KCC Quizzes AQQ303 about the radius of a circle
1. Quote of the month: "When I die, I want to die like my grandfather who died peacefully in his sleep. Not screaming like all the passengers in his car" - Will Rogers
2. Quiz AQQ304 about finding the radius of a circle
Good luck, and try to be
August Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Important: Read the blog first . The quiz questions are all based on the content of the blog:
Stay in the loop and win! Read the blog Current Output Driving Industrial Loops , then take our quick five-question quiz for a chance to win a gift card
MAX98090
Production
The MAX98090 is a fully integrated audio codec whose high-performance, ultra-low power consumption and small footprint make it ideal for portable applications...
Datasheet
MAX98090 on Analog.com
Hello!
I'm trying to get a MAX98090AETL Audio Codec working on my custom carrier board for an i.MX8MP SOM Module. The SOM is a "i.MX8M Plus DHCOM", and there's a device tree for its demo board (PDK3) with another audio chip mainline here: github.com/.../imx8mp-dhcom-pdk3.dts . I'm on Linux 6.6 LTS, and I'm building a yocto scarthgap image.
My audio codec is connected like this:
Assumptions:
* Since we're only using the audio output for internal speakers, the IRQ connection (for jack detection) is not needed.
* Since we're not using microphones, SDDOut connection is not needed.
* Connecting only one speaker to SPKR should work as a "Mono" output
I've created the changes below to my device tree, based on my supplier's demo board configuration that works with another audio codec, and based on the max98090 examples that I could find online.
The following things are a bit unclear to me:
* When I don't add an interrupt to the max98090 configuration, I get an error "request_irq failed" from the driver probe function. So I simply added an unused GPIO here. Is this problematic in any way?
* how is the "clocks" property of the max98090 meant to be configured? I found many examples where it is derived from the i2s node in some way, but since I have mclk connected to an oscillator, I believe this is what I should use here?
* Do I need anything special to configure a single ("Mono") speaker here? I wanted to rule out problems here and configured it as stereo with SPKL and SPKR instead for now.
Anyhow and finally, my problem is quite simple: I have connected a speaker to theSPKR output, and I don't get any sound on it.
I tried this the following way:
aplay example.wav
... and I got the following output:
Playing WAVE 'example.wav' : Signed 16 bit Little Endi[ 9268.175541] max98090 4-0010: No better method found
an, Rate 44100 Hz, Stereo
[ 9268.181906] max98090 4-0010: Calculating ni 22579 with mi 65536
So I guess that I either configured or connected something in a wrong way. What could be my issue here?
I also attach the result of alsa-info.sh, in the hope that this might be helpful ...
Best regards
Markus
// DTS file changes:
sound {
compatible = "simple-audio-card";
simple-audio-card,name = "MAX98090-Card";
simple-audio-card,format = "i2s";
simple-audio-card,bitclock-master = <&codec_dai>;
simple-audio-card,frame-master = <&codec_dai>;
simple-audio-card,widgets = "Speaker", "Speaker Internal";
simple-audio-card,routing = "Speaker Internal", "SPKR","Speaker Internal", "SPKL";
cpu_dai: simple-audio-card,cpu {
sound-dai = <&sai3>;
codec_dai: simple-audio-card,codec {
sound-dai = <&max98090>;
clk_ext_audio_codec: oscillator {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <12288000>;
&i2c5 {
max98090: audio-codec@10 {
compatible = "maxim,max98090";
reg = <0x10>;
clocks = <&clk_ext_audio_codec>;
clock-names = "mclk";
// Use a dummy (unused gpio) interrupt pin that's not connected
interrupt-parent = <&supply_io_expander>;
interrupts = <7 IRQ_TYPE_LEVEL_LOW>;
#sound-dai-cells = <0>;
// Audio interface configuration (copied from PDK3 demo board with same SOM module but other)
&sai3 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_sai3>;
assigned-clocks = <&clk IMX8MP_CLK_SAI3>;
assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL1_OUT>;
assigned-clock-rates = <12288000>;
fsl,sai-mclk-direction-output;
