KCC's Quizzes AQQ306 about a fish stick challenge
1. First the quote of the month: " I am so clever that sometimes I don't understand a single word of what I am saying" - Oscar Wilde
2. New quiz AQQ306 about a fish stick challenge:
Here below is a pseudo fish diagram swimming to the right.
Question
November Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Ever wonder how EMC limits came to be and why they matter? Dive into the interesting bits of EMC limits and levels, then test your knowledge with EMC: The Interesting Bits Quiz.
Read the blog first: EMC Limits and Levels Explained: Well, the Interesting
ADRV9002
Recommended for New Designs
The ADRV9002 is a highly integrated RF transceiver that has dual-channel transmitters, dual-channel receivers, integrated synthesizers, and digital signal...
Datasheet
ADRV9002 on Analog.com
I have successfully generated .json (profie) from TES(Transceiver Elevation Software) with (MCS enabled RFPLL phase) and upload on IIO.
I have set MCS settings and it successfully done the multi_chip_sync
I have changed the Rx/TX ENSM to rf_enabled mode and Reload Settigs
The ILA result of my external loop Tx1 to Rx1
The Rx signal (I and Q) has some phase offset even my MCS is enabled.
I was expecting Rx signal with zero phase offset.
Is it possible to achieve external loopback signal with zero phase offset with MCS for this transceiver (ADRV9002)?
We sincerely apologize for the delay in our response. If the question is still of interest, the first thing I would recommend is updating to our latest kernel and hdl, there have been multiple improvements made to the 9002, including some related to mcs_sync
Please let me know the latest version of kernal an HDL.
currently I am using Vivado 2021.2, hdl_2021_r2 Kernal release 2021_R1
The latest hdl release is hdl_2023_r2 https://github.com/analogdevicesinc/hdl/releases, however I think it requires upgrading vivado to 2023.2 as well. The latest kernel release branch is also 2023_R2 https://github.com/analogdevicesinc/linux/tree/2023_R2.
But you could also use the main branches from each repository:
https://github.com/analogdevicesinc/linux/tree/main
Ramona
Thank you rnechita I will let you know once I test with these latest versions.
