JESD204B Configuration In The Device Tree
Product Number: AD9986
I tried to modify the device tree JESD204B parameters for the AD9986, but I'm getting an error on boot that says "cf_axi_adc 84a10000.axi-ad9081-rx-hpc: JESD param mismatch between TPL and Link configuration !" I am prototyping with the AD9986 Eval board and the ZCU102 Eval board.
I attached the modified device tree as well as the boot log.
The original devicetree set the DAC sample clock to 11.79648 GHz, and I would like to reduce it to 9.8304 GHz. I'd also like to use on chip channelization and interpolation/decimation to get 307.2 MSPS channels.
Could you help me get the JESD link working at the new rates?
Thank You
Old Devicetree
/dts-v1/;
	compatible = "xlnx,zynqmp-zcu102-rev1.0\0xlnx,zynqmp-zcu102\0xlnx,zynqmp";
	#address-cells = < 0x02 >;
	#size-cells = < 0x02 >;
	model = "ZynqMP ZCU102 Rev1.0";
	cpus {
		#address-cells = < 0x01 >;
		#size-cells = < 0x00 >;
		cpu@0 {
			compatible = "arm,cortex-a53";
			device_type = "cpu";
			enable-method = "psci";
			operating-points-v2 = < 0x01 >;
			reg = < 0x00 >;
			cpu-idle-states = < 0x02 >;
			clocks = < 0x03 0x0a >;
		cpu@1 {
			reg = < 0x01 >;
		cpu@2 {
			reg = < 0x02 >;
		cpu@3 {
			reg = < 0x03 >;
		idle-states {
			entry-method = "psci";
			cpu-sleep-0 {
				compatible = "arm,idle-state";
				arm,psci-suspend-param = < 0x40000000 >;
				local-timer-stop;
				entry-latency-us = < 0x12c >;
				exit-latency-us = < 0x258 >;
				min-residency-us = < 0x2710 >;
				phandle = < 0x02 >;
	cpu-opp-table {
		compatible = "operating-points-v2";
		opp-shared;
		phandle = < 0x01 >;
		opp00 {
			opp-hz = < 0x00 0x47868bf4 >;
			opp-microvolt = < 0xf4240 >;
			clock-latency-ns = < 0x7a120 >;
		opp01 {
			opp-hz = < 0x00 0x23c345fa >;
		opp02 {
			opp-hz = < 0x00 0x17d783fc >;
		opp03 {
			opp-hz = < 0x00 0x11e1a2fd >;
	zynqmp_ipi {
		u-boot,dm-pre-reloc;
		compatible = "xlnx,zynqmp-ipi-mailbox";
		interrupt-parent = < 0x04 >;
		interrupts = < 0x00 0x23 0x04 >;
		xlnx,ipi-id = < 0x00 >;
		ranges;
		mailbox@ff990400 {
			reg = < 0x00 0xff9905c0 0x00 0x20 0x00 0xff9905e0 0x00 0x20 0x00 0xff990e80 0x00 0x20 0x00 0xff990ea0 0x00 0x20 >;
			reg-names = "local_request_region\0local_response_region\0remote_request_region\0remote_response_region";
			#mbox-cells = < 0x01 >;
			xlnx,ipi-id = < 0x04 >;
			phandle = < 0x05 >;
	dcc {
		compatible = "arm,dcc";
		status = "okay";
	pmu {
		compatible = "arm,armv8-pmuv3";
		interrupts = < 0x00 0x8f 0x04 0x00 0x90 0x04 0x00 0x91 0x04 0x00 0x92 0x04 >;
	psci {
		compatible = "arm,psci-0.2";
		method = "smc";
	firmware {
		zynqmp-firmware {
			compatible = "xlnx,zynqmp-firmware";
			method = "smc";
			#power-domain-cells = < 0x01 >;
			phandle = < 0x0c >;
			pcap {
				compatible = "xlnx,zynqmp-pcap-fpga";
				clock-names = "ref_clk";
				clocks = < 0x03 0x29 >;
				phandle = < 0x0b >;
			zynqmp-power {
				compatible = "xlnx,zynqmp-power";
				mboxes = < 0x05 0x00 0x05 0x01 >;
				mbox-names = "tx\0rx";
			reset-controller {
				compatible = "xlnx,zynqmp-reset";
				#reset-cells = < 0x01 >;
				phandle = < 0x1a >;
			pinctrl {
				compatible = "xlnx,zynqmp-pinctrl";
				status = "okay";
				i2c0-default {
					phandle = < 0x12 >;
					mux {
						groups = "i2c0_3_grp";
						function = "i2c0";
					conf {
						bias-pull-up;
						slew-rate = < 0x01 >;
						io-standard = < 0x01 >;
				i2c0-gpio {
					phandle = < 0x13 >;
					mux {
						groups = "gpio0_14_grp\0gpio0_15_grp";
						function = "gpio0";
					conf {
				i2c1-default {
					phandle = < 0x15 >;
					mux {
						groups = "i2c1_4_grp";
						function = "i2c1";
					conf {
						bias-pull-up;
				i2c1-gpio {
					phandle = < 0x16 >;
					mux {
						groups = "gpio0_16_grp\0gpio0_17_grp";
						function = "gpio0";
					conf {
				uart0-default {
					phandle = < 0x24 >;
					mux {
						groups = "uart0_4_grp";
						function = "uart0";
					conf {
					conf-rx {
						pins = "MIO18";
						bias-high-impedance;
					conf-tx {
						pins = "MIO19";
						bias-disable;
				uart1-default {
					phandle = < 0x25 >;
					mux {
						groups = "uart1_5_grp";
						function = "uart1";
					conf {
					conf-rx {
						pins = "MIO21";
					conf-tx {
						pins = "MIO20";
						bias-disable;
				usb0-default {
					phandle = < 0x26 >;
					mux {
						groups = "usb0_0_grp";
						function = "usb0";
					conf {
					conf-rx {
						pins = "MIO52\0MIO53\0MIO55";
					conf-tx {
						pins = "MIO54\0MIO56\0MIO57\0MIO58\0MIO59\0MIO60\0MIO61\0MIO62\0MIO63";
						bias-disable;
				gem3-default {
					phandle = < 0x10 >;
					mux {
						function = "ethernet3";
						groups = "ethernet3_0_grp";
					conf {
					conf-rx {
						pins = "MIO70\0MIO71\0MIO72\0MIO73\0MIO74\0MIO75";
						low-power-disable;
					conf-tx {
						pins = "MIO64\0MIO65\0MIO66\0MIO67\0MIO68\0MIO69";
						bias-disable;
						low-power-enable;
					mux-mdio {
						function = "mdio3";
						groups = "mdio3_0_grp";
					conf-mdio {
						bias-disable;
				can1-default {
					phandle = < 0x0d >;
					mux {
						function = "can1";
						groups = "can1_6_grp";
					conf {
					conf-rx {
						pins = "MIO25";
					conf-tx {
						pins = "MIO24";
						bias-disable;
				sdhci1-default {
					phandle = < 0x1c >;
					mux {
						groups = "sdio1_0_grp";
						function = "sdio1";
					conf {
						bias-disable;
					mux-cd {
						groups = "sdio1_cd_0_grp";
						function = "sdio1_cd";
					conf-cd {
						bias-pull-up;
					mux-wp {
						groups = "sdio1_wp_0_grp";
						function = "sdio1_wp";
					conf-wp {
						bias-pull-up;
				gpio-default {
					phandle = < 0x11 >;
					mux-sw {
						function = "gpio0";
						groups = "gpio0_22_grp\0gpio0_23_grp";
					conf-sw {
					mux-msp {
						function = "gpio0";
						groups = "gpio0_13_grp\0gpio0_38_grp";
					conf-msp {
					conf-pull-up {
						pins = "MIO22\0MIO23";
						bias-pull-up;
					conf-pull-none {
						pins = "MIO13\0MIO38";
						bias-disable;
			clock-controller {
				#clock-cells = < 0x01 >;
				compatible = "xlnx,zynqmp-clk";
				clocks = < 0x06 0x07 0x08 0x09 0x0a >;
				clock-names = "pss_ref_clk\0video_clk\0pss_alt_ref_clk\0aux_ref_clk\0gt_crx_ref_clk";
				phandle = < 0x03 >;
	timer {
		compatible = "arm,armv8-timer";
		interrupts = < 0x01 0x0d 0xf08 0x01 0x0e 0xf08 0x01 0x0b 0xf08 0x01 0x0a 0xf08 >;
	edac {
		compatible = "arm,cortex-a53-edac";
	fpga-full {
		compatible = "fpga-region";
		fpga-mgr = < 0x0b >;
		ranges;
	nvmem_firmware {
		compatible = "xlnx,zynqmp-nvmem-fw";
		#size-cells = < 0x01 >;
		soc_revision@0 {
			reg = < 0x00 0x04 >;
			phandle = < 0x19 >;
		efuse_dna@c {
			reg = < 0x0c 0x0c >;
		efuse_usr0@20 {
			reg = < 0x20 0x04 >;
		efuse_usr1@24 {
			reg = < 0x24 0x04 >;
		efuse_usr2@28 {
			reg = < 0x28 0x04 >;
		efuse_usr3@2c {
			reg = < 0x2c 0x04 >;
		efuse_usr4@30 {
			reg = < 0x30 0x04 >;
		efuse_usr5@34 {
			reg = < 0x34 0x04 >;
		efuse_usr6@38 {
			reg = < 0x38 0x04 >;
		efuse_usr7@3c {
			reg = < 0x3c 0x04 >;
		efuse_miscusr@40 {
			reg = < 0x40 0x04 >;
		efuse_chash@50 {
			reg = < 0x50 0x04 >;
		efuse_pufmisc@54 {
			reg = < 0x54 0x04 >;
		efuse_sec@58 {
