ZCU102+FMCOMMS2 AD9361 project on Petalinux
Product Number: AD9361
Software Version: Petalinux 2023.1
I built the the ZCU102+FMCOMMS2 AD9361 project on Petalinux.
But when I am booting from the SD card I am getting this:
Error: implausible serial number 0 read from EEPROM
Xilinx Zynq MP First Stage Boot Loader
Release 2022.2   May  8 2023  -  10:25:19
NOTICE:  BL31: v2.6(release):xlnx_rebase_v2.6_2022.1_update3-18-g0897efd45
NOTICE:  BL31: Built : 03:55:03, Sep  9 2022
U-Boot 2022.01 (Sep 20 2022 - 06:35:33 +0000)
CPU:   ZynqMP
Silicon: v3
Board: Xilinx ZynqMP
DRAM:  8 GiB
PMUFW:  v1.1
PMUFW no permission to change config object
EL Level:       EL2
Chip ID:        zu11eg
NAND:  0 MiB
MMC:   mmc@ff160000: 0
Loading Environment from FAT... *** Error - No Valid Environment Area found
*** Warning - bad env area, using default environment
In:    serial
Out:   serial
Err:   serial
Bootmode: SD_MODE
Reset reason:   EXTERNAL
Net:   FEC: can't find phy-handle
ZYNQ GEM: ff0c0000, mdio bus ff0c0000, phyaddr 0, interface rgmii-id
Warning: ethernet@ff0c0000 (eth0) using random MAC address - e2:79:ee:3c:0e:72
eth0: ethernet@ff0c0000FEC: can't find phy-handle
ZYNQ GEM: ff0e0000, mdio bus ff0e0000, phyaddr 0, interface rgmii-id
Warning: ethernet@ff0e0000 (eth1) using random MAC address - ae:db:05:24:fa:47
, eth1: ethernet@ff0e0000
scanning bus for devices...
starting USB...
Bus usb@fe200000: Register 2000440 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus usb@fe200000 for devices... 2 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
2777 bytes read in 17 ms (159.2 KiB/s)
## Executing script at 20000000
Trying to load boot images from mmc0
54295748 bytes read in 3410 ms (15.2 MiB/s)
## Loading kernel from FIT Image at 10000000 ...
   Using 'conf-system-top.dtb' configuration
   Trying 'kernel-1' kernel subimage
     Description:  Linux kernel
     Created:      2022-10-03   7:50:07 UTC
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x100000fc
     Data Size:    9328451 Bytes = 8.9 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00200000
     Entry Point:  0x00200000
     Hash algo:    sha256
     Hash value:   b92b9f8e8f9a3b7e556b6b1bd62331e9e8be647be75c559a1cc38c79212e6        0af
   Verifying Hash Integrity ... sha256+ OK
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk-1' ramdisk subimage
     Description:  petalinux-image-minimal
     Type:         RAMDisk Image
     Compression:  uncompressed
     Data Start:   0x108ef008
     Data Size:    44926788 Bytes = 42.8 MiB
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha256
     Hash value:   45985ff7d75b2a2c0104b8c9da43310c02559b95d7d967c80f12327d4cac8        783
## Loading fdt from FIT Image at 10000000 ...
   Trying 'fdt-system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x108e5950
     Data Size:    38376 Bytes = 37.5 KiB
     Hash algo:    sha256
     Hash value:   ffa6a05f5b8a38203dad0aa0b2a6eb33592b16f247884c584517dbe5f5f19        9df
   Booting using the fdt blob at 0x108e5950
   Uncompressing Kernel Image
   Loading Ramdisk to 7911f000, end 7bbf7744 ... OK
   Loading Device Tree to 0000000079112000, end 000000007911e5e7 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.15.36-xilinx-v2022.2 (oe-user@oe-host) (aarch64-x        ilinx-linux-gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.37.20210721) #1 SMP Mon Oc        t 3 07:50:07 UTC 2022
[    0.000000] Machine model: xlnx,zynqmp
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] printk: bootconsole [cdns0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000097fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000007fefffff]
[    0.000000]   node   0: [mem 0x0000000800000000-0x000000097fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000097fffffff]
[    0.000000] On node 0, zone Normal: 256 pages in unavailable ranges
[    0.000000] cma: Reserved 256 MiB at 0x0000000069000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 18 pages/cpu s34776 r8192 d30760 u73728
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2064132
[    0.000000] Kernel command line:  earlycon console=ttyPS0,115200 clk_ignore_u        nused root=/dev/ram0 rw
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 byte        s, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes,        linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x000000007bf00000-0x000000007ff0000        0] (64MB)
[    0.000000] Memory: 7833152K/8387584K available (14016K kernel code, 994K rwd        ata, 3944K rodata, 2176K init, 573K bss, 292288K reserved, 262144K cma-reserved)
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=16 to nr_cpu_ids=4.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jif        fies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x474/0x6d8 wit        h crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 50.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:        0xb8812736b, max_idle_ns: 440795202655 ns
[    0.000000] sched_clock: 56 bits at 50MHz, resolution 20ns, wraps every 43980        46511100ns
[    0.008270] Console: colour dummy device 80x25
[    0.012395] Calibrating delay loop (skipped), value calculated using timer fr        equency.. 100.00 BogoMIPS (lpj=200000)
[    0.022752] pid_max: default: 32768 minimum: 301
[    0.027542] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, li        near)
[    0.034879] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 byte        s, linear)
[    0.043817] rcu: Hierarchical SRCU implementation.
