Hi
I want to transmit/receive data from my custom IP rather than zynqMP, but the project provide by adi is packaged to a block design, for convenience of observe internel signal, I take out the axi_adrv9001 core and wrapped it to a independent module, the original block design contain PS_8 and dma... were wrapped to a new system wrapper. The new system wrapper and new adrv9002 wrapper connected in system_top module, the new hierarchy is below:
I changed the boot.scr and loaded this bit at U-boot,but linux stucked as below:
Then I recompile the petalinux project and end with error which indicates device tree error. After compared the new pl.dtsi with original pl.dtsi
/* * CAUTION: This file is automatically generated by Xilinx. * Version: XSCT * Today is: Wed Jul 24 06:50:27 2024 */ / { amba_pl: amba_pl@0 { #address-cells = <2>; #size-cells = <2>; compatible = "simple-bus"; ranges ; axi_adrv9001: axi_adrv9001@84a00000 { clock-names = "delay_clk", "s_axi_aclk"; clocks = <&zynqmp_clk 73>, <&zynqmp_clk 71>; compatible = "xlnx,axi-adrv9001-1.0"; reg = <0x0 0x84a00000 0x0 0x10000>; }; axi_adrv9001_rx1_dma: axi_dmac@84a30000 { clock-names = "s_axi_aclk", "m_dest_axi_aclk", "fifo_wr_clk"; clocks = <&zynqmp_clk 71>, <&zynqmp_clk 71>, <&misc_clk_0>; compatible = "xlnx,axi-dmac-1.0"; interrupt-names = "irq"; interrupt-parent = <&gic>; interrupts = <0 109 4>; reg = <0x0 0x84a30000 0x0 0x1000>; }; misc_clk_0: misc_clk_0 { #clock-cells = <0>; clock-frequency = <100000000>; compatible = "fixed-clock"; }; axi_adrv9001_rx2_dma: axi_dmac@84a40000 { clock-names = "s_axi_aclk", "m_dest_axi_aclk", "fifo_wr_clk"; clocks = <&zynqmp_clk 71>, <&zynqmp_clk 71>, <&misc_clk_0>; compatible = "xlnx,axi-dmac-1.0"; interrupt-names = "irq"; interrupt-parent = <&gic>; interrupts = <0 108 4>; reg = <0x0 0x84a40000 0x0 0x1000>; }; axi_adrv9001_tx1_dma: axi_dmac@84a50000 { clock-names = "s_axi_aclk", "m_src_axi_aclk", "m_axis_aclk"; clocks = <&zynqmp_clk 71>, <&zynqmp_clk 71>, <&misc_clk_0>; compatible = "xlnx,axi-dmac-1.0"; interrupt-names = "irq"; interrupt-parent = <&gic>; interrupts = <0 105 4>; reg = <0x0 0x84a50000 0x0 0x1000>; }; axi_adrv9001_tx2_dma: axi_dmac@84a60000 { clock-names = "s_axi_aclk", "m_src_axi_aclk", "m_axis_aclk"; clocks = <&zynqmp_clk 71>, <&zynqmp_clk 71>, <&misc_clk_0>; compatible = "xlnx,axi-dmac-1.0"; interrupt-names = "irq"; interrupt-parent = <&gic>; interrupts = <0 106 4>; reg = <0x0 0x84a60000 0x0 0x1000>; }; axi_sysid_0: axi_sysid@85000000 { clock-names = "s_axi_aclk"; clocks = <&zynqmp_clk 71>; compatible = "xlnx,axi-sysid-1.0"; reg = <0x0 0x85000000 0x0 0x10000>; }; }; }; /include/ "pl-delete-nodes-zynqmp-zcu102-rev10-adrv9002.dtsi"
/* * CAUTION: This file is automatically generated by Xilinx. * Version: XSCT * Today is: Mon Jul 29 08:10:27 2024 */ / { amba_pl: amba_pl@0 { #address-cells = <2>; #size-cells = <2>; compatible = "simple-bus"; ranges ; axi_adrv9001_rx1_dma: axi_dmac@84a30000 { clock-names = "s_axi_aclk", "m_dest_axi_aclk", "fifo_wr_clk"; clocks = <&zynqmp_clk 71>, <&zynqmp_clk 71>, <&misc_clk_0>; compatible = "xlnx,axi-dmac-1.0"; interrupt-names = "irq"; interrupt-parent = <&gic>; interrupts = <0 109 4>; reg = <0x0 0x84a30000 0x0 0x1000>; }; misc_clk_0: misc_clk_0 { #clock-cells = <0>; clock-frequency = <100000000>; compatible = "fixed-clock"; }; axi_adrv9001_rx2_dma: axi_dmac@84a40000 { clock-names = "s_axi_aclk", "m_dest_axi_aclk", "fifo_wr_clk"; clocks = <&zynqmp_clk 71>, <&zynqmp_clk 71>, <&misc_clk_0>; compatible = "xlnx,axi-dmac-1.0"; interrupt-names = "irq"; interrupt-parent = <&gic>; interrupts = <0 108 4>; reg = <0x0 0x84a40000 0x0 0x1000>; }; axi_adrv9001_tx1_dma: axi_dmac@84a50000 { clock-names = "s_axi_aclk", "m_src_axi_aclk", "m_axis_aclk"; clocks = <&zynqmp_clk 71>, <&zynqmp_clk 71>, <&misc_clk_0>; compatible = "xlnx,axi-dmac-1.0"; interrupt-names = "irq"; interrupt-parent = <&gic>; interrupts = <0 105 4>; reg = <0x0 0x84a50000 0x0 0x1000>; }; axi_adrv9001_tx2_dma: axi_dmac@84a60000 { clock-names = "s_axi_aclk", "m_src_axi_aclk", "m_axis_aclk"; clocks = <&zynqmp_clk 71>, <&zynqmp_clk 71>, <&misc_clk_0>; compatible = "xlnx,axi-dmac-1.0"; interrupt-names = "irq"; interrupt-parent = <&gic>; interrupts = <0 106 4>; reg = <0x0 0x84a60000 0x0 0x1000>; }; axi_sysid_0: axi_sysid@85000000 { clock-names = "s_axi_aclk"; clocks = <&zynqmp_clk 71>; compatible = "xlnx,axi-sysid-1.0"; reg = <0x0 0x85000000 0x0 0x10000>; }; }; }; /include/ "pl-delete-nodes-hzg-custom-adrv9002.dtsi"
So I followed the step in https://github.com/analogdevicesinc/meta-adi/tree/2022_R2/meta-adi-xilinx#adding-a-new-devicetree.
