AD9081 Device Tree JESD204C DAC mode 15
The user is trying to configure the AD9081-FMCA-EBZ with the ZCU106 to run in JESD204C DAC mode 15. The final answer indicates that the Zynq GTH transceivers only support up to 16.3Gbps, which is insufficient for the desired 24.75Gbps lane rate.
Product Number: AD9081
I have the AD9081-FMCA-EBZ connected to the ZCU106, and managed to get the default ZCU102 design ported over and running.  I am now trying to get it running in the mode we actually want, JESD204C DAC mode 15, I am interested in DAC only and don't really care about the ADC.  From ACE when set the configuration to the DAC only AD9177 it sets the ADC as mode 10, so as I seemed to need something to use I have started with this.
So for the HDL design I have built it with these parameters:
JESD_MODE=64B66B
RX_LANE_RATE=8.25
TX_LANE_RATE=24.75
RX_JESD_M=8
RX_JESD_L=4
RX_JESD_S=1
RX_JESD_NP=16
TX_JESD_M=8
TX_JESD_L=8
TX_JESD_S=1
TX_JESD_NP=16
I have tried modifying the device tree but am having trouble getting it working, the dts files are attached.
Can anyone help with what needs to be done to get it working?
Also attached are the boot messages, clk_summary report and jesd_status reports.
root@zcu106-ad9081:~#
root@zcu106-ad9081:~# cat /sys/kernel/debug/clk/clk_summary
                                 enable  prepare  protect                                duty
   clock                          count    count    count        rate   accuracy phase  cycle  nshot
 clkin2_0                             0        0        0           0          0     0  50000        0
 clkin1_0                             0        0        0           0          0     0  50000        0
 si570_mgt                            0        0        0   148499999          0     0  50000        0
 si570_user                           0        0        0   299999998          0     0  50000        0
 hmc7044_out13                        0        0        0     1953125          0     0  50000        0
 hmc7044_out12                        2        2        0   125000000          0     0  50000        0
    tx_out_clk                        0        0        0   125000000          0     0  50000        0
    tx_gt_clk                         0        0        0     2500000          0     0  50000        0
    rx_out_clk                        0        0        0   125000000          0     0  50000        0
    rx_gt_clk                         0        0        0     2500000          0     0  50000        0
 hmc7044_out10                        0        0        0   125000000          0     0  50000        0
 hmc7044_out8                         0        0        0   750000000          0     0  50000        0
 hmc7044_out6                         0        0        0   375000000          0     0  50000        0
 hmc7044_out3                         0        0        0     1953125          0     0  50000        0
 hmc7044_out2                         2        2        0   500000000          0     0  50000        0
    spi1.0-tx_sampl_clk               1        1        0  1500000000          0     0  50000        0
    spi1.0-rx_sampl_clk               0        0        0   250000000          0     0  50000        0
 hmc7044_out0                         0        0        0   375000000          0     0  50000        0
 refhdmi                              1        1        0   114285000          0     0  50000        0
    xtal_0                            0        0        0   114285000          0     0  50000        0
       pll_0                          0        0        0 40731174000000          0     0  50000        0
          clk1_0                      0        0        0    27000000          0     0  50000        0
          clk0_0                      0        0        0    27000000          0     0  50000        0
 ref48M                               2        2        0    48000000          0     0  50000        0
    si5341                            3        4        0    14000000          0     0  50000        0
       clock-generator.N4             0        0        0           0          0     0  50000        0
       clock-generator.N3             0        1        0   733260000          0     0  50000        0
          clock-generator.9           0        1        0    33330000          0     0  50000        0
       clock-generator.N2             1        1        0   104000000          0     0  50000        0
          clock-generator.2           1        2        0    26000000          0     0  50000        0
       clock-generator.N1             1        2        0   594000000          0     0  50000        0
          clock-generator.7           0        1        0    74250000          0     0  50000        0
          clock-generator.0           1        2        0    27000000          0     0  50000        0
       clock-generator.N0             1        2        0  1000000000          0     0  50000        0
          clock-generator.8           0        0        0           0          0     0  50000        0
          clock-generator.6           0        1        0   125000000          0     0  50000        0
          clock-generator.5           0        0        0   100000000          0     0  50000        0
          clock-generator.4           0        0        0   100000000          0     0  50000        0
          clock-generator.3           1        2        0   125000000          0     0  50000        0
          clock-generator.1           0        0        0           0          0     0  50000        0
 dp_aclk                              1        1        0   100000000        100     0  50000        0
 aux_ref_clk                          0        0        0    27000000          0     0  50000        0
 gt_crx_ref_clk                       0        0        0   108000000          0     0  50000        0
 pss_alt_ref_clk                      0        0        0           0          0     0  50000        0
 video_clk                            0        0        0    27000000          0     0  50000        0
 pss_ref_clk                          2        2        2    33333333          0     0  50000        0
    vpll_post_src                     0        0        0    33333333          0     0  50000        0
    vpll_pre_src                      0        0        0    33333333          0     0  50000        0
       vpll_int                       0        0        0  2999999970          0     0  50000        0
          vpll_half                   0        0        0  1499999985          0     0  50000        0
             vpll_int_mux             0        0        0  1499999985          0     0  50000        0
                vpll                  0        0        0  1499999985          0     0  50000        0
                   dp_video_ref_mux       0        0        0  1499999985          0     0  50000        0
                      dp_video_ref_div1       0        0        0   299999997          0     0  50000        0
                         dp_video_ref_div2       0        0        0   299999997          0     0  50000        0
                            dp_video_ref       0        0        0   299999997          0     0  50000        0
                   vpll_to_lpd        0        0        0   499999995          0     0  50000        0
    dpll_post_src                     0        0        0    33333333          0     0  50000        0
    dpll_pre_src                      0        0        0    33333333          0     0  50000        0
       dpll_int                       0        0        0  2099999979          0     0  50000        0
          dpll_half                   0        0        0  1049999989          0     0  50000        0
             dpll_int_mux             0        0        0  1049999989          0     0  50000        0
                dpll                  0        0        0  1049999989          0     0  50000        0
                   pcie_ref_mux       0        0        0  1049999989          0     0  50000        0
                      pcie_ref_div1       0        0        0    87500000          0     0  50000        0
                         pcie_ref       0        0        0    87500000          0     0  50000        0
                   dpll_to_lpd        0        0        0   524999995          0     0  50000        0
    apll_post_src                     0        0        0    33333333          0     0  50000        0
    apll_pre_src                      1        1        1    33333333          0     0  50000        0
       apll_int                       1        1        1  2399999976          0     0  50000        0
          apll_half                   1        1        1  1199999988          0     0  50000        0
             apll_int_mux             1        1        1  1199999988          0     0  50000        0
                apll                  1        1        1  1199999988          0     0  50000        0
                   dpdma_ref_mux       1        1        1  1199999988          0     0  50000        0
                      dpdma_ref_div1       1        1        1   599999994          0     0  50000        0
                         dpdma_ref       1        1        1   599999994          0     0  50000        0
                   gdma_ref_mux       0        0        0  1199999988          0     0  50000        0
                      gdma_ref_div1       0        0        0   599999994          0     0  50000        0
                         gdma_ref       0        0        0   599999994          0     0  50000        0
                   acpu_mux           0        0        0  1199999988          0     0  50000        0
                      acpu            0        0        0  1199999988          0     0  50000        0
    rpll_post_src                     0        0        0    33333333          0     0  50000        0
    rpll_pre_src                      0        0        0    33333333          0     0  50000        0
       rpll_int                       0        0        0  2399999976          0     0  50000        0
          rpll_half                   0        0        0  1199999988          0     0  50000        0
             rpll_int_mux             0        0        0  1199999988          0     0  50000        0
                rpll                  0        0        0  1199999988          0     0  50000        0
                   spi1_ref_mux       0        0        0  1199999988          0     0  50000        0
                      spi1_ref_div1       0        0        0    99999999          0     0  50000        0
                         spi1_ref_div2       0        0        0    99999999          0     0  50000        0
                            spi1_ref       0        0        0    99999999          0     0  50000        0
                   spi0_ref_mux       0        0        0  1199999988          0     0  50000        0
                      spi0_ref_div1       0        0        0    99999999          0     0  50000        0
                         spi0_ref_div2       0        0        0    99999999          0     0  50000        0
                            spi0_ref       0        0        0    99999999          0     0  50000        0
                   rpll_to_fpd        0        0        0    22641510          0     0  50000        0
                      dp_stc_ref_mux       0        0        0    22641510          0     0  50000        0
                         dp_stc_ref_div1       0        0        0     1509434          0     0  50000        0
                            dp_stc_ref_div2       0        0        0     1509434          0     0  50000        0
                               dp_stc_ref       0        0        0     1509434          0     0  50000        0
                      dp_audio_ref_mux       0        0        0    22641510          0     0  50000        0
                         dp_audio_ref_div1       0        0        0    22641510          0     0  50000        0
                            dp_audio_ref_div2       0        0        0    22641510          0     0  50000        0
                               dp_audio_ref       0        0        0    22641510          0     0  50000        0
    iopll_post_src                    0        0        0    33333333          0     0  50000        0
    iopll_pre_src                     1        1        1    33333333          0     0  50000        0
       iopll_int                      1        1        1  2999999970          0     0  50000        0
          iopll_half                  1        1        1  1499999985          0     0  50000        0
             iopll_int_mux            1        1        1  1499999985          0     0  50000        0
                iopll                14       16       10  1499999985          0     0  50000        0
                   gem3_ref_ung_mux       1        1        0  1499999985          0     0  50000        0
                      gem3_ref_ung_div1       1        1        0   124999999          0     0  50000        0
                         gem3_ref_ung       1        1        0   124999999          0     0  50000        0
                            gem3_ref       2        2        0   124999999          0     0  50000        0
