Problem with AD-FMCOMMS2-EBZ on ZedBoard : Unable to write attribute / Runtime Error
I downloaded the prebuilt image "2022_r2 Patch 1" from Analog Devices and booted the ZedBoard  using the default BIN file. After connecting the AD-FMCOMMS2-EBZ to the ZedBoard , i encountered a runtime error when running GRC (GNU Radio Companion) in standalone mode. However, I could successfully run in "IIO Oscilloscope".
Error message when connected with GRC is given below
Executing: /usr/bin/python3 -u /home/analog/jdefault.py
Parsing /proc/self/auxv to extract ELF hwcaps!
Unable to write attribute out_altvoltage0_RX_LO_frequency: -13
Unable to write attribute in_voltage_rf_bandwidth: -13
Unable to write attribute in_voltage_quadrature_tracking_en: -13
Unable to write attribute in_voltage_rf_dc_offset_tracking_en: -13
Unable to write attribute in_voltage_bb_dc_offset_tracking_en: -13
Unable to write attribute in_voltage0_gain_control_mode: -13
Unable to write attribute in_voltage0_hardwaregain: -13
Unable to write attribute in_voltage1_gain_control_mode: -13
Unable to write attribute in_voltage1_hardwaregain: -13
Unable to write attribute in_voltage0_rf_port_select: -13
Traceback (most recent call last):
  File "/home/analog/jdefault.py", line 176, in <module>
    main()
  File "/home/analog/jdefault.py", line 152, in main
    tb = top_block_cls()
  File "/home/analog/jdefault.py", line 119, in __init__
    self.iio_fmcomms2_source_0 = iio.fmcomms2_source_f32c('local:', 101900000, 2084000, 20000000, False, True, 32768, True, True, True, 'manual', 64, 'manual', 64, 'A_BALANCED', '', True)
  File "/usr/local/lib/python3/dist-packages/iio/iio_swig.py", line 199, in make
    return _iio_swig.fmcomms2_source_f32c_make(*args, **kwargs)
RuntimeError: Unable to set BB rate
>>> Done (return code 1)
Test setup file of GRC is also attached
options:
  parameters:
    author: analog
    category: '[GRC Hier Blocks]'
    cmake_opt: ''
    comment: ''
    copyright: ''
    description: ''
    gen_cmake: 'On'
    gen_linking: dynamic
    generate_options: qt_gui
    hier_block_src_path: '.:'
    max_nouts: '0'
    output_language: python
    placement: (0,0)
    qt_qss_theme: ''
    realtime_scheduling: ''
    run: 'True'
    run_command: '{python} -u {filename}'
    run_options: prompt
    sizing_mode: fixed
    thread_safe_setters: ''
    title: Not titled yet
    window_size: ''
  states:
    bus_sink: false
    bus_source: false
    bus_structure: null
    coordinate: [8, 8]
    rotation: 0
    state: enabled
blocks:
- name: samp_rate
  parameters:
    comment: ''
    value: '32000'
  states:
    bus_sink: false
    bus_source: false
    bus_structure: null
    coordinate: [184, 12]
    rotation: 0
    state: enabled
- name: iio_fmcomms2_source_0
  parameters:
    affinity: ''
    alias: ''
    auto_filter: 'True'
    bandwidth: '20000000'
    bbdc: 'True'
    buffer_size: '32768'
    comment: ''
    filter: ''
    frequency: '101900000'
    gain1: '''manual'''
    gain2: '''manual'''
    manual_gain1: '64'
    manual_gain2: '64'
    maxoutbuf: '0'
    minoutbuf: '0'
    quadrature: 'True'
    rf_port_select: '''A_BALANCED'''
    rfdc: 'True'
    rx1_en: 'False'
    rx2_en: 'True'
    samplerate: '2084000'
    uri: 'local:'
  states:
    bus_sink: false
    bus_source: false
    bus_structure: null
    coordinate: [160, 236.0]
    rotation: 0
    state: true
- name: qtgui_freq_sink_x_0
  parameters:
    affinity: ''
    alias: ''
    alpha1: '1.0'
    alpha10: '1.0'
    alpha2: '1.0'
    alpha3: '1.0'
    alpha4: '1.0'
    alpha5: '1.0'
    alpha6: '1.0'
    alpha7: '1.0'
    alpha8: '1.0'
    alpha9: '1.0'
    autoscale: 'False'
    average: '1.0'
    axislabels: 'True'
    bw: samp_rate
    color1: '"blue"'
    color10: '"dark blue"'
    color2: '"red"'
    color3: '"green"'
    color4: '"black"'
    color5: '"cyan"'
    color6: '"magenta"'
    color7: '"yellow"'
    color8: '"dark red"'
    color9: '"dark green"'
    comment: ''
    ctrlpanel: 'False'
    fc: '0'
    fftsize: '1024'
    freqhalf: 'True'
    grid: 'False'
    gui_hint: ''
    label: Relative Gain
    label1: ''
    label10: ''''''
    label2: ''''''
    label3: ''''''
    label4: ''''''
    label5: ''''''
    label6: ''''''
    label7: ''''''
    label8: ''''''
    label9: ''''''
    legend: 'True'
    maxoutbuf: '0'
    minoutbuf: '0'
    nconnections: '1'
    showports: 'False'
    tr_chan: '0'
    tr_level: '0.0'
    tr_mode: qtgui.TRIG_MODE_FREE
    tr_tag: '""'
    type: complex
    units: dB
    update_time: '0.10'
    width1: '1'
    width10: '1'
    width2: '1'
    width3: '1'
    width4: '1'
    width5: '1'
    width6: '1'
    width7: '1'
    width8: '1'
    width9: '1'
    wintype: firdes.WIN_BLACKMAN_hARRIS
    ymax: '10'
    ymin: '-140'
  states:
    bus_sink: false
    bus_source: false
    bus_structure: null
    coordinate: [520, 312.0]
    rotation: 0
    state: true
connections:
- [iio_fmcomms2_source_0, '0', qtgui_freq_sink_x_0, '0']
metadata:
  file_format: 1
I launched GNU radio with linux command  'sudo' . Then I encountered a 'AttributeError'  when run GRC (GNU Radio Companion).
Error Message when GNU radio is launched by "sudo" linux command
<<< Welcome to GNU Radio Companion 3.8.2.0 >>>
Block paths:
    /usr/share/gnuradio/grc/blocks
    /usr/local/share/gnuradio/grc/blocks
Loading: "/home/analog/fmc.grc"
>>> Done
Generating: '/home/analog/jdefault.py'
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
    main()
    self.iio_fmcomms2_source_0 = iio.fmcomms2_source_f32c('local:', 101900000, 2084000, 20000000, False, True, 32768, True, True, True, 'manual', 64, 'manual', 64, 'A_BALANCED', '', False)
AttributeError: module 'iio' has no attribute 'fmcomms2_source_f32c'
If anyone has encountered a similar issue or knows a solution, please let me know.
Thanks
Regards!
