Kernel Hangs on inclusion of pl.dtsi and on changing the compatibility strings of the DMAs and Sysid nodes
The user encountered kernel hangs when including pl.dtsi in their custom device tree for a design using the Kria K26 SOM and AD9364 chip. The solution was to ensure the top.bit file was included in the bootgen.bif. The issue was related to the SPI devices not showing up, and the correct compatibility strings were used in the device tree.
Product Number: ad9361
Software Version: 2023.1
Hey. Im using petalinux and vivado 2023.1 . I have a HDL for my custom board that uses the Kria k26c Som and the ad9364 chip.
I based my design off of the fmcomms2 design.
Im trying to include pl.dtsi in my custon-devicetree but after the inclusion of pl.dtsi my kernel hangs and this is the boot log.
Zynq MP First Stage Boot Loader
Release 2023.1   May  1 2023  -  00:38:12
MultiBootOffset: 0x0
Reset Mode      :       System Reset
Platform: Silicon (4.0), Running on A53-0 (64-bit) Processor, Device Name: XCZUUNKNEG
QSPI 32 bit Boot Mode
FlashID=0x20 0xBB 0x20
Skipping the Partition 0x4
▒  BL31: Non secure code at 0x8000000e ▒ꊕ
NOTICE:  BL31: v2.8(release):xlnx_rebase_v2.8_2023.1_update1
NOTICE:  BL31: Built : 09:24:17, Apr 12 2023
U-Boot 2023.01 (Mar 29 2023 - 13:08:40 +0000)
CPU:   ZynqMP
Silicon: v3
Chip:  xck26
Detected name: zynqmp-sm-k26-xcl2gi-rev1
Model: ZynqMP SM-K26 Rev1/B/A
Board: Xilinx ZynqMP
DRAM:  2 GiB (effective 4 GiB)
PMUFW:  v1.1
Xilinx I2C FRU format at nvmem0:
 Manufacturer Name: XILINX
 Product Name: SM-K26-XCL2GI
 Serial No: XFL1JNRSSQX5
 Part Number: 5057-03
 File ID: 0x0
 Revision Number: 1
EL Level:       EL2
Secure Boot:    not authenticated, not encrypted
Core:  61 devices, 29 uclasses, devicetree: board
NAND:  0 MiB
MMC:   mmc@ff160000: 0
Loading Environment from nowhere... OK
In:    serial
Out:   serial
Err:   serial
Bootmode: QSPI_MODE
Reset reason:   EXTERNAL
Net:   Could not get PHY for eth0: addr -19
No ethernet found.
Hit any key to stop autoboot:  0
SF: Detected mt25qu512a with page size 256 Bytes, erase size 64 KiB, total 64 MiB
device 0 offset 0xa00000, size 0xbc0
SF: 3008 bytes @ 0xa00000 Read: OK
## Executing script at 20000000
device 0 offset 0xa00500, size 0x35ffb00
SF: 56621824 bytes @ 0xa00500 Read: OK
## Loading kernel from FIT Image at 10000000 ...
   Using 'conf-system-top.dtb' configuration
   Trying 'kernel-1' kernel subimage
     Description:  Linux kernel
     Created:      2023-12-20  15:50:24 UTC
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x10000100
     Data Size:    12457351 Bytes = 11.9 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00200000
     Entry Point:  0x00200000
     Hash algo:    sha256
     Hash value:   429005a2fa2f55ac79101f59629b6db0380cc459d20348c928a372acbac7aa34
   Verifying Hash Integrity ... sha256+ OK
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk-1' ramdisk subimage
     Description:  petalinux-image-minimal
     Type:         RAMDisk Image
     Compression:  uncompressed
     Data Start:   0x10bee3bc
     Data Size:    35247994 Bytes = 33.6 MiB
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha256
     Hash value:   46a4442a25dc6dbc23546092a05629f8e0580a336598a92805c5fbf8ef4aa9d9
## Loading fdt from FIT Image at 10000000 ...
   Trying 'fdt-system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x10be1798
     Data Size:    52050 Bytes = 50.8 KiB
     Hash algo:    sha256
     Hash value:   8d548bc7afa5dd2636a2d12cf37ff62a27063c2afd82dbe554e38bf42c412a11
   Booting using the fdt blob at 0x10be1798
Working FDT set to 10be1798
   Uncompressing Kernel Image
   Loading Ramdisk to 79a54000, end 7bbf177a ... OK
   Loading Device Tree to 0000000079a44000, end 0000000079a53b51 ... OK
Working FDT set to 79a44000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.1.0-xilinx-v2023.1 (oe-user@oe-host) (aarch64-xilinx-linux-gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0.20220819) #1 SMP Wed Dec 20 15:50:24 UTC 2023
[    0.000000] Machine model: ZynqMP SM-K26 Rev1/B/A
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff010000 (options '115200n8')
[    0.000000] printk: bootconsole [cdns0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000087fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000007fefffff]
[    0.000000]   node   0: [mem 0x0000000800000000-0x000000087fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000087fffffff]
[    0.000000] On node 0, zone Normal: 256 pages in unavailable ranges
[    0.000000] cma: Reserved 256 MiB at 0x0000000069a00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 18 pages/cpu s35368 r8192 d30168 u73728
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1031940
[    0.000000] Kernel command line: earlycon console=ttyPS1,115200 clk_ignore_unused earlyprintk
[    0.000000] Unknown kernel command line parameters "earlyprintk", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x000000007bf00000-0x000000007ff00000] (64MB)
[    0.000000] Memory: 3711188K/4193280K available (17856K kernel code, 1768K rwdata, 15524K rodata, 2752K init, 673K bss, 219948K reserved, 262144K cma-reserved)
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x1ffffffffffffff max_cycles: 0x171015c90f, max_idle_ns: 440795203080 ns
[    0.000000] sched_clock: 57 bits at 100MHz, resolution 10ns, wraps every 4398046511101ns
[    0.008444] Console: colour dummy device 80x25
[    0.012557] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399996)
[    0.022972] pid_max: default: 32768 minimum: 301
[    0.027773] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.034988] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.043866] rcu: Hierarchical SRCU implementation.
[    0.047596] rcu:     Max phase no-delay instances is 1000.
[    0.053021] EFI services will not be available.
[    0.057493] smp: Bringing up secondary CPUs ...
[    0.203157] Detected VIPT I-cache on CPU1
[    0.203223] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.577265] Detected VIPT I-cache on CPU2
[    0.577319] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.953222] Detected VIPT I-cache on CPU3
[    0.953276] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.953320] smp: Brought up 1 node, 4 CPUs
[    0.983355] SMP: Total of 4 processors activated.
[    0.988054] CPU features: detected: 32-bit EL0 Support
[    0.993187] CPU features: detected: CRC32 instructions
[    0.998376] CPU: All CPU(s) started at EL2
[    1.002410] alternatives: applying system-wide alternatives
[    1.009003] devtmpfs: initialized
[    1.015660] Registered cp15_barrier emulation handler
[    1.016336] Registered setend emulation handler
[    1.020949] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    1.030605] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    1.043149] pinctrl core: initialized pinctrl subsystem
[    1.044016] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    1.049283] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    1.055794] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    1.063576] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    1.071397] audit: initializing netlink subsys (disabled)
[    1.076881] audit: type=2000 audit(1.008:1): state=initialized audit_enabled=0 res=1
[    1.077174] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    1.091338] ASID allocator initialised with 65536 entries
[    1.113830] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    1.114985] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    1.121605] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    1.128402] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
[    1.134825] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    1.141609] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    1.147962] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    1.154746] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    1.229073] raid6: neonx8   gen()  2510 MB/s
[    1.297129] raid6: neonx4   gen()  2462 MB/s
[    1.365194] raid6: neonx2   gen()  2358 MB/s
[    1.433247] raid6: neonx1   gen()  2017 MB/s
[    1.501303] raid6: int64x8  gen()  1572 MB/s
[    1.569357] raid6: int64x4  gen()  1743 MB/s
[    1.637412] raid6: int64x2  gen()  1551 MB/s
[    1.705474] raid6: int64x1  gen()  1148 MB/s
[    1.705513] raid6: using algorithm neonx8 gen() 2510 MB/s
[    1.777538] raid6: .... xor() 1834 MB/s, rmw enabled
[    1.777583] raid6: using neon recovery algorithm
[    1.781882] iommu: Default domain type: Translated
[    1.786341] iommu: DMA domain TLB invalidation policy: strict mode
[    1.792787] SCSI subsystem initialized
[    1.796481] usbcore: registered new interface driver usbfs
[    1.801849] usbcore: registered new interface driver hub
[    1.807151] usbcore: registered new device driver usb
[    1.812322] mc: Linux media interface: v0.10
[    1.816466] videodev: Linux video capture interface: v2.00
[    1.821966] pps_core: LinuxPPS API ver. 1 registered
[    1.826882] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.836023] PTP clock support registered
[    1.839948] EDAC MC: Ver: 3.0.0
[    1.843315] zynqmp-ipi-mbox mailbox@ff9905c0: Registered ZynqMP IPI mbox with TX/RX channels.
[    1.851905] jesd204: found 0 devices and 0 topologies
[    1.856661] FPGA manager framework
[    1.860151] Advanced Linux Sound Architecture Driver Initialized.
[    1.866522] Bluetooth: Core ver 2.22
[    1.869696] NET: Registered PF_BLUETOOTH protocol family
[    1.874994] Bluetooth: HCI device and connection manager initialized
[    1.881347] Bluetooth: HCI socket layer initialized
[    1.886218] Bluetooth: L2CAP socket layer initialized
[    1.891268] Bluetooth: SCO socket layer initialized
[    1.896602] clocksource: Switched to clocksource arch_sys_counter
[    1.902374] VFS: Disk quotas dquot_6.6.0
[    1.906177] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.917537] NET: Registered PF_INET protocol family
[    1.918035] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    1.927756] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    1.933834] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.941556] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    1.949654] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    1.957596] TCP: Hash tables configured (established 32768 bind 32768)
[    1.963458] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.970154] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.977361] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.983228] RPC: Registered named UNIX socket transport module.
[    1.988798] RPC: Registered udp transport module.
[    1.993490] RPC: Registered tcp transport module.
[    1.998187] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.005217] PCI: CLS 0 bytes, default 64
[    2.008821] Trying to unpack rootfs image as initramfs...
