AD9164 and AD9508 Devices not being recognized on Eval Board for ZCU102 Linux Interface
Product Number: AD9164
Hi, I'm trying to run Linux on ZCU102 and interface with the AD9164 Eval Board via FMC. I've created the Vivado project from ADI HDL github and changed the configuration under hdl/projects/dac_fmc_ebz_commons/config.tcl to AD9164 and mode 08. I use the generated .xsa file, a custom device tree, and meta-adi to create a PetaLinux build. I load the image onto the ZCU102 board and it runs, but it says AD9508 has an unexpected device ID and that the AD9162 device has no configuration node. I look under /sys/bus/iio/devices and I see 2 devices: Device0's label is ams and Device1's label is ADF4355. I expect 2 more devices for AD9508 and AD9164. Any suggestions? I've included the Linux Boot file and my device trees.
Boot Log:
Xilinx Zynq MP First Stage Boot Loader
Release 2022.2   Oct  7 2022  -  04:56:16
NOTICE:  BL31: v2.6(release):xlnx_rebase_v2.6_2022.1_update3-18-g0897efd45
NOTICE:  BL31: Built : 03:55:03, Sep  9 2022
U-Boot 2022.01 (Sep 20 2022 - 06:35:33 +0000)
CPU:   ZynqMP
Silicon: v3
Model: ZynqMP ZCU102 Rev1.0
Board: Xilinx ZynqMP
DRAM:  4 GiB
PMUFW:  v1.1
PMUFW no permission to change config object
Xilinx I2C Legacy format at nvmem0:
 Board name:    zcu102
 Board rev:     1.0
 Board SN:      881456042107-48616
 Ethernet mac:  00:0a:35:07:65:f0
EL Level:       EL2
Chip ID:        zu9eg
NAND:  0 MiB
MMC:   mmc@ff170000: 0
Loading Environment from FAT... *** Error - No Valid Environment Area found
*** Warning - bad env area, using default environment
In:    serial
Out:   serial
Err:   serial
Bootmode: LVL_SHFT_SD_MODE1
Reset reason:   EXTERNAL
Net:   FEC: can't find phy-handle
ZYNQ GEM: ff0e0000, mdio bus ff0e0000, phyaddr 12, interface rgmii-id
eth0: ethernet@ff0e0000
scanning bus for devices...
SATA link 0 timeout.
SATA link 1 timeout.
AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq pm clo only pmp fbss pio slum part ccc apst
starting USB...
Bus usb@fe200000: Register 2000440 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus usb@fe200000 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
2777 bytes read in 20 ms (134.8 KiB/s)
## Executing script at 20000000
Trying to load boot images from mmc0
43776880 bytes read in 2852 ms (14.6 MiB/s)
## Loading kernel from FIT Image at 10000000 ...
   Using 'conf-system-top.dtb' configuration
   Trying 'kernel-1' kernel subimage
     Description:  Linux kernel
     Created:      2024-02-13   7:48:41 UTC
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x10000104
     Data Size:    11912935 Bytes = 11.4 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00200000
     Entry Point:  0x00200000
     Hash algo:    sha256
     Hash value:   fc6844e5dbba84bbfd55f01fcc4023b4956b76a3610b8d8f76aa0e07d5cc70c3
   Verifying Hash Integrity ... sha256+ OK
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk-1' ramdisk subimage
     Description:  petalinux-image-minimal
     Type:         RAMDisk Image
     Compression:  uncompressed
     Data Start:   0x10b6b710
     Data Size:    31801064 Bytes = 30.3 MiB
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha256
     Hash value:   233d3c8fd5684df04674fce6268d0e35607d02e97860a3a9ef35b9bedf51bc24
## Loading fdt from FIT Image at 10000000 ...
   Trying 'fdt-system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x10b5c8fc
     Data Size:    60740 Bytes = 59.3 KiB
     Hash algo:    sha256
     Hash value:   25545a6e0756cdf6c89de1c4c488d543994fa4b0587d37de4f632d3ebb651fdb
   Booting using the fdt blob at 0x10b5c8fc
   Uncompressing Kernel Image
   Loading Ramdisk to 79fa1000, end 7bdf4ee8 ... OK
   Loading Device Tree to 0000000079f8f000, end 0000000079fa0d43 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.15.36-xilinx-v2022.2 (oe-user@oe-host) (aarch64-xilinx-linux-gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.37.20210721) #1 SMP Tue Feb 13 07:48:41 UTC 2024
[    0.000000] Machine model: ZynqMP ZCU102 Rev1.0
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] printk: bootconsole [cdns0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000087fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000]   node   0: [mem 0x0000000800000000-0x000000087fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000087fffffff]
[    0.000000] cma: Reserved 256 MiB at 0x0000000069c00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 18 pages/cpu s35800 r8192 d29736 u73728
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] Kernel command line:  earlycon console=ttyPS0,115200 clk_ignore_unused root=/dev/ram0 rw
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x000000007c000000-0x0000000080000000] (64MB)
[    0.000000] Memory: 3718828K/4194304K available (17152K kernel code, 1740K rwdata, 13116K rodata, 2624K init, 650K bss, 213332K reserved, 262144K cma-reserved)
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x470/0x6d4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 100.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171024e7e0, max_idle_ns: 440795205315 ns
[    0.000000] sched_clock: 56 bits at 100MHz, resolution 10ns, wraps every 4398046511100ns
[    0.008485] Console: colour dummy device 80x25
[    0.012485] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=400000)
[    0.022839] pid_max: default: 32768 minimum: 301
[    0.027645] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.034786] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.043638] rcu: Hierarchical SRCU implementation.
[    0.047576] EFI services will not be available.
[    0.051961] smp: Bringing up secondary CPUs ...
[    0.056705] Detected VIPT I-cache on CPU1
[    0.056747] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.057148] Detected VIPT I-cache on CPU2
[    0.057172] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.057557] Detected VIPT I-cache on CPU3
[    0.057581] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.057625] smp: Brought up 1 node, 4 CPUs
[    0.091778] SMP: Total of 4 processors activated.
[    0.096450] CPU features: detected: 32-bit EL0 Support
[    0.101553] CPU features: detected: CRC32 instructions
[    0.106694] CPU: All CPU(s) started at EL2
[    0.110735] alternatives: patching kernel code
[    0.116081] devtmpfs: initialized
[    0.124685] Registered cp15_barrier emulation handler
[    0.124737] Registered setend emulation handler
[    0.128704] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.138295] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.151349] pinctrl core: initialized pinctrl subsystem
[    0.152143] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.157907] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.163933] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.171672] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.179448] audit: initializing netlink subsys (disabled)
[    0.184852] audit: type=2000 audit(0.116:1): state=initialized audit_enabled=0 res=1
[    0.192492] cpuidle: using governor menu
[    0.196442] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.203170] ASID allocator initialised with 65536 entries
[    0.229326] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.230383] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.237054] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.243727] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    1.334461] DRBG: Continuing without Jitter RNG
[    1.435207] raid6: neonx8   gen()  2135 MB/s
[    1.503267] raid6: neonx8   xor()  1583 MB/s
[    1.571327] raid6: neonx4   gen()  2191 MB/s
[    1.639383] raid6: neonx4   xor()  1556 MB/s
[    1.707451] raid6: neonx2   gen()  2070 MB/s
[    1.775508] raid6: neonx2   xor()  1429 MB/s
[    1.843586] raid6: neonx1   gen()  1770 MB/s
[    1.911640] raid6: neonx1   xor()  1213 MB/s
[    1.979704] raid6: int64x8  gen()  1366 MB/s
[    2.047775] raid6: int64x8  xor()   773 MB/s
[    2.115839] raid6: int64x4  gen()  1603 MB/s
[    2.183907] raid6: int64x4  xor()   850 MB/s
[    2.251969] raid6: int64x2  gen()  1393 MB/s
[    2.320035] raid6: int64x2  xor()   749 MB/s
[    2.388113] raid6: int64x1  gen()  1032 MB/s
[    2.456163] raid6: int64x1  xor()   517 MB/s
[    2.456202] raid6: using algorithm neonx4 gen() 2191 MB/s
[    2.460152] raid6: .... xor() 1556 MB/s, rmw enabled
[    2.465088] raid6: using neon recovery algorithm
[    2.470132] iommu: Default domain type: Translated
[    2.474518] iommu: DMA domain TLB invalidation policy: strict mode
[    2.480954] SCSI subsystem initialized
[    2.484613] usbcore: registered new interface driver usbfs
[    2.489945] usbcore: registered new interface driver hub
[    2.495215] usbcore: registered new device driver usb
[    2.500341] mc: Linux media interface: v0.10
[    2.504463] videodev: Linux video capture interface: v2.00
[    2.509948] pps_core: LinuxPPS API ver. 1 registered
[    2.514826] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    2.523916] PTP clock support registered
[    2.527819] EDAC MC: Ver: 3.0.0
[    2.531203] zynqmp-ipi-mbox mailbox@ff990400: Registered ZynqMP IPI mbox with TX/RX channels.
[    2.539808] OF: /fpga-axi@0/axi-adxcvr-tx@84a60000: could not get #jesd204-cells for /axi/spi@ff040000/ad9508@0
[    2.549432] jesd204: framework error: -22
[    2.553438] FPGA manager framework
[    2.556907] Advanced Linux Sound Architecture Driver Initialized.
[    2.563266] Bluetooth: Core ver 2.22
[    2.566390] NET: Registered PF_BLUETOOTH protocol family
[    2.571657] Bluetooth: HCI device and connection manager initialized
[    2.577974] Bluetooth: HCI socket layer initialized
[    2.582817] Bluetooth: L2CAP socket layer initialized
[    2.587838] Bluetooth: SCO socket layer initialized
[    2.593083] clocksource: Switched to clocksource arch_sys_counter
[    2.598858] VFS: Disk quotas dquot_6.6.0
[    2.602665] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    2.613743] NET: Registered PF_INET protocol family
[    2.614418] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    2.623233] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    2.630171] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    2.638206] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    2.645666] TCP: Hash tables configured (established 32768 bind 32768)
[    2.651826] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    2.658487] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    2.665649] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    2.671452] RPC: Registered named UNIX socket transport module.
[    2.677021] RPC: Registered udp transport module.
[    2.681688] RPC: Registered tcp transport module.
[    2.686357] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.693363] PCI: CLS 0 bytes, default 64
[    2.696789] Trying to unpack rootfs image as initramfs...
[    2.702811] armv8-pmu pmu: hw perfevents: no interrupt-affinity property, guessing.