			reg = < 0x58 0x04 >;
		efuse_spkid@5c {
			reg = < 0x5c 0x04 >;
		efuse_ppk0hash@a0 {
			reg = < 0xa0 0x30 >;
		efuse_ppk1hash@d0 {
			reg = < 0xd0 0x30 >;
	zynqmp_rsa {
		compatible = "xlnx,zynqmp-rsa";
	sha384 {
		compatible = "xlnx,zynqmp-keccak-384";
	zynqmp_aes {
		compatible = "xlnx,zynqmp-aes";
	amba-apu@0 {
		compatible = "simple-bus";
		ranges = < 0x00 0x00 0x00 0x00 0xffffffff >;
		interrupt-controller@f9010000 {
			compatible = "arm,gic-400";
			#interrupt-cells = < 0x03 >;
			reg = < 0x00 0xf9010000 0x10000 0x00 0xf9020000 0x20000 0x00 0xf9040000 0x20000 0x00 0xf9060000 0x20000 >;
			interrupt-controller;
			interrupts = < 0x01 0x09 0xf04 >;
			phandle = < 0x04 >;
	smmu@fd800000 {
		compatible = "arm,mmu-500";
		reg = < 0x00 0xfd800000 0x00 0x20000 >;
		#iommu-cells = < 0x01 >;
		status = "disabled";
		#global-interrupts = < 0x01 >;
		interrupts = < 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 >;
		phandle = < 0x0e >;
	amba {
		ranges;
		can@ff060000 {
			compatible = "xlnx,zynq-can-1.0";
			clock-names = "can_clk\0pclk";
			reg = < 0x00 0xff060000 0x00 0x1000 >;
			interrupts = < 0x00 0x17 0x04 >;
			tx-fifo-depth = < 0x40 >;
			rx-fifo-depth = < 0x40 >;
			power-domains = < 0x0c 0x2f >;
			clocks = < 0x03 0x3f 0x03 0x1f >;
		can@ff070000 {
			status = "okay";
			reg = < 0x00 0xff070000 0x00 0x1000 >;
			interrupts = < 0x00 0x18 0x04 >;
			power-domains = < 0x0c 0x30 >;
			clocks = < 0x03 0x40 0x03 0x1f >;
			pinctrl-names = "default";
			pinctrl-0 = < 0x0d >;
		cci@fd6e0000 {
			compatible = "arm,cci-400";
			reg = < 0x00 0xfd6e0000 0x00 0x9000 >;
			ranges = < 0x00 0x00 0xfd6e0000 0x10000 >;
			pmu@9000 {
				compatible = "arm,cci-400-pmu,r1";
				reg = < 0x9000 0x5000 >;
				interrupts = < 0x00 0x7b 0x04 0x00 0x7b 0x04 0x00 0x7b 0x04 0x00 0x7b 0x04 0x00 0x7b 0x04 >;
		dma@fd500000 {
			status = "okay";
			compatible = "xlnx,zynqmp-dma-1.0";
			reg = < 0x00 0xfd500000 0x00 0x1000 >;
			interrupts = < 0x00 0x7c 0x04 >;
			clock-names = "clk_main\0clk_apb";
			xlnx,bus-width = < 0x80 >;
			#stream-id-cells = < 0x01 >;
			iommus = < 0x0e 0x14e8 >;
			power-domains = < 0x0c 0x2a >;
			clocks = < 0x03 0x13 0x03 0x1f >;
		dma@fd510000 {
			status = "okay";
			reg = < 0x00 0xfd510000 0x00 0x1000 >;
			interrupts = < 0x00 0x7d 0x04 >;
			iommus = < 0x0e 0x14e9 >;
		dma@fd520000 {
			status = "okay";
			reg = < 0x00 0xfd520000 0x00 0x1000 >;
			interrupts = < 0x00 0x7e 0x04 >;
			iommus = < 0x0e 0x14ea >;
		dma@fd530000 {
			status = "okay";
			reg = < 0x00 0xfd530000 0x00 0x1000 >;
			interrupts = < 0x00 0x7f 0x04 >;
			iommus = < 0x0e 0x14eb >;
		dma@fd540000 {
			status = "okay";
			reg = < 0x00 0xfd540000 0x00 0x1000 >;
			interrupts = < 0x00 0x80 0x04 >;
			iommus = < 0x0e 0x14ec >;
		dma@fd550000 {
			status = "okay";
			reg = < 0x00 0xfd550000 0x00 0x1000 >;
			interrupts = < 0x00 0x81 0x04 >;
			iommus = < 0x0e 0x14ed >;
		dma@fd560000 {
			status = "okay";
			reg = < 0x00 0xfd560000 0x00 0x1000 >;
			interrupts = < 0x00 0x82 0x04 >;
			iommus = < 0x0e 0x14ee >;
		dma@fd570000 {
			status = "okay";
			reg = < 0x00 0xfd570000 0x00 0x1000 >;
			interrupts = < 0x00 0x83 0x04 >;
			iommus = < 0x0e 0x14ef >;
		gpu@fd4b0000 {
			status = "okay";
			compatible = "arm,mali-400\0arm,mali-utgard";
			reg = < 0x00 0xfd4b0000 0x00 0x10000 >;
			interrupts = < 0x00 0x84 0x04 0x00 0x84 0x04 0x00 0x84 0x04 0x00 0x84 0x04 0x00 0x84 0x04 0x00 0x84 0x04 >;
			interrupt-names = "IRQGP\0IRQGPMMU\0IRQPP0\0IRQPPMMU0\0IRQPP1\0IRQPPMMU1";
			clock-names = "gpu\0gpu_pp0\0gpu_pp1";
			power-domains = < 0x0c 0x3a >;
			clocks = < 0x03 0x18 0x03 0x19 0x03 0x1a >;
		dma@ffa80000 {
			reg = < 0x00 0xffa80000 0x00 0x1000 >;
			interrupts = < 0x00 0x4d 0x04 >;
			xlnx,bus-width = < 0x40 >;
			power-domains = < 0x0c 0x2b >;
			clocks = < 0x03 0x44 0x03 0x1f >;
		dma@ffa90000 {
			reg = < 0x00 0xffa90000 0x00 0x1000 >;
			interrupts = < 0x00 0x4e 0x04 >;
		dma@ffaa0000 {
			reg = < 0x00 0xffaa0000 0x00 0x1000 >;
			interrupts = < 0x00 0x4f 0x04 >;
		dma@ffab0000 {
			reg = < 0x00 0xffab0000 0x00 0x1000 >;
			interrupts = < 0x00 0x50 0x04 >;
		dma@ffac0000 {
			reg = < 0x00 0xffac0000 0x00 0x1000 >;
			interrupts = < 0x00 0x51 0x04 >;
		dma@ffad0000 {
			reg = < 0x00 0xffad0000 0x00 0x1000 >;
			interrupts = < 0x00 0x52 0x04 >;
		dma@ffae0000 {
			reg = < 0x00 0xffae0000 0x00 0x1000 >;
			interrupts = < 0x00 0x53 0x04 >;
		dma@ffaf0000 {
			reg = < 0x00 0xffaf0000 0x00 0x1000 >;
			interrupts = < 0x00 0x54 0x04 >;
		memory-controller@fd070000 {
			compatible = "xlnx,zynqmp-ddrc-2.40a";
			reg = < 0x00 0xfd070000 0x00 0x30000 >;
			interrupts = < 0x00 0x70 0x04 >;
		nand@ff100000 {
			compatible = "arasan,nfc-v3p10";
			reg = < 0x00 0xff100000 0x00 0x1000 >;
			clock-names = "clk_sys\0clk_flash";
			interrupts = < 0x00 0x0e 0x04 >;
			iommus = < 0x0e 0x872 >;
			power-domains = < 0x0c 0x2c >;
			clocks = < 0x03 0x3c 0x03 0x1f >;
		ethernet@ff0b0000 {
			compatible = "cdns,zynqmp-gem\0cdns,gem";
			interrupts = < 0x00 0x39 0x04 0x00 0x39 0x04 >;
			reg = < 0x00 0xff0b0000 0x00 0x1000 >;
			clock-names = "pclk\0hclk\0tx_clk\0rx_clk\0tsu_clk";
			iommus = < 0x0e 0x874 >;
			power-domains = < 0x0c 0x1d >;
			clocks = < 0x03 0x1f 0x03 0x68 0x03 0x2d 0x03 0x31 0x03 0x2c >;
		ethernet@ff0c0000 {
			interrupts = < 0x00 0x3b 0x04 0x00 0x3b 0x04 >;
			reg = < 0x00 0xff0c0000 0x00 0x1000 >;
			iommus = < 0x0e 0x875 >;
			power-domains = < 0x0c 0x1e >;
			clocks = < 0x03 0x1f 0x03 0x69 0x03 0x2e 0x03 0x32 0x03 0x2c >;
		ethernet@ff0d0000 {
			interrupts = < 0x00 0x3d 0x04 0x00 0x3d 0x04 >;
			reg = < 0x00 0xff0d0000 0x00 0x1000 >;
			iommus = < 0x0e 0x876 >;
			power-domains = < 0x0c 0x1f >;
			clocks = < 0x03 0x1f 0x03 0x6a 0x03 0x2f 0x03 0x33 0x03 0x2c >;
		ethernet@ff0e0000 {
			status = "okay";
			interrupts = < 0x00 0x3f 0x04 0x00 0x3f 0x04 >;
			reg = < 0x00 0xff0e0000 0x00 0x1000 >;
			iommus = < 0x0e 0x877 >;
			power-domains = < 0x0c 0x20 >;
			clocks = < 0x03 0x1f 0x03 0x6b 0x03 0x30 0x03 0x34 0x03 0x2c >;
			phy-handle = < 0x0f >;
			phy-mode = "rgmii-id";
			pinctrl-0 = < 0x10 >;
			ethernet-phy@c {
				reg = < 0x0c >;
				ti,rx-internal-delay = < 0x08 >;
				ti,tx-internal-delay = < 0x0a >;
				ti,fifo-depth = < 0x01 >;
				ti,dp83867-rxctrl-strap-quirk;
				phandle = < 0x0f >;
		gpio@ff0a0000 {
			compatible = "xlnx,zynqmp-gpio-1.0";
			status = "okay";
			#gpio-cells = < 0x02 >;
			gpio-controller;
			interrupts = < 0x00 0x10 0x04 >;
			#interrupt-cells = < 0x02 >;
			reg = < 0x00 0xff0a0000 0x00 0x1000 >;
			power-domains = < 0x0c 0x2e >;
			clocks = < 0x03 0x1f >;
			pinctrl-0 = < 0x11 >;
			phandle = < 0x14 >;
		i2c@ff020000 {
			compatible = "cdns,i2c-r1p14\0cdns,i2c-r1p10";
			status = "okay";
			interrupts = < 0x00 0x11 0x04 >;
			reg = < 0x00 0xff020000 0x00 0x1000 >;
			power-domains = < 0x0c 0x25 >;
			clocks = < 0x03 0x3d >;
			clock-frequency = < 0x61a80 >;
			pinctrl-names = "default\0gpio";
			pinctrl-0 = < 0x12 >;
			pinctrl-1 = < 0x13 >;
			scl-gpios = < 0x14 0x0e 0x00 >;
			sda-gpios = < 0x14 0x0f 0x00 >;
			gpio@20 {
				compatible = "ti,tca6416";
				reg = < 0x20 >;
