Hello Everyone,
Our team is currently working with the ADRV9009 and manages two FPGA boards: A10GX and ZCU102.
For the ADRV9009 and A10GX interface, we have followed the detailed instructions outlined on the ADI website. However, we encountered an error: "ERROR: 294: TALISE_waitArmCmdStatus() failed due to thrown ARM error". The complete log for the ADRV9009 and A10GX issue is attached below.
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-BlasterII [USB-1]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Linux version 4.19.0-g17f4223 (jenkins@romlxbuild1.adlk.analog.com) (gcc version 8.3.1 20190416 (Altera 19.3 Build 222)) #1876 Tue Jul 27 14:47:24 IST 2021
On node 0 totalpages: 65536
Normal zone: 512 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 65536 pages, LIFO batch:15
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists, mobility grouping on. Total pages: 65024
Kernel command line: debug console=ttyJ0,115200
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Sorting __ex_table...
Memory: 247876K/262144K available (3795K kernel code, 469K rwdata, 4372K rodata, 3176K init, 106K bss, 14268K reserved, 0K cma-reserved)
NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
clocksource: nios2-clksrc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=400000)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
devtmpfs: initialized
random: get_random_u32 called from bucket_table_alloc.isra.6+0x98/0x1e8 with crng_init=0
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
futex hash table entries: 256 (order: -1, 3072 bytes)
NET: Registered protocol family 16
jesd204: found 0 devices and 0 topologies
clocksource: Switched to clocksource nios2-clksrc
NET: Registered protocol family 2
tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
random: fast init done
workingset: timestamp_bits=30 max_order=16 bucket_order=0
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
io scheduler mq-deadline registered
io scheduler kyber registered
101814f0.serial: ttyJ0 at MMIO 0x101814f0 (irq = 2, base_baud = 0) is a Altera JTAG UART
console [ttyJ0] enabled
loop: module loaded
spi_altera 10181400.spi: base (ptrval), irq 8
libphy: Fixed MDIO Bus: probed
libphy: altera_tse: probed
altera_tse 10181000.ethernet (unnamed net_device) (uninitialized): MDIO bus altera_tse-0: created
altera_tse 10181000.ethernet: Altera TSE MAC version 19.5 at 0x10181000 irq 1/3
adrv9009 spi0.1: adrv9009_probe : enter
altera-a10-fpll 10056000.altera-a10-fpll: FPLL PLL calibration OK (1400 us)
altera-a10-fpll 10046000.altera-a10-fpll: FPLL PLL calibration OK (1400 us)
altera-a10-fpll 10026000.altera-a10-fpll: FPLL PLL calibration OK (1400 us)
altera_adxcvr 10024000.axi-adrv9009-tx-xcvr: ATX PLL calibration OK (20 ms)
altera_adxcvr 10024000.axi-adrv9009-tx-xcvr: Lane 0 TX termination and VOD calibration OK (500 us)
altera_adxcvr 10024000.axi-adrv9009-tx-xcvr: Lane 1 TX termination and VOD calibration OK (500 us)
altera_adxcvr 10024000.axi-adrv9009-tx-xcvr: Lane 2 TX termination and VOD calibration OK (400 us)
altera_adxcvr 10024000.axi-adrv9009-tx-xcvr: Lane 3 TX termination and VOD calibration OK (500 us)
altera_adxcvr 10024000.axi-adrv9009-tx-xcvr: Altera ADXCVR (17.01.a) probed
altera_adxcvr 10044000.axi-adrv9009-rx-xcvr: Lane 0 CDR/CMU PLL & RX offset calibration OK (500 us)
altera_adxcvr 10044000.axi-adrv9009-rx-xcvr: Lane 1 CDR/CMU PLL & RX offset calibration OK (500 us)
altera_adxcvr 10044000.axi-adrv9009-rx-xcvr: Altera ADXCVR (17.01.a) probed
altera_adxcvr 10054000.axi-adrv9009-rx-os-xcvr: Lane 0 CDR/CMU PLL & RX offset calibration OK (500 us)
altera_adxcvr 10054000.axi-adrv9009-rx-os-xcvr: Lane 1 CDR/CMU PLL & RX offset calibration OK (600 us)
altera_adxcvr 10054000.axi-adrv9009-rx-os-xcvr: Altera ADXCVR (17.01.a) probed
altera_adxcvr 10024000.axi-adrv9009-tx-xcvr: Setting link rate to 61440000 (lane rate: 2457600)
altera_adxcvr 10044000.axi-adrv9009-rx-xcvr: Setting link rate to 122880000 (lane rate: 4915200)
altera_adxcvr 10054000.axi-adrv9009-rx-os-xcvr: Setting link rate to 122880000 (lane rate: 4915200)
altera_adxcvr 10054000.axi-adrv9009-rx-os-xcvr: Lane 1 CDR/CMU PLL & RX offset calibration OK (500 us)
adrv9009 spi0.1: ADIHAL_resetHw
altera_adxcvr 10054000.axi-adrv9009-rx-os-xcvr: Setting link rate to 61440000 (lane rate: 2457600)
random: crng init done
adrv9009 spi0.1: ERROR: 294: TALISE_waitArmCmdStatus() failed due to thrown ARM error. Is device in correct state for calling command?
adrv9009 spi0.1: ERROR: 131086: Talise init calibration error encountered
adrv9009 spi0.1: adrv9009_do_setup:784 (ret 6)
adrv9009: probe of spi0.1 failed with error -14
Freeing unused kernel memory: 3176K
This architecture does not have kernel memory protection.
Run /init as init process
Starting logging: OK
Initializing random number generator... done.
