Error while setting values to DAC in CN0554
Product Number: EVAL-CN0554-RPIZ
Software Version: pyadi-iio 0.0.16, pylibiio 0.23.1
I am getting the following error when I write to the DAC in EVAL-CN0554-RP1Z connected to RPi 4B via the GPIO ports. I am able to connect to the device and read ADC values.
Command issued:  cn_obj.volt = vset[2 * a].   [from the cn0554_example.py]
ERROR: READ LINE: -32
Traceback (most recent call last):
  File "/home/analog/Downloads/cn0554_example.py", line 46, in <module>
  File "/home/analog/.local/lib/python3.9/site-packages/adi/ltc2688.py", line 96, in volt
    self.raw = int(((val / self.scale) - self.offset) * (ltc2688.vref / 4.096))
  File "/home/analog/.local/lib/python3.9/site-packages/adi/ltc2688.py", line 45, in scale
    return self._get_iio_attr(self.name, "scale", True, self._ctrl)
  File "/home/analog/.local/lib/python3.9/site-packages/adi/attribute.py", line 127, in _get_iio_attr
    self._get_iio_attr_str(channel_name, attr_name, output, _ctrl)
  File "/home/analog/.local/lib/python3.9/site-packages/adi/attribute.py", line 122, in _get_iio_attr_str
    return channel.attrs[attr_name].value
  File "/usr/local/lib/python3.9/dist-packages/iio.py", line 711, in <lambda>
    lambda self: self._read(),
  File "/usr/local/lib/python3.9/dist-packages/iio.py", line 740, in _read
    _c_read_attr(self._channel, self._name_ascii, buf, len(buf))
  File "/usr/local/lib/python3.9/dist-packages/iio.py", line 62, in _check_negative
    raise OSError(-result, _strerror(-result))
BrokenPipeError: [Errno 32] Broken pipe
Some information regarding the setup
I am on Kuiper linux
analog@analog:~/Downloads $
Linux analog 5.10.63-v7l+ #1 SMP Fri Mar 10 16:35:58 UTC 2023 armv7l GNU/Linux
Highly appreciate any help in this regards
Thanking you
Krishna
  • After some searches, I had put in a dev rule to change the permissions. Now the /dev/iio:device and the linked director spi0.1 are owned by iio. Still no luck. osc says, need root permission to change registers and python codes give permission errors.
    analog@analog:~ $ ls -al /sys/devices/platform/soc/fe204000.spi/spi_master/spi0/
    total 0
    drwxr-xr-x 6 root root    0 Nov 24 11:36 .
    drwxr-xr-x 3 root root    0 Nov 24 11:36 ..
    lrwxrwxrwx 1 root root    0 Nov 24 11:39 device -> ../../../fe204000.spi
    lrwxrwxrwx 1 root root    0 Nov 24 11:39 of_node -> ../../../../../../firmware/devicetree/base/soc/spi@7e204000
    drwxr-xr-x 2 root root    0 Nov 24 11:36 power
    drwxr-xr-x 6 root root    0 Nov 24 11:36 spi0.0
    drwxrwxr-x 5 root iio     0 Nov 24 11:36 spi0.1
    drwxr-xr-x 2 root root    0 Nov 24 11:36 statistics
    lrwxrwxrwx 1 root root    0 Nov 24 11:36 subsystem -> ../../../../../../class/spi_master
    -rw-r--r-- 1 root root 4096 Nov 24 11:36 uevent
  • Can you go to the IIO device under /sys/bus/iio/devices/iio:deviceX and check and control the attributes from there.
    What error do you get?
    -Michael