status = "okay";
And here the output of alsa-info.sh:
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.5.3
!!Script ran on: Tue Feb 27 17:54:27 UTC 2024
!!Linux Distribution
!!DMI Information
Manufacturer:
Product Name:
Product Version:
Firmware Version:
System SKU:
Board Vendor:
Board Name:
!!ACPI Device Status Information
!!Kernel Information
Kernel release: #1 SMP Sun Nov 17 14:08:59 UTC 2024
Operating System: GNU/Linux
Architecture: aarch64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k6.6.62-stable-standard-00052-geaa641e9be61
Library version: 1.2.11
Utilities version: 1.2.11
!!Loaded ALSA modules
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
!!Soundcards recognised by ALSA
0 [MAX98090Card ]: simple-card - MAX98090-Card
MAX98090-Card
!!PCI Soundcards installed in the system
!!Loaded sound module options
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/platform/drivers/asoc-simple-card
Tree:
|-- controlC0
| |-- dev
| |-- device -> ../../card0
| |-- power
| |-- subsystem -> ../../../../../../class/sound
| `-- uevent
|-- device -> ../../../sound
|-- id
|-- number
|-- pcmC0D0c
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- pcmC0D0p
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- power
| |-- autosuspend_delay_ms
| |-- control
| |-- runtime_active_time
| |-- runtime_status
| `-- runtime_suspended_time
|-- subsystem -> ../../../../../class/sound
`-- uevent
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 0 Feb 27 17:26 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 24 Feb 27 17:26 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 16 Feb 27 17:26 /dev/snd/pcmC0D0p
crw-rw---- 1 root audio 116, 33 Feb 27 17:26 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Feb 27 17:26 .
drwxr-xr-x 3 root root 140 Feb 27 17:26 ..
lrwxrwxrwx 1 root root 12 Feb 27 17:26 platform-sound -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: MAX98090Card [MAX98090-Card], device 0: 30c30000.sai-HiFi HiFi-0 [30c30000.sai-HiFi HiFi-0]
Subdevices: 1/1
Subdevice #0: subdevice #0
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card MAX98090Card
Card sysdefault:0 'MAX98090Card'/'MAX98090-Card'
Mixer name : ''
Components : ''
Controls : 136
Simple ctrls : 134
Simple mixer control 'Headphone',0
Capabilities: volume
Playback channels: Front Left - Front Right
Capture channels: Front Left - Front Right
Limits: 0 - 31
Front Left: 0 [0%] [-67.00dB]
Front Right: 0 [0%] [-67.00dB]
Simple mixer control 'Headphone Left',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'Headphone Left Mixer',0
Capabilities: volume volume-joined
Capture channels: Mono
Limits: 0 - 3
Mono: 3 [100%] [0.00dB]
Simple mixer control 'Headphone Right',0
Mono: Playback [on]
Simple mixer control 'Headphone Right Mixer',0
Limits: 0 - 3
Simple mixer control 'Speaker',0
Limits: 0 - 39
Front Left: 20 [51%] [0.00dB]
Front Right: 20 [51%] [0.00dB]
Simple mixer control 'Speaker Left',0
Mono: Playback [on]
Simple mixer control 'Speaker Left Mixer',0
Limits: 0 - 3
Simple mixer control 'Speaker Right',0
Mono: Playback [on]
Simple mixer control 'Speaker Right Mixer',0
Limits: 0 - 3
Simple mixer control 'Playback Path DC Blocking',0
Mono: Playback [off]
Simple mixer control 'ADC High Performance Mode',0
Capabilities: enum
Items: 'Low Power' 'High Performance'
Item0: 'High Performance'
Simple mixer control 'ADC Oversampling Rate',0
Capabilities: enum
Items: '64*fs' '128*fs'
Item0: '128*fs'
Simple mixer control 'ADC Quantizer Dither',0
Mono: Playback [on]
Simple mixer control 'ADCL',0
Limits: 0 - 15
Mono: 12 [80%] [0.00dB]
Simple mixer control 'ADCL Boost',0
Limits: 0 - 7
Mono: 0 [0%] [0.00dB]
Simple mixer control 'ADCR',0
Limits: 0 - 15
Simple mixer control 'ADCR Boost',0
Limits: 0 - 7
Simple mixer control 'ALC Attack Time',0
Capabilities: enum
Items: '0.5ms' '1ms' '5ms' '10ms' '25ms' '50ms' '100ms' '200ms'
Item0: '0.5ms'
Simple mixer control 'ALC Compression Ratio',0
Capabilities: enum
Items: '1:1' '1:1.5' '1:2' '1:4' '1:INF'
Item0: '1:1'
Simple mixer control 'ALC Compression Threshold',0
Limits: 0 - 31
Mono: 31 [100%] [0.00dB]
Simple mixer control 'ALC Enable',0