Starting network: OK
altera_tse 10181000.ethernet eth0: device MAC address b2:94:3d:6e:11:8f
altera_tse 10181000.ethernet eth0: TSE revision 1305
altera_tse 10181000.ethernet eth0: PCS PHY ID: 0x00000000
altera_tse 10181000.ethernet eth0: SGMII PCS block initialised OK
altera_tse 10181000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
Network cable is plugged
udhcpc: started, v1.25.0
udhcpc: sending discover
udhcpc: sending select for 130.65.150.80
udhcpc: lease of 130.65.150.80 obtained, lease time 172800
deleting routers
adding dns 10.10.90.50
adding dns 10.20.90.50
inet addr:130.65.150.80 Bcast:130.65.150.255 Mask:255.255.255.0
Starting dropbear sshd: OK
Starting IIO Server Daemon
Welcome to Buildroot
buildroot login: root
Password:
# ifconfig
eth0 Link encap:Ethernet HWaddr B2:94:3D:6E:11:8F
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:47 errors:0 dropped:24 overruns:0 frame:0
TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:7442 (7.2 KiB) TX bytes:684 (684.0 B)
Memory:10181000-101813ff
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
# cd /sys/bus/platform/devices
# ls
10020000.axi-jesd204-tx 10064000.axi-adrv9009-tx-hpc
10024000.axi-adrv9009-tx-xcvr 10068000.axi-adrv9009-rx-obs-hpc
10026000.altera-a10-fpll 10181000.ethernet
10032000.tx-dmac 10181400.spi
10040000.axi-jesd204-rx 10181420.timer
10044000.axi-adrv9009-rx-xcvr 101814c0.gpio
10046000.altera-a10-fpll 101814d0.gpio
1004c000.rx-dmac 101814e8.sysid
10050000.axi-jesd204-rx 101814f0.serial
10054000.axi-adrv9009-rx-os-xcvr 10181500.gpio
10056000.altera-a10-fpll 10181520.timer
1005c000.rx-obs-dmac Fixed MDIO bus.0
10060000.axi-adrv9009-rx-hpc alarmtimer
10060000.gpio sopc
# cd 10020000.axi-jesd204-tx
# cat status
Link is disabled
Measured Link Clock: 61.440 MHz
Reported Link Clock: 61.440 MHz
External reset is deasserted
# cd ../10040000.axi-jesd204-rx
# cat status
Link is disabled
Measured Link Clock: 122.881 MHz
Reported Link Clock: 122.880 MHz
# cd ../10050000.axi-jesd204-rx
# cat status
Link is disabled
During attempts to establish a connection with IIO Oscilloscope, only "iio:device0-ad9528-1" appears in the list of recognized devices. Other devices remain inaccessible.
For the ADRV9009 and ZCU102 integration, there is a same error: "ERROR: 247: TALISE_waitArmCmdStatus() failed due to thrown ARM error. ARM time out". The complete log for the ADRV9009 and ZCU102 connection issue is attached below.
Xilinx Zynq MP First Stage Boot Loader
Release 2021.2 Mar 31 2023 - 23:09:32
NOTICE: BL31: v2.6(release):xilinx-v2022.1-7-g38ee444bc
NOTICE: BL31: Built : 18:20:16, Sep 2 2022
PMUFW: v1.1
U-Boot 2018.01-21441-ga6ab387 (Aug 31 2022 - 11:47:19 +0100) Xilinx ZynqMP ZCU10 2 revA, Build: jenkins-development-build_uboot-2
I2C: ready
DRAM: 4 GiB
EL Level: EL2
Chip ID: zu9eg
MMC: sdhci@ff170000: 0 (SD)
*** Warning - bad CRC, using default environment
In: serial@ff000000
Out: serial@ff000000
Err: serial@ff000000
Bootmode: LVL_SHFT_SD_MODE1
Net: ZYNQ GEM: ff0e0000, phyaddr 15, interface rgmii-id
Warning: ethernet@ff0e0000 using MAC address from ROM
eth0: ethernet@ff0e0000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
Device: sdhci@ff170000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 119.1 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading uEnv.txt
407 bytes read in 19 ms (20.5 KiB/s)
Loaded environment from uEnv.txt
Importing environment from SD ...
Running uenvcmd ...
Copying Linux from SD to RAM...
** No boot file defined **
reading system.dtb
75482 bytes read in 29 ms (2.5 MiB/s)
reading Image
32715264 bytes read in 2156 ms (14.5 MiB/s)
## Flattened Device Tree blob at 04000000
Booting using the fdt blob at 0x4000000
Loading Device Tree to 000000000ffea000, end 000000000ffff6d9 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.10.0-98744-g64e7a607b659 (jenkins@romlxbuild1) (a arch64-xilinx-linux-gcc.real (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.0.20200730 ) #1789 SMP Fri Mar 31 17:23:38 EEST 2023
[ 0.000000] Machine model: ZynqMP ZCU102 Rev1.0
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] printk: bootconsole [cdns0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 256 MiB at 0x0000000070000000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff]
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] node 0: [mem 0x0000000800000000-0x000000087fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000087fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 22 pages/cpu s49496 r8192 d32424 u90112
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1034240
[ 0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlycon rootfstype=ext4 rootwait clk_ignore_unused cpuidle.off=1 root=/dev/mmc blk0p2 rw rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes , linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x000000003bfff000-0x000000003ffff00 0] (64MB)
[ 0.000000] Memory: 3761188K/4194304K available (15552K kernel code, 1676K rw data, 12112K rodata, 2496K init, 650K bss, 170972K reserved, 262144K cma-reserve d)
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jif fies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x31c/0x550 wit h crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 100.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171024e7e0, max_idle_ns: 440795205315 ns
[ 0.000004] sched_clock: 56 bits at 100MHz, resolution 10ns, wraps every 4398 046511100ns
[ 0.008478] Console: colour dummy device 80x25
[ 0.012483] Calibrating delay loop (skipped), value calculated using timer fr equency.. 200.00 BogoMIPS (lpj=400000)
[ 0.022840] pid_max: default: 32768 minimum: 301
[ 0.027559] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, line ar)
[ 0.034788] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.043440] rcu: Hierarchical SRCU implementation.
[ 0.047565] EFI services will not be available.
[ 0.051941] smp: Bringing up secondary CPUs ...
[ 0.056666] Detected VIPT I-cache on CPU1
[ 0.056707] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.057083] Detected VIPT I-cache on CPU2
[ 0.057108] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.057448] Detected VIPT I-cache on CPU3
[ 0.057471] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.057517] smp: Brought up 1 node, 4 CPUs
[ 0.091779] SMP: Total of 4 processors activated.