[    0.047787] EFI services will not be available.
[    0.052207] smp: Bringing up secondary CPUs ...
[    0.056926] Detected VIPT I-cache on CPU1
[    0.056964] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.057332] Detected VIPT I-cache on CPU2
[    0.057354] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.057700] Detected VIPT I-cache on CPU3
[    0.057721] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.057761] smp: Brought up 1 node, 4 CPUs
[    0.092037] SMP: Total of 4 processors activated.
[    0.096709] CPU features: detected: 32-bit EL0 Support
[    0.101813] CPU features: detected: CRC32 instructions
[    0.106951] CPU: All CPU(s) started at EL2
[    0.110993] alternatives: patching kernel code
[    0.116302] devtmpfs: initialized
[    0.123849] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 7645041785100000 ns
[    0.128379] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.140877] pinctrl core: initialized pinctrl subsystem
[    0.141334] DMI not present or invalid.
[    0.144510] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.151086] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.157389] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic a        llocations
[    0.165240] audit: initializing netlink subsys (disabled)
[    0.170644] audit: type=2000 audit(0.112:1): state=initialized audit_enabled=        0 res=1
[    0.170973] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.185068] ASID allocator initialised with 65536 entries
[    0.190475] Serial: AMBA PL011 UART driver
[    0.209585] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.210653] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.217308] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.223968] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    1.198829] cryptd: max_cpu_qlen set to 1000
[    1.220454] DRBG: Continuing without Jitter RNG
[    1.319320] raid6: neonx8   gen()  2357 MB/s
[    1.387372] raid6: neonx8   xor()  1752 MB/s
[    1.455423] raid6: neonx4   gen()  2421 MB/s
[    1.523477] raid6: neonx4   xor()  1716 MB/s
[    1.591540] raid6: neonx2   gen()  2285 MB/s
[    1.659584] raid6: neonx2   xor()  1566 MB/s
[    1.727651] raid6: neonx1   gen()  1951 MB/s
[    1.795700] raid6: neonx1   xor()  1339 MB/s
[    1.863757] raid6: int64x8  gen()  1508 MB/s
[    1.931815] raid6: int64x8  xor()   854 MB/s
[    1.999868] raid6: int64x4  gen()  1766 MB/s
[    2.067930] raid6: int64x4  xor()   936 MB/s
[    2.135995] raid6: int64x2  gen()  1542 MB/s
[    2.204040] raid6: int64x2  xor()   827 MB/s
[    2.272113] raid6: int64x1  gen()  1140 MB/s
[    2.340168] raid6: int64x1  xor()   571 MB/s
[    2.340205] raid6: using algorithm neonx4 gen() 2421 MB/s
[    2.344160] raid6: .... xor() 1716 MB/s, rmw enabled
[    2.349091] raid6: using neon recovery algorithm
[    2.354084] iommu: Default domain type: Translated
[    2.358522] iommu: DMA domain TLB invalidation policy: strict mode
[    2.364962] SCSI subsystem initialized
[    2.368590] usbcore: registered new interface driver usbfs
[    2.373946] usbcore: registered new interface driver hub
[    2.379211] usbcore: registered new device driver usb
[    2.384270] mc: Linux media interface: v0.10
[    2.388464] videodev: Linux video capture interface: v2.00
[    2.393929] pps_core: LinuxPPS API ver. 1 registered
[    2.398829] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome        tti <giometti@linux.it>
[    2.407918] PTP clock support registered
[    2.411819] EDAC MC: Ver: 3.0.0
[    2.415177] zynqmp-ipi-mbox mailbox@ff990400: Registered ZynqMP IPI mbox with        TX/RX channels.
