I'm trying to use an FMCOMMS5 on a ZCU706, and use the blocks on the GNU radio to interact with the transceiver. I'm running the latest version of Kuiper Linux directly on the board and the flow desing on GNU Radio is as follows:
Although it worked perfectly on IIO Oscilloscope, when trying to run the above flow design the following error appears:
I'm running GNURadio 3.8.2.0 (Python 3.9.2) on $ sudo gnuradio-companion directly on the ZCU706 running Kuiper Linux 2022-08-04-ADI-Kuiper-full. The board also appears when $ iio_info is used (output content bellow).
Library version: 0.24 (git tag: cc96e44) Compiled with backends: local xml ip usb serial IIO context created with local backend. Backend version: 0.24 (git tag: cc96e44) Backend description string: Linux analog 5.10.0-98248-g1bbe32fa5182 #1142 SMP PREEMPT Wed Aug 3 17:51:18 IST 2022 armv7l IIO context has 2 attributes: local,kernel: 5.10.0-98248-g1bbe32fa5182 uri: local: IIO context has 9 devices: iio:device0: ad7291 9 channels found: voltage6: (input) 2 channel-specific attributes found: attr 0: raw value: 1309 attr 1: scale value: 0.610351562 temp0: (input) 3 channel-specific attributes found: attr 0: mean_raw value: 144 attr 1: raw value: 143 attr 2: scale value: 250 voltage3: (input) 2 channel-specific attributes found: attr 0: raw value: 3637 attr 1: scale value: 0.610351562 voltage7: (input) 2 channel-specific attributes found: attr 0: raw value: 1306 attr 1: scale value: 0.610351562 voltage0: (input) 2 channel-specific attributes found: attr 0: raw value: 1820 attr 1: scale value: 0.610351562 voltage4: (input) 2 channel-specific attributes found: attr 0: raw value: 1303 attr 1: scale value: 0.610351562 voltage1: (input) 2 channel-specific attributes found: attr 0: raw value: 3284 attr 1: scale value: 0.610351562 voltage5: (input) 2 channel-specific attributes found: attr 0: raw value: 1318 attr 1: scale value: 0.610351562 voltage2: (input) 2 channel-specific attributes found: attr 0: raw value: 3320 attr 1: scale value: 0.610351562 No trigger on this device iio:device1: ad9361-phy 11 channels found: altvoltage1: TX_LO (output) 8 channel-specific attributes found: attr 0: external value: 0 attr 1: fastlock_load value: 0 attr 2: fastlock_recall ERROR: Invalid argument (22) attr 3: fastlock_save value: 0 230,215,255,246,245,254,230,230,254,86,246,230,230,253,230,246 attr 4: fastlock_store value: 0 attr 5: frequency value: 2400000000 attr 6: frequency_available value: [46875001 1 6000000000] attr 7: powerdown value: 0 voltage1: (output) 10 channel-specific attributes found: attr 0: filter_fir_en value: 0 attr 1: hardwaregain value: -10.000000 dB attr 2: hardwaregain_available value: [-89.750000 0.250000 0.000000] attr 3: rf_bandwidth value: 18000000 attr 4: rf_bandwidth_available value: [200000 1 40000000] attr 5: rf_port_select value: A attr 6: rf_port_select_available value: A B attr 7: rssi value: 0.00 dB attr 8: sampling_frequency value: 30720000 attr 9: sampling_frequency_available value: [2083333 1 61440000] voltage0: (input) 15 channel-specific attributes found: attr 0: bb_dc_offset_tracking_en value: 1 attr 1: filter_fir_en value: 0 attr 2: gain_control_mode value: slow_attack attr 3: gain_control_mode_available value: manual fast_attack slow_attack hybrid attr 4: hardwaregain value: 7.000000 dB attr 5: hardwaregain_available value: [-3 1 71] attr 6: quadrature_tracking_en value: 1 attr 7: rf_bandwidth value: 18000000 attr 8: rf_bandwidth_available value: [200000 1 56000000] attr 9: rf_dc_offset_tracking_en value: 1 attr 10: rf_port_select value: A_BALANCED attr 11: rf_port_select_available value: A_BALANCED B_BALANCED C_BALANCED A_N A_P B_N B_P C_N C_P TX_MONITOR1 TX_MONITOR2 TX_MONITOR1_2 attr 12: rssi value: 30.25 dB attr 13: sampling_frequency value: 30720000 attr 14: sampling_frequency_available value: [2083333 1 61440000] voltage1: (input) 15 channel-specific attributes found: attr 0: bb_dc_offset_tracking_en value: 1 attr 1: filter_fir_en value: 0 attr 2: gain_control_mode value: slow_attack attr 3: gain_control_mode_available value: manual fast_attack slow_attack hybrid attr 4: hardwaregain value: 7.000000 dB attr 5: hardwaregain_available value: [-3 1 71] attr 6: quadrature_tracking_en value: 1 attr 7: rf_bandwidth value: 18000000 attr 8: rf_bandwidth_available value: [200000 1 56000000] attr 9: rf_dc_offset_tracking_en value: 1 attr 10: rf_port_select value: A_BALANCED attr 11: rf_port_select_available value: A_BALANCED B_BALANCED C_BALANCED A_N A_P B_N B_P C_N C_P TX_MONITOR1 TX_MONITOR2 TX_MONITOR1_2 attr 12: rssi value: 30.00 dB attr 13: sampling_frequency value: 30720000 attr 14: sampling_frequency_available value: [2083333 1 61440000] voltage3: (output) 8 channel-specific attributes found: attr 0: filter_fir_en value: 0 attr 1: raw value: 306 attr 2: rf_bandwidth value: 18000000 attr 3: rf_bandwidth_available value: [200000 1 40000000] attr 4: rf_port_select_available value: A B attr 5: sampling_frequency value: 30720000 attr 6: sampling_frequency_available value: [2083333 1 61440000] attr 7: scale value: 1.000000 altvoltage0: RX_LO (output) 8 channel-specific attributes found: attr 0: external value: 0 attr 1: fastlock_load value: 0 attr 2: fastlock_recall ERROR: Invalid argument (22) attr 3: fastlock_save value: 0 69,101,182,101,69,69,69,117,77,227,69,69,69,69,69,69 attr 4: fastlock_store value: 0 attr 5: frequency value: 2400000000 attr 6: frequency_available value: [70000000 1 6000000000] attr 7: powerdown value: 0 voltage2: (output) 8 channel-specific attributes found: attr 0: filter_fir_en value: 0 attr 1: raw value: 306 attr 2: rf_bandwidth value: 18000000 attr 3: rf_bandwidth_available value: [200000 1 