ad9176 channel interpolation issue
Product Number: ad9176_ebz, ad9176
Hi
based on ad9176 datasheet
in mode4 and single link mode, channel interplation should be 2x or 3x but in https://github.com/analogdevicesinc/linux/blob/2021_R2/arch/arm64/boot/dts/xilinx/zynqmp-zcu102-rev10-ad9172-fmc-ebz-mode4.dts,  adi,channel-interpolation = <4>; and there isn't adi,dual-link property this means this node is in single-link so channel-interpolation should be 2 or 3, why this is 4, and when i set this property to 3 for example jesd_status is:
and i attach my iio_info output in this situation,
Library version: 0.24 (git tag: accb7b5)
Compiled with backends: local xml ip usb serial
IIO context created with local backend.
Backend version: 0.24 (git tag: accb7b5)
Backend description string: Linux ad9172 5.10.0-xilinx-v2021.2 #1 SMP Tue Oct 10 13:10:16 UTC 2023 aarch64
IIO context has 2 attributes:
	local,kernel: 5.10.0-xilinx-v2021.2
	uri: local:
IIO context has 4 devices:
	iio:device0: ams
		30 channels found:
			voltage6: vccpsintfpddr (input)
			2 channel-specific attributes found:
				attr  0: raw value: 18078
				attr  1: scale value: 0.045776367
			voltage14: vccpsio2 (input)
				attr  0: raw value: 19533
				attr  1: scale value: 0.091552734
			voltage16: psmgtravtt (input)
				attr  0: raw value: 39253
			voltage23: vccplintlp (input)
				attr  0: raw value: 18070
			voltage0: vcc_pspll0 (input)
				attr  0: raw value: 26067
			voltage22: vccbram (input)
				attr  0: raw value: 18284
			voltage26: vccams (input)
				attr  0: raw value: 39191
				attr  1: scale value: 0.015258789
			voltage8: vccpsintfp (input)
				attr  0: raw value: 18045
			temp1: remote_temp (input)
			3 channel-specific attributes found:
				attr  0: offset value: -36058
				attr  1: raw value: 40906
				attr  2: scale value: 7.771514892
			voltage9: vccpsaux (input)
				attr  0: raw value: 39284
			voltage25: vccplaux (input)
				attr  0: raw value: 39261
			voltage18: vccint (input)
				attr  0: raw value: 18470
			voltage15: psmgtravcc (input)
				attr  0: raw value: 18528
			temp0: ps_temp (input)
				attr  1: raw value: 41236
			voltage2: vccint (input)
				attr  0: raw value: 18229
			voltage5: vcc_psddrpll (input)
				attr  0: raw value: 39262
			voltage21: vccvrefn (input)
				attr  0: raw value: 6
			voltage7: vccpsintlp (input)
				attr  0: raw value: 18064
			voltage11: vccpsio3 (input)
				attr  0: raw value: 35862
			temp2: pl_temp (input)
				attr  1: raw value: 40566
			voltage13: vccpsio1 (input)
				attr  0: raw value: 19534
			voltage3: vccbram (input)
				attr  0: raw value: 18257
			voltage4: vccaux (input)
				attr  0: raw value: 39271
			voltage12: vccpsio0 (input)
				attr  0: raw value: 19528
			voltage10: vccpsddr (input)
				attr  0: raw value: 26328
			voltage24: vccplintfp (input)
				attr  0: raw value: 18080
			voltage1: vcc_psbatt (input)
				attr  0: raw value: 987
			voltage19: vccaux (input)
				attr  0: raw value: 39236
			voltage17: vccams (input)
				attr  0: raw value: 39299
			voltage20: vccvrefp (input)
				attr  0: raw value: 27293
		1 device-specific attributes found:
				attr  0: sampling_frequency ERROR: Invalid argument (22)
		No trigger on this device
	iio:device1: hmc7044
		4 channels found:
			altvoltage2: DAC_CLK (output)
				attr  0: frequency value: 368640000
				attr  1: phase value: 0.000000
			altvoltage3: DAC_SYSREF (output)
				attr  0: frequency value: 1920000
			altvoltage12: FPGA_CLK (output)
			altvoltage13: FPGA_SYSREF (output)