Simple mixer control 'ALC Expansion Ratio',0
Capabilities: enum
Items: '1:1' '2:1' '3:1'
Item0: '1:1'
Simple mixer control 'ALC Expansion Threshold',0
Limits: 0 - 31
Mono: 31 [100%] [-35.00dB]
Simple mixer control 'ALC Make Up',0
Limits: 0 - 12
Simple mixer control 'ALC Release Time',0
Capabilities: enum
Items: '8s' '4s' '2s' '1s' '0.5s' '0.25s' '0.125s' '0.0625s'
Item0: '8s'
Simple mixer control 'Biquad',0
Simple mixer control 'DAC HP Playback Performance Mode',0
Capabilities: enum
Items: 'High Performance' 'Low Power'
Simple mixer control 'DAC High Performance Mode',0
Capabilities: enum
Simple mixer control 'DAC Mono Mode',0
Simple mixer control 'DMIC MIC Comp Filter Config',0
Limits: 0 - 15
Mono: 6 [40%]
Simple mixer control 'DMIC Mux',0
Capabilities: enum
Items: 'ADC' 'DMIC'
Item0: 'ADC'
Simple mixer control 'Digital',0
Limits: 0 - 15
Mono: 15 [100%] [0.00dB]
Simple mixer control 'Digital BQ',0
Limits: 0 - 15
Simple mixer control 'Digital Coarse',0
Limits: 0 - 3
Simple mixer control 'Digital EQ',0
Limits: 0 - 15
Simple mixer control 'Digital EQ 3 Band',0
Simple mixer control 'Digital EQ 5 Band',0
Simple mixer control 'Digital EQ 7 Band',0
Simple mixer control 'Digital EQ Clipping Detection',0
Mono: Playback [on]
Simple mixer control 'Digital Sidetone',0
Limits: 0 - 30
Mono: 0 [0%] [0.50dB]
Simple mixer control 'Enhanced Vol Smoothing',0
Mono: Playback [on]
Simple mixer control 'Filter Mode',0
Capabilities: enum
Items: 'Voice' 'Music'
Item0: 'Music'
Simple mixer control 'LBENL Mux',0
Capabilities: enum
Items: 'Normal' 'Loopback'
Item0: 'Normal'
Simple mixer control 'LBENR Mux',0
Capabilities: enum
Item0: 'Normal'
Simple mixer control 'LINEA',0
Limits: 0 - 5
Mono: 2 [40%] [0.00dB]
Simple mixer control 'LINEA Ext Resistor Gain Mode',0
Simple mixer control 'LINEA Mixer IN1',0
Simple mixer control 'LINEA Mixer IN3',0
Simple mixer control 'LINEA Mixer IN34',0
Simple mixer control 'LINEA Mixer IN5',0
Simple mixer control 'LINEA Single Ended',0
Limits: 0 - 1
Mono: 1 [100%] [0.00dB]
Simple mixer control 'LINEB',0
Limits: 0 - 5
Simple mixer control 'LINEB Ext Resistor Gain Mode',0
Simple mixer control 'LINEB Mixer IN2',0
Simple mixer control 'LINEB Mixer IN4',0
Simple mixer control 'LINEB Mixer IN56',0
Simple mixer control 'LINEB Mixer IN6',0
Simple mixer control 'LINEB Single Ended',0
Limits: 0 - 1
Simple mixer control 'LINMOD Mux',0
Capabilities: enum
Items: 'Left Only' 'Left and Right'
Item0: 'Left Only'
Simple mixer control 'LTENL Mux',0
Capabilities: enum
Items: 'Normal' 'Loopthrough'
Item0: 'Normal'
Simple mixer control 'LTENR Mux',0
Capabilities: enum
Item0: 'Normal'
Simple mixer control 'Left ADC Mixer IN12',0
Simple mixer control 'Left ADC Mixer IN34',0
Simple mixer control 'Left ADC Mixer IN56',0
Simple mixer control 'Left ADC Mixer LINEA',0
Simple mixer control 'Left ADC Mixer LINEB',0
Simple mixer control 'Left ADC Mixer MIC1',0
Simple mixer control 'Left ADC Mixer MIC2',0
Simple mixer control 'Left Headphone Mixer LINEA',0
Simple mixer control 'Left Headphone Mixer LINEB',0
Simple mixer control 'Left Headphone Mixer Left DAC',0
Simple mixer control 'Left Headphone Mixer MIC1',0
Simple mixer control 'Left Headphone Mixer MIC2',0
Simple mixer control 'Left Headphone Mixer Right DAC',0
Simple mixer control 'Left Receiver Mixer LINEA',0
Simple mixer control 'Left Receiver Mixer LINEB',0
Simple mixer control 'Left Receiver Mixer Left DAC',0
Simple mixer control 'Left Receiver Mixer MIC1',0
Simple mixer control 'Left Receiver Mixer MIC2',0
Simple mixer control 'Left Receiver Mixer Right DAC',0
Simple mixer control 'Left Speaker Mixer LINEA',0
Simple mixer control 'Left Speaker Mixer LINEB',0
Simple mixer control 'Left Speaker Mixer Left DAC',0
Simple mixer control 'Left Speaker Mixer MIC1',0
Simple mixer control 'Left Speaker Mixer MIC2',0
Simple mixer control 'Left Speaker Mixer Right DAC',0
Simple mixer control 'MIC Bias VCM Bandgap',0
Capabilities: enum
Simple mixer control 'MIC1',0
Limits: 0 - 20
Simple mixer control 'MIC1 Boost',0
Limits: 0 - 2
Simple mixer control 'MIC1 Mux',0
Capabilities: enum
Items: 'IN12' 'IN56'
Item0: 'IN12'
Simple mixer control 'MIC2',0
Limits: 0 - 20
