hdl_2019r2 for ZED board does not boot with Full fledged GUI
Product Number: AD-FMCOMMS2-EBZ
Software Version: hdl_2019_r2
I am using following HDL https://github.com/analogdevicesinc/hdl/releases/tag/2019_r2 and associated Linux branch https://github.com/analogdevicesinc/linux/tree/2019_R2
My Boards are : Zed board  + AD-FMCOMMS2-EBZ
When  I try to boot using built images I am not able to get proper output at HDMI Monitor. It shows Linux icon but does not show the complete Linux GUI after boot. It as if the booting not complete.
Attached is the image
I am attaching the boot log when i boot with ZED Board.
U-Boot 2019.01 (Jun 05 2024 - 16:59:00 +0530)
CPU:   Zynq 7z020
Silicon: v3.1
Model: Avnet ZedBoard board
DRAM:  ECC disabled 512 MiB
MMC:   mmc@e0100000: 0
Loading Environment from SPI Flash... SF: Detected s25fl256s_64k with page size 256 Bytes, erase size 64 KiB, total 32 MiB
OK
In:    serial@e0001000
Out:   serial@e0001000
Err:   serial@e0001000
Net:   ZYNQ GEM: e000b000, phyaddr 0, interface rgmii-id
eth0: ethernet@e000b000
Hit any key to stop autoboot:  0
Device: mmc@e0100000
Manufacturer ID: 3
OEM: 5344
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.7 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
407 bytes read in 16 ms (24.4 KiB/s)
Loaded environment from uEnv.txt
Importing environment from SD ...
Running uenvcmd ...
Copying Linux from SD to RAM...
6349592 bytes read in 370 ms (16.4 MiB/s)
20057 bytes read in 31 ms (631.8 KiB/s)
** Unable to read file uramdisk.image.gz **
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   Linux-4.19.0
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    6349528 Bytes = 6.1 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x2a00000
   Loading Kernel Image ... OK
   Loading Device Tree to 1eb19000, end 1eb20e58 ... OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 4.19.0 (cstg@cstg-OptiPlex-9020) (gcc version 10.2.0 (GCC)) #1 SMP PREEMPT Wed Jun 5 09:46:55 IST 2024
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt: Machine model: Xilinx Zynq ZED
OF: fdt: earlycon: stdout-path /amba@0/uart@E0001000 not found
Memory policy: Data cache writealloc
cma: Reserved 128 MiB at 0x16800000
random: get_random_bytes called from start_kernel+0x9c/0x410 with crng_init=0
percpu: Embedded 16 pages/cpu @(ptrval) s33548 r8192 d23796 u65536
Built 1 zonelists, mobility grouping on.  Total pages: 130048
Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlycon rootfstype=ext4 rootwait clk_ignore_unused cpuidle.off=1
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 369112K/524288K available (9216K kernel code, 760K rwdata, 6784K rodata, 1024K init, 455K bss, 24104K reserved, 131072K cma-reserved, 0K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
    lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
      .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
      .data : 0x(ptrval) - 0x(ptrval)   ( 761 kB)
       .bss : 0x(ptrval) - 0x(ptrval)   ( 456 kB)
rcu: Preemptible hierarchical RCU implementation.
rcu:    RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
        Tasks RCU enabled.
rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
efuse mapped to (ptrval)
slcr mapped to (ptrval)
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at (ptrval)
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at (ptrval), irq=17
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
CPU0: Spectre v2: using BPIALL workaround
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x100000 - 0x100060
rcu: Hierarchical SRCU implementation.
smp: Bringing up secondary CPUs ...