[    2.021590] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    2.024693] Initialise system trusted keyrings
[    2.028526] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    2.035461] NFS: Registering the id_resolver key type
[    2.039677] Key type id_resolver registered
[    2.043803] Key type id_legacy registered
[    2.047840] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.054503] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.061937] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    2.069251] fuse: init (API version 7.37)
[    2.105798] NET: Registered PF_ALG protocol family
[    2.105865] xor: measuring software checksum speed
[    2.113265]    8regs           :  2801 MB/sec
[    2.117607]    32regs          :  2802 MB/sec
[    2.122212]    arm64_neon      :  2612 MB/sec
[    2.122793] xor: using function: 32regs (2802 MB/sec)
[    2.127853] Key type asymmetric registered
[    2.131933] Asymmetric key parser 'x509' registered
[    2.136876] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.144204] io scheduler mq-deadline registered
[    2.148725] io scheduler kyber registered
[    2.184882] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.192256] brd: module loaded
[    2.195416] loop: module loaded
[    2.195795] Registered mathworks_ip class
[    2.197412] mtdoops: mtd device (mtddev=name/number) must be supplied
[    2.203520] SPI driver spidev has no spi_device_id for adi,swspi
[    2.211996] tun: Universal TUN/TAP device driver, 1.6
[    2.214546] CAN device driver interface
[    2.219122] SPI driver wl1271_spi has no spi_device_id for ti,wl1271
[    2.224606] SPI driver wl1271_spi has no spi_device_id for ti,wl1273
[    2.230941] SPI driver wl1271_spi has no spi_device_id for ti,wl1281
[    2.237291] SPI driver wl1271_spi has no spi_device_id for ti,wl1283
[    2.243642] SPI driver wl1271_spi has no spi_device_id for ti,wl1285
[    2.249994] SPI driver wl1271_spi has no spi_device_id for ti,wl1801
[    2.256345] SPI driver wl1271_spi has no spi_device_id for ti,wl1805
[    2.262695] SPI driver wl1271_spi has no spi_device_id for ti,wl1807
[    2.269046] SPI driver wl1271_spi has no spi_device_id for ti,wl1831
[    2.275397] SPI driver wl1271_spi has no spi_device_id for ti,wl1835
[    2.281748] SPI driver wl1271_spi has no spi_device_id for ti,wl1837
[    2.288289] usbcore: registered new interface driver asix
[    2.293546] usbcore: registered new interface driver ax88179_178a
[    2.299626] usbcore: registered new interface driver cdc_ether
[    2.305454] usbcore: registered new interface driver net1080
[    2.311102] usbcore: registered new interface driver cdc_subset
[    2.317022] usbcore: registered new interface driver zaurus
[    2.322603] usbcore: registered new interface driver cdc_ncm
[    2.328268] usbcore: registered new interface driver r8153_ecm
[    2.335407] usbcore: registered new interface driver uas
[    2.339396] usbcore: registered new interface driver usb-storage
[    2.345432] usbcore: registered new interface driver usbserial_generic
[    2.351891] usbserial: USB Serial support registered for generic
[    2.357905] usbcore: registered new interface driver ftdi_sio
[    2.363637] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.370982] usbcore: registered new interface driver upd78f0730
[    2.376863] usbserial: USB Serial support registered for upd78f0730
[    2.384258] SPI driver ads7846 has no spi_device_id for ti,tsc2046
[    2.389291] SPI driver ads7846 has no spi_device_id for ti,ads7843
[    2.395460] SPI driver ads7846 has no spi_device_id for ti,ads7845
[    2.401636] SPI driver ads7846 has no spi_device_id for ti,ads7873
[    2.408589] rtc_zynqmp ffa60000.rtc: registered as rtc0
[    2.413049] rtc_zynqmp ffa60000.rtc: setting system clock to 1970-01-01T18:12:27 UTC (65547)
[    2.421634] i2c_dev: i2c /dev entries driver
[    2.427589] usbcore: registered new interface driver uvcvideo
[    2.432869] Bluetooth: HCI UART driver ver 2.3
[    2.435911] Bluetooth: HCI UART protocol H4 registered
[    2.441057] Bluetooth: HCI UART protocol BCSP registered
[    2.446391] Bluetooth: HCI UART protocol LL registered
[    2.451492] Bluetooth: HCI UART protocol ATH3K registered
[    2.456913] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.463285] Bluetooth: HCI UART protocol Intel registered
[    2.468582] Bluetooth: HCI UART protocol QCA registered
[    2.473814] usbcore: registered new interface driver bcm203x
[    2.479440] usbcore: registered new interface driver bpa10x
[    2.485009] usbcore: registered new interface driver bfusb
[    2.490504] usbcore: registered new interface driver btusb
[    2.496005] usbcore: registered new interface driver ath3k
[    2.501635] EDAC MC: ECC not enabled
[    2.505268] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV edac (POLLED)
[    2.513969] cortex_edac edac: cortex l1/l2 driver is deprecated
[    2.520269] EDAC DEVICE1: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    2.532730] sdhci: Secure Digital Host Controller Interface driver
[    2.538235] sdhci: Copyright(c) Pierre Ossman
[    2.542578] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.549332] ledtrig-cpu: registered to indicate activity on CPUs
[    2.554321] SMCCC: SOC_ID: ID = jep106:0049:0000 Revision = 0x04724093
[    2.560896] zynqmp_firmware_probe Platform Management API v1.1
[    2.566641] zynqmp_firmware_probe Trustzone version v1.0
[    2.600386] usbcore: registered new interface driver usbhid
[    2.600447] usbhid: USB HID core driver
[    2.604331] SPI driver fb_seps525 has no spi_device_id for syncoam,seps525
[    2.612006] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7988-5
[    2.618270] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7988-1
[    2.625479] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7986
[    2.632524] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7985
[    2.639570] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7984
[    2.646616] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7983
[    2.653663] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7982
[    2.660710] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7980
[    2.667755] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7949
[    2.674804] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7946
[    2.681849] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7944
[    2.688898] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7942
[    2.695946] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7699
[    2.702994] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7693
[    2.710044] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7691
[    2.717088] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7690
[    2.724134] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7689
[    2.731180] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7688
[    2.738227] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7687
[    2.745274] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7686
[    2.752325] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7685
[    2.759371] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7682
[    2.766589] SPI driver ad7124 has no spi_device_id for adi,ad7124-4
[    2.772688] SPI driver ad7124 has no spi_device_id for adi,ad7124-8
[    2.778984] SPI driver ad7192 has no spi_device_id for adi,ad7190
[    2.785037] SPI driver ad7192 has no spi_device_id for adi,ad7193
[    2.791125] SPI driver ad7192 has no spi_device_id for adi,ad7195
[    2.798235] SPI driver ad9467 has no spi_device_id for adi,ad9643
[    2.803314] SPI driver ad9467 has no spi_device_id for adi,ad9250
[    2.809395] SPI driver ad9467 has no spi_device_id for adi,ad9250_2
[    2.815660] SPI driver ad9467 has no spi_device_id for adi,ad9265
[    2.821748] SPI driver ad9467 has no spi_device_id for adi,ad9683
[    2.827838] SPI driver ad9467 has no spi_device_id for adi,ad9434
[    2.833933] SPI driver ad9467 has no spi_device_id for adi,ad9625
[    2.840018] SPI driver ad9467 has no spi_device_id for adi,ad9652
[    2.846107] SPI driver ad9467 has no spi_device_id for adi,ad9649
[    2.854792] SPI driver adar3000 has no spi_device_id for adi,adar3001
[    2.858648] SPI driver adar3000 has no spi_device_id for adi,adar3002
[    2.866443] SPI driver ad9783 has no spi_device_id for adi,ad9780
[    2.871170] SPI driver ad9783 has no spi_device_id for adi,ad9781
[    2.877597] SPI driver adis16475 has no spi_device_id for adi,adis16470
[    2.883874] SPI driver adis16475 has no spi_device_id for adi,adis16475-1
[    2.890653] SPI driver adis16475 has no spi_device_id for adi,adis16475-2
[    2.897440] SPI driver adis16475 has no spi_device_id for adi,adis16475-3
[    2.904226] SPI driver adis16475 has no spi_device_id for adi,adis16477-1
[    2.911011] SPI driver adis16475 has no spi_device_id for adi,adis16477-2
[    2.917795] SPI driver adis16475 has no spi_device_id for adi,adis16477-3
[    2.924582] SPI driver adis16475 has no spi_device_id for adi,adis16465-1
[    2.931369] SPI driver adis16475 has no spi_device_id for adi,adis16465-2
[    2.938154] SPI driver adis16475 has no spi_device_id for adi,adis16465-3
[    2.944940] SPI driver adis16475 has no spi_device_id for adi,adis16467-1
[    2.951726] SPI driver adis16475 has no spi_device_id for adi,adis16467-2
[    2.958530] SPI driver adis16475 has no spi_device_id for adi,adis16467-3
[    2.965301] SPI driver adis16475 has no spi_device_id for adi,adis16500
[    2.971918] SPI driver adis16475 has no spi_device_id for adi,adis16505-1
[    2.978699] SPI driver adis16475 has no spi_device_id for adi,adis16505-2
[    2.985484] SPI driver adis16475 has no spi_device_id for adi,adis16505-3
[    2.992270] SPI driver adis16475 has no spi_device_id for adi,adis16507-1
[    2.999055] SPI driver adis16475 has no spi_device_id for adi,adis16507-2
[    3.005842] SPI driver adis16475 has no spi_device_id for adi,adis16507-3
[    3.014455] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    3.019810] usbcore: registered new interface driver snd-usb-audio
[    3.027074] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    3.037489] Initializing XFRM netlink socket
[    3.037599] NET: Registered PF_INET6 protocol family
[    3.042602] Segment Routing with IPv6
[    3.045722] In-situ OAM (IOAM) with IPv6
[    3.049690] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.055941] NET: Registered PF_PACKET protocol family
[    3.060578] NET: Registered PF_KEY protocol family
[    3.065534] can: controller area network core
[    3.069743] NET: Registered PF_CAN protocol family
[    3.074488] can: raw protocol
[    3.077448] can: broadcast manager protocol
[    3.081626] can: netlink gateway - max_hops=1
[    3.086135] Bluetooth: RFCOMM TTY layer initialized
[    3.090852] Bluetooth: RFCOMM socket layer initialized
[    3.095989] Bluetooth: RFCOMM ver 1.11
[    3.099726] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.105020] Bluetooth: BNEP filters: protocol multicast
[    3.110250] Bluetooth: BNEP socket layer initialized
[    3.115200] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.121123] Bluetooth: HIDP socket layer initialized
[    3.126317] 9pnet: Installing 9P2000 support
[    3.130379] NET: Registered PF_IEEE802154 protocol family
[    3.135768] Key type dns_resolver registered
[    3.140208] registered taskstats version 1
[    3.144087] Loading compiled-in X.509 certificates
[    3.149361] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[    3.546637] Freeing initrd memory: 34420K
[    3.875735] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 23, base_baud = 6249999) is a xuartps
[    3.884816] printk: console [ttyPS1] enabled
[    3.889118] printk: bootconsole [cdns0] disabled
[   24.916592] rcu: INFO: rcu_sched detected stalls on CPUs/tasks:
[   24.922500] rcu:     0-...0: (1 GPs behind) idle=234c/1/0x4000000000000000 softirq=61/61 fqs=2626
[   24.931101]  (detected by 2, t=5255 jiffies, g=-915, q=8 ncpus=4)
[   24.937186] Task dump for CPU 0:
[   24.940397] task:kworker/u8:1    state:R  running task     stack:0     pid:47    ppid:2      flags:0x0000000a
[   24.950302] Workqueue: events_unbound deferred_probe_work_func
[   24.956134] Call trace:
[   24.958564]  __switch_to+0xe4/0x160
[   24.962045]  0xffffff88009c8180
My spi devices are not working for the ad9361 and I cant see any controls regarding it, I saw that in the fmcomms2 when the adi pl nodes that get deleted and redefend use the following compatibility string for the dma 'adi,axi-dmac-1.00.a' and the following for the sysid 'adi,axi-sysid-1.00.a', in the pl.dtsi for the fmcomms2 project they use 'xlnx,axi-ad9361-1.0' and 'xlnx,axi-sysid-1.0' respectively. So i followed the same style for my custom device tree and whenever I change the compatibility string from 'xlnx,axi-ad9361-1.0' to 'adi,axi-dmac-1.00.a' when i redefine the node after deleting it from the pl the kernel also hangs but at a different place. following is the boot log for that error.
CPU:   ZynqMP
Silicon: v3
Chip:  xck26
PMUFW:  v1.1
 File ID: 0x0
 Revision Number: 1
EL Level:       EL2
NAND:  0 MiB
In:    serial
Out:   serial
Err:   serial
Bootmode: QSPI_MODE
No ethernet found.
ZynqMP>  Zynq MP First Stage Boot Loader
In JTAG Boot Mode
PMU-FW is not running, certain applications may not be supported.
Protection configuration applied
Exit from FSBL
CPU:   ZynqMP
Silicon: v3
Chip:  xck26
PMUFW:  v1.1
 File ID: 0x0
 Revision Number: 1
EL Level:       EL2
Core:  59 devices, 29 uclasses, devicetree: board
NAND:  0 MiB
In:    serial
Out:   serial
Err:   serial
Bootmode: QSPI_MODE
No ethernet found.
     Type:         Kernel Image
     OS:           Linux
     Hash algo:    sha256
     Hash value:   619940861101ef15fd3d205cb61a3022b619b96161f717ba909d098026fca1bf
     Type:         RAMDisk Image
     Data Start:   0x10bed838
     Data Size:    35247997 Bytes = 33.6 MiB
     OS:           Linux
     Hash algo:    sha256
     Hash value:   0ef344eb8d2c78493c49b7fba2e35db2bd453aa61fe3508ab86be581cfc45d8c
     Data Size:    49103 Bytes = 48 KiB
     Hash algo:    sha256
     Hash value:   07fa6c5032f6711a8c4ca6c52d2581564f6fe59e0fc556d2f575e477508d1552
   Loading Ramdisk to 79a54000, end 7bbf177d ... OK
   Loading Device Tree to 0000000079a45000, end 0000000079a53fce ... OK
Working FDT set to 79a45000
Starting kernel ...
[    0.000000] Memory: 3711196K/4193280K available (17856K kernel code, 1768K rwdata, 15524K rodata, 2752K init, 673K bss, 219940K reserved, 262144K cma-reserved)
[    0.008434] Console: colour dummy device 80x25
[    0.027774] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.034987] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.043873] rcu: Hierarchical SRCU implementation.
[    0.053012] EFI services will not be available.
[    0.057494] smp: Bringing up secondary CPUs ...
[    0.191576] Detected VIPT I-cache on CPU1
[    0.191644] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.566145] Detected VIPT I-cache on CPU2
[    0.566197] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.961680] Detected VIPT I-cache on CPU3
[    0.961734] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.961780] smp: Brought up 1 node, 4 CPUs
[    0.991811] SMP: Total of 4 processors activated.