[    2.709972] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    2.718297] Initialise system trusted keyrings
[    2.721889] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    2.729295] NFS: Registering the id_resolver key type
[    2.733173] Key type id_resolver registered
[    2.737304] Key type id_legacy registered
[    2.741309] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.747953] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.755328] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    2.762651] fuse: init (API version 7.34)
[    2.803138] NET: Registered PF_ALG protocol family
[    2.803205] xor: measuring software checksum speed
[    2.811236]    8regs           :  2363 MB/sec
[    2.814903]    32regs          :  2799 MB/sec
[    2.819979]    arm64_neon      :  2307 MB/sec
[    2.820035] xor: using function: 32regs (2799 MB/sec)
[    2.825076] Key type asymmetric registered
[    2.829124] Asymmetric key parser 'x509' registered
[    2.834052] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.841323] io scheduler mq-deadline registered
[    2.845818] io scheduler kyber registered
[    2.877935] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.880862] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.889128] brd: module loaded
[    2.892760] loop: module loaded
[    2.893185] Registered mathworks_ip class
[    2.898043] tun: Universal TUN/TAP device driver, 1.6
[    2.899945] CAN device driver interface
[    2.904434] SPI driver wl1271_spi has no spi_device_id for ti,wl1271
[    2.909974] SPI driver wl1271_spi has no spi_device_id for ti,wl1273
[    2.916281] SPI driver wl1271_spi has no spi_device_id for ti,wl1281
[    2.922595] SPI driver wl1271_spi has no spi_device_id for ti,wl1283
[    2.928910] SPI driver wl1271_spi has no spi_device_id for ti,wl1285
[    2.935225] SPI driver wl1271_spi has no spi_device_id for ti,wl1801
[    2.941539] SPI driver wl1271_spi has no spi_device_id for ti,wl1805
[    2.947853] SPI driver wl1271_spi has no spi_device_id for ti,wl1807
[    2.954175] SPI driver wl1271_spi has no spi_device_id for ti,wl1831
[    2.960488] SPI driver wl1271_spi has no spi_device_id for ti,wl1835
[    2.966799] SPI driver wl1271_spi has no spi_device_id for ti,wl1837
[    2.973319] usbcore: registered new interface driver asix
[    2.978523] usbcore: registered new interface driver ax88179_178a
[    2.984570] usbcore: registered new interface driver cdc_ether
[    2.990360] usbcore: registered new interface driver net1080
[    2.995976] usbcore: registered new interface driver cdc_subset
[    3.001859] usbcore: registered new interface driver zaurus
[    3.007417] usbcore: registered new interface driver cdc_ncm
[    3.013784] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.019480] ehci-pci: EHCI PCI platform driver
[    3.024386] usbcore: registered new interface driver uas
[    3.029212] usbcore: registered new interface driver usb-storage
[    3.035197] usbcore: registered new interface driver usbserial_generic
[    3.041635] usbserial: USB Serial support registered for generic
[    3.047617] usbcore: registered new interface driver ftdi_sio
[    3.053311] usbserial: USB Serial support registered for FTDI USB Serial Device
[    3.060604] usbcore: registered new interface driver upd78f0730
[    3.066465] usbserial: USB Serial support registered for upd78f0730
[    3.073852] SPI driver ads7846 has no spi_device_id for ti,tsc2046
[    3.078821] SPI driver ads7846 has no spi_device_id for ti,ads7843
[    3.084960] SPI driver ads7846 has no spi_device_id for ti,ads7845
[    3.091099] SPI driver ads7846 has no spi_device_id for ti,ads7873
[    3.097959] rtc_zynqmp ffa60000.rtc: registered as rtc0
[    3.102451] rtc_zynqmp ffa60000.rtc: setting system clock to 2021-01-20T15:47:03 UTC (1611157623)
[    3.111431] i2c_dev: i2c /dev entries driver
[    3.117467] usbcore: registered new interface driver uvcvideo
[    3.122767] Bluetooth: HCI UART driver ver 2.3
[    3.125622] Bluetooth: HCI UART protocol H4 registered
[    3.130728] Bluetooth: HCI UART protocol BCSP registered
[    3.136028] Bluetooth: HCI UART protocol LL registered
[    3.141095] Bluetooth: HCI UART protocol ATH3K registered
[    3.146482] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    3.152831] Bluetooth: HCI UART protocol Intel registered
[    3.158077] Bluetooth: HCI UART protocol QCA registered
[    3.163302] usbcore: registered new interface driver bcm203x
[    3.168903] usbcore: registered new interface driver bpa10x
[    3.174446] usbcore: registered new interface driver bfusb
[    3.179905] usbcore: registered new interface driver btusb
[    3.185361] usbcore: registered new interface driver ath3k
[    3.190941] EDAC MC: ECC not enabled
[    3.194612] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    3.207056] sdhci: Secure Digital Host Controller Interface driver
[    3.212555] sdhci: Copyright(c) Pierre Ossman
[    3.216869] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.223395] ledtrig-cpu: registered to indicate activity on CPUs
[    3.228657] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    3.234984] zynqmp_firmware_probe Platform Management API v1.1
[    3.240665] zynqmp_firmware_probe Trustzone version v1.0
[    3.277419] zynqmp-aes firmware:zynqmp-firmware:zynqmp-aes: will run requests pump with realtime priority
[    4.189018] Freeing initrd memory: 31052K
[    4.205304] zynqmp-keccak-384 firmware:zynqmp-firmware:sha384: The zynqmp-sha-deprecated driver shall be deprecated in 2022.2 and removed in 2023.1 release
[    4.213618] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[    4.219911] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[    4.225386] usbcore: registered new interface driver usbhid
[    4.230763] usbhid: USB HID core driver
[    4.234762] SPI driver fb_seps525 has no spi_device_id for syncoam,seps525
[    4.242085] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7988-5
[    4.248581] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7988-1
[    4.255759] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7984
[    4.262765] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7983
[    4.269772] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7982
[    4.276778] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7980
[    4.283784] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7949
[    4.290791] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7946
[    4.297797] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7942
[    4.304804] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7699
[    4.311810] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7693
[    4.318817] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7691
[    4.325823] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7690
[    4.332830] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7689
[    4.339836] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7688
[    4.346843] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7687
[    4.353854] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7686
[    4.360856] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7685
[    4.367862] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7682
[    4.374984] SPI driver ad7124 has no spi_device_id for adi,ad7124-4
[    4.381098] SPI driver ad7124 has no spi_device_id for adi,ad7124-8
[    4.387339] SPI driver ad7192 has no spi_device_id for adi,ad7190
[    4.393380] SPI driver ad7192 has no spi_device_id for adi,ad7193
[    4.399435] SPI driver ad7192 has no spi_device_id for adi,ad7195
[    4.406252] SPI driver ad9467 has no spi_device_id for adi,ad9643
[    4.411546] SPI driver ad9467 has no spi_device_id for adi,ad9250
[    4.417600] SPI driver ad9467 has no spi_device_id for adi,ad9250_2
[    4.423827] SPI driver ad9467 has no spi_device_id for adi,ad9265
[    4.429882] SPI driver ad9467 has no spi_device_id for adi,ad9683
[    4.435937] SPI driver ad9467 has no spi_device_id for adi,ad9434
[    4.441992] SPI driver ad9467 has no spi_device_id for adi,ad9625
[    4.448047] SPI driver ad9467 has no spi_device_id for adi,ad9652
[    4.454102] SPI driver ad9467 has no spi_device_id for adi,ad9649
[    4.462912] SPI driver adar3000 has no spi_device_id for adi,adar3001
[    4.466565] SPI driver adar3000 has no spi_device_id for adi,adar3002
[    4.474172] SPI driver ad9783 has no spi_device_id for adi,ad9780
[    4.479022] SPI driver ad9783 has no spi_device_id for adi,ad9781
[    4.485261] SPI driver adis16475 has no spi_device_id for adi,adis16470
[    4.491647] SPI driver adis16475 has no spi_device_id for adi,adis16475-1
[    4.498392] SPI driver adis16475 has no spi_device_id for adi,adis16475-2
[    4.505138] SPI driver adis16475 has no spi_device_id for adi,adis16475-3
[    4.511886] SPI driver adis16475 has no spi_device_id for adi,adis16477-1
[    4.518632] SPI driver adis16475 has no spi_device_id for adi,adis16477-2
[    4.525379] SPI driver adis16475 has no spi_device_id for adi,adis16477-3
[    4.532126] SPI driver adis16475 has no spi_device_id for adi,adis16465-1
[    4.538873] SPI driver adis16475 has no spi_device_id for adi,adis16465-2
[    4.545620] SPI driver adis16475 has no spi_device_id for adi,adis16465-3
[    4.552367] SPI driver adis16475 has no spi_device_id for adi,adis16467-1
[    4.559116] SPI driver adis16475 has no spi_device_id for adi,adis16467-2
[    4.565862] SPI driver adis16475 has no spi_device_id for adi,adis16467-3
[    4.572608] SPI driver adis16475 has no spi_device_id for adi,adis16500
[    4.579182] SPI driver adis16475 has no spi_device_id for adi,adis16505-1
[    4.585929] SPI driver adis16475 has no spi_device_id for adi,adis16505-2
[    4.592676] SPI driver adis16475 has no spi_device_id for adi,adis16505-3
[    4.599423] SPI driver adis16475 has no spi_device_id for adi,adis16507-1
[    4.606176] SPI driver adis16475 has no spi_device_id for adi,adis16507-2
[    4.612918] SPI driver adis16475 has no spi_device_id for adi,adis16507-3
[    4.620700] axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.01.a) found
[    4.627631] axi_sysid 85000000.axi-sysid-0: [dac_fmc_ebz] [AD9164 - 08] on [zcu102] git branch <hdl_2022_r2> git <e2a27347334a84d8618bc72d34fed0d8920a04b4> dirty [2024-02-23 16:05:50] UTC
[    4.644627] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    4.650929] usbcore: registered new interface driver snd-usb-audio
[    4.658442] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    4.664879] Initializing XFRM netlink socket
[    4.668444] NET: Registered PF_INET6 protocol family
[    4.673754] Segment Routing with IPv6
[    4.676936] In-situ OAM (IOAM) with IPv6
[    4.680895] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    4.687050] NET: Registered PF_PACKET protocol family
[    4.691732] NET: Registered PF_KEY protocol family
[    4.696551] can: controller area network core
[    4.700834] NET: Registered PF_CAN protocol family
[    4.705561] can: raw protocol
[    4.708497] can: broadcast manager protocol
[    4.712657] can: netlink gateway - max_hops=1
[    4.717055] Bluetooth: RFCOMM TTY layer initialized
[    4.721829] Bluetooth: RFCOMM socket layer initialized
[    4.726938] Bluetooth: RFCOMM ver 1.11
[    4.730655] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.735922] Bluetooth: BNEP filters: protocol multicast
[    4.741114] Bluetooth: BNEP socket layer initialized
[    4.746042] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.751926] Bluetooth: HIDP socket layer initialized
[    4.756993] 9pnet: Installing 9P2000 support
[    4.761123] NET: Registered PF_IEEE802154 protocol family
[    4.766476] Key type dns_resolver registered
[    4.770921] registered taskstats version 1
[    4.774762] Loading compiled-in X.509 certificates
[    4.780031] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[    4.795296] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 48, base_baud = 6249999) is a xuartps
[    4.804331] printk: console [ttyPS0] enabled
[    4.808634] printk: bootconsole [cdns0] disabled
[    4.818187] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 49, base_baud = 6249999) is a xuartps
[    4.831377] of-fpga-region fpga-full: FPGA Region probed
[    4.837917] nwl-pcie fd0e0000.pcie: host bridge /axi/pcie@fd0e0000 ranges:
[    4.844822] nwl-pcie fd0e0000.pcie:      MEM 0x00e0000000..0x00efffffff -> 0x00e0000000
[    4.852833] nwl-pcie fd0e0000.pcie:      MEM 0x0600000000..0x07ffffffff -> 0x0600000000
[    4.860914] nwl-pcie fd0e0000.pcie: Link is DOWN
[    4.865674] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
[    4.871859] pci_bus 0000:00: root bus resource [bus 00-ff]
[    4.877339] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
[    4.884213] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
[    4.891721] pci 0000:00:00.0: [10ee:d021] type 01 class 0x060400
[    4.897787] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
[    4.907926] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