                               gem3_tx       1        1        0   124999999          0     0  50000        0
                   gem2_ref_ung_mux       0        0        0  1499999985          0     0  50000        0
                      gem2_ref_ung_div1       0        0        0    62500000          0     0  50000        0
                         gem2_ref_ung       0        0        0    62500000          0     0  50000        0
                            gem2_ref       0        0        0    62500000          0     0  50000        0
                               gem2_tx       0        0        0    62500000          0     0  50000        0
                   gem1_ref_ung_mux       0        0        0  1499999985          0     0  50000        0
                      gem1_ref_ung_div1       0        0        0    62500000          0     0  50000        0
                         gem1_ref_ung       0        0        0    62500000          0     0  50000        0
                            gem1_ref       0        0        0    62500000          0     0  50000        0
                               gem1_tx       0        0        0    62500000          0     0  50000        0
                   gem0_ref_ung_mux       0        0        0  1499999985          0     0  50000        0
                      gem0_ref_ung_div1       0        0        0    62500000          0     0  50000        0
                         gem0_ref_ung       0        0        0    62500000          0     0  50000        0
                            gem0_ref       0        0        0    62500000          0     0  50000        0
                               gem0_tx       0        0        0    62500000          0     0  50000        0
                   pl3_ref_mux        1        1        0  1499999985          0     0  50000        0
                      pl3_ref_div1       1        1        0    46875000          0     0  50000        0
                         pl3_ref_div2       1        1        0     9375000          0     0  50000        0
                            pl3_ref       1        1        0     9375000          0     0  50000        0
                   pl2_ref_mux        1        1        0  1499999985          0     0  50000        0
                      pl2_ref_div1       1        1        0   499999995          0     0  50000        0
                         pl2_ref_div2       1        1        0   499999995          0     0  50000        0
                            pl2_ref       3        3        0   499999995          0     0  50000        0
                   pl1_ref_mux        1        1        0  1499999985          0     0  50000        0
                      pl1_ref_div1       1        1        0   249999998          0     0  50000        0
                         pl1_ref_div2       1        1        0   249999998          0     0  50000        0
                            pl1_ref       1        1        0   249999998          0     0  50000        0
                   pl0_ref_mux        1        1        0  1499999985          0     0  50000        0
                      pl0_ref_div1       1        1        0    99999999          0     0  50000        0
                         pl0_ref_div2       1        1        0    99999999          0     0  50000        0
                            pl0_ref       3        3        0    99999999          0     0  50000        0
                   ams_ref_mux        0        0        0  1499999985          0     0  50000        0
                      ams_ref_div1       0        0        0    50000000          0     0  50000        0
                         ams_ref_div2       0        0        0    50000000          0     0  50000        0
                            ams_ref       0        0        0    50000000          0     0  50000        0
                   adma_ref_mux       0        0        0  1499999985          0     0  50000        0
                      adma_ref_div1       0        0        0   499999995          0     0  50000        0
                         adma_ref       0        0        0   499999995          0     0  50000        0
                   can1_ref_mux       0        0        0  1499999985          0     0  50000        0
                      can1_ref_div1       0        0        0    99999999          0     0  50000        0
                         can1_ref_div2       0        0        0    99999999          0     0  50000        0
                            can1_ref       0        0        0    99999999          0     0  50000        0
                               can1       0        0        0    99999999          0     0  50000        0
                   can0_ref_mux       0        0        0  1499999985          0     0  50000        0
                      can0_ref_div1       0        0        0    46875000          0     0  50000        0
                         can0_ref_div2       0        0        0    46875000          0     0  50000        0
                            can0_ref       0        0        0    46875000          0     0  50000        0
                               can0       0        0        0    46875000          0     0  50000        0
                   i2c1_ref_mux       1        1        1  1499999985          0     0  50000        0
                      i2c1_ref_div1       1        1        1    99999999          0     0  50000        0
                         i2c1_ref_div2       1        1        1    99999999          0     0  50000        0
                            i2c1_ref       1        1        1    99999999          0     0  50000        0
                   i2c0_ref_mux       0        1        1  1499999985          0     0  50000        0
                      i2c0_ref_div1       0        1        1    99999999          0     0  50000        0
                         i2c0_ref_div2       0        1        1    99999999          0     0  50000        0
                            i2c0_ref       0        1        1    99999999          0     0  50000        0
                   nand_ref_mux       0        0        0  1499999985          0     0  50000        0
                      nand_ref_div1       0        0        0    46875000          0     0  50000        0
                         nand_ref_div2       0        0        0     9375000          0     0  50000        0
                            nand_ref       0        0        0     9375000          0     0  50000        0
                   uart1_ref_mux       0        1        1  1499999985          0     0  50000        0
                      uart1_ref_div1       0        1        1    99999999          0     0  50000        0
                         uart1_ref_div2       0        1        1    99999999          0     0  50000        0
                            uart1_ref       0        1        1    99999999          0     0  50000        0
                   uart0_ref_mux       1        1        1  1499999985          0     0  50000        0
                      uart0_ref_div1       1        1        1    99999999          0     0  50000        0
                         uart0_ref_div2       1        1        1    99999999          0     0  50000        0
                            uart0_ref       1        1        1    99999999          0     0  50000        0
                   sdio1_ref_mux       1        1        1  1499999985          0     0  50000        0
                      sdio1_ref_div1       1        1        1   187499999          0     0  50000        0
                         sdio1_ref_div2       1        1        1   187499999          0     0  50000        0
                            sdio1_ref       1        1        1   187499999          0     0  50000        0
                               clk_in_sd1       0        0        0    50000000          0     0  50000        0
                               clk_out_sd1       0        0        0    50000000          0     0  50000        0
                   sdio0_ref_mux       0        0        0  1499999985          0     0  50000        0
                      sdio0_ref_div1       0        0        0    99999999          0     0  50000        0
                         sdio0_ref_div2       0        0        0    99999999          0     0  50000        0
                            sdio0_ref       0        0        0    99999999          0     0  50000        0
                   qspi_ref_mux       1        1        1  1499999985          0     0  50000        0
                      qspi_ref_div1       1        1        1   124999999          0     0  50000        0
                         qspi_ref_div2       1        1        1   124999999          0     0  50000        0
                            qspi_ref       2        1        1   124999999          0     0  50000        0
                   gem_tsu_ref_mux       1        1        1  1499999985          0     0  50000        0
                      gem_tsu_ref_div1       1        1        1   249999998          0     0  50000        0
                         gem_tsu_ref_div2       1        1        1   249999998          0     0  50000        0
                            gem_tsu_ref       1        1        1   249999998          0     0  50000        0
                               gem_tsu       1        1        0   249999998          0     0  50000        0
                   usb3_dual_ref_mux       1        1        1  1499999985          0     0  50000        0
                      usb3_dual_ref_div1       1        1        1    60000000          0     0  50000        0
                         usb3_dual_ref_div2       1        1        1    20000000          0     0  50000        0
                            usb3_dual_ref       1        1        1    20000000          0     0  50000        0
                   usb1_bus_ref_mux       0        0        0  1499999985          0     0  50000        0
                      usb1_bus_ref_div1       0        0        0   124999999          0     0  50000        0
                         usb1_bus_ref_div2       0        0        0   124999999          0     0  50000        0
                            usb1_bus_ref       0        0        0   124999999          0     0  50000        0
                   usb0_bus_ref_mux       1        1        1  1499999985          0     0  50000        0
                      usb0_bus_ref_div1       1        1        1   249999998          0     0  50000        0
                         usb0_bus_ref_div2       1        1        1   249999998          0     0  50000        0
                            usb0_bus_ref       1        1        1   249999998          0     0  50000        0
                   lpd_lsbus_mux       1        1        0  1499999985          0     0  50000        0
                      lpd_lsbus_div1       1        1        0    99999999          0     0  50000        0
                         lpd_lsbus       8        8        0    99999999          0     0  50000        0
                            lpd_wdt       0        0        0    99999999          0     0  50000        0
                   iopll_to_fpd       2        2        1   499999995          0     0  50000        0
                      topsw_lsbus_mux       1        1        0   499999995          0     0  50000        0
                         topsw_lsbus_div1       1        1        0    99999999          0     0  50000        0
                            topsw_lsbus       3        3        0    99999999          0     0  50000        0
                               fpd_wdt       1        1        0    99999999          0     0  50000        0
                      gpu_ref_mux       0        0        0   499999995          0     0  50000        0
                         gpu_ref_div1       0        0        0   499999995          0     0  50000        0
                            gpu_ref       0        0        0   499999995          0     0  50000        0
                               gpu_pp1_ref       0        0        0   499999995          0     0  50000        0
                               gpu_pp0_ref       0        0        0   499999995          0     0  50000        0
                      sata_ref_mux       1        1        1   499999995          0     0  50000        0
                         sata_ref_div1       1        1        1   249999998          0     0  50000        0
                            sata_ref       1        1        1   249999998          0     0  50000        0
 can1_mio                             0        0        0           0          0     0  50000        0
 can0_mio                             0        0        0           0          0     0  50000        0
 gem3_rx                              1        1        0           0          0     0  50000        0
 gem2_rx                              0        0        0           0          0     0  50000        0
 gem1_rx                              0        0        0           0          0     0  50000        0
 gem0_rx                              0        0        0           0          0     0  50000        0
jesd_status -s
 You can also use 'q' to quit and 'a' or 'd' to move between devices!