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU1: Spectre v2: using BPIALL workaround
smp: Brought up 1 node, 2 CPUs
SMP: Total of 2 processors activated (1333.33 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0x(ptrval)
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 25, base_baud = 3125000) is a xuartps
console [ttyPS0] enabled
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
media: Linux media interface: v0.10
videodev: Linux video capture interface: v2.00
jesd204: found 0 devices and 0 topologies
FPGA manager framework
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
NET: Registered protocol family 2
tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
hw perfevents: no interrupt-affinity property for /pmu@f8891000, guessing.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
workingset: timestamp_bits=30 max_order=17 bucket_order=0
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
io scheduler mq-deadline registered
io scheduler kyber registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac:        DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
brd: module loaded
loop: module loaded
Registered mathworks_ip class
m25p80 spi2.0: found s25fl256s1, expected n25q128a11
m25p80 spi2.0: s25fl256s1 (32768 Kbytes)
5 fixed-partitions partitions found on MTD device spi2.0
Creating 5 MTD partitions on "spi2.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000540000 : "config"
0x000000540000-0x000000fc0000 : "image"
0x000000fc0000-0x000002000000 : "spare"
MACsec IEEE 802.1AE
libphy: Fixed MDIO Bus: probed
tun: Universal TUN/TAP device driver, 1.6
libphy: MACB_mii_bus: probed
Marvell 88E1510 e000b000.ethernet-ffffffff:00: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=e000b000.ethernet-ffffffff:00, irq=POLL)
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 29 (00:0a:35:00:01:22)
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
usbcore: registered new interface driver uas
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver upd78f0730
usbserial: USB Serial support registered for upd78f0730
chipidea-usb2 e0002000.usb: e0002000.usb supply vbus not found, using dummy regulator
chipidea-usb2 e0002000.usb: Linked as a consumer to regulator.0
ULPI transceiver vendor/product ID 0x0451/0x1507
Found TI TUSB1210 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 4.19.0 ehci_hcd
usb usb1: SerialNumber: ci_hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
i2c /dev entries driver
adv7511 0-0039: 0-0039 supply avdd not found, using dummy regulator
adv7511 0-0039: Linked as a consumer to regulator.0
adv7511 0-0039: 0-0039 supply dvdd not found, using dummy regulator
adv7511 0-0039: 0-0039 supply pvdd not found, using dummy regulator
adv7511 0-0039: 0-0039 supply bgvdd not found, using dummy regulator
adv7511 0-0039: 0-0039 supply dvdd-3v not found, using dummy regulator
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
gspca_main: v2.14.0 registered
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer with timeout 10s
Xilinx Zynq CpuIdle Driver started
failed to register cpuidle driver
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: SDHCI controller on e0100000.mmc [e0100000.mmc] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ad7291: probe of 1-002f failed with error -5
ad9361 spi0.0: ad9361_probe : enter (ad9361)
ad9361 spi0.0: No GPIOs defined for ext band ctrl
ad9361 spi0.0: ad9361_probe : Unsupported PRODUCT_ID 0xFF
adf4350 spi1.0: spi1.0 supply vcc not found, using dummy regulator
adf4350 spi1.0: Linked as a consumer to regulator.0
mmc0: new high speed SDHC card at address aaaa
adf4350 spi1.1: spi1.1 supply vcc not found, using dummy regulator
mmcblk0: mmc0:aaaa SK32G 29.7 GiB
adf4350 spi1.1: Linked as a consumer to regulator.0
 mmcblk0: p1 p2 p3
axi_sysid 45000000.axi-sysid-0: AXI System ID core version (1.00.a) found
axi_sysid 45000000.axi-sysid-0: [fmcomms2] on [zed] git <43cdc6263baf3edb166a3def6fab15bc81c4c729> clean [2024-06-05 07:04:06] UTC
fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
usbcore: registered new interface driver snd-usb-audio
NET: Registered protocol family 10
Segment Routing with IPv6
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered protocol family 36
Registering SWP/SWPB emulation handler
[drm] Cannot find any crtc or sizes
[drm] Initialized axi_hdmi_drm 1.0.0 20120930 for 70e00000.axi_hdmi on minor 0
asoc-simple-card adv7511_hdmi_snd: spdif-hifi <-> 75c00000.axi-spdif-tx mapping ok
asoc-simple-card zed_sound: adau-hifi <-> 77600000.axi-i2s mapping ok
hctosys: unable to open rtc device (rtc0)
clk: Not disabling unused clocks
ALSA device list:
  #0: HDMI monitor
  #1: ZED ADAU1761
random: fast init done
EXT4-fs (mmcblk0p2): recovery complete
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 1024K
Run /sbin/init as init process
systemd[1]: System time before build time, advancing clock.
systemd[1]: Failed to lookup module alias 'autofs4': Function not implemented
systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
systemd[1]: Detected architecture arm.
Welcome to Kuiper GNU/Linux 10 (buster)!
systemd[1]: Set hostname to <analog>.
systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
systemd[1]: /etc/systemd/system/tof-server.service:1: Assignment outside of section. Ignoring.
systemd[1]: /etc/systemd/system/tof-server.service:2: Assignment outside of section. Ignoring.
random: systemd: uninitialized urandom read (16 bytes read)
systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
         Mounting Kernel Debug File System...
[  OK  ] Created slice system-getty.slice.