[    0.996510] CPU features: detected: 32-bit EL0 Support
[    1.001643] CPU features: detected: CRC32 instructions
[    1.006833] CPU: All CPU(s) started at EL2
[    1.010867] alternatives: applying system-wide alternatives
[    1.017460] devtmpfs: initialized
[    1.023887] Registered cp15_barrier emulation handler
[    1.024792] Registered setend emulation handler
[    1.029405] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    1.039061] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    1.051599] pinctrl core: initialized pinctrl subsystem
[    1.052479] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    1.057732] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    1.064239] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    1.072022] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    1.079844] audit: initializing netlink subsys (disabled)
[    1.085328] audit: type=2000 audit(1.016:1): state=initialized audit_enabled=0 res=1
[    1.085623] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    1.099786] ASID allocator initialised with 65536 entries
[    1.121399] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    1.122553] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    1.129176] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    1.135977] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
[    1.142394] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    1.149178] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    1.155530] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    1.162315] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    1.236640] raid6: neonx8   gen()  2518 MB/s
[    1.304699] raid6: neonx4   gen()  2459 MB/s
[    1.372762] raid6: neonx2   gen()  2358 MB/s
[    1.440816] raid6: neonx1   gen()  2017 MB/s
[    1.508870] raid6: int64x8  gen()  1572 MB/s
[    1.576933] raid6: int64x4  gen()  1742 MB/s
[    1.644978] raid6: int64x2  gen()  1550 MB/s
[    1.713043] raid6: int64x1  gen()  1148 MB/s
[    1.713082] raid6: using algorithm neonx8 gen() 2518 MB/s
[    1.785107] raid6: .... xor() 1834 MB/s, rmw enabled
[    1.785152] raid6: using neon recovery algorithm
[    1.789414] iommu: Default domain type: Translated
[    1.793909] iommu: DMA domain TLB invalidation policy: strict mode
[    1.800354] SCSI subsystem initialized
[    1.804048] usbcore: registered new interface driver usbfs
[    1.809419] usbcore: registered new interface driver hub
[    1.814721] usbcore: registered new device driver usb
[    1.819885] mc: Linux media interface: v0.10
[    1.824033] videodev: Linux video capture interface: v2.00
[    1.829534] pps_core: LinuxPPS API ver. 1 registered
[    1.834450] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.843592] PTP clock support registered
[    1.847517] EDAC MC: Ver: 3.0.0
[    1.850885] zynqmp-ipi-mbox mailbox@ff9905c0: Registered ZynqMP IPI mbox with TX/RX channels.
[    1.859469] jesd204: found 0 devices and 0 topologies
[    1.864231] FPGA manager framework
[    1.867710] Advanced Linux Sound Architecture Driver Initialized.
[    1.874090] Bluetooth: Core ver 2.22
[    1.877265] NET: Registered PF_BLUETOOTH protocol family
[    1.882563] Bluetooth: HCI device and connection manager initialized
[    1.888916] Bluetooth: HCI socket layer initialized
[    1.893787] Bluetooth: L2CAP socket layer initialized
[    1.898837] Bluetooth: SCO socket layer initialized
[    1.904149] clocksource: Switched to clocksource arch_sys_counter
[    1.909956] VFS: Disk quotas dquot_6.6.0
[    1.913745] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.925090] NET: Registered PF_INET protocol family
[    1.925594] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    1.935328] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    1.941403] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.949126] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    1.957232] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    1.965164] TCP: Hash tables configured (established 32768 bind 32768)
[    1.971027] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.977723] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.984927] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.990766] RPC: Registered named UNIX socket transport module.
[    1.996366] RPC: Registered udp transport module.
[    2.001059] RPC: Registered tcp transport module.
[    2.005756] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.012778] PCI: CLS 0 bytes, default 64
[    2.016373] Trying to unpack rootfs image as initramfs...
[    2.029155] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    2.032131] Initialise system trusted keyrings
[    2.035856] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    2.042932] NFS: Registering the id_resolver key type
[    2.047209] Key type id_resolver registered
[    2.051363] Key type id_legacy registered
[    2.055403] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.062064] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.069496] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    2.076810] fuse: init (API version 7.37)
[    2.112518] NET: Registered PF_ALG protocol family
[    2.112583] xor: measuring software checksum speed
[    2.119977]    8regs           :  2801 MB/sec
[    2.124326]    32regs          :  2802 MB/sec
[    2.128929]    arm64_neon      :  2612 MB/sec
[    2.129509] xor: using function: 32regs (2802 MB/sec)
[    2.134570] Key type asymmetric registered
[    2.138649] Asymmetric key parser 'x509' registered
[    2.143587] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.150924] io scheduler mq-deadline registered
[    2.155441] io scheduler kyber registered
[    2.191542] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.198721] brd: module loaded
[    2.201882] loop: module loaded
[    2.202239] Registered mathworks_ip class
[    2.203808] mtdoops: mtd device (mtddev=name/number) must be supplied
[    2.209963] SPI driver spidev has no spi_device_id for adi,swspi
[    2.218389] tun: Universal TUN/TAP device driver, 1.6
[    2.220998] CAN device driver interface
[    2.225411] SPI driver wl1271_spi has no spi_device_id for ti,wl1271
[    2.231065] SPI driver wl1271_spi has no spi_device_id for ti,wl1273
[    2.237406] SPI driver wl1271_spi has no spi_device_id for ti,wl1281
[    2.243756] SPI driver wl1271_spi has no spi_device_id for ti,wl1283
[    2.250106] SPI driver wl1271_spi has no spi_device_id for ti,wl1285
[    2.256462] SPI driver wl1271_spi has no spi_device_id for ti,wl1801
[    2.262809] SPI driver wl1271_spi has no spi_device_id for ti,wl1805
[    2.269160] SPI driver wl1271_spi has no spi_device_id for ti,wl1807
[    2.275510] SPI driver wl1271_spi has no spi_device_id for ti,wl1831
[    2.281862] SPI driver wl1271_spi has no spi_device_id for ti,wl1835
[    2.288212] SPI driver wl1271_spi has no spi_device_id for ti,wl1837
[    2.294749] usbcore: registered new interface driver asix
[    2.300006] usbcore: registered new interface driver ax88179_178a
[    2.306102] usbcore: registered new interface driver cdc_ether
[    2.311918] usbcore: registered new interface driver net1080
[    2.317568] usbcore: registered new interface driver cdc_subset
[    2.323482] usbcore: registered new interface driver zaurus
[    2.329070] usbcore: registered new interface driver cdc_ncm
[    2.334723] usbcore: registered new interface driver r8153_ecm
[    2.341670] usbcore: registered new interface driver uas
[    2.345850] usbcore: registered new interface driver usb-storage
[    2.351901] usbcore: registered new interface driver usbserial_generic
[    2.358357] usbserial: USB Serial support registered for generic
[    2.364384] usbcore: registered new interface driver ftdi_sio
[    2.370097] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.377441] usbcore: registered new interface driver upd78f0730
[    2.383327] usbserial: USB Serial support registered for upd78f0730
[    2.390586] SPI driver ads7846 has no spi_device_id for ti,tsc2046
[    2.395754] SPI driver ads7846 has no spi_device_id for ti,ads7843
[    2.401924] SPI driver ads7846 has no spi_device_id for ti,ads7845
[    2.408101] SPI driver ads7846 has no spi_device_id for ti,ads7873
[    2.415056] rtc_zynqmp ffa60000.rtc: registered as rtc0
[    2.419526] rtc_zynqmp ffa60000.rtc: setting system clock to 1970-01-01T00:00:11 UTC (11)
[    2.427828] i2c_dev: i2c /dev entries driver
[    2.433618] usbcore: registered new interface driver uvcvideo
[    2.439004] Bluetooth: HCI UART driver ver 2.3
[    2.442129] Bluetooth: HCI UART protocol H4 registered
[    2.447252] Bluetooth: HCI UART protocol BCSP registered
[    2.452597] Bluetooth: HCI UART protocol LL registered
[    2.457695] Bluetooth: HCI UART protocol ATH3K registered
[    2.463120] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.469472] Bluetooth: HCI UART protocol Intel registered
[    2.474782] Bluetooth: HCI UART protocol QCA registered
[    2.480017] usbcore: registered new interface driver bcm203x
[    2.485646] usbcore: registered new interface driver bpa10x
[    2.491219] usbcore: registered new interface driver bfusb
[    2.496700] usbcore: registered new interface driver btusb
[    2.502210] usbcore: registered new interface driver ath3k
[    2.507861] EDAC MC: ECC not enabled
[    2.511446] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV edac (POLLED)
[    2.520177] cortex_edac edac: cortex l1/l2 driver is deprecated
[    2.526442] EDAC DEVICE1: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    2.538871] sdhci: Secure Digital Host Controller Interface driver
[    2.544442] sdhci: Copyright(c) Pierre Ossman
[    2.548782] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.555450] ledtrig-cpu: registered to indicate activity on CPUs
[    2.560520] SMCCC: SOC_ID: ID = jep106:0049:0000 Revision = 0x04724093
[    2.567095] zynqmp_firmware_probe Platform Management API v1.1
[    2.572852] zynqmp_firmware_probe Trustzone version v1.0
[    2.606381] usbcore: registered new interface driver usbhid
[    2.606441] usbhid: USB HID core driver
[    2.610326] SPI driver fb_seps525 has no spi_device_id for syncoam,seps525
[    2.617969] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7988-5
[    2.624265] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7988-1
[    2.631475] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7986
[    2.638518] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7985
[    2.645565] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7984
[    2.652611] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7983
[    2.659658] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7982
[    2.666705] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7980
[    2.673751] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7949
[    2.680811] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7946
[    2.687846] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7944
[    2.694892] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7942
[    2.701939] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7699
[    2.708988] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7693
[    2.716033] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7691
[    2.723081] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7690
[    2.730129] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7689
[    2.737174] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7688
[    2.744221] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7687
[    2.751269] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7686
[    2.758317] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7685
[    2.765365] SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7682
[    2.772584] SPI driver ad7124 has no spi_device_id for adi,ad7124-4
[    2.778684] SPI driver ad7124 has no spi_device_id for adi,ad7124-8
[    2.784985] SPI driver ad7192 has no spi_device_id for adi,ad7190
[    2.791031] SPI driver ad7192 has no spi_device_id for adi,ad7193
[    2.797119] SPI driver ad7192 has no spi_device_id for adi,ad7195
[    2.804137] SPI driver ad9467 has no spi_device_id for adi,ad9643
[    2.809300] SPI driver ad9467 has no spi_device_id for adi,ad9250
[    2.815390] SPI driver ad9467 has no spi_device_id for adi,ad9250_2
[    2.821653] SPI driver ad9467 has no spi_device_id for adi,ad9265
[    2.827742] SPI driver ad9467 has no spi_device_id for adi,ad9683
[    2.833832] SPI driver ad9467 has no spi_device_id for adi,ad9434
[    2.839921] SPI driver ad9467 has no spi_device_id for adi,ad9625
[    2.846012] SPI driver ad9467 has no spi_device_id for adi,ad9652
[    2.852101] SPI driver ad9467 has no spi_device_id for adi,ad9649
[    2.860663] SPI driver adar3000 has no spi_device_id for adi,adar3001
[    2.864641] SPI driver adar3000 has no spi_device_id for adi,adar3002
[    2.872355] SPI driver ad9783 has no spi_device_id for adi,ad9780
[    2.877160] SPI driver ad9783 has no spi_device_id for adi,ad9781
[    2.883573] SPI driver adis16475 has no spi_device_id for adi,adis16470
[    2.889868] SPI driver adis16475 has no spi_device_id for adi,adis16475-1
[    2.896646] SPI driver adis16475 has no spi_device_id for adi,adis16475-2
[    2.903431] SPI driver adis16475 has no spi_device_id for adi,adis16475-3
[    2.910217] SPI driver adis16475 has no spi_device_id for adi,adis16477-1
[    2.917003] SPI driver adis16475 has no spi_device_id for adi,adis16477-2
[    2.923787] SPI driver adis16475 has no spi_device_id for adi,adis16477-3
[    2.930587] SPI driver adis16475 has no spi_device_id for adi,adis16465-1
[    2.937361] SPI driver adis16475 has no spi_device_id for adi,adis16465-2
[    2.944146] SPI driver adis16475 has no spi_device_id for adi,adis16465-3
[    2.950932] SPI driver adis16475 has no spi_device_id for adi,adis16467-1
[    2.957718] SPI driver adis16475 has no spi_device_id for adi,adis16467-2
[    2.964505] SPI driver adis16475 has no spi_device_id for adi,adis16467-3
[    2.971292] SPI driver adis16475 has no spi_device_id for adi,adis16500
[    2.977903] SPI driver adis16475 has no spi_device_id for adi,adis16505-1
[    2.984697] SPI driver adis16475 has no spi_device_id for adi,adis16505-2
[    2.991483] SPI driver adis16475 has no spi_device_id for adi,adis16505-3
[    2.998269] SPI driver adis16475 has no spi_device_id for adi,adis16507-1
[    3.005051] SPI driver adis16475 has no spi_device_id for adi,adis16507-2
[    3.011836] SPI driver adis16475 has no spi_device_id for adi,adis16507-3
[    3.553408] Freeing initrd memory: 34420K
[   23.872141] rcu: INFO: rcu_sched detected stalls on CPUs/tasks:
[   23.872421] rcu:     0-...0: (23 ticks this GP) idle=2a8c/1/0x4000000000000000 softirq=64/64 fqs=2616
[   23.881381]  (detected by 1, t=5254 jiffies, g=-1107, q=4347 ncpus=4)
[   23.887819] Task dump for CPU 0:
[   23.891037] task:swapper/0       state:R  running task     stack:0     pid:1     ppid:0      flags:0x0000000a
[   23.900956] Call trace:
[   23.903392]  __switch_to+0xe4/0x160
[   23.906871]  0xffffffc00a547be8
My final devicetree is below not including the pl.dtsi or the compatibility strings that cause the hangs.
