ZC702 ADV7511 DRM Driver Problem - failed to load driver: axi_hdmi_drm
Product Number: meta-adi
Software Version: 2021.2
  • Vivado Version: 2021.2
  • HDL branch: hdl_2021_r1
  • Vivado Project: hdl-master\projects\adv7511\zc702
  • Petalinux version: 2021.2
  • META-ADI branch: 2021_R1
  • OS : Ubuntu 20.04.4 LTS
I am using ZC702 evaluation board with ADV7511. I am building a petalinux 2021.2 with the meta-adi layers for zynq-zc702-adv7511.
I can run HDMI video on ZC702 via ADV7511. But I have a problem axi_hdmi_drm driver. Xorg cannot find the axi_hdmi_drm driver under /usr/lib/dri. Doesn't libgl support analog devices driver?
MESA-LOADER: failed to open axi_hdmi_drm (search paths /usr/lib/dri)
libGL error: MESA-LOADER: failed to open axi_hdmi_drm (search paths /usr/lib/dri)
libGL error: failed to load driver: axi_hdmi_drm
Although there is an image at the HDMI output, dma-buf is empty.
I enable the modesetting driver the create /etc/X11/xorg.conf and add following lines:
Section "Device"
 Identifier "ADV7511 HDMI"
 Driver "modesetting"
EndSection
But as you can see in the dmesg messages, drm initialization seems to be correct.
My dmesg output for drm:
root@lyb_fmzrg_petalinux:~# dmesg | grep hdmi*
[   18.123071] [drm] Initialized axi_hdmi_drm 1.0.0 20120930 for 70e00000.axi_hdmi on minor 0
[   18.261289] axi-hdmi 70e00000.axi_hdmi: [drm] fb0: axi_hdmi_drmdrm frame buffer device
My /var/log/Xorg.0.log output for drm:
My /var/log/Xorg.0.log full output:
root@lyb_fmzrg_petalinux:~# cat /var/log/Xorg.0.log
[    26.440]
X.Org X Server 1.20.9
X Protocol Version 11, Revision 0
[    26.440] Build Operating System: Linux
[    26.440] Current Operating System: Linux lyb_fmzrg_petalinux 5.10.0-xilinx-v2021.2 #1 SMP PREEMPT Mon Feb 6 12:44:01 UTC 2023 armv7l
[    26.441] Kernel command line: console=ttyPS0,115200 earlycon root=/dev/ram0 rw
[    26.441] Build Date: 25 August 2020  03:40:19PM
[    26.441]
[    26.441] Current version of pixman: 0.40.0
[    26.441]    Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
[    26.441] Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    26.441] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Mar  9 12:35:01 2018
[    26.442] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    26.443] (==) No Layout section.  Using the first Screen section.
[    26.443] (==) No screen section available. Using defaults.
[    26.443] (**) |-->Screen "Default Screen Section" (0)
[    26.443] (**) |   |-->Monitor "<default monitor>"
[    26.444] (==) No monitor specified for screen "Default Screen Section".
        Using a default monitor configuration.
[    26.444] (==) Automatically adding devices
[    26.444] (==) Automatically enabling devices
[    26.444] (==) Automatically adding GPU devices
[    26.444] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    26.444] (WW) The directory "/usr/share/fonts/X11/misc/" does not exist.
[    26.444]    Entry deleted from font path.
[    26.444] (WW) The directory "/usr/share/fonts/X11/TTF/" does not exist.
[    26.444] (WW) The directory "/usr/share/fonts/X11/OTF/" does not exist.
[    26.445] (WW) The directory "/usr/share/fonts/X11/Type1/" does not exist.
[    26.445]    Entry deleted from font path.
[    26.445] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    26.445] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    26.445] (==) FontPath set to:
[    26.445] (==) ModulePath set to "/usr/lib/xorg/modules"
[    26.445] (II) The server relies on udev to provide the list of input devices.
        If no devices become available, reconfigure udev or disable AutoAddDevices.