		7 device-specific attributes found:
				attr  0: mute_request value: 0
				attr  1: reseed_request value: 0
				attr  2: reset_dividers_request value: 0
				attr  3: sleep_request value: 0
				attr  4: sync_pin_mode value: disable
				attr  5: sync_pin_mode_available value: disable sync sysref sync_else_sysref
				attr  6: sysref_request value: 0
		2 debug attributes found:
				debug attr  0: status ERROR: Input/output error (5)
				debug attr  1: direct_reg_access value: 0x0
	iio:device2: axi-ad9172-hpc (buffer capable)
		15 channels found:
			voltage0_i:  (output, index: 0, format: le:S16/16>>0)
				attr  0: sampling_frequency value: 491520000
				attr  1: scale value: 1.000000000
			voltage0_q:  (output, index: 1, format: le:S16/16>>0)
			voltage1_i:  (output, index: 2, format: le:S16/16>>0)
			voltage1_q:  (output, index: 3, format: le:S16/16>>0)
			voltage1: nco (output)
			4 channel-specific attributes found:
				attr  0: enable value: 0
				attr  1: frequency value: 0
				attr  2: phase value: 0
				attr  3: sampling_frequency value: 491520000
			altvoltage3: TX1_Q_F2 (output)
			5 channel-specific attributes found:
				attr  0: frequency value: 39998110
				attr  2: raw value: 1
				attr  4: scale value: 0.250000
			altvoltage5: TX2_I_F2 (output)
				attr  1: phase value: 90000
			voltage6: nco (output)
			altvoltage2: TX1_Q_F1 (output)
			altvoltage1: TX1_I_F2 (output)
			altvoltage7: TX2_Q_F2 (output)
			altvoltage4: TX2_I_F1 (output)
			altvoltage0: TX1_I_F1 (output)
			altvoltage6: TX2_Q_F1 (output)
			voltage0: nco (output)
		2 device-specific attributes found:
				attr  0: sync_start_enable value: disarm
				attr  1: sync_start_enable_available value: arm
		2 buffer-specific attributes found:
				attr  0: data_available value: 0
				attr  1: length_align_bytes value: 16
		1 debug attributes found:
				debug attr  0: direct_reg_access value: 0x18
	iio_sysfs_trigger:
		0 channels found:
				attr  0: add_trigger ERROR: Permission denied (13)
				attr  1: remove_trigger ERROR: Permission denied (13)
when this property is 4 every thing is ok,
Parents
  • I would read this table differently. 4x8 is a valid configuration for both single and dual.
    Can you please provide your exact dts modifications?
    It's likely the case that the clock chip needs a different configuration if you change the interpolation factors...
    -Michael
  • 4x8 is a valid configuration for both single and dual
    so 2x6, 2x8, 3x6, 3x8 is for only one (single or dual)? can you clear this for me?
    and so in my case (3x8 and due to the my devicetree I posted in previous response) what is this configuration?
    thanks
  • so 2x6, 2x8, 3x6, 3x8 is for only one (single or dual)? can you clear this for me?
    Those are valid values for single and dual link, as long as you don't violate the max channel NCO clock rate of 1540 MHz.
    diff --git a/arch/arm64/boot/dts/xilinx/zynqmp-zcu102-rev10-ad9172-fmc-ebz-mode4.dts b/arch/arm64/boot/dts/xilinx/zynqmp-zcu102-rev10-ad9172-fmc-ebz-mode4.dts
    index 08d20a54503a..ff80999aae97 100644
    --- a/arch/arm64/boot/dts/xilinx/zynqmp-zcu102-rev10-ad9172-fmc-ebz-mode4.dts
    +++ b/arch/arm64/boot/dts/xilinx/zynqmp-zcu102-rev10-ad9172-fmc-ebz-mode4.dts
    @@ -7,7 +7,7 @@
      * hdl_project: <dac_fmc_ebz/zcu102>
      * board_revision: <>
    - * JESD Link Mode 4 Example: M4, L4, S1, F2,  NP'16, Interpolation: 4*8
    + * JESD Link Mode 4 Example: M4, L4, S1, F2,  NP'16, Interpolation: 3*8
      * Copyright (C) 2018-2022 Analog Devices Inc.
