Long Boot time
Product Number: Xilinx ZynqMP
Software Version: Petalinux 2021.2
I am able to Build the Petalinux (2021.2)  and able to boot the petalinux for my harwdare
And able to communicate using ethernet, every thing seems OK,
But one thing bother me is that, during boot process it took around 20-25 minute to complete the booting process
It first stuck at line no. 43 and took significant amount of time (attached file)
then it stuck at like no 60 and again took significant amount of time (attached file)
and then again it stuck at line no 72 for a significant amount of time (attached file)
And then suddenly it will boot like no issue and boot normally till command pronmp.
why it took significant amount (~20-25 minute) for booting to complete,
Is it related to my .xsa file or boot address issue ?
please suggest where i am wrong.
///////////////////////////////////////////////////////////// Below is my boot.script information for reference////////////////////////////////////
# This is a boot script for U-Boot
# Generate boot.scr:
# mkimage -c none -A arm -T script -d boot.cmd.default boot.scr
fitimage_name=image.ub
kernel_name=Image
ramdisk_name=ramdisk.cpio.gz.u-boot
rootfs_name=rootfs.cpio.gz.u-boot
for boot_target in ${boot_targets};
do
echo "Trying to load boot images from ${boot_target}"
if test "${boot_target}" = "jtag" ; then
booti 0x00200000 0x04000000 0x00100000
fi
if test "${boot_target}" = "mmc0" || test "${boot_target}" = "mmc1" ; then
if test -e ${devtype} ${devnum}:${distro_bootpart} /uEnv.txt; then
fatload ${devtype} ${devnum}:${distro_bootpart} 0x00200000 uEnv.txt;
echo "Importing environment(uEnv.txt) from ${boot_target}..."
env import -t 0x00200000 $filesize
if test -n $uenvcmd; then
echo "Running uenvcmd ...";
run uenvcmd;
fi
fi
if test -e ${devtype} ${devnum}:${distro_bootpart} /${fitimage_name}; then
fatload ${devtype} ${devnum}:${distro_bootpart} 0x10000000 ${fitimage_name};
bootm 0x10000000;
fi
if test -e ${devtype} ${devnum}:${distro_bootpart} /${kernel_name}; then
fatload ${devtype} ${devnum}:${distro_bootpart} 0x00200000 ${kernel_name};
fi
if test -e ${devtype} ${devnum}:${distro_bootpart} /system.dtb; then
fatload ${devtype} ${devnum}:${distro_bootpart} 0x00100000 system.dtb;
fi
if test -e ${devtype} ${devnum}:${distro_bootpart} /${ramdisk_name} && test "${skip_tinyramdisk}" != "yes"; then
fatload ${devtype} ${devnum}:${distro_bootpart} 0x04000000 ${ramdisk_name};
fi
if test -e ${devtype} ${devnum}:${distro_bootpart} /${rootfs_name} && test "${skip_ramdisk}" != "yes"; then
fatload ${devtype} ${devnum}:${distro_bootpart} 0x04000000 ${rootfs_name};
fi
booti 0x00200000 - 0x00100000
fi
if test "${boot_target}" = "xspi0" || test "${boot_target}" = "qspi" || test "${boot_target}" = "qspi0"; then
sf probe 0 0 0;
sf read 0x10000000 0xF40000 0x6400000
bootm 0x10000000;
echo "Booting using Fit image failed"
sf read 0x00200000 0x1E40000 0x2040000
sf read 0x04000000 0x4000000 0x4000000
booti 0x00200000 0x04000000 0x00100000;
echo "Booting using Separate images failed"
fi
if test "${boot_target}" = "nand" || test "${boot_target}" = "nand0"; then
nand info;
nand read 0x10000000 0x4180000 0x6400000
bootm 0x10000000;
nand read 0x00200000 0x4100000 0x3200000
nand read 0x04000000 0x7800000 0x3200000
fi
done
Regards
it stuck 2-3 places during boot time, i have attached the booting sequence along with the place where it stuck .