[ 0.096451] CPU features: detected: 32-bit EL0 Support
[ 0.101555] CPU features: detected: CRC32 instructions
[ 0.106695] CPU: All CPU(s) started at EL2
[ 0.110736] alternatives: patching kernel code
[ 0.116198] devtmpfs: initialized
[ 0.125508] Registered cp15_barrier emulation handler
[ 0.125559] Registered setend emulation handler
[ 0.129538] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 7645041785100000 ns
[ 0.139119] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.152537] pinctrl core: initialized pinctrl subsystem
[ 0.153188] NET: Registered protocol family 16
[ 0.157650] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.163618] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allo cations
[ 0.171341] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic al locations
[ 0.179151] audit: initializing netlink subsys (disabled)
[ 0.184613] audit: type=2000 audit(0.116:1): state=initialized audit_enabled= 0 res=1
[ 0.184968] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.198977] ASID allocator initialised with 65536 entries
[ 0.227917] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.228984] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.235639] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.242301] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.307667] DRBG: Continuing without Jitter RNG
[ 1.385736] raid6: neonx8 gen() 2139 MB/s
[ 1.453776] raid6: neonx8 xor() 1599 MB/s
[ 1.521838] raid6: neonx4 gen() 2194 MB/s
[ 1.589888] raid6: neonx4 xor() 1564 MB/s
[ 1.657956] raid6: neonx2 gen() 2080 MB/s
[ 1.726010] raid6: neonx2 xor() 1440 MB/s
[ 1.794073] raid6: neonx1 gen() 1779 MB/s
[ 1.862123] raid6: neonx1 xor() 1220 MB/s
[ 1.930179] raid6: int64x8 gen() 1438 MB/s
[ 1.998237] raid6: int64x8 xor() 771 MB/s
[ 2.066302] raid6: int64x4 gen() 1601 MB/s
[ 2.134365] raid6: int64x4 xor() 817 MB/s
[ 2.202423] raid6: int64x2 gen() 1397 MB/s
[ 2.270480] raid6: int64x2 xor() 749 MB/s
[ 2.338545] raid6: int64x1 gen() 1033 MB/s
[ 2.406598] raid6: int64x1 xor() 517 MB/s
[ 2.406636] raid6: using algorithm neonx4 gen() 2194 MB/s
[ 2.410589] raid6: .... xor() 1564 MB/s, rmw enabled
[ 2.415524] raid6: using neon recovery algorithm
[ 2.420565] iommu: Default domain type: Translated
[ 2.425157] SCSI subsystem initialized
[ 2.428822] usbcore: registered new interface driver usbfs
[ 2.434147] usbcore: registered new interface driver hub
[ 2.439424] usbcore: registered new device driver usb
[ 2.444556] mc: Linux media interface: v0.10
[ 2.448678] videodev: Linux video capture interface: v2.00
[ 2.454164] EDAC MC: Ver: 3.0.0
[ 2.457591] zynqmp-ipi-mbox mailbox@ff990400: Registered ZynqMP IPI mbox with TX/RX channels.
[ 2.466218] jesd204: created con: id=0, topo=0, link=0, /axi/spi@ff040000/ad9 528-1@0 <-> /fpga-axi@0/axi-adxcvr-tx@84a80000
[ 2.476781] jesd204: created con: id=1, topo=0, link=2, /axi/spi@ff040000/ad9 528-1@0 <-> /fpga-axi@0/axi-adxcvr-rx-os@84a50000
[ 2.488110] jesd204: created con: id=2, topo=0, link=1, /axi/spi@ff040000/ad9 528-1@0 <-> /fpga-axi@0/axi-adxcvr-rx@84a60000
[ 2.499179] jesd204: created con: id=3, topo=0, link=2, /fpga-axi@0/axi-adxcv r-rx-os@84a50000 <-> /fpga-axi@0/axi-jesd204-rx-os@84ab0000
[ 2.511376] jesd204: created con: id=4, topo=0, link=0, /fpga-axi@0/axi-adxcv r-tx@84a80000 <-> /fpga-axi@0/axi-jesd204-tx@84a90000
[ 2.523059] jesd204: created con: id=5, topo=0, link=1, /fpga-axi@0/axi-adxcv r-rx@84a60000 <-> /fpga-axi@0/axi-jesd204-rx@84aa0000
[ 2.534732] jesd204: created con: id=6, topo=0, link=0, /fpga-axi@0/axi-jesd2 04-tx@84a90000 <-> /fpga-axi@0/axi-adrv9009-tx-hpc@84a04000
[ 2.546969] jesd204: created con: id=7, topo=0, link=1, /fpga-axi@0/axi-jesd2 04-rx@84aa0000 <-> /axi/spi@ff040000/adrv9009-phy@1
[ 2.558440] jesd204: created con: id=8, topo=0, link=2, /fpga-axi@0/axi-jesd2 04-rx-os@84ab0000 <-> /axi/spi@ff040000/adrv9009-phy@1
[ 2.570205] jesd204: created con: id=9, topo=0, link=0, /fpga-axi@0/axi-adrv9 009-tx-hpc@84a04000 <-> /axi/spi@ff040000/adrv9009-phy@1
[ 2.582141] jesd204: /axi/spi@ff040000/adrv9009-phy@1: JESD204[0:0] transitio n uninitialized -> initialized
[ 2.591816] jesd204: /axi/spi@ff040000/adrv9009-phy@1: JESD204[0:1] transitio n uninitialized -> initialized
[ 2.601504] jesd204: /axi/spi@ff040000/adrv9009-phy@1: JESD204[0:2] transitio n uninitialized -> initialized
[ 2.611187] jesd204: found 9 devices and 1 topologies
[ 2.616230] FPGA manager framework
[ 2.619715] Advanced Linux Sound Architecture Driver Initialized.
[ 2.626014] Bluetooth: Core ver 2.22
[ 2.629192] NET: Registered protocol family 31
[ 2.633592] Bluetooth: HCI device and connection manager initialized
[ 2.639908] Bluetooth: HCI socket layer initialized
[ 2.644751] Bluetooth: L2CAP socket layer initialized
[ 2.649779] Bluetooth: SCO socket layer initialized
[ 2.654986] clocksource: Switched to clocksource arch_sys_counter
[ 2.660770] VFS: Disk quotas dquot_6.6.0
[ 2.664607] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.675331] NET: Registered protocol family 2
[ 2.676061] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 3276 8 bytes, linear)
[ 2.684236] TCP established hash table entries: 32768 (order: 6, 262144 bytes , linear)
[ 2.692267] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linea r)
[ 2.699725] TCP: Hash tables configured (established 32768 bind 32768)
[ 2.705893] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 2.712551] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 2.719719] NET: Registered protocol family 1
[ 2.724200] RPC: Registered named UNIX socket transport module.
[ 2.729789] RPC: Registered udp transport module.
[ 2.734452] RPC: Registered tcp transport module.