1. create a new .dts named hzg-custom-adrv9002.dts and new .dtsi file named pl-delete-nodes-hzg-custom-adrv9002.dtsi and put them in /meta-adi-2022-R2/meta-adi-xilinx-recipes-bsp/device-tree/files/
hzg-custom-adrv9002.dts :
// SPDX-License-Identifier: GPL-2.0
* Analog Devices ADRV9002
* hdl_project: <adrv9001/zcu102>
* board_revision: <>
* Copyright (C) 2020 Analog Devices Inc.
#include "zynqmp-zcu102-rev1.0.dts"
#include <dt-bindings/interrupt-controller/irq.h>
#include <dt-bindings/gpio/gpio.h>
&i2c1 {
i2c-mux@75 {
i2c@0 { /* HPC0 */
#address-cells = <1>;
#size-cells = <0>;
reg = <0>;
/* HPC0_IIC */
eeprom@50 {
compatible = "at24,24c02";
reg = <0x50>;
fpga_axi {
#address-cells = <0x1>;
#size-cells = <0x1>;
ranges = <0 0 0 0xffffffff>;
rx1_dma: dma@84A30000 {
compatible = "adi,axi-dmac-1.00.a";
reg = <0x84A30000 0x10000>;
#dma-cells = <1>;
interrupts = <0 109 IRQ_TYPE_LEVEL_HIGH>;
adi,channels {
#size-cells = <0>;
dma-channel@0 {
reg = <0>;
adi,source-bus-width = <64>;
adi,source-bus-type = <2>;
adi,destination-bus-width = <64>;
adi,destination-bus-type = <0>;
rx2_dma: dma@84A40000 {
reg = <0x84A40000 0x10000>;
#dma-cells = <1>;
interrupts = <0 108 IRQ_TYPE_LEVEL_HIGH>;
adi,channels {
#size-cells = <0>;
dma-channel@0 {
reg = <0>;
tx1_dma: dma@84A50000 {
reg = <0x84A50000 0x10000>;
#dma-cells = <1>;
interrupts = <0 105 IRQ_TYPE_LEVEL_HIGH>;
adi,channels {
#size-cells = <0>;
dma-channel@0 {
reg = <0>;
adi,source-bus-type = <0>;
adi,destination-bus-type = <2>;
tx2_dma: dma@84A6000 {
reg = <0x84A60000 0x10000>;
#dma-cells = <1>;
interrupts = <0 106 IRQ_TYPE_LEVEL_HIGH>;
adi,channels {
#size-cells = <0>;
dma-channel@0 {
reg = <0>;
axi_adrv9002_core_rx1: axi-adrv9002-rx-lpc@84A00000 {
compatible = "adi,axi-adrv9002-rx-1.0";
reg = <0x84A00000 0x6000>;
clocks = <&adc0_adrv9002 0>;
dmas = <&rx1_dma 0>;
dma-names = "rx";
spibus-connected = <&adc0_adrv9002>;
axi_adrv9002_core_tx1: axi-adrv9002-tx-lpc@84A04000 {
compatible = "adi,axi-adrv9002-tx-1.0";
reg = <0x84A0A000 0x2000>;
clocks = <&adc0_adrv9002 1>;
clock-names = "sampl_clk";
dmas = <&tx1_dma 0>;
dma-names = "tx";
adi,axi-dds-default-scale = <0x800>;
adi,axi-dds-default-frequency = <2000000>;
axi_adrv9002_core_tdd1: axi-adrv9002-core-tdd1-lpc@44A0C800 {
compatible = "adi,axi-tdd-1.00";
reg = <0x84A0C800 0x400>;
clocks = <&zynqmp_clk 71>, <&adc0_adrv9002 2>;
clock-names = "s_axi_aclk", "intf_clk";
label = "axi-core-tdd-1";
axi_adrv9002_core_rx2: axi-adrv9002-rx2-lpc@84A02000 {
compatible = "adi,axi-adrv9002-rx2-1.0";
reg = <0x84A09000 0x1000>;
clocks = <&adc0_adrv9002 3>;
dmas = <&rx2_dma 0>;
dma-names = "rx";
axi_adrv9002_core_tx2: axi-adrv9002-tx2-lpc@84A06000 {
reg = <0x84A0C000 0x2000>;
clocks = <&adc0_adrv9002 4>;
dmas = <&tx2_dma 0>;
dma-names = "tx";
axi_adrv9002_core_tdd2: axi-adrv9002-core-tdd2-lpc@44A0C800 {
reg = <0x84A0CC00 0x400>;
clocks = <&zynqmp_clk 71>, <&adc0_adrv9002 5>;
label = "axi-core-tdd-2";
axi_sysid_0: axi-sysid-0@85000000 {
compatible = "adi,axi-sysid-1.00.a";
reg = <0x85000000 0x10000>;
&spi0 {
status = "okay";
#define fmc_spi spi0
#include "adi-adrv9002.dtsi"
Name HDL Linux
ssi_sync 54 132