[    26.445] (II) Loader magic: 0x558d48
[    26.445] (II) Module ABI versions:
[    26.445]    X.Org ANSI C Emulation: 0.4
[    26.445]    X.Org Video Driver: 24.1
[    26.445]    X.Org XInput driver : 24.1
[    26.445]    X.Org Server Extension : 10.0
[    26.446] (II) xfree86: Adding drm device (/dev/dri/card0)
[    26.446] (II) Platform probe for /sys/devices/soc0/fpga-axi@0/70e00000.axi_hdmi/drm/card0
[    26.459] (II) no primary bus or device found
[    26.459]    falling back to /sys/devices/soc0/fpga-axi@0/70e00000.axi_hdmi/drm/card0
[    26.459] (II) LoadModule: "glx"
[    26.460] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    26.475] (II) Module glx: vendor="X.Org Foundation"
[    26.475]    compiled for 1.20.9, module version = 1.0.0
[    26.475]    ABI class: X.Org Server Extension, version 10.0
[    26.475] (==) Matched modesetting as autoconfigured driver 0
[    26.475] (==) Matched fbdev as autoconfigured driver 1
[    26.475] (==) Assigned the driver to the xf86ConfigLayout
[    26.475] (II) LoadModule: "modesetting"
[    26.476] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    26.476] (II) Module modesetting: vendor="X.Org Foundation"
[    26.476]    compiled for 1.20.9, module version = 1.20.9
[    26.476]    Module class: X.Org Video Driver
[    26.476]    ABI class: X.Org Video Driver, version 24.1
[    26.477] (II) LoadModule: "fbdev"
[    26.477] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    26.477] (II) Module fbdev: vendor="X.Org Foundation"
[    26.478]    compiled for 1.20.9, module version = 0.5.0
[    26.478]    Module class: X.Org Video Driver
[    26.478]    ABI class: X.Org Video Driver, version 24.1
[    26.478] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    26.478] (II) FBDEV: driver for framebuffer: fbdev
[    26.478] (--) using VT number 2
[    26.483] (II) modeset(0): using drv /dev/dri/card0
[    26.483] (WW) Falling back to old probe method for fbdev
[    26.483] (II) Loading sub module "fbdevhw"
[    26.483] (II) LoadModule: "fbdevhw"
[    26.483] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    26.484] (II) Module fbdevhw: vendor="X.Org Foundation"
[    26.484]    compiled for 1.20.9, module version = 0.0.2
[    26.484]    ABI class: X.Org Video Driver, version 24.1
[    26.484] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    26.489] (II) modeset(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[    26.489] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[    26.489] (==) modeset(0): RGB weight 888
[    26.489] (==) modeset(0): Default visual is TrueColor
[    26.489] (II) Loading sub module "glamoregl"
[    26.489] (II) LoadModule: "glamoregl"
[    26.490] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    26.522] (II) Module glamoregl: vendor="X.Org Foundation"
[    26.522]    compiled for 1.20.9, module version = 1.0.1
[    26.522]    ABI class: X.Org ANSI C Emulation, version 0.4
[    26.760] (II) modeset(0): glamor X acceleration enabled on softpipe
[    26.760] (II) modeset(0): glamor initialized
[    26.793] (II) modeset(0): Output HDMI-1 has no monitor section
[    26.799] (II) modeset(0): EDID for output HDMI-1
[    26.799] (II) modeset(0): Manufacturer: HWP  Model: 3281  Serial#: 16843009
[    26.799] (II) modeset(0): Year: 2016  Week: 13
[    26.799] (II) modeset(0): EDID Version: 1.3
[    26.799] (II) modeset(0): Digital Display Input
[    26.799] (II) modeset(0): Max Image Size [cm]: horiz.: 48  vert.: 27
[    26.799] (II) modeset(0): Gamma: 2.20
[    26.800] (II) modeset(0): DPMS capabilities: Off
[    26.800] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    26.800] (II) modeset(0): First detailed timing is preferred mode
[    26.800] (II) modeset(0): redX: 0.651 redY: 0.338   greenX: 0.318 greenY: 0.612
[    26.800] (II) modeset(0): blueX: 0.151 blueY: 0.065   whiteX: 0.313 whiteY: 0.329
[    26.800] (II) modeset(0): Supported established timings:
[    26.800] (II) modeset(0): 640x480@60Hz
[    26.800] (II) modeset(0): 800x600@60Hz
[    26.800] (II) modeset(0): 1024x768@60Hz
[    26.800] (II) modeset(0): Manufacturer's mask: 0
[    26.800] (II) modeset(0): Supported standard timings:
[    26.800] (II) modeset(0): #0: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[    26.800] (II) modeset(0): #1: hsize: 1280  vsize 720  refresh: 60  vid: 49281