[    4.913683] xilinx-zynqmp-dma fd500000.dma-controller: ZynqMP DMA driver Probe success
[    4.921776] xilinx-zynqmp-dma fd510000.dma-controller: ZynqMP DMA driver Probe success
[    4.929856] xilinx-zynqmp-dma fd520000.dma-controller: ZynqMP DMA driver Probe success
[    4.937940] xilinx-zynqmp-dma fd530000.dma-controller: ZynqMP DMA driver Probe success
[    4.946017] xilinx-zynqmp-dma fd540000.dma-controller: ZynqMP DMA driver Probe success
[    4.954107] xilinx-zynqmp-dma fd550000.dma-controller: ZynqMP DMA driver Probe success
[    4.962191] xilinx-zynqmp-dma fd560000.dma-controller: ZynqMP DMA driver Probe success
[    4.970274] xilinx-zynqmp-dma fd570000.dma-controller: ZynqMP DMA driver Probe success
[    4.978581] xilinx-zynqmp-dpdma fd4c0000.dma-controller: Xilinx DPDMA engine is probed
[    4.997586] ad9508 spi1.0: Unexpected device ID (0x00)
[    5.003337] adf5355 spi1.2: supply vcc not found, using dummy regulator
[    5.011915] spi-nor spi0.0: SPI-NOR-UniqueID aaed0400060a000d00d432c0b277
[    5.018705] spi-nor spi0.0: found mt25qu512a, expected m25p80
[    5.024800] spi-nor spi0.0: mt25qu512a (131072 Kbytes)
[    5.029959] 4 fixed-partitions partitions found on MTD device spi0.0
[    5.036303] Creating 4 MTD partitions on "spi0.0":
[    5.041090] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
[    5.047698] 0x000000100000-0x000000600000 : "qspi-linux"
[    5.053732] 0x000000600000-0x000000620000 : "qspi-device-tree"
[    5.060268] 0x000000620000-0x000000c00000 : "qspi-rootfs"
[    5.067325] xilinx_can ff070000.can can0: TDC Offset value not in range
[    5.075566] macb ff0e0000.ethernet: Not enabling partial store and forward
[    5.085831] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 30 (00:0a:35:07:65:f0)
[    5.096108] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    5.102647] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[    5.109142] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[    5.115629] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[    5.123039] pca953x 0-0020: supply vcc not found, using dummy regulator
[    5.129739] pca953x 0-0020: using no AI
[    5.134234] gpio-318 (sel0): hogged as output/low
[    5.139138] gpio-319 (sel1): hogged as output/high
[    5.144129] gpio-320 (sel2): hogged as output/high
[    5.149119] gpio-321 (sel3): hogged as output/high
[    5.154298] pca953x 0-0021: supply vcc not found, using dummy regulator
[    5.160974] pca953x 0-0021: using no AI
[    5.166444] ina2xx 2-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.173442] ina2xx 2-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.180438] ina2xx 2-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.187427] ina2xx 2-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.194417] ina2xx 2-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.201415] ina2xx 2-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.208418] ina2xx 2-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.215407] ina2xx 2-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.222459] ina2xx 2-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.229451] ina2xx 2-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.235865] i2c i2c-0: Added multiplexed i2c bus 2
[    5.241421] ina2xx 3-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[    5.248418] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.255418] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.262412] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.269408] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.276400] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.283406] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.290407] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.296812] i2c i2c-0: Added multiplexed i2c bus 3
[    5.311261] random: fast init done
[    5.356396] i2c i2c-0: Added multiplexed i2c bus 4
[    5.361352] i2c i2c-0: Added multiplexed i2c bus 5
[    5.366141] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[    5.373514] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 32
[    5.380944] at24 6-0054: supply vcc not found, using dummy regulator
[    5.387849] at24 6-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[    5.394605] i2c i2c-1: Added multiplexed i2c bus 6
[    5.399967] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[    5.407278] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[    5.414580] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[    5.421888] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[    5.429196] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[    5.436496] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[    5.443796] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[    5.451095] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
[    5.459502] si5341 7-0036: Chip: 5341 Grade: 1 Rev: 1
[    5.498033] i2c i2c-1: Added multiplexed i2c bus 7
[    5.505689] si570 8-005d: registered, current frequency 300000000 Hz
[    5.512094] i2c i2c-1: Added multiplexed i2c bus 8
[    5.531882] si570 9-005d: registered, current frequency 148500000 Hz
[    5.538291] i2c i2c-1: Added multiplexed i2c bus 9
[    5.543314] si5324 10-0069: si5328 probed
[    5.609460] si5324 10-0069: si5328 probe successful
[    5.614391] i2c i2c-1: Added multiplexed i2c bus 10
[    5.619439] i2c i2c-1: Added multiplexed i2c bus 11
[    5.624475] i2c i2c-1: Added multiplexed i2c bus 12
[    5.629510] i2c i2c-1: Added multiplexed i2c bus 13
[    5.634387] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[    5.642383] i2c i2c-1: Added multiplexed i2c bus 14
[    5.647426] i2c i2c-1: Added multiplexed i2c bus 15
[    5.652474] i2c i2c-1: Added multiplexed i2c bus 16
[    5.657521] i2c i2c-1: Added multiplexed i2c bus 17
[    5.662562] i2c i2c-1: Added multiplexed i2c bus 18
[    5.667612] i2c i2c-1: Added multiplexed i2c bus 19
[    5.672658] i2c i2c-1: Added multiplexed i2c bus 20
[    5.677707] i2c i2c-1: Added multiplexed i2c bus 21
[    5.682587] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[    5.690204] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 33
[    5.699492] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
[    5.709624] zynqmp-display fd4a0000.display: vtc bridge property not present
[    5.717832] zynqmp_clk_divider_set_rate() set divider failed for spi1_ref_div1, ret = -13
[    5.727522] xilinx-dp-snd-codec fd4a0000.display:zynqmp_dp_snd_codec0: Failed to get required clock freq
[    5.737014] xilinx-dp-snd-codec: probe of fd4a0000.display:zynqmp_dp_snd_codec0 failed with error -22
[    5.741348] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[    5.746508] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[    5.761948] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[    5.770112] OF: graph: no port node found in /axi/display@fd4a0000
[    5.776619] xlnx-drm xlnx-drm.0: bound fd4a0000.display (ops 0xffffffc009196640)
[    5.789832] mmc0: new high speed SDHC card at address 5048
[    5.795692] mmcblk0: mmc0:5048 SD32G 29.7 GiB
[    5.802653]  mmcblk0: p1
[    6.861108] zynqmp-display fd4a0000.display: [drm] Cannot find any crtc or sizes
[    6.868740] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.display on minor 0
[    6.876244] zynqmp-display fd4a0000.display: ZynqMP DisplayPort Subsystem driver probed
[    6.884522] ahci-ceva fd0c0000.ahci: supply ahci not found, using dummy regulator
[    6.892083] ahci-ceva fd0c0000.ahci: supply phy not found, using dummy regulator
[    6.899552] ahci-ceva fd0c0000.ahci: supply target not found, using dummy regulator
[    6.907388] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    6.916349] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    6.926981] scsi host0: ahci-ceva
[    6.930581] scsi host1: ahci-ceva
[    6.934015] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 45
[    6.941929] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 45
[    6.950253] ad9162 spi1.1: Device has no configuration node
[    6.975987] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    6.981502] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[    6.989269] xhci-hcd xhci-hcd.1.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000002010890
[    6.998697] xhci-hcd xhci-hcd.1.auto: irq 56, io mem 0xfe200000
[    7.004848] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    7.013117] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.020335] usb usb1: Product: xHCI Host Controller
[    7.025213] usb usb1: Manufacturer: Linux 5.15.36-xilinx-v2022.2 xhci-hcd
[    7.031990] usb usb1: SerialNumber: xhci-hcd.1.auto
[    7.037190] hub 1-0:1.0: USB hub found
[    7.040946] hub 1-0:1.0: 1 port detected
[    7.045064] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    7.050559] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[    7.058228] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    7.064868] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    7.073131] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.080349] usb usb2: Product: xHCI Host Controller
[    7.085218] usb usb2: Manufacturer: Linux 5.15.36-xilinx-v2022.2 xhci-hcd
[    7.091997] usb usb2: SerialNumber: xhci-hcd.1.auto
[    7.097151] hub 2-0:1.0: USB hub found
[    7.100904] hub 2-0:1.0: 1 port detected
[    7.114586] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    7.121735] of_cfs_init
[    7.124184] of_cfs_init: OK
[    7.127141] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    7.263291] ata2: SATA link down (SStatus 0 SControl 330)
[    7.267994] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    7.268752] ata1: SATA link down (SStatus 0 SControl 330)
[    7.275224] clk: Not disabling unused clocks
[    7.285154] ALSA device list:
[    7.288106]   No soundcards found.
[    7.291807] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    7.292443] Freeing unused kernel memory: 2624K
[    7.300422] cfg80211: failed to load regulatory.db
[    7.333139] Run /init as init process
[    7.346569] systemd[1]: System time before build time, advancing clock.
[    7.356795] systemd[1]: systemd 249.7+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[    7.387146] systemd[1]: Detected architecture arm64.
Welcome to PetaLinux 2022.2_release_S10071807 (honister)!
[    7.445251] systemd[1]: Hostname set to <dacproject>.
[    7.450403] random: systemd: uninitialized urandom read (16 bytes read)
[    7.457029] systemd[1]: Initializing machine ID from random generator.
[    7.492991] systemd-sysv-generator[143]: SysV service '/etc/init.d/watchdog-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    7.519947] systemd-sysv-generator[143]: SysV service '/etc/init.d/nfsserver' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    7.544043] systemd-sysv-generator[143]: SysV service '/etc/init.d/nfscommon' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    7.568443] systemd-sysv-generator[143]: SysV service '/etc/init.d/inetd.busybox' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    7.594793] systemd-sysv-generator[143]: SysV service '/etc/init.d/dropbear' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    7.819666] systemd[1]: Queued start job for default target Multi-User System.
[    7.827779] random: systemd: uninitialized urandom read (16 bytes read)
[    7.864030] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    7.885210] random: systemd: uninitialized urandom read (16 bytes read)
[    7.893168] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    7.914356] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    7.938204] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    7.961360] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    7.965120] zynqmp-display fd4a0000.display: [drm] Cannot find any crtc or sizes
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    7.993306] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    8.017342] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[    8.033179] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    8.053180] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[    8.069200] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[    8.085635] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    8.109181] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    8.129428] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    8.145334] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    8.169647] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[    8.189383] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    8.209450] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    8.225596] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    8.249462] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    8.269372] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    8.289395] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[    8.315748] systemd[1]: Mounting Huge Pages File System...