40000000] attr 4: rf_port_select_available value: A B attr 5: sampling_frequency value: 30720000 attr 6: sampling_frequency_available value: [2083333 1 61440000] attr 7: scale value: 1.000000 temp0: (input) 1 channel-specific attributes found: attr 0: input value: 35965 voltage0: (output) 10 channel-specific attributes found: attr 0: filter_fir_en value: 0 attr 1: hardwaregain value: -10.000000 dB attr 2: hardwaregain_available value: [-89.750000 0.250000 0.000000] attr 3: rf_bandwidth value: 18000000 attr 4: rf_bandwidth_available value: [200000 1 40000000] attr 5: rf_port_select value: A attr 6: rf_port_select_available value: A B attr 7: rssi value: 0.00 dB attr 8: sampling_frequency value: 30720000 attr 9: sampling_frequency_available value: [2083333 1 61440000] voltage2: (input) 13 channel-specific attributes found: attr 0: bb_dc_offset_tracking_en value: 1 attr 1: filter_fir_en value: 0 attr 2: gain_control_mode_available value: manual fast_attack slow_attack hybrid attr 3: offset value: 57 attr 4: quadrature_tracking_en value: 1 attr 5: raw value: 1057 attr 6: rf_bandwidth value: 18000000 attr 7: rf_bandwidth_available value: [200000 1 56000000] attr 8: rf_dc_offset_tracking_en value: 1 attr 9: rf_port_select_available value: A_BALANCED B_BALANCED C_BALANCED A_N A_P B_N B_P C_N C_P TX_MONITOR1 TX_MONITOR2 TX_MONITOR1_2 attr 10: sampling_frequency value: 30720000 attr 11: sampling_frequency_available value: [2083333 1 61440000] attr 12: scale value: 0.305250 out: (input, WARN:iio_channel_get_type()=UNKNOWN) 1 channel-specific attributes found: attr 0: voltage_filter_fir_en value: 0 18 device-specific attributes found: attr 0: calib_mode value: auto attr 1: calib_mode_available value: auto manual manual_tx_quad tx_quad rf_dc_offs rssi_gain_step attr 2: dcxo_tune_coarse ERROR: No such device (19) attr 3: dcxo_tune_coarse_available value: [0 0 0] attr 4: dcxo_tune_fine ERROR: No such device (19) attr 5: dcxo_tune_fine_available value: [0 0 0] attr 6: ensm_mode value: fdd attr 7: ensm_mode_available value: sleep wait alert fdd pinctrl pinctrl_fdd_indep attr 8: filter_fir_config value: FIR Rx: 0,0 Tx: 0,0 attr 9: gain_table_config value: <gaintable AD9361 type=FULL dest=3 start=1300000000 end=4000000000> -3, 0x00, 0x00, 0x20 -3, 0x00, 0x00, 0x00 -3, 0x00, 0x00, 0x00 -2, 0x00, 0x01, 0x00 -1, 0x00, 0x02, 0x00 0, 0x00, 0x03, 0x00 1, 0x00, 0x04, 0x00 2, 0x00, 0x05, 0x00 3, 0x01, 0x03, 0x20 4, 0x01, 0x04, 0x00 5, 0x01, 0x05, 0x00 6, 0x01, 0x06, 0x00 7, 0x01, 0x07, 0x00 8, 0x01, 0x08, 0x00 9, 0x01, 0x09, 0x00 10, 0x01, 0x0A, 0x00 11, 0x01, 0x0B, 0x00 12, 0x01, 0x0C, 0x00 13, 0x01, 0x0D, 0x00 14, 0x01, 0x0E, 0x00 15, 0x02, 0x09, 0x20 16, 0x02, 0x0A, 0x00 17, 0x02, 0x0B, 0x00 18, 0x02, 0x0C, 0x00 19, 0x02, 0x0D, 0x00 20, 0x02, 0x0E, 0x00 21, 0x02, 0x0F, 0x00 22, 0x02, 0x10, 0x00 23, 0x02, 0x2B, 0x20 24, 0x02, 0x2C, 0x00 25, 0x04, 0x27, 0x20 26, 0x04, 0x28, 0x00 27, 0x04, 0x29, 0x00 28, 0x04, 0x2A, 0x00 29, 0x04, 0x2B, 0x00 30, 0x24, 0x21, 0x20 31, 0x24, 0x22, 0x00 32, 0x44, 0x20, 0x20 33, 0x44, 0x21, 0x00 34, 0x44, 0x22, 0x00 35, 0x44, 0x23, 0x00 36, 0x44, 0x24, 0x00 37, 0x44, 0x25, 0x00 38, 0x44, 0x26, 0x00 39, 0x44, 0x27, 0x00 40, 0x44, 0x28, 0x00 41, 0x44, 0x29, 0x00 42, 0x44, 0x2A, 0x00 43, 0x44, 0x2B, 0x00 44, 0x44, 0x2C, 0x00 45, 0x44, 0x2D, 0x00 46, 0x44, 0x2E, 0x00 47, 0x44, 0x2F, 0x00 48, 0x44, 0x30, 0x00 49, 0x44, 0x31, 0x00 50, 0x64, 0x2E, 0x20 51, 0x64, 0x2F, 0x00 52, 0x64, 0x30, 0x00 53, 0x64, 0x31, 0x00 54, 0x64, 0x32, 0x00 55, 0x64, 0x33, 0x00 56, 0x64, 0x34, 0x00 57, 0x64, 0x35, 0x00 58, 0x64, 0x36, 0x00 59, 0x64, 0x37, 0x00 60, 0x64, 0x38, 0x00 61, 0x65, 0x38, 0x20 62, 0x66, 0x38, 0x20 63, 0x67, 0x38, 0x20 64, 0x68, 0x38, 0x20 65, 0x69, 0x38, 0x20 66, 0x6A, 0x38, 0x20 67, 0x6B, 0x38, 0x20 68, 0x6C, 0x38, 0x20 69, 0x6D, 0x38, 0x20 70, 0x6E, 0x38, 0x20 71, 0x6F, 0x38, 0x20 </gaintable> attr 10: multichip_sync ERROR: Permission denied (13) attr 11: rssi_gain_step_error value: lna_error: 0 0 0 0 mixer_error: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 gain_step_calib_reg_val: 0 0 0 0 0 attr 12: rx_path_rates value: BBPLL:983040000 ADC:245760000 R2:122880000 R1:61440000 RF:30720000 RXSAMP:30720000 attr 13: trx_rate_governor value: nominal attr 14: trx_rate_governor_available value: nominal highest_osr attr 15: tx_path_rates value: BBPLL:983040000 DAC:122880000 T2:122880000 T1:61440000 TF:30720000 TXSAMP:30720000 attr 16: xo_correction value: 40000000 attr 17: xo_correction_available value: [39992000 1 40008000] 182 debug attributes found: debug attr 0: digital_tune value: 0 debug attr 1: calibration_switch_control value: 0 debug attr 2: multichip_sync value: 0 debug attr 3: gaininfo_rx2 value: 7 12 0 0 0 0 0 0 debug attr 4: gaininfo_rx1 value: 7 12 0 0 0 0 0 0 debug attr 5: bist_timing_analysis value: 0 debug attr 6: gpo_set value: 0 debug attr 7: bist_tone value: 0 debug attr 8: bist_prbs value: 0 debug attr 9: loopback value: 0 debug attr 10: initialize value: 0 debug attr 11: adi,bb-clk-change-dig-tune-enable value: 0 debug attr 12: adi,axi-half-dac-rate-enable value: 0 debug attr 13: adi,txmon-2-lo-cm value: 48 debug attr 14: adi,txmon-1-lo-cm value: 48 debug attr 15: adi,txmon-2-front-end-gain value: 2 debug attr 16: adi,txmon-1-front-end-gain value: 2 debug attr 17: adi,txmon-duration value: 8192 debug attr 18: adi,txmon-delay value: 511 debug attr 19: adi,txmon-one-shot-mode-enable value: 0 debug attr 20: adi,txmon-dc-tracking-enable value: 0 debug attr 21: adi,txmon-high-gain value: 24 debug attr 22: adi,txmon-low-gain value: 0 debug attr 23: adi,txmon-low-high-thresh value: 37000 debug attr 24: adi,gpo3-tx-delay-us value: 0 debug attr 25: adi,gpo3-rx-delay-us value: 0 debug attr 26: adi,gpo2-tx-delay-us value: 0 debug attr 27: adi,gpo2-rx-delay-us value: 0 debug attr 28: adi,gpo1-tx-delay-us value: 0 debug attr 29: adi,gpo1-rx-delay-us value: 0 debug attr 30: adi,gpo0-tx-delay-us value: 0 debug attr 31: adi,gpo0-rx-delay-us value: 0 debug attr 32: adi,gpo3-slave-tx-enable value: 0 debug attr 33: adi,gpo3-slave-rx-enable value: 0 debug attr 34: adi,gpo2-slave-tx-enable value: 0 debug attr 35: adi,gpo2-slave-rx-enable value: 0 debug attr 36: adi,gpo1-slave-tx-enable value: 0 debug attr 37: adi,gpo1-slave-rx-enable value: 0 debug attr 38: adi,gpo0-slave-tx-enable value: 0 debug attr 39: adi,gpo0-slave-rx-enable value: 0 debug attr 40: adi,gpo3-inactive-state-high-enable value: 0 debug attr 41: adi,gpo2-inactive-state-high-enable value: 0 debug attr 42: adi,gpo1-inactive-state-high-enable value: 0 debug attr 43: adi,gpo0-inactive-state-high-enable value: 0 debug attr 44: adi,gpo-manual-mode-enable-mask value: 0 debug attr 45: adi,gpo-manual-mode-enable value: 0 debug attr 46: adi,aux-dac2-tx-delay-us value: 0 debug attr 47: adi,aux-dac2-rx-delay-us value: 0 debug attr 48: adi,aux-dac2-active-in-alert-enable value: 0 debug attr 49: adi,aux-dac2-active-in-tx-enable value: 0 debug attr 50: adi,aux-dac2-active-in-rx-enable value: 0 debug attr 51: adi,aux-dac2-default-value-mV value: 0 debug attr 52: adi,aux-dac1-tx-delay-us value: 0 debug attr 53: adi,aux-dac1-rx-delay-us value: 0 debug attr 54: adi,aux-dac1-active-in-alert-enable value: 0 debug attr 55: adi,aux-dac1-active-in-tx-enable value: 0 debug attr 56: adi,aux-dac1-active-in-rx-enable value: 0 debug attr 57: adi,aux-dac1-default-value-mV value: 0 debug attr 58: adi,aux-dac-manual-mode-enable value: 1 debug attr 59: adi,aux-adc-decimation value: 256 debug attr 60: adi,aux-adc-rate value: 40000000 debug attr 61: adi,temp-sense-decimation value: 256 debug attr 62: adi,temp-sense-periodic-measurement-enable value: 1 debug attr 63: adi,temp-sense-offset-signed value: 206 debug attr 64: adi,temp-sense-measurement-interval-ms value: 1000 debug attr 65: adi,elna-gaintable-all-index-enable value: 0 debug attr 66: adi,elna-rx2-gpo1-control-enable value: 0 debug attr 67: adi,elna-rx1-gpo0-control-enable value: 0 debug attr 68: adi,elna-bypass-loss-mdB value: 0 debug attr 69: adi,elna-gain-mdB value: 0 debug attr 70: adi,elna-settling-delay-ns value: 0 debug attr 71: adi,ctrl-outs-enable-mask value: 255 debug attr 72: adi,ctrl-outs-index value: 0 debug attr 73: adi,rssi-duration value: 1000 debug attr 74: adi,rssi-wait value: 1 debug attr 75: adi,rssi-delay value: 1 debug attr 76: adi,rssi-unit-is-rx-samples-enable value: 0 debug attr 77: adi,rssi-restart-mode value: 3 debug attr 78: adi,fagc-adc-large-overload-inc-steps value: 2 debug attr 79: adi,fagc-power-measurement-duration-in-state5 value: 64 debug attr 80: adi,fagc-rst-gla-if-en-agc-pulled-high-mode value: 0 debug attr 81: adi,fagc-rst-gla-en-agc-pulled-high-enable value: 0 debug attr 82: adi,fagc-rst-gla-large-lmt-overload-enable value: 1 debug attr 83: adi,fagc-rst-gla-large-adc-overload-enable value: 1 debug attr 84: adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt value: 8 debug attr 85: adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll value: 10 debug attr 86: adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable value: 1 debug attr 87: adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable value: 1 debug attr 88: adi,fagc-rst-gla-stronger-sig-thresh-above-ll value: 10 debug attr 89: adi,fagc-optimized-gain-offset value: 5 debug attr 90: adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable value: 1 debug attr 91: adi,fagc-use-last-lock-level-for-set-gain-enable value: 1 debug attr 92: adi,fagc-gain-index-type-after-exit-rx-mode value: 0 debug attr 93: adi,fagc-gain-increase-after-gain-lock-enable value: 0 debug attr 94: adi,fagc-final-overrange-count value: 3 debug attr 95: adi,fagc-lmt-final-settling-steps value: 1 debug attr 96: adi,fagc-lpf-final-settling-steps value: 1 debug attr 97: adi,fagc-lock-level-gain-increase-upper-limit value: 5 debug attr 98: adi,fagc-lock-level-lmt-gain-increase-enable value: 1 debug attr 99: adi,fagc-lp-thresh-increment-steps value: 1 debug attr 100: adi,fagc-lp-thresh-increment-time value: 5 debug attr 101: adi,fagc-allow-agc-gain-increase-enable value: 0 debug attr 102: adi,fagc-state-wait-time-ns value: 260 debug attr 103: adi,fagc-dec-pow-measurement-duration value: 64 debug attr 104: adi,agc-immed-gain-change-if-large-lmt-overload-enable value: 0 debug attr 105: adi,agc-immed-gain-change-if-large-adc-overload-enable value: 0 debug attr 106: adi,agc-gain-update-interval-us value: 1000 debug attr 107: adi,agc-sync-for-gain-counter-enable value: 0 debug attr 108: adi,agc-dig-gain-step-size value: 4 debug attr 109: adi,agc-dig-saturation-exceed-counter value: 3 debug attr 110: adi,agc-lmt-overload-large-inc-steps value: 2 debug attr 111: adi,agc-lmt-overload-small-exceed-counter value: 10 debug attr 112: adi,agc-lmt-overload-large-exceed-counter value: 10 debug attr 113: adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable value: 0 debug attr 114: adi,agc-adc-large-overload-inc-steps value: 2 debug attr 115: adi,agc-adc-large-overload-exceed-counter value: 10 debug attr 116: adi,agc-adc-small-overload-exceed-counter value: 10 debug attr 117: adi,agc-outer-thresh-low-inc-steps value: 2 debug attr 118: adi,agc-outer-thresh-low value: 18 debug attr 119: adi,agc-inner-thresh-low-inc-steps value: 1 debug attr 120: adi,agc-inner-thresh-low value: 12 debug attr 121: adi,agc-inner-thresh-high-dec-steps value: 1 debug attr 122: adi,agc-inner-thresh-high value: 10 debug attr 123: adi,agc-outer-thresh-high-dec-steps