[    26.800] (II) modeset(0): #2: hsize: 1600  vsize 900  refresh: 60  vid: 49321
[    26.800] (II) modeset(0): #3: hsize: 1440  vsize 900  refresh: 60  vid: 149
[    26.800] (II) modeset(0): #4: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[    26.800] (II) modeset(0): #5: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[    26.800] (II) modeset(0): #6: hsize: 1280  vsize 800  refresh: 60  vid: 129
[    26.800] (II) modeset(0): Supported detailed timing:
[    26.800] (II) modeset(0): clock: 148.5 MHz   Image Size:  476 x 268 mm
[    26.800] (II) modeset(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[    26.800] (II) modeset(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[    26.800] (II) modeset(0): Ranges: V min: 50 V max: 60 Hz, H min: 30 H max: 80 kHz, PixClock max 175 MHz
[    26.800] (II) modeset(0): Monitor name: HP Z22n
[    26.800] (II) modeset(0): Serial No: 6CM613134Z
[    26.801] (II) modeset(0): Supported detailed timing:
[    26.801] (II) modeset(0): clock: 148.5 MHz   Image Size:  476 x 268 mm
[    26.801] (II) modeset(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2640 h_border: 0
[    26.801] (II) modeset(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[    26.801] (II) modeset(0): Number of EDID sections to follow: 1
[    26.801] (II) modeset(0): EDID (in hex):
[    26.801] (II) modeset(0):   00ffffffffffff0022f0813201010101
[    26.801] (II) modeset(0):   0d1a010380301b782aebf5a656519c26
[    26.801] (II) modeset(0):   105054210800d1c081c0a9c09500b300
[    26.801] (II) modeset(0):   818081000101023a801871382d40582c
[    26.801] (II) modeset(0):   4500dc0c1100001e000000fd00323c1e
[    26.801] (II) modeset(0):   5011000a202020202020000000fc0048
[    26.801] (II) modeset(0):   50205a32326e0a2020202020000000ff
[    26.801] (II) modeset(0):   0036434d3631333133345a0a2020012e
[    26.801] (II) modeset(0):   020319b149901f041303021211016703
[    26.801] (II) modeset(0):   0c0010000022e2002b023a801871382d
[    26.801] (II) modeset(0):   40582c4500dc0c1100001e023a80d072
[    26.801] (II) modeset(0):   382d40582c4500dc0c1100001e000000
[    26.801] (II) modeset(0):   00000000000000000000000000000000
[    26.801] (II) modeset(0):   000000000000000000000000000000f7
[    26.802] (--) modeset(0): HDMI max TMDS frequency 170000KHz
[    26.802] (II) modeset(0): Printing probed modes for output HDMI-1
[    26.802] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    26.802] (II) modeset(0): Modeline "1920x1080"x50.0  148.50  1920 2008 2052 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    26.802] (II) modeset(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    26.802] (II) modeset(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[    26.802] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    26.802] (II) modeset(0): Modeline "1600x900"x60.0  108.00  1600 1624 1704 1800  900 901 904 1000 +hsync +vsync (60.0 kHz e)
[    26.802] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    26.802] (II) modeset(0): Modeline "1440x900"x59.9   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[    26.802] (II) modeset(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[    26.802] (II) modeset(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    26.802] (II) modeset(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    26.802] (II) modeset(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    26.802] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    26.802] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    26.802] (II) modeset(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    26.802] (II) modeset(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    26.803] (II) modeset(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    26.803] (II) modeset(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    26.803] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    26.803] (II) modeset(0): Output HDMI-1 connected
[    26.803] (II) modeset(0): Using exact sizes for initial modes
[    26.803] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0
[    26.803] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    26.803] (==) modeset(0): DPI set to (96, 96)
[    26.803] (II) Loading sub module "fb"
[    26.803] (II) LoadModule: "fb"
