Booting Petalinux 2021.2 along with Ethernet , SPI and Serial Interface
Product Number: VPX3-ZU1B-C2M-CC
Software Version: Petalinux 2021.2
Hello There,
I am trying to boot petalinux 2021.2 on my CoTS hardware " VPX3-ZU1B-C2M-CC" from PanaTeQ to interface FMC-SDR400D from Sundance DSP.
My aim is to configure and control FMC using SPI and commnicate CoTS hrdware remotely through ethernet interface.
Using my .xsa i am able to build petalinux and also able to write boot image in flash "s25fl512s-1.8v-qspi-x8-dual"
I have added SPI information in system-user.dtsi also but don't know how to add ethernet information in system-user.dtsi. (for reference i have attached both system-top.dts and system-user.dtsi)
while i boot the CoTS hardware i have got "ZynqMP>" cansole (attached), not command prompt hence not able to see weather spidev is enable or not.
why i am not able to boot the hardware up to terminal , is there any flash address error or something else
please help me out what i missing.
while partationig the flash following partation i have done.
1. BOOT.bin size : 1F00000   (Offset start from 0X0 )
2. bootenv    size : 100000     (Offset start from 0X1F00000 )
3. Image       size : 2000000   (Offset start from 0X2000000 )
4. bootscr     size  : 180000    (Offset start from 0X4000000 )
5. rootfs        size :  4000000  (Offset start from 0X4180000 )
below is system-top.dts
 * CAUTION: This file is automatically generated by Xilinx.
 * Version:
 * Today is: Tue Oct 22 11:04:51 2024
/dts-v1/;
#include "zynqmp.dtsi"
#include "zynqmp-clk-ccf.dtsi"
#include "pl.dtsi"
#include "pcw.dtsi"
	chosen {
		bootargs = "earlycon";
		stdout-path = "serial0:115200n8";
	aliases {
		ethernet0 = &gem1;
		ethernet1 = &gem3;
		i2c0 = &i2c0;
		i2c1 = &i2c1;
		serial0 = &uart0;
		serial1 = &uart1;
		spi0 = &qspi;
		spi1 = &spi0;
	memory {
		device_type = "memory";
		reg = <0x0 0x0 0x0 0x7ff00000>, <0x00000008 0x00000000 0x0 0x80000000>;
#include "system-user.dtsi"
below is system-user.dtsi
/include/ "system-conf.dtsi"
&spi0 {
	status ="okay";
	spidev@0{
			reg	=	<0>;
			compatible = "rohm,dh2228fv";
			spi-max-frequency	=	<25000000>;
below is bootloader information
Xilinx Zynq MP First Stage Boot Loader
Release 2021.2   Oct 13 2021  -  07:15:53
NOTICE:  BL31: v2.4(release):xlnx_rebase_v2.4_2021.1_update1-23-g9188496b9
NOTICE:  BL31: Built : 07:41:24, Oct 13 2021
U-Boot 2021.01 (Oct 12 2021 - 09:28:42 +0000)
CPU:   ZynqMP
Silicon: v3
Board: Xilinx ZynqMP
DRAM:  4 GiB
PMUFW:  v1.1
EL Level:       EL2
Chip ID:        zu15eg
NAND:  0 MiB
MMC:   mmc@ff160000: 0
Loading Environment from SPIFlash... SF: Detected s25fl512s with page size 512 Bytes, erase size 512 KiB, total 128 MiB
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Bootmode: QSPI_MODE
Reset reason:   EXTERNAL
Net:
ZYNQ GEM: ff0c0000, mdio bus ff0c0000, phyaddr -1, interface rgmii-id
Could not get PHY for eth0: addr -1
ZYNQ GEM: ff0e0000, mdio bus ff0e0000, phyaddr -1, interface rgmii-id
Could not get PHY for eth1: addr -1
No ethernet found.
Hit any key to stop autoboot:  0
device 0 offset 0x3e80000, size 0x80000
SF: 524288 bytes @ 0x3e80000 Read: OK
QSPI: Trying to boot script at 20000000
## Executing script at 20000000
Wrong image format for "source" command
QSPI: SCRIPT FAILED: continuing...
JTAG: Trying to boot script at 20000000
JTAG: SCRIPT FAILED: continuing...
switch to partitions #0, OK
mmc0(part 0) is current device
** No partition table - mmc 0 **
MMC Device 1 not found
no mmc device at slot 1
no devices available
NAND: SCRIPT FAILED: continuing...
starting USB...
No working controllers found
USB is stopped. Please issue 'usb start' first.
starting USB...
scanning bus for devices...
SATA link 0 timeout.
SATA link 1 timeout.
AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq pm clo only pmp fbss pio slum part ccc apst
Device 0: unknown device
starting USB...
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-zynqmp-zynqmp
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
starting USB...
No ethernet found.
No ethernet found.
ZynqMP>