 F1axi-jesd204-rx/84a90000.axi-jesd204-rxF2axi-jesd204-tx/84b90000.axi-jesd204-txF9Quit
  (DEVICES) Found 2 JESD204 Link Layer peripherals
  (0): axi-jesd204-rx/84a90000.axi-jesd204-rx
  (1): axi-jesd204-tx/84b90000.axi-jesd204-tx  [*]  (LANE STATUS)
  Lane#0123
  Errors0000
  Extended multiblock alignment   EMB_INIT   EMB_INIT   EMB_INIT   EMB_INIT  (STATUS)
  Link isdisabled
  Link Status
  Measured Link Clock (MHz)    62.505
  Reported Link Clock (MHz)    125.000
  Measured Device Clock (MHz)  125.012
  Reported Device Clock (MHz)  125.000
  Desired Device Clock (MHz)   37.879
  Lane rate (MHz)
  Lane rate / 66 (MHz)
  LEMC rate (MHz)
  SYSREF captured
  SYSREF alignment error6
1212516
2125
1
  (STATUS)
  Link isdisabled
  Link Status
  Measured Device Clock (MHz)  125.011
  Lane rate (MHz)
  LEMC rate (MHz)
  SYSREF captured
  SYSREF alignment error You can also use 'q' to quit and 'a' or 'd' to move between devices!
  (STATUS)
  Link isdisabled
  Link Status
  Measured Link Clock (MHz)    62.506
  Measured Device Clock (MHz)  375.035
  Reported Device Clock (MHz)  375.000
  Lane rate (MHz)
  LEMC rate (MHz)
  SYSREF captured
 F1axi-jesd204-rx/84a90000.axi-jesd204-rxF2axi-jesd204-tx/84b90000.axi-jesd204-txF9Quit75565
765756root@zcu106-ad9081:~#
Xilinx Zynq MP First Stage Boot Loader
Release 2021.2   Oct 13 2021  -  07:15:53
NOTICE:  BL31: v2.4(release):xlnx_rebase_v2.4_2021.1_update1-23-g9188496b9
NOTICE:  BL31: Built : 07:41:24, Oct 13 2021
U-Boot 2021.01 (Oct 12 2021 - 09:28:42 +0000)
CPU:   ZynqMP
Silicon: v3
Model: ZynqMP ZCU106 RevA
Board: Xilinx ZynqMP
DRAM:  4 GiB
PMUFW:	v1.1
Xilinx I2C Legacy format at nvmem0:
 Board name:	zcu106
 Board rev:	1.0
 Board SN:	921747562017-31324
 Ethernet mac:	00:0a:35:05:6e:ce
EL Level:	EL2
Chip ID:	zu7ev
NAND:  0 MiB
MMC:   mmc@ff170000: 0
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Bootmode: LVL_SHFT_SD_MODE1
Reset reason:	EXTERNAL
Net:
ZYNQ GEM: ff0e0000, mdio bus ff0e0000, phyaddr 12, interface rgmii-id
eth0: ethernet@ff0e0000
Hit any key to stop autoboot:  2  1  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
2710 bytes read in 24 ms (109.4 KiB/s)
## Executing script at 20000000
Trying to load boot images from mmc0
407 bytes read in 21 ms (18.6 KiB/s)
Importing environment(uEnv.txt) from mmc0...
Running uenvcmd ...
Copying Linux from SD to RAM...
** No boot file defined **
32740616 bytes read in 2182 ms (14.3 MiB/s)
## Loading kernel from FIT Image at 10000000 ...
   Using 'conf-system-top.dtb' configuration
   Trying 'kernel-1' kernel subimage
     Description:  Linux kernel
     Created:      2023-10-10  13:10:16 UTC
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x10000104
     Data Size:    11218521 Bytes = 10.7 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00200000
     Entry Point:  0x00200000
     Hash algo:    sha256
     Hash value:   2d1e81b4782713d8648196d29939b7db6c2fcff6e1feb1184662f6ae0ee70c49
   Verifying Hash Integrity ... sha256+ OK
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk-1' ramdisk subimage
     Description:  petalinux-image-minimal
     Type:         RAMDisk Image
     Compression:  uncompressed
     Data Start:   0x10ac3048
     Data Size:    21454663 Bytes = 20.5 MiB
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha256
     Hash value:   999960267fe93c093e81a53f5c2b94c816e36f426d57f076d0c4c6447ebb2651
## Loading fdt from FIT Image at 10000000 ...
   Trying 'fdt-system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x10ab3070
     Data Size:    65285 Bytes = 63.8 KiB
     Hash algo:    sha256
     Hash value:   41640295e3b73bfca1aefe25ca73e897590d5f2707455f7b3c7d0b060a6e260b
   Booting using the fdt blob at 0x10ab3070
   Uncompressing Kernel Image
   Loading Ramdisk to 7c995000, end 7de0af47 ... OK
   Loading Device Tree to 000000007c982000, end 000000007c994f04 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.0-xilinx-v2021.2 (oe-user@oe-host) (aarch64-xilinx-linux-gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP Tue Oct 10 13:10:16 UTC 2023
[    0.000000] Machine model: ZynqMP ZCU106 RevA
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] printk: bootconsole [cdns0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x000000006c800000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000087fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000]   node   0: [mem 0x0000000800000000-0x000000087fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000087fffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 22 pages/cpu s50968 r8192 d30952 u90112
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlycon rootfstype=ext4 rootwait clk_ignore_unused cpuidle.off=1
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x000000003bfff000-0x000000003ffff000] (64MB)
[    0.000000] Memory: 3731240K/4194304K available (16064K kernel code, 1728K rwdata, 12220K rodata, 2624K init, 660K bss, 200920K reserved, 262144K cma-reserved)
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x524 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 100.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171024e7e0, max_idle_ns: 440795205315 ns
[    0.000003] sched_clock: 56 bits at 100MHz, resolution 10ns, wraps every 4398046511100ns
[    0.008495] Console: colour dummy device 80x25
[    0.012485] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=400000)
[    0.022841] pid_max: default: 32768 minimum: 301
[    0.027598] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.034790] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.043613] rcu: Hierarchical SRCU implementation.
[    0.047592] EFI services will not be available.
[    0.051962] smp: Bringing up secondary CPUs ...
[    0.056702] Detected VIPT I-cache on CPU1
[    0.056746] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.057144] Detected VIPT I-cache on CPU2
[    0.057168] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.057550] Detected VIPT I-cache on CPU3
[    0.057573] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.057620] smp: Brought up 1 node, 4 CPUs
[    0.091780] SMP: Total of 4 processors activated.
[    0.096453] CPU features: detected: 32-bit EL0 Support
[    0.101556] CPU features: detected: CRC32 instructions
[    0.106694] CPU: All CPU(s) started at EL2
[    0.110736] alternatives: patching kernel code
[    0.116262] devtmpfs: initialized
[    0.125472] Registered cp15_barrier emulation handler
[    0.125523] Registered setend emulation handler
[    0.129504] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.139085] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.152497] pinctrl core: initialized pinctrl subsystem
[    0.153183] NET: Registered protocol family 16
[    0.157610] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.163575] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.171297] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.179126] audit: initializing netlink subsys (disabled)
[    0.184584] audit: type=2000 audit(0.116:1): state=initialized audit_enabled=0 res=1
[    0.184936] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.198939] ASID allocator initialised with 65536 entries
[    0.226319] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.227375] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.234048] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.240701] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    1.306385] DRBG: Continuing without Jitter RNG
[    1.384164] raid6: neonx8   gen()  2143 MB/s
[    1.452219] raid6: neonx8   xor()  1596 MB/s
[    1.520292] raid6: neonx4   gen()  2189 MB/s
[    1.588341] raid6: neonx4   xor()  1566 MB/s
[    1.656420] raid6: neonx2   gen()  2077 MB/s
[    1.724470] raid6: neonx2   xor()  1433 MB/s
[    1.792543] raid6: neonx1   gen()  1775 MB/s
[    1.860593] raid6: neonx1   xor()  1219 MB/s
[    1.928663] raid6: int64x8  gen()  1437 MB/s
[    1.996722] raid6: int64x8  xor()   771 MB/s
[    2.064788] raid6: int64x4  gen()  1602 MB/s
[    2.132859] raid6: int64x4  xor()   816 MB/s
[    2.200931] raid6: int64x2  gen()  1397 MB/s
[    2.268980] raid6: int64x2  xor()   750 MB/s
[    2.337068] raid6: int64x1  gen()  1033 MB/s
[    2.405127] raid6: int64x1  xor()   517 MB/s
[    2.405165] raid6: using algorithm neonx4 gen() 2189 MB/s
[    2.409124] raid6: .... xor() 1566 MB/s, rmw enabled
[    2.414054] raid6: using neon recovery algorithm
[    2.419099] iommu: Default domain type: Translated
[    2.423703] SCSI subsystem initialized
[    2.427355] usbcore: registered new interface driver usbfs
[    2.432680] usbcore: registered new interface driver hub
[    2.437960] usbcore: registered new device driver usb
[    2.443082] mc: Linux media interface: v0.10
[    2.447202] videodev: Linux video capture interface: v2.00
[    2.452696] EDAC MC: Ver: 3.0.0
[    2.456140] zynqmp-ipi-mbox mailbox@ff990400: Registered ZynqMP IPI mbox with TX/RX channels.