[  OK  ] Listening on udev Control Socket.
         Starting Restore / save the current clock...
[  OK  ] Listening on fsck to fsckd communication Socket.
         Mounting RPC Pipe File System...
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Listening on Syslog Socket.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Reached target Swap.
         Starting udev Coldplug all Devices...
         Starting Load Kernel Modules...
[  OK  ] Created slice system-systemd\x2dfsck.slice.
         Starting Journal Service...
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
         Starting Set the console keyboard layout...
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Started Journal Service.
[  OK  ] Started Restore / save the current clock.
[FAILED] Failed to mount RPC Pipe File System.
See 'systemctl status run-rpc_pipefs.mount' for details.
[DEPEND] Dependency failed for RPC …curity service for NFS server.
[DEPEND] Dependency failed for RPC …ice for NFS client and server.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
         Starting Apply Kernel Variables...
         Mounting Kernel Configuration File System...
[  OK  ] Reached target NFS client services.
[  OK  ] Reached target Remote File Systems (Pre).
[  OK  ] Reached target Remote File Systems.
         Starting Remount Root and Kernel File Systems...
[  OK  ] Started Set the console keyboard layout.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started udev Coldplug all Devices.
         Starting Helper to synchronize boot up for ifupdown...
[  OK  ] Started Helper to synchronize boot up for ifupdown.
[  OK  ] Started Remount Root and Kernel File Systems.
         Starting Load/Save Random Seed...
         Starting Create System Users...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Create System Users.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Starting udev Kernel Device Manager...
[  OK  ] Started udev Kernel Device Manager.
         Starting Show Plymouth Boot Screen...
[  OK  ] Started Show Plymouth Boot Screen.
[  OK  ] Started Forward Password R…s to Plymouth Directory Watch.
[  OK  ] Reached target Local Encrypted Volumes.
[  OK  ] Found device /dev/ttyPS0.
[  OK  ] Found device /dev/disk/by-partuuid/004ba301-01.
         Starting File System Check…isk/by-partuuid/004ba301-01...
[  OK  ] Started File System Check Daemon to report status.
[  OK  ] Started File System Check …/disk/by-partuuid/004ba301-01.
         Mounting /boot...
[  OK  ] Mounted /boot.
[  OK  ] Reached target Local File Systems.
         Starting Set console font and keymap...
         Starting Tell Plymouth To Write Out Runtime Data...
         Starting Raise network interfaces...
         Starting Preprocess NFS configuration...
         Starting Create Volatile Files and Directories...
[  OK  ] Started Set console font and keymap.
[  OK  ] Started Tell Plymouth To Write Out Runtime Data.
[  OK  ] Started Preprocess NFS configuration.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Raise network interfaces.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Initialization.
[  OK  ] Started CUPS Scheduler.
[  OK  ] Reached target Paths.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on triggerhappy.socket.
[  OK  ] Listening on GPS (Global P…ioning System) Daemon Sockets.
[  OK  ] Listening on CUPS Scheduler.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting Check for Raspberry Pi EEPROM updates...
[  OK  ] Started D-Bus System Message Bus.
         Starting WPA supplicant...
         Starting Disk Manager...
         Starting Modem Manager...
[  OK  ] Started Regular background program processing daemon.
         Starting LSB: Switch to on…nless shift key is pressed)...
         Starting Login Service...
         Starting rng-tools.service...
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Started tof-server.service.
         Starting dphys-swapfile - …unt, and delete a swap file...
         Starting Avahi mDNS/DNS-SD Stack...
         Starting System Logging Service...
[  OK  ] Started Manage Sound Card State (restore and store).
         Starting Save/Restore Sound Card State...
         Starting dhcpcd on all interfaces...
         Starting triggerhappy global hotkey daemon...
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Daily man-db regeneration.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Daily apt download activities.
[  OK  ] Started Daily apt upgrade and clean activities.
[  OK  ] Reached target Timers.
[  OK  ] Started Check for Raspberry Pi EEPROM updates.
[FAILED] Failed to start rng-tools.service.
See 'systemctl status rng-tools.service' for details.
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Started triggerhappy global hotkey daemon.
[  OK  ] Reached target Sound Card.
[  OK  ] Started Login Service.
[  OK  ] Started System Logging Service.
[  OK  ] Started LSB: Switch to ond…(unless shift key is pressed).
[  OK  ] Started dhcpcd on all interfaces.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started WPA supplicant.
[  OK  ] Started Make remote CUPS printers available locally.