[    8.335879] systemd[1]: Mounting POSIX Message Queue File System...
[    8.359931] systemd[1]: Mounting Kernel Debug File System...
[    8.377506] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[    8.388643] systemd[1]: Mounting Temporary Directory /tmp...
[    8.405502] systemd[1]: Condition check resulted in Create List of Static Device Nodes being skipped.
[    8.417855] systemd[1]: Starting Load Kernel Module configfs...
[    8.436350] systemd[1]: Starting Load Kernel Module drm...
[    8.456143] systemd[1]: Starting Load Kernel Module fuse...
[    8.476117] systemd[1]: Starting RPC Bind...
[    8.489280] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    8.499042] systemd[1]: Condition check resulted in Load Kernel Modules being skipped.
[    8.509411] systemd[1]: Mounting NFSD configuration filesystem...
[    8.528052] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.552095] systemd[1]: Starting Apply Kernel Variables...
[    8.572082] systemd[1]: Starting Coldplug All udev Devices...
[    8.593613] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    8.609679] systemd[1]: Mounted Huge Pages File System.
[  OK  ] Mounted Huge Pages File System.
[    8.629637] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    8.653651] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[    8.673616] systemd[1]: Mounted Temporary Directory /tmp.
[  OK  ] Mounted Temporary Directory /tmp.
[    8.694134] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    8.702437] systemd[1]: Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module configfs.
[    8.726141] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    8.734123] systemd[1]: Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module drm.
[    8.758241] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    8.766245] systemd[1]: Finished Load Kernel Module fuse.
[  OK  ] Finished Load Kernel Module fuse.
[    8.789478] systemd[1]: proc-fs-nfsd.mount: Mount process exited, code=exited, status=32/n/a
[    8.797972] systemd[1]: proc-fs-nfsd.mount: Failed with result 'exit-code'.
[    8.806206] systemd[1]: Failed to mount NFSD configuration filesystem.
[FAILED] Failed to mount NFSD configuration filesystem.
See 'systemctl status proc-fs-nfsd.mount' for details.
[    8.841132] systemd[1]: Dependency failed for NFS Mount Daemon.
[DEPEND] Dependency failed for NFS Mount Daemon.
[    8.861132] systemd[1]: Dependency failed for NFS server and services.
[DEPEND] Dependency failed for NFS server and services.
[    8.885127] systemd[1]: nfs-server.service: Job nfs-server.service/start failed with result 'dependency'.
[    8.894739] systemd[1]: nfs-mountd.service: Job nfs-mountd.service/start failed with result 'dependency'.
[    8.905874] systemd[1]: Finished Remount Root and Kernel File Systems.
[  OK  ] Finished Remount Root and Kernel File Systems.
[    8.930609] systemd[1]: Finished Apply Kernel Variables.
[  OK  ] Finished Apply Kernel Variables.
[    8.958290] systemd[1]: Mounting FUSE Control File System...
[    8.975958] systemd[1]: Mounting Kernel Configuration File System...
[    8.997417] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    9.006242] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    9.018744] systemd[1]: Starting Create System Users...
[    9.037370] systemd[1]: Mounted FUSE Control File System.
[  OK  ] Mounted FUSE Control File System.
[    9.057797] systemd[1]: Mounted Kernel Configuration File System.
[  OK  ] Mounted Kernel Configuration File System.
[    9.082948] systemd[1]: Finished Create System Users.
[  OK  ] Finished Create System Users.
[    9.100616] systemd[1]: Starting Create Static Device Nodes in /dev...
[    9.127039] systemd[1]: Finished Create Static Device Nodes in /dev.
[  OK  ] Finished Create Static Device Nodes in /dev.
[    9.149511] systemd[1]: Reached target Preparation for Local File Systems.
[  OK  ] Reached target Preparation for Local File Systems.
[    9.176153] systemd[1]: Mounting /var/volatile...
[    9.196930] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[  OK  ] Started Entropy Daemon based on the HAVEGE algorithm.
[    9.222005] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    9.235037] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    9.247423] systemd[1]: Starting Journal Service...
[    9.265645] systemd[1]: Starting Rule-based Manager for Device Events and Files...
         Starting Rule-based Manage…for Device Events and Files...
[    9.291523] systemd[1]: Mounted /var/volatile.
[  OK  ] Mounted /var/volatile.
[    9.305531] systemd[1]: Condition check resulted in Bind mount volatile /var/cache being skipped.
[    9.325243] systemd[1]: Condition check resulted in Bind mount volatile /var/lib being skipped.
[    9.347804] systemd[1]: Starting Load/Save Random Seed...
[    9.365309] systemd[1]: Condition check resulted in Bind mount volatile /var/spool being skipped.
[    9.382639] systemd[1]: Condition check resulted in Bind mount volatile /srv being skipped.
[    9.391154] systemd[1]: Reached target Local File Systems.
[  OK  ] Reached target Local File Systems.
[    9.416455] systemd[1]: Starting Rebuild Dynamic Linker Cache...
[    9.438903] systemd[1]: Started Rule-based Manager for Device Events and Files.
[  OK  ] Started Rule-based Manager for Device Events and Files.
[    9.465918] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Finished Rebuild Dynamic Linker Cache.
         Starting Flush Journal to Persistent Storage...
[    9.559815] systemd-journald[174]: Received client request to flush runtime journal.
         Starting Network Configuration...
         Starting Wait for udev To …plete Device Initialization...
[  OK  ] Finished Flush Journal to Persistent Storage.
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Create Volatile Files and Directories.
         Starting Rebuild Journal Catalog...
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Started Network Configuration.
         Starting Network Name Resolution...
[  OK  ] Finished Rebuild Journal Catalog.
         Starting Update is Completed...
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[  OK  ] Finished Update is Completed.
[   10.055110] macb ff0e0000.ethernet eth0: PHY [ff0e0000.ethernet-ffffffff:0c] driver [TI DP83867] (irq=POLL)
[   10.064945] macb ff0e0000.ethernet eth0: configuring for phy/rgmii-id link mode
[   10.107846] pps pps0: new PPS source ptp0
[   10.128844] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Started Network Name Resolution.
[   10.903138] random: crng init done
[   10.906584] random: 7 urandom warning(s) missed due to ratelimiting
[  OK  ] Finished Load/Save Random Seed.
[  OK  ] Finished Wait for udev To Complete Device Initialization.
[  OK  ] Created slice Slice /system/systemd-fsck.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target Timer Units.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Reached target Socket Units.
[  OK  ] Reached target Basic System.
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started Kernel Logging Service.
[  OK  ] Started System Logging Service.
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Started FANCONTROL Daemon.
[  OK  ] Started IIO Daemon.
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting LSB: NFS support for both client and server...
         Starting File System Check on /dev/mmcblk0p1...
         Starting User Login Management...
         Starting Permit User Sessions...
         Starting Target Communication Framework agent...
[  OK  ] Started LSB: NFS support for both client and server.
[  OK  ] Finished File System Check on /dev/mmcblk0p1.
[  OK  ] Finished Permit User Sessions.
[  OK  ] Started Target Communication Framework agent.
         Mounting /run/media/mmcblk0p1...
[  OK  ] Started Getty on tty1.
         Starting inetd.busybox.service...
         Starting LSB: Kernel NFS server support...
[   12.268911] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  OK  ] Reached target Login Prompts.
[  OK  ] Mounted /run/media/mmcblk0p1.
[  OK  ] Started inetd.busybox.service.
[FAILED] Failed to start LSB: Kernel NFS server support.
See 'systemctl status nfsserver.service' for details.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started User Login Management.
[  OK  ] Stopped FANCONTROL Daemon.
[  OK  ] Reached target Multi-User System.
         Starting Record Runlevel Change in UTMP...
[  OK  ] Finished Record Runlevel Change in UTMP.
PetaLinux 2022.2_release_S10071807 dacproject ttyPS0
dacproject login: analog
Password:
[   51.782953] audit: type=1006 audit(1637342412.432:2): pid=533 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[   51.795537] audit: type=1300 audit(1637342412.432:2): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=7fe1b70b30 a2=4 a3=7fa85c36b0 items=0 ppid=1 pid=533 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[   51.821742] audit: type=1327 audit(1637342412.432:2): proctitle="(systemd)"
dacproject:~$ cd ../../sys/bus/iio/devices/iio
iio:device0/       iio:device1/       iio_sysfs_trigger/
My Device Tree files:
adi-ad9164-fmc-ebz.dts:
// SPDX-License-Identifier: GPL-2.0
 * dts file for AD9172-FMC-EBZ on Xilinx ZynqMP ZCU102 Rev 1.0
 * Copyright (C) 2018-2022 Analog Devices Inc.
