I download the ADI-Kuiper image from swdownloads.analog.com/.../image_2024-06-18-ADI-Kuiper-full.zip, then use Raspberry Pi Imager to burn image to SD card.
As my undertanding, CN0566 contains two adar1000, but the dts file only contain adar1000_0@0 BEAM0, there is no BEAM1? is it correct?
github.com/.../rpi-adar1000-overlay.dts
Also the config.txt, the SPI is disabled, adar1000 is SPI interface, what is the SPI setting of Raspberry pi?
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
If we want to setup 4 SPI interface from Raspberry GPIO, each SPI control 4 adar1000, how to setup config.txt/device tree/adar1000 driver?
rpi-adar1000-overlay.dts /dts-v1/; /plugin/; / { compatible = "brcm,bcm2835", "brcm,bcm2708", "brcm,bcm2709"; fragment@0 { target = <&spi0>; __overlay__ { #address-cells = <1>; #size-cells = <0>; status = "okay"; adar1000@0 { compatible = "adi,adar1000"; reg = <0>; spi-max-frequency = <1000000>; #address-cells = <1>; #size-cells = <0>; adar1000_0@0 { reg = <0>; label = "BEAM0"; adi,phasetable-name = "adar1000_std_phasetable"; }; adar1000_1@1 { reg = <1>; label = "BEAM1"; }; adar1000_2@2 { reg = <2>; label = "BEAM2"; }; adar1000_3@3 { reg = <3>; label = "BEAM3"; }; }; }; }; fragment@1 { target = <&spidev0>; __overlay__ { status = "disabled"; }; }; fragment@2 { target = <&spidev1>; __overlay__ { status = "disabled"; }; }; };
Thanks