    @@ -22,11 +22,17 @@ &dac0_ad9172 {
            adi,jesd-subclass = <1>;
            adi,dac-interpolation = <8>;
    -       adi,channel-interpolation = <4>;
    +       adi,channel-interpolation = <3>;
            adi,clock-output-divider = <4>;
            adi,syncoutb-signal-type-lvds-enable;
    +       //jesd204-ignore-errors;
     &axi_ad9172_adxcvr {
            adi,out-clk-select = <XCVR_REFCLK_DIV2>;
    +&hmc7044_c12 {
    +       adi,extended-name = "FPGA_CLK";
    +       adi,divider = <6>;      // 491.52 MHz
    With this configuration the link will come up.
      (DEVICES) Found 1 JESD204 Link Layer peripherals
      (0): axi-jesd204-tx/84a90000.axi-jesd204-tx  [*]
      (STATUS)
      Link is                      enabled
      Link Status                  DATA
      Measured Link Clock (MHz)    245.779
      Reported Link Clock (MHz)    245.760
      Measured Device Clock (MHz)  245.779
      Reported Device Clock (MHz)  245.760
      Desired Device Clock (MHz)   245.760
      Lane rate (MHz)              9830.400
      Lane rate / 40 (MHz)         245.760
      LMFC rate (MHz)              15.360
      SYSREF captured              Yes
      SYSREF alignment error       No
      SYNC~                        deasserted
    Some more info below:
    [    5.041074] cf_axi_dds 84a04000.axi-ad9172-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A04000 mapped to 0x(____ptrval____), probed DDS AD917x
    [    5.055863] axi_adxcvr 84a60000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.05.a) using QPLL on GTH4 at 0x84A60000. Number of lanes: 4.
    [    5.067452] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition initialized -> probed
    [    5.085409] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition probed -> idle
    [    5.095505] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition idle -> device_init
    [    5.106041] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition device_init -> link_init
    [    5.117012] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition link_init -> link_supported
    [    5.133829] hmc7044 spi1.0: hmc7044_jesd204_link_pre_setup: Link0 forcing continuous SYSREF mode
    [    5.146969] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition link_supported -> link_pre_setup
    [    5.173674] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition link_pre_setup -> clk_sync_stage1
    [    5.185423] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition clk_sync_stage1 -> clk_sync_stage2
    [    5.197251] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition clk_sync_stage2 -> clk_sync_stage3
    [    5.211091] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition clk_sync_stage3 -> link_setup
    [    5.222482] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition link_setup -> opt_setup_stage1
    [    5.233967] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition opt_setup_stage1 -> opt_setup_stage2
    [    5.245975] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition opt_setup_stage2 -> opt_setup_stage3
    [    5.257977] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition opt_setup_stage3 -> opt_setup_stage4
    [    5.269980] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition opt_setup_stage4 -> opt_setup_stage5
    [    5.281987] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition opt_setup_stage5 -> clocks_enable
    [    5.294100] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition clocks_enable -> link_enable
    [    5.316762] ad9172 spi1.1: Link0 code_grp_sync: f
    [    5.321459] ad9172 spi1.1: Link0 frame_sync_stat: f
    [    5.326328] ad9172 spi1.1: Link0 good_checksum_stat: f
    [    5.331457] ad9172 spi1.1: Link0 init_lane_sync_stat: f
    [    5.336674] ad9172 spi1.1: Link0 4 lanes @ 9830400 kBps
    [    5.341891] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition link_enable -> link_running
    [    5.353721] jesd204: /axi/spi@ff040000/ad9172@1,jesd204:1,parent=spi1.1: JESD204[0:0] transition link_running -> opt_post_running_stage
    [    5.365909] axi-jesd204-tx 84a90000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a) at 0x84A90000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm.
