Assistance Required with AD9434-FMC-500EBZ Register Write Issue
Product Number: ad9434-fmc-500ebz, ad9434
Software Version: petalinux 2022.1 , Linux version 5.15.0, Xilinx ZC702 Eval kit
I am currently using the AD9434-FMC-500EBZ card for my project. I am able to successfully detect the device using the following command:
iio_context_find_device(ctx, "9517-4");
However, I encounter an issue when attempting to write to the registers. The reg_write_status returns a non-negative number, specifically 254, for the following register write operations:
reg_write_status = iio_device_reg_write(ad9517, 0x000, 0x3c);
reg_write_status = iio_device_reg_write(ad9517, 0x232, 0x01);
reg_write_status = iio_device_reg_write(ad9517, 0x000, 0x18);
I have attached the kernel log, the application.c code, and the .dtsi file for your reference.
Could you please assist me in understanding why I am unable to write the values to the registers? Any guidance or troubleshooting tips would be greatly appreciated.
void ad9434_init()
	uint8_t reg_write_status;
	ctx = iio_create_local_context();
	if( ctx != NULL )
		printf(" iio_create_local_passed\n ");
	count = iio_context_get_devices_count( ctx );
	printf(" Dev count : %d\n",count );
	/* ad9517 configuration */
	ad9517 = iio_context_find_device( ctx ,"ad9517-4" );
	if( NULL != ad9517 )
		printf(" sucessfully ad9517 dev structure\n");
	else
		printf( " Failed ad9517 dev structure \n");
	reg_write_status=iio_device_reg_write( ad9517,0x000,0x3c );
	reg_write_status=iio_device_reg_write( ad9517,0x232,0x01 );
	reg_write_status=iio_device_reg_write( ad9517,0x000,0x18 );
	if( 0 != reg_write_status)
		printf(" ad9517 configuration error \n");
	else
		printf(" ad9517 configuration success\n");
	/* ad9434 configuration */
	ad9434 = iio_context_find_device( ctx ,"axi-ad9434-core-lpc" );
	if( NULL != ad9434 )
		printf(" sucessfully ad9434 dev structure\n");
	else
		printf( " Failed ad9434 dev structure \n");
	reg_write_status = iio_device_reg_write( ad9434,0x14,0 );
	reg_write_status = iio_device_reg_write( ad9434,0x0d,0 );
	reg_write_status = iio_device_reg_write( ad9434,0xFF,0x01);
	if( 0 != reg_write_status )
		printf(" ad9434 configuration error \n");
	else
		printf(" ad9434 configuration success\n");
 root_value Func : get_shot_config :: Oh no its NULL ad9517 & ad9434 initializat
  Dev count : 3
reg_write_status of reg 0x00 0x3c 254
reg_write_status of reg 0x232 0x01 254
reg_write_status of reg 0x0 0x018 254
U-Boot 2022.01 (Sep 25 2024 - 08:40:58 +0000)
CPU:   Zynq 7z020
Silicon: v3.1
Model: Xilinx Zynq Zc702
DRAM:  ECC disabled 1 GiB
Flash: 0 Bytes
NAND:  0 MiB
MMC:   mmc@e0100000: 0
Loading Environment from FAT... *** Error - No Valid Environment Area found
*** Warning - bad env area, using default environment
In:    serial@e0001000
Out:   serial@e0001000
Err:   serial@e0001000
Net:
ZYNQ GEM: e000b000, mdio bus e000b000, phyaddr 7, interface rgmii-id
zynq_gem ethernet@e000b000: Failed to read eth PHY id, err: -2
eth0: ethernet@e000b000
Hit any key to stop autoboot:  2  1  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
2776 bytes read in 13 ms (208 KiB/s)
## Executing script at 03000000
Trying to load boot images from mmc0
19440112 bytes read in 1378 ms (13.5 MiB/s)
## Loading kernel from FIT Image at 10000000 ...
   Using 'conf-system-top.dtb' configuration
   Verifying Hash Integrity ... OK
   Trying 'kernel-1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x100000ec
     Data Size:    5382048 Bytes = 5.1 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x00200000
     Entry Point:  0x00200000
     Hash algo:    sha256
     Hash value:   5395e794c6ad254ed2e3bf357a0e4d30a15ed053195b75faa474078d9a879515
   Verifying Hash Integrity ... sha256+ OK
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk-1' ramdisk subimage
     Description:  petalinux-image-minimal
     Type:         RAMDisk Image
     Data Start:   0x105279f8
     Data Size:    14033538 Bytes = 13.4 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha256