// Copied from adi-ad9172-fmc-ebz.dtsi, but changed for AD9164
	clocks {
		adf4355_clkin: clock@0 {
			compatible = "fixed-clock";
			clock-frequency = <120000000>;
			clock-output-names = "clkin";
			#clock-cells = <0>;
		hmc362_clk_div: hmc362 {
			compatible = "fixed-factor-clock";
			clock-div = <4>;
			clock-mult = <1>;
			clocks = <&adf4355>;
			#clock-cells = <0>;
#include <dt-bindings/iio/frequency/ad9508.h>
&fmc_spi {
	ad9508: ad9508@0 {
		#address-cells = <1>;
		#size-cells = <0>;
		#clock-cells = <1>;
		compatible = "adi,ad9508";
		reg = <0>;
		spi-cpol;
		spi-cpha;
		adi,spi-3wire-enable;
		spi-max-frequency = <10000000>;
		clocks = <&hmc362_clk_div>;
		clock-output-names = "ad9508-1_out0","ad9508-1_out1","ad9508-1_out2","ad9508-1_out3";
		ad9508_0_c0:channel@0 {
			reg = <0>;
			adi,extended-name = "GBTCLK0_M2C";
			adi,driver-mode = <(DRIVER_PHASE_NORMAL | DRIVER_MODE_HSTL)>;
			adi,divider-phase = <0>;
			adi,channel-divider = <1>;
		ad9508_0_c1:channel@1 {
			reg = <1>;
			adi,extended-name = "NA";
		ad9508_0_c2:channel@2 {
			reg = <2>;
			adi,extended-name = "SYSREF2";
		ad9508_0_c3:channel@3 {
			reg = <3>;
			adi,extended-name = "SYSREF";
	dac0_ad9164: ad9164@1 {
		#size-cells = <0>;
		compatible = "adi,ad9164";
		reg = <1>;
		spi-cpol;
		spi-cpha;
		//adi,spi-3wire-enable;
		spi-max-frequency = <1000000>;
		clock-names = "dac_clk";
		adi,full-scale-current-mircoamp = <40000>;
		dac_clk-clock-scales = <1 2>;
		/* jesd204-fsm support */
		jesd204-device;
		#jesd204-cells = <2>;
		jesd204-top-device = <0>; /* This is the TOP device */
		jesd204-link-ids = <0>;
		jesd204-inputs = <&axi_ad9164_core 0 0>;
		adi,subclass = <0>;			/* JESD SUBCLASS 0,1,2 */
		adi,version = <1>;			/* JESD VERSION 0=204A,1=204B,2=204C */
		/* MODE 8 */
		adi,interpolation = <2>;
		adi,octets-per-frame = <1>;		/* JESD F */
		adi,frames-per-multiframe = <32>;	/* JESD K */
		adi,converter-resolution = <16>;	/* JESD N */
		adi,bits-per-sample = <16>;		/* JESD NP' */
		adi,converters-per-device = <2>;	/* JESD M */
		adi,control-bits-per-sample = <0>;	/* JESD CS */
		adi,lanes-per-device = <8>;		/* JESD L */
		adi,samples-per-converter-per-frame = <2>; /* JESD S */
	adf4355: adf4355@2 {
		#clock-cells = <0>;
		compatible = "adi,adf4355";
		reg = <2>;
		clocks = <&adf4355_clkin>;
		clock-names = "clkin";
		clock-output-names = "adf4355_out";
		adi,charge-pump-current = <900>;
		adi,muxout-select = <6>;
		adi,mute-till-lock-enable;
		adi,output-a-power = <2>;
		adi,output-b-power = <2>;
		adi,output-b-enable;
		adi,output-a-enable;
		adi,charge-pump-negative-bleed-enable;
		adi,reference-differential-input-enable;
		adi,muxout-level-3v3-enable;
		adi,power-up-frequency = /bits/ 64 <1540000000>;
pl-delete-nodes-zynqmp-zcu102-rev10-ad9164-fmc-ebz.dtsi:
/delete-node/ &axi_sysid_0;
/delete-node/ &dac_dma;
/delete-node/ &dac_jesd204_link_tx_axi;
/delete-node/ &misc_clk_0;
/delete-node/ &dac_jesd204_transport_dac_tpl_core;
/delete-node/ &dac_jesd204_xcvr;
zynqmp-zcu102-rev10-ad9164-fmc-ebz.dts:
 * Analog Devices AD917x-FMC-EBZ
 * https://wiki.analog.com/resources/eval/dpg/ad917x-fmc-ebz
 * https://wiki.analog.com/resources/eval/dpg/eval-ad9172
 * hdl_project: <dac_fmc_ebz/zcu102>
 * board_revision: <>
// Copied from zynqmp-zcu102-rev10-ad9172-fmc-ebz.dts, but changed for AD9164
#include "zynqmp-zcu102-rev1.0.dts"
#include <dt-bindings/interrupt-controller/irq.h>
#include <dt-bindings/jesd204/adxcvr.h>
	fpga_axi: fpga-axi@0 {
		interrupt-parent = <&gic>;
		compatible = "simple-bus";
		#address-cells = <0x1>;
		#size-cells = <0x1>;
		ranges = <0 0 0 0xffffffff>;
		tx_dma: tx-dmac@9c420000 {
			#dma-cells = <1>;
			compatible = "adi,axi-dmac-1.00.a";
			reg = <0x9c420000 0x10000>;
			interrupts = <0 108 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&zynqmp_clk 71>;
		axi_ad9164_core: axi-ad9164-hpc@84a04000 {
			compatible = "adi,axi-ad9164-1.0";
			reg = <0x84a04000 0x10000>;
			dmas = <&tx_dma 0>;
			dma-names = "tx";
			spibus-connected = <&dac0_ad9164>;
			adi,axi-pl-fifo-enable;
			jesd204-device;
			jesd204-inputs = <&axi_ad9164_jesd 0 0>;
		axi_ad9164_jesd: axi-jesd204-tx@84a90000 {
			compatible = "adi,axi-jesd204-tx-1.0";
			reg = <0x84a90000 0x4000>;
			interrupts = <0 106 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&zynqmp_clk 71>, <&axi_ad9164_adxcvr 1>, <&axi_ad9164_adxcvr 0>;
			clock-names = "s_axi_aclk", "device_clk", "lane_clk";
			#clock-cells = <0>;
			clock-output-names = "jesd_dac_lane_clk";
			jesd204-device;
			jesd204-inputs = <&axi_ad9164_adxcvr 0 0>;
		axi_ad9164_adxcvr: axi-adxcvr-tx@84a60000 {
			compatible = "adi,axi-adxcvr-1.0";
			reg = <0x84a60000 0x1000>;
			clocks = <&ad9508 0>;
			clock-names = "conv";
			adi,sys-clk-select = <XCVR_QPLL>;
			adi,out-clk-select = <XCVR_REFCLK>;
			adi,use-lpm-enable;
			#clock-cells = <1>;
			clock-output-names = "dac_gt_clk", "tx_out_clk";
			jesd204-device;
			jesd204-inputs = <&ad9508 0 0>;
		axi_sysid_0: axi-sysid-0@85000000 {
			compatible = "adi,axi-sysid-1.00.a";
			reg = <0x85000000 0x10000>;
&spi0 {
	status = "okay";
#define fmc_spi spi0
#include "adi-ad9164-fmc-ebz.dtsi"
&dac0_ad9164 {
	txen-gpios = <&gpio0 99 0>;
Edit Notes
edited title
[edited by: samdhp at 10:14 PM (GMT -5) on 23 Feb 2024]
  • /* jesd204-fsm support */
    jesd204-device;
    jesd204-inputs = <&ad9508 0>;
    The AD9508 is not a jesd204-fsm enabled device, therefore it must be omitted from the jesd204-fsm topology.
    You can still use it as a clock provider and connect the clock handles but not include it in the jesd204-inputs.
    -Michael
  • Hey Michael, thanks for the quick response. I've excluded the JESD device/inputs from the fpga drivers and AD9164. Instead of using the JESD204 FSM, I'm using the Deprecated Non-jesd204-fsm mode. I'm still getting an error for the AD9508 and AD9164:
    [    4.989735] ad9508 spi1.0: Unexpected device ID (0x00)
    [ 6.948496] ad9162 spi1.1: AD916x DAC Product ID: AD9164
    [ 6.953811] ad9162 spi1.1: AD916x DAC Chip ID: 4
    [ 6.958423] ad9162 spi1.1: AD916x DAC Product Grade: 0
    [ 6.963551] ad9162 spi1.1: AD916x DAC Product Revision: 6
    [ 6.968946] ad9162 spi1.1: AD916x Revision: 1.0.0
    [ 7.084183] ad9162 spi1.1: Serdes PLL Locked (stat: b)
    [ 7.089840] ad9162 spi1.1: code_grp_sync: 0
    [ 7.094023] ad9162 spi1.1: frame_sync_stat: 0
    [ 7.098378] ad9162 spi1.1: good_checksum_stat: 0
    [ 7.102986] ad9162 spi1.1: init_lane_sync_stat: 0
    [ 7.107682] ad9162 spi1.1: Failed to setup JESD interface
    [ 7.113071] ad9162: probe of spi1.1 failed with error -5
    Boot Log:
    CPU:   ZynqMP
    Silicon: v3
    DRAM:  4 GiB
    PMUFW:  v1.1
     Board name:    zcu102
     Board rev:     1.0
    EL Level:       EL2
    Chip ID:        zu9eg
    NAND:  0 MiB
    In:    serial
    Out:   serial
    Err:   serial
    starting USB...
    USB XHCI 1.00
    Scanning mmc 0:1...
    43776648 bytes read in 2861 ms (14.6 MiB/s)
         Created:      2024-02-26   8:25:57 UTC
         Type:         Kernel Image
         Data Size:    11912934 Bytes = 11.4 MiB
         OS:           Linux
         Hash algo:    sha256
         Hash value:   afbd5e2a1a5bb3105b76769ffd3f98a983963477744c61c85f2328230b11fd53
         Type:         RAMDisk Image
         Data Start:   0x10b6b61c
         Data Size:    31801073 Bytes = 30.3 MiB
         OS:           Linux
         Hash algo:    sha256
         Hash value:   7bb74e8ce850531086ebd8cdc0455b8ffe6bab8c2e7694d5a99d88119087695e
         Data Size:    60496 Bytes = 59.1 KiB
         Hash algo:    sha256
         Hash value:   972f384601807d864792918f2da3e6328c24dcee3f88d0e4fda24a1b4d32e1f3
       Loading Ramdisk to 79fa2000, end 7bdf5ef1 ... OK
       Loading Device Tree to 0000000079f90000, end 0000000079fa1c4f ... OK
    Starting kernel ...
    [    0.000000] Linux version 5.15.36-xilinx-v2022.2 (oe-user@oe-host) (aarch64-xilinx-linux-gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.37.20210721) #1 SMP Mon Feb 26 08:25:57 UTC 2024
    [    0.008495] Console: colour dummy device 80x25
    [    0.012487] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=400000)
    [    0.027643] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.034787] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.043634] rcu: Hierarchical SRCU implementation.
    [    0.047582] EFI services will not be available.
    [    0.056706] Detected VIPT I-cache on CPU1
    [    0.056749] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.057152] Detected VIPT I-cache on CPU2
    [    0.057177] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.057560] Detected VIPT I-cache on CPU3
    [    0.057584] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.057629] smp: Brought up 1 node, 4 CPUs
    [    0.101554] CPU features: detected: CRC32 instructions
    [    0.106696] CPU: All CPU(s) started at EL2
    [    0.110736] alternatives: patching kernel code
    [    0.116088] devtmpfs: initialized
    [    0.124640] Registered cp15_barrier emulation handler
    [    0.124694] Registered setend emulation handler
    [    0.128663] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.138251] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.151341] pinctrl core: initialized pinctrl subsystem
    [    0.152140] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.157863] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.163925] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.171662] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.179440] audit: initializing netlink subsys (disabled)
    [    0.184846] audit: type=2000 audit(0.116:1): state=initialized audit_enabled=0 res=1
    [    0.192486] cpuidle: using governor menu
    [    0.196432] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.203162] ASID allocator initialised with 65536 entries
    [    0.229344] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.230410] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.237080] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.243753] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    1.334541] DRBG: Continuing without Jitter RNG
    [    1.435233] raid6: neonx8   gen()  2134 MB/s
    [    1.503296] raid6: neonx8   xor()  1582 MB/s
    [    1.571361] raid6: neonx4   gen()  2195 MB/s
    [    1.639416] raid6: neonx4   xor()  1556 MB/s
    [    1.707480] raid6: neonx2   gen()  2070 MB/s
    [    1.775536] raid6: neonx2   xor()  1428 MB/s
    [    1.843613] raid6: neonx1   gen()  1769 MB/s
    [    1.911678] raid6: neonx1   xor()  1213 MB/s
    [    1.979742] raid6: int64x8  gen()  1367 MB/s
    [    2.047802] raid6: int64x8  xor()   773 MB/s
    [    2.115875] raid6: int64x4  gen()  1603 MB/s
    [    2.183935] raid6: int64x4  xor()   851 MB/s
    [    2.251996] raid6: int64x2  gen()  1397 MB/s
    [    2.320057] raid6: int64x2  xor()   747 MB/s
    [    2.388140] raid6: int64x1  gen()  1034 MB/s
    [    2.456190] raid6: int64x1  xor()   517 MB/s
    [    2.456230] raid6: using algorithm neonx4 gen() 2195 MB/s
    [    2.460178] raid6: .... xor() 1556 MB/s, rmw enabled
    [    2.465114] raid6: using neon recovery algorithm
    [    2.470167] iommu: Default domain type: Translated
    [    2.474545] iommu: DMA domain TLB invalidation policy: strict mode
    [    2.480993] SCSI subsystem initialized
    [    2.484638] usbcore: registered new interface driver usbfs
    [    2.489966] usbcore: registered new interface driver hub
    [    2.495245] usbcore: registered new device driver usb
    [    2.500368] mc: Linux media interface: v0.10
    [    2.504491] videodev: Linux video capture interface: v2.00
    [    2.509976] pps_core: LinuxPPS API ver. 1 registered
    [    2.514852] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    2.523944] PTP clock support registered
    [    2.527846] EDAC MC: Ver: 3.0.0
    [    2.531218] zynqmp-ipi-mbox mailbox@ff990400: Registered ZynqMP IPI mbox with TX/RX channels.