Simple mixer control 'MIC2 Boost',0
Limits: 0 - 2
Simple mixer control 'MIC2 Mux',0
Capabilities: enum
Items: 'IN34' 'IN56'
Item0: 'IN34'
Simple mixer control 'MIXHPLSEL Mux',0
Capabilities: enum
Items: 'DAC Only' 'HP Mixer'
Item0: 'DAC Only'
Simple mixer control 'MIXHPRSEL Mux',0
Capabilities: enum
Item0: 'DAC Only'
Simple mixer control 'Receiver',0
Limits: 0 - 31
Front Left: 21 [68%] [0.00dB]
Front Right: 21 [68%] [0.00dB]
Simple mixer control 'Receiver Left',0
Mono: Playback [on]
Simple mixer control 'Receiver Left Mixer',0
Limits: 0 - 3
Simple mixer control 'Receiver Right',0
Mono: Playback [on]
Simple mixer control 'Receiver Right Mixer',0
Limits: 0 - 3
Simple mixer control 'Record Path DC Blocking',0
Simple mixer control 'Right ADC Mixer IN12',0
Simple mixer control 'Right ADC Mixer IN34',0
Simple mixer control 'Right ADC Mixer IN56',0
Simple mixer control 'Right ADC Mixer LINEA',0
Simple mixer control 'Right ADC Mixer LINEB',0
Simple mixer control 'Right ADC Mixer MIC1',0
Simple mixer control 'Right ADC Mixer MIC2',0
Simple mixer control 'Right Headphone Mixer LINEA',0
Simple mixer control 'Right Headphone Mixer LINEB',0
Simple mixer control 'Right Headphone Mixer Left DAC',0
Simple mixer control 'Right Headphone Mixer MIC1',0
Simple mixer control 'Right Headphone Mixer MIC2',0
Simple mixer control 'Right Headphone Mixer Right DAC',0
Simple mixer control 'Right Receiver Mixer LINEA',0
Simple mixer control 'Right Receiver Mixer LINEB',0
Simple mixer control 'Right Receiver Mixer Left DAC',0
Simple mixer control 'Right Receiver Mixer MIC1',0
Simple mixer control 'Right Receiver Mixer MIC2',0
Simple mixer control 'Right Receiver Mixer Right DAC',0
Simple mixer control 'Right Speaker Mixer LINEA',0
Simple mixer control 'Right Speaker Mixer LINEB',0
Simple mixer control 'Right Speaker Mixer Left DAC',0
Simple mixer control 'Right Speaker Mixer MIC1',0
Simple mixer control 'Right Speaker Mixer MIC2',0
Simple mixer control 'Right Speaker Mixer Right DAC',0
Simple mixer control 'SDIN Mode',0
Simple mixer control 'SDOUT Hi-Z Mode',0
Mono: Playback [on]
Simple mixer control 'SDOUT Mode',0
Simple mixer control 'STENL Mux',0
Capabilities: enum
Items: 'Normal' 'Sidetone Left'
Item0: 'Normal'
Simple mixer control 'STENR Mux',0
Capabilities: enum
Items: 'Normal' 'Sidetone Right'
Item0: 'Normal'
Simple mixer control 'Volume Adjustment Smoothing',0
Mono: Playback [on]
Simple mixer control 'Zero-Crossing Detection',0
Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.MAX98090Card {
control.1 {
iface MIXER
name 'MIC Bias VCM Bandgap'
value 'High Performance'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Low Power'
item.1 'High Performance'
control.2 {
iface MIXER
name 'DMIC MIC Comp Filter Config'
value 6
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
control.3 {
iface MIXER
name 'MIC1 Boost Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 2'
dbmin 0
dbmax 3000
dbvalue.0 0
control.4 {
iface MIXER
name 'MIC2 Boost Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 2'
dbmin 0
dbmax 3000
dbvalue.0 0
control.5 {
iface MIXER
name 'MIC1 Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 20'
dbmin 0
dbmax 2000
dbvalue.0 0
control.6 {
iface MIXER
name 'MIC2 Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 20'
dbmin 0
dbmax 2000
dbvalue.0 0
control.7 {
iface MIXER
name 'LINEA Single Ended Volume'
value 1
comment {
access 'read write'
type INTEGER
count 1
range '0 - 1'
dbmin -600
dbmax 0
dbvalue.0 0
control.8 {
iface MIXER
name 'LINEB Single Ended Volume'
value 1
comment {
access 'read write'
type INTEGER
count 1
range '0 - 1'
dbmin -600
dbmax 0
dbvalue.0 0
control.9 {
iface MIXER
name 'LINEA Volume'
value 2
comment {
access 'read write'
type INTEGER
count 1
range '0 - 5'
dbmin -600
dbmax 2000
dbvalue.0 0
control.10 {
iface MIXER
name 'LINEB Volume'
value 2
comment {
access 'read write'
type INTEGER
count 1
range '0 - 5'
dbmin -600
dbmax 2000
dbvalue.0 0
control.11 {
iface MIXER
name 'LINEA Ext Resistor Gain Mode'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface MIXER
name 'LINEB Ext Resistor Gain Mode'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.13 {
iface MIXER