[    2.423573] FPGA manager framework
[    2.426866] Advanced Linux Sound Architecture Driver Initialized.
[    2.433116] Bluetooth: Core ver 2.22
[    2.436381] NET: Registered PF_BLUETOOTH protocol family
[    2.441647] Bluetooth: HCI device and connection manager initialized
[    2.447964] Bluetooth: HCI socket layer initialized
[    2.452806] Bluetooth: L2CAP socket layer initialized
[    2.457828] Bluetooth: SCO socket layer initialized
[    2.462969] clocksource: Switched to clocksource arch_sys_counter
[    2.468840] VFS: Disk quotas dquot_6.6.0
[    2.472647] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    2.483411] NET: Registered PF_INET protocol family
[    2.484463] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, li        near)
[    2.494450] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 6553        6 bytes, linear)
[    2.500367] TCP established hash table entries: 65536 (order: 7, 524288 bytes        , linear)
[    2.508529] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, line        ar)
[    2.516241] TCP: Hash tables configured (established 65536 bind 65536)
[    2.522073] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    2.528879] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear        )
[    2.536119] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    2.541889] RPC: Registered named UNIX socket transport module.
[    2.547445] RPC: Registered udp transport module.
[    2.552110] RPC: Registered tcp transport module.
[    2.556778] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.563182] PCI: CLS 0 bytes, default 64
[    2.567230] Trying to unpack rootfs image as initramfs...
[    2.579150] armv8-pmu pmu: hw perfevents: no interrupt-affinity property, gue        ssing.
[    2.581621] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters av        ailable
[    4.446877] Freeing initrd memory: 43872K
[    4.499112] Initialise system trusted keyrings
[    4.499239] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    4.505060] NFS: Registering the id_resolver key type
[    4.509360] Key type id_resolver registered
[    4.513496] Key type id_legacy registered
[    4.517489] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    4.524144] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering        ...
[    4.531500] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    4.570572] NET: Registered PF_ALG protocol family
[    4.570617] xor: measuring software checksum speed
[    4.578257]    8regs           :  2609 MB/sec
[    4.581983]    32regs          :  3090 MB/sec
[    4.586989]    arm64_neon      :  2548 MB/sec
[    4.587447] xor: using function: 32regs (3090 MB/sec)
[    4.592471] Key type asymmetric registered
[    4.596535] Asymmetric key parser 'x509' registered
[    4.601411] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        44)
[    4.608734] io scheduler mq-deadline registered
[    4.613233] io scheduler kyber registered
[    4.641953] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    4.643613] Serial: AMBA driver
[    4.646454] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    4.655771] brd: module loaded
[    4.659035] loop: module loaded
[    4.660156] mtdoops: mtd device (mtddev=name/number) must be supplied
[    4.666937] tun: Universal TUN/TAP device driver, 1.6
[    4.669484] CAN device driver interface
[    4.673743] usbcore: registered new interface driver asix
[    4.678610] usbcore: registered new interface driver ax88179_178a
[    4.684652] usbcore: registered new interface driver cdc_ether
[    4.690439] usbcore: registered new interface driver net1080
[    4.696061] usbcore: registered new interface driver cdc_subset
[    4.701943] usbcore: registered new interface driver zaurus
[    4.707488] usbcore: registered new interface driver cdc_ncm
[    4.713555] usbcore: registered new interface driver cdc_acm
[    4.718709] cdc_acm: USB Abstract Control Model driver for USB modems and ISD        N adapters
[    4.726740] usbcore: registered new interface driver uas
[    4.731973] usbcore: registered new interface driver usb-storage
[    4.737958] usbcore: registered new interface driver usbserial_generic
[    4.744413] usbserial: USB Serial support registered for generic
[    4.750383] usbcore: registered new interface driver pl2303
[    4.755912] usbserial: USB Serial support registered for pl2303
[    4.762372] rtc_zynqmp ffa60000.rtc: registered as rtc0
[    4.766985] rtc_zynqmp ffa60000.rtc: setting system clock to 1970-01-01T00:00        :09 UTC (9)
[    4.775058] i2c_dev: i2c /dev entries driver
[    4.780631] usbcore: registered new interface driver uvcvideo
[    4.785307] Bluetooth: HCI UART driver ver 2.3
[    4.789380] Bluetooth: HCI UART protocol H4 registered
