Morning,
I have the AD9081 evaluation board running on a custom carrier and consistently see glitching in the ADC data. Upon rebooting the system the glitching moves to a different channel, so it seems to be some sort of configuration error. See below screenshots of data processed with Pyadi-iio, and also with IIO Oscilloscope. Could you please advise what could be causing this issue?
The only change to the Vivado design was to change JESD mode, add some GPIO, and adjust the reference clock from 33.33MHz to 50MHz as per the carrier card I'm using. I have also attached my device tree below - perhaps the mode is invalid or the IIO functions can't handle the datarate? I have been connecting over the network so USB limitations should not be a concern. For reference I am running 4x ADCs at 4GSPS.
Thanks for your help!
Jack
// SPDX-License-Identifier: GPL-2.0 /* * Analog Devices AD9081-FMC-EBZ * https://wiki.analog.com/resources/tools-software/linux-drivers/iio-mxfe/ad9081 * https://wiki.analog.com/resources/eval/user-guides/ad9081_fmca_ebz/ad9081_fmca_ebz_hdl * * hdl_project: <ad9081_fmca_ebz/vck190> * board_revision: <> * * Copyright (C) 2019-2023 Analog Devices Inc. */ #include "versal-vck190-revA.dts" #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/iio/adc/adi,ad9081.h> #include <dt-bindings/jesd204/adxcvr.h> #include <dt-bindings/iio/frequency/hmc7044.h> /* RX path */ #define AD9081_RX_LANERATE_KHZ 24750000 #define AD9081_RX_LINK_CLK 375000000 /* TX path */ #define AD9081_TX_LANERATE_KHZ 24750000 #define AD9081_TX_LINK_CLK 375000000 / { model = "DTS Edit 2"; chosen { bootargs = "console=ttyAMA0 earlycon=pl011,mmio32,0xFF000000,115200n8 clk_ignore_unused root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait"; stdout-path = "serial0:115200"; }; fpga_axi: fpga-axi@0 { interrupt-parent = <&gic>; compatible = "simple-bus"; #address-cells = <0x1>; #size-cells = <0x1>; ranges = <0 0 0 0xffffffff>; clocks { rx_fixed_linerate: clock@0 { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <AD9081_RX_LANERATE_KHZ>; clock-output-names = "rx_lane_clk"; }; tx_fixed_linerate: clock@1 { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <AD9081_TX_LANERATE_KHZ>; clock-output-names = "tx_lane_clk"; }; rx_fixed_link_clk: clock@2 { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <AD9081_RX_LINK_CLK>; clock-output-names = "rx_link_clk"; }; tx_fixed_link_clk: clock@3 { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <AD9081_TX_LINK_CLK>; clock-output-names = "tx_link_clk"; }; }; axi_gpio: gpio@a4000000 { #gpio-cells = <2>; #interrupt-cells = <2>; clock-names = "s_axi_aclk"; clocks = <&versal_clk PMC_PL0_REF>; compatible = "xlnx,axi-gpio-2.0", "xlnx,xps-gpio-1.00.a"; gpio-controller; interrupt-controller; interrupt-names = "ip2intc_irpt"; interrupt-parent = <&gic>; interrupts = <0 84 4>; reg = <0xa4000000 0x1000>; xlnx,all-inputs = <0x0>; xlnx,all-inputs-2 = <0x0>; xlnx,all-outputs = <0x0>; xlnx,all-outputs-2 = <0x0>; xlnx,dout-default = <0x00000000>; xlnx,dout-default-2 = <0x00000000>; xlnx,gpio-width = <0x20>; xlnx,gpio2-width = <0x20>; xlnx,interrupt-present = <0x1>; xlnx,is-dual = <0x1>; xlnx,tri-default = <0xFFFFFFFF>; xlnx,tri-default-2 = <0xFFFFFFFF>; }; rx_dma: dma@bc420000 { compatible = "adi,axi-dmac-1.00.a"; reg = <0xbc420000 0x10000>; #dma-cells = <1>; #clock-cells = <0>; interrupts = <0 97 IRQ_TYPE_LEVEL_HIGH>; clocks = <&versal_clk PMC_PL1_REF>; adi,channels { #size-cells = <0>; #address-cells = <1>; dma-channel@0 { reg = <0>; adi,source-bus-type = <2>; adi,destination-bus-type = <0>; }; }; }; tx_dma: dma@bc430000 { compatible = "adi,axi-dmac-1.00.a"; reg = <0xbc430000 0x10000>; #dma-cells = <1>; #clock-cells = <0>; interrupts = <0 96 IRQ_TYPE_LEVEL_HIGH>; clocks = <&versal_clk PMC_PL1_REF>; adi,channels { #size-cells = <0>; #address-cells = <1>; dma-channel@0 { reg = <0>; adi,source-bus-type = <0>; adi,destination-bus-type = <2>; }; }; }; axi_ad9081_core_rx: axi-ad9081-rx-hpc@a4a10000 { compatible = "adi,axi-ad9081-rx-1.0"; reg = <0xa4a10000 0x8000>; dmas = <&rx_dma 0>; dma-names = "rx"; spibus-connected = <&trx0_ad9081>; jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_ad9081_rx_jesd 0 FRAMER_LINK0_RX>; }; axi_ad9081_core_tx: axi-ad9081-tx-hpc@a4b10000 { compatible = "adi,axi-ad9081-tx-1.0"; reg = <0xa4b10000 0x4000>; dmas = <&tx_dma 0>; dma-names = "tx"; clocks = <&trx0_ad9081 1>; clock-names = "sampl_clk"; spibus-connected = <&trx0_ad9081>; jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&axi_ad9081_tx_jesd 0 DEFRAMER_LINK0_TX>; }; axi_ad9081_rx_jesd: axi-jesd204-rx@a4a90000 { compatible = "adi,axi-jesd204-rx-1.0"; reg = <0xa4a90000 0x1000>; interrupts = <0 95 IRQ_TYPE_LEVEL_HIGH>; clocks = <&versal_clk PMC_PL0_REF>, <&hmc7044 10>, <&rx_fixed_link_clk>, <&rx_fixed_linerate>; clock-names = "s_axi_aclk", "device_clk", "link_clk", "lane_clk"; #clock-cells = <0>; clock-output-names = "jesd_rx_lane_clk"; jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&hmc7044 0 FRAMER_LINK0_RX>; }; axi_ad9081_tx_jesd: axi-jesd204-tx@a4b90000 { compatible = "adi,axi-jesd204-tx-1.0"; reg = <0xa4b90000 0x1000>; interrupts = <0 94 IRQ_TYPE_LEVEL_HIGH>; clocks = <&versal_clk PMC_PL0_REF>, <&hmc7044 6>, <&tx_fixed_link_clk>, <&tx_fixed_linerate>; clock-names = "s_axi_aclk", "device_clk", "link_clk", "lane_clk"; #clock-cells = <0>; clock-output-names = "jesd_tx_lane_clk"; jesd204-device; #jesd204-cells = <2>; jesd204-inputs = <&hmc7044 0 DEFRAMER_LINK0_TX>; }; axi_sysid_0: axi-sysid-0@a5000000 { compatible = "adi,axi-sysid-1.00.a"; reg = <0xa5000000 0x10000>; }; }; }; &gic { num_cpus = <2>; num_interrupts = <96>; }; &lpd_dma_chan0 { status = "okay"; }; &lpd_dma_chan1 { status = "okay"; }; &lpd_dma_chan2 { status = "okay"; }; &lpd_dma_chan3 { status = "okay"; }; &lpd_dma_chan4 { status = "okay"; }; &lpd_dma_chan5 { status = "okay"; }; &lpd_dma_chan6 { status = "okay"; }; &lpd_dma_chan7 { status = "okay"; }; &cci { status = "okay"; }; &smmu { status = "okay"; }; &i2c1 { status = "disabled"; }; &gpio1 { status = "okay"; }; &qspi { is-dual = <1>; num-cs = <1>; spi-rx-bus-width = <4>; spi-tx-bus-width = <4>; status = "okay"; }; &sdhci1 { clock-frequency = <199999985>; status = "okay"; }; &serial0 { cts-override ; device_type = "serial"; port-number = <0>; }; &spi0 { is-decoded-cs = <0>; num-cs = <3>; status = "okay"; }; &spi1 { is-decoded-cs = <0>; num-cs = <3>; status = "okay"; }; &ttc0 { status = "okay"; }; &ref_clk { clock-frequency = <50000000>; }; &gem0 { local-mac-address = [00 0a 35 ad 90 81]; }; &fpga_axi { axi_data_offload_tx: axi-data-offload-0@bc440000 { compatible = "adi,axi-data-offload-1.0.a"; reg = <0xbc440000 0x10000>; }; axi_data_offload_rx: axi-data-offload-1@bc450000 { compatible = "adi,axi-data-offload-1.0.a"; reg = <0xbc450000 0x10000>; }; }; &axi_ad9081_core_tx { adi,axi-data-offload-connected = <&axi_data_offload_tx>; adi,axi-pl-fifo-enable; }; #define fmc_spi spi0 &spi1 { status = "okay"; hmc7044: hmc7044@0 { #address-cells = <1>; #size-cells = <0>; #clock-cells = <1>; compatible = "adi,hmc7044"; reg = <0>; spi-max-frequency = <1000000>; jesd204-device; #jesd204-cells = <2>; jesd204-sysref-provider; adi,jesd204-max-sysref-frequency-hz = <2000000>; /* 2 MHz */ /* * There are different versions of the AD9081-FMCA-EBZ & AD9082-FMCA-EBZ * VCXO = 122.880 MHz, XO = 122.880MHz (AD9081-FMC-EBZ & AD9082-FMC-EBZ) * VCXO = 100.000 MHz, XO = 100.000MHz (AD9081-FMC-EBZ-A2 & AD9082-FMC-EBZ-A2) * To determine which board is which, read the freqency printed on the VCXO * or use the fru-dump utility: * #fru-dump -b /sys/bus/i2c/devices/15-0050/eeprom */ //adi,pll1-clkin-frequencies = <122880000 30720000 0 0>; //adi,vcxo-frequency = <122880000>; adi,pll1-clkin-frequencies = <100000000 10000000 0 0>; adi,pll1-ref-prio-ctrl = <0xE1>; /* prefer CLKIN1 -> CLKIN0 -> CLKIN2 -> CLKIN3 */ adi,pll1-ref-autorevert-enable; adi,vcxo-frequency = <100000000>; adi,pll1-loop-bandwidth-hz = <200>; adi,pll1-charge-pump-current-ua = <720>; adi,pfd1-maximum-limit-frequency-hz = <1000000>; /* 1 MHz */ adi,pll2-output-frequency = <3000000000>; adi,sysref-timer-divider = <1024>; adi,pulse-generator-mode = <0>; adi,clkin0-buffer-mode = <0x07>; adi,clkin1-buffer-mode = <0x07>; adi,oscin-buffer-mode = <0x15>; adi,gpi-controls = <0x00 0x00 0x00 0x00>; adi,gpo-controls = <0x37 0x33 0x00 0x00>; clock-output-names = "hmc7044_out0", "hmc7044_out1", "hmc7044_out2", "hmc7044_out3", "hmc7044_out4", "hmc7044_out5", "hmc7044_out6", "hmc7044_out7", "hmc7044_out8", "hmc7044_out9", "hmc7044_out10", "hmc7044_out11", "hmc7044_out12", "hmc7044_out13"; hmc7044_c0: channel@0 { reg = <0>; adi,extended-name = "CORE_CLK_RX"; adi,divider = <8>; // 375 adi,driver-mode = <HMC7044_DRIVER_MODE_LVDS>; // LVDS }; hmc7044_c2: channel@2 { reg = <2>; adi,extended-name = "DEV_REFCLK"; adi,divider = <8>; // 375 adi,driver-mode = <HMC7044_DRIVER_MODE_LVDS>; // LVDS }; hmc7044_c3: channel@3 { reg = <3>; adi,extended-name = "DEV_SYSREF"; adi,divider = <768>; // 3.90625 adi,driver-mode = <HMC7044_DRIVER_MODE_LVDS>; // LVDS adi,jesd204-sysref-chan; }; hmc7044_c6: channel@6 { reg = <6>; adi,extended-name = "CORE_CLK_TX"; adi,divider = <12>; // 250 = LR/66*4/6 adi,driver-mode = <HMC7044_DRIVER_MODE_LVDS>; // LVDS }; hmc7044_c8: channel@8 { reg = <8>; adi,extended-name = "FPGA_REFCLK1"; adi,divider = <4>; // 750 adi,driver-mode = <HMC7044_DRIVER_MODE_LVDS>; // LVDS }; hmc7044_c10: channel@10 { reg = <10>; adi,extended-name = "CORE_CLK_RX"; adi,divider = <12>; // 250 = LR/66*4/6 adi,driver-mode = <HMC7044_DRIVER_MODE_LVDS>; // LVDS }; hmc7044_c12: channel@12 { reg = <12>; adi,extended-name = "FPGA_REFCLK"; adi,divider = <8>; // 375 adi,driver-mode = <HMC7044_DRIVER_MODE_LVDS>; // LVDS }; hmc7044_c13: channel@13 { reg = <13>; adi,extended-name = "FPGA_SYSREF"; adi,divider = <768>; // 3.90625 adi,driver-mode = <HMC7044_DRIVER_MODE_LVDS>; // LVDS adi,jesd204-sysref-chan; }; }; }; &fmc_spi { trx0_ad9081: ad9081@0 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,ad9081"; reg = <0>; spi-max-frequency = <5000000>; /* Clocks */ clocks = <&hmc7044 2>; clock-names = "dev_clk"; clock-output-names = "rx_sampl_clk", "tx_sampl_clk"; #clock-cells = <1>; reset-gpios = <&axi_gpio 23 0>; sysref-req-gpios = <&axi_gpio 11 0>; rx2-enable-gpios = <&axi_gpio 25 0>; rx1-enable-gpios = <&axi_gpio 24 0>; tx2-enable-gpios = <&axi_gpio 27 0>; tx1-enable-gpios = <&axi_gpio 26 0>; jesd204-device; #jesd204-cells = <2>; jesd204-top-device = <0>; /* This is the TOP device */ jesd204-link-ids = <FRAMER_LINK0_RX DEFRAMER_LINK0_TX>; jesd204-inputs = <&axi_ad9081_core_rx 0 FRAMER_LINK0_RX>, <&axi_ad9081_core_tx 0 DEFRAMER_LINK0_TX>; adi,tx-dacs { #size-cells = <0>; #address-cells = <1>; adi,dac-frequency-hz = /bits/ 64 <4000000000>; adi,main-data-paths { #address-cells = <1>; #size-cells = <0>; adi,interpolation = <1>; ad9081_dac0: dac@0 { reg = <0>; adi,nco-frequency-shift-hz = /bits/ 64 <0>; /* 200 MHz */ }; ad9081_dac1: dac@1 { reg = <1>; adi,nco-frequency-shift-hz = /bits/ 64 <0>; /* 1 GHz */ }; ad9081_dac2: dac@2 { reg = <2>; adi,nco-frequency-shift-hz = /bits/ 64 <0>; /* 2 GHz */ }; ad9081_dac3: dac@3 { reg = <3>; adi,nco-frequency-shift-hz = /bits/ 64 <0>; /* 3 GHz */ }; }; adi,channelizer-paths { #address-cells = <1>; #size-cells = <0>; adi,interpolation = <1>; }; adi,jesd-links { #size-cells = <0>; #address-cells = <1>; ad9081_tx_jesd_l0: link@0 { #address-cells = <1>; #size-cells = <0>; reg = <0>; adi,logical-lane-mapping = /bits/ 8 <0 2 7 6 1 5 4 3>; adi,link-mode = <35>; /* JESD Quick Configuration Mode */ adi,subclass = <1>; /* JESD SUBCLASS 0,1,2 */ adi,version = <2>; /* JESD VERSION 