[ 2.739122] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.746133] PCI: CLS 0 bytes, default 64
[ 2.749832] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 2.756683] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters av ailable
[ 2.765061] Initialise system trusted keyrings
[ 2.768729] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[ 2.775615] NFS: Registering the id_resolver key type
[ 2.780052] Key type id_resolver registered
[ 2.784189] Key type id_legacy registered
[ 2.788180] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.794845] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 2.802017] fuse: init (API version 7.32)
[ 2.841155] NET: Registered protocol family 38
[ 2.841198] xor: measuring software checksum speed
[ 2.848893] 8regs : 2363 MB/sec
[ 2.852558] 32regs : 2799 MB/sec
[ 2.857501] arm64_neon : 2380 MB/sec
[ 2.857690] xor: using function: 32regs (2799 MB/sec)
[ 2.862717] Key type asymmetric registered
[ 2.866777] Asymmetric key parser 'x509' registered
[ 2.871638] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 48)
[ 2.878978] io scheduler mq-deadline registered
[ 2.883472] io scheduler kyber registered
[ 2.913208] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.918022] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 2.924201] brd: module loaded
[ 2.928459] loop: module loaded
[ 2.928775] Registered mathworks_ip class
[ 2.932268] libphy: Fixed MDIO Bus: probed
[ 2.935186] tun: Universal TUN/TAP device driver, 1.6
[ 2.939262] CAN device driver interface
[ 2.943833] usbcore: registered new interface driver asix
[ 2.948396] usbcore: registered new interface driver ax88179_178a
[ 2.954423] usbcore: registered new interface driver cdc_ether
[ 2.960216] usbcore: registered new interface driver net1080
[ 2.965843] usbcore: registered new interface driver cdc_subset
[ 2.971722] usbcore: registered new interface driver zaurus
[ 2.977266] usbcore: registered new interface driver cdc_ncm
[ 2.983717] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.989351] ehci-pci: EHCI PCI platform driver
[ 2.994167] usbcore: registered new interface driver uas
[ 2.999069] usbcore: registered new interface driver usb-storage
[ 3.005066] usbcore: registered new interface driver usbserial_generic
[ 3.011505] usbserial: USB Serial support registered for generic
[ 3.017483] usbcore: registered new interface driver ftdi_sio
[ 3.023181] usbserial: USB Serial support registered for FTDI USB Serial Devi ce
[ 3.030454] usbcore: registered new interface driver upd78f0730
[ 3.036331] usbserial: USB Serial support registered for upd78f0730
[ 3.044034] rtc_zynqmp ffa60000.rtc: registered as rtc0
[ 3.047760] rtc_zynqmp ffa60000.rtc: setting system clock to 2018-11-15T10:34 :53 UTC (1542278093)
[ 3.056623] i2c /dev entries driver
[ 3.061979] usbcore: registered new interface driver uvcvideo
[ 3.065729] USB Video Class driver (1.1.1)
[ 3.071312] Bluetooth: HCI UART driver ver 2.3
[ 3.074201] Bluetooth: HCI UART protocol H4 registered
[ 3.079310] Bluetooth: HCI UART protocol BCSP registered
[ 3.084601] Bluetooth: HCI UART protocol LL registered
[ 3.089688] Bluetooth: HCI UART protocol ATH3K registered
[ 3.095065] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 3.101319] Bluetooth: HCI UART protocol Intel registered
[ 3.106656] Bluetooth: HCI UART protocol QCA registered
[ 3.111854] usbcore: registered new interface driver bcm203x
[ 3.117480] usbcore: registered new interface driver bpa10x
[ 3.123016] usbcore: registered new interface driver bfusb
[ 3.128463] usbcore: registered new interface driver btusb
[ 3.133924] usbcore: registered new interface driver ath3k
[ 3.139415] EDAC MC: ECC not enabled
[ 3.143038] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac control ler zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[ 3.155359] sdhci: Secure Digital Host Controller Interface driver
[ 3.161138] sdhci: Copyright(c) Pierre Ossman
[ 3.165463] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.171528] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.177070] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 3.183494] zynqmp_firmware_probe Platform Management API v1.1
[ 3.189253] zynqmp_firmware_probe Trustzone version v1.0
[ 3.236167] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl i nitialized
[ 3.289275] zynqmp-aes firmware:zynqmp-firmware:zynqmp-aes: will run requests pump with realtime priority
[ 3.304980] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[ 3.305690] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[ 3.311203] usbcore: registered new interface driver usbhid
[ 3.316589] usbhid: USB HID core driver
[ 3.328689] axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.01. a) found
[ 3.331043] axi_sysid 85000000.axi-sysid-0: [adrv9009] on [zcu102] git branch <hdl_2021_r2> git <a83056b11d6b092d342b72c68ef713b362b10521> clean [2023-03-31 22:06:20] UTC
[ 3.346546] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 3.352921] usbcore: registered new interface driver snd-usb-audio
[ 3.360451] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 3.366565] Initializing XFRM netlink socket
[ 3.370404] NET: Registered protocol family 10
[ 3.375135] Segment Routing with IPv6
[ 3.378487] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.384573] NET: Registered protocol family 17
[ 3.388665] NET: Registered protocol family 15
[ 3.393164] can: controller area network core
[ 3.397419] NET: Registered protocol family 29
[ 3.401804] can: raw protocol
[ 3.404741] can: broadcast manager protocol
[ 3.408895] can: netlink gateway - max_hops=1
[ 3.413292] Bluetooth: RFCOMM TTY layer initialized
[ 3.418069] Bluetooth: RFCOMM socket layer initialized
[ 3.423179] Bluetooth: RFCOMM ver 1.11
[ 3.426883] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.432160] Bluetooth: BNEP filters: protocol multicast
[ 3.437353] Bluetooth: BNEP socket layer initialized
[ 3.442280] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.448163] Bluetooth: HIDP socket layer initialized
[ 3.453226] 9pnet: Installing 9P2000 support
[ 3.457342] NET: Registered protocol family 36
[ 3.461762] Key type dns_resolver registered
[ 3.466198] registered taskstats version 1
[ 3.470054] Loading compiled-in X.509 certificates
[ 3.475178] Btrfs loaded, crc32c=crc32c-generic
[ 3.487991] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 48, base_baud = 6249999) is a xuartps
[ 3.497013] printk: console [ttyPS0] enabled
[ 3.501315] printk: bootconsole [cdns0] disabled
[ 3.510972] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 49, base_baud = 6249999) is a xuartps
[ 3.524155] of-fpga-region fpga-full: FPGA Region probed
[ 3.531159] nwl-pcie fd0e0000.pcie: host bridge /axi/pcie@fd0e0000 ranges:
[ 3.538050] nwl-pcie fd0e0000.pcie: MEM 0x00e0000000..0x00efffffff -> 0x 00e0000000
[ 3.546056] nwl-pcie fd0e0000.pcie: MEM 0x0600000000..0x07ffffffff -> 0x 0600000000
[ 3.554123] nwl-pcie fd0e0000.pcie: Link is DOWN
[ 3.558882] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