[    4.794482] Bluetooth: HCI UART protocol BCSP registered
[    4.799771] Bluetooth: HCI UART protocol LL registered
[    4.804861] Bluetooth: HCI UART protocol ATH3K registered
[    4.810240] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    4.816481] Bluetooth: HCI UART protocol Intel registered
[    4.821829] Bluetooth: HCI UART protocol QCA registered
[    4.827027] usbcore: registered new interface driver bcm203x
[    4.832649] usbcore: registered new interface driver bpa10x
[    4.838186] usbcore: registered new interface driver bfusb
[    4.843634] usbcore: registered new interface driver btusb
[    4.849094] usbcore: registered new interface driver ath3k
[    4.854703] EDAC MC0: Giving out device to module 1 controller synps_ddr_cont        roller: DEV synps_edac (INTERRUPT)
[    4.864662] EDAC DEVICE0: Giving out device to module edac controller cache_e        rr: DEV edac (POLLED)
[    4.873590] EDAC DEVICE1: Giving out device to module zynqmp-ocm-edac control        ler zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    4.885926] sdhci: Secure Digital Host Controller Interface driver
[    4.891713] sdhci: Copyright(c) Pierre Ossman
[    4.896033] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.901914] ledtrig-cpu: registered to indicate activity on CPUs
[    4.907720] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    4.914089] zynqmp_firmware_probe Platform Management API v1.1
[    4.919823] zynqmp_firmware_probe Trustzone version v1.0
[    4.950034] securefw securefw: securefw probed
[    4.950147] zynqmp_aes firmware:zynqmp-firmware:zynqmp-aes: The zynqmp-aes dr        iver shall be deprecated in 2022.2 and removed in 2023.1
[    4.961059] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[    4.966425] zynqmp_aes firmware:zynqmp-firmware:zynqmp-aes: AES Successfully        Registered
[    4.974455] zynqmp-keccak-384 firmware:zynqmp-firmware:sha384: The zynqmp-sha        -deprecated driver shall be deprecated in 2022.2 and removed in 2023.1 release
[    4.988258] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[    4.994512] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[    5.000022] usbcore: registered new interface driver usbhid
[    5.005414] usbhid: USB HID core driver
[    5.011931] ARM CCI_400_r1 PMU driver probed
[    5.012475] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    5.020200] usbcore: registered new interface driver snd-usb-audio
[    5.026664] pktgen: Packet Generator for packet performance testing. Version:        2.75
[    5.034875] Initializing XFRM netlink socket
[    5.037834] NET: Registered PF_INET6 protocol family
[    5.043171] Segment Routing with IPv6
[    5.046333] In-situ OAM (IOAM) with IPv6
[    5.050283] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    5.056413] NET: Registered PF_PACKET protocol family
[    5.061127] NET: Registered PF_KEY protocol family
[    5.065888] can: controller area network core
[    5.070225] NET: Registered PF_CAN protocol family
[    5.074962] can: raw protocol
[    5.077896] can: broadcast manager protocol
[    5.082054] can: netlink gateway - max_hops=1
[    5.086468] Bluetooth: RFCOMM TTY layer initialized
[    5.091226] Bluetooth: RFCOMM socket layer initialized
[    5.096333] Bluetooth: RFCOMM ver 1.11
[    5.100046] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    5.105319] Bluetooth: BNEP filters: protocol multicast
[    5.110510] Bluetooth: BNEP socket layer initialized
[    5.115438] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    5.121323] Bluetooth: HIDP socket layer initialized
[    5.126278] 8021q: 802.1Q VLAN Support v1.8
[    5.130502] 9pnet: Installing 9P2000 support
[    5.134659] Key type dns_resolver registered
[    5.139006] registered taskstats version 1
[    5.142942] Loading compiled-in X.509 certificates
[    5.148726] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[    5.162336] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 54, base_baud =        6250000) is a xuartps
[    5.171364] printk: console [ttyPS0] enabled
[    5.175659] printk: bootconsole [cdns0] disabled
[    5.184972] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 55, base_baud =        6250000) is a xuartps
[    5.198377] of-fpga-region fpga-full: FPGA Region probed
[    5.204208] nwl-pcie fd0e0000.pcie: host bridge /axi/pcie@fd0e0000 ranges:
[    5.211107] nwl-pcie fd0e0000.pcie:      MEM 0x00e0000000..0x00efffffff -> 0x        00e0000000
[    5.219112] nwl-pcie fd0e0000.pcie:      MEM 0x0600000000..0x07ffffffff -> 0x        0600000000
[    6.227265] nwl-pcie fd0e0000.pcie: PHY link never came up
[    6.232760] nwl-pcie fd0e0000.pcie: HW Initialization failed
[    6.238469] nwl-pcie: probe of fd0e0000.pcie failed with error -110