Xilinx Zynq MP First Stage Boot Loader
Release 2021.2   Oct 13 2021  -  07:15:53
NOTICE:  BL31: v2.4(release):xlnx_rebase_v2.4_2021.1_update1-23-g9188496b9
NOTICE:  BL31: Built : 07:41:24, Oct 13 2021
U-Boot 2021.01 (Oct 12 2021 - 09:28:42 +0000)
CPU:   ZynqMP
Silicon: v3
Board: Xilinx ZynqMP
DRAM:  4 GiB
PMUFW:  v1.1
EL Level:       EL2
Chip ID:        zu15eg
NAND:  0 MiB
MMC:   mmc@ff160000: 0
Loading Environment from SPIFlash... SF: Detected s25fl512s with page size 512 B              ytes, erase size 512 KiB, total 128 MiB
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Bootmode: QSPI_MODE
Reset reason:   EXTERNAL
Net:
ZYNQ GEM: ff0c0000, mdio bus ff0c0000, phyaddr 1, interface rgmii-id
Warning: ethernet@ff0c0000 (eth0) using random MAC address - aa:f3:07:93:80:87
eth0: ethernet@ff0c0000
ZYNQ GEM: ff0e0000, mdio bus ff0e0000, phyaddr 1, interface rgmii-id
Warning: ethernet@ff0e0000 (eth1) using random MAC address - 6e:53:46:dc:56:09
, eth1: ethernet@ff0e0000
Hit any key to stop autoboot:  0
SF: Detected s25fl512s with page size 512 Bytes, erase size 512 KiB, total 128 M              iB
device 0 offset 0x3e80000, size 0x80000
SF: 524288 bytes @ 0x3e80000 Read: OK
QSPI: Trying to boot script at 20000000
## Executing script at 20000000
Trying to load boot images from qspi0
device 0 offset 0xf40000, size 0x6400000
/////////////BOOTING STUCK AT THIS PLACE for lomg time///////////////
/////////////After some time say 7-8 min//////////////////////////////
SF: 104857600 bytes @ 0xf40000 Read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
device 0 offset 0x1e40000, size 0x2040000
/////////////After some time say 4-5 min//////////////////////////////
SF: 33816576 bytes @ 0x1e40000 Read: OK
device 0 offset 0x4000000, size 0x4000000
/////////////After some time say 4-5 min//////SUddenly Booting Start till END
SF: 67108864 bytes @ 0x4000000 Read: OK
## Loading init Ramdisk from Legacy Image at 04000000 ...
   Image Name:   petalinux-image-minimal-zynqmp-g
   Created:      2011-04-05  23:00:00 UTC
   Image Type:   AArch64 Linux RAMDisk Image (uncompressed)
   Data Size:    10403838 Bytes = 9.9 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 00100000
   Booting using the fdt blob at 0x100000
   Loading Ramdisk to 7d327000, end 7dd12ffe ... OK
   Loading Device Tree to 000000007d31a000, end 000000007d32644a ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.0-xilinx-v2021.2 (oe-user@oe-host) (aarch64-xilinx-linux-gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP Tue Oct 12 09:30:57 UTC 2021
[    0.000000] Machine model: xlnx,zynqmp
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] printk: bootconsole [cdns0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x000000006d000000
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000087fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000007fefffff]
[    0.000000]   node   0: [mem 0x0000000800000000-0x000000087fffffff]
[    0.000000] Zeroed struct page in unavailable ranges: 256 pages
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000087fffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 22 pages/cpu s50968 r8192 d30952 u90112
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1031940
[    0.000000] Kernel command line:  earlycon console=ttyPS0,115200 clk_ignore_unused root=/dev/ram0 rw
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x0000000069000000-0x000000006d000000] (64MB)
[    0.000000] Memory: 3752920K/4193280K available (13952K kernel code, 984K rwdata, 3916K rodata, 2112K init, 588K bss, 178216K reserved, 262144K cma-reserved)
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x524 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171015c90f, max_idle_ns: 440795203080 ns
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[    0.008268] Console: colour dummy device 80x25
[    0.012394] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399996)
[    0.022754] pid_max: default: 32768 minimum: 301
[    0.027478] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.034702] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.043532] rcu: Hierarchical SRCU implementation.