value: 2 debug attr 124: adi,agc-outer-thresh-high value: 5 debug attr 125: adi,agc-attack-delay-extra-margin-us value: 1 debug attr 126: adi,mgc-split-table-ctrl-inp-gain-mode value: 0 debug attr 127: adi,mgc-dec-gain-step value: 2 debug attr 128: adi,mgc-inc-gain-step value: 2 debug attr 129: adi,mgc-rx2-ctrl-inp-enable value: 0 debug attr 130: adi,mgc-rx1-ctrl-inp-enable value: 0 debug attr 131: adi,gc-use-rx-fir-out-for-dec-pwr-meas-enable value: 0 debug attr 132: adi,gc-max-dig-gain value: 15 debug attr 133: adi,gc-dig-gain-enable value: 0 debug attr 134: adi,gc-low-power-thresh value: 24 debug attr 135: adi,gc-dec-pow-measurement-duration value: 8192 debug attr 136: adi,gc-lmt-overload-low-thresh value: 704 debug attr 137: adi,gc-lmt-overload-high-thresh value: 800 debug attr 138: adi,gc-adc-large-overload-thresh value: 58 debug attr 139: adi,gc-adc-small-overload-thresh value: 47 debug attr 140: adi,gc-adc-ovr-sample-size value: 4 debug attr 141: adi,gc-rx2-mode value: 2 debug attr 142: adi,gc-rx1-mode value: 2 debug attr 143: adi,update-tx-gain-in-alert-enable value: 0 debug attr 144: adi,tx-attenuation-mdB value: 10000 debug attr 145: adi,rf-tx-bandwidth-hz value: 18000000 debug attr 146: adi,rf-rx-bandwidth-hz value: 18000000 debug attr 147: adi,qec-tracking-slow-mode-enable value: 0 debug attr 148: adi,dc-offset-count-low-range value: 50 debug attr 149: adi,dc-offset-count-high-range value: 40 debug attr 150: adi,dc-offset-attenuation-low-range value: 5 debug attr 151: adi,dc-offset-attenuation-high-range value: 6 debug attr 152: adi,dc-offset-tracking-update-event-mask value: 5 debug attr 153: adi,clk-output-mode-select value: 0 debug attr 154: adi,external-rx-lo-enable value: 0 debug attr 155: adi,external-tx-lo-enable value: 0 debug attr 156: adi,xo-disable-use-ext-refclk-enable value: 1 debug attr 157: adi,tx-lo-powerdown-managed-enable value: 1 debug attr 158: adi,trx-synthesizer-target-fref-overwrite-hz value: 80008000 debug attr 159: adi,rx1-rx2-phase-inversion-enable value: 1 debug attr 160: adi,tx-rf-port-input-select-lock-enable value: 0 debug attr 161: adi,rx-rf-port-input-select-lock-enable value: 0 debug attr 162: adi,tx-rf-port-input-select value: 0 debug attr 163: adi,rx-rf-port-input-select value: 0 debug attr 164: adi,split-gain-table-mode-enable value: 0 debug attr 165: adi,1rx-1tx-mode-use-tx-num value: 1 debug attr 166: adi,1rx-1tx-mode-use-rx-num value: 1 debug attr 167: adi,2rx-2tx-mode-enable value: 1 debug attr 168: adi,digital-interface-tune-fir-disable value: 0 debug attr 169: adi,digital-interface-tune-skip-mode value: 0 debug attr 170: adi,tx-fastlock-pincontrol-enable value: 0 debug attr 171: adi,rx-fastlock-pincontrol-enable value: 0 debug attr 172: adi,rx-fastlock-delay-ns value: 0 debug attr 173: adi,tx-fastlock-delay-ns value: 0 debug attr 174: adi,tdd-skip-vco-cal-enable value: 0 debug attr 175: adi,tdd-use-dual-synth-mode-enable value: 0 debug attr 176: adi,debug-mode-enable value: 0 debug attr 177: adi,ensm-enable-txnrx-control-enable value: 0 debug attr 178: adi,ensm-enable-pin-pulse-mode-enable value: 0 debug attr 179: adi,frequency-division-duplex-independent-mode-enable value: 0 debug attr 180: adi,frequency-division-duplex-mode-enable value: 1 debug attr 181: direct_reg_access value: 0x0 No trigger on this device iio:device2: ad9361-phy-B 11 channels found: altvoltage1: TX_LO (output) 8 channel-specific attributes found: attr 0: external value: 0 attr 1: fastlock_load value: 0 attr 2: fastlock_recall ERROR: Invalid argument (22) attr 3: fastlock_save value: 0 114,112,112,112,48,191,252,112,120,112,112,80,112,126,112,112 attr 4: fastlock_store value: 0 attr 5: frequency value: 2400000000 attr 6: frequency_available value: [46875001 1 6000000000] attr 7: powerdown value: 0 voltage1: (output) 10 channel-specific attributes found: attr 0: filter_fir_en value: 0 attr 1: hardwaregain value: -10.000000 dB attr 2: hardwaregain_available value: [-89.750000 0.250000 0.000000] attr 3: rf_bandwidth value: 18000000 attr 4: rf_bandwidth_available value: [200000 1 40000000] attr 5: rf_port_select value: A attr 6: rf_port_select_available value: A B attr 7: rssi value: 0.00 dB attr 8: sampling_frequency value: 30720000 attr 9: sampling_frequency_available value: [2083333 1 61440000] voltage0: (input) 15 channel-specific attributes found: attr 0: bb_dc_offset_tracking_en value: 1 attr 1: filter_fir_en value: 0 attr 2: gain_control_mode value: slow_attack attr 3: gain_control_mode_available value: manual fast_attack slow_attack hybrid attr 4: hardwaregain value: 8.000000 dB attr 5: hardwaregain_available value: [-3 1 71] attr 6: quadrature_tracking_en value: 1 attr 7: rf_bandwidth value: 18000000 attr 8: rf_bandwidth_available value: [200000 1 56000000] attr 9: rf_dc_offset_tracking_en value: 1 attr 10: rf_port_select value: A_BALANCED attr 11: rf_port_select_available value: A_BALANCED B_BALANCED C_BALANCED A_N A_P B_N B_P C_N C_P TX_MONITOR1 TX_MONITOR2 TX_MONITOR1_2 attr 12: rssi value: 30.50 dB attr 13: sampling_frequency value: 30720000 attr 14: sampling_frequency_available value: [2083333 1 61440000] voltage1: (input) 15 channel-specific attributes found: attr 0: bb_dc_offset_tracking_en value: 1 attr 1: filter_fir_en value: 0 attr 2: gain_control_mode value: slow_attack attr 3: gain_control_mode_available value: manual fast_attack slow_attack hybrid attr 4: hardwaregain value: 7.000000 dB attr 5: hardwaregain_available value: [-3 1 71] attr 6: quadrature_tracking_en value: 1 attr 7: rf_bandwidth value: 18000000 attr 8: rf_bandwidth_available value: [200000 1 56000000] attr 9: rf_dc_offset_tracking_en value: 1 attr 10: rf_port_select value: A_BALANCED attr 