[    6.245408] xilinx-zynqmp-dma fd500000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.253497] xilinx-zynqmp-dma fd510000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.261567] xilinx-zynqmp-dma fd520000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.269629] xilinx-zynqmp-dma fd530000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.277702] xilinx-zynqmp-dma fd540000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.285760] xilinx-zynqmp-dma fd550000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.293837] xilinx-zynqmp-dma fd560000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.301900] xilinx-zynqmp-dma fd570000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.310050] xilinx-zynqmp-dma ffa80000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.318119] xilinx-zynqmp-dma ffa90000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.326189] xilinx-zynqmp-dma ffaa0000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.334250] xilinx-zynqmp-dma ffab0000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.342319] xilinx-zynqmp-dma ffac0000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.350390] xilinx-zynqmp-dma ffad0000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.358461] xilinx-zynqmp-dma ffae0000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.366524] xilinx-zynqmp-dma ffaf0000.dma-controller: ZynqMP DMA driver Prob        e success
[    6.374739] spi_master spi0: /axi/spi@ff0f0000/flash@0 has no valid 'reg' pro        perty (-22)
[    6.382838] spi_master spi0: Failed to create SPI device for /axi/spi@ff0f000        0/flash@0
[    6.391256] xilinx_can ff060000.can can0: TDC Offset value not in range
[    6.398241] macb ff0c0000.ethernet: Not enabling partial store and forward
[    6.410282] macb ff0c0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0c        0000 irq 39 (e2:79:ee:3c:0e:72)
[    6.410837] zynqmp_pll_disable() clock disable failed for dpll_int, ret = -13
[    6.427313] macb ff0e0000.ethernet: Not enabling partial store and forward
[    6.439132] macb ff0e0000.ethernet eth1: Cadence GEM rev 0x50070106 at 0xff0e        0000 irq 40 (ae:db:05:24:fa:47)
[    6.449341] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    6.455860] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[    6.462320] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[    6.468788] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[    6.496123] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    6.501614] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus nu        mber 1
[    6.509360] xhci-hcd xhci-hcd.1.auto: hcc params 0x0238f625 hci version 0x100        quirks 0x0000000002010090
[    6.518764] xhci-hcd xhci-hcd.1.auto: irq 57, io mem 0xfe200000
[    6.524877] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc        dDevice= 5.15
[    6.533138] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
[    6.540358] usb usb1: Product: xHCI Host Controller
[    6.545230] usb usb1: Manufacturer: Linux 5.15.36-xilinx-v2022.2 xhci-hcd
[    6.552019] usb usb1: SerialNumber: xhci-hcd.1.auto
[    6.557207] hub 1-0:1.0: USB hub found
[    6.560966] hub 1-0:1.0: 1 port detected
[    6.565063] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    6.570543] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus nu        mber 2
[    6.578202] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    6.584857] usb usb2: We don't know the algorithms for LPM for this host, dis        abling LPM.
[    6.593038] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc        dDevice= 5.15
[    6.601301] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
[    6.608513] usb usb2: Product: xHCI Host Controller
[    6.613380] usb usb2: Manufacturer: Linux 5.15.36-xilinx-v2022.2 xhci-hcd
[    6.620162] usb usb2: SerialNumber: xhci-hcd.1.auto
[    6.625268] hub 2-0:1.0: USB hub found
[    6.629031] hub 2-0:1.0: 1 port detected
[    6.633609] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 42
[    6.642665] of_cfs_init
[    6.645146] of_cfs_init: OK
[    6.648037] clk: Not disabling unused clocks
[    6.652546] ALSA device list:
[    6.655507]   No soundcards found.
[    6.672769] mmc0: SDHCI controller on ff160000.mmc [ff160000.mmc] using ADMA        64-bit
[    6.680952] Freeing unused kernel memory: 2176K
[    6.685535] Run /init as init process
[    6.698490] systemd[1]: System time before build time, advancing clock.
[    6.708466] systemd[1]: systemd 249.7+ running in system mode (+PAM -AUDIT -S        ELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL        -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUAL        ITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD +XKBCOMMON +UTMP +SYSVINIT def        ault-hierarchy=hybrid)
[    6.738732] systemd[1]: Detected architecture arm64.