/dts-v1/;
	compatible = "xlnx,zynqmp-sm-k26-rev1", "xlnx,zynqmp-sm-k26-revB", "xlnx,zynqmp-sm-k26-revA", "xlnx,zynqmp-sm-k26", "xlnx,zynqmp";
	#address-cells = <0x2>;
	#size-cells = <0x2>;
	model = "ZynqMP SM-K26 Rev1/B/A";
	cpus {
		#address-cells = <0x1>;
		#size-cells = <0x0>;
		cpu@0 {
			compatible = "arm,cortex-a53";
			device_type = "cpu";
			enable-method = "psci";
			operating-points-v2 = <0x1>;
			reg = <0x0>;
			cpu-idle-states = <0x2>;
			next-level-cache = <0x3>;
			clocks = <0x4 0xa>;
			phandle = <0x6>;
		cpu@1 {
			reg = <0x1>;
			phandle = <0x7>;
		cpu@2 {
			reg = <0x2>;
			phandle = <0x8>;
		cpu@3 {
			reg = <0x3>;
			phandle = <0x9>;
		l2-cache {
			compatible = "cache";
			cache-level = <0x2>;
			phandle = <0x3>;
		idle-states {
			entry-method = "psci";
			cpu-sleep-0 {
				compatible = "arm,idle-state";
				arm,psci-suspend-param = <0x40000000>;
				local-timer-stop;
				entry-latency-us = <0x12c>;
				exit-latency-us = <0x258>;
				min-residency-us = <0x2710>;
				phandle = <0x2>;
	opp-table-cpu {
		compatible = "operating-points-v2";
		opp-shared;
		phandle = <0x1>;
		opp00 {
			opp-hz = <0x0 0x4f790c10>;
			opp-microvolt = <0xf4240>;
			clock-latency-ns = <0x7a120>;
		opp01 {
			opp-hz = <0x0 0x27bc8608>;
		opp02 {
			opp-hz = <0x0 0x1a7daeb0>;
		opp03 {
			opp-hz = <0x0 0x13de4304>;
		opp04 {
			opp-hz = <0x0 0x4d7c6cf4>;
	zynqmp_ipi {
		u-boot,dm-pre-reloc;
		compatible = "xlnx,zynqmp-ipi-mailbox";
		interrupt-parent = <0x5>;
		interrupts = <0x0 0x23 0x4>;
		xlnx,ipi-id = <0x0>;
		ranges;
		phandle = <0x25>;
		mailbox@ff9905c0 {
			reg = <0x0 0xff9905c0 0x0 0x20 0x0 0xff9905e0 0x0 0x20 0x0 0xff990e80 0x0 0x20 0x0 0xff990ea0 0x0 0x20>;
			reg-names = "local_request_region", "local_response_region", "remote_request_region", "remote_response_region";
			#mbox-cells = <0x1>;
			xlnx,ipi-id = <0x4>;
			phandle = <0xa>;
	dcc {
		compatible = "arm,dcc";
		status = "disabled";
		phandle = <0x26>;
	pmu {
		compatible = "arm,armv8-pmuv3";
		interrupts = <0x0 0x8f 0x4 0x0 0x90 0x4 0x0 0x91 0x4 0x0 0x92 0x4>;
		interrupt-affinity = <0x6 0x7 0x8 0x9>;
	psci {
		compatible = "arm,psci-0.2";
		method = "smc";
	firmware {
		zynqmp-firmware {
			compatible = "xlnx,zynqmp-firmware";
			method = "smc";
			#power-domain-cells = <0x1>;
			phandle = <0x11>;
			zynqmp-power {
				compatible = "xlnx,zynqmp-power";
				mboxes = <0xa 0x0 0xa 0x1>;
				mbox-names = "tx", "rx";
				phandle = <0x27>;
			nvmem_firmware {
				compatible = "xlnx,zynqmp-nvmem-fw";
				#size-cells = <0x1>;
				soc_revision@0 {
					reg = <0x0 0x4>;
					phandle = <0x28>;
				efuse_dna@c {
					reg = <0xc 0xc>;
					phandle = <0x29>;
				efuse_usr0@20 {
					reg = <0x20 0x4>;
					phandle = <0x2a>;
				efuse_usr1@24 {
					reg = <0x24 0x4>;
					phandle = <0x2b>;
				efuse_usr2@28 {
					reg = <0x28 0x4>;
					phandle = <0x2c>;
				efuse_usr3@2c {
					reg = <0x2c 0x4>;
					phandle = <0x2d>;
				efuse_usr4@30 {
					reg = <0x30 0x4>;
					phandle = <0x2e>;
				efuse_usr5@34 {
					reg = <0x34 0x4>;
					phandle = <0x2f>;
				efuse_usr6@38 {
					reg = <0x38 0x4>;
					phandle = <0x30>;
				efuse_usr7@3c {
					reg = <0x3c 0x4>;
					phandle = <0x31>;
				efuse_miscusr@40 {
					reg = <0x40 0x4>;
					phandle = <0x32>;
				efuse_chash@50 {
					reg = <0x50 0x4>;
					phandle = <0x33>;
				efuse_pufmisc@54 {
					reg = <0x54 0x4>;
					phandle = <0x34>;
				efuse_sec@58 {
					reg = <0x58 0x4>;
					phandle = <0x35>;
				efuse_spkid@5c {
					reg = <0x5c 0x4>;
					phandle = <0x36>;
				efuse_ppk0hash@a0 {
					reg = <0xa0 0x30>;
					phandle = <0x37>;
				efuse_ppk1hash@d0 {
					reg = <0xd0 0x30>;
					phandle = <0x38>;
			pcap {
				compatible = "xlnx,zynqmp-pcap-fpga";
				clock-names = "ref_clk";
				clocks = <0x4 0x29>;
				phandle = <0x10>;
			reset-controller {
				compatible = "xlnx,zynqmp-reset";
				#reset-cells = <0x1>;
				phandle = <0x13>;
			pinctrl {
				compatible = "xlnx,zynqmp-pinctrl";
				status = "okay";
				phandle = <0x39>;
				sdhci0-default {
					phandle = <0x17>;
					conf {
						groups = "sdio0_0_grp";
						slew-rate = <0x1>;
						power-source = <0x1>;
						bias-disable;
					mux {
						function = "sdio0";
			gpio {
				compatible = "xlnx,zynqmp-gpio-modepin";
				gpio-controller;
				#gpio-cells = <0x2>;
				label = "modepin";
				phandle = <0x19>;
			clock-controller {
				#clock-cells = <0x1>;
				compatible = "xlnx,zynqmp-clk";
				clocks = <0xb 0xc 0xd 0xe 0xf>;
				clock-names = "pss_ref_clk", "video_clk", "pss_alt_ref_clk", "aux_ref_clk", "gt_crx_ref_clk";
				phandle = <0x4>;
	timer {
		compatible = "arm,armv8-timer";
		interrupts = <0x1 0xd 0xf08 0x1 0xe 0xf08 0x1 0xb 0xf08 0x1 0xa 0xf08>;
	edac {
		compatible = "arm,cortex-a53-edac";
	fpga-full {
		compatible = "fpga-region";
		fpga-mgr = <0x10>;
		ranges;
		phandle = <0x3a>;
	axi {
		compatible = "simple-bus";
		ranges;
		phandle = <0x3b>;
		can@ff060000 {
			compatible = "xlnx,zynq-can-1.0";
			clock-names = "can_clk", "pclk";
			reg = <0x0 0xff060000 0x0 0x1000>;
			interrupts = <0x0 0x17 0x4>;
			tx-fifo-depth = <0x40>;
			rx-fifo-depth = <0x40>;
			power-domains = <0x11 0x2f>;
			clocks = <0x4 0x3f 0x4 0x1f>;
			phandle = <0x3c>;
		can@ff070000 {
			reg = <0x0 0xff070000 0x0 0x1000>;
			interrupts = <0x0 0x18 0x4>;
			power-domains = <0x11 0x30>;
			clocks = <0x4 0x40 0x4 0x1f>;
			phandle = <0x3d>;
		cci@fd6e0000 {
			compatible = "arm,cci-400";
			status = "okay";
			reg = <0x0 0xfd6e0000 0x0 0x9000>;
			ranges = <0x0 0x0 0xfd6e0000 0x10000>;
			phandle = <0x3e>;
			pmu@9000 {
				compatible = "arm,cci-400-pmu,r1";
				reg = <0x9000 0x5000>;
				interrupts = <0x0 0x7b 0x4 0x0 0x7b 0x4 0x0 0x7b 0x4 0x0 0x7b 0x4 0x0 0x7b 0x4>;
		dma-controller@fd500000 {
			status = "okay";
			compatible = "xlnx,zynqmp-dma-1.0";
			reg = <0x0 0xfd500000 0x0 0x1000>;
			interrupts = <0x0 0x7c 0x4>;
			clock-names = "clk_main", "clk_apb";
			#dma-cells = <0x1>;
			xlnx,bus-width = <0x80>;
			iommus = <0x12 0x14e8>;
			power-domains = <0x11 0x2a>;
			clocks = <0x4 0x13 0x4 0x1f>;
			phandle = <0x3f>;
		dma-controller@fd510000 {
			status = "okay";
			reg = <0x0 0xfd510000 0x0 0x1000>;
			interrupts = <0x0 0x7d 0x4>;
			#dma-cells = <0x1>;
			iommus = <0x12 0x14e9>;
			phandle = <0x40>;
		dma-controller@fd520000 {
			status = "okay";
			reg = <0x0 0xfd520000 0x0 0x1000>;
			interrupts = <0x0 0x7e 0x4>;
			#dma-cells = <0x1>;
			iommus = <0x12 0x14ea>;
			phandle = <0x41>;
		dma-controller@fd530000 {
			status = "okay";
			reg = <0x0 0xfd530000 0x0 0x1000>;
			interrupts = <0x0 0x7f 0x4>;
			#dma-cells = <0x1>;
			iommus = <0x12 0x14eb>;
			phandle = <0x42>;
		dma-controller@fd540000 {
			status = "okay";
			reg = <0x0 0xfd540000 0x0 0x1000>;
			interrupts = <0x0 0x80 0x4>;
			#dma-cells = <0x1>;
			iommus = <0x12 0x14ec>;
			phandle = <0x43>;
		dma-controller@fd550000 {
			status = "okay";
			reg = <0x0 0xfd550000 0x0 0x1000>;
			interrupts = <0x0 0x81 0x4>;
			#dma-cells = <0x1>;
			iommus = <0x12 0x14ed>;
			phandle = <0x44>;
		dma-controller@fd560000 {
			status = "okay";
			reg = <0x0 0xfd560000 0x0 0x1000>;
			interrupts = <0x0 0x82 0x4>;
			#dma-cells = <0x1>;
			iommus = <0x12 0x14ee>;
			phandle = <0x45>;
		dma-controller@fd570000 {
			status = "okay";
			reg = <0x0 0xfd570000 0x0 0x1000>;
			interrupts = <0x0 0x83 0x4>;
			#dma-cells = <0x1>;
			iommus = <0x12 0x14ef>;
			phandle = <0x46>;
		interrupt-controller@f9010000 {
			compatible = "arm,gic-400";
			#interrupt-cells = <0x3>;
			reg = <0x0 0xf9010000 0x0 0x10000 0x0 0xf9020000 0x0 0x20000 0x0 0xf9040000 0x0 0x20000 0x0 0xf9060000 0x0 0x20000>;
			interrupt-controller;
			interrupts = <0x1 0x9 0xf04>;
			num_cpus = <0x2>;
			num_interrupts = <0x60>;
			phandle = <0x5>;
		gpu@fd4b0000 {
			status = "okay";
			compatible = "xlnx,zynqmp-mali", "arm,mali-400";
			reg = <0x0 0xfd4b0000 0x0 0x10000>;
			interrupts = <0x0 0x84 0x4 0x0 0x84 0x4 0x0 0x84 0x4 0x0 0x84 0x4 0x0 0x84 0x4 0x0 0x84 0x4>;
			interrupt-names = "gp", "gpmmu", "pp0", "ppmmu0", "pp1", "ppmmu1";
			clock-names = "bus", "core";
			power-domains = <0x11 0x3a>;
			clocks = <0x4 0x18 0x4 0x19>;
			xlnx,tz-nonsecure = <0x1>;
			phandle = <0x47>;
		dma-controller@ffa80000 {
			status = "okay";
			reg = <0x0 0xffa80000 0x0 0x1000>;
			interrupts = <0x0 0x4d 0x4>;
			#dma-cells = <0x1>;
			xlnx,bus-width = <0x40>;
			power-domains = <0x11 0x2b>;
			clocks = <0x4 0x44 0x4 0x1f>;
			phandle = <0x48>;
		dma-controller@ffa90000 {
			status = "okay";
			reg = <0x0 0xffa90000 0x0 0x1000>;
			interrupts = <0x0 0x4e 0x4>;