name 'ADCL Boost Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
dbmin 0
dbmax 4200
dbvalue.0 0
control.14 {
iface MIXER
name 'ADCR Boost Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
dbmin 0
dbmax 4200
dbvalue.0 0
control.15 {
iface MIXER
name 'ADCL Volume'
value 12
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin -1200
dbmax 300
dbvalue.0 0
control.16 {
iface MIXER
name 'ADCR Volume'
value 12
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin -1200
dbmax 300
dbvalue.0 0
control.17 {
iface MIXER
name 'ADC Oversampling Rate'
value '128*fs'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '64*fs'
item.1 '128*fs'
control.18 {
iface MIXER
name 'ADC Quantizer Dither'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.19 {
iface MIXER
name 'ADC High Performance Mode'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Low Power'
control.20 {
iface MIXER
name 'DAC Mono Mode'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.21 {
iface MIXER
name 'SDIN Mode'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.22 {
iface MIXER
name 'SDOUT Mode'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.23 {
iface MIXER
name 'SDOUT Hi-Z Mode'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface MIXER
name 'Filter Mode'
value Music
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Voice
item.1 Music
control.25 {
iface MIXER
name 'Record Path DC Blocking'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.26 {
iface MIXER
name 'Playback Path DC Blocking'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.27 {
iface MIXER
name 'Digital BQ Volume'
value 15
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin -1500
dbmax 0
dbvalue.0 0
control.28 {
iface MIXER
name 'Digital Sidetone Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 30'
dbmin 50
dbmax 6050
dbvalue.0 50
control.29 {
iface MIXER
name 'Digital Coarse Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 3'
dbmin 0
dbmax 1800
dbvalue.0 0
control.30 {
iface MIXER
name 'Digital Volume'
value 15
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin -1500
dbmax 0
dbvalue.0 0
control.31 {
iface MIXER
name 'EQ Coefficients'
value '000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type BYTES
count 105
control.32 {
iface MIXER
name 'Digital EQ 3 Band Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.33 {
iface MIXER
name 'Digital EQ 5 Band Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.34 {
iface MIXER
name 'Digital EQ 7 Band Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.35 {
iface MIXER
name 'Digital EQ Clipping Detection'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface MIXER
name 'Digital EQ Volume'
value 15
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin -1500
dbmax 0
dbvalue.0 0
control.37 {
iface MIXER
name 'ALC Enable'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.38 {
iface MIXER
name 'ALC Attack Time'
value '0.5ms'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '0.5ms'
item.1 '1ms'
item.2 '5ms'
item.3 '10ms'
item.4 '25ms'
item.5 '50ms'
item.6 '100ms'
item.7 '200ms'
control.39 {
iface MIXER
name 'ALC Release Time'
value '8s'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '8s'
item.1 '4s'
item.2 '2s'
item.3 '1s'
item.4 '0.5s'
item.5 '0.25s'
item.6 '0.125s'
item.7 '0.0625s'
control.40 {
iface MIXER
name 'ALC Make Up Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 12'
dbmin 0
dbmax 1200
dbvalue.0 0
control.41 {
iface MIXER
name 'ALC Compression Ratio'
value '1:1'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '1:1'
item.1 '1:1.5'
item.2 '1:2'
item.3 '1:4'
item.4 '1:INF'
control.42 {
iface MIXER
name 'ALC Expansion Ratio'
value '1:1'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '1:1'
item.1 '2:1'
item.2 '3:1'
control.43 {
iface MIXER
name 'ALC Compression Threshold Volume'
value 31
comment {
access 'read write'
type INTEGER
count 1
range '0 - 31'
dbmin -3100
dbmax 0
dbvalue.0 0
control.44 {
iface MIXER
name 'ALC Expansion Threshold Volume'
value 31
comment {
access 'read write'
type INTEGER
count 1
range '0 - 31'
dbmin -6600
dbmax -3500
dbvalue.0 -3500
control.45 {
iface MIXER
name 'DAC HP Playback Performance Mode'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'High Performance'