[    2.464670] jesd204: created con: id=0, topo=0, link=0, /axi/spi@ff050000/hmc7044@0 <-> /fpga-axi@0/axi-adxcvr-tx@84b60000
[    2.475223] jesd204: created con: id=1, topo=0, link=2, /axi/spi@ff050000/hmc7044@0 <-> /fpga-axi@0/axi-adxcvr-rx@84a60000
[    2.486206] jesd204: created con: id=2, topo=0, link=0, /fpga-axi@0/axi-adxcvr-tx@84b60000 <-> /fpga-axi@0/axi-jesd204-tx@84b90000
[    2.497884] jesd204: created con: id=3, topo=0, link=2, /fpga-axi@0/axi-adxcvr-rx@84a60000 <-> /fpga-axi@0/axi-jesd204-rx@84a90000
[    2.509584] jesd204: created con: id=4, topo=0, link=0, /fpga-axi@0/axi-jesd204-tx@84b90000 <-> /fpga-axi@0/axi-ad9081-tx-hpc@84b10000
[    2.521584] jesd204: created con: id=5, topo=0, link=2, /fpga-axi@0/axi-jesd204-rx@84a90000 <-> /fpga-axi@0/axi-ad9081-rx-hpc@84a10000
[    2.533628] jesd204: created con: id=6, topo=0, link=2, /fpga-axi@0/axi-ad9081-rx-hpc@84a10000 <-> /axi/spi@ff040000/ad9081@0
[    2.544852] jesd204: created con: id=7, topo=0, link=0, /fpga-axi@0/axi-ad9081-tx-hpc@84b10000 <-> /axi/spi@ff040000/ad9081@0
[    2.556103] jesd204: /axi/spi@ff040000/ad9081@0: JESD204[0:2] transition uninitialized -> initialized
[    2.565261] jesd204: /axi/spi@ff040000/ad9081@0: JESD204[0:0] transition uninitialized -> initialized
[    2.574426] jesd204: found 8 devices and 1 topologies
[    2.579473] FPGA manager framework
[    2.582951] Advanced Linux Sound Architecture Driver Initialized.
[    2.589261] Bluetooth: Core ver 2.22
[    2.592428] NET: Registered protocol family 31
[    2.596830] Bluetooth: HCI device and connection manager initialized
[    2.603146] Bluetooth: HCI socket layer initialized
[    2.607989] Bluetooth: L2CAP socket layer initialized
[    2.613013] Bluetooth: SCO socket layer initialized
[    2.618215] clocksource: Switched to clocksource arch_sys_counter
[    2.624048] VFS: Disk quotas dquot_6.6.0
[    2.627841] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    2.638788] NET: Registered protocol family 2
[    2.639308] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    2.647476] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    2.655505] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    2.662962] TCP: Hash tables configured (established 32768 bind 32768)
[    2.669131] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    2.675794] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    2.682961] NET: Registered protocol family 1
[    2.687465] RPC: Registered named UNIX socket transport module.
[    2.693028] RPC: Registered udp transport module.
[    2.697694] RPC: Registered tcp transport module.
[    2.702361] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.709363] PCI: CLS 0 bytes, default 64
[    2.712765] Trying to unpack rootfs image as initramfs...
[    3.711234] Freeing initrd memory: 20948K
[    3.711695] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    3.716901] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    3.725336] Initialise system trusted keyrings
[    3.729021] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    3.735941] NFS: Registering the id_resolver key type
[    3.740254] Key type id_resolver registered
[    3.744420] Key type id_legacy registered
[    3.748389] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    3.755049] jffs2: version 2.2. (NAND) (SUMMARY)  � 2001-2006 Red Hat, Inc.
[    3.762251] fuse: init (API version 7.32)
[    3.802485] NET: Registered protocol family 38
[    3.802530] xor: measuring software checksum speed
[    3.810220]    8regs           :  2363 MB/sec
[    3.813880]    32regs          :  2799 MB/sec
[    3.818833]    arm64_neon      :  2380 MB/sec
[    3.819018] xor: using function: 32regs (2799 MB/sec)
[    3.824044] Key type asymmetric registered
[    3.828106] Asymmetric key parser 'x509' registered
[    3.832968] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    3.840305] io scheduler mq-deadline registered
[    3.844806] io scheduler kyber registered
[    3.875564] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    3.880212] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.886866] brd: module loaded
[    3.891396] loop: module loaded
[    3.891976] Registered mathworks_ip class
[    3.895032] libphy: Fixed MDIO Bus: probed
[    3.897982] tun: Universal TUN/TAP device driver, 1.6
[    3.902062] CAN device driver interface
[    3.906598] usbcore: registered new interface driver asix
[    3.911175] usbcore: registered new interface driver ax88179_178a
[    3.917213] usbcore: registered new interface driver cdc_ether
[    3.923008] usbcore: registered new interface driver net1080
[    3.928629] usbcore: registered new interface driver cdc_subset
[    3.934513] usbcore: registered new interface driver zaurus
[    3.940057] usbcore: registered new interface driver cdc_ncm
[    3.946462] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.952138] ehci-pci: EHCI PCI platform driver
[    3.956954] usbcore: registered new interface driver uas
[    3.961866] usbcore: registered new interface driver usb-storage
[    3.967850] usbcore: registered new interface driver usbserial_generic
[    3.974296] usbserial: USB Serial support registered for generic
[    3.980269] usbcore: registered new interface driver ftdi_sio
[    3.985971] usbserial: USB Serial support registered for FTDI USB Serial Device
[    3.993244] usbcore: registered new interface driver upd78f0730
[    3.999121] usbserial: USB Serial support registered for upd78f0730
[    4.006815] rtc_zynqmp ffa60000.rtc: registered as rtc0
[    4.010545] rtc_zynqmp ffa60000.rtc: setting system clock to 2023-06-10T16:26:15 UTC (1686414375)
[    4.019407] i2c /dev entries driver
[    4.024703] usbcore: registered new interface driver uvcvideo
[    4.028519] USB Video Class driver (1.1.1)
[    4.034103] Bluetooth: HCI UART driver ver 2.3
[    4.036998] Bluetooth: HCI UART protocol H4 registered
[    4.042098] Bluetooth: HCI UART protocol BCSP registered
[    4.047390] Bluetooth: HCI UART protocol LL registered
[    4.052479] Bluetooth: HCI UART protocol ATH3K registered
[    4.057853] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    4.064108] Bluetooth: HCI UART protocol Intel registered
[    4.069445] Bluetooth: HCI UART protocol QCA registered
[    4.074646] usbcore: registered new interface driver bcm203x
[    4.080270] usbcore: registered new interface driver bpa10x
[    4.085807] usbcore: registered new interface driver bfusb
[    4.091253] usbcore: registered new interface driver btusb
[    4.096718] usbcore: registered new interface driver ath3k
[    4.102198] EDAC MC: ECC not enabled
[    4.105823] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    4.118138] sdhci: Secure Digital Host Controller Interface driver
[    4.123936] sdhci: Copyright(c) Pierre Ossman
[    4.128258] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.134315] ledtrig-cpu: registered to indicate activity on CPUs
[    4.139859] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    4.146283] zynqmp_firmware_probe Platform Management API v1.1
[    4.152043] zynqmp_firmware_probe Trustzone version v1.0
[    4.191025] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
[    4.238740] zynqmp-aes firmware:zynqmp-firmware:zynqmp-aes: will run requests pump with realtime priority
[    4.260480] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[    4.261215] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[    4.266726] usbcore: registered new interface driver usbhid
[    4.272096] usbhid: USB HID core driver
[    4.282448] axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.01.a) found
[    4.284794] axi_sysid 85000000.axi-sysid-0: [ad9081_fmca_ebz] on [zcu106] git branch <ad9081_zcu106> git <01a9fbb236f574912c7cdbe06b0290546f0aab08> dirty [2023-10-13 09:23:22] UTC
[    4.301123] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    4.307463] usbcore: registered new interface driver snd-usb-audio
[    4.314946] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    4.321242] Initializing XFRM netlink socket
[    4.324923] NET: Registered protocol family 10
[    4.329675] Segment Routing with IPv6
[    4.333050] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    4.339124] NET: Registered protocol family 17
[    4.343200] NET: Registered protocol family 15
[    4.347679] can: controller area network core
[    4.351957] NET: Registered protocol family 29
[    4.356340] can: raw protocol
[    4.359278] can: broadcast manager protocol
[    4.363432] can: netlink gateway - max_hops=1
[    4.367824] Bluetooth: RFCOMM TTY layer initialized
[    4.372607] Bluetooth: RFCOMM socket layer initialized
[    4.377714] Bluetooth: RFCOMM ver 1.11
[    4.381426] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.386697] Bluetooth: BNEP filters: protocol multicast
[    4.391888] Bluetooth: BNEP socket layer initialized
[    4.396817] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.402701] Bluetooth: HIDP socket layer initialized
[    4.407773] 9pnet: Installing 9P2000 support
[    4.411908] NET: Registered protocol family 36
[    4.416298] Key type dns_resolver registered
[    4.420728] registered taskstats version 1
[    4.424592] Loading compiled-in X.509 certificates
[    4.429718] Btrfs loaded, crc32c=crc32c-generic
[    4.442989] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 44, base_baud = 6249999) is a xuartps
[    4.452017] printk: console [ttyPS0] enabled
[    4.456317] printk: bootconsole [cdns0] disabled
[    4.465977] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 45, base_baud = 6249999) is a xuartps
[    4.479161] of-fpga-region fpga-full: FPGA Region probed