				gpio-controller;
				gpio-line-names = "PS_GTR_LAN_SEL0\0PS_GTR_LAN_SEL1\0PS_GTR_LAN_SEL2\0PS_GTR_LAN_SEL3\0PCI_CLK_DIR_SEL\0IIC_MUX_RESET_B\0GEM3_EXP_RESET_B\0\0\0\0\0\0\0\0\0";
				gtr-sel0 {
					gpio-hog;
					gpios = < 0x00 0x00 >;
					output-low;
					line-name = "sel0";
				gtr-sel1 {
					gpio-hog;
					gpios = < 0x01 0x00 >;
					output-high;
					line-name = "sel1";
				gtr-sel2 {
					gpio-hog;
					gpios = < 0x02 0x00 >;
					output-high;
					line-name = "sel2";
				gtr-sel3 {
					gpio-hog;
					gpios = < 0x03 0x00 >;
					output-high;
					line-name = "sel3";
			gpio@21 {
				reg = < 0x21 >;
				gpio-controller;
				gpio-line-names = "VCCPSPLL_EN\0MGTRAVCC_EN\0MGTRAVTT_EN\0VCCPSDDRPLL_EN\0MIO26_PMU_INPUT_LS\0PL_PMBUS_ALERT\0PS_PMBUS_ALERT\0MAXIM_PMBUS_ALERT\0PL_DDR4_VTERM_EN\0PL_DDR4_VPP_2V5_EN\0PS_DIMM_VDDQ_TO_PSVCCO_ON\0PS_DIMM_SUSPEND_EN\0PS_DDR4_VTERM_EN\0PS_DDR4_VPP_2V5_EN\0\0";
			i2c-mux@75 {
				compatible = "nxp,pca9544";
				reg = < 0x75 >;
				i2c@0 {
					reg = < 0x00 >;
					ina226@40 {
						compatible = "ti,ina226";
						#io-channel-cells = < 0x01 >;
						label = "ina226-u76";
						reg = < 0x40 >;
						shunt-resistor = < 0x1388 >;
						phandle = < 0x2e >;
					ina226@41 {
						label = "ina226-u77";
						reg = < 0x41 >;
						phandle = < 0x2f >;
					ina226@42 {
						label = "ina226-u78";
						reg = < 0x42 >;
						phandle = < 0x30 >;
					ina226@43 {
						label = "ina226-u87";
						reg = < 0x43 >;
						phandle = < 0x31 >;
					ina226@44 {
						label = "ina226-u85";
						reg = < 0x44 >;
						phandle = < 0x32 >;
					ina226@45 {
						label = "ina226-u86";
						reg = < 0x45 >;
						phandle = < 0x33 >;
					ina226@46 {
						label = "ina226-u93";
						reg = < 0x46 >;
						phandle = < 0x34 >;
					ina226@47 {
						label = "ina226-u88";
						reg = < 0x47 >;
						phandle = < 0x35 >;
					ina226@4a {
						label = "ina226-u15";
						reg = < 0x4a >;
						phandle = < 0x36 >;
					ina226@4b {
						label = "ina226-u92";
						reg = < 0x4b >;
						phandle = < 0x37 >;
				i2c@1 {
					reg = < 0x01 >;
					ina226@40 {
						label = "ina226-u79";
						reg = < 0x40 >;
						shunt-resistor = < 0x7d0 >;
						phandle = < 0x38 >;
					ina226@41 {
						label = "ina226-u81";
						reg = < 0x41 >;
						phandle = < 0x39 >;
					ina226@42 {
						label = "ina226-u80";
						reg = < 0x42 >;
						phandle = < 0x3a >;
					ina226@43 {
						label = "ina226-u84";
						reg = < 0x43 >;
						phandle = < 0x3b >;
					ina226@44 {
						label = "ina226-u16";
						reg = < 0x44 >;
						phandle = < 0x3c >;
					ina226@45 {
						label = "ina226-u65";
						reg = < 0x45 >;
						phandle = < 0x3d >;
					ina226@46 {
						label = "ina226-u74";
						reg = < 0x46 >;
						phandle = < 0x3e >;
					ina226@47 {
						label = "ina226-u75";
						reg = < 0x47 >;
						phandle = < 0x3f >;
				i2c@2 {
					reg = < 0x02 >;
					max15301@a {
						compatible = "maxim,max15301";
						reg = < 0x0a >;
					max15303@b {
						compatible = "maxim,max15303";
						reg = < 0x0b >;
					max15303@10 {
						reg = < 0x10 >;
					max15301@13 {
						reg = < 0x13 >;
					max15303@14 {
						reg = < 0x14 >;
					max15303@15 {
						reg = < 0x15 >;
					max15303@16 {
						reg = < 0x16 >;
					max15303@17 {
						reg = < 0x17 >;
					max15301@18 {
						reg = < 0x18 >;
					max15303@1a {
						reg = < 0x1a >;
					max15303@1d {
						reg = < 0x1d >;
					max20751@72 {
						compatible = "maxim,max20751";
						reg = < 0x72 >;
					max20751@73 {
						reg = < 0x73 >;
					max15303@1b {
						reg = < 0x1b >;
		i2c@ff030000 {
			status = "okay";
			interrupts = < 0x00 0x12 0x04 >;
			reg = < 0x00 0xff030000 0x00 0x1000 >;
			power-domains = < 0x0c 0x26 >;
			clocks = < 0x03 0x3e >;
			pinctrl-0 = < 0x15 >;
			pinctrl-1 = < 0x16 >;
			scl-gpios = < 0x14 0x10 0x00 >;
			sda-gpios = < 0x14 0x11 0x00 >;
			i2c-mux@74 {
				compatible = "nxp,pca9548";
				reg = < 0x74 >;
				i2c@0 {
					reg = < 0x00 >;
					eeprom@54 {
						compatible = "atmel,24c08";
						reg = < 0x54 >;
						board-sn@0 {
							reg = < 0x00 0x14 >;
						eth-mac@20 {
							reg = < 0x20 0x06 >;
						board-name@d0 {
							reg = < 0xd0 0x06 >;
						board-revision@e0 {
							reg = < 0xe0 0x03 >;
				i2c@1 {
					reg = < 0x01 >;
					clock-generator@36 {
						compatible = "silabs,si5341";
						reg = < 0x36 >;
				i2c@2 {
					reg = < 0x02 >;
					clock-generator@5d {
						#clock-cells = < 0x00 >;
						compatible = "silabs,si570";
						reg = < 0x5d >;
						temperature-stability = < 0x32 >;
						factory-fout = < 0x11e1a300 >;
						clock-frequency = < 0x11e1a300 >;
						clock-output-names = "si570_user";
				i2c@3 {
					reg = < 0x03 >;
						reg = < 0x5d >;
						factory-fout = < 0x9502f90 >;
						clock-frequency = < 0x8d9ee20 >;
						clock-output-names = "si570_mgt";
				i2c@4 {
					reg = < 0x04 >;
					clock-generator@69 {
						compatible = "silabs,si5328";
						reg = < 0x69 >;
			i2c-mux@75 {
				reg = < 0x75 >;
				i2c@0 {
					reg = < 0x00 >;
					eeprom@50 {
						compatible = "at24,24c02";
						reg = < 0x50 >;
				i2c@1 {
					reg = < 0x01 >;
				i2c@2 {
					reg = < 0x02 >;
				i2c@3 {
					reg = < 0x03 >;
				i2c@4 {
					reg = < 0x04 >;
				i2c@5 {
					reg = < 0x05 >;
				i2c@6 {
					reg = < 0x06 >;
				i2c@7 {
					reg = < 0x07 >;
		memory-controller@ff960000 {
			compatible = "xlnx,zynqmp-ocmc-1.0";
			reg = < 0x00 0xff960000 0x00 0x1000 >;
			interrupts = < 0x00 0x0a 0x04 >;
		perf-monitor@ffa00000 {
			compatible = "xlnx,axi-perf-monitor";
			reg = < 0x00 0xffa00000 0x00 0x10000 >;
			interrupts = < 0x00 0x19 0x04 >;
			xlnx,enable-profile = < 0x00 >;
			xlnx,enable-trace = < 0x00 >;
			xlnx,num-monitor-slots = < 0x01 >;
			xlnx,enable-event-count = < 0x01 >;
			xlnx,enable-event-log = < 0x01 >;
			xlnx,have-sampled-metric-cnt = < 0x01 >;
			xlnx,num-of-counters = < 0x08 >;
			xlnx,metric-count-width = < 0x20 >;
			xlnx,metrics-sample-count-width = < 0x20 >;
			xlnx,global-count-width = < 0x20 >;
			xlnx,metric-count-scale = < 0x01 >;
		perf-monitor@fd0b0000 {
			reg = < 0x00 0xfd0b0000 0x00 0x10000 >;
			interrupts = < 0x00 0x7b 0x04 >;
			xlnx,num-monitor-slots = < 0x06 >;
			xlnx,enable-event-log = < 0x00 >;
			xlnx,num-of-counters = < 0x0a >;
			clocks = < 0x03 0x1c >;
		perf-monitor@fd490000 {
			reg = < 0x00 0xfd490000 0x00 0x10000 >;
		perf-monitor@ffa10000 {
			reg = < 0x00 0xffa10000 0x00 0x10000 >;
		pcie@fd0e0000 {
			compatible = "xlnx,nwl-pcie-2.11";
			status = "okay";
			#address-cells = < 0x03 >;
			#interrupt-cells = < 0x01 >;
			msi-controller;
			device_type = "pci";
			interrupts = < 0x00 0x76 0x04 0x00 0x75 0x04 0x00 0x74 0x04 0x00 0x73 0x04 0x00 0x72 0x04 >;
			interrupt-names = "misc\0dummy\0intx\0msi1\0msi0";
			msi-parent = < 0x17 >;
			reg = < 0x00 0xfd0e0000 0x00 0x1000 0x00 0xfd480000 0x00 0x1000 0x80 0x00 0x00 0x1000000 >;
			reg-names = "breg\0pcireg\0cfg";
			ranges = < 0x2000000 0x00 0xe0000000 0x00 0xe0000000 0x00 0x10000000 0x43000000 0x06 0x00 0x06 0x00 0x02 0x00 >;
			bus-range = < 0x00 0xff >;
			interrupt-map-mask = < 0x00 0x00 0x00 0x07 >;