mcs 53 131
output_enable 52 130
tx2_enable 51 129
tx1_enable 50 128
rx2_enable 49 127
rx1_enable 48 126
sm_fan_tach 47 125
reset_trx 46 124
mode 45 123
gp_int 44 122
dgpio_11 43 121
dgpio_10 42 120
dgpio_9 41 119
dgpio_8 40 118
dgpio_7 39 117
dgpio_6 38 116
dgpio_5 37 115
dgpio_4 36 114
dgpio_3 35 113
dgpio_2 34 112
dgpio_1 33 111
dgpio_0 32 110
&adc0_adrv9002 {
reset-gpios = <&gpio 124 GPIO_ACTIVE_LOW>;
pl-delete-nodes-hzg-custom-adrv9002.dtsi:
/delete-node/ &axi_adrv9001_rx1_dma;
/delete-node/ &misc_clk_0;
/delete-node/ &axi_adrv9001_rx2_dma;
/delete-node/ &axi_adrv9001_tx1_dma;
/delete-node/ &axi_adrv9001_tx2_dma;
/delete-node/ &axi_sysid_0;
2. change /meta-adi-2022-R2/meta-adi-xilinx-recipes-bsp/device-tree/device-tree.bbappend
add SRC_URI:append:zynqmp=
file://pl-delete-nodes-hzg-custom-adrv9002.dtsi \
file://hzg-custom-adrv9002.dts"
set KERNEL_DTB_PATH ?= "${WORKDIR}"
USE_KERNEL_SOURCES ?= "y"
3. Execute command to clean up build
4. petalinux-config .xsa
5. add KERNEL_DTB = "hzg-custom-adrv9002" in petalinuxbsp.conf
6. petalinux-build
make sd card boot image and boot the platform, but still stucked at boot, the kernel log shows below
Xilinx Zynq MP First Stage Boot Loader
Release 2022.2 Oct 7 2022 - 04:56:16
NOTICE: BL31: v2.6(release):xlnx_rebase_v2.6_2022.1_update3-18-g0897efd45
NOTICE: BL31: Built : 03:55:03, Sep 9 2022
U-Boot 2022.01 (Sep 20 2022 - 06:35:33 +0000)
CPU: ZynqMP
Silicon: v3
Model: ZynqMP ZCU102 Rev1.0
Board: Xilinx ZynqMP
DRAM: 4 GiB
PMUFW: v1.1
PMUFW no permission to change config object
Xilinx I2C Legacy format at nvmem0:
Board name: zcu102
Board rev: 1.0
Board SN: 881478702346-96092
Ethernet mac: 00:0a:35:1d:22:69
EL Level: EL2
Chip ID: zu9eg
NAND: 0 MiB
MMC: mmc@ff170000: 0
Loading Environment from FAT... *** Error - No Valid Environment Area found
*** Warning - bad env area, using default environment
In: serial
Out: serial
Err: serial
Bootmode: LVL_SHFT_SD_MODE1
Reset reason: EXTERNAL
Net: FEC: can't find phy-handle
ZYNQ GEM: ff0e0000, mdio bus ff0e0000, phyaddr 12, interface rgmii-id
eth0: ethernet@ff0e0000
scanning bus for devices...
SATA link 0 timeout.
SATA link 1 timeout.
AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq pm clo only pmp fbss pio slum part ccc apst
starting USB...
Bus usb@fe200000: Register 2000440 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus usb@fe200000 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
2894 bytes read in 13 ms (216.8 KiB/s)
## Executing script at 20000000
Trying to load boot images from mmc0
==LOAD BITSTREAM START==
Device: mmc@ff170000
Manufacturer ID: 3
OEM: 5344
Bus Speed: 50000000
Mode: SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
26510895 bytes read in 1759 ms (14.4 MiB/s)
==LOAD BITFILE DONE==
11972136 bytes read in 802 ms (14.2 MiB/s)
## Loading kernel from FIT Image at 10000000 ...
Using 'conf-system-top.dtb' configuration
Trying 'kernel-1' kernel subimage
Description: Linux kernel
Created: 2024-06-18 7:23:35 UTC
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x10000104
Data Size: 11909300 Bytes = 11.4 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00200000