[    0.047462] EFI services will not be available.
[    0.051875] smp: Bringing up secondary CPUs ...
[    0.056601] Detected VIPT I-cache on CPU1
[    0.056640] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.057026] Detected VIPT I-cache on CPU2
[    0.057051] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.057411] Detected VIPT I-cache on CPU3
[    0.057434] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.057481] smp: Brought up 1 node, 4 CPUs
[    0.091694] SMP: Total of 4 processors activated.
[    0.096366] CPU features: detected: 32-bit EL0 Support
[    0.101470] CPU features: detected: CRC32 instructions
[    0.106607] CPU: All CPU(s) started at EL2
[    0.110651] alternatives: patching kernel code
[    0.116161] devtmpfs: initialized
[    0.122707] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.128040] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.141426] pinctrl core: initialized pinctrl subsystem
[    0.141924] DMI not present or invalid.
[    0.144998] NET: Registered protocol family 16
[    0.150298] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.156345] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.164150] audit: initializing netlink subsys (disabled)
[    0.169615] audit: type=2000 audit(0.108:1): state=initialized audit_enabled=0 res=1
[    0.177194] cpuidle: using governor menu
[    0.181135] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.187869] ASID allocator initialised with 65536 entries
[    0.193284] Serial: AMBA PL011 UART driver
[    0.217026] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.218087] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.224743] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.231403] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    1.282936] cryptd: max_cpu_qlen set to 1000
[    1.307402] DRBG: Continuing without Jitter RNG
[    1.386840] raid6: neonx8   gen()  2138 MB/s
[    1.454899] raid6: neonx8   xor()  1598 MB/s
[    1.522963] raid6: neonx4   gen()  2193 MB/s
[    1.591021] raid6: neonx4   xor()  1567 MB/s
[    1.659090] raid6: neonx2   gen()  2077 MB/s
[    1.727141] raid6: neonx2   xor()  1437 MB/s
[    1.795225] raid6: neonx1   gen()  1775 MB/s
[    1.863271] raid6: neonx1   xor()  1219 MB/s
[    1.931344] raid6: int64x8  gen()  1437 MB/s
[    1.999398] raid6: int64x8  xor()   771 MB/s
[    2.067462] raid6: int64x4  gen()  1601 MB/s
[    2.135519] raid6: int64x4  xor()   815 MB/s
[    2.203594] raid6: int64x2  gen()  1397 MB/s
[    2.271649] raid6: int64x2  xor()   744 MB/s
[    2.339723] raid6: int64x1  gen()  1031 MB/s
[    2.407796] raid6: int64x1  xor()   517 MB/s
[    2.407834] raid6: using algorithm neonx4 gen() 2193 MB/s
[    2.411794] raid6: .... xor() 1567 MB/s, rmw enabled
[    2.416725] raid6: using neon recovery algorithm
[    2.421755] iommu: Default domain type: Translated
[    2.426380] SCSI subsystem initialized
[    2.430015] usbcore: registered new interface driver usbfs
[    2.435350] usbcore: registered new interface driver hub
[    2.440626] usbcore: registered new device driver usb
[    2.445674] mc: Linux media interface: v0.10
[    2.449875] videodev: Linux video capture interface: v2.00
[    2.455346] EDAC MC: Ver: 3.0.0
[    2.458799] zynqmp-ipi-mbox mailbox@ff990400: Registered ZynqMP IPI mbox with TX/RX channels.
[    2.467080] FPGA manager framework
[    2.470381] Advanced Linux Sound Architecture Driver Initialized.