    [    2.539811] jesd204: found 0 devices and 0 topologies
    [    2.544466] FPGA manager framework
    [    2.547937] Advanced Linux Sound Architecture Driver Initialized.
    [    2.554286] Bluetooth: Core ver 2.22
    [    2.557420] NET: Registered PF_BLUETOOTH protocol family
    [    2.562688] Bluetooth: HCI device and connection manager initialized
    [    2.569004] Bluetooth: HCI socket layer initialized
    [    2.573847] Bluetooth: L2CAP socket layer initialized
    [    2.578868] Bluetooth: SCO socket layer initialized
    [    2.584126] clocksource: Switched to clocksource arch_sys_counter
    [    2.589898] VFS: Disk quotas dquot_6.6.0
    [    2.593694] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    2.604948] NET: Registered PF_INET protocol family
    [    2.605449] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    2.614258] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    2.621201] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    2.629236] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    2.636697] TCP: Hash tables configured (established 32768 bind 32768)
    [    2.642857] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    2.649517] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    2.656677] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    2.662493] RPC: Registered named UNIX socket transport module.
    [    2.668049] RPC: Registered udp transport module.
    [    2.672718] RPC: Registered tcp transport module.
    [    2.677387] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    2.684390] PCI: CLS 0 bytes, default 64
    [    2.687818] Trying to unpack rootfs image as initramfs...
    [    2.693843] armv8-pmu pmu: hw perfevents: no interrupt-affinity property, guessing.
    [    2.701011] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [    2.709351] Initialise system trusted keyrings
    [    2.712923] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    2.720322] NFS: Registering the id_resolver key type
    [    2.724201] Key type id_resolver registered
    [    2.728334] Key type id_legacy registered
    [    2.732338] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    2.738983] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    2.746357] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
    [    2.753675] fuse: init (API version 7.34)
    [    2.793895] NET: Registered PF_ALG protocol family
    [    2.793962] xor: measuring software checksum speed
    [    2.801990]    8regs           :  2363 MB/sec
    [    2.805657]    32regs          :  2799 MB/sec
    [    2.810729]    arm64_neon      :  2308 MB/sec
    [    2.810789] xor: using function: 32regs (2799 MB/sec)
    [    2.815824] Key type asymmetric registered
    [    2.819878] Asymmetric key parser 'x509' registered
    [    2.824807] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
    [    2.832079] io scheduler mq-deadline registered
    [    2.836571] io scheduler kyber registered
    [    2.869132] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    [    2.872137] cacheinfo: Unable to detect cache hierarchy for CPU 0
    [    2.880328] brd: module loaded
    [    2.883963] loop: module loaded
    [    2.884399] Registered mathworks_ip class
    [    2.889283] tun: Universal TUN/TAP device driver, 1.6
    [    2.891151] CAN device driver interface
    [    2.895684] SPI driver wl1271_spi has no spi_device_id for ti,wl1271
    [    2.901176] SPI driver wl1271_spi has no spi_device_id for ti,wl1273
    [    2.907484] SPI driver wl1271_spi has no spi_device_id for ti,wl1281
    [    2.913798] SPI driver wl1271_spi has no spi_device_id for ti,wl1283
    [    2.920113] SPI driver wl1271_spi has no spi_device_id for ti,wl1285
    [    2.926427] SPI driver wl1271_spi has no spi_device_id for ti,wl1801
    [    2.932741] SPI driver wl1271_spi has no spi_device_id for ti,wl1805
    [    2.939056] SPI driver wl1271_spi has no spi_device_id for ti,wl1807
    [    2.945370] SPI driver wl1271_spi has no spi_device_id for ti,wl1831
    [    2.951692] SPI driver wl1271_spi has no spi_device_id for ti,wl1835
    [    2.958005] SPI driver wl1271_spi has no spi_device_id for ti,wl1837
    [    2.964522] usbcore: registered new interface driver asix
    [    2.969730] usbcore: registered new interface driver ax88179_178a
    [    2.975772] usbcore: registered new interface driver cdc_ether
    [    2.981570] usbcore: registered new interface driver net1080
    [    2.987184] usbcore: registered new interface driver cdc_subset
    [    2.993068] usbcore: registered new interface driver zaurus
    [    2.998622] usbcore: registered new interface driver cdc_ncm
    [    3.005025] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    3.010684] ehci-pci: EHCI PCI platform driver
    [    3.015604] usbcore: registered new interface driver uas
    [    3.020416] usbcore: registered new interface driver usb-storage
    [    3.026403] usbcore: registered new interface driver usbserial_generic
    [    3.032839] usbserial: USB Serial support registered for generic
    [    3.038823] usbcore: registered new interface driver ftdi_sio
    [    3.044518] usbserial: USB Serial support registered for FTDI USB Serial Device
    [    3.051806] usbcore: registered new interface driver upd78f0730
    [    3.057667] usbserial: USB Serial support registered for upd78f0730
    [    3.065094] SPI driver ads7846 has no spi_device_id for ti,tsc2046
    [    3.070024] SPI driver ads7846 has no spi_device_id for ti,ads7843
    [    3.076163] SPI driver ads7846 has no spi_device_id for ti,ads7845
    [    3.082302] SPI driver ads7846 has no spi_device_id for ti,ads7873
    [    3.089146] rtc_zynqmp ffa60000.rtc: registered as rtc0
    [    3.093655] rtc_zynqmp ffa60000.rtc: setting system clock to 2021-01-23T15:39:31 UTC (1611416371)
    [    3.102636] i2c_dev: i2c /dev entries driver
    [    3.108723] usbcore: registered new interface driver uvcvideo
    [    3.113972] Bluetooth: HCI UART driver ver 2.3
    [    3.116826] Bluetooth: HCI UART protocol H4 registered
    [    3.121930] Bluetooth: HCI UART protocol BCSP registered
    [    3.127230] Bluetooth: HCI UART protocol LL registered
    [    3.132298] Bluetooth: HCI UART protocol ATH3K registered
    [    3.137681] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [    3.144032] Bluetooth: HCI UART protocol Intel registered
    [    3.149281] Bluetooth: HCI UART protocol QCA registered
    [    3.154503] usbcore: registered new interface driver bcm203x
    [    3.160108] usbcore: registered new interface driver bpa10x
    [    3.165637] usbcore: registered new interface driver bfusb
    [    3.171097] usbcore: registered new interface driver btusb
    [    3.176556] usbcore: registered new interface driver ath3k
    [    3.182142] EDAC MC: ECC not enabled
    [    3.185819] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
    [    3.198255] sdhci: Secure Digital Host Controller Interface driver
    [    3.203753] sdhci: Copyright(c) Pierre Ossman
    [    3.208071] sdhci-pltfm: SDHCI platform and OF driver helper
    [    3.214440] ledtrig-cpu: registered to indicate activity on CPUs
    [    3.219848] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    3.226186] zynqmp_firmware_probe Platform Management API v1.1
    [    3.231865] zynqmp_firmware_probe Trustzone version v1.0
    [    3.268615] zynqmp-aes firmware:zynqmp-firmware:zynqmp-aes: will run requests pump with realtime priority
    [    4.180886] Freeing initrd memory: 31052K
    [    4.197238] zynqmp-keccak-384 firmware:zynqmp-firmware:sha384: The zynqmp-sha-deprecated driver shall be deprecated in 2022.2 and removed in 2023.1 release
    [    4.205577] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
    [    4.211844] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
    [    4.217320] usbcore: registered new interface driver usbhid
    [    4.222701] usbhid: USB HID core driver
    [    4.226698] SPI driver fb_seps525 has no spi_device_id for syncoam,seps525
    [    4.234036] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7988-5
    [    4.240520] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7988-1
    [    4.247697] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7984
    [    4.254703] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7983
    [    4.261710] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7982
    [    4.268716] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7980
    [    4.275723] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7949
    [    4.282729] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7946
    [    4.289736] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7942
    [    4.296742] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7699
    [    4.303749] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7693
    [    4.310755] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7691
    [    4.317762] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7690
    [    4.324768] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7689
    [    4.331775] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7688
    [    4.338781] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7687
    [    4.345792] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7686
    [    4.352795] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7685
    [    4.359801] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7682
    [    4.366923] SPI driver ad7124 has no spi_device_id for adi,ad7124-4
    [    4.373036] SPI driver ad7124 has no spi_device_id for adi,ad7124-8
    [    4.379277] SPI driver ad7192 has no spi_device_id for adi,ad7190
    [    4.385319] SPI driver ad7192 has no spi_device_id for adi,ad7193
    [    4.391373] SPI driver ad7192 has no spi_device_id for adi,ad7195
    [    4.398223] SPI driver ad9467 has no spi_device_id for adi,ad9643
    [    4.403485] SPI driver ad9467 has no spi_device_id for adi,ad9250
    [    4.409538] SPI driver ad9467 has no spi_device_id for adi,ad9250_2
    [    4.415766] SPI driver ad9467 has no spi_device_id for adi,ad9265
    [    4.421821] SPI driver ad9467 has no spi_device_id for adi,ad9683
    [    4.427876] SPI driver ad9467 has no spi_device_id for adi,ad9434
    [    4.433931] SPI driver ad9467 has no spi_device_id for adi,ad9625
    [    4.439986] SPI driver ad9467 has no spi_device_id for adi,ad9652
    [    4.446041] SPI driver ad9467 has no spi_device_id for adi,ad9649
    [    4.454850] SPI driver adar3000 has no spi_device_id for adi,adar3001
    [    4.458503] SPI driver adar3000 has no spi_device_id for adi,adar3002
    [    4.466129] SPI driver ad9783 has no spi_device_id for adi,ad9780
    [    4.470959] SPI driver ad9783 has no spi_device_id for adi,ad9781
    [    4.477194] SPI driver adis16475 has no spi_device_id for adi,adis16470
    [    4.483584] SPI driver adis16475 has no spi_device_id for adi,adis16475-1
    [    4.490329] SPI driver adis16475 has no spi_device_id for adi,adis16475-2
    [    4.497076] SPI driver adis16475 has no spi_device_id for adi,adis16475-3
    [    4.503823] SPI driver adis16475 has no spi_device_id for adi,adis16477-1
    [    4.510570] SPI driver adis16475 has no spi_device_id for adi,adis16477-2
    [    4.517317] SPI driver adis16475 has no spi_device_id for adi,adis16477-3
    [    4.524064] SPI driver adis16475 has no spi_device_id for adi,adis16465-1
    [    4.530811] SPI driver adis16475 has no spi_device_id for adi,adis16465-2
    [    4.537558] SPI driver adis16475 has no spi_device_id for adi,adis16465-3
    [    4.544305] SPI driver adis16475 has no spi_device_id for adi,adis16467-1
    [    4.551052] SPI driver adis16475 has no spi_device_id for adi,adis16467-2
    [    4.557799] SPI driver adis16475 has no spi_device_id for adi,adis16467-3
    [    4.564546] SPI driver adis16475 has no spi_device_id for adi,adis16500
    [    4.571120] SPI driver adis16475 has no spi_device_id for adi,adis16505-1
    [    4.577867] SPI driver adis16475 has no spi_device_id for adi,adis16505-2
    [    4.584614] SPI driver adis16475 has no spi_device_id for adi,adis16505-3
    [    4.591361] SPI driver adis16475 has no spi_device_id for adi,adis16507-1
    [    4.598112] SPI driver adis16475 has no spi_device_id for adi,adis16507-2
    [    4.604855] SPI driver adis16475 has no spi_device_id for adi,adis16507-3
    [    4.612661] axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.01.a) found
    [    4.619567] axi_sysid 85000000.axi-sysid-0: [dac_fmc_ebz] [AD9164 - 08] on [zcu102] git branch <hdl_2022_r2> git <e2a27347334a84d8618bc72d34fed0d8920a04b4> dirty [2024-02-23 16:05:50] UTC
    [    4.636582] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
    [    4.642871] usbcore: registered new interface driver snd-usb-audio
    [    4.650398] pktgen: Packet Generator for packet performance testing. Version: 2.75