11: rf_port_select_available value: A_BALANCED B_BALANCED C_BALANCED A_N A_P B_N B_P C_N C_P TX_MONITOR1 TX_MONITOR2 TX_MONITOR1_2 attr 12: rssi value: 30.25 dB attr 13: sampling_frequency value: 30720000 attr 14: sampling_frequency_available value: [2083333 1 61440000] voltage3: (output) 8 channel-specific attributes found: attr 0: filter_fir_en value: 0 attr 1: raw value: 306 attr 2: rf_bandwidth value: 18000000 attr 3: rf_bandwidth_available value: [200000 1 40000000] attr 4: rf_port_select_available value: A B attr 5: sampling_frequency value: 30720000 attr 6: sampling_frequency_available value: [2083333 1 61440000] attr 7: scale value: 1.000000 altvoltage0: RX_LO (output) 8 channel-specific attributes found: attr 0: external value: 0 attr 1: fastlock_load value: 0 attr 2: fastlock_recall ERROR: Invalid argument (22) attr 3: fastlock_save value: 0 93,127,249,244,249,249,249,217,249,249,249,191,249,241,249,245 attr 4: fastlock_store value: 0 attr 5: frequency value: 2400000000 attr 6: frequency_available value: [70000000 1 6000000000] attr 7: powerdown value: 0 voltage2: (output) 8 channel-specific attributes found: attr 0: filter_fir_en value: 0 attr 1: raw value: 306 attr 2: rf_bandwidth value: 18000000 attr 3: rf_bandwidth_available value: [200000 1 40000000] attr 4: rf_port_select_available value: A B attr 5: sampling_frequency value: 30720000 attr 6: sampling_frequency_available value: [2083333 1 61440000] attr 7: scale value: 1.000000 temp0: (input) 1 channel-specific attributes found: attr 0: input value: 35088 voltage0: (output) 10 channel-specific attributes found: attr 0: filter_fir_en value: 0 attr 1: hardwaregain value: -10.000000 dB attr 2: hardwaregain_available value: [-89.750000 0.250000 0.000000] attr 3: rf_bandwidth value: 18000000 attr 4: rf_bandwidth_available value: [200000 1 40000000] attr 5: rf_port_select value: A attr 6: rf_port_select_available value: A B attr 7: rssi value: 0.00 dB attr 8: sampling_frequency value: 30720000 attr 9: sampling_frequency_available value: [2083333 1 61440000] voltage2: (input) 13 channel-specific attributes found: attr 0: bb_dc_offset_tracking_en value: 1 attr 1: filter_fir_en value: 0 attr 2: gain_control_mode_available value: manual fast_attack slow_attack hybrid attr 3: offset value: 57 attr 4: quadrature_tracking_en value: 1 attr 5: raw value: 1454 attr 6: rf_bandwidth value: 18000000 attr 7: rf_bandwidth_available value: [200000 1 56000000] attr 8: rf_dc_offset_tracking_en value: 1 attr 9: rf_port_select_available value: A_BALANCED B_BALANCED C_BALANCED A_N A_P B_N B_P C_N C_P TX_MONITOR1 TX_MONITOR2 TX_MONITOR1_2 attr 10: sampling_frequency value: 30720000 attr 11: sampling_frequency_available value: [2083333 1 61440000] attr 12: scale value: 0.305250 out: (input, WARN:iio_channel_get_type()=UNKNOWN) 1 channel-specific attributes found: attr 0: voltage_filter_fir_en value: 0 18 device-specific attributes found: attr 0: calib_mode value: auto attr 1: calib_mode_available value: auto manual manual_tx_quad tx_quad rf_dc_offs rssi_gain_step attr 2: dcxo_tune_coarse ERROR: No such device (19) attr 3: dcxo_tune_coarse_available value: [0 0 0] attr 4: dcxo_tune_fine ERROR: No such device (19) attr 5: dcxo_tune_fine_available value: [0 0 0] attr 6: ensm_mode value: fdd attr 7: ensm_mode_available value: sleep wait alert fdd pinctrl pinctrl_fdd_indep attr 8: filter_fir_config value: FIR Rx: 0,0 Tx: 0,0 attr 9: gain_table_config value: <gaintable AD9361 type=FULL dest=3 start=1300000000 end=4000000000> -3, 0x00, 0x00, 0x20 -3, 0x00, 0x00, 0x00 -3, 0x00, 0x00, 0x00 -2, 0x00, 0x01, 0x00 -1, 0x00, 0x02, 0x00 0, 0x00, 0x03, 0x00 1, 0x00, 0x04, 0x00 2, 0x00, 0x05, 0x00 3, 0x01, 0x03, 0x20 4, 0x01, 0x04, 0x00 5, 0x01, 0x05, 0x00 6, 0x01, 0x06, 0x00 7, 0x01, 0x07, 0x00 8, 0x01, 0x08, 0x00 9, 0x01, 0x09, 0x00 10, 0x01, 0x0A, 0x00 11, 0x01, 0x0B, 0x00 12, 0x01, 0x0C, 0x00 13, 0x01, 0x0D, 0x00 14, 0x01, 0x0E, 0x00 15, 0x02, 0x09, 0x20 16, 0x02, 0x0A, 0x00 17, 0x02, 0x0B, 0x00 18, 0x02, 0x0C, 0x00 19, 0x02, 0x0D, 0x00 20, 0x02, 0x0E, 0x00 21, 0x02, 0x0F, 0x00 22, 0x02, 0x10, 0x00 23, 0x02, 0x2B, 0x20 24, 0x02, 0x2C, 0x00 25, 0x04, 0x27, 0x20 26, 0x04, 0x28, 0x00 27, 0x04, 0x29, 0x00 28, 0x04, 0x2A, 0x00 29, 0x04, 0x2B, 0x00 30, 0x24, 0x21, 0x20 31, 0x24, 0x22, 0x00 32, 0x44, 0x20, 0x20 33, 0x44, 0x21, 0x00 34, 0x44, 0x22, 0x00 35, 0x44, 0x23, 0x00 36, 0x44, 0x24, 0x00 37, 0x44, 0x25, 0x00 38, 0x44, 0x26, 0x00 39, 0x44, 0x27, 0x00 40, 0x44, 0x28, 0x00 41, 0x44, 0x29, 0x00 42, 0x44, 0x2A, 0x00 43, 0x44, 0x2B, 0x00 44, 0x44, 0x2C, 0x00 45, 0x44, 0x2D, 0x00 46, 0x44, 0x2E, 0x00 47, 0x44, 0x2F, 0x00 48, 0x44, 0x30, 0x00 49, 0x44, 0x31, 0x00 50, 0x64, 0x2E, 0x20 51, 0x64, 0x2F, 0x00 52, 0x64, 0x30, 0x00 53, 0x64, 0x31, 0x00 54, 0x64, 0x32, 0x00 55, 0x64, 0x33, 0x00 56, 0x64, 0x34, 0x00 57, 0x64, 0x35, 0x00 58, 0x64, 0x36, 0x00 59, 0x64, 0x37, 0x00 60, 0x64, 0x38, 0x00 61, 0x65, 0x38, 0x20 62, 0x66, 0x38, 0x20 63, 0x67, 0x38, 0x20 64, 0x68, 0x38, 0x20 65, 0x69, 0x38, 0x20 66, 0x6A, 0x38, 0x20 67, 0x6B, 0x38, 0x20 68, 0x6C, 0x38, 0x20 69, 0x6D, 0x38, 0x20 70, 0x6E, 0x38, 0x20 71, 0x6F, 0x38, 0x20 </gaintable> attr 10: multichip_sync ERROR: Permission denied (13) attr 11: rssi_gain_step_error value: lna_error: 0 0 0 0 mixer_error: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 gain_step_calib_reg_val: 0 0 0 0 0 attr 12: rx_path_rates value: BBPLL:983040000 ADC:245760000 R2:122880000 R1:61440000 RF:30720000 RXSAMP:30720000 attr 13: trx_rate_governor value: nominal attr 14: trx_rate_governor_available value: nominal highest_osr attr 15: tx_path_rates value: BBPLL:983040000 DAC:122880000 T2:122880000 T1:61440000 TF:30720000 TXSAMP:30720000 attr 16: xo_correction