[    2.476620] Bluetooth: Core ver 2.22
[    2.479882] NET: Registered protocol family 31
[    2.484284] Bluetooth: HCI device and connection manager initialized
[    2.490600] Bluetooth: HCI socket layer initialized
[    2.495443] Bluetooth: L2CAP socket layer initialized
[    2.500466] Bluetooth: SCO socket layer initialized
[    2.505545] clocksource: Switched to clocksource arch_sys_counter
[    2.511504] VFS: Disk quotas dquot_6.6.0
[    2.515294] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    2.526517] NET: Registered protocol family 2
[    2.526899] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    2.534932] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    2.542963] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    2.550411] TCP: Hash tables configured (established 32768 bind 32768)
[    2.556582] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    2.563248] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    2.570423] NET: Registered protocol family 1
[    2.574887] RPC: Registered named UNIX socket transport module.
[    2.580480] RPC: Registered udp transport module.
[    2.585145] RPC: Registered tcp transport module.
[    2.589820] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.596904] Trying to unpack rootfs image as initramfs...
[    3.055003] Freeing initrd memory: 10156K
[    3.129795] Initialise system trusted keyrings
[    3.129933] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    3.135722] NFS: Registering the id_resolver key type
[    3.140043] Key type id_resolver registered
[    3.144180] Key type id_legacy registered
[    3.148190] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    3.154833] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    3.197350] NET: Registered protocol family 38
[    3.197395] xor: measuring software checksum speed
[    3.205088]    8regs           :  2363 MB/sec
[    3.208753]    32regs          :  2799 MB/sec
[    3.213700]    arm64_neon      :  2380 MB/sec
[    3.213886] xor: using function: 32regs (2799 MB/sec)
[    3.218911] Key type asymmetric registered
[    3.222974] Asymmetric key parser 'x509' registered
[    3.227838] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    3.235172] io scheduler mq-deadline registered
[    3.239668] io scheduler kyber registered
[    3.245499] ps_pcie_dma init()
[    3.273610] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    3.275366] Serial: AMBA driver
[    3.279345] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.288062] brd: module loaded
[    3.292508] loop: module loaded
[    3.293271] mtdoops: mtd device (mtddev=name/number) must be supplied
[    3.297928] libphy: Fixed MDIO Bus: probed
[    3.301768] tun: Universal TUN/TAP device driver, 1.6
[    3.305605] CAN device driver interface
[    3.309967] usbcore: registered new interface driver asix
[    3.314714] usbcore: registered new interface driver ax88179_178a
[    3.320750] usbcore: registered new interface driver cdc_ether
[    3.326545] usbcore: registered new interface driver net1080
[    3.332169] usbcore: registered new interface driver cdc_subset
[    3.338049] usbcore: registered new interface driver zaurus
[    3.343594] usbcore: registered new interface driver cdc_ncm
[    3.349993] usbcore: registered new interface driver uas
[    3.354498] usbcore: registered new interface driver usb-storage
[    3.361044] rtc_zynqmp ffa60000.rtc: registered as rtc0
[    3.365643] rtc_zynqmp ffa60000.rtc: setting system clock to 2103-10-29T21:15:34 UTC (4223135734)
[    3.374489] i2c /dev entries driver
[    3.379329] usbcore: registered new interface driver uvcvideo
[    3.383617] USB Video Class driver (1.1.1)
[    3.388146] Bluetooth: HCI UART driver ver 2.3
[    3.392097] Bluetooth: HCI UART protocol H4 registered
[    3.397198] Bluetooth: HCI UART protocol BCSP registered
[    3.402487] Bluetooth: HCI UART protocol LL registered
[    3.407577] Bluetooth: HCI UART protocol ATH3K registered
[    3.412951] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    3.419199] Bluetooth: HCI UART protocol Intel registered
[    3.424544] Bluetooth: HCI UART protocol QCA registered
[    3.429745] usbcore: registered new interface driver bcm203x
[    3.435372] usbcore: registered new interface driver bpa10x
[    3.440903] usbcore: registered new interface driver bfusb
[    3.446353] usbcore: registered new interface driver btusb
[    3.451825] usbcore: registered new interface driver ath3k
[    3.457306] EDAC MC: ECC not enabled
[    3.460908] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    3.473236] sdhci: Secure Digital Host Controller Interface driver
[    3.479031] sdhci: Copyright(c) Pierre Ossman
[    3.483352] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.489255] ledtrig-cpu: registered to indicate activity on CPUs
[    3.494954] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    3.501383] zynqmp_firmware_probe Platform Management API v1.1
[    3.507142] zynqmp_firmware_probe Trustzone version v1.0
[    3.561470] securefw securefw: securefw probed
[    3.561749] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[    3.565921] zynqmp_aes firmware:zynqmp-firmware:zynqmp-aes: AES Successfully Registered
[    3.574038] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[    3.580173] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[    3.585696] usbcore: registered new interface driver usbhid