0=204A,1=204B,2=204C */ adi,dual-link = <0>; /* JESD Dual Link Mode */ adi,converters-per-device = <4>; /* JESD M */ adi,octets-per-frame = <3>; /* JESD F */ adi,frames-per-multiframe = <256>; /* JESD K */ adi,converter-resolution = <12>; /* JESD N */ adi,bits-per-sample = <12>; /* JESD NP' */ adi,control-bits-per-sample = <0>; /* JESD CS */ adi,lanes-per-device = <8>; /* JESD L */ adi,samples-per-converter-per-frame = <4>; /* JESD S */ adi,high-density = <0>; /* JESD HD */ adi,tpl-phase-adjust = <0x3b>; }; }; }; adi,rx-adcs { #size-cells = <0>; #address-cells = <1>; adi,adc-frequency-hz = /bits/ 64 <4000000000>; adi,main-data-paths { #address-cells = <1>; #size-cells = <0>; ad9081_adc0: adc@0 { reg = <0>; adi,decimation = <1>; adi,nco-mixer-mode = <AD9081_ADC_NCO_ZIF>; adi,crossbar-select = <&ad9081_rx_fddc_chan0>; }; ad9081_adc1: adc@1 { reg = <1>; adi,decimation = <1>; adi,nco-mixer-mode = <AD9081_ADC_NCO_ZIF>; adi,crossbar-select = <&ad9081_rx_fddc_chan1>; }; ad9081_adc2: adc@2 { reg = <2>; adi,decimation = <1>; adi,nco-mixer-mode = <AD9081_ADC_NCO_ZIF>; adi,crossbar-select = <&ad9081_rx_fddc_chan4>; }; ad9081_adc3: adc@3 { reg = <3>; adi,decimation = <1>; adi,nco-mixer-mode = <AD9081_ADC_NCO_ZIF>; adi,crossbar-select = <&ad9081_rx_fddc_chan5>; }; }; adi,channelizer-paths { #address-cells = <1>; #size-cells = <0>; ad9081_rx_fddc_chan0: channel@0 { reg = <0>; adi,decimation = <1>; adi,gain = <0>; /* 2048 * 10^(gain_dB/20) */ adi,nco-frequency-shift-hz = /bits/ 64 <0>; }; ad9081_rx_fddc_chan1: channel@1 { reg = <1>; adi,decimation = <1>; adi,gain = <0>; /* 2048 * 10^(gain_dB/20) */ adi,nco-frequency-shift-hz = /bits/ 64 <0>; }; ad9081_rx_fddc_chan4: channel@4 { reg = <4>; adi,decimation = <1>; adi,gain = <0>; /* 2048 * 10^(gain_dB/20) */ adi,nco-frequency-shift-hz = /bits/ 64 <0>; }; ad9081_rx_fddc_chan5: channel@5 { reg = <5>; adi,decimation = <1>; adi,gain = <0>; /* 2048 * 10^(gain_dB/20) */ adi,nco-frequency-shift-hz = /bits/ 64 <0>; }; }; adi,jesd-links { #size-cells = <0>; #address-cells = <1>; ad9081_rx_jesd_l0: link@0 { reg = <0>; adi,converter-select = <&ad9081_rx_fddc_chan0 FDDC_I>, <&ad9081_rx_fddc_chan1 FDDC_I>, <&ad9081_rx_fddc_chan4 FDDC_Q>, <&ad9081_rx_fddc_chan5 FDDC_Q>; adi,logical-lane-mapping = /bits/ 8 <2 0 7 6 5 4 3 1>; adi,link-mode = <27>; /* JESD Quick Configuration Mode */ adi,subclass = <1>; /* JESD SUBCLASS 0,1,2 */ adi,version = <2>; /* JESD VERSION 0=204A,1=204B,2=204C */ adi,dual-link = <0>; /* JESD Dual Link Mode */ adi,converters-per-device = <4>; /* JESD M */ adi,octets-per-frame = <3>; /* JESD F */ adi,frames-per-multiframe = <256>; /* JESD K */ adi,converter-resolution = <12>; /* JESD N */ adi,bits-per-sample = <12>; /* JESD NP' */ adi,control-bits-per-sample = <0>; /* JESD CS */ adi,lanes-per-device = <8>; /* JESD L */ adi,samples-per-converter-per-frame = <4>; /* JESD S */ adi,high-density = <0>; /* JESD HD */ }; }; }; }; };
