"; reg = <0x50>; }; }; }; }; / { fpga_axi: fpga-axi@0 { interrupt-parent = <&gic>; compatible = "simple-bus"; #address-cells = <0x1>; #size-cells = <0x1>; ranges = <0 0 0 0xffffffff>; /* HPC0 */ rx_dma_0: dma_0@9c400000 { compatible = "adi,axi-dmac-1.00.a"; reg = <0x9c400000 0x10000>; #dma-cells = <1>; #clock-cells = <0>; interrupts = <0 110 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 73>; }; tx_dma_0: dma_0@9c420000 { compatible = "adi,axi-dmac-1.00.a"; reg = <0x9c420000 0x10000>; #dma-cells = <1>; #clock-cells = <0>; interrupts = <0 109 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 73>; }; axi_adrv9025_core_rx_0: axi-adrv9025-rx-hpc_0@84a00000 { compatible = "adi,axi-adc-10.0.a"; reg = <0x84a00000 0x8000>; dmas = <&rx_dma_0 0>; dma-names = "rx"; spibus-connected = <&trx0_adrv9025_0>; label = "axi-adrv9025-rx-hpc-0"; }; axi_adrv9025_core_tx_0: axi-adrv9025-tx-hpc_0@84a04000 { compatible = "adi,axi-adrv9025-tx-1.0"; reg = <0x84a04000 0x4000>; dmas = <&tx_dma_0 0>; dma-names = "tx"; clocks = <&trx0_adrv9025_0 1>; clock-names = "sampl_clk"; //adi,axi-pl-fifo-enable; jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_adrv9025_tx_jesd_0 0 DEFRAMER0_LINK_TX>; label = "axi-adrv9025-tx-hpc-0"; }; axi_adrv9025_rx_jesd_0: axi-jesd204-rx_0@84aa0000 { compatible = "adi,axi-jesd204-rx-1.0"; reg = <0x84aa0000 0x1000>; interrupts = <0 107 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>, <&clk0_ad9528_0 3>, <&axi_adrv9025_adxcvr_rx_0 0>; clock-names = "s_axi_aclk", "device_clk", "lane_clk"; #clock-cells = <0>; clock-output-names = "jesd_rx_lane_clk"; adi,octets-per-frame = <4>; adi,frames-per-multiframe = <32>; jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_adrv9025_adxcvr_rx_0 0 FRAMER0_LINK_RX>; label = "axi-jesd204-rx_0"; }; axi_adrv9025_tx_jesd_0: axi-jesd204-tx_0@84a90000 { compatible = "adi,axi-jesd204-tx-1.0"; reg = <0x84a90000 0x1000>; interrupts = <0 106 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>, <&clk0_ad9528_0 3>, <&axi_adrv9025_adxcvr_tx_0 0>; clock-names = "s_axi_aclk", "device_clk", "lane_clk"; #clock-cells = <0>; clock-output-names = "jesd_tx_lane_clk"; jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_adrv9025_adxcvr_tx_0 0 DEFRAMER0_LINK_TX>; label = "axi-jesd204-tx_0"; }; axi_adrv9025_adxcvr_rx_0: axi-adxcvr-rx_0@84a60000 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,axi-adxcvr-1.0"; reg = <0x84a60000 0x1000>; clocks = <&clk0_ad9528_0 13>; clock-names = "conv"; #clock-cells = <1>; clock-output-names = "rx_gt_clk", "rx_out_clk"; adi,sys-clk-select = <XCVR_CPLL>; adi,out-clk-select = <XCVR_REFCLK>; adi,use-lpm-enable; adi,use-cpll-enable; jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&clk0_ad9528_0 0 FRAMER0_LINK_RX>; label = "axi-adxcvr-rx_0"; }; axi_adrv9025_adxcvr_tx_0: axi-adxcvr-tx_0@84a80000 