value: 40000000 attr 17: xo_correction_available value: [39992000 1 40008000] 182 debug attributes found: debug attr 0: digital_tune value: 0 debug attr 1: calibration_switch_control value: 0 debug attr 2: multichip_sync value: 0 debug attr 3: gaininfo_rx2 value: 7 12 0 0 0 0 0 0 debug attr 4: gaininfo_rx1 value: 8 13 0 0 0 0 0 0 debug attr 5: bist_timing_analysis value: 0 debug attr 6: gpo_set value: 0 debug attr 7: bist_tone value: 0 debug attr 8: bist_prbs value: 0 debug attr 9: loopback value: 0 debug attr 10: initialize value: 0 debug attr 11: adi,bb-clk-change-dig-tune-enable value: 0 debug attr 12: adi,axi-half-dac-rate-enable value: 0 debug attr 13: adi,txmon-2-lo-cm value: 48 debug attr 14: adi,txmon-1-lo-cm value: 48 debug attr 15: adi,txmon-2-front-end-gain value: 2 debug attr 16: adi,txmon-1-front-end-gain value: 2 debug attr 17: adi,txmon-duration value: 8192 debug attr 18: adi,txmon-delay value: 511 debug attr 19: adi,txmon-one-shot-mode-enable value: 0 debug attr 20: adi,txmon-dc-tracking-enable value: 0 debug attr 21: adi,txmon-high-gain value: 24 debug attr 22: adi,txmon-low-gain value: 0 debug attr 23: adi,txmon-low-high-thresh value: 37000 debug attr 24: adi,gpo3-tx-delay-us value: 0 debug attr 25: adi,gpo3-rx-delay-us value: 0 debug attr 26: adi,gpo2-tx-delay-us value: 0 debug attr 27: adi,gpo2-rx-delay-us value: 0 debug attr 28: adi,gpo1-tx-delay-us value: 0 debug attr 29: adi,gpo1-rx-delay-us value: 0 debug attr 30: adi,gpo0-tx-delay-us value: 0 debug attr 31: adi,gpo0-rx-delay-us value: 0 debug attr 32: adi,gpo3-slave-tx-enable value: 0 debug attr 33: adi,gpo3-slave-rx-enable value: 0 debug attr 34: adi,gpo2-slave-tx-enable value: 0 debug attr 35: adi,gpo2-slave-rx-enable value: 0 debug attr 36: adi,gpo1-slave-tx-enable value: 0 debug attr 37: adi,gpo1-slave-rx-enable value: 0 debug attr 38: adi,gpo0-slave-tx-enable value: 0 debug attr 39: adi,gpo0-slave-rx-enable value: 0 debug attr 40: adi,gpo3-inactive-state-high-enable value: 0 debug attr 41: adi,gpo2-inactive-state-high-enable value: 0 debug attr 42: adi,gpo1-inactive-state-high-enable value: 0 debug attr 43: adi,gpo0-inactive-state-high-enable value: 0 debug attr 44: adi,gpo-manual-mode-enable-mask value: 0 debug attr 45: adi,gpo-manual-mode-enable value: 0 debug attr 46: adi,aux-dac2-tx-delay-us value: 0 debug attr 47: adi,aux-dac2-rx-delay-us value: 0 debug attr 48: adi,aux-dac2-active-in-alert-enable value: 0 debug attr 49: adi,aux-dac2-active-in-tx-enable value: 0 debug attr 50: adi,aux-dac2-active-in-rx-enable value: 0 debug attr 51: adi,aux-dac2-default-value-mV value: 0 debug attr 52: adi,aux-dac1-tx-delay-us value: 0 debug attr 53: adi,aux-dac1-rx-delay-us value: 0 debug attr 54: adi,aux-dac1-active-in-alert-enable value: 0 debug attr 55: adi,aux-dac1-active-in-tx-enable value: 0 debug attr 56: adi,aux-dac1-active-in-rx-enable value: 0 debug attr 57: adi,aux-dac1-default-value-mV value: 0 debug attr 58: adi,aux-dac-manual-mode-enable value: 1 debug attr 59: adi,aux-adc-decimation value: 256 debug attr 60: adi,aux-adc-rate value: 40000000 debug attr 61: adi,temp-sense-decimation value: 256 debug attr 62: adi,temp-sense-periodic-measurement-enable value: 1 debug attr 63: adi,temp-sense-offset-signed value: 206 debug attr 64: adi,temp-sense-measurement-interval-ms value: 1000 debug attr 65: adi,elna-gaintable-all-index-enable value: 0 debug attr 66: adi,elna-rx2-gpo1-control-enable value: 0 debug attr 67: adi,elna-rx1-gpo0-control-enable value: 0 debug attr 68: adi,elna-bypass-loss-mdB value: 0 debug attr 69: adi,elna-gain-mdB value: 0 debug attr 70: adi,elna-settling-delay-ns value: 0 debug attr 71: adi,ctrl-outs-enable-mask value: 255 debug attr 72: adi,ctrl-outs-index value: 0 debug attr 73: adi,rssi-duration value: 1000 debug attr 74: adi,rssi-wait value: 1 debug attr 75: adi,rssi-delay value: 1 debug attr 76: adi,rssi-unit-is-rx-samples-enable value: 0 debug attr 77: adi,rssi-restart-mode value: 3 debug attr 78: adi,fagc-adc-large-overload-inc-steps value: 2 debug attr 79: adi,fagc-power-measurement-duration-in-state5 value: 64 debug attr 80: adi,fagc-rst-gla-if-en-agc-pulled-high-mode value: 0 debug attr 81: adi,fagc-rst-gla-en-agc-pulled-high-enable value: 0 debug attr 82: adi,fagc-rst-gla-large-lmt-overload-enable value: 1 debug attr 83: adi,fagc-rst-gla-large-adc-overload-enable value: 1 debug attr 84: adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt value: 8 debug attr 85: adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll value: 10 debug attr 86: adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable value: 1 debug attr 87: adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable value: 1 debug attr 88: adi,fagc-rst-gla-stronger-sig-thresh-above-ll value: 10 debug attr 89: adi,fagc-optimized-gain-offset value: 5 debug attr 90: adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable value: 1 debug attr 91: adi,fagc-use-last-lock-level-for-set-gain-enable value: 1 debug attr 92: adi,fagc-gain-index-type-after-exit-rx-mode value: 0 debug attr 93: adi,fagc-gain-increase-after-gain-lock-enable value: 0 debug attr 94: adi,fagc-final-overrange-count value: 3 debug attr 95: adi,fagc-lmt-final-settling-steps value: 1 debug attr 96: adi,fagc-lpf-final-settling-steps value: 1 debug attr 97: adi,fagc-lock-level-gain-increase-upper-limit value: 5 debug attr 98: adi,fagc-lock-level-lmt-gain-increase-enable value: 1 debug attr 99: adi,fagc-lp-thresh-increment-steps value: 1 debug attr 100: adi,fagc-lp-thresh-increment-time value: 5 debug attr 101: adi,fagc-allow-agc-gain-increase-enable value: 0 debug attr 102: adi,fagc-state-wait-time-ns value: 260 debug attr 103: adi,fagc-dec-pow-measurement-duration