			interrupt-map = < 0x00 0x00 0x00 0x01 0x18 0x01 0x00 0x00 0x00 0x02 0x18 0x02 0x00 0x00 0x00 0x03 0x18 0x03 0x00 0x00 0x00 0x04 0x18 0x04 >;
			power-domains = < 0x0c 0x3b >;
			clocks = < 0x03 0x17 >;
			phandle = < 0x17 >;
			legacy-interrupt-controller {
				#address-cells = < 0x00 >;
				phandle = < 0x18 >;
		spi@ff0f0000 {
			compatible = "xlnx,zynqmp-qspi-1.0";
			status = "okay";
			clock-names = "ref_clk\0pclk";
			interrupts = < 0x00 0x0f 0x04 >;
			num-cs = < 0x01 >;
			reg = < 0x00 0xff0f0000 0x00 0x1000 0x00 0xc0000000 0x00 0x8000000 >;
			iommus = < 0x0e 0x873 >;
			power-domains = < 0x0c 0x2d >;
			clocks = < 0x03 0x35 0x03 0x1f >;
			is-dual = < 0x01 >;
			flash@0 {
				compatible = "m25p80\0jedec,spi-nor";
				reg = < 0x00 >;
				spi-tx-bus-width = < 0x01 >;
				spi-rx-bus-width = < 0x04 >;
				spi-max-frequency = < 0x66ff300 >;
				partition@0 {
					label = "qspi-fsbl-uboot";
					reg = < 0x00 0x100000 >;
				partition@100000 {
					label = "qspi-linux";
					reg = < 0x100000 0x500000 >;
				partition@600000 {
					label = "qspi-device-tree";
					reg = < 0x600000 0x20000 >;
				partition@620000 {
					label = "qspi-rootfs";
					reg = < 0x620000 0x5e0000 >;
		rtc@ffa60000 {
			compatible = "xlnx,zynqmp-rtc";
			status = "okay";
			reg = < 0x00 0xffa60000 0x00 0x100 >;
			interrupts = < 0x00 0x1a 0x04 0x00 0x1b 0x04 >;
			interrupt-names = "alarm\0sec";
			calibration = < 0x8000 >;
		zynqmp_phy@fd400000 {
			compatible = "xlnx,zynqmp-psgtr-v1.1";
			status = "okay";
			reg = < 0x00 0xfd400000 0x00 0x40000 0x00 0xfd3d0000 0x00 0x1000 >;
			reg-names = "serdes\0siou";
			nvmem-cells = < 0x19 >;
			nvmem-cell-names = "soc_revision";
			resets = < 0x1a 0x10 0x1a 0x3b 0x1a 0x3c 0x1a 0x3d 0x1a 0x3e 0x1a 0x3f 0x1a 0x40 0x1a 0x03 0x1a 0x1d 0x1a 0x1e 0x1a 0x1f 0x1a 0x20 >;
			reset-names = "sata_rst\0usb0_crst\0usb1_crst\0usb0_hibrst\0usb1_hibrst\0usb0_apbrst\0usb1_apbrst\0dp_rst\0gem0_rst\0gem1_rst\0gem2_rst\0gem3_rst";
			lane0 {
				#phy-cells = < 0x04 >;
			lane1 {
				phandle = < 0x29 >;
			lane2 {
				phandle = < 0x27 >;
			lane3 {
				phandle = < 0x1b >;
		ahci@fd0c0000 {
			compatible = "ceva,ahci-1v84";
			status = "okay";
			reg = < 0x00 0xfd0c0000 0x00 0x2000 >;
			interrupts = < 0x00 0x85 0x04 >;
			power-domains = < 0x0c 0x1c >;
			#stream-id-cells = < 0x04 >;
			clocks = < 0x03 0x16 >;
			ceva,p0-cominit-params = < 0x18401828 >;
			ceva,p0-comwake-params = < 0x614080e >;
			ceva,p0-burst-params = < 0x13084a06 >;
			ceva,p0-retry-params = < 0x96a43ffc >;
			ceva,p1-cominit-params = < 0x18401828 >;
			ceva,p1-comwake-params = < 0x614080e >;
			ceva,p1-burst-params = < 0x13084a06 >;
			ceva,p1-retry-params = < 0x96a43ffc >;
			phy-names = "sata-phy";
			phys = < 0x1b 0x01 0x01 0x01 0x7735940 >;
		mmc@ff160000 {
			compatible = "xlnx,zynqmp-8.9a\0arasan,sdhci-8.9a";
			interrupts = < 0x00 0x30 0x04 >;
			reg = < 0x00 0xff160000 0x00 0x1000 >;
			clock-names = "clk_xin\0clk_ahb";
			xlnx,device_id = < 0x00 >;
			iommus = < 0x0e 0x870 >;
			power-domains = < 0x0c 0x27 >;
			clock-output-names = "clk_out_sd0\0clk_in_sd0";
			clocks = < 0x03 0x36 0x03 0x1f >;
		mmc@ff170000 {
			status = "okay";
			interrupts = < 0x00 0x31 0x04 >;
			reg = < 0x00 0xff170000 0x00 0x1000 >;
			xlnx,device_id = < 0x01 >;
			iommus = < 0x0e 0x871 >;
			power-domains = < 0x0c 0x28 >;
			clock-output-names = "clk_out_sd1\0clk_in_sd1";
			clocks = < 0x03 0x37 0x03 0x1f >;
			no-1-8-v;
			pinctrl-0 = < 0x1c >;
			xlnx,mio-bank = < 0x01 >;
		spi@ff040000 {
			compatible = "cdns,spi-r1p6";
			status = "okay";
			interrupts = < 0x00 0x13 0x04 >;
			reg = < 0x00 0xff040000 0x00 0x1000 >;
			power-domains = < 0x0c 0x23 >;
			clocks = < 0x03 0x3a 0x03 0x1f >;
			ad9986@0 {
				compatible = "adi,ad9986";
				reg = < 0x00 >;
				spi-max-frequency = < 0x4c4b40 >;
				clocks = < 0x1d 0x02 >;
				clock-names = "dev_clk";
				clock-output-names = "rx_sampl_clk\0tx_sampl_clk";
				jesd204-device;
				#jesd204-cells = < 0x02 >;
				jesd204-top-device = < 0x00 >;
				jesd204-link-ids = < 0x02 0x00 >;
				jesd204-inputs = < 0x1e 0x00 0x02 0x1f 0x00 0x00 >;
				reset-gpios = < 0x14 0x85 0x00 >;
				sysref-req-gpios = < 0x14 0x79 0x00 >;
				rx2-enable-gpios = < 0x14 0x87 0x00 >;
				rx1-enable-gpios = < 0x14 0x86 0x00 >;
				tx2-enable-gpios = < 0x14 0x89 0x00 >;
				tx1-enable-gpios = < 0x14 0x88 0x00 >;
				phandle = < 0x41 >;
				adi,tx-dacs {
					adi,dac-frequency-hz = < 0x02 0xcb417800 >;
					adi,main-data-paths {
						adi,interpolation = < 0x08 >;
						dac@0 {
							reg = < 0x00 >;
							adi,crossbar-select = < 0x20 >;
							adi,nco-frequency-shift-hz = < 0x00 0x3b9aca00 >;
						dac@1 {
							reg = < 0x01 >;
							adi,crossbar-select = < 0x21 >;
							adi,nco-frequency-shift-hz = < 0x00 0x4190ab00 >;
					adi,channelizer-paths {
						adi,interpolation = < 0x01 >;
						channel@0 {
							reg = < 0x00 >;
							adi,gain = < 0x800 >;
							adi,nco-frequency-shift-hz = < 0x00 0x00 >;
							phandle = < 0x20 >;
						channel@1 {
							reg = < 0x01 >;
							phandle = < 0x21 >;
					adi,jesd-links {
						link@0 {
							reg = < 0x00 >;
							adi,converter-select = < 0x20 0x00 0x20 0x01 0x21 0x00 0x21 0x01 >;
							adi,logical-lane-mapping = < 0x20706 0x1050403 >;
							adi,link-mode = < 0x11 >;
							adi,subclass = < 0x01 >;
							adi,version = < 0x01 >;
							adi,dual-link = < 0x00 >;
							adi,converters-per-device = < 0x04 >;
							adi,octets-per-frame = < 0x01 >;
							adi,frames-per-multiframe = < 0x20 >;
							adi,converter-resolution = < 0x10 >;
							adi,bits-per-sample = < 0x10 >;
							adi,control-bits-per-sample = < 0x00 >;
							adi,lanes-per-device = < 0x08 >;
							adi,samples-per-converter-per-frame = < 0x01 >;
							adi,high-density = < 0x01 >;
							adi,tpl-phase-adjust = < 0x06 >;
				adi,rx-adcs {
					adi,adc-frequency-hz = < 0x01 0x65a0bc00 >;
						adc@0 {
							reg = < 0x00 >;
							adi,decimation = < 0x04 >;
							adi,nco-mode = < 0x00 >;
						adc@1 {
							reg = < 0x01 >;
						channel@0 {
							reg = < 0x00 >;
							adi,decimation = < 0x01 >;
							phandle = < 0x22 >;
						channel@1 {
							reg = < 0x01 >;
							phandle = < 0x23 >;
					adi,jesd-links {
						link@0 {
							reg = < 0x00 >;
							adi,converter-select = < 0x22 0x00 0x22 0x01 0x23 0x00 0x23 0x01 >;
							adi,logical-lane-mapping = < 0x2000706 0x5040301 >;
							adi,link-mode = < 0x12 >;
		spi@ff050000 {
			status = "okay";
			interrupts = < 0x00 0x14 0x04 >;
			reg = < 0x00 0xff050000 0x00 0x1000 >;
			power-domains = < 0x0c 0x24 >;
			clocks = < 0x03 0x3b 0x03 0x1f >;
			hmc7044@0 {
				compatible = "adi,hmc7044";
				reg = < 0x00 >;
				spi-max-frequency = < 0xf4240 >;
				jesd204-device;
				jesd204-sysref-provider;
				adi,jesd204-max-sysref-frequency-hz = < 0x1e8480 >;
				adi,pll1-clkin-frequencies = < 0x7530000 0x1d4c000 0x00 0x00 >;
				adi,vcxo-frequency = < 0x7530000 >;
				adi,pll1-loop-bandwidth-hz = < 0xc8 >;
				adi,pll2-output-frequency = < 0xb2d05e00 >;
				adi,sysref-timer-divider = < 0x400 >;
				adi,pulse-generator-mode = < 0x00 >;
				adi,clkin0-buffer-mode = < 0x07 >;