     Hash value:   6f0ee6da35682b2caffb2ebd0de5aeba2f8263790577d31c213faccb49e42cae
## Loading fdt from FIT Image at 10000000 ...
   Trying 'fdt-system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x10522198
     Data Size:    22420 Bytes = 21.9 KiB
     Architecture: ARM
     Hash algo:    sha256
     Hash value:   e4eb50ae0222fdb17696c84fe5bc479aab061080c6fe58de695bea36dc63fe2f
   Booting using the fdt blob at 0x10522198
   Loading Kernel Image
   Loading Ramdisk to 2f29d000, end 2ffff282 ... OK
   Loading Device Tree to 2f294000, end 2f29c793 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.15.0-xilinx-v2022.1 (oe-user@oe-host) (arm-xilinx-linux-gnueabi-gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.37.20210721) #1 SMP PREEMPT Mon Dec 20 02:57:12 UTC 2021
[    0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Xilinx Zynq Zc702
[    0.000000] earlycon: cdns0 at MMIO 0xe0001000 (options '115200n8')
[    0.000000] printk: bootconsole [cdns0] enabled
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 16 MiB at 0x3f000000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000000000000-0x000000002fffffff]
[    0.000000]   HighMem  [mem 0x0000000030000000-0x000000003fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000003fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003fffffff]
[    0.000000] percpu: Embedded 12 pages/cpu s16588 r8192 d24372 u49152
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260608
[    0.000000] Kernel command line: console=ttyPS0,115200 earlycon root=/dev/ram0 rw
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 991328K/1048576K available (8192K kernel code, 662K rwdata, 6056K rodata, 1024K init, 436K bss, 40864K reserved, 16384K cma-reserved, 245760K highmem)
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] efuse mapped to (ptrval)
[    0.000000] slcr mapped to (ptrval)
[    0.000000] GIC physical location is 0xf8f01000
[    0.000000] L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
[    0.000000] L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
[    0.000000] L2C-310 erratum 769419 enabled
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[    0.000000] L2C-310 ID prefetch enabled, offset 1 lines
[    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[    0.000000] L2C-310 cache controller enabled, 8 ways, 512 kB
[    0.000000] L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
[    0.000000] random: get_random_bytes called from start_kernel+0x364/0x5d0 with crng_init=0
[    0.000000] zynq_clock_init: clkc starts at (ptrval)
[    0.000000] Zynq clock init
[    0.000001] sched_clock: 64 bits at 166MHz, resolution 6ns, wraps every 4398046511103ns
[    0.005517] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x26703d7dd8, max_idle_ns: 440795208065 ns
[    0.016452] Switching to timer-based delay loop, resolution 6ns
[    0.022385] clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
[    0.031339] timer #0 at (ptrval), irq=25
[    0.035977] Console: colour dummy device 80x30
[    0.039602] Calibrating delay loop (skipped), value calculated using timer frequency.. 333.33 BogoMIPS (lpj=1666666)
[    0.049987] pid_max: default: 32768 minimum: 301
[    0.054739] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.061773] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.070186] CPU: Testing write buffer coherency: ok
[    0.074226] CPU0: Spectre v2: using BPIALL workaround
[    0.079411] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.085534] Setting up static identity map for 0x100000 - 0x100060
[    0.091061] rcu: Hierarchical SRCU implementation.
[    0.096019] smp: Bringing up secondary CPUs ...
[    0.100966] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.100987] CPU1: Spectre v2: using BPIALL workaround
[    0.110818] smp: Brought up 1 node, 2 CPUs
[    0.114732] SMP: Total of 2 processors activated (666.66 BogoMIPS).
[    0.120968] CPU: All CPU(s) started in SVC mode.