[    4.486730] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    4.493902] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    4.501078] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    4.508247] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    4.515419] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    4.522594] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    4.529763] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    4.536948] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    4.544355] xilinx-zynqmp-dpdma fd4c0000.dma-controller: Xilinx DPDMA engine is probed
[    4.552876] ahci-ceva fd0c0000.ahci: supply ahci not found, using dummy regulator
[    4.560433] ahci-ceva fd0c0000.ahci: supply phy not found, using dummy regulator
[    4.650388] hmc7044 spi2.0: PLL1: Locked, CLKIN0 @ 100000000 Hz, PFD: 10000 kHz - PLL2: Locked @ 3000.000000 MHz
[    4.660933] jesd204: /axi/spi@ff050000/hmc7044@0,jesd204:1,parent=spi2.0: Using as SYSREF provider
[    4.670538] spi-nor spi0.0: SPI-NOR-UniqueID d43e9800091a0012006166d3b94d
[    4.677322] spi-nor spi0.0: found mt25qu512a, expected m25p80
[    4.683734] spi-nor spi0.0: trying to lock already unlocked area
[    4.689740] spi-nor spi0.0: mt25qu512a (131072 Kbytes)
[    4.694903] 4 fixed-partitions partitions found on MTD device spi0.0
[    4.701246] Creating 4 MTD partitions on "spi0.0":
[    4.706030] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
[    4.712603] 0x000000100000-0x000000600000 : "qspi-linux"
[    4.718612] 0x000000600000-0x000000620000 : "qspi-device-tree"
[    4.725129] 0x000000620000-0x000000c00000 : "qspi-rootfs"
[    4.733696] macb ff0e0000.ethernet: Not enabling partial store and forward
[    4.741230] libphy: MACB_mii_bus: probed
[    4.749100] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 30 (00:0a:35:05:6e:ce)
[    4.759434] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    4.766028] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[    4.772566] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[    4.779111] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[    4.788497] pca953x 0-0020: supply vcc not found, using dummy regulator
[    4.795175] pca953x 0-0020: using no AI
[    4.799697] pca953x 0-0021: supply vcc not found, using dummy regulator
[    4.806376] pca953x 0-0021: using no AI
[    4.812155] ina2xx 2-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.819189] ina2xx 2-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.826227] ina2xx 2-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.833253] ina2xx 2-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.840278] ina2xx 2-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.847316] ina2xx 2-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.854348] ina2xx 2-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.861382] ina2xx 2-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.868418] ina2xx 2-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.875470] ina2xx 2-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.881875] i2c i2c-0: Added multiplexed i2c bus 2
[    4.887576] ina2xx 3-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[    4.894249] random: fast init done
[    4.897927] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.904961] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.911996] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.919024] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.926059] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.933121] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.940154] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.946556] i2c i2c-0: Added multiplexed i2c bus 3
[    5.002580] i2c i2c-0: Added multiplexed i2c bus 4
[    5.007523] i2c i2c-0: Added multiplexed i2c bus 5
[    5.012317] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[    5.019669] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 32
[    5.027417] at24 6-0054: supply vcc not found, using dummy regulator
[    5.034313] at24 6-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[    5.041065] i2c i2c-1: Added multiplexed i2c bus 6
[    5.047340] si5341 7-0036: Chip: 5341 Grade: 1 Rev: 1
[    5.085234] i2c i2c-1: Added multiplexed i2c bus 7
[    5.092922] si570 8-005d: registered, current frequency 300000000 Hz
[    5.099329] i2c i2c-1: Added multiplexed i2c bus 8
[    5.119140] si570 9-005d: registered, current frequency 148500000 Hz
[    5.125547] i2c i2c-1: Added multiplexed i2c bus 9
[    5.130597] si5324 10-0069: si5328 probed
[    5.198626] si5324 10-0069: si5328 probe successful
[    5.203556] i2c i2c-1: Added multiplexed i2c bus 10
[    5.208801] i2c i2c-1: Added multiplexed i2c bus 11
[    5.213836] i2c i2c-1: Added multiplexed i2c bus 12
[    5.218857] i2c i2c-1: Added multiplexed i2c bus 13
[    5.223736] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[    5.231878] at24 14-0050: supply vcc not found, using dummy regulator
[    5.238677] at24 14-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    5.245422] i2c i2c-1: Added multiplexed i2c bus 14
[    5.250468] i2c i2c-1: Added multiplexed i2c bus 15
[    5.255513] i2c i2c-1: Added multiplexed i2c bus 16
[    5.260553] i2c i2c-1: Added multiplexed i2c bus 17
[    5.265592] i2c i2c-1: Added multiplexed i2c bus 18
[    5.270637] i2c i2c-1: Added multiplexed i2c bus 19
[    5.275675] i2c i2c-1: Added multiplexed i2c bus 20
[    5.280717] i2c i2c-1: Added multiplexed i2c bus 21
[    5.285601] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[    5.293210] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 33
[    5.303005] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
[    5.314150] axi_adxcvr 84a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.05.a) using CPLL on GTH4 at 0x84A60000. Number of lanes: 4.
[    5.326398] axi_adxcvr 84b60000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.05.a) using QPLL on GTH4 at 0x84B60000. Number of lanes: 8.
[    5.338057] axi-jesd204-rx 84a90000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x84A90000. Encoder 64b66b, width 8/8, lanes 4, jesd204-fsm.
[    5.345152] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[    5.351018] axi-jesd204-tx 84b90000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a) at 0x84B90000. Encoder 64b66b, width 8/8, lanes 8, jesd204-fsm.
[    5.371972] zynqmp-display fd4a0000.display: vtc bridge property not present
[    5.381648] xilinx-dp-snd-codec fd4a0000.display:zynqmp_dp_snd_codec0: Failed to get required clock freq
[    5.391156] xilinx-dp-snd-codec: probe of fd4a0000.display:zynqmp_dp_snd_codec0 failed with error -22
[    5.394108] mmc0: new high speed SDHC card at address aaaa
[    5.400702] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[    5.406253] mmcblk0: mmc0:aaaa SB16G 14.8 GiB
[    5.414033] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[    5.422275]  mmcblk0: p1 p2 p3
[    5.426389] OF: graph: no port node found in /axi/display@fd4a0000
[    5.435502] xlnx-drm xlnx-drm.0: bound fd4a0000.display (ops 0xffffffc011090608)
[    6.522232] zynqmp-display fd4a0000.display: [drm] Cannot find any crtc or sizes
[    6.529870] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.display on minor 0
[    6.537361] zynqmp-display fd4a0000.display: ZynqMP DisplayPort Subsystem driver probed
[    6.545701] ahci-ceva fd0c0000.ahci: supply ahci not found, using dummy regulator
[    6.553250] ahci-ceva fd0c0000.ahci: supply phy not found, using dummy regulator
[    6.560714] ahci-ceva fd0c0000.ahci: supply target not found, using dummy regulator
[    6.568553] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    6.577513] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    6.588235] scsi host0: ahci-ceva
[    6.591846] scsi host1: ahci-ceva
[    6.595274] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 40
[    6.603187] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 40
[    6.611943] ad9081 spi1.0: supply vdd not found, using dummy regulator
[    6.924461] ata1: SATA link down (SStatus 0 SControl 330)
[    6.929874] ata2: SATA link down (SStatus 0 SControl 330)
[    7.606235] zynqmp-display fd4a0000.display: [drm] Cannot find any crtc or sizes
[    8.508522] ad9081 spi1.0: AD9081 Rev. 3 Grade 10 (API 1.3.1) probed
[    8.517624] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    8.523117] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[    8.530870] xhci-hcd xhci-hcd.1.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000002010810
[    8.540291] xhci-hcd xhci-hcd.1.auto: irq 53, io mem 0xfe200000
[    8.546418] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    8.554676] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    8.561894] usb usb1: Product: xHCI Host Controller
[    8.566767] usb usb1: Manufacturer: Linux 5.10.0-xilinx-v2021.2 xhci-hcd
[    8.573465] usb usb1: SerialNumber: xhci-hcd.1.auto
[    8.578650] hub 1-0:1.0: USB hub found
[    8.582420] hub 1-0:1.0: 1 port detected
[    8.586533] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    8.592019] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[    8.599675] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    8.606307] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    8.614566] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    8.621777] usb usb2: Product: xHCI Host Controller
[    8.626650] usb usb2: Manufacturer: Linux 5.10.0-xilinx-v2021.2 xhci-hcd
[    8.633349] usb usb2: SerialNumber: xhci-hcd.1.auto
[    8.638471] hub 2-0:1.0: USB hub found
[    8.642238] hub 2-0:1.0: 1 port detected
[    8.673468] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: ADI AIM (10.02.b) at 0x84A10000 mapped to 0x(____ptrval____) probed ADC AD9081 as MASTER
[    8.706233] iio_dmaengine_buffer_alloc:226 width 0 (DMA width >= 256-bits ?)