			#dma-cells = <0x1>;
			phandle = <0x49>;
		dma-controller@ffaa0000 {
			status = "okay";
			reg = <0x0 0xffaa0000 0x0 0x1000>;
			interrupts = <0x0 0x4f 0x4>;
			#dma-cells = <0x1>;
			phandle = <0x4a>;
		dma-controller@ffab0000 {
			status = "okay";
			reg = <0x0 0xffab0000 0x0 0x1000>;
			interrupts = <0x0 0x50 0x4>;
			#dma-cells = <0x1>;
			phandle = <0x4b>;
		dma-controller@ffac0000 {
			status = "okay";
			reg = <0x0 0xffac0000 0x0 0x1000>;
			interrupts = <0x0 0x51 0x4>;
			#dma-cells = <0x1>;
			phandle = <0x4c>;
		dma-controller@ffad0000 {
			status = "okay";
			reg = <0x0 0xffad0000 0x0 0x1000>;
			interrupts = <0x0 0x52 0x4>;
			#dma-cells = <0x1>;
			phandle = <0x4d>;
		dma-controller@ffae0000 {
			status = "okay";
			reg = <0x0 0xffae0000 0x0 0x1000>;
			interrupts = <0x0 0x53 0x4>;
			phandle = <0x4e>;
		dma-controller@ffaf0000 {
			status = "okay";
			reg = <0x0 0xffaf0000 0x0 0x1000>;
			interrupts = <0x0 0x54 0x4>;
			#dma-cells = <0x1>;
			phandle = <0x4f>;
		memory-controller@fd070000 {
			compatible = "xlnx,zynqmp-ddrc-2.40a";
			reg = <0x0 0xfd070000 0x0 0x30000>;
			interrupts = <0x0 0x70 0x4>;
			phandle = <0x50>;
		nand-controller@ff100000 {
			compatible = "xlnx,zynqmp-nand-controller", "arasan,nfc-v3p10";
			reg = <0x0 0xff100000 0x0 0x1000>;
			clock-names = "controller", "bus";
			interrupts = <0x0 0xe 0x4>;
			iommus = <0x12 0x872>;
			power-domains = <0x11 0x2c>;
			clocks = <0x4 0x3c 0x4 0x1f>;
			phandle = <0x51>;
		ethernet@ff0b0000 {
			compatible = "xlnx,zynqmp-gem", "cdns,gem";
			interrupts = <0x0 0x39 0x4 0x0 0x39 0x4>;
			reg = <0x0 0xff0b0000 0x0 0x1000>;
			clock-names = "pclk", "hclk", "tx_clk", "rx_clk", "tsu_clk";
			iommus = <0x12 0x874>;
			power-domains = <0x11 0x1d>;
			resets = <0x13 0x1d>;
			reset-names = "gem0_rst";
			clocks = <0x4 0x1f 0x4 0x68 0x4 0x2d 0x4 0x31 0x4 0x2c>;
			phandle = <0x52>;
		ethernet@ff0c0000 {
			interrupts = <0x0 0x3b 0x4 0x0 0x3b 0x4>;
			reg = <0x0 0xff0c0000 0x0 0x1000>;
			iommus = <0x12 0x875>;
			power-domains = <0x11 0x1e>;
			resets = <0x13 0x1e>;
			reset-names = "gem1_rst";
			clocks = <0x4 0x1f 0x4 0x69 0x4 0x2e 0x4 0x32 0x4 0x2c>;
			phandle = <0x53>;
		ethernet@ff0d0000 {
			interrupts = <0x0 0x3d 0x4 0x0 0x3d 0x4>;
			reg = <0x0 0xff0d0000 0x0 0x1000>;
			iommus = <0x12 0x876>;
			power-domains = <0x11 0x1f>;
			resets = <0x13 0x1f>;
			reset-names = "gem2_rst";
			clocks = <0x4 0x1f 0x4 0x6a 0x4 0x2f 0x4 0x33 0x4 0x2c>;
			phandle = <0x54>;
		ethernet@ff0e0000 {
			status = "okay";
			interrupts = <0x0 0x3f 0x4 0x0 0x3f 0x4>;
			reg = <0x0 0xff0e0000 0x0 0x1000>;
			iommus = <0x12 0x877>;
			power-domains = <0x11 0x20>;
			resets = <0x13 0x20>;
			reset-names = "gem3_rst";
			clocks = <0x4 0x1f 0x4 0x6b 0x4 0x30 0x4 0x34 0x4 0x2c>;
			phy-mode = "rgmii-id";
			xlnx,ptp-enet-clock = <0x0>;
			phandle = <0x55>;
		gpio@ff0a0000 {
			compatible = "xlnx,zynqmp-gpio-1.0";
			status = "okay";
			gpio-controller;
			interrupts = <0x0 0x10 0x4>;
			#interrupt-cells = <0x2>;
			reg = <0x0 0xff0a0000 0x0 0x1000>;
			power-domains = <0x11 0x2e>;
			clocks = <0x4 0x1f>;
			gpio-line-names = "QSPI_CLK", "QSPI_DQ1", "QSPI_DQ2", "QSPI_DQ3", "QSPI_DQ0", "QSPI_CS_B", "SPI_CLK", "LED1", "LED2", "SPI_CS_B", "SPI_MISO", "SPI_MOSI", "FWUEN", "EMMC_DAT0", "EMMC_DAT1", "EMMC_DAT2", "EMMC_DAT3", "EMMC_DAT4", "EMMC_DAT5", "EMMC_DAT6", "EMMC_DAT7", "EMMC_CMD", "EMMC_CLK", "EMMC_RST", "I2C1_SCL", "I2C1_SDA", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "";
			emio-gpio-width = <0x20>;
			gpio-mask-high = <0x0>;
			gpio-mask-low = <0x5600>;
			phandle = <0x14>;
		i2c@ff020000 {
			compatible = "cdns,i2c-r1p14";
			interrupts = <0x0 0x11 0x4>;
			reg = <0x0 0xff020000 0x0 0x1000>;
			power-domains = <0x11 0x25>;
			clocks = <0x4 0x3d>;
			phandle = <0x56>;
		i2c@ff030000 {
			status = "okay";
			interrupts = <0x0 0x12 0x4>;
			reg = <0x0 0xff030000 0x0 0x1000>;
			power-domains = <0x11 0x26>;
			clocks = <0x4 0x3e>;
			clock-frequency = <0x61a80>;
			scl-gpios = <0x14 0x18 0x0>;
			sda-gpios = <0x14 0x19 0x0>;
			phandle = <0x57>;
			eeprom@50 {
				compatible = "st,24c64", "atmel,24c64";
				reg = <0x50>;
				phandle = <0x58>;
			eeprom@51 {
				reg = <0x51>;
				phandle = <0x59>;
			pmic@33 {
				compatible = "dlg,da9131";
				reg = <0x33>;
				phandle = <0x5a>;
				regulators {
					buck1 {
						regulator-name = "da9131_buck1";
						regulator-boot-on;
						regulator-always-on;
						phandle = <0x5b>;
					buck2 {
						regulator-name = "da9131_buck2";
						regulator-boot-on;
						phandle = <0x5c>;
			pmic@32 {
				compatible = "dlg,da9130";
				reg = <0x32>;
				phandle = <0x5d>;
				regulators {
					buck1 {
						regulator-name = "da9130_buck1";
						regulator-boot-on;
						phandle = <0x5e>;
		memory-controller@ff960000 {
			compatible = "xlnx,zynqmp-ocmc-1.0";
			reg = <0x0 0xff960000 0x0 0x1000>;
			interrupts = <0x0 0xa 0x4>;
			phandle = <0x5f>;
		perf-monitor@ffa00000 {
			compatible = "xlnx,axi-perf-monitor";
			reg = <0x0 0xffa00000 0x0 0x10000>;
			interrupts = <0x0 0x19 0x4>;
			xlnx,enable-profile = <0x0>;
			xlnx,enable-trace = <0x0>;
			xlnx,num-monitor-slots = <0x1>;
			xlnx,enable-event-count = <0x1>;
			xlnx,enable-event-log = <0x1>;
			xlnx,have-sampled-metric-cnt = <0x1>;
			xlnx,num-of-counters = <0x8>;
			xlnx,metric-count-width = <0x20>;
			xlnx,metrics-sample-count-width = <0x20>;
			xlnx,global-count-width = <0x20>;
			xlnx,metric-count-scale = <0x1>;
			phandle = <0x60>;
		perf-monitor@fd0b0000 {
			reg = <0x0 0xfd0b0000 0x0 0x10000>;
			interrupts = <0x0 0x7b 0x4>;
			xlnx,num-monitor-slots = <0x6>;
			xlnx,enable-event-log = <0x0>;
			xlnx,num-of-counters = <0xa>;
			clocks = <0x4 0x1c>;
			phandle = <0x61>;
		perf-monitor@fd490000 {
			reg = <0x0 0xfd490000 0x0 0x10000>;
			phandle = <0x62>;
		perf-monitor@ffa10000 {
			reg = <0x0 0xffa10000 0x0 0x10000>;
			phandle = <0x63>;
		pcie@fd0e0000 {
			compatible = "xlnx,nwl-pcie-2.11";
			#address-cells = <0x3>;
			#interrupt-cells = <0x1>;
			msi-controller;
			device_type = "pci";
			interrupts = <0x0 0x76 0x4 0x0 0x75 0x4 0x0 0x74 0x4 0x0 0x73 0x4 0x0 0x72 0x4>;
			interrupt-names = "misc", "dummy", "intx", "msi1", "msi0";
			msi-parent = <0x15>;
			reg = <0x0 0xfd0e0000 0x0 0x1000 0x0 0xfd480000 0x0 0x1000 0x80 0x0 0x0 0x1000000>;
			reg-names = "breg", "pcireg", "cfg";
			ranges = <0x2000000 0x0 0xe0000000 0x0 0xe0000000 0x0 0x10000000 0x43000000 0x6 0x0 0x6 0x0 0x2 0x0>;
			interrupt-map-mask = <0x0 0x0 0x0 0x7>;
			bus-range = <0x0 0xff>;
			interrupt-map = <0x0 0x0 0x0 0x1 0x16 0x1 0x0 0x0 0x0 0x2 0x16 0x2 0x0 0x0 0x0 0x3 0x16 0x3 0x0 0x0 0x0 0x4 0x16 0x4>;
			iommus = <0x12 0x4d0>;
			power-domains = <0x11 0x3b>;
			clocks = <0x4 0x17>;
			phandle = <0x15>;
			legacy-interrupt-controller {
				#address-cells = <0x0>;
				phandle = <0x16>;
		spi@ff0f0000 {
			compatible = "xlnx,zynqmp-qspi-1.0";
			status = "okay";
			clock-names = "ref_clk", "pclk";
			interrupts = <0x0 0xf 0x4>;
			num-cs = <0x1>;
			reg = <0x0 0xff0f0000 0x0 0x1000 0x0 0xc0000000 0x0 0x8000000>;
			iommus = <0x12 0x873>;
			power-domains = <0x11 0x2d>;
			clocks = <0x4 0x35 0x4 0x1f>;
			is-dual = <0x0>;
			spi-rx-bus-width = <0x4>;
			spi-tx-bus-width = <0x4>;
			phandle = <0x64>;
			flash@0 {
				compatible = "mt25qu512a", "jedec,spi-nor";
				reg = <0x0>;
				spi-max-frequency = <0x2625a00>;
				phandle = <0x65>;
				partitions {
					compatible = "fixed-partitions";
					partition@0 {
						label = "Image Selector";
						reg = <0x0 0x80000>;
						read-only;
						lock;
					partition@80000 {
						label = "Image Selector Golden";
						reg = <0x80000 0x80000>;
						read-only;
						lock;
					partition@100000 {
						label = "Persistent Register";
						reg = <0x100000 0x20000>;
					partition@120000 {
						label = "Persistent Register Backup";
						reg = <0x120000 0x20000>;
					partition@140000 {
						label = "Open_1";
						reg = <0x140000 0xc0000>;
					partition@200000 {
						label = "Image A (FSBL, PMU, ATF, U-Boot)";
						reg = <0x200000 0xd00000>;
					partition@f00000 {
						label = "ImgSel Image A Catch";
						reg = <0xf00000 0x80000>;
						read-only;
						lock;
					partition@f80000 {
						label = "Image B (FSBL, PMU, ATF, U-Boot)";
						reg = <0xf80000 0xd00000>;
					partition@1c80000 {
						label = "ImgSel Image B Catch";
						reg = <0x1c80000 0x80000>;
						read-only;
						lock;
					partition@1d00000 {
						label = "Open_2";
						reg = <0x1d00000 0x100000>;
					partition@1e00000 {
						label = "Recovery Image";