Welcome to PetaLinux 2022.2_release_S10071807 (honister)!
[    6.779124] systemd[1]: Hostname set to <9z1-petalinux-zu11eg-20222>.
[    6.785702] random: systemd: uninitialized urandom read (16 bytes read)
[    6.791347] mmc0: new high speed MMC card at address 0001
[    6.792342] systemd[1]: Initializing machine ID from random generator.
[    6.798138] mmcblk0: mmc0:0001 HCG4a2 59.2 GiB
[    6.810115]  mmcblk0: p1
[    6.813018] mmcblk0boot0: mmc0:0001 HCG4a2 8.00 MiB
[    6.819286] mmcblk0boot1: mmc0:0001 HCG4a2 8.00 MiB
[    6.823041] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    6.838605] systemd-sysv-generator[234]: SysV service '/etc/init.d/watchdog-i        nit' lacks a native systemd unit file. Automatically generating a unit file for        compatibility. Please update package to include a native systemd unit file, in o        rder to make it more safe and robust.
[    6.862910] mmcblk0rpmb: mmc0:0001 HCG4a2 4.00 MiB, chardev (239:0)
[    6.864711] systemd-sysv-generator[234]: SysV service '/etc/init.d/sshd' lack        s a native systemd unit file. Automatically generating a unit file for compatibi        lity. Please update package to include a native systemd unit file, in order to m        ake it more safe and robust.
[    6.893293] systemd-sysv-generator[234]: SysV service '/etc/init.d/rng-tools'        lacks a native systemd unit file. Automatically generating a unit file for comp        atibility. Please update package to include a native systemd unit file, in order        to make it more safe and robust.
[    6.917491] systemd-sysv-generator[234]: SysV service '/etc/init.d/nfsserver'        lacks a native systemd unit file. Automatically generating a unit file for comp        atibility. Please update package to include a native systemd unit file, in order        to make it more safe and robust.
[    6.941502] systemd-sysv-generator[234]: SysV service '/etc/init.d/nfscommon'        lacks a native systemd unit file. Automatically generating a unit file for comp        atibility. Please update package to include a native systemd unit file, in order        to make it more safe and robust.
[    6.965766] systemd-sysv-generator[234]: SysV service '/etc/init.d/inetd.busy        box' lacks a native systemd unit file. Automatically generating a unit file for        compatibility. Please update package to include a native systemd unit file, in o        rder to make it more safe and robust.
[    7.011130] usb 1-1: New USB device found, idVendor=04b4, idProduct=6560, bcd        Device=90.15
[    7.019332] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    7.064915] hub 1-1:1.0: USB hub found
[    7.068706] hub 1-1:1.0: 4 ports detected
[    7.174069] systemd[1]: Queued start job for default target Multi-User System        .
[    7.182160] random: systemd: uninitialized urandom read (16 bytes read)
[    7.213649] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    7.235083] random: systemd: uninitialized urandom read (16 bytes read)
[    7.242971] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    7.264124] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    7.288024] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    7.311224] systemd[1]: Started Dispatch Password Requests to Console Directo        ry Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    7.335151] systemd[1]: Started Forward Password Requests to Wall Directory W        atch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    7.359207] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[    7.375063] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    7.395047] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[    7.411077] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[    7.427448] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    7.451055] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    7.471322] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    7.487187] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    7.511476] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[    7.531242] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    7.551311] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    7.567461] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    7.591308] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    7.611241] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    7.631257] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[    7.657382] systemd[1]: Mounting Huge Pages File System...
[    7.677510] systemd[1]: Mounting POSIX Message Queue File System...
[    7.701634] systemd[1]: Mounting Kernel Debug File System...
[    7.719372] systemd[1]: Condition check resulted in Kernel Trace File System        being skipped.
[    7.730399] systemd[1]: Mounting Temporary Directory /tmp...
[    7.747292] systemd[1]: Condition check resulted in Create List of Static Dev        ice Nodes being skipped.
[    7.759394] systemd[1]: Starting Load Kernel Module configfs...
[    7.778022] systemd[1]: Starting Load Kernel Module drm...
[    7.797792] systemd[1]: Starting Load Kernel Module fuse...
[    7.817876] systemd[1]: Starting RPC Bind...
[    7.831136] systemd[1]: Condition check resulted in File System Check on Root        Device being skipped.
[    7.840868] systemd[1]: Condition check resulted in Load Kernel Modules being        skipped.