[    26.803] (II) Loading /usr/lib/xorg/modules/libfb.so
[    26.805] (II) Module fb: vendor="X.Org Foundation"
[    26.805]    compiled for 1.20.9, module version = 1.0.0
[    26.805]    ABI class: X.Org ANSI C Emulation, version 0.4
[    26.805] (II) UnloadModule: "fbdev"
[    26.805] (II) Unloading fbdev
[    26.805] (II) UnloadSubModule: "fbdevhw"
[    26.805] (II) Unloading fbdevhw
[    27.069] (==) modeset(0): Backing store enabled
[    27.069] (==) modeset(0): Silken mouse enabled
[    27.070] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    27.070] (==) modeset(0): DPMS enabled
[    27.071] (II) modeset(0): [DRI2] Setup complete
[    27.071] (II) modeset(0): [DRI2]   DRI driver: kms_swrast
[    27.071] (II) modeset(0): [DRI2]   VDPAU driver: kms_swrast
[    27.071] (II) Initializing extension Generic Event Extension
[    27.071] (II) Initializing extension SHAPE
[    27.071] (II) Initializing extension MIT-SHM
[    27.071] (II) Initializing extension XInputExtension
[    27.071] (II) Initializing extension XTEST
[    27.071] (II) Initializing extension BIG-REQUESTS
[    27.071] (II) Initializing extension SYNC
[    27.071] (II) Initializing extension XKEYBOARD
[    27.072] (II) Initializing extension XC-MISC
[    27.072] (II) Initializing extension XFIXES
[    27.072] (II) Initializing extension RENDER
[    27.072] (II) Initializing extension RANDR
[    27.072] (II) Initializing extension COMPOSITE
[    27.072] (II) Initializing extension DAMAGE
[    27.072] (II) Initializing extension MIT-SCREEN-SAVER
[    27.072] (II) Initializing extension DOUBLE-BUFFER
[    27.072] (II) Initializing extension DPMS
[    27.072] (II) Initializing extension Present
[    27.072] (II) Initializing extension DRI3
[    27.072] (II) Initializing extension X-Resource
[    27.072] (II) Initializing extension XVideo
[    27.072] (II) Initializing extension XVideo-MotionCompensation
[    27.072] (II) Initializing extension GLX
[    27.094] (II) AIGLX: Loaded and initialized kms_swrast
[    27.094] (II) GLX: Initialized DRI2 GL provider for screen 0
[    27.094] (II) Initializing extension XFree86-VidModeExtension
[    27.094] (II) Initializing extension XFree86-DGA
[    27.094] (II) Initializing extension XFree86-DRI
[    27.094] (II) Initializing extension DRI2
[    27.100] (II) modeset(0): Damage tracking initialized
[    27.100] (II) modeset(0): Setting screen physical size to 508 x 285
[    29.839] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    29.839] (==) modeset(0): DPMS enabled
[    29.840] (II) modeset(0): [DRI2] Setup complete
[    29.840] (II) modeset(0): [DRI2]   DRI driver: kms_swrast
[    29.840] (II) modeset(0): [DRI2]   VDPAU driver: kms_swrast
[    29.840] (II) Initializing extension Generic Event Extension
[    29.840] (II) Initializing extension SHAPE
[    29.840] (II) Initializing extension MIT-SHM
[    29.840] (II) Initializing extension XInputExtension
[    29.840] (II) Initializing extension XTEST
[    29.840] (II) Initializing extension BIG-REQUESTS
[    29.840] (II) Initializing extension SYNC
[    29.840] (II) Initializing extension XKEYBOARD
[    29.840] (II) Initializing extension XC-MISC
[    29.840] (II) Initializing extension XFIXES
[    29.840] (II) Initializing extension RENDER
[    29.840] (II) Initializing extension RANDR
[    29.840] (II) Initializing extension COMPOSITE
[    29.840] (II) Initializing extension DAMAGE
[    29.841] (II) Initializing extension MIT-SCREEN-SAVER
[    29.841] (II) Initializing extension DOUBLE-BUFFER
[    29.841] (II) Initializing extension DPMS
[    29.841] (II) Initializing extension Present
[    29.841] (II) Initializing extension DRI3
[    29.841] (II) Initializing extension X-Resource
[    29.841] (II) Initializing extension XVideo
[    29.841] (II) Initializing extension XVideo-MotionCompensation
[    29.841] (II) Initializing extension GLX
[    29.863] (II) AIGLX: Loaded and initialized kms_swrast
[    29.863] (II) GLX: Initialized DRI2 GL provider for screen 0
[    29.863] (II) Initializing extension XFree86-VidModeExtension
[    29.863] (II) Initializing extension XFree86-DGA
[    29.863] (II) Initializing extension XFree86-DRI
[    29.863] (II) Initializing extension DRI2
[    29.864] (II) modeset(0): Damage tracking initialized