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,axi-adxcvr-1.0"; reg = <0x84a80000 0x1000>; clocks = <&clk0_ad9528_0 13>; clock-names = "conv"; #clock-cells = <1>; clock-output-names = "tx_gt_clk", "tx_out_clk"; adi,sys-clk-select = <XCVR_QPLL>; adi,out-clk-select = <XCVR_REFCLK>; jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&clk0_ad9528_0 0 DEFRAMER0_LINK_TX>; label = "axi-adxcvr-tx_0"; }; /* HPC1 */ rx_dma_1: dma_1@9c440000 { compatible = "adi,axi-dmac-1.00.a"; reg = <0x9c440000 0x10000>; #dma-cells = <1>; #clock-cells = <0>; interrupts = <0 95 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 73>; }; tx_dma_1: dma_1@9c460000 { compatible = "adi,axi-dmac-1.00.a"; reg = <0x9c460000 0x10000>; #dma-cells = <1>; #clock-cells = <0>; interrupts = <0 94 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 73>; }; axi_adrv9025_core_rx_1: axi-adrv9025-rx-hpc_1@83a00000 { compatible = "adi,axi-adc-10.0.a"; reg = <0x83a00000 0x8000>; dmas = <&rx_dma_1 0>; dma-names = "rx"; spibus-connected = <&trx0_adrv9025_1>; label = "axi-adrv9025-rx-hpc-1"; }; axi_adrv9025_core_tx_1: axi-adrv9025-tx-hpc_1@83a04000 { compatible = "adi,axi-adrv9025-tx-1.0"; reg = <0x83a04000 0x4000>; dmas = <&tx_dma_1 0>; dma-names = "tx"; clocks = <&trx0_adrv9025_1 1>; clock-names = "sampl_clk"; //adi,axi-pl-fifo-enable; jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_adrv9025_tx_jesd_1 0 DEFRAMER0_LINK_TX>; label = "axi-adrv9025-tx-hpc-1"; }; axi_adrv9025_rx_jesd_1: axi-jesd204-rx_1@83aa0000 { compatible = "adi,axi-jesd204-rx-1.0"; reg = <0x83aa0000 0x1000>; interrupts = <0 92 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>, <&clk0_ad9528_1 3>, <&axi_adrv9025_adxcvr_rx_1 0>; clock-names = "s_axi_aclk", "device_clk", "lane_clk"; #clock-cells = <0>; clock-output-names = "jesd_rx_lane_clk"; adi,octets-per-frame = <4>; adi,frames-per-multiframe = <32>; jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_adrv9025_adxcvr_rx_1 0 FRAMER0_LINK_RX>; label = "axi-jesd204-rx_1"; }; axi_adrv9025_tx_jesd_1: axi-jesd204-tx_1@83a90000 { compatible = "adi,axi-jesd204-tx-1.0"; reg = <0x83a90000 0x1000>; interrupts = <0 91 IRQ_TYPE_LEVEL_HIGH>; clocks = <&zynqmp_clk 71>, <&clk0_ad9528_1 3>, <&axi_adrv9025_adxcvr_tx_1 0>; clock-names = "s_axi_aclk", "device_clk", "lane_clk"; #clock-cells = <0>; clock-output-names = "jesd_tx_lane_clk"; jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_adrv9025_adxcvr_tx_1 0 DEFRAMER0_LINK_TX>; label = "axi-jesd204-tx_1"; }; axi_adrv9025_adxcvr_rx_1: axi-adxcvr-rx_1@83a60000 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,axi-adxcvr-1.0"; reg = <0x83a60000 0x1000>; clocks = <&clk0_ad9528_1 13>; clock-names = "conv"; #clock-cells = <1>; clock-output-names = "rx_gt_clk", "rx_out_clk"; adi,sys-clk-select = <XCVR_CPLL>; adi,out-clk-select = <XCVR_REFCLK>; adi,use-lpm-enable; adi,use-cpll-enable; jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&clk0_ad9528_1 0 FRAMER0_LINK_RX>; label = "axi-adxcvr-rx_1"; }; axi_adrv9025_adxcvr_tx_1: axi-adxcvr-tx_1@83a80000 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,axi-adxcvr-1.0"; reg = <0x83a80000 0x1000>; clocks = <&clk0_ad9528_1 13>; clock-names = "conv"; #clock-cells = <1>; clock-output-names = "tx_gt_clk", "tx_out_clk"; adi,sys-clk-select = <XCVR_QPLL>; adi,out-clk-select = <XCVR_REFCLK>; jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&clk0_ad9528_1 0 DEFRAMER0_LINK_TX>; label = "axi-adxcvr-tx_1"; }; axi_sysid_0: axi-sysid-0@85000000 { compatible = "adi,axi-sysid-1.00.a"; reg = <0x85000000 0x10000>; }; }; }; /* HPC0 */ // ad9528_reset_b, // 68 // ad9528_sysref_req, // 67 // adrv9025_test, // 58 // adrv9025_reset_b, // 57 // adrv9025_gpint1, // 56 // adrv9025_gpint2, // 55 // adrv9025_gpio_00, // 50 // adrv9025_gpio_01, // 49 // adrv9025_gpio_02, // 48 // adrv9025_gpio_03, // 47 // adrv9025_gpio_04, // 46 // adrv9025_gpio_05, // 45 // adrv9025_gpio_06, // 44 // adrv9025_gpio_07, // 43 // adrv9025_gpio_08, // 42 // adrv9025_gpio_09, // 41 // adrv9025_gpio_10, // 40 // adrv9025_gpio_11, // 39 // adrv9025_gpio_12, // 38 // adrv9025_gpio_13, // 37 // adrv9025_gpio_14, // 36 // adrv9025_gpio_15, // 35 // adrv9025_gpio_16, // 34 // adrv9025_gpio_17, // 33 // adrv9025_gpio_18})); // 32 + 78 /* HPC1 */ // ad9528_reset_b, // 94 // ad9528_sysref_req, // 93 // adrv9025_test, // 92 // adrv9025_reset_b, // 91 // adrv9025_gpint1, // 90 // adrv9025_gpint2, // 89 // adrv9025_gpio_00, // 88 // adrv9025_gpio_01, // 87 // adrv9025_gpio_02, // 86 // adrv9025_gpio_03, // 85 // adrv9025_gpio_04, // 84 // adrv9025_gpio_05, // 83 // adrv9025_gpio_06, // 82 // adrv9025_gpio_07, // 81 // adrv9025_gpio_08, // 80 // adrv9025_gpio_09, // 79 // adrv9025_gpio_10, // 78 // adrv9025_gpio_11, // 77 // adrv9025_gpio_12, // 76 // adrv9025_gpio_13, // 75 // adrv9025_gpio_14, // 74 // adrv9025_gpio_15, // 73 // adrv9025_gpio_16, // 72 // adrv9025_gpio_17, // 71 // adrv9025_gpio_18})); // 70 + 78 &trx0_adrv9025_0 { reset-gpios = <&gpio 135 0>; test-gpios = <&gpio 136 0>; }; &trx0_adrv9025_1 { reset-gpios = <&gpio 169 0>; test-gpios = <&gpio 170 0>; }; &clk0_ad9528_0 { reset-gpios = <&gpio 146 0>; }; &clk0_ad9528_1 { reset-gpios = <&gpio 172 0>; }; &axi_adrv9025_core_tx_0 { plddrbypass-gpios = <&gpio 147 0>; }; &axi_adrv9025_core_tx_1 { plddrbypass-gpios = <&gpio 173 0>; };
Thanks
-17 == EEXIST /* File exists */
You need to change the name for the clock-output-names on the second ad9528
clock-output-names = "ad9528-1_2_out0", ...
-Michael
Hi
I followed your answer, modified the clock-output-names of second ad9528 and two other similar mistakes. The second adrv9025 and ad9528 works.
Thanks