Entry Point: 0x00200000
Hash algo: sha256
Hash value: 32f7587275e8e6caaea89afcbe2c29c92b61b2aaf17dec300efc5c47ca258600
Verifying Hash Integrity ... sha256+ OK
## Loading fdt from FIT Image at 10000000 ...
Trying 'fdt-system-top.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x10b5bac8
Data Size: 60917 Bytes = 59.5 KiB
Hash algo: sha256
Hash value: 2b2700f3c794d5476b16440717a8b8c1cce9b36f13e142a713d1b59cc4586da3
Booting using the fdt blob at 0x10b5bac8
Uncompressing Kernel Image
Loading Device Tree to 000000007bde3000, end 000000007bdf4df4 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.15.36-xilinx-v2022.2 (oe-user@oe-host) (aarch64-xilinx-linux-gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.37.20210721) #1 SMP Tue Jun 18 07:23:35 UTC 2024
[ 0.000000] Machine model: ZynqMP ZCU102 Rev1.0
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] printk: bootconsole [cdns0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] node 0: [mem 0x0000000800000000-0x000000087fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000087fffffff]
[ 0.000000] cma: Reserved 256 MiB at 0x000000006bc00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 18 pages/cpu s35800 r8192 d29736 u73728
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: earlycon console=ttyPS0,115200 clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x000000007c000000-0x0000000080000000] (64MB)
[ 0.000000] Memory: 3749884K/4194304K available (17152K kernel code, 1740K rwdata, 13116K rodata, 2624K init, 650K bss, 182276K reserved, 262144K cma-reserved)
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x470/0x6d4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 100.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171024e7e0, max_idle_ns: 440795205315 ns
[ 0.000000] sched_clock: 56 bits at 100MHz, resolution 10ns, wraps every 4398046511100ns
[ 0.008504] Console: colour dummy device 80x25
[ 0.012486] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=400000)
[ 0.022839] pid_max: default: 32768 minimum: 301
[ 0.027642] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.034786] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.043646] rcu: Hierarchical SRCU implementation.
[ 0.047576] EFI services will not be available.
[ 0.051963] smp: Bringing up secondary CPUs ...
[ 0.056703] Detected VIPT I-cache on CPU1
[ 0.056745] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.057146] Detected VIPT I-cache on CPU2
[ 0.057171] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.057555] Detected VIPT I-cache on CPU3
[ 0.057578] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.057623] smp: Brought up 1 node, 4 CPUs
[ 0.091778] SMP: Total of 4 processors activated.
[ 0.096450] CPU features: detected: 32-bit EL0 Support
[ 0.101554] CPU features: detected: CRC32 instructions
[ 0.106696] CPU: All CPU(s) started at EL2
[ 0.110735] alternatives: patching kernel code
[ 0.116082] devtmpfs: initialized
[ 0.124763] Registered cp15_barrier emulation handler
[ 0.124816] Registered setend emulation handler
[ 0.128791] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.138383] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.151444] pinctrl core: initialized pinctrl subsystem
[ 0.152235] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.157992] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.164021] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.171759] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.179535] audit: initializing netlink subsys (disabled)
[ 0.184938] audit: type=2000 audit(0.116:1): state=initialized audit_enabled=0 res=1
[ 0.192580] cpuidle: using governor menu
[ 0.196533] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.203259] ASID allocator initialised with 65536 entries
[ 0.230043] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.231102] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.237772] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.244439] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.335450] DRBG: Continuing without Jitter RNG
[ 1.435921] raid6: neonx8 gen() 2139 MB/s
[ 1.503969] raid6: neonx8 xor() 1583 MB/s
[ 1.572036] raid6: neonx4 gen() 2182 MB/s
[ 1.640089] raid6: neonx4 xor() 1551 MB/s
[ 1.708162] raid6: neonx2 gen() 2070 MB/s
[ 1.776219] raid6: neonx2 xor() 1432 MB/s
[ 1.844285] raid6: neonx1 gen() 1769 MB/s
[ 1.912346] raid6: neonx1 xor() 1212 MB/s
[ 1.980407] raid6: int64x8 gen() 1366 MB/s
[ 2.048474] raid6: int64x8 xor() 773 MB/s
[ 2.116544] raid6: int64x4 gen() 1603 MB/s
[ 2.184600] raid6: int64x4 xor() 847 MB/s
[ 2.252675] raid6: int64x2 gen() 1393 MB/s
[ 2.320732] raid6: int64x2 xor() 750 MB/s
[ 2.388795] raid6: int64x1 gen() 1033 MB/s
[ 2.456855] raid6: int64x1 xor() 517 MB/s
[ 2.456894] raid6: using algorithm neonx4 gen() 2182 MB/s
[ 2.460844] raid6: .... xor() 1551 MB/s, rmw enabled
[ 2.465780] raid6: using neon recovery algorithm
[ 2.470841] iommu: Default domain type: Translated
[ 2.475211] iommu: DMA domain TLB invalidation policy: strict mode
[ 2.481644] SCSI subsystem initialized
[ 2.485312] usbcore: registered new interface driver usbfs
[ 2.490633] usbcore: registered new interface driver hub
[ 2.495903] usbcore: registered new device driver usb
[ 2.501042] mc: Linux media interface: v0.10
[ 2.505155] videodev: Linux video capture interface: v2.00
[ 2.510643] pps_core: LinuxPPS API ver. 1 registered
[ 2.515518] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 2.524608] PTP clock support registered
[ 2.528510] EDAC MC: Ver: 3.0.0
[ 2.531895] zynqmp-ipi-mbox mailbox@ff990400: Registered ZynqMP IPI mbox with TX/RX channels.
[ 2.540493] jesd204: found 0 devices and 0 topologies
[ 2.545134] FPGA manager framework
[ 2.548606] Advanced Linux Sound Architecture Driver Initialized.
[ 2.554951] Bluetooth: Core ver 2.22
[ 2.558086] NET: Registered PF_BLUETOOTH protocol family
[ 2.563354] Bluetooth: HCI device and connection manager initialized
[ 2.569670] Bluetooth: HCI socket layer initialized
[ 2.574512] Bluetooth: L2CAP socket layer initialized
[ 2.579535] Bluetooth: SCO socket layer initialized
[ 2.584795] clocksource: Switched to clocksource arch_sys_counter
[ 2.590569] VFS: Disk quotas dquot_6.6.0
[ 2.594358] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.605606] NET: Registered PF_INET protocol family
[ 2.606112] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 2.614925] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 2.621867] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 2.629903] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 2.637363] TCP: Hash tables configured (established 32768 bind 32768)
[ 2.643523] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 2.650183] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 2.657343] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 2.663143] RPC: Registered named UNIX socket transport module.