[    0.126138] devtmpfs: initialized
[    0.133774] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.136587] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.146073] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.153668] pinctrl core: initialized pinctrl subsystem
[    0.158759] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.166146] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.171730] thermal_sys: Registered thermal governor 'step_wise'
[    0.171885] cpuidle: using governor menu
[    0.191734] amba f8801000.etb: Fixing up cyclic dependency with replicator
[    0.193376] amba f8803000.tpiu: Fixing up cyclic dependency with replicator
[    0.200299] amba f8804000.funnel: Fixing up cyclic dependency with replicator
[    0.207342] amba f889c000.ptm: Fixing up cyclic dependency with f8804000.funnel
[    0.214527] amba f889d000.ptm: Fixing up cyclic dependency with f8804000.funnel
[    0.223791] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.229282] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.235579] e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 35, base_baud = 3125000) is a xuartps
[    0.249602] printk: console [ttyPS0] enabled
[    0.253893] printk: bootconsole [cdns0] disabled
[    0.274439] vgaarb: loaded
[    0.277542] SCSI subsystem initialized
[    0.281527] usbcore: registered new interface driver usbfs
[    0.287096] usbcore: registered new interface driver hub
[    0.292448] usbcore: registered new device driver usb
[    0.297652] mc: Linux media interface: v0.10
[    0.301952] videodev: Linux video capture interface: v2.00
[    0.307501] pps_core: LinuxPPS API ver. 1 registered
[    0.312462] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.321620] PTP clock support registered
[    0.325604] EDAC MC: Ver: 3.0.0
[    0.329210] FPGA manager framework
[    0.332943] Advanced Linux Sound Architecture Driver Initialized.
[    0.340090] clocksource: Switched to clocksource arm_global_timer
[    0.356825] NET: Registered PF_INET protocol family
[    0.361938] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.370761] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.379209] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.387056] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.394362] TCP: Hash tables configured (established 8192 bind 8192)
[    0.400865] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.407520] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.414836] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.421136] RPC: Registered named UNIX socket transport module.
[    0.427056] RPC: Registered udp transport module.
[    0.431792] RPC: Registered tcp transport module.
[    0.436490] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.442969] PCI: CLS 0 bytes, default 64
[    0.447219] armv7-pmu f8891000.pmu: hw perfevents: no interrupt-affinity property, guessing.
[    0.447302] Trying to unpack rootfs image as initramfs...
[    0.461110] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[    0.470816] workingset: timestamp_bits=30 max_order=18 bucket_order=0
[    0.478356] jffs2: version 2.2. (NAND) (SUMMARY)  � 2001-2006 Red Hat, Inc.
[    0.485882] bounce: pool size: 64 pages
[    0.489741] io scheduler mq-deadline registered
[    0.494329] io scheduler kyber registered
[    0.499558] zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
[    0.521022] dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
[    0.527739] dma-pl330 f8003000.dmac: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
[    0.558901] brd: module loaded
[    0.567079] loop: module loaded
[    0.573924] spi_master spi0: cannot find modalias for /axi/spi@e000d000/flash@0
[    0.581370] spi_master spi0: Failed to create SPI device for /axi/spi@e000d000/flash@0
[    0.590241] libphy: Fixed MDIO Bus: probed
[    0.595701] CAN device driver interface
[    0.600563] xilinx_can e0008000.can can0: TDC Offset value not in range
[    0.609214] libphy: MACB_mii_bus: probed
[    1.677698] Freeing initrd memory: 13708K
[    1.693007] macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 39 (00:0a:35:00:1e:53)
[    1.703335] e1000e: Intel(R) PRO/1000 Network Driver
[    1.708293] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.714889] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.721472] ehci-pci: EHCI PCI platform driver
[    1.726026] usbcore: registered new interface driver usb-storage
[    1.741031] ULPI transceiver vendor/product ID 0x0424/0x0007
[    1.746694] Found SMSC USB3320 ULPI transceiver.
[    1.751352] ULPI integrity check: passed.
[    1.757624] i2c_dev: i2c /dev entries driver
[    1.762572] cdns-i2c e0004000.i2c: 400 kHz mmio e0004000 irq 32
[    1.771440] cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer with timeout 10s
[    1.779034] EDAC MC: ECC not enabled
[    1.782830] Xilinx Zynq CpuIdle Driver started
[    1.787771] sdhci: Secure Digital Host Controller Interface driver
[    1.793970] sdhci: Copyright(c) Pierre Ossman
[    1.798322] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.804713] ledtrig-cpu: registered to indicate activity on CPUs
[    1.810966] usbcore: registered new interface driver usbhid
[    1.816541] usbhid: USB HID core driver
[    1.830153] mmc0: SDHCI controller on e0100000.mmc [e0100000.mmc] using ADMA
[    1.838450] ad9517 spi1.1: AD9517 successfully initialized
[    1.846977] fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
[    1.855063] NET: Registered PF_INET6 protocol family
[    1.861466] Segment Routing with IPv6
[    1.865166] In-situ OAM (IOAM) with IPv6
[    1.869187] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.875931] NET: Registered PF_PACKET protocol family
[    1.881023] can: controller area network core
[    1.885431] NET: Registered PF_CAN protocol family
[    1.890240] can: raw protocol
[    1.893208] can: broadcast manager protocol
[    1.897397] can: netlink gateway - max_hops=1
[    1.902113] zynq_pm_remap_ocm: no compatible node found for 'mmio-sram'
[    1.908731] zynq_pm_suspend_init: Unable to map OCM.