    [    4.656852] Initializing XFRM netlink socket
    [    4.660380] NET: Registered PF_INET6 protocol family
    [    4.665740] Segment Routing with IPv6
    [    4.668902] In-situ OAM (IOAM) with IPv6
    [    4.672827] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    4.678983] NET: Registered PF_PACKET protocol family
    [    4.683673] NET: Registered PF_KEY protocol family
    [    4.688508] can: controller area network core
    [    4.692772] NET: Registered PF_CAN protocol family
    [    4.697501] can: raw protocol
    [    4.700441] can: broadcast manager protocol
    [    4.704595] can: netlink gateway - max_hops=1
    [    4.708986] Bluetooth: RFCOMM TTY layer initialized
    [    4.713769] Bluetooth: RFCOMM socket layer initialized
    [    4.718879] Bluetooth: RFCOMM ver 1.11
    [    4.722594] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    4.727861] Bluetooth: BNEP filters: protocol multicast
    [    4.733053] Bluetooth: BNEP socket layer initialized
    [    4.737981] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    4.743865] Bluetooth: HIDP socket layer initialized
    [    4.748930] 9pnet: Installing 9P2000 support
    [    4.753062] NET: Registered PF_IEEE802154 protocol family
    [    4.758411] Key type dns_resolver registered
    [    4.762863] registered taskstats version 1
    [    4.766701] Loading compiled-in X.509 certificates
    [    4.771972] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
    [    4.787241] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 48, base_baud = 6249999) is a xuartps
    [    4.796279] printk: console [ttyPS0] enabled
    [    4.800580] printk: bootconsole [cdns0] disabled
    [    4.810128] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 49, base_baud = 6249999) is a xuartps
    [    4.823347] of-fpga-region fpga-full: FPGA Region probed
    [    4.829878] nwl-pcie fd0e0000.pcie: host bridge /axi/pcie@fd0e0000 ranges:
    [    4.836778] nwl-pcie fd0e0000.pcie:      MEM 0x00e0000000..0x00efffffff -> 0x00e0000000
    [    4.844804] nwl-pcie fd0e0000.pcie:      MEM 0x0600000000..0x07ffffffff -> 0x0600000000
    [    4.852876] nwl-pcie fd0e0000.pcie: Link is DOWN
    [    4.857643] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
    [    4.863821] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    4.869309] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
    [    4.876178] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
    [    4.883692] pci 0000:00:00.0: [10ee:d021] type 01 class 0x060400
    [    4.889752] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
    [    4.900064] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
    [    4.905814] xilinx-zynqmp-dma fd500000.dma-controller: ZynqMP DMA driver Probe success
    [    4.913899] xilinx-zynqmp-dma fd510000.dma-controller: ZynqMP DMA driver Probe success
    [    4.921985] xilinx-zynqmp-dma fd520000.dma-controller: ZynqMP DMA driver Probe success
    [    4.930067] xilinx-zynqmp-dma fd530000.dma-controller: ZynqMP DMA driver Probe success
    [    4.938152] xilinx-zynqmp-dma fd540000.dma-controller: ZynqMP DMA driver Probe success
    [    4.946229] xilinx-zynqmp-dma fd550000.dma-controller: ZynqMP DMA driver Probe success
    [    4.954315] xilinx-zynqmp-dma fd560000.dma-controller: ZynqMP DMA driver Probe success
    [    4.962391] xilinx-zynqmp-dma fd570000.dma-controller: ZynqMP DMA driver Probe success
    [    4.970704] xilinx-zynqmp-dpdma fd4c0000.dma-controller: Xilinx DPDMA engine is probed
    [    4.995479] adf5355 spi1.2: supply vcc not found, using dummy regulator
    [    5.004061] spi-nor spi0.0: SPI-NOR-UniqueID aaed0400060a000d00d432c0b277
    [    5.010854] spi-nor spi0.0: found mt25qu512a, expected m25p80
    [    5.016943] spi-nor spi0.0: mt25qu512a (131072 Kbytes)
    [    5.022105] 4 fixed-partitions partitions found on MTD device spi0.0
    [    5.028453] Creating 4 MTD partitions on "spi0.0":
    [    5.033245] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
    [    5.039863] 0x000000100000-0x000000600000 : "qspi-linux"
    [    5.045907] 0x000000600000-0x000000620000 : "qspi-device-tree"
    [    5.052452] 0x000000620000-0x000000c00000 : "qspi-rootfs"
    [    5.059491] xilinx_can ff070000.can can0: TDC Offset value not in range
    [    5.067749] macb ff0e0000.ethernet: Not enabling partial store and forward
    [    5.078000] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 30 (00:0a:35:07:65:f0)
    [    5.088312] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
    [    5.094853] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
    [    5.101341] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
    [    5.107831] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
    [    5.115243] pca953x 0-0020: supply vcc not found, using dummy regulator
    [    5.121948] pca953x 0-0020: using no AI
    [    5.126444] gpio-318 (sel0): hogged as output/low
    [    5.131346] gpio-319 (sel1): hogged as output/high
    [    5.136340] gpio-320 (sel2): hogged as output/high
    [    5.141325] gpio-321 (sel3): hogged as output/high
    [    5.146486] pca953x 0-0021: supply vcc not found, using dummy regulator
    [    5.153164] pca953x 0-0021: using no AI
    [    5.158648] ina2xx 2-0040: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.165643] ina2xx 2-0041: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.172650] ina2xx 2-0042: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.179646] ina2xx 2-0043: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.186642] ina2xx 2-0044: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.193640] ina2xx 2-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.200655] ina2xx 2-0046: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.207652] ina2xx 2-0047: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.214702] ina2xx 2-004a: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.221702] ina2xx 2-004b: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.228122] i2c i2c-0: Added multiplexed i2c bus 2
    [    5.233683] ina2xx 3-0040: power monitor ina226 (Rshunt = 2000 uOhm)
    [    5.240701] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.247696] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.254688] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.261694] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.268705] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.275711] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.282708] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
    [    5.289116] i2c i2c-0: Added multiplexed i2c bus 3
    [    5.303810] random: fast init done
    [    5.347934] i2c i2c-0: Added multiplexed i2c bus 4
    [    5.352881] i2c i2c-0: Added multiplexed i2c bus 5
    [    5.357670] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
    [    5.365044] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 32
    [    5.372498] at24 6-0054: supply vcc not found, using dummy regulator
    [    5.379394] at24 6-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
    [    5.386152] i2c i2c-1: Added multiplexed i2c bus 6
    [    5.391522] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
    [    5.398831] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
    [    5.406140] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
    [    5.413444] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
    [    5.420749] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
    [    5.428053] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
    [    5.435361] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
    [    5.442661] si5341 7-0036: no regulator set, defaulting vdd_sel to 2.5V for out
    [    5.451070] si5341 7-0036: Chip: 5341 Grade: 1 Rev: 1
    [    5.489615] i2c i2c-1: Added multiplexed i2c bus 7
    [    5.497289] si570 8-005d: registered, current frequency 300000000 Hz
    [    5.503694] i2c i2c-1: Added multiplexed i2c bus 8
    [    5.523476] si570 9-005d: registered, current frequency 148500000 Hz
    [    5.529883] i2c i2c-1: Added multiplexed i2c bus 9
    [    5.534902] si5324 10-0069: si5328 probed
    [    5.600511] si5324 10-0069: si5328 probe successful
    [    5.605445] i2c i2c-1: Added multiplexed i2c bus 10
    [    5.610480] i2c i2c-1: Added multiplexed i2c bus 11
    [    5.615517] i2c i2c-1: Added multiplexed i2c bus 12
    [    5.620549] i2c i2c-1: Added multiplexed i2c bus 13
    [    5.625430] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
    [    5.633441] i2c i2c-1: Added multiplexed i2c bus 14
    [    5.638489] i2c i2c-1: Added multiplexed i2c bus 15
    [    5.643537] i2c i2c-1: Added multiplexed i2c bus 16
    [    5.648582] i2c i2c-1: Added multiplexed i2c bus 17
    [    5.653621] i2c i2c-1: Added multiplexed i2c bus 18
    [    5.658675] i2c i2c-1: Added multiplexed i2c bus 19
    [    5.663719] i2c i2c-1: Added multiplexed i2c bus 20
    [    5.672575] i2c i2c-1: Added multiplexed i2c bus 21
    [    5.677449] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
    [    5.685070] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 33
    [    5.694503] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
    [    5.704642] zynqmp-display fd4a0000.display: vtc bridge property not present
    [    5.712861] zynqmp_clk_divider_set_rate() set divider failed for spi1_ref_div1, ret = -13
    [    5.722540] xilinx-dp-snd-codec fd4a0000.display:zynqmp_dp_snd_codec0: Failed to get required clock freq
    [    5.732033] xilinx-dp-snd-codec: probe of fd4a0000.display:zynqmp_dp_snd_codec0 failed with error -22
    [    5.736365] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
    [    5.741528] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
    [    5.756979] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
    [    5.765144] OF: graph: no port node found in /axi/display@fd4a0000
    [    5.771653] xlnx-drm xlnx-drm.0: bound fd4a0000.display (ops 0xffffffc009196640)
    [    5.782803] mmc0: new high speed SDHC card at address 5048
    [    5.788664] mmcblk0: mmc0:5048 SD32G 29.7 GiB
    [    5.795604]  mmcblk0: p1
    [    6.856151] zynqmp-display fd4a0000.display: [drm] Cannot find any crtc or sizes
    [    6.863801] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.display on minor 0
    [    6.871313] zynqmp-display fd4a0000.display: ZynqMP DisplayPort Subsystem driver probed
    [    6.879592] ahci-ceva fd0c0000.ahci: supply ahci not found, using dummy regulator
    [    6.887152] ahci-ceva fd0c0000.ahci: supply phy not found, using dummy regulator
    [    6.894629] ahci-ceva fd0c0000.ahci: supply target not found, using dummy regulator
    [    6.902472] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
    [    6.911430] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
    [    6.922112] scsi host0: ahci-ceva
    [    6.925710] scsi host1: ahci-ceva
    [    6.929145] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 45
    [    6.937062] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 45
    [    7.139006] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    7.144511] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
    [    7.152266] xhci-hcd xhci-hcd.1.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000002010890
    [    7.161691] xhci-hcd xhci-hcd.1.auto: irq 56, io mem 0xfe200000
    [    7.167848] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
    [    7.176111] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    7.183329] usb usb1: Product: xHCI Host Controller
    [    7.188203] usb usb1: Manufacturer: Linux 5.15.36-xilinx-v2022.2 xhci-hcd
    [    7.194986] usb usb1: SerialNumber: xhci-hcd.1.auto
    [    7.200181] hub 1-0:1.0: USB hub found
    [    7.203941] hub 1-0:1.0: 1 port detected
    [    7.208067] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    7.213552] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
    [    7.221207] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
    [    7.227843] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
    [    7.236108] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    7.243334] usb usb2: Product: xHCI Host Controller
    [    7.248204] usb usb2: Manufacturer: Linux 5.15.36-xilinx-v2022.2 xhci-hcd
    [    7.254982] usb usb2: SerialNumber: xhci-hcd.1.auto
    [    7.258386] ata1: SATA link down (SStatus 0 SControl 330)
    [    7.260174] hub 2-0:1.0: USB hub found
    [    7.265279] ata2: SATA link down (SStatus 0 SControl 330)
    [    7.269006] hub 2-0:1.0: 1 port detected
    [    7.288465] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    7.295542] of_cfs_init
    [    7.298014] of_cfs_init: OK
    [    7.300978] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    7.441717] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    7.448261] clk: Not disabling unused clocks
    [    7.452806] ALSA device list:
    [    7.455762]   No soundcards found.