value: 64 debug attr 104: adi,agc-immed-gain-change-if-large-lmt-overload-enable value: 0 debug attr 105: adi,agc-immed-gain-change-if-large-adc-overload-enable value: 0 debug attr 106: adi,agc-gain-update-interval-us value: 1000 debug attr 107: adi,agc-sync-for-gain-counter-enable value: 0 debug attr 108: adi,agc-dig-gain-step-size value: 4 debug attr 109: adi,agc-dig-saturation-exceed-counter value: 3 debug attr 110: adi,agc-lmt-overload-large-inc-steps value: 2 debug attr 111: adi,agc-lmt-overload-small-exceed-counter value: 10 debug attr 112: adi,agc-lmt-overload-large-exceed-counter value: 10 debug attr 113: adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable value: 0 debug attr 114: adi,agc-adc-large-overload-inc-steps value: 2 debug attr 115: adi,agc-adc-large-overload-exceed-counter value: 10 debug attr 116: adi,agc-adc-small-overload-exceed-counter value: 10 debug attr 117: adi,agc-outer-thresh-low-inc-steps value: 2 debug attr 118: adi,agc-outer-thresh-low value: 18 debug attr 119: adi,agc-inner-thresh-low-inc-steps value: 1 debug attr 120: adi,agc-inner-thresh-low value: 12 debug attr 121: adi,agc-inner-thresh-high-dec-steps value: 1 debug attr 122: adi,agc-inner-thresh-high value: 10 debug attr 123: adi,agc-outer-thresh-high-dec-steps value: 2 debug attr 124: adi,agc-outer-thresh-high value: 5 debug attr 125: adi,agc-attack-delay-extra-margin-us value: 1 debug attr 126: adi,mgc-split-table-ctrl-inp-gain-mode value: 0 debug attr 127: adi,mgc-dec-gain-step value: 2 debug attr 128: adi,mgc-inc-gain-step value: 2 debug attr 129: adi,mgc-rx2-ctrl-inp-enable value: 0 debug attr 130: adi,mgc-rx1-ctrl-inp-enable value: 0 debug attr 131: adi,gc-use-rx-fir-out-for-dec-pwr-meas-enable value: 0 debug attr 132: adi,gc-max-dig-gain value: 15 debug attr 133: adi,gc-dig-gain-enable value: 0 debug attr 134: adi,gc-low-power-thresh value: 24 debug attr 135: adi,gc-dec-pow-measurement-duration value: 8192 debug attr 136: adi,gc-lmt-overload-low-thresh value: 704 debug attr 137: adi,gc-lmt-overload-high-thresh value: 800 debug attr 138: adi,gc-adc-large-overload-thresh value: 58 debug attr 139: adi,gc-adc-small-overload-thresh value: 47 debug attr 140: adi,gc-adc-ovr-sample-size value: 4 debug attr 141: adi,gc-rx2-mode value: 2 debug attr 142: adi,gc-rx1-mode value: 2 debug attr 143: adi,update-tx-gain-in-alert-enable value: 0 debug attr 144: adi,tx-attenuation-mdB value: 10000 debug attr 145: adi,rf-tx-bandwidth-hz value: 18000000 debug attr 146: adi,rf-rx-bandwidth-hz value: 18000000 debug attr 147: adi,qec-tracking-slow-mode-enable value: 0 debug attr 148: adi,dc-offset-count-low-range value: 50 debug attr 149: adi,dc-offset-count-high-range value: 40 debug attr 150: adi,dc-offset-attenuation-low-range value: 5 debug attr 151: adi,dc-offset-attenuation-high-range value: 6 debug attr 152: adi,dc-offset-tracking-update-event-mask value: 5 debug attr 153: adi,clk-output-mode-select value: 0 debug attr 154: adi,external-rx-lo-enable value: 0 debug attr 155: adi,external-tx-lo-enable value: 0 debug attr 156: adi,xo-disable-use-ext-refclk-enable value: 1 debug attr 157: adi,tx-lo-powerdown-managed-enable value: 1 debug attr 158: adi,trx-synthesizer-target-fref-overwrite-hz value: 80008000 debug attr 159: adi,rx1-rx2-phase-inversion-enable value: 1 debug attr 160: adi,tx-rf-port-input-select-lock-enable value: 0 debug attr 161: adi,rx-rf-port-input-select-lock-enable value: 0 debug attr 162: adi,tx-rf-port-input-select value: 0 debug attr 163: adi,rx-rf-port-input-select value: 0 debug attr 164: adi,split-gain-table-mode-enable value: 0 debug attr 165: adi,1rx-1tx-mode-use-tx-num value: 1 debug attr 166: adi,1rx-1tx-mode-use-rx-num value: 1 debug attr 167: adi,2rx-2tx-mode-enable value: 1 debug attr 168: adi,digital-interface-tune-fir-disable value: 0 debug attr 169: adi,digital-interface-tune-skip-mode value: 0 debug attr 170: adi,tx-fastlock-pincontrol-enable value: 0 debug attr 171: adi,rx-fastlock-pincontrol-enable value: 0 debug attr 172: adi,rx-fastlock-delay-ns value: 0 debug attr 173: adi,tx-fastlock-delay-ns value: 0 debug attr 174: adi,tdd-skip-vco-cal-enable value: 0 debug attr 175: adi,tdd-use-dual-synth-mode-enable value: 0 debug attr 176: adi,debug-mode-enable value: 0 debug attr 177: adi,ensm-enable-txnrx-control-enable value: 0 debug attr 178: adi,ensm-enable-pin-pulse-mode-enable value: 0 debug attr 179: adi,frequency-division-duplex-independent-mode-enable value: 0 debug attr 180: adi,frequency-division-duplex-mode-enable value: 1 debug attr 181: direct_reg_access value: 0x0 No trigger on this device iio:device3: xadc 9 channels found: voltage5: vccoddr (input) 2 channel-specific attributes found: attr 0: raw value: 2059 attr 1: scale value: 0.732421875 voltage0: vccint (input) 2 channel-specific attributes found: attr 0: raw value: 1377 attr 1: scale value: 0.732421875 voltage4: vccpaux (input) 2 channel-specific attributes found: attr 0: raw value: 2466 attr 1: scale value: 0.732421875 temp0: (input) 3 channel-specific attributes found: attr 0: offset value: -2219 attr 1: raw value: 2516 attr 2: scale value: 123.040771484 voltage7: vrefn (input) 2 channel-specific attributes found: attr 0: raw value: 2 attr 1: scale value: 0.732421875 voltage1: vccaux (input) 2 channel-specific attributes found: attr 0: raw value: 2471 attr 1: scale value: 0.732421875 voltage2: vccbram (input) 2 channel-specific attributes found: attr 0: raw value: 1378 attr 1: scale value: 0.732421875 voltage3: vccpint (input) 2 channel-specific attributes found: attr 0: raw value: 1372 attr 1: scale value: 0.732421875 voltage6: vrefp (input) 2 channel-specific attributes found: attr 0: raw value: 1709 