item.1 'Low Power'
control.46 {
iface MIXER
name 'DAC High Performance Mode'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Low Power'
control.47 {
iface MIXER
name 'Headphone Left Mixer Volume'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 3'
dbmin -1200
dbmax 0
dbvalue.0 0
control.48 {
iface MIXER
name 'Headphone Right Mixer Volume'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 3'
dbmin -1200
dbmax 0
dbvalue.0 0
control.49 {
iface MIXER
name 'Speaker Left Mixer Volume'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 3'
dbmin -1200
dbmax 0
dbvalue.0 0
control.50 {
iface MIXER
name 'Speaker Right Mixer Volume'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 3'
dbmin -1200
dbmax 0
dbvalue.0 0
control.51 {
iface MIXER
name 'Receiver Left Mixer Volume'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 3'
dbmin -1200
dbmax 0
dbvalue.0 0
control.52 {
iface MIXER
name 'Receiver Right Mixer Volume'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 3'
dbmin -1200
dbmax 0
dbvalue.0 0
control.53 {
iface MIXER
name 'Headphone Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -6700
dbmax 300
dbvalue.0 -6700
dbvalue.1 -6700
control.54 {
iface MIXER
name 'Speaker Volume'
value.0 20
value.1 20
comment {
access 'read write'
type INTEGER
count 2
range '0 - 39'
dbmin -4800
dbmax 1400
dbvalue.0 0
dbvalue.1 0
control.55 {
iface MIXER
name 'Receiver Volume'
value.0 21
value.1 21
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -6200
dbmax 800
dbvalue.0 0
dbvalue.1 0
control.56 {
iface MIXER
name 'Headphone Left Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.57 {
iface MIXER
name 'Headphone Right Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.58 {
iface MIXER
name 'Speaker Left Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.59 {
iface MIXER
name 'Speaker Right Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.60 {
iface MIXER
name 'Receiver Left Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.61 {
iface MIXER
name 'Receiver Right Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.62 {
iface MIXER
name 'Zero-Crossing Detection'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.63 {
iface MIXER
name 'Enhanced Vol Smoothing'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.64 {
iface MIXER
name 'Volume Adjustment Smoothing'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.65 {
iface MIXER
name 'Biquad Coefficients'
value '000000000000000000000000000000'
comment {
access 'read write'
type BYTES
count 15
control.66 {
iface MIXER
name 'Biquad Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.67 {
iface MIXER
name 'MIC1 Mux'
value IN12
comment {
access 'read write'
type ENUMERATED
count 1
item.0 IN12
item.1 IN56
control.68 {
iface MIXER
name 'MIC2 Mux'
value IN34
comment {
access 'read write'
type ENUMERATED
count 1
item.0 IN34
item.1 IN56
control.69 {
iface MIXER
name 'DMIC Mux'
value ADC
comment {
access 'read write'
type ENUMERATED
count 1
item.0 ADC
item.1 DMIC
control.70 {
iface MIXER
name 'LINEA Mixer IN1 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.71 {
iface MIXER
name 'LINEA Mixer IN3 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.72 {
iface MIXER
name 'LINEA Mixer IN5 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.73 {
iface MIXER
name 'LINEA Mixer IN34 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.74 {
iface MIXER
name 'LINEB Mixer IN2 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.75 {
iface MIXER
name 'LINEB Mixer IN4 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.76 {
iface MIXER
name 'LINEB Mixer IN6 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.77 {
iface MIXER
name 'LINEB Mixer IN56 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.78 {
iface MIXER
name 'Left ADC Mixer IN12 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.79 {
iface MIXER
name 'Left ADC Mixer IN34 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.80 {
iface MIXER
name 'Left ADC Mixer IN56 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.81 {
iface MIXER
name 'Left ADC Mixer LINEA Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.82 {