    [    7.459430] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    7.468040] cfg80211: failed to load regulatory.db
    [    7.473487] Freeing unused kernel memory: 2624K
    [    7.488183] Run /init as init process
    [    7.501634] systemd[1]: System time before build time, advancing clock.
    [    7.511891] systemd[1]: systemd 249.7+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    7.542223] systemd[1]: Detected architecture arm64.
    [    7.584272] systemd[1]: Hostname set to <dacproject>.
    [    7.589440] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.596074] systemd[1]: Initializing machine ID from random generator.
    [    7.630437] systemd-sysv-generator[145]: SysV service '/etc/init.d/watchdog-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    7.657428] systemd-sysv-generator[145]: SysV service '/etc/init.d/nfsserver' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    7.681495] systemd-sysv-generator[145]: SysV service '/etc/init.d/nfscommon' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    7.705819] systemd-sysv-generator[145]: SysV service '/etc/init.d/inetd.busybox' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    7.732232] systemd-sysv-generator[145]: SysV service '/etc/init.d/dropbear' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    7.957442] systemd[1]: Queued start job for default target Multi-User System.
    [    7.965588] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.976169] zynqmp-display fd4a0000.display: [drm] Cannot find any crtc or sizes
    [    8.010758] systemd[1]: Created slice Slice /system/getty.
    [    8.032257] random: systemd: uninitialized urandom read (16 bytes read)
    [    8.040218] systemd[1]: Created slice Slice /system/modprobe.
    [    8.061479] systemd[1]: Created slice Slice /system/serial-getty.
    [    8.085250] systemd[1]: Created slice User and Session Slice.
    [    8.108406] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    8.132336] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    8.156341] systemd[1]: Reached target Path Units.
    [    8.172237] systemd[1]: Reached target Remote File Systems.
    [    8.192224] systemd[1]: Reached target Slice Units.
    [    8.208246] systemd[1]: Reached target Swaps.
    [    8.224657] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    8.248213] systemd[1]: Reached target RPC Port Mapper.
    [    8.268468] systemd[1]: Listening on Syslog Socket.
    [    8.284368] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    8.308723] systemd[1]: Listening on Journal Audit Socket.
    [    8.328429] systemd[1]: Listening on Journal Socket (/dev/log).
    [    8.348503] systemd[1]: Listening on Journal Socket.
    [    8.364643] systemd[1]: Listening on Network Service Netlink Socket.
    [    8.388485] systemd[1]: Listening on udev Control Socket.
    [    8.408425] systemd[1]: Listening on udev Kernel Socket.
    [    8.428431] systemd[1]: Listening on User Database Manager Socket.
    [    8.454763] systemd[1]: Mounting Huge Pages File System...
    [    8.474923] systemd[1]: Mounting POSIX Message Queue File System...
    [    8.498943] systemd[1]: Mounting Kernel Debug File System...
    [    8.516584] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
    [    8.527735] systemd[1]: Mounting Temporary Directory /tmp...
    [    8.544545] systemd[1]: Condition check resulted in Create List of Static Device Nodes being skipped.
    [    8.556874] systemd[1]: Starting Load Kernel Module configfs...
    [    8.575406] systemd[1]: Starting Load Kernel Module drm...
    [    8.595152] systemd[1]: Starting Load Kernel Module fuse...
    [    8.615145] systemd[1]: Starting RPC Bind...
    [    8.632299] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    8.642048] systemd[1]: Condition check resulted in Load Kernel Modules being skipped.
    [    8.652461] systemd[1]: Mounting NFSD configuration filesystem...
    [    8.675126] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    8.699194] systemd[1]: Starting Apply Kernel Variables...
    [    8.723107] systemd[1]: Starting Coldplug All udev Devices...
    [    8.744810] systemd[1]: Started RPC Bind.
    [    8.760704] systemd[1]: Mounted Huge Pages File System.
    [    8.780670] systemd[1]: Mounted POSIX Message Queue File System.
    [    8.804723] systemd[1]: Mounted Kernel Debug File System.
    [    8.824666] systemd[1]: Mounted Temporary Directory /tmp.
    [    8.845150] systemd[1]: modprobe@configfs.service: Deactivated successfully.
    [    8.853437] systemd[1]: Finished Load Kernel Module configfs.
    [    8.877174] systemd[1]: modprobe@drm.service: Deactivated successfully.
    [    8.885388] systemd[1]: Finished Load Kernel Module drm.
    [    8.909257] systemd[1]: modprobe@fuse.service: Deactivated successfully.
    [    8.917352] systemd[1]: Finished Load Kernel Module fuse.
    [    8.940533] systemd[1]: proc-fs-nfsd.mount: Mount process exited, code=exited, status=32/n/a
    [    8.949003] systemd[1]: proc-fs-nfsd.mount: Failed with result 'exit-code'.
    [    8.957265] systemd[1]: Failed to mount NFSD configuration filesystem.
    [    8.992176] systemd[1]: Dependency failed for NFS Mount Daemon.
    [    9.012177] systemd[1]: Dependency failed for NFS server and services.
    [    9.036176] systemd[1]: nfs-server.service: Job nfs-server.service/start failed with result 'dependency'.
    [    9.045809] systemd[1]: nfs-mountd.service: Job nfs-mountd.service/start failed with result 'dependency'.
    [    9.056946] systemd[1]: Finished Remount Root and Kernel File Systems.
    [    9.081647] systemd[1]: Finished Apply Kernel Variables.
    [    9.109761] systemd[1]: Mounting FUSE Control File System...
    [    9.127042] systemd[1]: Mounting Kernel Configuration File System...
    [    9.148491] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
    [    9.157294] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
    [    9.169831] systemd[1]: Starting Create System Users...
    [    9.188375] systemd[1]: Mounted FUSE Control File System.
    [    9.208821] systemd[1]: Mounted Kernel Configuration File System.
    [    9.234010] systemd[1]: Finished Create System Users.
    [    9.251682] systemd[1]: Starting Create Static Device Nodes in /dev...
    [    9.278219] systemd[1]: Finished Create Static Device Nodes in /dev.
    [    9.300561] systemd[1]: Reached target Preparation for Local File Systems.
    [    9.327114] systemd[1]: Mounting /var/volatile...
    [    9.348015] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
    [    9.372980] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    9.385945] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    9.398354] systemd[1]: Starting Journal Service...
    [    9.416643] systemd[1]: Starting Rule-based Manager for Device Events and Files...
    [    9.442604] systemd[1]: Mounted /var/volatile.
    [    9.456578] systemd[1]: Condition check resulted in Bind mount volatile /var/cache being skipped.
    [    9.476291] systemd[1]: Condition check resulted in Bind mount volatile /var/lib being skipped.
    [    9.498862] systemd[1]: Starting Load/Save Random Seed...
    [    9.517285] systemd[1]: Condition check resulted in Bind mount volatile /var/spool being skipped.
    [    9.526392] systemd[1]: Condition check resulted in Bind mount volatile /srv being skipped.
    [    9.534996] systemd[1]: Reached target Local File Systems.
    [    9.561971] systemd[1]: Starting Rebuild Dynamic Linker Cache...
    [    9.581252] systemd[1]: Started Rule-based Manager for Device Events and Files.
    [    9.621963] systemd[1]: Finished Coldplug All udev Devices.
    [    9.644881] systemd[1]: Started Journal Service.
    [    9.714084] systemd-journald[175]: Received client request to flush runtime journal.
    [   10.340157] macb ff0e0000.ethernet eth0: PHY [ff0e0000.ethernet-ffffffff:0c] driver [TI DP83867] (irq=POLL)
    [   10.349995] macb ff0e0000.ethernet eth0: configuring for phy/rgmii-id link mode
    [   10.454145] pps pps0: new PPS source ptp0
    [   10.488292] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
    [  OK  ] Started Network Name Resolution.[   11.122074] random: crng init done
    [   11.126335] random: 7 urandom warning(s) missed due to ratelimiting
    [   12.377313] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    dacproject login:
    adi-ad9164-fmc-ebz.dtsi:
    	clocks {
    			#clock-cells = <0>;
    			clock-div = <4>;
    			clock-mult = <1>;
    			#clock-cells = <0>;
    &fmc_spi {
    	ad9508: ad9508@0 {
    		#size-cells = <0>;
    		#clock-cells = <1>;
    		reg = <0>;
    		spi-cpol;
    		spi-cpha;
    			reg = <0>;
    			reg = <1>;
    			reg = <2>;
    			reg = <3>;
    		#size-cells = <0>;
    		reg = <1>;
    		spi-cpol;
    		spi-cpha;
    		/* MODE 8 */
    		#clock-cells = <0>;
    		reg = <2>;
    			#dma-cells = <1>;
    			dmas = <&tx_dma 0>;
    			dma-names = "tx";
    			#clock-cells = <0>;
    			// Copy from AD9164: JESD Configuration
    			adi,subclass = <0>;
    			adi,use-lpm-enable;
    			#clock-cells = <1>;
    &spi0 {
    	status = "okay";
    &dac0_ad9164 {