[    7.851066] systemd[1]: Mounting NFSD configuration filesystem...
[    7.873798] systemd[1]: Starting Remount Root and Kernel File Systems...
         Starting Remount Root and Kernel File Systems    7.885347] tmpfs: Unkno        wn parameter 'stri'
0m...
[    7.901817] systemd[1]: Starting Apply Kernel Variables...
[    7.921812] systemd[1]: Starting Coldplug All udev Devices...
[    7.947278] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    7.963556] systemd[1]: Mounted Huge Pages File System.
[  OK  ] Mounted Huge Pages File System.
[    7.983493] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    8.007488] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[    8.027499] systemd[1]: Mounted Temporary Directory /tmp.
[  OK  ] Mounted Temporary Directory /tmp.
[    8.048011] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    8.056251] systemd[1]: Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module configfs.
[    8.079685] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    8.087552] systemd[1]: Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module drm.
[    8.107833] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    8.115570] systemd[1]: Finished Load Kernel Module fuse.
[  OK  ] Finished Load Kernel Module fuse.
[    8.135425] systemd[1]: proc-fs-nfsd.mount: Mount process exited, code=exited        , status=32/n/a
[    8.143884] systemd[1]: proc-fs-nfsd.mount: Failed with result 'exit-code'.
[    8.152091] systemd[1]: Failed to mount NFSD configuration filesystem.
[FAILED] Failed to mount NFSD configuration filesystem.
See 'systemctl status proc-fs-nfsd.mount' for details.
[    8.187147] systemd[1]: Dependency failed for NFS server and services.
[DEPEND] Dependency failed for NFS server and services.
[    8.215011] systemd[1]: Dependency failed for NFS Mount Daemon.
[DEPEND] Dependency failed for NFS Mount Daemon.
[    8.235003] systemd[1]: nfs-mountd.service: Job nfs-mountd.service/start fail        ed with result 'dependency'.
[    8.244598] systemd[1]: nfs-server.service: Job nfs-server.service/start fail        ed with result 'dependency'.
[    8.254523] systemd[1]: systemd-remount-fs.service: Main process exited, code        =exited, status=1/FAILURE
[    8.264189] systemd[1]: systemd-remount-fs.service: Failed with result 'exit-        code'.
[    8.273029] systemd[1]: Failed to start Remount Root and Kernel File Systems.
[FAILED] Failed to start Remount Root and Kernel File Systems.
See 'systemctl status systemd-remount-fs.service' for details.
[    8.308461] systemd[1]: Finished Apply Kernel Variables.
[  OK  ] Finished Apply Kernel Variables.
[    8.333652] systemd[1]: Condition check resulted in FUSE Control File System        being skipped.
[    8.344651] systemd[1]: Mounting Kernel Configuration File System...
[    8.367319] systemd[1]: Condition check resulted in Rebuild Hardware Database        being skipped.
[    8.376029] systemd[1]: Condition check resulted in Platform Persistent Stora        ge Archival being skipped.
[    8.388355] systemd[1]: Starting Create System Users...
[    8.406796] systemd[1]: Mounted Kernel Configuration File System.
[  OK  ] Mounted Kernel Configuration File System.
[    8.428728] systemd[1]: Finished Create System Users.
[  OK  ] Finished Create System Users.
[    8.446171] systemd[1]: Starting Create Static Device Nodes in /dev...
[    8.468846] systemd[1]: Finished Create Static Device Nodes in /dev.
[  OK  ] Finished Create Static Device Nodes in /dev.
[    8.491384] systemd[1]: Reached target Preparation for Local File Systems.
[  OK  ] Reached target Preparation for Local File Systems.
[    8.517786] systemd[1]: Mounting /var/volatile...
[    8.534594] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[  OK  ] Started Entropy Daemon based on the HAVEGE algorithm.
[    8.559794] systemd[1]: systemd-journald.service: unit configures an IP firew        all, but the local system does not support BPF/cgroup firewalling.
[    8.572851] systemd[1]: (This warning is only shown for the first unit using        IP firewalling.)
[    8.585011] systemd[1]: Starting Journal Service...
[    8.603227] systemd[1]: Starting Rule-based Manager for Device Events and Fil        es...
         Starting Rule-based Manage…for Device Events and Files...
[    8.629332] systemd[1]: Mounted /var/volatile.
[  OK  ] Mounted /var/volatile.
[    8.644963] systemd[1]: Finished Coldplug All udev Devices.
[  OK  ] Finished Coldplug All udev Devices.