iface MIXER
name 'Left ADC Mixer LINEB Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.83 {
iface MIXER
name 'Left ADC Mixer MIC1 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.84 {
iface MIXER
name 'Left ADC Mixer MIC2 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.85 {
iface MIXER
name 'Right ADC Mixer IN12 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.86 {
iface MIXER
name 'Right ADC Mixer IN34 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.87 {
iface MIXER
name 'Right ADC Mixer IN56 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.88 {
iface MIXER
name 'Right ADC Mixer LINEA Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.89 {
iface MIXER
name 'Right ADC Mixer LINEB Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.90 {
iface MIXER
name 'Right ADC Mixer MIC1 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.91 {
iface MIXER
name 'Right ADC Mixer MIC2 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.92 {
iface MIXER
name 'LBENL Mux'
value Normal
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Normal
item.1 Loopback
control.93 {
iface MIXER
name 'LBENR Mux'
value Normal
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Normal
item.1 Loopback
control.94 {
iface MIXER
name 'LTENL Mux'
value Normal
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Normal
item.1 Loopthrough
control.95 {
iface MIXER
name 'LTENR Mux'
value Normal
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Normal
item.1 Loopthrough
control.96 {
iface MIXER
name 'STENL Mux'
value Normal
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Normal
item.1 'Sidetone Left'
control.97 {
iface MIXER
name 'STENR Mux'
value Normal
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Normal
item.1 'Sidetone Right'
control.98 {
iface MIXER
name 'Left Headphone Mixer Left DAC Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.99 {
iface MIXER
name 'Left Headphone Mixer Right DAC Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.100 {
iface MIXER
name 'Left Headphone Mixer LINEA Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.101 {
iface MIXER
name 'Left Headphone Mixer LINEB Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.102 {
iface MIXER
name 'Left Headphone Mixer MIC1 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.103 {
iface MIXER
name 'Left Headphone Mixer MIC2 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.104 {
iface MIXER
name 'Right Headphone Mixer Left DAC Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.105 {
iface MIXER
name 'Right Headphone Mixer Right DAC Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.106 {
iface MIXER
name 'Right Headphone Mixer LINEA Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.107 {
iface MIXER
name 'Right Headphone Mixer LINEB Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.108 {
iface MIXER
name 'Right Headphone Mixer MIC1 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.109 {
iface MIXER
name 'Right Headphone Mixer MIC2 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.110 {
iface MIXER
name 'Left Speaker Mixer Left DAC Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.111 {
iface MIXER
name 'Left Speaker Mixer Right DAC Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.112 {
iface MIXER
name 'Left Speaker Mixer LINEA Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.113 {
iface MIXER
name 'Left Speaker Mixer LINEB Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.114 {
iface MIXER
name 'Left Speaker Mixer MIC1 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.115 {
iface MIXER
name 'Left Speaker Mixer MIC2 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.116 {
iface MIXER
name 'Right Speaker Mixer Left DAC Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.117 {
iface MIXER
name 'Right Speaker Mixer Right DAC Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.118 {
iface MIXER
name 'Right Speaker Mixer LINEA Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.119 {
iface MIXER
name 'Right Speaker Mixer LINEB Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.120 {
iface MIXER