[    1.913731] Registering SWP/SWPB emulation handler
[    1.919097] of-fpga-region fpga-full: FPGA Region probed
[    2.010454] |
[    2.010464] -
[    2.012032] -
[    2.013602] -
[    2.015174] -
[    2.016773] -
[    2.018373] -
[    2.019965] -
[    2.021563] -
[    2.023133] -
[    2.024704] -
[    2.026275] -
[    2.027846] -
[    2.029417] -
[    2.031029] -
[    2.032634] -
[    2.034235] -
[    2.035806] -
[    2.037377] -
[    2.038948] -
[    2.040536] -
[    2.042108] -
[    2.043679] -
[    2.045250] -
[    2.046848] -
[    2.048449] -
[    2.050041] -
[    2.051629] -
[    2.053201] -
[    2.054772] -
[    2.056343] -
[    2.057914] -
[    2.059485]
[    2.062577] -
[    2.062583] -
[    2.064185] -
[    2.065778] -
[    2.067349] -
[    2.068920] -
[    2.070509] -
[    2.072080] -
[    2.073651] -
[    2.075222] -
[    2.076793] -
[    2.078392] -
[    2.079992] -
[    2.081609] -
[    2.083182] -
[    2.084752] -
[    2.086323] -
[    2.087895] -
[    2.089466] -
[    2.091053] -
[    2.092625] -
[    2.094224] -
[    2.095824] -
[    2.097416] -
[    2.098988] -
[    2.100661] -
[    2.102234] -
[    2.103805] -
[    2.105376] -
[    2.106947] -
[    2.108518] -
[    2.110129] -
[    2.111736]   IDELAY 0x0
[    2.116619] cf_axi_adc 44a00000.axi-ad9434-core-lpc: ADI AIM (0.00.) at 0x44A00000 mapped to 0x(ptrval) probed ADC AD9434 as MASTER
[    2.128898] of_cfs_init
[    2.131397] of_cfs_init: OK
[    2.134526] ALSA device list:
[    2.137495]   No soundcards found.
[    2.144173] Freeing unused kernel image (initmem) memory: 1024K
[    2.150594] Run /init as init process
INIT: version 2.99 booting
[    2.255672] mmc0: new high speed SD card at address 3ff0
[    2.261818] mmcblk0: mmc0:3ff0 SD02G 1.92 GiB
[    2.269086]  mmcblk0: p1
Starting udev
Starting version 249.7+
[    2.861120] random: fast init done
[    4.162447] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
bootlogd: /dev/ttyPS0hwclock: can't open '/dev/misc/rtc': No such file or directory
Fri Mar  9 12:34:56 UTC 2018
[    5.134056] random: dd: uninitialized urandom read (512 bytes read)
Configuring packages on first boot....
 (This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
 Removing any system startup links for run-postinsts ...
  /etc/rcS.d/S99run-postinsts
INIT: Entering runlevel: 5
Configuring network interfaces... [    6.240311] macb e000b000.ethernet eth0: PHY [e000b000.ethernet-ffffffff:07] driver [Marvell 88E1116R] (irq=POLL)
[    6.250615] macb e000b000.ethernet eth0: configuring for phy/rgmii-id link mode
done.
[    6.327876] random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
[    6.335048] random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
Starting system message bus: [    6.359274] random: dbus-daemon: uninitialized urandom read (12 bytes read)
dbus.