[ 3.565061] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.570543] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
[ 3.577409] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff p ref]
[ 3.584913] pci 0000:00:00.0: [10ee:d021] type 01 class 0x060400
[ 3.590979] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
[ 3.601576] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
[ 3.608575] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[ 3.615750] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[ 3.622916] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[ 3.630093] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[ 3.637258] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[ 3.644424] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[ 3.651596] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[ 3.658772] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[ 3.666157] xilinx-zynqmp-dpdma fd4c0000.dma-controller: Xilinx DPDMA engine is probed
[ 3.674536] ahci-ceva fd0c0000.ahci: supply ahci not found, using dummy regul ator
[ 3.682079] ahci-ceva fd0c0000.ahci: supply phy not found, using dummy regula tor
[ 3.690792] ad9528 spi1.0: supply vcc not found, using dummy regulator
[ 3.720543] jesd204: /axi/spi@ff040000/ad9528-1@0,jesd204:0,parent=spi1.0: Us ing as SYSREF provider
[ 3.729966] adrv9009 spi1.1: adrv9009_probe : enter
[ 3.741027] spi-nor spi0.0: SPI-NOR-UniqueID 4a960c001111002400cae5c42a8e
[ 3.747822] spi-nor spi0.0: found mt25qu512a, expected m25p80
[ 3.754211] spi-nor spi0.0: trying to lock already unlocked area
[ 3.760217] spi-nor spi0.0: mt25qu512a (131072 Kbytes)
[ 3.765372] 4 fixed-partitions partitions found on MTD device spi0.0
[ 3.771719] Creating 4 MTD partitions on "spi0.0":
[ 3.776504] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
[ 3.783049] 0x000000100000-0x000000600000 : "qspi-linux"
[ 3.789079] 0x000000600000-0x000000620000 : "qspi-device-tree"
[ 3.795562] 0x000000620000-0x000000c00000 : "qspi-rootfs"
[ 3.804202] macb ff0e0000.ethernet: Not enabling partial store and forward
[ 3.811719] libphy: MACB_mii_bus: probed
[ 3.817088] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e 0000 irq 30 (00:0a:35:07:f9:b8)
[ 3.827322] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[ 3.833892] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[ 3.840422] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[ 3.846942] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[ 3.856379] pca953x 0-0020: supply vcc not found, using dummy regulator
[ 3.863064] pca953x 0-0020: using no AI
[ 3.867536] gpio-322 (sel0): hogged as output/low
[ 3.872433] gpio-323 (sel1): hogged as output/high
[ 3.877422] gpio-324 (sel2): hogged as output/high
[ 3.882408] gpio-325 (sel3): hogged as output/high
[ 3.887585] pca953x 0-0021: supply vcc not found, using dummy regulator
[ 3.894252] pca953x 0-0021: using no AI
[ 3.900034] ina2xx 2-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[ 3.907061] ina2xx 2-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[ 3.914103] ina2xx 2-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[ 3.921130] ina2xx 2-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[ 3.928160] ina2xx 2-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[ 3.935183] ina2xx 2-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 3.942221] ina2xx 2-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[ 3.949243] ina2xx 2-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[ 3.956315] ina2xx 2-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[ 3.963340] ina2xx 2-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[ 3.969744] i2c i2c-0: Added multiplexed i2c bus 2
[ 3.975334] ina2xx 3-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[ 3.982357] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[ 3.989386] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[ 3.996411] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.003453] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.010326] random: fast init done
[ 4.013799] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.020821] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.027857] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[ 4.034255] i2c i2c-0: Added multiplexed i2c bus 3
[ 4.089802] i2c i2c-0: Added multiplexed i2c bus 4
[ 4.094743] i2c i2c-0: Added multiplexed i2c bus 5
[ 4.099533] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca95 44
[ 4.106883] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 32
[ 4.114681] at24 6-0054: supply vcc not found, using dummy regulator
[ 4.121568] at24 6-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[ 4.128326] i2c i2c-1: Added multiplexed i2c bus 6
[ 4.134612] si5341 7-0036: Chip: 5341 Grade: 1 Rev: 3
[ 4.172436] i2c i2c-1: Added multiplexed i2c bus 7
[ 4.180107] si570 8-005d: registered, current frequency 300000000 Hz
[ 4.186512] i2c i2c-1: Added multiplexed i2c bus 8
[ 4.206297] si570 9-005d: registered, current frequency 148500000 Hz
[ 4.212700] i2c i2c-1: Added multiplexed i2c bus 9
[ 4.217745] si5324 10-0069: si5328 probed
[ 4.283362] si5324 10-0069: si5328 probe successful
[ 4.288287] i2c i2c-1: Added multiplexed i2c bus 10
[ 4.293313] i2c i2c-1: Added multiplexed i2c bus 11
[ 4.298338] i2c i2c-1: Added multiplexed i2c bus 12
[ 4.303368] i2c i2c-1: Added multiplexed i2c bus 13
[ 4.308244] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pc a9548
[ 4.316265] i2c i2c-1: Added multiplexed i2c bus 14
[ 4.322455] at24 15-0050: supply vcc not found, using dummy regulator
[ 4.329244] at24 15-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 4.335992] i2c i2c-1: Added multiplexed i2c bus 15
[ 4.341041] i2c i2c-1: Added multiplexed i2c bus 16
[ 4.346074] i2c i2c-1: Added multiplexed i2c bus 17
[ 4.351126] i2c i2c-1: Added multiplexed i2c bus 18
[ 4.356158] i2c i2c-1: Added multiplexed i2c bus 19
[ 4.361190] i2c i2c-1: Added multiplexed i2c bus 20
[ 4.366232] i2c i2c-1: Added multiplexed i2c bus 21
[ 4.371112] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pc a9548
[ 4.378722] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 33
[ 4.388517] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60 s
[ 4.417387] cf_axi_adc 84a00000.axi-adrv9009-rx-hpc: ADI AIM (10.02.b) at 0x8 4A00000 mapped to 0x(____ptrval____) probed ADC ADRV9009 as MASTER
[ 4.430374] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[ 4.451462] cf_axi_dds 84a04000.axi-adrv9009-tx-hpc: Analog Devices CF_AXI_DD S_DDS MASTER (9.01.b) at 0x84A04000 mapped to 0x(____ptrval____), probed DDS AD9 371
[ 4.468008] axi_adxcvr 84a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.05.a) using CPLL on GTH4 at 0x84A60000. Number of lanes: 2.
[ 4.477141] mmc0: new high speed SDXC card at address aaaa
[ 4.481577] axi_adxcvr 84a50000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.05.a) usi ng CPLL on GTH4 at 0x84A50000. Number of lanes: 2.
[ 4.485076] mmcblk0: mmc0:aaaa SC128 119 GiB
[ 4.497157] axi_adxcvr 84a80000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.05.a) using QPLL on GTH4 at 0x84A80000. Number of lanes: 4.