						reg = <0x1e00000 0x200000>;
						read-only;
						lock;
					partition@2000000 {
						label = "Recovery Image Backup";
						reg = <0x2000000 0x200000>;
						read-only;
						lock;
					partition@2200000 {
						label = "U-Boot storage variables";
						reg = <0x2200000 0x20000>;
					partition@2220000 {
						label = "U-Boot storage variables backup";
						reg = <0x2220000 0x20000>;
					partition@2240000 {
						label = "SHA256";
						reg = <0x2240000 0x40000>;
						read-only;
						lock;
					partition@2280000 {
						label = "Secure OS Storage";
						reg = <0x2280000 0x20000>;
					partition@22A0000 {
						label = "User";
						reg = <0x22a0000 0x1db0000>;
		phy@fd400000 {
			compatible = "xlnx,zynqmp-psgtr-v1.1";
			status = "okay";
			reg = <0x0 0xfd400000 0x0 0x40000 0x0 0xfd3d0000 0x0 0x1000>;
			reg-names = "serdes", "siou";
			#phy-cells = <0x4>;
			phandle = <0x66>;
		rtc@ffa60000 {
			compatible = "xlnx,zynqmp-rtc";
			status = "okay";
			reg = <0x0 0xffa60000 0x0 0x100>;
			interrupts = <0x0 0x1a 0x4 0x0 0x1b 0x4>;
			interrupt-names = "alarm", "sec";
			calibration = <0x7fff>;
			phandle = <0x67>;
		ahci@fd0c0000 {
			compatible = "ceva,ahci-1v84";
			reg = <0x0 0xfd0c0000 0x0 0x2000>;
			interrupts = <0x0 0x85 0x4>;
			power-domains = <0x11 0x1c>;
			resets = <0x13 0x10>;
			clocks = <0x4 0x16>;
			phandle = <0x68>;
		mmc@ff160000 {
			compatible = "xlnx,zynqmp-8.9a", "arasan,sdhci-8.9a";
			status = "okay";
			interrupts = <0x0 0x30 0x4>;
			reg = <0x0 0xff160000 0x0 0x1000>;
			clock-names = "clk_xin", "clk_ahb";
			iommus = <0x12 0x870>;
			power-domains = <0x11 0x27>;
			clock-output-names = "clk_out_sd0", "clk_in_sd0";
			resets = <0x13 0x26>;
			clocks = <0x4 0x36 0x4 0x1f>;
			assigned-clocks = <0x4 0x36>;
			pinctrl-names = "default";
			pinctrl-0 = <0x17>;
			non-removable;
			disable-wp;
			bus-width = <0x8>;
			xlnx,mio-bank = <0x0>;
			assigned-clock-rates = <0xb2cfe8b>;
			clock-frequency = <0xb2cfe8b>;
			phandle = <0x69>;
		mmc@ff170000 {
			interrupts = <0x0 0x31 0x4>;
			reg = <0x0 0xff170000 0x0 0x1000>;
			iommus = <0x12 0x871>;
			power-domains = <0x11 0x28>;
			clock-output-names = "clk_out_sd1", "clk_in_sd1";
			resets = <0x13 0x27>;
			clocks = <0x4 0x37 0x4 0x1f>;
			assigned-clocks = <0x4 0x37>;
			phandle = <0x6a>;
		smmu@fd800000 {
			compatible = "arm,mmu-500";
			reg = <0x0 0xfd800000 0x0 0x20000>;
			#iommu-cells = <0x1>;
			#global-interrupts = <0x1>;
			interrupts = <0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4 0x0 0x9b 0x4>;
			phandle = <0x12>;
		spi@ff040000 {
			compatible = "cdns,spi-r1p6";
			status = "okay";
			interrupts = <0x0 0x13 0x4>;
			reg = <0x0 0xff040000 0x0 0x1000>;
			power-domains = <0x11 0x23>;
			clocks = <0x4 0x3a 0x4 0x1f>;
			is-decoded-cs = <0x0>;
			num-cs = <0x3>;
			phandle = <0x6b>;
			ad9361-phy@0 {
				compatible = "adi,ad9361";
				reg = <0x0>;
				spi-cpha;
				spi-max-frequency = <0x989680>;
				clocks = <0x18 0x0>;
				clock-names = "ad9361_ext_refclk";
				clock-output-names = "rx_sampl_clk", "tx_sampl_clk";
				adi,digital-interface-tune-skip-mode = <0x0>;
				adi,pp-tx-swap-enable;
				adi,pp-rx-swap-enable;
				adi,rx-frame-pulse-mode-enable;
				adi,lvds-mode-enable;
				adi,lvds-bias-mV = <0x96>;
				adi,lvds-rx-onchip-termination-enable;
				adi,rx-data-delay = <0x4>;
				adi,tx-fb-clock-delay = <0x7>;
				adi,dcxo-coarse-and-fine-tune = <0x8 0x1720>;
				adi,2rx-2tx-mode-enable;
				adi,frequency-division-duplex-mode-enable;
				adi,rx-rf-port-input-select = <0x0>;
				adi,tx-rf-port-input-select = <0x0>;
				adi,tx-attenuation-mdB = <0x2710>;
				adi,tx-lo-powerdown-managed-enable;
				adi,rf-rx-bandwidth-hz = <0x112a880>;
				adi,rf-tx-bandwidth-hz = <0x112a880>;
				adi,rx-synthesizer-frequency-hz = <0x0 0x8f0d1800>;
				adi,tx-synthesizer-frequency-hz = <0x0 0x92080880>;
				adi,rx-path-clock-frequencies = <0x3a980000 0xea60000 0x7530000 0x3a98000 0x1d4c000 0x1d4c000>;
				adi,tx-path-clock-frequencies = <0x3a980000 0x7530000 0x7530000 0x3a98000 0x1d4c000 0x1d4c000>;
				adi,gc-rx1-mode = <0x2>;
				adi,gc-rx2-mode = <0x2>;
				adi,gc-adc-ovr-sample-size = <0x4>;
				adi,gc-adc-small-overload-thresh = <0x2f>;
				adi,gc-adc-large-overload-thresh = <0x3a>;
				adi,gc-lmt-overload-high-thresh = <0x320>;
				adi,gc-lmt-overload-low-thresh = <0x2c0>;
				adi,gc-dec-pow-measurement-duration = <0x2000>;
				adi,gc-low-power-thresh = <0x18>;
				adi,mgc-inc-gain-step = <0x2>;
				adi,mgc-dec-gain-step = <0x2>;
				adi,mgc-split-table-ctrl-inp-gain-mode = <0x0>;
				adi,agc-attack-delay-extra-margin-us = <0x1>;
				adi,agc-outer-thresh-high = <0x5>;
				adi,agc-outer-thresh-high-dec-steps = <0x2>;
				adi,agc-inner-thresh-high = <0xa>;
				adi,agc-inner-thresh-high-dec-steps = <0x1>;
				adi,agc-inner-thresh-low = <0xc>;
				adi,agc-inner-thresh-low-inc-steps = <0x1>;
				adi,agc-outer-thresh-low = <0x12>;
				adi,agc-outer-thresh-low-inc-steps = <0x2>;
				adi,agc-adc-small-overload-exceed-counter = <0xa>;
				adi,agc-adc-large-overload-exceed-counter = <0xa>;
				adi,agc-adc-large-overload-inc-steps = <0x2>;
				adi,agc-lmt-overload-large-exceed-counter = <0xa>;
				adi,agc-lmt-overload-small-exceed-counter = <0xa>;
				adi,agc-lmt-overload-large-inc-steps = <0x2>;
				adi,agc-gain-update-interval-us = <0x3e8>;
				adi,fagc-dec-pow-measurement-duration = <0x40>;
				adi,fagc-lp-thresh-increment-steps = <0x1>;
				adi,fagc-lp-thresh-increment-time = <0x5>;
				adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt = <0x8>;
				adi,fagc-final-overrange-count = <0x3>;
				adi,fagc-gain-index-type-after-exit-rx-mode = <0x0>;
				adi,fagc-lmt-final-settling-steps = <0x1>;
				adi,fagc-lock-level = <0xa>;
				adi,fagc-lock-level-gain-increase-upper-limit = <0x5>;
				adi,fagc-lock-level-lmt-gain-increase-enable;
				adi,fagc-lpf-final-settling-steps = <0x1>;
				adi,fagc-optimized-gain-offset = <0x5>;
				adi,fagc-power-measurement-duration-in-state5 = <0x40>;
				adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable;
				adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll = <0xa>;
				adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable;
				adi,fagc-rst-gla-if-en-agc-pulled-high-mode = <0x0>;
				adi,fagc-rst-gla-large-adc-overload-enable;
				adi,fagc-rst-gla-large-lmt-overload-enable;
				adi,fagc-rst-gla-stronger-sig-thresh-above-ll = <0xa>;
				adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable;
				adi,fagc-state-wait-time-ns = <0x104>;
				adi,fagc-use-last-lock-level-for-set-gain-enable;
				adi,rssi-restart-mode = <0x3>;
				adi,rssi-delay = <0x1>;
				adi,rssi-wait = <0x1>;
				adi,rssi-duration = <0x3e8>;
				adi,ctrl-outs-index = <0x0>;
				adi,ctrl-outs-enable-mask = <0xff>;
				adi,temp-sense-measurement-interval-ms = <0x3e8>;
				adi,temp-sense-offset-signed = <0xce>;
				adi,temp-sense-periodic-measurement-enable;
				adi,aux-dac-manual-mode-enable;
				adi,aux-dac1-default-value-mV = <0x0>;
				adi,aux-dac1-rx-delay-us = <0x0>;
				adi,aux-dac1-tx-delay-us = <0x0>;
				adi,aux-dac2-default-value-mV = <0x0>;
				adi,aux-dac2-rx-delay-us = <0x0>;
				adi,aux-dac2-tx-delay-us = <0x0>;
				en_agc-gpios = <0x14 0x1e 0x0>;
				sync-gpios = <0x14 0x1f 0x0>;
				reset-gpios = <0x14 0x20 0x0>;
				enable-gpios = <0x14 0x21 0x0>;
				txnrx-gpios = <0x14 0x22 0x0>;
				phandle = <0x23>;
		spi@ff050000 {
			interrupts = <0x0 0x14 0x4>;
			reg = <0x0 0xff050000 0x0 0x1000>;
			power-domains = <0x11 0x24>;
			clocks = <0x4 0x3b 0x4 0x1f>;
			label = "TPM";
			num-cs = <0x1>;
			phandle = <0x6c>;
			tpm@0 {
				compatible = "infineon,slb9670", "tcg,tpm_tis-spi";
				reg = <0x0>;
				spi-max-frequency = <0x11a49a0>;
		timer@ff110000 {
			compatible = "cdns,ttc";
			status = "okay";
			interrupts = <0x0 0x24 0x4 0x0 0x25 0x4 0x0 0x26 0x4>;
			reg = <0x0 0xff110000 0x0 0x1000>;
			timer-width = <0x20>;
			power-domains = <0x11 0x18>;
			#pwm-cells = <0x3>;
			phandle = <0x21>;
		timer@ff120000 {
			status = "okay";
			interrupts = <0x0 0x27 0x4 0x0 0x28 0x4 0x0 0x29 0x4>;
			reg = <0x0 0xff120000 0x0 0x1000>;
			power-domains = <0x11 0x19>;
			phandle = <0x6d>;
		timer@ff130000 {
			status = "okay";
			interrupts = <0x0 0x2a 0x4 0x0 0x2b 0x4 0x0 0x2c 0x4>;
			reg = <0x0 0xff130000 0x0 0x1000>;
			power-domains = <0x11 0x1a>;
			phandle = <0x6e>;
		timer@ff140000 {
			status = "okay";
			interrupts = <0x0 0x2d 0x4 0x0 0x2e 0x4 0x0 0x2f 0x4>;
			reg = <0x0 0xff140000 0x0 0x1000>;
			power-domains = <0x11 0x1b>;
			phandle = <0x6f>;
		serial@ff000000 {