[    3.591073] usbhid: USB HID core driver
[    3.597546] ARM CCI_400_r1 PMU driver probed
[    3.597995] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    3.605941] usbcore: registered new interface driver snd-usb-audio
[    3.612423] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    3.619815] Initializing XFRM netlink socket
[    3.623489] NET: Registered protocol family 10
[    3.628247] Segment Routing with IPv6
[    3.631642] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.637704] NET: Registered protocol family 17
[    3.641771] NET: Registered protocol family 15
[    3.646182] can: controller area network core
[    3.650520] NET: Registered protocol family 29
[    3.654909] can: raw protocol
[    3.657851] can: broadcast manager protocol
[    3.662004] can: netlink gateway - max_hops=1
[    3.666399] Bluetooth: RFCOMM TTY layer initialized
[    3.671176] Bluetooth: RFCOMM socket layer initialized
[    3.676282] Bluetooth: RFCOMM ver 1.11
[    3.679997] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.685270] Bluetooth: BNEP filters: protocol multicast
[    3.690466] Bluetooth: BNEP socket layer initialized
[    3.695390] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.701277] Bluetooth: HIDP socket layer initialized
[    3.706325] 9pnet: Installing 9P2000 support
[    3.710457] Key type dns_resolver registered
[    3.714867] registered taskstats version 1
[    3.718752] Loading compiled-in X.509 certificates
[    3.724443] Btrfs loaded, crc32c=crc32c-generic
[    3.736627] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 51, base_baud = 6249999) is a xuartps
[    3.745651] printk: console [ttyPS0] enabled
[    3.749945] printk: bootconsole [cdns0] disabled
[    3.759349] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 52, base_baud = 6249999) is a xuartps
[    3.772770] of-fpga-region fpga-full: FPGA Region probed
[    3.778818] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    3.786000] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    3.793179] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    3.800356] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    3.807521] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    3.814703] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    3.821870] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    3.829042] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    3.836283] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    3.843471] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    3.850651] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    3.857821] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    3.864996] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    3.872166] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    3.879333] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    3.886502] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    3.893738] ahci-ceva fd0c0000.ahci: supply ahci not found, using dummy regulator
[    3.901286] ahci-ceva fd0c0000.ahci: supply phy not found, using dummy regulator
[    3.908706] ahci-ceva fd0c0000.ahci: supply target not found, using dummy regulator
[    3.916436] ahci-ceva fd0c0000.ahci: ceva,p0-cominit-params property not defined
[    3.923977] ahci-ceva: probe of fd0c0000.ahci failed with error -22
[    3.930659] zynqmp_pll_disable() clock disable failed for rpll_int, ret = -13
[    3.938786] spi_master spi0: cannot find modalias for /axi/spi@ff0f0000/flash@0
[    3.946106] spi_master spi0: Failed to create SPI device for /axi/spi@ff0f0000/flash@0
[    3.954387] macb ff0c0000.ethernet: Not enabling partial store and forward
[    3.962008] libphy: MACB_mii_bus: probed
[    3.968922] macb ff0c0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0c0000 irq 37 (aa:f3:07:93:80:87)
[    3.979185] macb ff0e0000.ethernet: Not enabling partial store and forward
[    3.986796] libphy: MACB_mii_bus: probed
[    3.993390] macb ff0e0000.ethernet eth1: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 38 (6e:53:46:dc:56:09)
[    4.003654] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    4.010296] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[    4.016829] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[    4.023364] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[    4.030098] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 40
[    4.036475] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 41
[    4.042805] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
[    4.050285] cdns-wdt ff150000.watchdog: Xilinx Watchdog Timer with timeout 10s
[    4.060745] of_cfs_init
[    4.063226] of_cfs_init: OK
[    4.066151] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.094426] mmc0: SDHCI controller on ff160000.mmc [ff160000.mmc] using ADMA 64-bit
[    4.172854] mmc0: new HS200 MMC card at address 0001
[    4.178245] mmcblk0: mmc0:0001 IX2964 58.3 GiB
[    4.182973] mmcblk0boot0: mmc0:0001 IX2964 partition 1 4.00 MiB
[    4.189066] mmcblk0boot1: mmc0:0001 IX2964 partition 2 4.00 MiB
[    4.195078] mmcblk0rpmb: mmc0:0001 IX2964 partition 3 4.00 MiB, chardev (245:0)
[    4.205189] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.211727] clk: Not disabling unused clocks
[    4.216245] ALSA device list:
[    4.219201]   No soundcards found.
