I am having the EVAL_BOARD AD7768.
I have to interface this ad7768 eval board to zedboard.
I use this link to get image: https://wiki.analog.com/resources/tools-software/linux-software/kuiper-linux
from above link i fallowed all the steps. flash the image on sd card. I got different type of ad folder in that i went folder name==> zynq-zed-adv7511-ad7768
i got BOOT.BIN, devicetree.dtb, bootgen_sysfiles.tgz. There is no file image.ub. why ?
on Uart I am able to see:
U-Boot 2018.01-21441-ga6ab387 (Aug 31 2022 - 11:43:06 +0100), Build: jenkins-development-build_uboot-2
Model: Zynq Zed Development Board
Board: Xilinx Zynq
Silicon: v3.1
DRAM: ECC disabled 512 MiB
MMC: sdhci@e0100000: 0 (SD)
SF: Detected s25fl256s_64k with page size 256 Bytes, erase size 64 KiB, total 32 MiB
*** Warning - bad CRC, using default environment
In: serial@e0001000
Out: serial@e0001000
Err: serial@e0001000
Net: ZYNQ GEM: e000b000, phyaddr 0, interface rgmii-id
eth0: ethernet@e000b000
reading uEnv.txt
407 bytes read in 18 ms (21.5 KiB/s)
Importing environment from SD ...
Hit any key to stop autoboot: 0
Device: sdhci@e0100000
Manufacturer ID: 27
OEM: 5048
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 28.9 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading uEnv.txt
Loaded environment from uEnv.txt
Running uenvcmd ...
Copying Linux from SD to RAM...
Unable to read file uImage
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
starting USB...
USB0: USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
ethernet@e000b000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
missing environment variable: pxefile_addr_r
Zynq>
Please provide some solution.