			compatible = "xlnx,zynqmp-uart", "cdns,uart-r1p12";
			interrupts = <0x0 0x15 0x4>;
			reg = <0x0 0xff000000 0x0 0x1000>;
			clock-names = "uart_clk", "pclk";
			power-domains = <0x11 0x21>;
			clocks = <0x4 0x38 0x4 0x1f>;
			phandle = <0x70>;
		serial@ff010000 {
			status = "okay";
			interrupts = <0x0 0x16 0x4>;
			reg = <0x0 0xff010000 0x0 0x1000>;
			power-domains = <0x11 0x22>;
			clocks = <0x4 0x39 0x4 0x1f>;
			cts-override;
			device_type = "serial";
			port-number = <0x0>;
			phandle = <0x71>;
		usb@ff9d0000 {
			compatible = "xlnx,zynqmp-dwc3";
			reg = <0x0 0xff9d0000 0x0 0x100>;
			clock-names = "bus_clk", "ref_clk";
			power-domains = <0x11 0x16>;
			resets = <0x13 0x3b 0x13 0x3d 0x13 0x3f>;
			reset-names = "usb_crst", "usb_hibrst", "usb_apbrst";
			reset-gpios = <0x19 0x1 0x1>;
			ranges;
			clocks = <0x4 0x20 0x4 0x22>;
			assigned-clocks = <0x4 0x20 0x4 0x22>;
			phandle = <0x72>;
			usb@fe200000 {
				compatible = "snps,dwc3";
				status = "okay";
				reg = <0x0 0xfe200000 0x0 0x40000>;
				interrupt-names = "dwc_usb3", "otg", "hiber";
				interrupts = <0x0 0x41 0x4 0x0 0x45 0x4 0x0 0x4b 0x4>;
				iommus = <0x12 0x860>;
				snps,quirk-frame-length-adjustment = <0x20>;
				clock-names = "ref";
				snps,enable_guctl1_resume_quirk;
				snps,enable_guctl1_ipd_quirk;
				snps,resume-hs-terminations;
				clocks = <0x4 0x22>;
				dr_mode = "otg";
				phandle = <0x73>;
		usb@ff9e0000 {
			reg = <0x0 0xff9e0000 0x0 0x100>;
			power-domains = <0x11 0x17>;
			resets = <0x13 0x3c 0x13 0x3e 0x13 0x40>;
			ranges;
			clocks = <0x4 0x21 0x4 0x22>;
			assigned-clocks = <0x4 0x21 0x4 0x22>;
			phandle = <0x74>;
			usb@fe300000 {
				reg = <0x0 0xfe300000 0x0 0x40000>;
				interrupts = <0x0 0x46 0x4 0x0 0x4a 0x4 0x0 0x4c 0x4>;
				iommus = <0x12 0x861>;
				phandle = <0x75>;
		watchdog@fd4d0000 {
			compatible = "cdns,wdt-r1p2";
			status = "okay";
			interrupts = <0x0 0x71 0x1>;
			reg = <0x0 0xfd4d0000 0x0 0x1000>;
			timeout-sec = <0x3c>;
			reset-on-timeout;
			clocks = <0x4 0x4b>;
			phandle = <0x76>;
		watchdog@ff150000 {
			status = "okay";
			interrupts = <0x0 0x34 0x1>;
			reg = <0x0 0xff150000 0x0 0x1000>;
			timeout-sec = <0xa>;
			clocks = <0x4 0x70>;
			phandle = <0x77>;
		ams@ffa50000 {
			compatible = "xlnx,zynqmp-ams";
			status = "okay";
			interrupts = <0x0 0x38 0x4>;
			interrupt-names = "ams-irq";
			reg = <0x0 0xffa50000 0x0 0x800>;
			reg-names = "ams-base";
			#io-channel-cells = <0x1>;
			ranges = <0x0 0x0 0xffa50800 0x800>;
			clocks = <0x4 0x46>;
			phandle = <0x20>;
			ams_ps@0 {
				compatible = "xlnx,zynqmp-ams-ps";
				status = "okay";
				reg = <0x0 0x400>;
				phandle = <0x78>;
			ams_pl@400 {
				compatible = "xlnx,zynqmp-ams-pl";
				status = "okay";
				reg = <0x400 0x400>;
				phandle = <0x79>;
		dma-controller@fd4c0000 {
			compatible = "xlnx,zynqmp-dpdma";
			reg = <0x0 0xfd4c0000 0x0 0x1000>;
			interrupts = <0x0 0x7a 0x4>;
			clock-names = "axi_clk";
			power-domains = <0x11 0x29>;
			dma-channels = <0x6>;
			iommus = <0x12 0xce4>;
			#dma-cells = <0x1>;
			clocks = <0x4 0x14>;
			assigned-clocks = <0x4 0x14>;
			phandle = <0x1b>;
		dp_aud@fd4ac000 {
			compatible = "xlnx,zynqmp-dpaud-setting", "syscon";
			reg = <0x0 0xfd4ac000 0x0 0x1000>;
			phandle = <0x1a>;
		display@fd4a0000 {
			compatible = "xlnx,zynqmp-dpsub-1.7";
			reg = <0x0 0xfd4a0000 0x0 0x1000 0x0 0xfd4aa000 0x0 0x1000 0x0 0xfd4ab000 0x0 0x1000>;
			reg-names = "dp", "blend", "av_buf";
			xlnx,dpaud-reg = <0x1a>;
			interrupts = <0x0 0x77 0x4>;
			iommus = <0x12 0xce3>;
			clock-names = "dp_apb_clk", "dp_aud_clk", "dp_vtc_pixel_clk_in";
			resets = <0x13 0x3>;
			dma-names = "vid0", "vid1", "vid2", "gfx0";
			dmas = <0x1b 0x0 0x1b 0x1 0x1b 0x2 0x1b 0x3>;
			clocks = <0x1c 0x4 0x11 0x4 0x10>;
			assigned-clocks = <0x4 0x12 0x4 0x11 0x4 0x10>;
			phandle = <0x7a>;
			i2c-bus {
			zynqmp_dp_snd_codec0 {
				compatible = "xlnx,dp-snd-codec";
				clock-names = "aud_clk";
				clocks = <0x4 0x11>;
				phandle = <0x1f>;
			zynqmp_dp_snd_pcm0 {
				compatible = "xlnx,dp-snd-pcm0";
				dmas = <0x1b 0x4>;
				dma-names = "tx";
				phandle = <0x1d>;
			zynqmp_dp_snd_pcm1 {
				compatible = "xlnx,dp-snd-pcm1";
				dmas = <0x1b 0x5>;
				dma-names = "tx";
				phandle = <0x1e>;
			zynqmp_dp_snd_card {
				compatible = "xlnx,dp-snd-card";
				xlnx,dp-snd-pcm = <0x1d 0x1e>;
				xlnx,dp-snd-codec = <0x1f>;
				phandle = <0x7b>;
	fclk0 {
		status = "okay";
		compatible = "xlnx,fclk";
		clocks = <0x4 0x47>;
		phandle = <0x7c>;
	fclk1 {
		status = "okay";
		clocks = <0x4 0x48>;
		phandle = <0x7d>;
	fclk2 {
		status = "okay";
		clocks = <0x4 0x49>;
		phandle = <0x7e>;
	fclk3 {
		status = "okay";
		clocks = <0x4 0x4a>;
		phandle = <0x7f>;
	pss_ref_clk {
		compatible = "fixed-clock";
		#clock-cells = <0x0>;
		clock-frequency = <0x1fca055>;
		phandle = <0xb>;
	video_clk {
		clock-frequency = <0x19bfcc0>;
		phandle = <0xc>;
	pss_alt_ref_clk {
		clock-frequency = <0x0>;
		phandle = <0xd>;
	gt_crx_ref_clk {
		clock-frequency = <0x66ff300>;
		phandle = <0xf>;
	aux_ref_clk {
		phandle = <0xe>;
	dp_aclk {
		clock-frequency = <0x5f5e100>;
		clock-accuracy = <0x64>;
		phandle = <0x1c>;
	aliases {
		gpio0 = "/axi/gpio@ff0a0000";
		i2c0 = "/axi/i2c@ff020000";
		i2c1 = "/axi/i2c@ff030000";
		mmc0 = "/axi/mmc@ff160000";
		mmc1 = "/axi/mmc@ff170000";
		nvmem0 = "/axi/i2c@ff030000/eeprom@50";
		nvmem1 = "/axi/i2c@ff030000/eeprom@51";
		rtc0 = "/axi/rtc@ffa60000";
		serial0 = "/axi/serial@ff000000";
		serial1 = "/axi/serial@ff010000";
		serial2 = "/dcc";
		spi0 = "/axi/spi@ff0f0000";
		spi1 = "/axi/spi@ff040000";
		spi2 = "/axi/spi@ff050000";
		usb0 = "/axi/usb@ff9d0000";
		usb1 = "/axi/usb@ff9e0000";
	chosen {
		bootargs = "earlycon console=ttyPS1,115200 clk_ignore_unused earlyprintk";
		stdout-path = "serial1:115200n8";
	gpio-keys {
		compatible = "gpio-keys";
		autorepeat;
		key-fwuen {
			label = "fwuen";
			gpios = <0x14 0xc 0x1>;
			linux,code = <0x100>;
			wakeup-source;
			autorepeat;
	leds {
		compatible = "gpio-leds";
		ds35-led {
			label = "heartbeat";
			gpios = <0x14 0x7 0x0>;
			linux,default-trigger = "heartbeat";
		ds36-led {
			label = "vbus_det";
			gpios = <0x14 0x8 0x0>;
			default-state = "on";
	ams {
		compatible = "iio-hwmon";
		io-channels = <0x20 0x0 0x20 0x1 0x20 0x2 0x20 0x3 0x20 0x4 0x20 0x5 0x20 0x6 0x20 0x7 0x20 0x8 0x20 0x9 0x20 0xa 0x20 0xb 0x20 0xc 0x20 0xd 0x20 0xe 0x20 0xf 0x20 0x10 0x20 0x11 0x20 0x12 0x20 0x13 0x20 0x14 0x20 0x15 0x20 0x16 0x20 0x17 0x20 0x18 0x20 0x19 0x20 0x1a 0x20 0x1b 0x20 0x1c 0x20 0x1d>;
	pwm-fan {
		compatible = "pwm-fan";
		pwms = <0x21 0x2 0x9c40 0x0>;
	memory@0 {
		device_type = "memory";
		reg = <0x0 0x0 0x0 0x7ff00000 0x8 0x0 0x0 0x80000000>;
	clocks {
		clock@0 {
			clock-frequency = <0x2625a00>;
			clock-output-names = "ad9361_ext_refclk";
			phandle = <0x18>;
	fpga-axi@0 {
		ranges = <0x0 0x0 0x0 0xffffffff>;
		phandle = <0x80>;
		dma@80000000 {
			compatible = "xlnx,axi-dmac-1.0";
			#dma-cells = <0x1>;
			interrupts = <0x0 0x68 0x4>;
			reg = <0x80000000 0x10000>;
			phandle = <0x22>;
			adi,channels {
				dma-channel@0 {
					reg = <0x0>;
					adi,source-bus-width = <0x40>;
					adi,source-bus-type = <0x2>;
					adi,destination-bus-width = <0x40>;
					adi,destination-bus-type = <0x0>;
		dma1@80060000 {
			#dma-cells = <0x1>;
			interrupts = <0x0 0x69 0x4>;
			reg = <0x80060000 0x10000>;
			phandle = <0x24>;
			adi,channels {
				dma-channel@0 {
					reg = <0x0>;
					adi,source-bus-type = <0x0>;
					adi,destination-bus-type = <0x2>;
		cf-ad9361-lpc@80010000 {
			compatible = "adi,axi-ad9361-6.00.a";
			reg = <0x80010000 0x6000>;
			dmas = <0x22 0x0>;
			dma-names = "rx";
			spibus-connected = <0x23>;
			phandle = <0x81>;
		cf-ad9361-dds-core-lpc@80014000 {
			compatible = "adi,axi-ad9361-dds-6.00.a";
			reg = <0x80014000 0x1000>;
			clocks = <0x23 0xd>;
			clock-names = "sampl_clk";
			dmas = <0x24 0x0>;
			dma-names = "tx";
			phandle = <0x82>;
		axi_sysid-0@80040000 {
			compatible = "xlnx,axi-sysid-1.0";
			reg = <0x80040000 0x10000>;
			phandle = <0x83>;
	__symbols__ {
		cpu0 = "/cpus/cpu@0";
		cpu1 = "/cpus/cpu@1";
		cpu2 = "/cpus/cpu@2";
		cpu3 = "/cpus/cpu@3";
		L2 = "/cpus/l2-cache";
		CPU_SLEEP_0 = "/cpus/idle-states/cpu-sleep-0";
		cpu_opp_table = "/opp-table-cpu";
		zynqmp_ipi = "/zynqmp_ipi";
		ipi_mailbox_pmu1 = "/zynqmp_ipi/mailbox@ff9905c0";
		dcc = "/dcc";
		zynqmp_firmware = "/firmware/zynqmp-firmware";
		zynqmp_power = "/firmware/zynqmp-firmware/zynqmp-power";
		soc_revision = "/firmware/zynqmp-firmware/nvmem_firmware/soc_revision@0";