Starting haveged: haveged: command socket is listening at fd 3
haveged: haveged starting up
[  OK  ]
Starting Dropbear SSH server: Waiting for kernel randomness to be initialised...
haveged: haveged: ver: 1.9.14; arch: generic; vend: ; build: (gcc 11.2.0 CTV); collect: 128K
haveged: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 12/40; sz: 15126/57786
haveged: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 8.00244
haveged: haveged: fills: 0, generated: 0
[    8.759553] random: crng init done
[    8.763066] random: 1 urandom warning(s) missed due to ratelimiting
Generating 2048 bit rsa key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCG5UAaJ6sHXPSv2W0zdc5DhgEd2Xk7J9QkJo1c8Yqle2AG4hYwdCv1cU64WDlB9cKBXHybDhp3gOKmtlXxjpHv3PcExDhNYQ2NO9IK9tH7aidAOD7wSllHxEY/xJ9pUG/IpaL+Be8AGUCJ5bd5BE1QENpMKTJaFflo1qUcde0+hEWQjvlU4g4qkMt0eg5KGU4Aw7H+BxLoflm23h+ZL+H4yc+tNPN4j0MvOzDP3rsOZWXGLQXRXI4+ttPNRhLpJ837jdRsNbAerXc2iMyVishG09jVWdFAz373sy5pU4u8KFVl2GsurR0tnpOCB57p3/L+G7UjiOuZ++9/DvY7+oo9 root@gen4
Fingerprint: sha1!! 52:be:95:94:2f:f8:97:5b:43:22:1a:0f:7d:c9:cc:d2:50:db:b0:14
dropbear.
Starting rpcbind daemon...done.
starting statd: done
Starting internet superserver: inetd.
NFS daemon support not enabled in kernel
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2022.1_release_S04190222 gen4 /dev/ttyPS0
gen4 login: root
Password:
Login incorrect
gen4 login: root
Password:
Login incorrect
gen4 login: root
Password:
Login incorrect
gen4 login: petalinux
You are required to change your password immediately (administrator enforced).
New password:
Retype new password:
gen4:~$ sudo fiber
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
Password:
 root_value Func : get_shot_config :: Oh no its NULL ad9517 & ad9434 initialization
  Dev count : 4
Num of channels : 1
 Channel is input
 Channel is enable
 Buffer is created successfully
 Ethernet initialization
Socket creation success
 Bind success
 Client Connected :192.168.1.100 : 5001
HSSD System Initialization Complete.
Firmware Version:  0. 2
FPGA Technology : 1000000
FPGA Family     : 40000
Speed Grade     : a00
Dev Package     : e
Disabled auto tuning node-wall positions.
Default node-wall positions are used.
/include/ "system-conf.dtsi"
/delete-node/ &axi_ad9434;
/delete-node/ &axi_ad9434_dma;
/delete-node/ &misc_clk_0;
        interrupt-parent = <0x4>;
        model = "Xilinx Zynq Zc702";
	clocks {
			ad9517_ref_clk: clock@0 {
					compatible = "fixed-clock";
					clock-frequency = <500000000>;
					clock-output-names = "ad9517_refclk";
					#clock-cells = <0>;
&amba_pl {
                rx_dma: rx-dmac@44a30000 {
                compatible = "adi,axi-dmac-1.00.a";
                reg = <0x44a30000 0x10000>;
                #dma-cells = <1>;
                interrupts = <0 57 4>; /* 57 */
                clocks = <&clkc 16>;
                adi,channels {
                        #size-cells = <0>;
                        #address-cells = <1>;
                        dma-channel@0 {
                                reg = <0>;
                                adi,source-bus-width = <64>;
                                adi,source-bus-type = <2>;
                                adi,destination-bus-width = <64>;
                                adi,destination-bus-type = <0>;
        axi_ad9434_core_0: axi-ad9434-core-lpc@44a00000 {
                compatible = "xlnx,axi-ad9434-1.00.a";
                reg = <0x44a00000 0x10000>;
                dmas = <&rx_dma 0>;
                dma-names = "rx";
                spibus-connected = <&adc_ad9434>;
&spi0 {
        status = "okay";
        adc_ad9434: ad9434@0 {
		compatible = "adi,ad9434";
		reg = <0>;
		spi-max-frequency = <10000000>;
		adi,spi-3wire-enable;
		clocks = <&clk_ad9517 3>;
		clock-names = "adc_clk";
	clk_ad9517: ad9517@1 {
		compatible = "adi,ad9517-4";
		reg = <1>;
		clocks = <&ad9517_ref_clk>, <&ad9517_ref_clk>;
		clock-names = "refclk", "clkin";
		clock-output-names = "out0", "out1", "out2", "out3", "out4", "out5", "out6", "out7";
		#clock-cells = <1>;
		firmware = "ad9467_intbypass_ad9517.stp";
&gem0 {
              status = "okay";
              phy-handle = <&ethernet_phy>;
              phy-mode = "rgmii-id";
              ethernet_phy: ethernet-phy@7{
                             reg =<7>;