[ 2.668716] RPC: Registered udp transport module.
[ 2.673385] RPC: Registered tcp transport module.
[ 2.678053] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.685061] PCI: CLS 0 bytes, default 64
[ 2.688675] armv8-pmu pmu: hw perfevents: no interrupt-affinity property, guessing.
[ 2.696121] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.704546] Initialise system trusted keyrings
[ 2.708151] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 2.715203] NFS: Registering the id_resolver key type
[ 2.719501] Key type id_resolver registered
[ 2.723639] Key type id_legacy registered
[ 2.727631] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.734278] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.741647] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 2.748835] fuse: init (API version 7.34)
[ 2.787837] NET: Registered PF_ALG protocol family
[ 2.787890] xor: measuring software checksum speed
[ 2.795915] 8regs : 2363 MB/sec
[ 2.799584] 32regs : 2799 MB/sec
[ 2.804656] arm64_neon : 2308 MB/sec
[ 2.804717] xor: using function: 32regs (2799 MB/sec)
[ 2.809740] Key type asymmetric registered
[ 2.813804] Asymmetric key parser 'x509' registered
[ 2.818681] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 2.826005] io scheduler mq-deadline registered
[ 2.830499] io scheduler kyber registered
[ 2.861803] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.864797] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 2.872961] brd: module loaded
[ 2.876519] loop: module loaded
[ 2.876904] Registered mathworks_ip class
[ 2.881916] tun: Universal TUN/TAP device driver, 1.6
[ 2.883790] CAN device driver interface
[ 2.888283] SPI driver wl1271_spi has no spi_device_id for ti,wl1271
[ 2.893837] SPI driver wl1271_spi has no spi_device_id for ti,wl1273
[ 2.900150] SPI driver wl1271_spi has no spi_device_id for ti,wl1281
[ 2.906464] SPI driver wl1271_spi has no spi_device_id for ti,wl1283
[ 2.912777] SPI driver wl1271_spi has no spi_device_id for ti,wl1285
[ 2.919091] SPI driver wl1271_spi has no spi_device_id for ti,wl1801
[ 2.925406] SPI driver wl1271_spi has no spi_device_id for ti,wl1805
[ 2.931721] SPI driver wl1271_spi has no spi_device_id for ti,wl1807
[ 2.938036] SPI driver wl1271_spi has no spi_device_id for ti,wl1831
[ 2.944349] SPI driver wl1271_spi has no spi_device_id for ti,wl1835
[ 2.950670] SPI driver wl1271_spi has no spi_device_id for ti,wl1837
[ 2.957081] usbcore: registered new interface driver asix
[ 2.962389] usbcore: registered new interface driver ax88179_178a
[ 2.968418] usbcore: registered new interface driver cdc_ether
[ 2.974213] usbcore: registered new interface driver net1080
[ 2.979836] usbcore: registered new interface driver cdc_subset
[ 2.985721] usbcore: registered new interface driver zaurus
[ 2.991263] usbcore: registered new interface driver cdc_ncm
[ 2.997510] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.003347] ehci-pci: EHCI PCI platform driver
[ 3.008164] usbcore: registered new interface driver uas
[ 3.013066] usbcore: registered new interface driver usb-storage
[ 3.019055] usbcore: registered new interface driver usbserial_generic
[ 3.025502] usbserial: USB Serial support registered for generic
[ 3.031474] usbcore: registered new interface driver ftdi_sio
[ 3.037177] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.044452] usbcore: registered new interface driver upd78f0730
[ 3.050325] usbserial: USB Serial support registered for upd78f0730
[ 3.057559] SPI driver ads7846 has no spi_device_id for ti,tsc2046
[ 3.062686] SPI driver ads7846 has no spi_device_id for ti,ads7843
[ 3.068825] SPI driver ads7846 has no spi_device_id for ti,ads7845
[ 3.074966] SPI driver ads7846 has no spi_device_id for ti,ads7873
[ 3.081607] rtc_zynqmp ffa60000.rtc: registered as rtc0
[ 3.086313] rtc_zynqmp ffa60000.rtc: setting system clock to 2018-11-13T03:59:11 UTC (1542081551)
[ 3.095187] i2c_dev: i2c /dev entries driver
[ 3.101254] usbcore: registered new interface driver uvcvideo
[ 3.106557] Bluetooth: HCI UART driver ver 2.3
[ 3.109486] Bluetooth: HCI UART protocol H4 registered
[ 3.114584] Bluetooth: HCI UART protocol BCSP registered
[ 3.119873] Bluetooth: HCI UART protocol LL registered
[ 3.124962] Bluetooth: HCI UART protocol ATH3K registered
[ 3.130337] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 3.136591] Bluetooth: HCI UART protocol Intel registered
[ 3.141930] Bluetooth: HCI UART protocol QCA registered
[ 3.147131] usbcore: registered new interface driver bcm203x
[ 3.152752] usbcore: registered new interface driver bpa10x
[ 3.158286] usbcore: registered new interface driver bfusb
[ 3.163741] usbcore: registered new interface driver btusb
[ 3.169200] usbcore: registered new interface driver ath3k
[ 3.174685] EDAC MC: ECC not enabled
[ 3.178320] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[ 3.190648] sdhci: Secure Digital Host Controller Interface driver
[ 3.196414] sdhci: Copyright(c) Pierre Ossman
[ 3.200736] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.206796] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.212442] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 3.218805] zynqmp_firmware_probe Platform Management API v1.1