[    4.222880] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    4.231492] cfg80211: failed to load regulatory.db
[    4.237037] Freeing unused kernel memory: 2112K
[    4.257589] Run /init as init process
INIT: version 2.97 booting
Starting udev
[    4.363165] udevd[252]: starting version 3.2.9
[    4.367979] random: udevd: uninitialized urandom read (16 bytes read)
[    4.374509] random: udevd: uninitialized urandom read (16 bytes read)
[    4.380967] random: udevd: uninitialized urandom read (16 bytes read)
[    4.392015] udevd[253]: starting eudev-3.2.9
[    4.612609] random: fast init done
bootlogd: /dev/ttyPS0Configuring packages on first boot....
 (This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
INIT: Entering runlevel: 5
Configuring network interfaces... [    5.044613] macb ff0c0000.ethernet eth0: PHY [ff0c0000.ethernet-ffffffff:01] driver [TI DP83867] (irq=POLL)
[    5.054402] macb ff0c0000.ethernet eth0: configuring for phy/rgmii-id link mode
udhcpc: started, v1.32.0
udhcpc: sending discover
[    9.167222] macb ff0c0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control tx
[    9.174821] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
udhcpc: no lease, forking to background
done.
Starting haveged: haveged: command socket is listening at fd 3
haveged: haveged starting up
Starting Dropbear SSH server: Waiting for kernel randomness to be initialised...
haveged: haveged: ver: 1.9.13; arch: generic; vend: ; build: (gcc 10.2.0 CTV); collect: 128K
haveged: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 11/40; sz: 15456/64452
haveged: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 8.00288
haveged: haveged: fills: 0, generated: 0
[   14.995703] random: crng init done
Generating 2048 bit rsa key, this may take a while...
[   14.999124] random: 7 urandom warning(s) missed due to ratelimiting
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCcLQKVCrBjgAq0Dz3CcoOrAiwh3h/2gI/93mrsbcehIpCxZxroIVEc6Tv+koaJbpdAivXuf5bQgBwgny2owCUhpR0mWSoJ15ed8zBI+blFIvpHDX8hCYlzJuG7EenZD+BkWfkIEaNYrTAfLY2nrtwW8TmRY8w573gdRSANBbNKhI3PW3On/9zesSIh0BnlrkF8V43pfqlxY8aGrBj0EaT8RjHGn1GOPCXmGCS1s7hcWRbDR5glXRnJT1MJLhay7KEyv2SEVcet2H/pWzhOY3NBhmEMVirnQBj5D5Z1D9X1UNBX1yGUribeWkfvNicSjMOavt5Jw+Bhrena1uW55tTL root@VPX_COTS3
Fingerprint: sha1!! 45:fa:e7:a4:bc:b9:ac:11:a4:95:f5:78:93:57:52:61:0f:cd:37:9c
dropbear.
Starting internet superserver: inetd.
Starting syslogd/klogd: done
Starting tcf-agent: OK
root@VPX_COTS3:~#