				adi,clkin1-buffer-mode = < 0x07 >;
				adi,oscin-buffer-mode = < 0x15 >;
				adi,gpi-controls = < 0x00 0x00 0x00 0x00 >;
				adi,gpo-controls = < 0x37 0x33 0x00 0x00 >;
				clock-output-names = "hmc7044_out0\0hmc7044_out1\0hmc7044_out2\0hmc7044_out3\0hmc7044_out4\0hmc7044_out5\0hmc7044_out6\0hmc7044_out7\0hmc7044_out8\0hmc7044_out9\0hmc7044_out10\0hmc7044_out11\0hmc7044_out12\0hmc7044_out13";
				phandle = < 0x1d >;
				channel@0 {
					reg = < 0x00 >;
					adi,extended-name = "CORE_CLK_RX";
					adi,divider = < 0x0c >;
					adi,driver-mode = < 0x02 >;
				channel@2 {
					reg = < 0x02 >;
					adi,extended-name = "DEV_REFCLK";
				channel@3 {
					reg = < 0x03 >;
					adi,extended-name = "DEV_SYSREF";
					adi,divider = < 0x600 >;
					adi,jesd204-sysref-chan;
				channel@6 {
					reg = < 0x06 >;
					adi,extended-name = "CORE_CLK_TX";
				channel@8 {
					reg = < 0x08 >;
					adi,extended-name = "FPGA_REFCLK1";
					adi,divider = < 0x06 >;
				channel@10 {
					reg = < 0x0a >;
					adi,extended-name = "CORE_CLK_RX_ALT";
				channel@12 {
					reg = < 0x0c >;
					adi,extended-name = "FPGA_REFCLK2";
				channel@13 {
					reg = < 0x0d >;
					adi,extended-name = "FPGA_SYSREF";
		timer@ff110000 {
			compatible = "cdns,ttc";
			interrupts = < 0x00 0x24 0x04 0x00 0x25 0x04 0x00 0x26 0x04 >;
			reg = < 0x00 0xff110000 0x00 0x1000 >;
			timer-width = < 0x20 >;
			power-domains = < 0x0c 0x18 >;
		timer@ff120000 {
			interrupts = < 0x00 0x27 0x04 0x00 0x28 0x04 0x00 0x29 0x04 >;
			reg = < 0x00 0xff120000 0x00 0x1000 >;
			power-domains = < 0x0c 0x19 >;
		timer@ff130000 {
			interrupts = < 0x00 0x2a 0x04 0x00 0x2b 0x04 0x00 0x2c 0x04 >;
			reg = < 0x00 0xff130000 0x00 0x1000 >;
			power-domains = < 0x0c 0x1a >;
		timer@ff140000 {
			interrupts = < 0x00 0x2d 0x04 0x00 0x2e 0x04 0x00 0x2f 0x04 >;
			reg = < 0x00 0xff140000 0x00 0x1000 >;
			power-domains = < 0x0c 0x1b >;
		serial@ff000000 {
			compatible = "cdns,uart-r1p12\0xlnx,xuartps";
			status = "okay";
			interrupts = < 0x00 0x15 0x04 >;
			reg = < 0x00 0xff000000 0x00 0x1000 >;
			clock-names = "uart_clk\0pclk";
			power-domains = < 0x0c 0x21 >;
			clocks = < 0x03 0x38 0x03 0x1f >;
			pinctrl-0 = < 0x24 >;
		serial@ff010000 {
			status = "okay";
			interrupts = < 0x00 0x16 0x04 >;
			reg = < 0x00 0xff010000 0x00 0x1000 >;
			power-domains = < 0x0c 0x22 >;
			clocks = < 0x03 0x39 0x03 0x1f >;
			pinctrl-0 = < 0x25 >;
		usb0@ff9d0000 {
			status = "okay";
			compatible = "xlnx,zynqmp-dwc3";
			reg = < 0x00 0xff9d0000 0x00 0x100 >;
			clock-names = "bus_clk\0ref_clk";
			power-domains = < 0x0c 0x16 >;
			ranges;
			clocks = < 0x03 0x20 0x03 0x22 >;
			pinctrl-0 = < 0x26 >;
			dwc3@fe200000 {
				compatible = "snps,dwc3";
				status = "okay";
				reg = < 0x00 0xfe200000 0x00 0x40000 >;
				interrupt-names = "dwc_usb3\0otg\0hiber";
				interrupts = < 0x00 0x41 0x04 0x00 0x45 0x04 0x00 0x4b 0x04 >;
				iommus = < 0x0e 0x860 >;
				snps,quirk-frame-length-adjustment = < 0x20 >;
				snps,refclk_fladj;
				snps,enable_guctl1_resume_quirk;
				snps,enable_guctl1_ipd_quirk;
				snps,xhci-stream-quirk;
				dr_mode = "host";
				snps,usb3_lpm_capable;
				phy-names = "usb3-phy";
				phys = < 0x27 0x04 0x00 0x02 0x18cba80 >;
				maximum-speed = "super-speed";
		usb1@ff9e0000 {
			reg = < 0x00 0xff9e0000 0x00 0x100 >;
			power-domains = < 0x0c 0x17 >;
			ranges;
			clocks = < 0x03 0x21 0x03 0x22 >;
			dwc3@fe300000 {
				reg = < 0x00 0xfe300000 0x00 0x40000 >;
				interrupts = < 0x00 0x46 0x04 0x00 0x4a 0x04 0x00 0x4c 0x04 >;
				iommus = < 0x0e 0x861 >;
				snps,refclk_fladj;
		watchdog@fd4d0000 {
			compatible = "cdns,wdt-r1p2";
			status = "okay";
			interrupts = < 0x00 0x71 0x01 >;
			reg = < 0x00 0xfd4d0000 0x00 0x1000 >;
			timeout-sec = < 0x3c >;
			reset-on-timeout;
			clocks = < 0x03 0x4b >;
		watchdog@ff150000 {
			interrupts = < 0x00 0x34 0x01 >;
			reg = < 0x00 0xff150000 0x00 0x1000 >;
			timeout-sec = < 0x0a >;
			clocks = < 0x03 0x70 >;
		ams@ffa50000 {
			compatible = "xlnx,zynqmp-ams";
			status = "okay";
			interrupts = < 0x00 0x38 0x04 >;
			interrupt-names = "ams-irq";
			reg = < 0x00 0xffa50000 0x00 0x800 >;
			reg-names = "ams-base";
			ranges;
			clocks = < 0x03 0x46 >;
			ams_ps@ffa50800 {
				compatible = "xlnx,zynqmp-ams-ps";
				status = "okay";
				reg = < 0x00 0xffa50800 0x00 0x400 >;
			ams_pl@ffa50c00 {
				compatible = "xlnx,zynqmp-ams-pl";
				status = "okay";
				reg = < 0x00 0xffa50c00 0x00 0x400 >;
		dma@fd4c0000 {
			compatible = "xlnx,dpdma";
			status = "okay";
			reg = < 0x00 0xfd4c0000 0x00 0x1000 >;
			interrupts = < 0x00 0x7a 0x04 >;
			clock-names = "axi_clk";
			power-domains = < 0x0c 0x29 >;
			dma-channels = < 0x06 >;
			#dma-cells = < 0x01 >;
			clocks = < 0x03 0x14 >;
			phandle = < 0x2a >;
			dma-video0channel {
				compatible = "xlnx,video0";
			dma-video1channel {
				compatible = "xlnx,video1";
			dma-video2channel {
				compatible = "xlnx,video2";
			dma-graphicschannel {
				compatible = "xlnx,graphics";
			dma-audio0channel {
				compatible = "xlnx,audio0";
			dma-audio1channel {
				compatible = "xlnx,audio1";
		zynqmp-display@fd4a0000 {
			compatible = "xlnx,zynqmp-dpsub-1.7";
			status = "okay";
			reg = < 0x00 0xfd4a0000 0x00 0x1000 0x00 0xfd4aa000 0x00 0x1000 0x00 0xfd4ab000 0x00 0x1000 0x00 0xfd4ac000 0x00 0x1000 >;
			reg-names = "dp\0blend\0av_buf\0aud";
			interrupts = < 0x00 0x77 0x04 >;
			clock-names = "dp_apb_clk\0dp_aud_clk\0dp_vtc_pixel_clk_in";
			clocks = < 0x28 0x03 0x11 0x03 0x10 >;
			phy-names = "dp-phy0";
			phys = < 0x29 0x06 0x00 0x03 0x19bfcc0 >;
			vid-layer {
				dma-names = "vid0\0vid1\0vid2";
				dmas = < 0x2a 0x00 0x2a 0x01 0x2a 0x02 >;
			gfx-layer {
				dma-names = "gfx0";
				dmas = < 0x2a 0x03 >;
			i2c-bus {
			zynqmp_dp_snd_codec0 {
				compatible = "xlnx,dp-snd-codec";
				clock-names = "aud_clk";
				clocks = < 0x03 0x11 >;
				status = "okay";
				phandle = < 0x2d >;
			zynqmp_dp_snd_pcm0 {
				compatible = "xlnx,dp-snd-pcm";
				dmas = < 0x2a 0x04 >;
				dma-names = "tx";
				status = "okay";
				phandle = < 0x2b >;
			zynqmp_dp_snd_pcm1 {
				dmas = < 0x2a 0x05 >;
				dma-names = "tx";
				status = "okay";
				phandle = < 0x2c >;
			zynqmp_dp_snd_card {
				compatible = "xlnx,dp-snd-card";
				xlnx,dp-snd-pcm = < 0x2b 0x2c >;
				xlnx,dp-snd-codec = < 0x2d >;
				status = "okay";
	fclk0 {
		status = "okay";
		compatible = "xlnx,fclk";
		clocks = < 0x03 0x47 >;
	fclk1 {
		status = "okay";
		clocks = < 0x03 0x48 >;
	fclk2 {
		status = "okay";
		clocks = < 0x03 0x49 >;
	fclk3 {
		status = "okay";
		clocks = < 0x03 0x4a >;
	pss_ref_clk {
		compatible = "fixed-clock";
		clock-frequency = < 0x1fca055 >;
		phandle = < 0x06 >;
	video_clk {
		clock-frequency = < 0x19bfcc0 >;
		phandle = < 0x07 >;
	pss_alt_ref_clk {
		clock-frequency = < 0x00 >;
		phandle = < 0x08 >;
	gt_crx_ref_clk {
		clock-frequency = < 0x66ff300 >;
		phandle = < 0x0a >;
	aux_ref_clk {
		phandle = < 0x09 >;
	dp_aclk {
		clock-frequency = < 0x5f5e100 >;
		clock-accuracy = < 0x64 >;
		phandle = < 0x28 >;
	aliases {
		ethernet0 = "/amba/ethernet@ff0e0000";
		gpio0 = "/amba/gpio@ff0a0000";