[ 4.505027] mmcblk0: p1 p2 p3
[ 4.515501] zynqmp-display fd4a0000.display: vtc bridge property not present
[ 4.523679] zynqmp_clk_divider_set_rate() set divider failed for spi1_ref_div 1, ret = -13
[ 4.533366] xilinx-dp-snd-codec fd4a0000.display:zynqmp_dp_snd_codec0: Failed to get required clock freq
[ 4.542874] xilinx-dp-snd-codec: probe of fd4a0000.display:zynqmp_dp_snd_code c0 failed with error -22
[ 4.552415] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PC M probed
[ 4.560577] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PC M probed
[ 4.568784] OF: graph: no port node found in /axi/display@fd4a0000
[ 4.575339] xlnx-drm xlnx-drm.0: bound fd4a0000.display (ops 0xffffffc01100c9 20)
[ 5.659002] zynqmp-display fd4a0000.display: [drm] Cannot find any crtc or si zes
[ 5.666641] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.display on min or 0
[ 5.674134] zynqmp-display fd4a0000.display: ZynqMP DisplayPort Subsystem dri ver probed
[ 5.682443] ahci-ceva fd0c0000.ahci: supply ahci not found, using dummy regul ator
[ 5.689992] ahci-ceva fd0c0000.ahci: supply phy not found, using dummy regula tor
[ 5.697449] ahci-ceva fd0c0000.ahci: supply target not found, using dummy reg ulator
[ 5.705290] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0 x3 impl platform mode
[ 5.714245] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fb s pio slum part ccc sds apst
[ 5.724811] scsi host0: ahci-ceva
[ 5.728429] scsi host1: ahci-ceva
[ 5.731861] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x1 00 irq 45
[ 5.739772] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x1 80 irq 45
[ 5.750509] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 5.756007] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus nu mber 1
[ 5.763755] xhci-hcd xhci-hcd.1.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000002010810
[ 5.773172] xhci-hcd xhci-hcd.1.auto: irq 60, io mem 0xfe200000
[ 5.779305] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc dDevice= 5.10
[ 5.787572] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 5.794785] usb usb1: Product: xHCI Host Controller
[ 5.799653] usb usb1: Manufacturer: Linux 5.10.0-98744-g64e7a607b659 xhci-hcd
[ 5.806778] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 5.811947] hub 1-0:1.0: USB hub found
[ 5.815715] hub 1-0:1.0: 1 port detected
[ 5.819827] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 5.825310] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus nu mber 2
[ 5.832968] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 5.839596] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc dDevice= 5.10
[ 5.847858] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 5.855075] usb usb2: Product: xHCI Host Controller
[ 5.859942] usb usb2: Manufacturer: Linux 5.10.0-98744-g64e7a607b659 xhci-hcd
[ 5.867068] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 5.872174] hub 2-0:1.0: USB hub found
[ 5.875935] hub 2-0:1.0: 1 port detected
[ 5.884148] axi-jesd204-rx 84aa0000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) a t 0x84AA0000. Encoder 8b10b, width 4/4, lanes 2, jesd204-fsm.
[ 5.897064] axi-jesd204-rx 84ab0000.axi-jesd204-rx-os: AXI-JESD204-RX (1.07.a ) at 0x84AB0000. Encoder 8b10b, width 4/4, lanes 2, jesd204-fsm.
[ 5.910189] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition initialized -> probed
[ 5.921416] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition initialized -> probed
[ 5.932632] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition initialized -> probed
[ 5.943852] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition probed -> idle
[ 5.954459] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition probed -> idle
[ 5.965063] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition probed -> idle
[ 5.975676] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition idle -> device_init
[ 5.986715] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition idle -> device_init
[ 5.997753] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition idle -> device_init
[ 6.008808] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition device_init -> link_init
[ 6.020279] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition device_init -> link_init
[ 6.031752] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition device_init -> link_init
[ 6.043243] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition link_init -> link_supported
[ 6.054983] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition link_init -> link_supported
[ 6.066715] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition link_init -> link_supported
[ 6.071335] ata1: SATA link down (SStatus 0 SControl 330)
[ 6.078950] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition link_supported -> link_pre_setup
[ 6.083926] ata2: SATA link down (SStatus 0 SControl 330)
[ 6.096022] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition link_supported -> link_pre_setup
[ 6.113561] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition link_supported -> link_pre_setup
[ 6.125923] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition link_pre_setup -> clk_sync_stage1
[ 6.138182] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition link_pre_setup -> clk_sync_stage1
[ 6.150434] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition link_pre_setup -> clk_sync_stage1
[ 6.162693] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition clk_sync_stage1 -> clk_sync_stage2
[ 6.175037] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition clk_sync_stage1 -> clk_sync_stage2
[ 6.187379] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition clk_sync_stage1 -> clk_sync_stage2
[ 6.199725] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition clk_sync_stage2 -> clk_sync_stage3
[ 6.212063] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition clk_sync_stage2 -> clk_sync_stage3
[ 6.224405] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition clk_sync_stage2 -> clk_sync_stage3
[ 6.238759] adrv9009 spi1.1: ADIHAL_resetHw
[ 6.581476] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition clk_sync_stage3 -> link_setup
[ 6.593386] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition clk_sync_stage3 -> link_setup
[ 6.605291] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition clk_sync_stage3 -> link_setup
[ 6.617418] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition link_setup -> opt_setup_stage1
[ 6.629417] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition link_setup -> opt_setup_stage1
[ 6.641410] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition link_setup -> opt_setup_stage1
[ 6.860700] random: crng init done
[ 6.891009] zynqmp-display fd4a0000.display: [drm] Cannot find any crtc or si zes
[ 9.085702] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition opt_setup_stage1 -> opt_setup_stage2
[ 9.098217] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition opt_setup_stage1 -> opt_setup_stage2
[ 9.110731] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition opt_setup_stage1 -> opt_setup_stage2
[ 9.123427] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition opt_setup_stage2 -> opt_setup_stage3
[ 9.135948] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition opt_setup_stage2 -> opt_setup_stage3
[ 9.148462] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition opt_setup_stage2 -> opt_setup_stage3
[ 9.161207] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition opt_setup_stage3 -> opt_setup_stage4
[ 9.173724] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition opt_setup_stage3 -> opt_setup_stage4
[ 9.186242] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition opt_setup_stage3 -> opt_setup_stage4
[ 29.208163] adrv9009 spi1.1: ERROR: 247: TALISE_waitArmCmdStatus() failed due to thrown ARM error. ARM time out
[ 29.218332] adrv9009 spi1.1: adrv9009_jesd204_setup_stage5:6087 (ret 5): Init Cal errorFlag (0x0)
[ 29.227295] adrv9009 spi1.1: ERROR: 294: TALISE_waitArmCmdStatus() failed due to thrown ARM error. Is device in correct state for calling command?