[ 3.224528] zynqmp_firmware_probe Trustzone version v1.0
[ 3.259923] zynqmp-aes firmware:zynqmp-firmware:zynqmp-aes: will run requests pump with realtime priority
[ 3.276184] zynqmp-keccak-384 firmware:zynqmp-firmware:sha384: The zynqmp-sha-deprecated driver shall be deprecated in 2022.2 and removed in 2023.1 release
[ 3.284491] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[ 3.290762] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[ 3.296261] usbcore: registered new interface driver usbhid
[ 3.301642] usbhid: USB HID core driver
[ 3.305635] SPI driver fb_seps525 has no spi_device_id for syncoam,seps525
[ 3.312965] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7988-5
[ 3.319459] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7988-1
[ 3.326636] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7984
[ 3.333647] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7983
[ 3.340650] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7982
[ 3.347656] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7980
[ 3.354662] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7949
[ 3.361669] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7946
[ 3.368675] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7942
[ 3.375681] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7699
[ 3.382688] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7693
[ 3.389694] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7691
[ 3.396701] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7690
[ 3.403708] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7689
[ 3.410714] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7688
[ 3.417721] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7687
[ 3.424727] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7686
[ 3.431734] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7685
[ 3.438740] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7682
[ 3.445863] SPI driver ad7124 has no spi_device_id for adi,ad7124-4
[ 3.451976] SPI driver ad7124 has no spi_device_id for adi,ad7124-8
[ 3.458221] SPI driver ad7192 has no spi_device_id for adi,ad7190
[ 3.464258] SPI driver ad7192 has no spi_device_id for adi,ad7193
[ 3.470312] SPI driver ad7192 has no spi_device_id for adi,ad7195
[ 3.477169] SPI driver ad9467 has no spi_device_id for adi,ad9643
[ 3.482424] SPI driver ad9467 has no spi_device_id for adi,ad9250
[ 3.488478] SPI driver ad9467 has no spi_device_id for adi,ad9250_2
[ 3.494705] SPI driver ad9467 has no spi_device_id for adi,ad9265
[ 3.500760] SPI driver ad9467 has no spi_device_id for adi,ad9683
[ 3.506815] SPI driver ad9467 has no spi_device_id for adi,ad9434
[ 3.512870] SPI driver ad9467 has no spi_device_id for adi,ad9625
[ 3.518925] SPI driver ad9467 has no spi_device_id for adi,ad9652
[ 3.524980] SPI driver ad9467 has no spi_device_id for adi,ad9649
[ 3.533855] SPI driver adar3000 has no spi_device_id for adi,adar3001
[ 3.537442] SPI driver adar3000 has no spi_device_id for adi,adar3002
[ 3.545074] SPI driver ad9783 has no spi_device_id for adi,ad9780
[ 3.549894] SPI driver ad9783 has no spi_device_id for adi,ad9781
[ 3.556138] SPI driver adis16475 has no spi_device_id for adi,adis16470
[ 3.562523] SPI driver adis16475 has no spi_device_id for adi,adis16475-1
[ 3.569269] SPI driver adis16475 has no spi_device_id for adi,adis16475-2
[ 3.576015] SPI driver adis16475 has no spi_device_id for adi,adis16475-3
[ 3.582767] SPI driver adis16475 has no spi_device_id for adi,adis16477-1
[ 3.589510] SPI driver adis16475 has no spi_device_id for adi,adis16477-2
[ 3.596256] SPI driver adis16475 has no spi_device_id for adi,adis16477-3
[ 3.603003] SPI driver adis16475 has no spi_device_id for adi,adis16465-1
[ 3.609750] SPI driver adis16475 has no spi_device_id for adi,adis16465-2
[ 3.616497] SPI driver adis16475 has no spi_device_id for adi,adis16465-3
[ 3.623244] SPI driver adis16475 has no spi_device_id for adi,adis16467-1
[ 3.629991] SPI driver adis16475 has no spi_device_id for adi,adis16467-2
[ 3.636738] SPI driver adis16475 has no spi_device_id for adi,adis16467-3
[ 3.643485] SPI driver adis16475 has no spi_device_id for adi,adis16500
[ 3.650059] SPI driver adis16475 has no spi_device_id for adi,adis16505-1
[ 3.656806] SPI driver adis16475 has no spi_device_id for adi,adis16505-2
[ 3.663553] SPI driver adis16475 has no spi_device_id for adi,adis16505-3
[ 3.670300] SPI driver adis16475 has no spi_device_id for adi,adis16507-1
[ 3.677047] SPI driver adis16475 has no spi_device_id for adi,adis16507-2
[ 3.683794] SPI driver adis16475 has no spi_device_id for adi,adis16507-3
[ 3.691599] axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.01.a) found
[ 3.698507] axi_sysid 85000000.axi-sysid-0: [CMOSLVDSN0/adrv9001] [CMOS_LVDS_N=0] on [zcu102] git branch <> git <0> dirty [2024-07-23 09:44:13] UTC
[ 3.712055] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 3.718360] usbcore: registered new interface driver snd-usb-audio
[ 3.725905] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 3.732277] Initializing XFRM netlink socket
[ 3.735857] NET: Registered PF_INET6 protocol family
[ 3.741180] Segment Routing with IPv6
[ 3.744353] In-situ OAM (IOAM) with IPv6