		i2c0 = "/amba/i2c@ff020000";
		i2c1 = "/amba/i2c@ff030000";
		mmc0 = "/amba/mmc@ff170000";
		rtc0 = "/amba/rtc@ffa60000";
		serial0 = "/amba/serial@ff000000";
		serial1 = "/amba/serial@ff010000";
		serial2 = "/dcc";
		spi0 = "/amba/spi@ff0f0000";
		usb0 = "/amba/usb0@ff9d0000";
	chosen {
		bootargs = "earlycon";
		stdout-path = "serial0:115200n8";
		xlnx,eeprom = "/amba/i2c@ff030000/i2c-mux@74/i2c@0/eeprom@54";
	memory@0 {
		device_type = "memory";
		reg = < 0x00 0x00 0x00 0x80000000 0x08 0x00 0x00 0x80000000 >;
	gpio-keys {
		compatible = "gpio-keys";
		autorepeat;
		sw19 {
			label = "sw19";
			gpios = < 0x14 0x16 0x00 >;
			linux,code = < 0x6c >;
			wakeup-source;
			autorepeat;
	leds {
		compatible = "gpio-leds";
		heartbeat-led {
			label = "heartbeat";
			gpios = < 0x14 0x17 0x00 >;
			linux,default-trigger = "heartbeat";
	ina226-u76 {
		compatible = "iio-hwmon";
		io-channels = < 0x2e 0x00 0x2e 0x01 0x2e 0x02 0x2e 0x03 >;
	ina226-u77 {
		io-channels = < 0x2f 0x00 0x2f 0x01 0x2f 0x02 0x2f 0x03 >;
	ina226-u78 {
		io-channels = < 0x30 0x00 0x30 0x01 0x30 0x02 0x30 0x03 >;
	ina226-u87 {
		io-channels = < 0x31 0x00 0x31 0x01 0x31 0x02 0x31 0x03 >;
	ina226-u85 {
		io-channels = < 0x32 0x00 0x32 0x01 0x32 0x02 0x32 0x03 >;
	ina226-u86 {
		io-channels = < 0x33 0x00 0x33 0x01 0x33 0x02 0x33 0x03 >;
	ina226-u93 {
		io-channels = < 0x34 0x00 0x34 0x01 0x34 0x02 0x34 0x03 >;
	ina226-u88 {
		io-channels = < 0x35 0x00 0x35 0x01 0x35 0x02 0x35 0x03 >;
	ina226-u15 {
		io-channels = < 0x36 0x00 0x36 0x01 0x36 0x02 0x36 0x03 >;
	ina226-u92 {
		io-channels = < 0x37 0x00 0x37 0x01 0x37 0x02 0x37 0x03 >;
	ina226-u79 {
		io-channels = < 0x38 0x00 0x38 0x01 0x38 0x02 0x38 0x03 >;
	ina226-u81 {
		io-channels = < 0x39 0x00 0x39 0x01 0x39 0x02 0x39 0x03 >;
	ina226-u80 {
		io-channels = < 0x3a 0x00 0x3a 0x01 0x3a 0x02 0x3a 0x03 >;
	ina226-u84 {
		io-channels = < 0x3b 0x00 0x3b 0x01 0x3b 0x02 0x3b 0x03 >;
	ina226-u16 {
		io-channels = < 0x3c 0x00 0x3c 0x01 0x3c 0x02 0x3c 0x03 >;
	ina226-u65 {
		io-channels = < 0x3d 0x00 0x3d 0x01 0x3d 0x02 0x3d 0x03 >;
	ina226-u74 {
		io-channels = < 0x3e 0x00 0x3e 0x01 0x3e 0x02 0x3e 0x03 >;
	ina226-u75 {
		io-channels = < 0x3f 0x00 0x3f 0x01 0x3f 0x02 0x3f 0x03 >;
	fpga-axi@0 {
		ranges = < 0x00 0x00 0x00 0xffffffff >;
		dma@9c420000 {
			compatible = "adi,axi-dmac-1.00.a";
			reg = < 0x9c420000 0x10000 >;
			interrupts = < 0x00 0x6d 0x04 >;
			phandle = < 0x40 >;
		dma@9c430000 {
			reg = < 0x9c430000 0x10000 >;
			interrupts = < 0x00 0x6c 0x04 >;
			phandle = < 0x43 >;
		axi-ad9081-rx-hpc@84a10000 {
			compatible = "adi,axi-ad9081-rx-1.0";
			reg = < 0x84a10000 0x8000 >;
			dmas = < 0x40 0x00 >;
			dma-names = "rx";
			spibus-connected = < 0x41 >;
			jesd204-device;
			jesd204-inputs = < 0x42 0x00 0x02 >;
			phandle = < 0x1e >;
		axi-ad9081-tx-hpc@84b10000 {
			compatible = "adi,axi-ad9081-tx-1.0";
			reg = < 0x84b10000 0x4000 >;
			dmas = < 0x43 0x00 >;
			dma-names = "tx";
			clocks = < 0x41 0x01 >;
			clock-names = "sampl_clk";
			jesd204-device;
			jesd204-inputs = < 0x44 0x00 0x00 >;
			plddrbypass-gpios = < 0x14 0x8a 0x00 >;
			phandle = < 0x1f >;
		axi-jesd204-rx@84a90000 {
			compatible = "adi,axi-jesd204-rx-1.0";
			reg = < 0x84a90000 0x1000 >;
			interrupts = < 0x00 0x6b 0x04 >;
			clocks = < 0x03 0x47 0x1d 0x0a 0x45 0x00 >;
			clock-names = "s_axi_aclk\0device_clk\0lane_clk";
			clock-output-names = "jesd_rx_lane_clk";
			jesd204-device;
			jesd204-inputs = < 0x45 0x00 0x02 >;
			phandle = < 0x42 >;
		axi-jesd204-tx@84b90000 {
			compatible = "adi,axi-jesd204-tx-1.0";
			reg = < 0x84b90000 0x1000 >;
			interrupts = < 0x00 0x6a 0x04 >;
			clocks = < 0x03 0x47 0x1d 0x06 0x46 0x00 >;
			clock-output-names = "jesd_tx_lane_clk";
			jesd204-device;
			jesd204-inputs = < 0x46 0x00 0x00 >;
			phandle = < 0x44 >;
		axi-adxcvr-rx@84a60000 {
			compatible = "adi,axi-adxcvr-1.0";
			reg = < 0x84a60000 0x1000 >;
			clocks = < 0x1d 0x0c >;
			clock-names = "conv";
			clock-output-names = "rx_gt_clk\0rx_out_clk";
			adi,sys-clk-select = < 0x03 >;
			adi,out-clk-select = < 0x04 >;
			adi,use-lpm-enable;
			jesd204-device;
			jesd204-inputs = < 0x1d 0x00 0x02 >;
			phandle = < 0x45 >;
		axi-adxcvr-tx@84b60000 {
			reg = < 0x84b60000 0x1000 >;
			clock-output-names = "tx_gt_clk\0tx_out_clk";
			jesd204-device;
			jesd204-inputs = < 0x1d 0x00 0x00 >;
			phandle = < 0x46 >;
		axi-sysid-0@85000000 {
			compatible = "adi,axi-sysid-1.00.a";
			reg = < 0x85000000 0x10000 >;
New Devicetree:
system_lowrate.dts.txt
Boot Log:
root@analog:~# dmesg
[    4.491156] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.498113] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.505057] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.512001] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.518950] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.525340] i2c i2c-0: Added multiplexed i2c bus 4
[    4.573570] i2c i2c-0: Added multiplexed i2c bus 5
[    4.578505] i2c i2c-0: Added multiplexed i2c bus 6
[    4.583300] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[    4.590643] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 24
[    4.598367] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[    4.605112] i2c i2c-1: Added multiplexed i2c bus 7
[    4.610210] i2c i2c-1: Added multiplexed i2c bus 8
[    4.617827] si570 9-005d: registered, current frequency 300000000 Hz
[    4.624219] i2c i2c-1: Added multiplexed i2c bus 9
[    4.643890] si570 10-005d: registered, current frequency 148500000 Hz
[    4.650373] i2c i2c-1: Added multiplexed i2c bus 10
[    4.655457] si5324 11-0069: si5328 probed
[    4.721614] si5324 11-0069: si5328 probe successful
[    4.726531] i2c i2c-1: Added multiplexed i2c bus 11
[    4.731556] i2c i2c-1: Added multiplexed i2c bus 12
[    4.736582] i2c i2c-1: Added multiplexed i2c bus 13
[    4.741537] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    4.748669] i2c i2c-1: Added multiplexed i2c bus 14
[    4.753545] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[    4.761816] at24 15-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    4.768555] i2c i2c-1: Added multiplexed i2c bus 15
[    4.773608] i2c i2c-1: Added multiplexed i2c bus 16
[    4.778639] i2c i2c-1: Added multiplexed i2c bus 17
[    4.783664] i2c i2c-1: Added multiplexed i2c bus 18
[    4.788708] i2c i2c-1: Added multiplexed i2c bus 19
[    4.793740] i2c i2c-1: Added multiplexed i2c bus 20
[    4.798774] i2c i2c-1: Added multiplexed i2c bus 21
[    4.803815] i2c i2c-1: Added multiplexed i2c bus 22
[    4.808685] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[    4.816296] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 25
[    4.825963] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
[    4.868368] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[    4.877131] axi_adxcvr 84a60000.axi-adxcvr-rx: adxcvr_enforce_settings: Using QPLL without access, assuming desired Lane rate will be configured by a different instance
[    4.893660] axi_adxcvr 84a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) using QPLL on GTH4 at 0x84A60000. Number of lanes: 8.