[    8.714157] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition initialized -> probed
[    8.724854] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition initialized -> probed
[    8.735548] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition probed -> idle
[    8.745628] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition probed -> idle
[    8.755721] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition idle -> device_init
[    8.766246] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition idle -> device_init
[    8.776770] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition device_init -> link_init
[    8.787726] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition device_init -> link_init
[    8.798695] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_init -> link_supported
[    8.809905] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_init -> link_supported
[    8.821512] hmc7044 spi2.0: hmc7044_jesd204_link_pre_setup: Link2 forcing continuous SYSREF mode
[    8.830681] axi-jesd204-rx 84a90000.axi-jesd204-rx: axi_jesd204_rx_jesd204_link_pre_setup: Link2 set lane rate 8250000 kHz failed (-22)
[    8.842858] jesd204: /fpga-axi@0/axi-jesd204-rx@84a90000,jesd204:4,parent=84a90000.axi-jesd204-rx: JESD204[0:2] In link_pre_setup got error from cb: -22
[    8.856499] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: Rolling back from 'link_supported', got error -22
[    8.867549] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_supported -> link_pre_setup
[    8.879197] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_supported -> link_pre_setup
[    8.890848] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_pre_setup -> link_supported
[    8.902493] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_pre_setup -> link_supported
[    8.914144] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_supported -> link_init
[    8.925360] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_supported -> link_init
[    8.936580] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_init -> device_init
[    8.947537] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_init -> device_init
[    8.958496] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition device_init -> idle
[    8.969017] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition device_init -> idle
[    8.979541] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition idle -> idle
[    8.989449] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition idle -> idle
[    8.999364] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition idle -> device_init
[    9.009882] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition idle -> device_init
[    9.020406] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition device_init -> link_init
[    9.031356] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition device_init -> link_init
[    9.042319] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_init -> link_supported
[    9.053534] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_init -> link_supported
[    9.064951] axi-jesd204-rx 84a90000.axi-jesd204-rx: axi_jesd204_rx_jesd204_link_pre_setup: Link2 set lane rate 8250000 kHz failed (-22)
[    9.077121] jesd204: /fpga-axi@0/axi-jesd204-rx@84a90000,jesd204:4,parent=84a90000.axi-jesd204-rx: JESD204[0:2] In link_pre_setup got error from cb: -22
[    9.090767] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: Rolling back from 'link_supported', got error -22
[    9.101807] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_supported -> link_pre_setup
[    9.113452] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_supported -> link_pre_setup
[    9.125103] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_pre_setup -> link_supported
[    9.136750] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_pre_setup -> link_supported
[    9.148400] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_supported -> link_init
[    9.159612] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_supported -> link_init
[    9.170834] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_init -> device_init
[    9.181791] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_init -> device_init
[    9.192749] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition device_init -> idle
[    9.203264] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition device_init -> idle
[    9.213788] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition idle -> idle
[    9.223701] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition idle -> idle
[    9.233614] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition idle -> device_init
[    9.244129] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition idle -> device_init
[    9.254656] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition device_init -> link_init
[    9.265612] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition device_init -> link_init
[    9.276574] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_init -> link_supported
[    9.287790] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_init -> link_supported
[    9.299150] axi-jesd204-rx 84a90000.axi-jesd204-rx: axi_jesd204_rx_jesd204_link_pre_setup: Link2 set lane rate 8250000 kHz failed (-22)
[    9.311323] jesd204: /fpga-axi@0/axi-jesd204-rx@84a90000,jesd204:4,parent=84a90000.axi-jesd204-rx: JESD204[0:2] In link_pre_setup got error from cb: -22
[    9.324967] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: Rolling back from 'link_supported', got error -22
[    9.336011] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_supported -> link_pre_setup
[    9.347660] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_supported -> link_pre_setup
[    9.359308] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_pre_setup -> link_supported
[    9.370952] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_pre_setup -> link_supported
[    9.382604] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_supported -> link_init
[    9.393815] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_supported -> link_init
[    9.405036] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_init -> device_init
[    9.415985] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_init -> device_init
[    9.426944] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition device_init -> idle
[    9.437459] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition device_init -> idle
[    9.447983] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition idle -> idle
[    9.457891] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition idle -> idle
[    9.467807] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition idle -> device_init
[    9.478329] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition idle -> device_init
[    9.488849] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition device_init -> link_init
[    9.499799] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition device_init -> link_init
[    9.510762] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_init -> link_supported
[    9.521975] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_init -> link_supported
[    9.533337] axi-jesd204-rx 84a90000.axi-jesd204-rx: axi_jesd204_rx_jesd204_link_pre_setup: Link2 set lane rate 8250000 kHz failed (-22)
[    9.545511] jesd204: /fpga-axi@0/axi-jesd204-rx@84a90000,jesd204:4,parent=84a90000.axi-jesd204-rx: JESD204[0:2] In link_pre_setup got error from cb: -22
[    9.559153] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: Rolling back from 'link_supported', got error -22
[    9.570198] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_supported -> link_pre_setup
[    9.581850] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_supported -> link_pre_setup
[    9.593503] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_pre_setup -> link_supported
[    9.605152] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_pre_setup -> link_supported
[    9.616800] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_supported -> link_init
[    9.628012] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_supported -> link_init
[    9.639231] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_init -> device_init
[    9.650180] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_init -> device_init
[    9.661138] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition device_init -> idle
[    9.671654] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition device_init -> idle
[    9.682174] jesd204: /axi/spi@ff040000/ad9081@0,jesd204:0,parent=spi1.0: FSM completed with error -22
[    9.691396] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84B10000 mapped to 0x(____ptrval____), probed DDS AD9081
[    9.715082] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    9.722113] of_cfs_init
[    9.724580] of_cfs_init: OK
[    9.727556] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    9.868447] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    9.874996] clk: Not disabling unused clocks
[    9.879530] ALSA device list:
[    9.882494]   No soundcards found.
[    9.886181] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    9.894790] cfg80211: failed to load regulatory.db
[    9.900356] Freeing unused kernel memory: 2624K
[    9.934256] Run /init as init process
INIT: version 2.97 booting
Starting udev
[   10.044594] udevd[157]: starting version 3.2.9
[   10.049419] random: udevd: uninitialized urandom read (16 bytes read)
[   10.055936] random: udevd: uninitialized urandom read (16 bytes read)
[   10.062405] random: udevd: uninitialized urandom read (16 bytes read)
[   10.073552] udevd[158]: starting eudev-3.2.9
[   10.528963] EXT4-fs (mmcblk0p2): recovery complete
[   10.528985] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   10.533790] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[   10.603310] dmaproxy: loading out-of-tree module taints kernel.
bootlogd: /dev/ttyPS0chmod: /var/log/wtmp: No such file or directory
Failed to set mode -0664- for -/var/log/wtmp-.
Configuring packages on first boot....
 (This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
 Removing any system INIT: Entering runlevel: 5
Configuring network interfaces... [   10.930672] macb ff0e0000.ethernet eth0: PHY [ff0e0000.ethernet-ffffffff:0c] driver [TI DP83867] (irq=POLL)
[   10.940468] macb ff0e0000.ethernet eth0: configuring for phy/rgmii-id link mode
udhcpc: started, v1.32.0
udhcpc: sending discover
udhcpc: no lease, forking to background
done.
Starting system message bus: dbus.
Starting haveged: haveged: command socket is listening at fd 3
haveged: haveged starting up
Starting Dropbear SSH server: Waiting for kernel randomness to be initialised...
haveged: haveged: ver: 1.9.13; arch: generic; vend: ; build: (gcc 10.2.0 CTV); collect: 128K
haveged: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 11/40; sz: 15456/64452
haveged: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 8.0041
haveged: haveged: fills: 0, generated: 0
[   20.923373] random: crng init done
Generating 2048 bit rsa key, this may take a while...[   20.926798] random: 7 urandom warning(s) missed due to ratelimiting
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCH5qCJjko1Fsoxkdg/hVYC7jcKXxc4z/OMuKhdvlKMWoXpM4Q5VLBSFOK7zFNL4l9sZuBnftwYKpYalI/pgyzHsdPZtP/eGJlklat4sE2SAiZ6Sqf/9vqCwmyl1iSvcEKjarICpD3gzHYnUsQQN/P3BRt509CuTnsM41RepXZepb6K+inovnLgo4nFt7q4B/u7ugkZ98tcWUi17Rk4f9tKT+U98ngJsjYxyfTIDxUiMibk2wark+Ba3KRyEUbiM42VNaXJVjQOWrmY+IXZn87/pzoxKleVgI4vtUtqo7LVjLg6otiGrghl3LohyyDXhY62mVzPyswuBPMU7NOnSAsx root@zcu106-ad9081
Fingerprint: sha1!! ef:ee:ea:6c:1d:b8:a5:a2:56:bc:4d:67:c7:44:70:9c:ae:a8:ab:3f
dropbear.
Starting Fancontrol Daemon: fancontrold
Starting IIO Daemon: iiod
Starting internet superserver: inetd.
Starting syslogd/klogd: done
Starting tcf-agent: OK
/dts-v1/;
// SPDX-License-Identifier: GPL-2.0
 * Analog Devices AD9081-FMC-EBZ
 * https://wiki.analog.com/resources/eval/user-guides/quadmxfe/quick-start
 * https://wiki.analog.com/resources/tools-software/linux-drivers/iio-mxfe/ad9081
 * hdl_project: <ad9081_fmca_ebz/zcu106>
 * board_revision: <>
 * Copyright (C) 2019-2020 Analog Devices Inc.