[ 3.748311] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.754467] NET: Registered PF_PACKET protocol family
[ 3.759151] NET: Registered PF_KEY protocol family
[ 3.763969] can: controller area network core
[ 3.768255] NET: Registered PF_CAN protocol family
[ 3.772979] can: raw protocol
[ 3.775916] can: broadcast manager protocol
[ 3.780075] can: netlink gateway - max_hops=1
[ 3.784481] Bluetooth: RFCOMM TTY layer initialized
[ 3.789247] Bluetooth: RFCOMM socket layer initialized
[ 3.794355] Bluetooth: RFCOMM ver 1.11
[ 3.798068] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.803340] Bluetooth: BNEP filters: protocol multicast
[ 3.808531] Bluetooth: BNEP socket layer initialized
[ 3.813460] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.819344] Bluetooth: HIDP socket layer initialized
[ 3.824411] 9pnet: Installing 9P2000 support
[ 3.828539] NET: Registered PF_IEEE802154 protocol family
[ 3.833897] Key type dns_resolver registered
[ 3.838343] registered taskstats version 1
[ 3.842180] Loading compiled-in X.509 certificates
[ 3.847464] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[ 3.862681] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 48, base_baud = 6249999) is a xuartps
[ 3.871713] printk: console [ttyPS0] enabled
[ 3.876006] printk: bootconsole [cdns0] disabled
[ 3.885587] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 49, base_baud = 6249999) is a xuartps
[ 3.898751] of-fpga-region fpga-full: FPGA Region probed
[ 3.905276] nwl-pcie fd0e0000.pcie: host bridge /axi/pcie@fd0e0000 ranges:
[ 3.912182] nwl-pcie fd0e0000.pcie: MEM 0x00e0000000..0x00efffffff -> 0x00e0000000
[ 3.920193] nwl-pcie fd0e0000.pcie: MEM 0x0600000000..0x07ffffffff -> 0x0600000000
[ 3.928270] nwl-pcie fd0e0000.pcie: Link is DOWN
[ 3.933033] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
[ 3.939216] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.944706] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
[ 3.951579] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
[ 3.959086] pci 0000:00:00.0: [10ee:d021] type 01 class 0x060400
[ 3.965152] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
[ 3.975417] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
[ 3.981691] xilinx-zynqmp-dma fd500000.dma-controller: ZynqMP DMA driver Probe success
[ 3.989776] xilinx-zynqmp-dma fd510000.dma-controller: ZynqMP DMA driver Probe success
[ 3.997856] xilinx-zynqmp-dma fd520000.dma-controller: ZynqMP DMA driver Probe success
[ 4.005938] xilinx-zynqmp-dma fd530000.dma-controller: ZynqMP DMA driver Probe success
[ 4.014019] xilinx-zynqmp-dma fd540000.dma-controller: ZynqMP DMA driver Probe success
[ 4.022102] xilinx-zynqmp-dma fd550000.dma-controller: ZynqMP DMA driver Probe success
[ 4.030182] xilinx-zynqmp-dma fd560000.dma-controller: ZynqMP DMA driver Probe success
[ 4.038265] xilinx-zynqmp-dma fd570000.dma-controller: ZynqMP DMA driver Probe success
[ 4.046580] xilinx-zynqmp-dpdma fd4c0000.dma-controller: Xilinx DPDMA engine is probed
[ 4.056382] spi-nor spi0.0: SPI-NOR-UniqueID 64b311001610001b00e0bae6e06b
[ 4.063176] spi-nor spi0.0: found mt25qu512a, expected m25p80
[ 4.069315] spi-nor spi0.0: mt25qu512a (131072 Kbytes)
[ 4.074478] 4 fixed-partitions partitions found on MTD device spi0.0
[ 4.080823] Creating 4 MTD partitions on "spi0.0":
[ 4.085606] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
[ 4.092191] 0x000000100000-0x000000600000 : "qspi-linux"
[ 4.098226] 0x000000600000-0x000000620000 : "qspi-device-tree"
[ 4.104802] 0x000000620000-0x000000c00000 : "qspi-rootfs"
[ 4.111825] xilinx_can ff070000.can can0: TDC Offset value not in range
[ 4.120060] macb ff0e0000.ethernet: Not enabling partial store and forward
[ 4.128399] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 30 (00:0a:35:1d:22:69)
[ 4.138512] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[ 4.145054] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[ 4.151536] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[ 4.158032] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[ 4.165452] pca953x 0-0020: supply vcc not found, using dummy regulator
[ 4.172139] pca953x 0-0020: using no AI
[ 4.176635] gpio-318 (sel0): hogged as output/low
[ 4.181539] gpio-319 (sel1): hogged as output/high
[ 4.186529] gpio-320 (sel2): hogged as output/high
[ 4.191521] gpio-321 (sel3): hogged as output/high
[ 4.196687] pca953x 0-0021: supply vcc not found, using dummy regulator
[ 4.203363] pca953x 0-0021: using no AI
[ 4.208843] ina2xx 2-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.215832] ina2xx 2-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.222838] ina2xx 2-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.229832] ina2xx 2-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.236830] ina2xx 2-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.243842] ina2xx 2-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.250840] ina2xx 2-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.257835] ina2xx 2-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.264890] ina2xx 2-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.271884] ina2xx 2-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.278294] i2c i2c-0: Added multiplexed i2c bus 2