[    4.905736] axi_adxcvr 84b60000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using QPLL on GTH4 at 0x84B60000. Number of lanes: 8.
[    4.917415] axi-jesd204-rx 84a90000.axi-jesd204-rx: AXI-JESD204-RX (1.04.a) at 0x84A90000. Encoder 8b10b, width 4/0, lanes 8, jesd204-fsm.
[    4.930181] axi-jesd204-tx 84b90000.axi-jesd204-tx: AXI-JESD204-TX (1.03.a) at 0x84B90000. Encoder 8b10b, width 4/0, lanes 8, jesd204-fsm.
[    4.943522] usb 2-1: New USB device found, idVendor=2109, idProduct=0813, bcdDevice=90.11
[    4.951696] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.958829] usb 2-1: Product: USB3.0 Hub
[    4.962741] usb 2-1: Manufacturer: VIA Labs, Inc.
[    5.003360] mmc0: new high speed SDXC card at address 59b4
[    5.009192] mmcblk0: mmc0:59b4 GD2S5 119 GiB
[    5.015215]  mmcblk0: p1 p2 p3
[    5.025845] hub 2-1:1.0: USB hub found
[    5.029694] hub 2-1:1.0: 4 ports detected
[    5.279880] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    5.433438] usb 1-1: New USB device found, idVendor=2109, idProduct=2813, bcdDevice=90.11
[    5.441613] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.448745] usb 1-1: Product: USB2.0 Hub
[    5.452666] usb 1-1: Manufacturer: VIA Labs, Inc.
[    5.521887] hub 1-1:1.0: USB hub found
[    5.525832] hub 1-1:1.0: 4 ports detected
[    5.875874] usb 1-1.2: new low-speed USB device number 3 using xhci-hcd
[    5.900860] ad9081 spi1.0: AD9081 Rev. 3 Grade 2 (API 1.1.1) probed
[    5.935613] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: ADI AIM (10.01.b) at 0x84A10000 mapped to 0x(____ptrval____), probed ADC AD9081 as MASTER
[    5.968347] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84B10000 mapped to 0x(____ptrval____), probed DDS AD9081
[    5.982548] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition initialized -> probed
[    5.993156] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition initialized -> probed
[    6.003766] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition probed -> idle
[    6.013764] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition probed -> idle
[    6.023765] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
[    6.034196] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
[    6.039415] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c077, bcdDevice=72.00
[    6.044630] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
[    6.052963] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.063823] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
[    6.063836] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: profile0:link_num2 param M mismatch 4!=16*1
[    6.071121] usb 1-1.2: Product: USB Optical Mouse
[    6.071125] usb 1-1.2: Manufacturer: Logitech
[    6.081983] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: profile0:link_num2 param F mismatch 1!=4
[    6.081986] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: JESD param mismatch between TPL and Link configuration !
[    6.117700] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: profile0:link_num0 param M mismatch 4!=16*1
[    6.126307] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: profile0:link_num0 param F mismatch 1!=4
[    6.131710] input: Logitech USB Optical Mouse as /devices/platform/amba/ff9d0000.usb0/fe200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C077.0001/input/input0
[    6.134649] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: JESD param mismatch between TPL and Link configuration !
[    6.134656] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
[    6.150216] hid-generic 0003:046D:C077.0001: input: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-xhci-hcd.0.auto-1.2/input0
[    6.159844] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
[    6.183057] hmc7044 spi2.0: hmc7044_jesd204_link_pre_setup: Link2 forcing continuous SYSREF mode
[    6.203094] axi-jesd204-rx 84a90000.axi-jesd204-rx: axi_jesd204_rx_jesd204_link_pre_setup: Link2 set REFCLK to device/link rate 614400000 Hz failed (-22)
[    6.217139] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
[    6.228702] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
[    6.251921] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
[    6.263565] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
[    6.275217] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
[    6.286949] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
[    6.298681] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
[    6.310412] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
[    6.323152] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
[    6.331869] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd
[    6.334450] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
[    6.357307] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
[    6.368690] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
[    6.385639] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
[    6.397545] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
[    6.409698] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
[    6.421610] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
[    6.433520] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
[    6.445426] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
[    6.457333] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage5
[    6.469240] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5
[    6.486269] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> clocks_enable
[    6.497912] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> clocks_enable
[    6.498279] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=49.00
[    6.517906] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.525217] usb 1-1.3: Product: USB Keyboard
[    6.525229] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clocks_enable -> link_enable
[    6.529479] usb 1-1.3: Manufacturer: Logitech
[    6.545030] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clocks_enable -> link_enable
[    6.615752] input: Logitech USB Keyboard as /devices/platform/amba/ff9d0000.usb0/fe200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0002/input/input1
[    6.688179] hid-generic 0003:046D:C31C.0002: input: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input0
[    6.699873] axi-jesd204-tx 84b90000.axi-jesd204-tx: axi_jesd204_tx_jesd204_link_running: Link0 status failed (ILAS)
[    6.703641] input: Logitech USB Keyboard as /devices/platform/amba/ff9d0000.usb0/fe200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0003/input/input2
[    6.710508] jesd204: /fpga-axi@0/axi-jesd204-tx@84b90000,jesd204:5,parent=84b90000.axi-jesd204-tx: JESD204[0] got error from cb: -1
[    6.710515] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: Rolling back from 'link_enable', got error -1
[    6.748122] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_enable -> link_running
[    6.759247] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_enable -> link_running
[    6.770454] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_running -> link_enable
[    6.781578] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_running -> link_enable
[    6.783941] hid-generic 0003:046D:C31C.0003: input: USB HID v1.10 Device [Logitech USB Keyboard] on usb-xhci-hcd.0.auto-1.3/input1
[    6.808495] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_enable -> clocks_enable
[    6.819703] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_enable -> clocks_enable
[    6.830913] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clocks_enable -> opt_setup_stage5
[    6.842557] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clocks_enable -> opt_setup_stage5
[    6.854203] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4
[    6.866109] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> opt_setup_stage4
[    6.878014] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3
[    6.889922] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage3
[    6.901827] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2
[    6.913734] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage2
[    6.925636] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1
[    6.937536] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage1
[    6.949442] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> link_setup
[    6.960826] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> link_setup
[    6.972211] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> clk_sync_stage3
[    6.983510] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> clk_sync_stage3
[    6.994806] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2
[    7.006540] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> clk_sync_stage2
[    7.018271] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
[    7.030004] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
[    7.041735] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
[    7.053382] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
[    7.065030] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> link_supported
[    7.076586] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> link_supported
[    7.088144] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_init
[    7.099268] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_init
[    7.110391] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> device_init
[    7.121257] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> device_init
[    7.132120] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
[    7.142550] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
[    7.152980] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> idle
[    7.162804] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> idle
[    7.172626] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
[    7.183056] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
[    7.193486] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
[    7.204351] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
[    7.215216] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: profile0:link_num2 param M mismatch 4!=16*1
[    7.223821] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: profile0:link_num2 param F mismatch 1!=4
[    7.232162] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: JESD param mismatch between TPL and Link configuration !
[    7.241897] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: profile0:link_num0 param M mismatch 4!=16*1
[    7.250498] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: profile0:link_num0 param F mismatch 1!=4
[    7.258837] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: JESD param mismatch between TPL and Link configuration !
[    7.268571] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
[    7.279692] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
[    7.290960] axi-jesd204-rx 84a90000.axi-jesd204-rx: axi_jesd204_rx_jesd204_link_pre_setup: Link2 set REFCLK to device/link rate 614400000 Hz failed (-22)
[    7.304835] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
[    7.316398] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
[    7.340304] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
[    7.351955] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
[    7.363604] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
[    7.375337] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
[    7.387069] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
[    7.398804] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
[    7.411542] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
[    7.422840] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
[    7.439090] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
[    7.450474] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
[    7.467420] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
[    7.479327] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
[    7.491475] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
[    7.503384] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
[    7.515295] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
[    7.527200] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
[    7.539107] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage5
[    7.551014] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5
[    7.568037] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> clocks_enable
[    7.579679] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> clocks_enable
[    7.591396] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clocks_enable -> link_enable
[    7.602604] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clocks_enable -> link_enable
[    7.623480] random: crng init done
[    7.755879] axi-jesd204-tx 84b90000.axi-jesd204-tx: axi_jesd204_tx_jesd204_link_running: Link0 status failed (ILAS)
[    7.766308] jesd204: /fpga-axi@0/axi-jesd204-tx@84b90000,jesd204:5,parent=84b90000.axi-jesd204-tx: JESD204[0] got error from cb: -1
[    7.778123] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: Rolling back from 'link_enable', got error -1
[    7.788897] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_enable -> link_running
[    7.800023] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_enable -> link_running
[    7.811309] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_running -> link_enable
[    7.822432] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_running -> link_enable
[    7.837664] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_enable -> clocks_enable
[    7.848871] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_enable -> clocks_enable
[    7.860081] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clocks_enable -> opt_setup_stage5
[    7.871728] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clocks_enable -> opt_setup_stage5
[    7.883372] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4
[    7.895278] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> opt_setup_stage4
[    7.907183] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3
[    7.919093] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage3
[    7.931004] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2
[    7.942910] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage2
[    7.954815] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1
[    7.966722] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage1
[    7.978628] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> link_setup
[    7.990013] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> link_setup
[    8.001395] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> clk_sync_stage3
[    8.012699] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> clk_sync_stage3
[    8.024002] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2
[    8.035735] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> clk_sync_stage2
[    8.047466] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
[    8.059199] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
[    8.070931] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
[    8.082578] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
[    8.094221] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> link_supported
[    8.105780] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> link_supported
[    8.117338] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_init
[    8.128464] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_init
[    8.139587] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> device_init
[    8.150452] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> device_init
[    8.161315] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
[    8.171746] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
[    8.182177] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> idle
[    8.191999] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> idle
[    8.201821] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
[    8.212252] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
[    8.222681] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
[    8.233546] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
[    8.244410] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: profile0:link_num2 param M mismatch 4!=16*1
[    8.253016] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: profile0:link_num2 param F mismatch 1!=4
[    8.261357] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: JESD param mismatch between TPL and Link configuration !