    root@analog:~# cat /sys/kernel/debug/clk/clk_summary
                                     enable  prepare  protect                                duty         hardware
       clock                          count    count    count        rate   accuracy phase  cycle  nshot    enable
     clkin2_0                             0        0        0           0          0     0  50000        0
             Y
     clkin1_0                             0        0        0           0          0     0  50000        0
             Y
     si570_mgt                            0        0        0   148499999          0     0  50000        0
             Y
     si570_user                           0        0        0   299999999          0     0  50000        0
             Y
     hmc7044_out13                        0        0        0     1920000          0     0  50000        0
             Y
     hmc7044_out12                        3        3        1   491520000          0     0  50000        0
             Y
        tx_out_clk                        1        1        0   245760000          0     0  50000        0
             Y
        dac_gt_clk                        1        1        1     9830400          0     0  50000        0
     hmc7044_out3                         0        0        0     1920000          0     0  50000        0
             Y
     hmc7044_out2                         1        1        0   368640000          0     0  50000        0
    root@analog:~# iio_info
    iio_info version: 0.25 (git tag:8fb78e06)
    Libiio version: 0.25 (git tag: 8fb78e0) backends: local xml ip usb serial
    Backend version: 0.25 (git tag: 8fb78e0)
    Backend description string: Linux analog 5.15.0-20997-g527d7b34564d-dirty #3427 SMP Wed Jan 17 09:23:28 CET 2024 aarch64
    IIO context has 10 attributes:
            hdl_system_id: [dac_fmc_ebz] [AD9172 - 04] on [zcu102] git branch [hdl_2022_r2] git [b31d4fbba87a96f329f858da3118771503c7c6b4] clean [2023-11-01 17:22:20] UTC
            hw_model: AD9172-FMC-EBZ on ZynqMP ZCU102 Rev1.0
            hw_carrier: ZynqMP ZCU102 Rev1.0
            hw_mezzanine: AD9172-FMC-EBZ
            hw_name: AD9172-FMC-EBZ
            hw_vendor: Analog Devices
            hw_serial: Empty Field
            unique_id: aaed04000519000b00d7f8bfc576
            local,kernel: 5.15.0-20997-g527d7b34564d-dirty
            uri: local:
    IIO context has 24 devices:
            hwmon0: ina226
                    4 channels found:
                            in0:  (input)
                                    attr  0: crit value: 0
                                    attr  1: crit_alarm value: 0
                                    attr  2: input value: 7
                                    attr  3: lcrit value: 0
                                    attr  4: lcrit_alarm value: 0
                            power1:  (input)
                                    attr  2: input value: 1225000
                            in1:  (input)
                                    attr  2: input value: 848
                            curr1:  (input)
                            1 channel-specific attributes found:
                                    attr  0: input value: 1446
                                    attr  0: shunt_resistor value: 5000
                                    attr  1: update_interval value: 35
            hwmon1: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                                    attr  2: input value: 250000
                            in1:  (input)
                                    attr  2: input value: 845
                            curr1:  (input)
                                    attr  0: input value: 292
            hwmon10: ina226
                    4 channels found:
                            in0:  (input)
                                    attr  2: input value: 3
                            power1:  (input)
                                    attr  2: input value: 1375000
                            in1:  (input)
                                    attr  2: input value: 844
                            curr1:  (input)
                                    attr  0: input value: 1611
                                    attr  0: shunt_resistor value: 2000
            hwmon11: ina226
                    4 channels found:
                            in0:  (input)
                                    attr  2: input value: 0
                            power1:  (input)
                            in1:  (input)
                                    attr  2: input value: 849
                            curr1:  (input)
                                    attr  0: input value: 31
            hwmon12: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                                    attr  2: input value: 287500
                            in1:  (input)
                                    attr  2: input value: 1795
                            curr1:  (input)
                                    attr  0: input value: 164
            hwmon13: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                                    attr  2: input value: 12500
                            in1:  (input)
                                    attr  2: input value: 1201
                            curr1:  (input)
                                    attr  0: input value: 9
            hwmon14: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                                    attr  2: input value: 125000
                            in1:  (input)
                                    attr  2: input value: 3298
                            curr1:  (input)
                                    attr  0: input value: 38
            hwmon15: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                                    attr  2: input value: 1798
                            curr1:  (input)
            hwmon16: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                                    attr  2: input value: 550000
                            in1:  (input)
                                    attr  2: input value: 900
                            curr1:  (input)
                                    attr  0: input value: 606
            hwmon17: ina226
                    4 channels found:
                            in0:  (input)
                                    attr  2: input value: 4