[    29.864] (II) modeset(0): Setting screen physical size to 508 x 285
[    31.788] (II) modeset(0): EDID vendor "HWP", prod id 12929
[    31.788] (II) modeset(0): Using EDID range info for horizontal sync
[    31.788] (II) modeset(0): Using EDID range info for vertical refresh
[    31.788] (II) modeset(0): Printing DDC gathered Modelines:
[    31.788] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    31.788] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    31.788] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    31.788] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    31.788] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    31.788] (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    31.788] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    31.788] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    31.788] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    31.788] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    31.788] (II) modeset(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
[    31.789] (II) modeset(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[    31.789] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    31.789] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    31.789] (II) modeset(0): Modeline "1280x800"x0.0   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[    31.789] (--) modeset(0): HDMI max TMDS frequency 170000KHz
[    31.809] (II) modeset(0): EDID vendor "HWP", prod id 12929
[    31.810] (II) modeset(0): Using hsync ranges from config file
[    31.810] (II) modeset(0): Using vrefresh ranges from config file
[    31.810] (II) modeset(0): Printing DDC gathered Modelines:
[    31.810] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    31.810] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    31.810] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    31.810] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    31.810] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    31.810] (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    31.810] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    31.810] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    31.810] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    31.810] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    31.811] (II) modeset(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
[    31.811] (II) modeset(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[    31.811] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    31.811] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    31.811] (II) modeset(0): Modeline "1280x800"x0.0   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[    31.812] (--) modeset(0): HDMI max TMDS frequency 170000KHz
[    32.019] (II) modeset(0): EDID vendor "HWP", prod id 12929
[    32.019] (II) modeset(0): Using hsync ranges from config file
[    32.019] (II) modeset(0): Using vrefresh ranges from config file
[    32.019] (II) modeset(0): Printing DDC gathered Modelines:
[    32.019] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    32.019] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    32.019] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    32.019] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    32.019] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    32.019] (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    32.019] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    32.019] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    32.019] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    32.019] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    32.020] (II) modeset(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
[    32.020] (II) modeset(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[    32.020] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    32.020] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    32.020] (II) modeset(0): Modeline "1280x800"x0.0   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[    32.021] (--) modeset(0): HDMI max TMDS frequency 170000KHz
[    32.022] (II) modeset(0): Allocate new frame buffer 1024x768 stride
[    33.388] (II) modeset(0): Disabling kernel dirty updates, not required.
Parents Reply Children
No Data