		efuse_dna = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_dna@c";
		efuse_usr0 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr0@20";
		efuse_usr1 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr1@24";
		efuse_usr2 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr2@28";
		efuse_usr3 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr3@2c";
		efuse_usr4 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr4@30";
		efuse_usr5 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr5@34";
		efuse_usr6 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr6@38";
		efuse_usr7 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr7@3c";
		efuse_miscusr = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_miscusr@40";
		efuse_chash = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_chash@50";
		efuse_pufmisc = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_pufmisc@54";
		efuse_sec = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_sec@58";
		efuse_spkid = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_spkid@5c";
		efuse_ppk0hash = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_ppk0hash@a0";
		efuse_ppk1hash = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_ppk1hash@d0";
		zynqmp_pcap = "/firmware/zynqmp-firmware/pcap";
		zynqmp_reset = "/firmware/zynqmp-firmware/reset-controller";
		pinctrl0 = "/firmware/zynqmp-firmware/pinctrl";
		pinctrl_sdhci0_default = "/firmware/zynqmp-firmware/pinctrl/sdhci0-default";
		modepin_gpio = "/firmware/zynqmp-firmware/gpio";
		zynqmp_clk = "/firmware/zynqmp-firmware/clock-controller";
		fpga_full = "/fpga-full";
		amba = "/axi";
		can0 = "/axi/can@ff060000";
		can1 = "/axi/can@ff070000";
		cci = "/axi/cci@fd6e0000";
		fpd_dma_chan1 = "/axi/dma-controller@fd500000";
		fpd_dma_chan2 = "/axi/dma-controller@fd510000";
		fpd_dma_chan3 = "/axi/dma-controller@fd520000";
		fpd_dma_chan4 = "/axi/dma-controller@fd530000";
		fpd_dma_chan5 = "/axi/dma-controller@fd540000";
		fpd_dma_chan6 = "/axi/dma-controller@fd550000";
		fpd_dma_chan7 = "/axi/dma-controller@fd560000";
		fpd_dma_chan8 = "/axi/dma-controller@fd570000";
		gic = "/axi/interrupt-controller@f9010000";
		gpu = "/axi/gpu@fd4b0000";
		lpd_dma_chan1 = "/axi/dma-controller@ffa80000";
		lpd_dma_chan2 = "/axi/dma-controller@ffa90000";
		lpd_dma_chan3 = "/axi/dma-controller@ffaa0000";
		lpd_dma_chan4 = "/axi/dma-controller@ffab0000";
		lpd_dma_chan5 = "/axi/dma-controller@ffac0000";
		lpd_dma_chan6 = "/axi/dma-controller@ffad0000";
		lpd_dma_chan7 = "/axi/dma-controller@ffae0000";
		lpd_dma_chan8 = "/axi/dma-controller@ffaf0000";
		mc = "/axi/memory-controller@fd070000";
		nand0 = "/axi/nand-controller@ff100000";
		gem0 = "/axi/ethernet@ff0b0000";
		gem1 = "/axi/ethernet@ff0c0000";
		gem2 = "/axi/ethernet@ff0d0000";
		gem3 = "/axi/ethernet@ff0e0000";
		gpio = "/axi/gpio@ff0a0000";
		eeprom = "/axi/i2c@ff030000/eeprom@50";
		eeprom_cc = "/axi/i2c@ff030000/eeprom@51";
		da9131 = "/axi/i2c@ff030000/pmic@33";
		da9131_buck1 = "/axi/i2c@ff030000/pmic@33/regulators/buck1";
		da9131_buck2 = "/axi/i2c@ff030000/pmic@33/regulators/buck2";
		da9130 = "/axi/i2c@ff030000/pmic@32";
		da9130_buck1 = "/axi/i2c@ff030000/pmic@32/regulators/buck1";
		ocm = "/axi/memory-controller@ff960000";
		perf_monitor_ocm = "/axi/perf-monitor@ffa00000";
		perf_monitor_ddr = "/axi/perf-monitor@fd0b0000";
		perf_monitor_cci = "/axi/perf-monitor@fd490000";
		perf_monitor_lpd = "/axi/perf-monitor@ffa10000";
		pcie = "/axi/pcie@fd0e0000";
		pcie_intc = "/axi/pcie@fd0e0000/legacy-interrupt-controller";
		qspi = "/axi/spi@ff0f0000";
		spi_flash = "/axi/spi@ff0f0000/flash@0";
		psgtr = "/axi/phy@fd400000";
		rtc = "/axi/rtc@ffa60000";
		sata = "/axi/ahci@fd0c0000";
		sdhci0 = "/axi/mmc@ff160000";
		sdhci1 = "/axi/mmc@ff170000";
		smmu = "/axi/smmu@fd800000";
		spi0 = "/axi/spi@ff040000";
		adc0_ad9361 = "/axi/spi@ff040000/ad9361-phy@0";
		spi1 = "/axi/spi@ff050000";
		ttc0 = "/axi/timer@ff110000";
		ttc1 = "/axi/timer@ff120000";
		ttc2 = "/axi/timer@ff130000";
		ttc3 = "/axi/timer@ff140000";
		uart0 = "/axi/serial@ff000000";
		uart1 = "/axi/serial@ff010000";
		dwc3_0 = "/axi/usb@ff9d0000/usb@fe200000";
		dwc3_1 = "/axi/usb@ff9e0000/usb@fe300000";
		watchdog0 = "/axi/watchdog@fd4d0000";
		lpd_watchdog = "/axi/watchdog@ff150000";
		xilinx_ams = "/axi/ams@ffa50000";
		ams_ps = "/axi/ams@ffa50000/ams_ps@0";
		ams_pl = "/axi/ams@ffa50000/ams_pl@400";
		zynqmp_dpdma = "/axi/dma-controller@fd4c0000";
		zynqmp_dpaud_setting = "/axi/dp_aud@fd4ac000";
		zynqmp_dpsub = "/axi/display@fd4a0000";
		zynqmp_dp_snd_codec0 = "/axi/display@fd4a0000/zynqmp_dp_snd_codec0";
		zynqmp_dp_snd_pcm0 = "/axi/display@fd4a0000/zynqmp_dp_snd_pcm0";
		zynqmp_dp_snd_pcm1 = "/axi/display@fd4a0000/zynqmp_dp_snd_pcm1";
		zynqmp_dp_snd_card0 = "/axi/display@fd4a0000/zynqmp_dp_snd_card";
		fclk0 = "/fclk0";
		fclk1 = "/fclk1";
		fclk2 = "/fclk2";
		fclk3 = "/fclk3";
		pss_ref_clk = "/pss_ref_clk";
		video_clk = "/video_clk";
		pss_alt_ref_clk = "/pss_alt_ref_clk";
		gt_crx_ref_clk = "/gt_crx_ref_clk";
		aux_ref_clk = "/aux_ref_clk";
		dp_aclk = "/dp_aclk";
		ad9361_clkin = "/clocks/clock@0";
		fpga_axi = "/fpga-axi@0";
		rx_dma = "/fpga-axi@0/dma@80000000";
		tx_dma = "/fpga-axi@0/dma1@80060000";
		cf_ad9361_adc_core_0 = "/fpga-axi@0/cf-ad9361-lpc@80010000";
		cf_ad9361_dac_core_0 = "/fpga-axi@0/cf-ad9361-dds-core-lpc@80014000";
		axi_sysid_0 = "/fpga-axi@0/axi_sysid-0@80040000";
and here is my pl.dtsi
 * CAUTION: This file is automatically generated by Xilinx.
 * Version: XSCT
 * Today is: Mon Jan 29 22:56:00 2024
	amba_pl: amba_pl@0 {
		#address-cells = <2>;
		#size-cells = <2>;
		ranges ;
		Memory_devices_FRAM_SPI: axi_quad_spi@a0000000 {
			bits-per-word = <8>;
			clock-names = "ext_spi_clk", "s_axi_aclk";
			clocks = <&zynqmp_clk 71>, <&zynqmp_clk 71>;
			compatible = "xlnx,axi-quad-spi-3.2", "xlnx,xps-spi-2.00.a";
			fifo-size = <16>;
			interrupt-names = "ip2intc_irpt";
			interrupt-parent = <&gic>;
			interrupts = <0 89 1>;
			num-cs = <0x3>;
			reg = <0x0 0xa0000000 0x0 0x10000>;
			xlnx,num-ss-bits = <0x3>;
			xlnx,spi-mode = <0>;
		Memory_devices_NOR_Flash_NOR0_QSPI: axi_quad_spi@a0010000 {
			fifo-size = <16>;
			interrupts = <0 93 1>;
			num-cs = <0x1>;
			reg = <0x0 0xa0010000 0x0 0x10000>;
			xlnx,num-ss-bits = <0x1>;
			xlnx,spi-mode = <2>;
		Memory_devices_NOR_Flash_NOR1_QSPI: axi_quad_spi@a0020000 {
			fifo-size = <16>;
			interrupts = <0 92 1>;
			num-cs = <0x1>;
			reg = <0x0 0xa0020000 0x0 0x10000>;
		Memory_devices_NOR_Flash_NOR2_QSPI: axi_quad_spi@a0030000 {
			fifo-size = <16>;
			interrupts = <0 91 1>;
			num-cs = <0x1>;
			reg = <0x0 0xa0030000 0x0 0x10000>;
		Memory_devices_TLM_SPI: axi_quad_spi@a0040000 {
			fifo-size = <16>;
			interrupts = <0 90 1>;
			num-cs = <0x1>;
			reg = <0x0 0xa0040000 0x0 0x10000>;
		adc_dma: axi_dmac@80000000 {
			clock-names = "s_axi_aclk", "m_dest_axi_aclk", "fifo_wr_clk";
			clocks = <&zynqmp_clk 71>, <&zynqmp_clk 71>, <&misc_clk_0>;
			interrupt-names = "irq";
			interrupts = <0 104 4>;
			reg = <0x0 0x80000000 0x0 0x10000>;
		misc_clk_0: misc_clk_0 {
			#clock-cells = <0>;
			clock-frequency = <100000000>;
		axi_ad9361_0: axi_ad9361@80010000 {
			clock-names = "delay_clk", "clk", "s_axi_aclk";
			clocks = <&zynqmp_clk 72>, <&misc_clk_0>, <&zynqmp_clk 71>;
			compatible = "xlnx,axi-ad9361-1.0";
			reg = <0x0 0x80010000 0x0 0x10000>;
		axi_gpio_0: gpio@a0050000 {
			#gpio-cells = <2>;
			clock-names = "s_axi_aclk";
			clocks = <&zynqmp_clk 71>;
			compatible = "xlnx,axi-gpio-2.0", "xlnx,xps-gpio-1.00.a";
			gpio-controller ;
			reg = <0x0 0xa0050000 0x0 0x10000>;
			xlnx,all-inputs = <0x1>;
			xlnx,all-inputs-2 = <0x0>;
			xlnx,all-outputs = <0x0>;
			xlnx,all-outputs-2 = <0x1>;
			xlnx,dout-default = <0x00000000>;
			xlnx,dout-default-2 = <0x00000000>;
			xlnx,gpio-width = <0x20>;
			xlnx,gpio2-width = <0x20>;
			xlnx,interrupt-present = <0x0>;
			xlnx,is-dual = <0x1>;
			xlnx,tri-default = <0xFFFFFFFF>;
			xlnx,tri-default-2 = <0xFFFFFFFF>;
		axi_sysid_0: axi_sysid@80040000 {
			reg = <0x0 0x80040000 0x0 0x10000>;
		dac_dma: axi_dmac@80060000 {
			clock-names = "s_axi_aclk", "m_src_axi_aclk", "m_axis_aclk";
			interrupts = <0 105 4>;
			reg = <0x0 0x80060000 0x0 0x10000>;
/include/ "pl-delete-nodes-custom-devicetree.dtsi"
any help would be appreciated. I want to included the pl.dtsi because of the memory devices and I am trying to change the compatibility strings because I cant get any spi devices to show up for anything and think that could be why.
Thread Notes