[    8.670526] systemd[1]: Starting Wait for udev To Complete Device Initializat        ion...
         Starting Wait for udev To …plete Device Initialization...
[    8.695158] systemd[1]: Condition check resulted in Bind mount volatile /var/        cache being skipped.
[    8.704251] systemd[1]: Condition check resulted in Bind mount volatile /var/        lib being skipped.
[    8.737687] systemd[1]: Starting Load/Save Random Seed...
[    8.755162] systemd[1]: Condition check resulted in Bind mount volatile /var/        spool being skipped.
[    8.764386] systemd[1]: Condition check resulted in Bind mount volatile /srv        being skipped.
[    8.772926] systemd[1]: Reached target Local File Systems.
[  OK  ] Reached target Local File Systems.
[    8.798948] systemd[1]: Starting Rebuild Dynamic Linker Cache...
[    8.816479] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Started Rule-based Manager for Device Events and Files.
[  OK  ] Finished Rebuild Dynamic Linker Cache.
         Starting Flush Journal to Persistent Storage...
[    8.901608] systemd-journald[266]: Received client request to flush runtime j        ournal.
         Starting Network Configuration...
[  OK  ] Finished Flush Journal to Persistent Storage.
         Starting Create Volatile Files and Directories...
[    9.235365] random: fast init done
[  OK  ] Finished Create Volatile Files and Directories.
[  OK  ] Started Network Configuration.
[    9.623466] macb ff0e0000.ethernet eth1: PHY [ff0e0000.ethernet-ffffffff:00]        driver [Marvell 88E1510] (irq=POLL)
[    9.633687] macb ff0e0000.ethernet eth1: configuring for phy/rgmii-id link mo        de
[    9.643342] pps pps0: new PPS source ptp0
[    9.650871] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
[    9.719491] macb ff0c0000.ethernet eth0: PHY [ff0c0000.ethernet-ffffffff:00]        driver [Marvell 88E1510] (irq=POLL)
[    9.729709] macb ff0c0000.ethernet eth0: configuring for phy/rgmii-id link mo        de
[    9.738889] pps pps1: new PPS source ptp1
[    9.743777] macb ff0c0000.ethernet: gem-ptp-timer ptp clock registered.
[  OK  ] Finished Wait for udev To Complete Device Initialization.
[  OK  ] Found device /dev/mmcblk0p1.
[    9.968661] random: crng init done
[    9.972072] random: 7 urandom warning(s) missed due to ratelimiting
[  OK  ] Finished Load/Save Random Seed.
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
         Mounting /mnt...
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
         Starting Rebuild Journal Catalog...
         Starting Network Name Resolution...
[   10.416974] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data        may be corrupt. Please run fsck.
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Mounted /mnt.
[  OK  ] Finished Rebuild Journal Catalog.
         Starting Update is Completed...
[  OK  ] Finished Update is Completed.
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target Timer Units.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting sshd.socket...
[  OK  ] Listening on sshd.socket.
[  OK  ] Reached target Socket Units.
[  OK  ] Reached target Basic System.
[  OK  ] Started Kernel Logging Service.
[  OK  ] Started System Logging Service.
[  OK  ] Started D-Bus System Message Bus.
         Starting rng-tools.service...
         Starting User Login Management...
         Starting Permit User Sessions...
         Starting Target Communication Framework agent...
         Starting OpenSSH Key Generation...
[  OK  ] Started rng-tools.service.
[  OK  ] Finished Permit User Sessions.
[  OK  ] Started Target Communication Framework agent.
[  OK  ] Started Getty on tty1.
         Starting LSB: NFS support for both client and server...
[  OK  ] Started Serial Getty on ttyPS0.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started LSB: NFS support for both client and server.
         Starting inetd.busybox.service...
         Starting LSB: Kernel NFS server support...
[  OK  ] Started inetd.busybox.service.
[FAILED] Failed to start LSB: Kernel NFS server support.
See 'systemctl status nfsserver.service' for details.
[  OK  ] Started User Login Management.
[  OK  ] Reached target Multi-User System.
         Starting Record Runlevel Change in UTMP...
[  OK  ] Finished Record Runlevel Change in UTMP.
PetaLinux 2022.2_release_S10071807 9z1-petalinux-zu11eg-20222 ttyPS0
9z1-petalinux-zu11eg-20222 login:
Can you please help me debug why I get the error:
And why is not running  the ADI application ?
Thanks
Thread Notes
Parents Reply Children
No Data
