I added AXI Bram controller IP to the base design to R/W new memory and registers. I exported the XSA file recompiled the DAQ2 example SW code and downloaded the elf to successfully R/W the new memory from the XSDB% prompt, but I don't get the same boot screen prompting me for a user login while in the terminal window. If i download the stock simpleImage.kc705_fmcdaq2.strip file I can't read the memory that was added, but all the iio drivers and user login is present in the terminal window. How do you merge a new elf with the Linux kernel that contains the IIO drivers to make a new *.strip file? I want to r/w the added memory and also run the iio-oscilloscope application. Thanks