[ 29.240417] adrv9009 spi1.1: ERROR: 803588: Talise ARM Command not accepted i n this state
[ 29.248590] adrv9009 spi1.1: adrv9009_jesd204_setup_stage5:6094 (ret 9): Init Cal calsSincePowerUp (0x0) calsLastRun (0x0) calsMinimum (0x0) initErrCal (0x0) initErrCode (0x0)
[ 29.264239] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] In opt_setup_stage5 got error from cb: -14
[ 29.276323] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : Rolling back from 'opt_setup_stage4', got error -14
[ 29.288063] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition opt_setup_stage4 -> opt_setup_stage5
[ 29.300577] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition opt_setup_stage4 -> opt_setup_stage5
[ 29.313092] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition opt_setup_stage4 -> opt_setup_stage5
[ 29.325612] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition opt_setup_stage5 -> opt_setup_stage4
[ 29.338125] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition opt_setup_stage5 -> opt_setup_stage4
[ 29.350641] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition opt_setup_stage5 -> opt_setup_stage4
[ 29.363162] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition opt_setup_stage4 -> opt_setup_stage3
[ 29.375675] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition opt_setup_stage4 -> opt_setup_stage3
[ 29.388198] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition opt_setup_stage4 -> opt_setup_stage3
[ 29.400713] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition opt_setup_stage3 -> opt_setup_stage2
[ 29.413225] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition opt_setup_stage3 -> opt_setup_stage2
[ 29.425741] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition opt_setup_stage3 -> opt_setup_stage2
[ 29.438261] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition opt_setup_stage2 -> opt_setup_stage1
[ 29.450775] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition opt_setup_stage2 -> opt_setup_stage1
[ 29.463293] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition opt_setup_stage2 -> opt_setup_stage1
[ 29.475816] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition opt_setup_stage1 -> link_setup
[ 29.487812] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition opt_setup_stage1 -> link_setup
[ 29.499808] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition opt_setup_stage1 -> link_setup
[ 29.511811] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition link_setup -> clk_sync_stage3
[ 29.523721] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition link_setup -> clk_sync_stage3
[ 29.535629] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition link_setup -> clk_sync_stage3
[ 29.547542] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition clk_sync_stage3 -> clk_sync_stage2
[ 29.559882] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition clk_sync_stage3 -> clk_sync_stage2
[ 29.572224] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition clk_sync_stage3 -> clk_sync_stage2
[ 29.584571] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition clk_sync_stage2 -> clk_sync_stage1
[ 29.596911] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition clk_sync_stage2 -> clk_sync_stage1
[ 29.609254] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition clk_sync_stage2 -> clk_sync_stage1
[ 29.621592] adrv9009 spi1.1: ADIHAL_resetHw
[ 29.626824] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition clk_sync_stage1 -> link_pre_setup
[ 29.639085] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition clk_sync_stage1 -> link_pre_setup
[ 29.651344] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition clk_sync_stage1 -> link_pre_setup
[ 29.663603] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition link_pre_setup -> link_supported
[ 29.675767] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition link_pre_setup -> link_supported
[ 29.687938] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition link_pre_setup -> link_supported
[ 29.700111] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition link_supported -> link_init
[ 29.711842] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition link_supported -> link_init
[ 29.723580] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition link_supported -> link_init
[ 29.735319] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition link_init -> device_init
[ 29.746789] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition link_init -> device_init
[ 29.758264] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition link_init -> device_init
[ 29.769745] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:2] transition device_init -> idle
[ 29.780787] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:1] transition device_init -> idle
[ 29.791830] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : JESD204[0:0] transition device_init -> idle
[ 29.802869] jesd204: /axi/spi@ff040000/adrv9009-phy@1,jesd204:1,parent=spi1.1 : FSM completed with error -14
[ 29.812615] axi-jesd204-tx 84a90000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a) a t 0x84A90000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm.
[ 29.834703] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 29.841841] of_cfs_init
[ 29.844309] of_cfs_init: OK
[ 29.847318] cfg80211: Loading compiled-in X.509 certificates for regulatory d atabase
[ 29.985428] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 29.991960] clk: Not disabling unused clocks
[ 29.996489] ALSA device list:
[ 29.999448] No soundcards found.
[ 30.003137] platform regulatory.0: Direct firmware load for regulatory.db fai led with error -2
[ 30.011745] cfg80211: failed to load regulatory.db
[ 30.460063] EXT4-fs (mmcblk0p2): recovery complete
[ 30.466114] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O pts: (null)
[ 30.474244] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 30.491643] devtmpfs: mounted
[ 30.495511] Freeing unused kernel memory: 2496K
[ 30.500141] Run /sbin/init as init process
[ 31.010563] systemd[1]: System time before build time, advancing clock.
[ 31.048743] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRY PT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 31.072713] systemd[1]: Detected architecture arm64.
Welcome to Kuiper GNU/Linux 11.2 (bullseye)!
[ 31.101831] systemd[1]: Set hostname to <analog>.
[ 32.354598] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit c onfigured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is dep recated and will eventually be removed.
[ 32.564370] systemd[1]: Queued start job for default target Graphical Interfa ce.
[ 32.573145] systemd[1]: system-getty.slice: unit configures an IP firewall, b ut the local system does not support BPF/cgroup firewalling.
[ 32.585500] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 32.594547] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 32.615445] systemd[1]: Created slice system-modprobe.slice.
[ OK ] Created slice system-modprobe.slice.
[ 32.635372] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 32.659364] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ 32.683243] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 32.703337] systemd[1]: Started Forward Password Requests to Wall Directory W atch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 32.727282] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[ 32.739599] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 32.755127] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 32.771829] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 32.787416] systemd[1]: Listening on fsck to fsckd communication Socket.
[ OK ] Listening on fsck to fsckd communication Socket.
[ 32.811233] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 32.835689] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 32.855402] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 32.879438] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 32.898126] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 32.919384] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 32.940967] systemd[1]: Mounting Huge Pages File System...
[ 32.956811] systemd[1]: Mounting POSIX Message Queue File System...
[ 32.980686] systemd[1]: Mounting RPC Pipe File System...
[ 32.996915] systemd[1]: Mounting Kernel Debug File System...
[ 33.011543] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 33.020241] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 33.034657] systemd[1]: Starting Restore / save the current clock...
[ 33.069324] systemd[1]: Starting Set the console keyboard layout...
[ 33.096299] systemd[1]: Condition check resulted in Create list of static dev ice nodes for the current kernel being skipped.