                            power1:  (input)
                                    attr  2: input value: 1050000
                            in1:  (input)
                                    attr  2: input value: 1196
                            curr1:  (input)
                                    attr  0: input value: 880
            hwmon18: max20751
                    5 channels found:
                            in2:  (input)
                            8 channel-specific attributes found:
                                    attr  0: input value: 900
                                    attr  1: label value: vout1
                                    attr  2: lcrit value: 765
                                    attr  3: lcrit_alarm value: 0
                                    attr  4: max value: 1000
                                    attr  5: max_alarm value: 0
                                    attr  6: min value: 855
                                    attr  7: min_alarm value: 0
                            curr1:  (input)
                                    attr  0: input value: 500
                                    attr  1: label value: iout1
                                    attr  2: max value: 511500
                                    attr  3: max_alarm value: 0
                            in1:  (input)
                            7 channel-specific attributes found:
                                    attr  0: alarm value: 0
                                    attr  1: crit value: 15000
                                    attr  2: input value: 11906
                                    attr  3: label value: vin
                                    attr  4: lcrit value: 4687
                                    attr  5: max value: 14906
                                    attr  6: min value: 4750
                            power1:  (input)
                                    attr  0: input value: 0
                                    attr  1: label value: pout1
                            temp1:  (input)
                                    attr  0: crit value: 133000
                                    attr  2: input value: 48000
                                    attr  3: max value: 130000
                                    attr  4: max_alarm value: 0
                                    attr  5: min value: -40000
                                    attr  6: min_alarm value: 0
            hwmon19: max20751
                    5 channels found:
                            in2:  (input)
                                    attr  0: input value: 1200
                                    attr  2: lcrit value: 1100
                                    attr  4: max value: 1375
                                    attr  6: min value: 1140
                            curr1:  (input)
                                    attr  0: input value: 1000
                            in1:  (input)
                                    attr  2: input value: 11937
                            power1:  (input)
                                    attr  0: input value: 2000000
                            temp1:  (input)
                                    attr  2: input value: 40000
            hwmon2: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                                    attr  2: input value: 1815
                            curr1:  (input)
                                    attr  0: input value: 11
            hwmon3: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                                    attr  2: input value: 37500
                            in1:  (input)
                                    attr  2: input value: 1200
                            curr1:  (input)
                                    attr  0: input value: 34
            hwmon4: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
                                    attr  0: input value: 59
            hwmon5: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                                    attr  2: input value: 1819
                            curr1:  (input)
            hwmon6: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                                    attr  2: input value: 187500
                            in1:  (input)
                                    attr  2: input value: 1194
                            curr1:  (input)
                                    attr  0: input value: 153
            hwmon7: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                                    attr  2: input value: 1796
                            curr1:  (input)
                                    attr  0: input value: 17
            hwmon8: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                                    attr  2: input value: 1808
                            curr1:  (input)
            hwmon9: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                                    attr  2: input value: 1813
                            curr1:  (input)
                                    attr  0: input value: 24
            iio:device0: ams
                    30 channels found:
                                    attr  0: label value: vccpsintfpddr
                                    attr  1: raw value: 18426
                                    attr  2: scale value: 0.045776367
                                    attr  0: label value: vccint
                                    attr  1: raw value: 18427
                                    attr  0: label value: vccpsio2
                                    attr  1: raw value: 19450
                                    attr  2: scale value: 0.091552734
                                    attr  0: label value: psmgtravtt
                                    attr  1: raw value: 39676
                                    attr  0: label value: vccplintlp
                                    attr  1: raw value: 18422
                                    attr  0: label value: vcc_pspll0
                                    attr  1: raw value: 26133
                                    attr  1: raw value: 18506
                                    attr  0: label value: vccbram
                                    attr  1: raw value: 18540
                                    attr  0: label value: vccams
                                    attr  1: raw value: 39110