[    8.271096] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: profile0:link_num0 param M mismatch 4!=16*1
[    8.279702] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: profile0:link_num0 param F mismatch 1!=4
[    8.288043] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: JESD param mismatch between TPL and Link configuration !
[    8.297775] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
[    8.308894] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
[    8.320200] axi-jesd204-rx 84a90000.axi-jesd204-rx: axi_jesd204_rx_jesd204_link_pre_setup: Link2 set REFCLK to device/link rate 614400000 Hz failed (-22)
[    8.334082] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
[    8.345645] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
[    8.369503] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
[    8.381150] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
[    8.392800] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
[    8.404533] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
[    8.416263] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
[    8.427999] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
[    8.440741] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
[    8.452036] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
[    8.468285] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
[    8.479669] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
[    8.496558] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
[    8.508462] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
[    8.520606] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
[    8.532511] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
[    8.544421] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
[    8.556326] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
[    8.568234] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage5
[    8.580139] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5
[    8.597163] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> clocks_enable
[    8.608803] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> clocks_enable
[    8.620510] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clocks_enable -> link_enable
[    8.631721] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clocks_enable -> link_enable
[    8.783869] axi-jesd204-tx 84b90000.axi-jesd204-tx: axi_jesd204_tx_jesd204_link_running: Link0 status failed (CGS)
[    8.794210] jesd204: /fpga-axi@0/axi-jesd204-tx@84b90000,jesd204:5,parent=84b90000.axi-jesd204-tx: JESD204[0] got error from cb: -1
[    8.806025] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: Rolling back from 'link_enable', got error -1
[    8.816799] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_enable -> link_running
[    8.827925] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_enable -> link_running
[    8.839121] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_running -> link_enable
[    8.850246] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_running -> link_enable
[    8.865434] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_enable -> clocks_enable
[    8.876643] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_enable -> clocks_enable
[    8.887852] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clocks_enable -> opt_setup_stage5
[    8.899499] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clocks_enable -> opt_setup_stage5
[    8.911143] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4
[    8.923048] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> opt_setup_stage4
[    8.934955] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3
[    8.946863] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage3
[    8.958774] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2
[    8.970682] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage2
[    8.982587] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1
[    8.994494] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage1
[    9.006399] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> link_setup
[    9.017785] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> link_setup
[    9.029169] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> clk_sync_stage3
[    9.040469] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> clk_sync_stage3
[    9.051774] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2
[    9.063506] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> clk_sync_stage2
[    9.075236] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
[    9.086971] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
[    9.098702] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
[    9.110347] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
[    9.121993] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> link_supported
[    9.133552] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> link_supported
[    9.145108] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_init
[    9.156236] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_init
[    9.167358] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> device_init
[    9.178224] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> device_init
[    9.189086] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
[    9.199518] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
[    9.209947] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> idle
[    9.219771] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> idle
[    9.229592] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition idle -> device_init
[    9.240023] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition idle -> device_init
[    9.250451] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> link_init
[    9.261317] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> link_init
[    9.272181] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: profile0:link_num2 param M mismatch 4!=16*1
[    9.280787] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: profile0:link_num2 param F mismatch 1!=4
[    9.289128] cf_axi_adc 84a10000.axi-ad9081-rx-hpc: JESD param mismatch between TPL and Link configuration !
[    9.298867] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: profile0:link_num0 param M mismatch 4!=16*1
[    9.307472] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: profile0:link_num0 param F mismatch 1!=4
[    9.315813] cf_axi_dds 84b10000.axi-ad9081-tx-hpc: JESD param mismatch between TPL and Link configuration !
[    9.325547] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> link_supported
[    9.336666] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> link_supported
[    9.347932] axi-jesd204-rx 84a90000.axi-jesd204-rx: axi_jesd204_rx_jesd204_link_pre_setup: Link2 set REFCLK to device/link rate 614400000 Hz failed (-22)
[    9.361810] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_pre_setup
[    9.373373] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_pre_setup
[    9.397226] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> clk_sync_stage1
[    9.408868] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> clk_sync_stage1
[    9.420519] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> clk_sync_stage2
[    9.432252] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> clk_sync_stage2
[    9.443984] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage3
[    9.455718] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage3
[    9.468460] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> link_setup
[    9.479754] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> link_setup
[    9.496006] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> opt_setup_stage1
[    9.507397] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> opt_setup_stage1
[    9.524306] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> opt_setup_stage2
[    9.536220] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> opt_setup_stage2
[    9.548372] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage3
[    9.560281] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage3
[    9.572192] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage4
[    9.584098] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage4
[    9.596005] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage5
[    9.607910] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage5
[    9.624934] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> clocks_enable
[    9.636586] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> clocks_enable
[    9.648296] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clocks_enable -> link_enable
[    9.659509] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clocks_enable -> link_enable
[    9.788146] ad9081 spi1.0: JESD RX (JTX) Link2 in DATA, SYNC deasserted, PLL locked, PHASE established, MODE valid
[    9.880165] ad9081 spi1.0: JESD TX (JRX) Link0 0x0 lanes in DATA
[    9.886167] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] got error from cb: -1
[    9.895811] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: Rolling back from 'link_enable', got error -1
[    9.906585] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_enable -> link_running
[    9.917703] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_enable -> link_running
[    9.929004] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_running -> link_enable
[    9.940131] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_running -> link_enable
[    9.955344] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_enable -> clocks_enable
[    9.966552] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_enable -> clocks_enable
[    9.977760] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clocks_enable -> opt_setup_stage5
[    9.989408] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clocks_enable -> opt_setup_stage5
[   10.001052] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage5 -> opt_setup_stage4
[   10.012960] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage5 -> opt_setup_stage4
[   10.024863] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage4 -> opt_setup_stage3
[   10.036771] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage4 -> opt_setup_stage3
[   10.048675] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage3 -> opt_setup_stage2
[   10.060584] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage3 -> opt_setup_stage2
[   10.072488] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage2 -> opt_setup_stage1
[   10.084394] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage2 -> opt_setup_stage1
[   10.096300] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition opt_setup_stage1 -> link_setup
[   10.107684] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition opt_setup_stage1 -> link_setup
[   10.119069] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_setup -> clk_sync_stage3
[   10.130368] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_setup -> clk_sync_stage3
[   10.141668] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage3 -> clk_sync_stage2
[   10.153400] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage3 -> clk_sync_stage2
[   10.165129] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage2 -> clk_sync_stage1
[   10.176862] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage2 -> clk_sync_stage1
[   10.188593] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition clk_sync_stage1 -> link_pre_setup
[   10.200240] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition clk_sync_stage1 -> link_pre_setup
[   10.211884] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_pre_setup -> link_supported
[   10.223443] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_pre_setup -> link_supported
[   10.235001] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_supported -> link_init
[   10.246128] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_supported -> link_init
[   10.257250] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition link_init -> device_init
[   10.268115] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition link_init -> device_init
[   10.278978] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[0] transition device_init -> idle
[   10.289408] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: JESD204[2] transition device_init -> idle
[   10.299835] jesd204: /amba/spi@ff040000/ad9986@0,jesd204:0,parent=spi1.0: FSM completed with error -1
[   10.318136] input: gpio-keys as /devices/platform/gpio-keys/input/input3
[   10.325177] rtc_zynqmp ffa60000.rtc: setting system clock to 2023-08-10T22:59:49 UTC (1691708389)
[   10.334049] of_cfs_init
[   10.336513] of_cfs_init: OK
[   10.339439] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   10.473898] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   10.480427] clk: Not disabling unused clocks
[   10.484957] ALSA device list:
[   10.487920]   #0: DisplayPort monitor
[   10.491853] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   10.500462] cfg80211: failed to load regulatory.db
[   10.516118] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[   10.524233] VFS: Mounted root (ext4 filesystem) on device 179:2.
[   10.537554] devtmpfs: mounted
[   10.540667] Freeing unused kernel memory: 704K
[   10.545140] Run /sbin/init as init process
[   11.114304] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[   11.136190] systemd[1]: Detected architecture arm64.
[   11.160513] systemd[1]: Set hostname to <analog>.
[   11.333918] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[   11.350965] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[   11.503512] systemd[1]: /etc/systemd/system/tof-server.service:1: Assignment outside of section. Ignoring.
[   11.513193] systemd[1]: /etc/systemd/system/tof-server.service:2: Assignment outside of section. Ignoring.
[   11.690195] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   11.712533] systemd[1]: Created slice system-getty.slice.
[   11.732086] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   12.489841] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   12.676689] systemd-journald[181]: Received request to flush runtime journal from PID 1
[   18.241617] pps pps0: new PPS source ptp0
[   18.241630] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
[   18.242500] macb ff0e0000.ethernet eth0: link up (1000/Full)
[   18.242514] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   18.555901] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SS
root@analog:~#
Top Replies
  • cf_axi_adc 84a10000.axi-ad9081-rx-hpc: JESD param mismatch between TPL and Link configuration !
    The main problem is that you didn't rebuild your HDL with the proper link parameters for your…