// 204C use case with Subclass 1,
// Med. lane rate, using gearbox and PRGOGDIV
//     * 4Txs / 4Rxs per MxFE
//     * DAC_CLK = 12 GSPS
//     * ADC_CLK = 4 GSPS
//     * Tx I/Q Rate: 1.5 GSPS (Interpolation of 1x1)
//     * Rx I/Q Rate: 0.25 GSPS (Decimation of 1x1)
//     * DAC JESD204C: Mode 15, L=8, M=8, N=N'=16
//     * ADC JESD204C: Mode 10, L=4, M=8, N=N'=16
//     * DAC-Side JESD204C Lane Rate: 24.75Gbps
//     * ADC-Side JESD204C Lane Rate: 8.25Gbps
// HDL Synthesis Parameters:
// JESD_MODE=64B66B \
// RX_RATE=8.25 \
// TX_RATE=24.75 \
// RX_JESD_M=8 \
// RX_JESD_L=4 \
// RX_JESD_S=1 \
// RX_JESD_NP=16 \
// TX_JESD_M=8 \
// TX_JESD_L=8 \
// TX_JESD_S=1 \
// TX_JESD_NP=16 \
#include "zynqmp-zcu106-revA-ad9081.dts"
&axi_ad9081_rx_jesd {
	clocks = <&zynqmp_clk 71>, <&hmc7044 10>, <&axi_ad9081_adxcvr_rx 1>, <&axi_ad9081_adxcvr_rx 0>;
	clock-names = "s_axi_aclk", "device_clk", "link_clk", "lane_clk";
&axi_ad9081_tx_jesd {
	clocks = <&zynqmp_clk 71>, <&hmc7044 6>, <&axi_ad9081_adxcvr_tx 1>, <&axi_ad9081_adxcvr_tx 0>;
&axi_ad9081_adxcvr_rx {
	adi,sys-clk-select = <XCVR_CPLL>;
	adi,out-clk-select = <XCVR_REFCLK>;
&axi_ad9081_adxcvr_tx {
	adi,out-clk-select = <XCVR_QPLL>;
&spi1 {
	status = "okay";
	hmc7044: hmc7044@0 {
		#address-cells = <1>;
		#size-cells = <0>;
		#clock-cells = <1>;
		compatible = "adi,hmc7044";
		reg = <0>;
		spi-max-frequency = <1000000>;
		jesd204-device;
		#jesd204-cells = <2>;
		jesd204-sysref-provider;
		adi,jesd204-max-sysref-frequency-hz = <2000000>; /* 2 MHz */
		* There are different versions of the AD9081-FMCA-EBZ & AD9082-FMCA-EBZ
		* VCXO = 122.880 MHz, XO = 122.880MHz (AD9081-FMC-EBZ & AD9082-FMC-EBZ)
		* VCXO = 100.000 MHz, XO = 100.000MHz (AD9081-FMC-EBZ-A2 & AD9082-FMC-EBZ-A2)
		* To determine which board is which, read the freqency printed on the VCXO
		* or use the fru-dump utility:
		* #fru-dump -b /sys/bus/i2c/devices/15-0050/eeprom
		//adi,pll1-clkin-frequencies = <122880000 30720000 0 0>;
		//adi,vcxo-frequency = <122880000>;
		adi,pll1-clkin-frequencies = <100000000 10000000 0 0>;
		adi,pll1-ref-prio-ctrl = <0xE1>; /* prefer CLKIN1 -> CLKIN0 -> CLKIN2 -> CLKIN3 */
		adi,pll1-ref-autorevert-enable;
		adi,vcxo-frequency = <100000000>;
		adi,pll1-loop-bandwidth-hz = <200>;
		adi,pll2-output-frequency = <3000000000>;
		adi,sysref-timer-divider = <1024>;
		adi,pulse-generator-mode = <0>;
		adi,clkin0-buffer-mode  = <0x07>;
		adi,clkin1-buffer-mode  = <0x07>;
		adi,oscin-buffer-mode = <0x15>;
		adi,gpi-controls = <0x00 0x00 0x00 0x00>;
		adi,gpo-controls = <0x37 0x33 0x00 0x00>;
		clock-output-names =
		"hmc7044_out0", "hmc7044_out1", "hmc7044_out2",
		"hmc7044_out3", "hmc7044_out4", "hmc7044_out5",
		"hmc7044_out6", "hmc7044_out7", "hmc7044_out8",
		"hmc7044_out9", "hmc7044_out10", "hmc7044_out11",
		"hmc7044_out12", "hmc7044_out13";
		hmc7044_c0: channel@0 {
			reg = <0>;
			adi,extended-name = "CORE_CLK_RX";
			adi,divider = <8>;
			adi,driver-mode = <HMC7044_DRIVER_MODE_LVDS>;
		hmc7044_c2: channel@2 {
			reg = <2>;
			adi,extended-name = "DEV_REFCLK";
			adi,divider = <6>;
		hmc7044_c3: channel@3 {
			reg = <3>;
			adi,extended-name = "DEV_SYSREF";
			adi,divider = <256>;
			adi,jesd204-sysref-chan;
		hmc7044_c6: channel@6 {
			reg = <6>;
			adi,extended-name = "CORE_CLK_TX";
			adi,divider = <8>;
		hmc7044_c8: channel@8 {
			reg = <8>;
			adi,extended-name = "FPGA_REFCLK1";
			adi,divider = <4>;
		hmc7044_c10: channel@10 {
			reg = <10>;
			adi,extended-name = "CORE_CLK_RX_ALT";
			adi,divider = <12>;
		hmc7044_c12: channel@12 {
			reg = <12>;
			adi,extended-name = "FPGA_REFCLK2";
			adi,divider = <4>;
		hmc7044_c13: channel@13 {
			reg = <13>;
			adi,extended-name = "FPGA_SYSREF";
&fmc_spi {
	trx0_ad9081: ad9081@0 {
		#size-cells = <0>;
		compatible = "adi,ad9081";
		reg = <0>;
		spi-max-frequency = <5000000>;
		/* Clocks */
		clocks = <&hmc7044 2>;
		clock-names = "dev_clk";
		clock-output-names = "rx_sampl_clk", "tx_sampl_clk";
		#clock-cells = <1>;
		jesd204-device;
		jesd204-top-device = <0>; /* This is the TOP device */
		#jesd204-ignore-errors;
		jesd204-link-ids = <FRAMER_LINK0_RX DEFRAMER_LINK0_TX>;
		jesd204-inputs =
			<&axi_ad9081_core_rx 0 FRAMER_LINK0_RX>,
			<&axi_ad9081_core_tx 0 DEFRAMER_LINK0_TX>;
		adi,tx-dacs {
			#size-cells = <0>;
			adi,dac-frequency-hz = /bits/ 64 <12000000000>;
			adi,main-data-paths {
				#size-cells = <0>;
				adi,interpolation = <8>;
				ad9081_dac0: dac@0 {
					reg = <0>;
					adi,crossbar-select = <&ad9081_tx_fddc_chan0>;
					adi,nco-frequency-shift-hz = /bits/ 64 <1000000000>; /* 100 MHz */
				ad9081_dac1: dac@1 {
					reg = <1>;
					adi,crossbar-select = <&ad9081_tx_fddc_chan1>;
					adi,nco-frequency-shift-hz = /bits/ 64 <1100000000>; /* 200 MHz */
				ad9081_dac2: dac@2 {
					reg = <2>;
					adi,crossbar-select = <&ad9081_tx_fddc_chan2>; /* All 4 channels @ dac2 */
					adi,nco-frequency-shift-hz = /bits/ 64 <1200000000>;  /* 300 MHz */
				ad9081_dac3: dac@3 {
					reg = <3>;
					adi,crossbar-select = <&ad9081_tx_fddc_chan3>; /* All 4 channels @ dac2 */
					adi,nco-frequency-shift-hz = /bits/ 64 <1300000000>; /* 400 MHz */
			adi,channelizer-paths {
				#size-cells = <0>;
				adi,interpolation = <1>;
				ad9081_tx_fddc_chan0: channel@0 {
					reg = <0>;
					adi,gain = <2048>; /* 2048 * 10^(gain_dB/20) */
					adi,nco-frequency-shift-hz =  /bits/ 64 <0>;
				ad9081_tx_fddc_chan1: channel@1 {
					reg = <1>;
				ad9081_tx_fddc_chan2: channel@2 {
					reg = <2>;
				ad9081_tx_fddc_chan3: channel@3 {
					reg = <3>;
			adi,jesd-links {
				#size-cells = <0>;
				ad9081_tx_jesd_l0: link@0 {
					#size-cells = <0>;
					reg = <0>;
					adi,logical-lane-mapping = /bits/ 8 <0 2 7 6 1 5 4 3>;
					adi,link-mode = <15>;			/* JESD Quick Configuration Mode */
					adi,subclass = <1>;			/* JESD SUBCLASS 0,1,2 */
					adi,version = <2>;			/* JESD VERSION 0=204A,1=204B,2=204C */
					adi,dual-link = <0>;			/* JESD Dual Link Mode */
					adi,converters-per-device = <8>;	/* JESD M */
					adi,octets-per-frame = <2>;		/* JESD F */
					adi,frames-per-multiframe = <128>;	/* JESD K */
					adi,converter-resolution = <16>;	/* JESD N */
					adi,bits-per-sample = <16>;		/* JESD NP' */
					adi,control-bits-per-sample = <0>;	/* JESD CS */
					adi,lanes-per-device = <8>;		/* JESD L */
					adi,samples-per-converter-per-frame = <1>; /* JESD S */
					adi,high-density = <0>;			/* JESD HD */
		adi,rx-adcs {
			#size-cells = <0>;
			adi,adc-frequency-hz = /bits/ 64 <4000000000>;
				#size-cells = <0>;