[  OK  ] Reached target Network.
[  OK  ] Reached target Network is Online.
         Starting Internet superserver...
         Starting /etc/rc.local Compatibility...
         Starting OpenBSD Secure Shell server...
[  OK  ] Started IIO Daemon.
         Starting Permit User Sessions...
         Starting HTTP based time synchronization tool...
[  OK  ] Started Internet superserver.
[  OK  ] Started dphys-swapfile - s…mount, and delete a swap file.
[  OK  ] Started /etc/rc.local Compatibility.
         Starting Authorization Manager...
[  OK  ] Started Permit User Sessions.
[  OK  ] Started HTTP based time synchronization tool.
         Starting Hold until boot process finishes up...
         Starting Light Display Manager...
[  OK  ] Started OpenBSD Secure Shell server.
[  OK  ] Started Authorization Manager.
Raspbian GNU/Linux 10 analog ttyPS0
analog login: root (automatic login)
Last login: Wed Jul 28 22:17:15 BST 2021 on ttyPS0
Linux analog 4.19.0 #1 SMP PREEMPT Wed Jun 5 09:46:55 IST 2024 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@analog:~#
Here I am able to boot upto the command line. Why am I not able to get the complete Linux GUI ??
To check HDMI I tried i2c detect
root@analog:~#
root@analog:~#
root@analog:~# i2cdetect 0
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-0.
I will probe address range 0x03-0x77.
Continue? [Y/n] y
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- UU UU -- UU UU -- 3e UU
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@analog:~#
I could get response at 0x3e address.
What could be the issue with GUI??
Please help
Edit Notes
typos
[edited by: rakeshm55 at 10:36 AM (GMT -4) on 18 Jun 2024]
  • I have tested default pre-built images for 2019R2 on zed board. Here too i observe no GUI output on monitor. The screen is stuck at linux icon on screen
    Where as when i boot with latest prebuilt images i am able to get Linux Desktop on screen. So i guess this is not a hardware issue
  • Hi ,
    2019_r2 release is pretty old and we stopped maintaining it, and I recommend to go with latest Kuiper release - 2022_r2 Patch1.
    But even so, you can still download the official Kuiper 2019_r2 SD Card image from here ("Previous Kuiper Linux Releases" section) and then configure the SD card for Zed + fmcomms2 by following the steps here (AMD/Xilinx -> Zynq Projects section).
    A quick start guide can also be found here.
    Stefan
    1. I could boot with complete Linux Desktop GUI using the official Kuiper 2019_r2 SD Card image on ZED Board.
    2. Now  I replaced the devicetree.dtb with dtb files  built from source for ZED board  https://github.com/analogdevicesinc/hdl/releases/tag/2019_r2
    I adopted the steps mentioned in https://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/software/linux/zynq_2014r2 and used steps in under title "Using the Linaro toolchain"
    In this case I could not get the Monitor working "it displayed input timing not supported"
    The BOOT.bin and uIMAGE were same as in prebuilt official SD card image.
    Note :: I am able to access command line via debug UART interface
    I am attaching both working devicetree.dtb and non-working devicetree.dtb
    1.
    devicetree_working.rar
    2.zynq-zed-adv7511-ad9361-fmcomms2-3.rar
  • Attaching boot log of working and non working
    here I observe that with dtb change following msg appears
    ""systemd-udevd[1359]: could not open moddep file '/lib/modules/4.14.0-gb9e7064/modules.dep.bin'""
    U-Boot 2014.07-dirty (Nov 20 2014 - 17:05:21)
    Board:  Xilinx Zynq
    I2C:   ready
    MMC:   zynq_sdhci: 0
    SF: Detected S25FL256S_64K with page size 256 Bytes, erase size 64 KiB, total 32 MiB
    In:    serial
    Out:   serial
    Err:   serial
    Net:   Gem.e000b000
    Device: zynq_sdhci
    Manufacturer ID: 3
    OEM: 5344
    Tran Speed: 50000000
    Rd Block Len: 512
    SD version 3.0
    High Capacity: Yes
    Capacity: 29.7 GiB
    Bus Width: 4-bit
    reading uEnv.txt
    376 bytes read in 9 ms (40 KiB/s)
    Running uenvcmd ...
    reading uImage
    4320224 bytes read in 386 ms (10.7 MiB/s)
    reading devicetree.dtb
    20350 bytes read in 27 ms (735.4 KiB/s)
    reading uramdisk.image.gz
       Image Name:   Linux-4.14.0-gb9e7064
       Data Size:    4320160 Bytes = 4.1 MiB
       Loading Device Tree to 1ed1b000, end 1ed22f7d ... OK
    Starting kernel ...