[ 33.109810] systemd[1]: Starting Load Kernel Module configfs...
[ 33.133388] systemd[1]: Starting Load Kernel Module drm...
[ 33.157197] systemd[1]: Starting Load Kernel Module fuse...
[ 33.183481] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 33.192759] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 33.203742] systemd[1]: Starting Journal Service...
[ 33.228888] systemd[1]: Starting Load Kernel Modules...
[ 33.245114] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 33.269033] systemd[1]: Starting Coldplug All udev Devices...
[ 33.294079] systemd[1]: Mounted Huge Pages File System.
[ OK ] Mounted Huge Pages File System.
[ 33.315623] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 33.343659] systemd[1]: Mounted RPC Pipe File System.
[ OK ] Mounted RPC Pipe File System.
[ 33.371707] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Debug File System.
[ 33.399916] systemd[1]: Finished Restore / save the current clock.
[ OK ] Finished Restore / save the current clock.
[ 33.428207] systemd[1]: Finished Set the console keyboard layout.
[ OK ] Finished Set the console keyboard layout.
[ 33.456102] systemd[1]: modprobe@configfs.service: Succeeded.
[ 33.462392] systemd[1]: Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module configfs.
[ 33.484106] systemd[1]: modprobe@drm.service: Succeeded.
[ 33.490014] systemd[1]: Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module drm.
[ 33.515639] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ 33.586155] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Mounting FUSE Control File System...
Mounting Kernel Configuration File System...
Starting Apply Kernel Variables...
[ OK ] Finished Remount Root and Kernel File Systems.
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Finished Apply Kernel Variables.
Starting Flush Journal to Persistent Storage...
Starting Load/Save Random Seed...
Starting Create System Users...
[ OK ] Finished Create System Users.
Starting Create Static Device Nodes in /dev...
[ OK ] Finished Load/Save Random Seed.
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Starting Rule-based Manage…for Device Events and Files...
[ OK ] Finished Coldplug All udev Devices.
Starting Helper to synchronize boot up for ifupdown...
Starting Wait for udev To …plete Device Initialization...
[ OK ] Finished Helper to synchronize boot up for ifupdown.
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Started Rule-based Manager for Device Events and Files.
Starting Show Plymouth Boot Screen...
[ OK ] Started Show Plymouth Boot Screen.
[ OK ] Started Forward Password R…s to Plymouth Directory Watch.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Found device /dev/ttyPS0.
[ OK ] Found device /dev/disk/by-partuuid/9785213e-01.
[ OK ] Found device /dev/ttyS0.
[ OK ] Finished Wait for udev To Complete Device Initialization.
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
Starting File System Check…isk/by-partuuid/9785213e-01...
[ OK ] Started File System Check Daemon to report status.
[ OK ] Finished File System Check…/disk/by-partuuid/9785213e-01.
Mounting /boot...
[ OK ] Mounted /boot.
[ OK ] Reached target Local File Systems.
Starting Set console font and keymap...
Starting Raise network interfaces...
Starting Preprocess NFS configuration...
Starting Tell Plymouth To Write Out Runtime Data...
Starting Create Volatile Files and Directories...
[ OK ] Finished Set console font and keymap.
[ OK ] Finished Preprocess NFS configuration.
[ OK ] Reached target NFS client services.
[ OK ] Reached target Remote File Systems (Pre).
[ OK ] Reached target Remote File Systems.
[ OK ] Finished Tell Plymouth To Write Out Runtime Data.
[ OK ] Finished Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Finished Update UTMP about System Boot/Shutdown.
[ OK ] Reached target System Initialization.
[ OK ] Started CUPS Scheduler.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Started Periodic ext4 Onli…ata Check for All Filesystems.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily man-db regeneration.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Paths.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on CUPS Scheduler.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on Erlang Port Mapper Daemon Activation Socket.
[ OK ] Listening on GPS (Global P…ioning System) Daemon Sockets.
[ OK ] Listening on triggerhappy.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Analog Devices power up/down sequence...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started Regular background program processing daemon.
[ OK ] Started D-Bus System Message Bus.
Starting dphys-swapfile - …unt, and delete a swap file...
Starting Remove Stale Onli…t4 Metadata Check Snapshots...
Starting Creating IIOD Context Attributes......
Starting Authorization Manager...
Starting DHCP Client Daemon...
Starting LSB: Switch to on…nless shift key is pressed)...
Starting LSB: rng-tools (Debian variant)...
Starting System Logging Service...
Starting User Login Management...
Starting triggerhappy global hotkey daemon...
Starting Disk Manager...
Starting WPA supplicant...
[ OK ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots.
[ OK ] Started triggerhappy global hotkey daemon.
[ OK ] Started DHCP Client Daemon.
[ OK ] Finished Raise network interfaces.
[ OK ] Started LSB: rng-tools (Debian variant).
[ OK ] Started System Logging Service.
[ OK ] Finished dphys-swapfile - …mount, and delete a swap file.
[ OK ] Started User Login Management.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started WPA supplicant.
[ OK ] Reached target Network.
[ OK ] Reached target Network is Online.
Starting CUPS Scheduler...
[ OK ] Started Erlang Port Mapper Daemon.
Starting HTTP based time synchronization tool...
Starting Internet superserver...
Starting /etc/rc.local Compatibility...
Starting OpenBSD Secure Shell server...
Starting Permit User Sessions...
[ OK ] Started Unattended Upgrades Shutdown.
[ OK ] Started Authorization Manager.
Starting Modem Manager...
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Finished Permit User Sessions.
Starting Light Display Manager...
Starting Hold until boot process finishes up...
[ OK ] Started HTTP based time synchronization tool.
[ OK ] Started Internet superserver.
[ OK ] Finished Creating IIOD Context Attributes....
[ OK ] Started IIO Daemon.
[ OK ] Started OpenBSD Secure Shell server.
Raspbian GNU/Linux 11 analog ttyPS0
analog login: root (automatic login)
Linux analog 5.10.0-98744-g64e7a607b659 #1789 SMP Fri Mar 31 17:23:38 EEST 2023 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Apr 2 21:43:06 BST 2023 on ttyPS0
root@analog:~#
Additionally, in both scenarios, only PLL2 is locking, while PLL1 fails to lock, Is this a problem? Furthermore, the JESD204 links are disabled in both cases.
# cat pll1_locked 0 # cat pll1_reference_clk_a_present 0 # cat pll1_reference_clk_ab_missing 1 # cat pll1_reference_clk_b_present 0 # cat pll2_feedback_clk_present 1 # cat pll2_locked 1 # cat vcxo_clk_present 1
We need your assistance to root cause these issues and guidance on how to proceed further.
Thank You,
Abhiram.
