MAX98390 Linux Driver with Alsa
The user encountered an error with the MAX98390C amplifier on an NXP i.MX8MP SOM, where the SAI interface failed to derive the required Tx rate of 1411200 Hz. The issue was resolved by setting the MCLK rate to 22579200 Hz and using IMX8MP_AUDIO_PLL2_OUT as the clock parent in the device tree configuration.
Product Number: 98390C
I am using Max98390C amplifier with speaker in our device having NXP IMX8MP SOM. I am able to play songs using the MAX98390 Development Board. But when I play the audio files in the device using aplay, I am getting the following errors:
[15666.371878] fsl-sai 30c10000.sai: failed to derive required Tx rate: 1411200
[15666.378977] fsl-sai 30c10000.sai: ASoC: error at snd_soc_dai_hw_params on 30c10000.sai: -22
[15666.387360] 30c10000.sai-max98390-aif1: ASoC: error at __soc_pcm_hw_params on 30c10000.sai-max98390-aif1: -22
ALSA lib /usr/src/debug/alsa-lib/1.2.8-r0/src/pcm/pcm_direct.c:1336:(snd1_pcm_direct_initialize_slave) unable to install hw params
ALSA lib /usr/src/debug/alsa-lib/1.2.8-r0/src/pcm/pcm_dmix.c:1011:(snd_pcm_dmix_open) unable to initialize slave
aplay: main:831: audio open error: Invalid argument
speaker-test also outputs the same error.
Below are the dts nodes:
sound {
compatible = "simple-audio-card";
pinctrl-names = "default";
simple-audio-card,name = "max98390-audio-card";
simple-audio-card,format = "i2s";
/*simple-audio-card,widgets = "Speaker", "Speaker";
simple-audio-card,routing = "Speaker", "Speaker";*/
simple-audio-card,bitclock-master = <&cpu_dai>;
simple-audio-card,frame-master = <&cpu_dai>;
/*simple-audio-card,mclk-fs = <256>;*/
status = "okay";
cpu_dai: simple-audio-card,cpu {
sound-dai = <&sai1>;
dai-tdm-slot-num = <2>;
dai-tdm-slot-width = <16>;
simple-audio-card,codec {
sound-dai = <&max98390>;
&sai1 {
#sound-dai-cells = <0>;
pinctrl-0 = <&pinctrl_sai1>;
assigned-clocks = <&clk IMX8MP_CLK_SAI1>;
assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL1_OUT>;
assigned-clock-rates = <24576000>;
clocks = <&audio_blk_ctrl IMX8MP_CLK_AUDIO_BLK_CTRL_SAI1_IPG>, <&clk IMX8MP_CLK_DUMMY>,
<&audio_blk_ctrl IMX8MP_CLK_AUDIO_BLK_CTRL_SAI1_MCLK1>, <&clk IMX8MP_CLK_DUMMY>,
<&clk IMX8MP_CLK_DUMMY>;
clock-names = "bus", "mclk0", "mclk1", "mclk2", "mclk3";
/*assigned-clock-rates = <0>, <786432000>, <49152000>, <12288000>, <49152000>;*/
fsl,mode = "i2s-master";
fsl,sai-mclk-direction-output;
status = "okay";
&i2c3 {
clock-frequency = <400000>;
pinctrl-names = "default", "gpio";
pinctrl-0 = <&pinctrl_i2c3>;
pinctrl-1 = <&pinctrl_i2c3_gpio>;
scl-gpios = <&gpio5 18 GPIO_ACTIVE_HIGH>;
sda-gpios = <&gpio5 19 GPIO_ACTIVE_HIGH>;
status = "okay";
max98390: amplifier@38 {
compatible = "maxim,max98390";
reg = <0x38>;
maxim,temperature_calib = <1024>;
maxim,r0_calib = <100232>;
reset-gpios = <&gpio4 21 GPIO_ACTIVE_LOW>;
status = "okay";
pinctrl_sai1: sai1grp {
fsl,pins = <
MX8MP_IOMUXC_SAI1_RXD7__AUDIOMIX_SAI1_TX_SYNC 0xd6
MX8MP_IOMUXC_SAI1_TXC__AUDIOMIX_SAI1_TX_BCLK 0xd6
MX8MP_IOMUXC_SAI1_TXD0__AUDIOMIX_SAI1_TX_DATA00 0xd6
Someone please help me to fix this issue?
Thanks
Chris
  • The problem is : failed to derive required Tx rate: 1411200
    and is coming from this line in NXP sai drivers.
    It looks like you're configuring the I2S interface in device-tree for dai-tdm-slot-num = <2>; dai-tdm-slot-width = <16>;
    If the audio file you're trying to play has a sampling rate of 44100 Hz then 2*16*44100 = 1411200 Hz exactly the bit-rate you're requesting to the SAI interface but it is not able to obtain.
    I think it is not able to obtain it because it requires integer division from the 24576000 Hz MCLK rate you're setting in &sai1 node.
    So you either use audio files with 48Khz sample rate and in that case 2*16*48000 = 1536000 * 16 = 24576000 Hz or you set in &sai1 node the MCLK to some multiple of 44100 Hz like 22579200 Hz.
    Bogdan
  • Hi Bogdan,
    Thank you for your reply.
    I changed the assigned-clock-rates = <24576000>;
    &sai1 {
    status = "okay";
    But still, I am having the same issue. But I noticed that there is no soundcard.
    # aplay test.wav
    [ 314.624387] fsl-sai 30c10000.sai: failed to derive required Tx rate: 1411200
    [ 314.631463] fsl-sai 30c10000.sai: ASoC: error at snd_soc_dai_hw_params on 30c10000.sai: -22
    [ 314.639834] 30c10000.sai-max98390-aif1: ASoC: error at __soc_pcm_hw_params on 30c10000.sai-max98390-aif1: -22
    # dmesg | grep -E "fsl|sound|snd"
    [ 2.807525] No soundcards found.
    Thanks
    Chris
    Take this as reference. Is a limitation of the SAI.
    I was suggesting to replace
    with
    assigned-clock-rates = <22579200>;
    but I think you may need to use PLL2 for 44.1Khz sampling rates. Better ask on NXP forum for exact solution.
  • Hi Bogdan,
    IMX8MP_AUDIO_PLL2_OUT and 22579200 fixed the issue. I am having sound now. Thank you so much for your help.
    &sai1 {
    assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL2_OUT>;
    status = "okay";
    Thanks
    Chris