    Uncompressing Linux... done, booting the kernel.
    Linux version 4.14.0-gb9e7064 (jenkins@romlxbuild1.adlk.analog.com) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11-rc1)) #441 SMP PREEMPT Fri Mar 29 08:45:14 GMT 2019
    cma: Reserved 128 MiB at 0x16c00000
    percpu: Embedded 16 pages/cpu @dfb88000 s32972 r8192 d24372 u65536
    PID hash table entries: 2048 (order: 1, 8192 bytes)
    Memory: 377012K/524288K available (6144K kernel code, 292K rwdata, 2308K rodata, 1024K init, 154K bss, 16204K reserved, 131072K cma-reserved, 0K highmem)
          .text : 0xc0008000 - 0xc0700000   (7136 kB)
          .init : 0xc0a00000 - 0xc0b00000   (1024 kB)
          .data : 0xc0b00000 - 0xc0b49140   ( 293 kB)
           .bss : 0xc0b4e6c0 - 0xc0b75094   ( 155 kB)
            Tasks RCU enabled.
    RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    efuse mapped to e0800000
    slcr mapped to e0802000
    zynq_clock_init: clkc starts at e0802100
    Zynq clock init
    timer #0 at e080a000, irq=17
    cpuidle: using governor ladder
    zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xe0840000
    pps_core: LinuxPPS API ver. 1 registered
    pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    PTP clock support registered
    brd: module loaded
    loop: module loaded
    5 ofpart partitions found on MTD device spi2.0
    MACsec IEEE 802.1AE
    IR NEC protocol handler initialized
    IR RC5(x/sz) protocol handler initialized
    IR RC6 protocol handler initialized
    IR JVC protocol handler initialized
    IR Sony protocol handler initialized
    IR SANYO protocol handler initialized
    IR Sharp protocol handler initialized
    IR MCE Keyboard/mouse protocol handler initialized
    IR XMP protocol handler initialized
    cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer at e088a000 with timeout 10s
    mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
    adf4350 spi1.0: Probe failed (muxout)
    adf4350 spi1.1: Probe failed (muxout)
     mmcblk0: p1 p2 p3
    ALSA device list:
      #0: HDMI monitor
    ÊEXT4-fs (mmcblk0p2): recovery complete
    devtmpfs: mounted
    Mount failed for selinuxfs on /sys/fs/selinux:  No such file or directory
    init: hwclock main process (919) terminated with status 1
     * Setting up X socket directories...                                    [ OK ]
     * STARTDISTCC is set to false in /etc/default/distcc
     * /usr/bin/distccd not starting
     * Starting IIO Daemon iiod                                              [ OK ]
    Last login: Thu Jan  1 00:00:07 UTC 1970 on tty1
    Welcome to Linaro 14.04 (GNU/Linux 4.14.0-gb9e7064 armv7l)
     * Documentation:  https://wiki.analog.com/ https://ez.analog.com/
    New release '16.04.6 LTS' available.
    Run 'do-release-upgrade' to upgrade to it.
    Continue? [Y/n] y
    30: -- -- -- -- -- -- -- -- 38 UU -- UU -- -- 3e UU
    root@analog:~#
    Board:  Xilinx Zynq
    I2C:   ready
    MMC:   zynq_sdhci: 0
    In:    serial
    Out:   serial
    Err:   serial
    Net:   Gem.e000b000
    Device: zynq_sdhci
    Manufacturer ID: 3
    OEM: 5344
    Rd Block Len: 512
    SD version 3.0
    High Capacity: Yes
    Capacity: 29.7 GiB
    Bus Width: 4-bit
    reading uEnv.txt
    Running uenvcmd ...
    reading uImage
    20057 bytes read in 27 ms (724.6 KiB/s)
       Loading Device Tree to 1ed1b000, end 1ed22e58 ... OK
    Starting kernel ...
            Tasks RCU enabled.
    Zynq clock init
    brd: module loaded
    loop: module loaded
    MACsec IEEE 802.1AE
     mmcblk0: p1 p2 p3
    ALSA device list:
      #0: HDMI monitor
    devtmpfs: mounted
    init: hwclock main process (920) terminated with status 1
    Last login: Thu Jan  1 00:00:10 UTC 1970 on tty1
    root@analog:~#
    Continue? [Y/n] y
    root@analog:~#