[ 4.283857] ina2xx 3-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[ 4.290856] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.297853] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.304854] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.311849] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.318848] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.325841] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.332848] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.339254] i2c i2c-0: Added multiplexed i2c bus 3
[ 4.355485] random: fast init done
[ 4.398393] i2c i2c-0: Added multiplexed i2c bus 4
[ 4.403358] i2c i2c-0: Added multiplexed i2c bus 5
[ 4.408152] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[ 4.415523] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 32
[ 4.422953] at24 6-0054: supply vcc not found, using dummy regulator
[ 4.429849] at24 6-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[ 4.436609] i2c i2c-1: Added multiplexed i2c bus 6
[ 4.441978] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[ 4.449285] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[ 4.456590] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[ 4.463888] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[ 4.471194] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[ 4.478499] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[ 4.485807] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[ 4.493107] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[ 4.501520] si5341 7-0036: Chip: 5341 Grade: 1 Rev: 3
[ 4.540078] i2c i2c-1: Added multiplexed i2c bus 7
[ 4.547732] si570 8-005d: registered, current frequency 300000000 Hz
[ 4.554140] i2c i2c-1: Added multiplexed i2c bus 8
[ 4.573927] si570 9-005d: registered, current frequency 148500000 Hz
[ 4.580336] i2c i2c-1: Added multiplexed i2c bus 9
[ 4.585364] si5324 10-0069: si5328 probed
[ 4.653167] si5324 10-0069: si5328 probe successful
[ 4.658103] i2c i2c-1: Added multiplexed i2c bus 10
[ 4.663140] i2c i2c-1: Added multiplexed i2c bus 11
[ 4.668181] i2c i2c-1: Added multiplexed i2c bus 12
[ 4.673210] i2c i2c-1: Added multiplexed i2c bus 13
[ 4.678091] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[ 4.686171] at24 14-0050: supply vcc not found, using dummy regulator
[ 4.692984] at24 14-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 4.699738] i2c i2c-1: Added multiplexed i2c bus 14
[ 4.704796] i2c i2c-1: Added multiplexed i2c bus 15
[ 4.709844] i2c i2c-1: Added multiplexed i2c bus 16
[ 4.714887] i2c i2c-1: Added multiplexed i2c bus 17
[ 4.719944] i2c i2c-1: Added multiplexed i2c bus 18
[ 4.724990] i2c i2c-1: Added multiplexed i2c bus 19
[ 4.730032] i2c i2c-1: Added multiplexed i2c bus 20
[ 4.735084] i2c i2c-1: Added multiplexed i2c bus 21
[ 4.739962] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[ 4.747582] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 33
[ 4.756862] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
[ 4.765234] Internal error: synchronous external abort: 96000010 [#1] SMP
[ 4.772014] Modules linked in:
[ 4.775061] CPU: 2 PID: 76 Comm: kworker/u8:1 Not tainted 5.15.36-xilinx-v2022.2 #1
[ 4.782706] Hardware name: ZynqMP ZCU102 Rev1.0 (DT)
[ 4.787656] Workqueue: events_unbound deferred_probe_work_func
[ 4.793488] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 4.798183] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[ 4.800439] pc : axiadc_probe+0x178/0x81c
[ 4.812071] lr : axiadc_probe+0x158/0x81c
[ 4.816072] sp : ffffffc00a713af0
[ 4.819371] x29: ffffffc00a713b00 x28: ffffff8800397e00 x27: ffffff8800878400
[ 4.826497] x26: 0000000000000001 x25: ffffffc0093e43e8 x24: 0000000000000000
[ 4.833623] x23: ffffff8800864d80 x22: ffffff880087dc10 x21: ffffff880087dc00
[ 4.840750] x20: ffffff8801dc8000 x19: ffffff8801dc8580 x18: ffffffffffffffff
[ 4.847876] x17: 0000000000000008 x16: 0000157ed37dd210 x15: ffffffc00a1f7560
[ 4.849181] mmc0: new high speed SDHC card at address aaaa
[ 4.855002] x14: 0000000084a06000 x13: ffffffc008000000 x12: ffffffc009e48558
[ 4.860862] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[ 4.867596] x11: ffffffc009e48558 x10: ffffffc00a1f7000 x9 : 0000000000000000
[ 4.877560] mmcblk0: p1 p2
[ 4.879150] x8 : ffffffc008007fff x7 : 0000000000000100 x6 : ffffff887ffff2a8
[ 4.889054] x5 : ffffff880087dec0 x4 : 0000000000000000 x3 : 0000000000000001
[ 4.896180] x2 : ffffff8801eeec00 x1 : ffffff880087deb8 x0 : ffffffc00a9c800c
[ 4.903307] Call trace:
[ 4.905738] axiadc_probe+0x178/0x81c
[ 4.909391] platform_probe+0x68/0xe0
[ 4.913045] really_probe.part.0+0x9c/0x30c
[ 4.917220] __driver_probe_device+0x98/0x144
[ 4.921569] driver_probe_device+0x44/0x11c
[ 4.925744] __device_attach_driver+0xb4/0x120
[ 4.930180] bus_for_each_drv+0x78/0xd0
[ 4.934008] __device_attach+0xdc/0x184
[ 4.937835] device_initial_probe+0x14/0x20
[ 4.942010] bus_probe_device+0x9c/0xa4
[ 4.945838] deferred_probe_work_func+0x88/0xc0
[ 4.950360] process_one_work+0x1d8/0x390
[ 4.954362] worker_thread+0x298/0x4e0
[ 4.958103] kthread+0x120/0x130
[ 4.961324] ret_from_fork+0x10/0x20
[ 4.964895] Code: f9000260 f9003ed4 f9405e60 91003000 (b9400000)
[ 4.970978] ---[ end trace 57376b8c7940088d ]---