                                    attr  2: scale value: 0.015258789
                                    attr  0: label value: remote_temp
                                    attr  1: offset value: -36058
                                    attr  2: raw value: 40662
                                    attr  3: scale value: 7.771514892
                                    attr  0: label value: vccpsaux
                                    attr  1: raw value: 39630
                                    attr  0: label value: vccplaux
                                    attr  1: raw value: 39636
                                    attr  0: label value: psmgtravcc
                                    attr  0: label value: ps_temp
                                    attr  2: raw value: 40824
                                    attr  0: label value: vccvrefn
                                    attr  1: raw value: 18437
                                    attr  0: label value: vcc_psddrpll
                                    attr  1: raw value: 39519
                                    attr  0: label value: vccpsintlp
                                    attr  1: raw value: 18431
                                    attr  0: label value: vccpsio3
                                    attr  1: raw value: 19619
                                    attr  0: label value: pl_temp
                                    attr  2: raw value: 40796
                                    attr  0: label value: vccpsio1
                                    attr  1: raw value: 19458
                                    attr  1: raw value: 18514
                                    attr  0: label value: vccaux
                                    attr  1: raw value: 39160
                                    attr  0: label value: vccpsio0
                                    attr  1: raw value: 19456
                                    attr  0: label value: vccplintfp
                                    attr  1: raw value: 18436
                                    attr  0: label value: vccpsddr
                                    attr  1: raw value: 25991
                                    attr  0: label value: vcc_psbatt
                                    attr  1: raw value: 30853
                                    attr  1: raw value: 39232
                                    attr  1: raw value: 39572
                                    attr  0: label value: vccvrefp
                                    attr  1: raw value: 27289
                    4 channels found:
                                    attr  1: label value: DAC_SYSREF
                                    attr  2: phase value: 0.000000
                                    attr  1: label value: DAC_CLK
                                    attr  0: frequency value: 491520000
                                    attr  1: label value: FPGA_CLK
                                    attr  1: label value: FPGA_SYSREF
                    15 channels found:
                            6 channel-specific attributes found:
                                    attr  1: label value: TX1_Q_F2
                                    attr  3: raw value: 1
                                    attr  4: sampling_frequency value: 491520000
                                    attr  5: scale value: 0.250000
                                    attr  1: label value: TX2_I_F2
                                    attr  2: phase value: 90000
                                    attr  0: enable value: 1
                                    attr  1: label value: TX1_Q_F1
                                    attr  1: label value: TX1_I_F2
                                    attr  1: label value: TX2_Q_F2
                                    attr  1: label value: TX2_I_F1
                                    attr  1: label value: TX1_I_F1
                                    attr  1: label value: TX2_Q_F1
            iio_sysfs_trigger:
                    0 channels found:
    root@analog:~#
    -Michael
Reply
    @@ -7,7 +7,7 @@
    +&hmc7044_c12 {
      (STATUS)
      Link is                      enabled
      Link Status                  DATA
      SYSREF captured              Yes
      SYNC~                        deasserted
             Y
             Y
             Y
             Y
             Y
             Y
             Y
             Y
            uri: local:
            hwmon0: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon1: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon10: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon11: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon12: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon13: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon14: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon15: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon16: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon17: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon18: max20751
                    5 channels found:
                            in2:  (input)
                            curr1:  (input)
                            in1:  (input)
                            power1:  (input)
                            temp1:  (input)
            hwmon19: max20751
                    5 channels found:
                            in2:  (input)
                            curr1:  (input)
                            in1:  (input)
                            power1:  (input)
                            temp1:  (input)
            hwmon2: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon3: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon4: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon5: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon6: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon7: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon8: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            hwmon9: ina226
                    4 channels found:
                            in0:  (input)
                            power1:  (input)
                            in1:  (input)
                            curr1:  (input)
            iio:device0: ams
                    30 channels found:
                    4 channels found:
                    15 channels found:
            iio_sysfs_trigger:
                    0 channels found:
    root@analog:~#
    -Michael
Children
No Data