				ad9081_adc0: adc@0 {
					reg = <0>;
					adi,decimation = <4>;
					adi,nco-frequency-shift-hz =  /bits/ 64 <400000000>;
					adi,nco-mixer-mode = <AD9081_ADC_NCO_VIF>;
					//adi,crossbar-select = <&ad9081_rx_fddc_chan0>, <&ad9081_rx_fddc_chan2>; /* Static for now */
				ad9081_adc1: adc@1 {
					reg = <1>;
					adi,nco-frequency-shift-hz =  /bits/ 64 <(-400000000)>;
					//adi,crossbar-select = <&ad9081_rx_fddc_chan1>, <&ad9081_rx_fddc_chan3>; /* Static for now */
				ad9081_adc2: adc@2 {
					reg = <2>;
					adi,nco-frequency-shift-hz =  /bits/ 64 <100000000>;
					//adi,crossbar-select = <&ad9081_rx_fddc_chan4>, <&ad9081_rx_fddc_chan6>; /* Static for now */
				ad9081_adc3: adc@3 {
					reg = <3>;
					//adi,crossbar-select = <&ad9081_rx_fddc_chan5>, <&ad9081_rx_fddc_chan7>; /* Static for now */
				#size-cells = <0>;
				ad9081_rx_fddc_chan0: channel@0 {
					reg = <0>;
				ad9081_rx_fddc_chan1: channel@1 {
					reg = <1>;
				ad9081_rx_fddc_chan4: channel@4 {
					reg = <4>;
				ad9081_rx_fddc_chan5: channel@5 {
					reg = <5>;
			adi,jesd-links {
				#size-cells = <0>;
				ad9081_rx_jesd_l0: link@0 {
					reg = <0>;
					adi,converter-select =
						<&ad9081_rx_fddc_chan0 FDDC_I>, <&ad9081_rx_fddc_chan0 FDDC_Q>,
						<&ad9081_rx_fddc_chan1 FDDC_I>, <&ad9081_rx_fddc_chan1 FDDC_Q>,
						<&ad9081_rx_fddc_chan4 FDDC_I>, <&ad9081_rx_fddc_chan4 FDDC_Q>,
						<&ad9081_rx_fddc_chan5 FDDC_I>, <&ad9081_rx_fddc_chan5 FDDC_Q>;
					adi,logical-lane-mapping = /bits/ 8 <2 0 7 6 5 4 3 1>;
					adi,link-mode = <10>;			/* JESD Quick Configuration Mode */
					adi,octets-per-frame = <4>;		/* JESD F */
					adi,frames-per-multiframe = <64>;	/* JESD K */
					adi,lanes-per-device = <4>;		/* JESD L */
/dts-v1/;
 * https://wiki.analog.com/resources/eval/user-guides/ad9081_fmca_ebz/ad9081_fmca_ebz_hdl
#include "zynqmp-zcu106-revA.dts"
#include <dt-bindings/interrupt-controller/irq.h>
#include <dt-bindings/iio/adc/adi,ad9081.h>
#include <dt-bindings/jesd204/adxcvr.h>
&i2c1 {
	i2c-mux@75 {
		i2c@0 { /* HPC0 */
			#size-cells = <0>;
			reg = <0>;
			/* HPC0_IIC */
			eeprom@50 {
				compatible = "at24,24c02";
				reg = <0x50>;
	fpga_axi: fpga-axi@0 {
		interrupt-parent = <&gic>;
		compatible = "simple-bus";
		#address-cells = <0x1>;
		#size-cells = <0x1>;
		ranges = <0 0 0 0xffffffff>;
		rx_dma: dma@9c420000 {
			compatible = "adi,axi-dmac-1.00.a";
			reg = <0x9c420000 0x10000>;
			#dma-cells = <1>;
			#clock-cells = <0>;
			interrupts = <0 109 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&zynqmp_clk 73>;
		tx_dma: dma@9c430000  {
			reg = <0x9c430000 0x10000>;
			#dma-cells = <1>;
			#clock-cells = <0>;
			interrupts = <0 108 IRQ_TYPE_LEVEL_HIGH>;
		axi_ad9081_core_rx: axi-ad9081-rx-hpc@84a10000 {
			compatible = "adi,axi-ad9081-rx-1.0";
			reg = <0x84a10000 0x8000>;
			dmas = <&rx_dma 0>;
			dma-names = "rx";
			spibus-connected = <&trx0_ad9081>;
			jesd204-device;
			jesd204-inputs = <&axi_ad9081_rx_jesd 0 FRAMER_LINK0_RX>;
		axi_ad9081_core_tx: axi-ad9081-tx-hpc@84b10000 {
			compatible = "adi,axi-ad9081-tx-1.0";
			reg = <0x84b10000 0x4000>;
			dmas = <&tx_dma 0>;
			dma-names = "tx";
			clocks = <&trx0_ad9081 1>;
			clock-names = "sampl_clk";
			//adi,axi-pl-fifo-enable;
			adi,axi-data-offload-connected = <&axi_data_offload_tx>;
			jesd204-device;
			jesd204-inputs = <&axi_ad9081_tx_jesd 0 DEFRAMER_LINK0_TX>;
		axi_ad9081_rx_jesd: axi-jesd204-rx@84a90000 {
			compatible = "adi,axi-jesd204-rx-1.0";
			reg = <0x84a90000 0x1000>;
			interrupts = <0 107 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&zynqmp_clk 71>, <&hmc7044 10>, <&axi_ad9081_adxcvr_rx 0>;
			clock-names = "s_axi_aclk", "device_clk", "lane_clk";
			#clock-cells = <0>;
			clock-output-names = "jesd_rx_lane_clk";
			jesd204-device;
			jesd204-inputs = <&axi_ad9081_adxcvr_rx 0 FRAMER_LINK0_RX>;
		axi_ad9081_tx_jesd: axi-jesd204-tx@84b90000 {
			compatible = "adi,axi-jesd204-tx-1.0";
			reg = <0x84b90000 0x1000>;
			interrupts = <0 106 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&zynqmp_clk 71>, <&hmc7044 6>, <&axi_ad9081_adxcvr_tx 0>;
			#clock-cells = <0>;
			clock-output-names = "jesd_tx_lane_clk";
			jesd204-device;
			jesd204-inputs = <&axi_ad9081_adxcvr_tx 0 DEFRAMER_LINK0_TX>;
		axi_ad9081_adxcvr_rx: axi-adxcvr-rx@84a60000 {
			#size-cells = <0>;
			compatible = "adi,axi-adxcvr-1.0";
			reg = <0x84a60000 0x1000>;
			clocks = <&hmc7044 12>;
			clock-names = "conv";
			#clock-cells = <1>;
			clock-output-names = "rx_gt_clk", "rx_out_clk";
			adi,sys-clk-select = <XCVR_QPLL>;
			adi,out-clk-select = <XCVR_REFCLK_DIV2>;
 			adi,use-lpm-enable;
			jesd204-device;
			jesd204-inputs =  <&hmc7044 0 FRAMER_LINK0_RX>;
		axi_ad9081_adxcvr_tx: axi-adxcvr-tx@84b60000 {
			#size-cells = <0>;
			reg = <0x84b60000 0x1000>;
			#clock-cells = <1>;
			clock-output-names = "tx_gt_clk", "tx_out_clk";
			jesd204-device;
			jesd204-inputs =  <&hmc7044 0 DEFRAMER_LINK0_TX>;
		axi_sysid_0: axi-sysid-0@85000000 {
			compatible = "adi,axi-sysid-1.00.a";
			reg = <0x85000000 0x10000>;
		axi_data_offload_tx: axi-data-offload-0@9c440000 {
			compatible = "adi,axi-data-offload-1.0.a";
			reg = <0x9c440000 0x10000>;
			// adi,bringup;
			// adi,oneshot;
			// adi,bypass;
			// adi,sync-config = <2>;
			// adi,transfer-length = /bits/ 64 <0x10000>; // 2**16 bytes
		axi_data_offload_rx: axi-data-offload-1@9c450000 {
			reg = <0x9c450000 0x10000>;
 &spi0 {
 	status = "okay";
#define fmc_spi spi0
#include "adi-ad9081-fmc-ebz.dtsi"
// ad_iobuf #(.DATA_WIDTH(12)) i_iobuf (
// 	.dio_t (gpio_t[43:32]),
// 	.dio_i (gpio_o[43:32]),
// 	.dio_o (gpio_i[43:32]),
// 	dio_p ({hmc_gpio1,       // 43 121
// 	gpio[10:0]}));   // 42-32
// assign gpio_i[44] = agc0[0];
// assign gpio_i[45] = agc0[1];
// assign gpio_i[46] = agc1[0];
// assign gpio_i[47] = agc1[1];
// assign gpio_i[48] = agc2[0];
// assign gpio_i[49] = agc2[1];
// assign gpio_i[50] = agc3[0];
// assign gpio_i[51] = agc3[1];
// assign gpio_i[52] = irqb[0];
// assign gpio_i[53] = irqb[1];
// assign hmc_sync         = gpio_o[54];
// assign rstb             = gpio_o[55]; 133
// assign rxen[0]          = gpio_o[56]; 134
// assign rxen[1]          = gpio_o[57]; 135
// assign txen[0]          = gpio_o[58]; 136
// assign txen[1]          = gpio_o[59]; 137
&trx0_ad9081 {
	reset-gpios = <&gpio 133 0>;
	sysref-req-gpios = <&gpio 121 0>;
	rx2-enable-gpios = <&gpio 135 0>;
	rx1-enable-gpios = <&gpio 134 0>;
	tx2-enable-gpios = <&gpio 137 0>;
	tx1-enable-gpios = <&gpio 136 0>;