name 'Right Speaker Mixer MIC1 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.121 {
iface MIXER
name 'Right Speaker Mixer MIC2 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.122 {
iface MIXER
name 'Left Receiver Mixer Left DAC Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.123 {
iface MIXER
name 'Left Receiver Mixer Right DAC Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.124 {
iface MIXER
name 'Left Receiver Mixer LINEA Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.125 {
iface MIXER
name 'Left Receiver Mixer LINEB Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.126 {
iface MIXER
name 'Left Receiver Mixer MIC1 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.127 {
iface MIXER
name 'Left Receiver Mixer MIC2 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.128 {
iface MIXER
name 'Right Receiver Mixer Left DAC Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.129 {
iface MIXER
name 'Right Receiver Mixer Right DAC Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.130 {
iface MIXER
name 'Right Receiver Mixer LINEA Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.131 {
iface MIXER
name 'Right Receiver Mixer LINEB Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.132 {
iface MIXER
name 'Right Receiver Mixer MIC1 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.133 {
iface MIXER
name 'Right Receiver Mixer MIC2 Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.134 {
iface MIXER
name 'LINMOD Mux'
value 'Left Only'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Left Only'
item.1 'Left and Right'
control.135 {
iface MIXER
name 'MIXHPLSEL Mux'
value 'DAC Only'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'DAC Only'
item.1 'HP Mixer'
control.136 {
iface MIXER
name 'MIXHPRSEL Mux'
value 'DAC Only'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'DAC Only'
item.1 'HP Mixer'
--endcollapse--
!!All Loaded Modules
btbcm
cfg80211
hci_uart
imx_pcm_dma
imx_sdma
nfnetlink
snd_pcm_dmaengine
snd_soc_core
snd_soc_fsl_sai
snd_soc_fsl_utils
snd_soc_max98090
snd_soc_simple_card
snd_soc_simple_card_utils
virt_dma
!!ALSA/HDA dmesg
[ 4.181737] clk: Disabling unused clocks
[ 4.198902] ALSA device list:
[ 4.203878] No soundcards found.
[ 4.224687] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
Hi Markus,
Let's discuss the assumptions first:
An IRQ is mandatory as is stated on the devicetree bindings : max98090.yaml and also because if the IRQ is not found the probe function will exit with and error. If &supply_io_expander is an interrupt controller and you see the new registered interrupt in /proc/interrupts it is fine.
For clocks devicetree property you can reference the yaml devicetree bindings but it looks fine for your usecase where you have the MCLK provided externally with a fixed oscillator.
But the oscillator you use is 12288000 Hz. That's integer dividable for 48Khz multiple sampling rates but it is not for 44100Khz. So that's why you see the print:
For audio outtput check the DAC-> SPK mixers for example:
And set them to ON
I think the reason you don't get audio at all is in the ALSA mixer configuration.
-Regards, Bogdan
Hi Bogdan,
thanks for your reply! I can confirm that I get sound now after enabling the missing mixers.
What is the typical way to make these mixers default-on in a Yocto/Weston-based system, is there a way to do this via the drivers? Any suggestions/pointers would be very welcome here :-)
I tried a bit more regarding the "no better method found" messages that I get. And I get the same message when using 48 kHz playback, which shouldn't be the case according to your explanation. What am I missing here? I believe these messages should not be printed in a properly configured system, right?
root@board:~# aplay piano2.wav
Playing WAVE 'piano2.wav' : Signed 16 bit Little Endi[ 7864.605075] max98090 4-0010: No better method found
an, Rate 48000 Hz, Stereo
[ 7864.611378] max98090 4-0010: Calculating ni 24576 with mi 65536
root@board:~# aplay example.wav
Playing WAVE 'example.wav' : Signed 16 bit Little Endi[ 7879.796059] max98090 4-0010: No better method found
[ 7879.803331] max98090 4-0010: Calculating ni 22579 with mi 65536
Best regards
Markus