attr 1: scale value: 0.732421875 1 device-specific attributes found: attr 0: sampling_frequency value: 961538 No trigger on this device iio:device4: cf-ad9361-dds-core-lpc (buffer capable) 16 channels found: voltage0: (output, index: 0, format: le:S16/16>>0) 3 channel-specific attributes found: attr 0: calibphase value: 0.000000 attr 1: calibscale value: 1.000000 attr 2: sampling_frequency value: 30720000 voltage1: (output, index: 1, format: le:S16/16>>0) 3 channel-specific attributes found: attr 0: calibphase value: 0.000000 attr 1: calibscale value: 1.000000 attr 2: sampling_frequency value: 30720000 voltage2: (output, index: 2, format: le:S16/16>>0) 3 channel-specific attributes found: attr 0: calibphase value: 0.000000 attr 1: calibscale value: 1.000000 attr 2: sampling_frequency value: 30720000 voltage3: (output, index: 3, format: le:S16/16>>0) 3 channel-specific attributes found: attr 0: calibphase value: 0.000000 attr 1: calibscale value: 1.000000 attr 2: sampling_frequency value: 30720000 voltage4: (output, index: 4, format: le:S16/16>>0) 1 channel-specific attributes found: attr 0: sampling_frequency value: 30720000 voltage5: (output, index: 5, format: le:S16/16>>0) 1 channel-specific attributes found: attr 0: sampling_frequency value: 30720000 voltage6: (output, index: 6, format: le:S16/16>>0) 1 channel-specific attributes found: attr 0: sampling_frequency value: 30720000 voltage7: (output, index: 7, format: le:S16/16>>0) 1 channel-specific attributes found: attr 0: sampling_frequency value: 30720000 altvoltage3: TX1_Q_F2 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 0 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 altvoltage1: TX1_I_F2 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 90000 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 altvoltage0: TX1_I_F1 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 90000 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 altvoltage7: TX2_Q_F2 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 0 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 altvoltage6: TX2_Q_F1 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 0 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 altvoltage5: TX2_I_F2 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 90000 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 altvoltage2: TX1_Q_F1 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 0 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 altvoltage4: TX2_I_F1 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 90000 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 2 device-specific attributes found: attr 0: sync_start_enable value: arm attr 1: sync_start_enable_available value: arm 2 buffer-specific attributes found: attr 0: data_available value: 0 attr 1: length_align_bytes value: 16 1 debug attributes found: debug attr 0: direct_reg_access value: 0x90162 No trigger on this device iio:device5: cf-ad9361-dds-core-B 12 channels found: voltage1: (output) 3 channel-specific attributes found: attr 0: calibphase value: 0.000000 attr 1: calibscale value: 1.000000 attr 2: sampling_frequency value: 30720000 voltage0: (output) 3 channel-specific attributes found: attr 0: calibphase value: 0.000000 attr 1: calibscale value: 1.000000 attr 2: sampling_frequency value: 30720000 altvoltage3: TX1_Q_F2 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 0 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 altvoltage1: TX1_I_F2 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 90000 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 altvoltage0: TX1_I_F1 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 90000 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 altvoltage7: TX2_Q_F2 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 0 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 voltage2: (output) 3 channel-specific attributes found: attr 0: calibphase value: 0.000000 attr 1: calibscale value: 1.000000 attr 2: sampling_frequency value: 30720000 altvoltage6: TX2_Q_F1 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 0 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 voltage3: (output) 3 channel-specific attributes found: attr 0: calibphase value: 0.000000 attr 1: calibscale value: 1.000000 attr 2: sampling_frequency value: 30720000 altvoltage5: TX2_I_F2 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 90000 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 altvoltage2: TX1_Q_F1 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 0 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 altvoltage4: TX2_I_F1 (output) 5 channel-specific attributes found: attr 0: frequency value: 9279985 attr 1: phase value: 90000 attr 2: raw value: 1 attr 3: sampling_frequency value: 30720000 attr 4: scale value: 0.250000 2 device-specific attributes found: attr 0: sync_start_enable value: arm attr 1: sync_start_enable_available value: arm 1 debug attributes found: debug attr 0: direct_reg_access value: 0x90162 No trigger on this device iio:device6: cf-ad9361-A (buffer capable) 8 channels found: voltage0: (input, index: 0, format: le:S12/16>>0) 6 channel-specific attributes found: attr 0: calibbias value: 0 attr 1: calibphase value: 0.000000 attr 2: calibscale value: 1.000000 attr 3: label ERROR: Function not implemented (38) attr 4: samples_pps ERROR: No such device (19) attr 5: sampling_frequency value: 30720000 voltage1: (input, index: 1, format: le:S12/16>>0) 6 channel-specific attributes found: attr 0: calibbias value: 0 attr 1: calibphase value: 0.000000 attr 2: calibscale value: 1.000000 attr 3: label ERROR: Function not implemented (38) attr 4: samples_pps ERROR: No such device (19) attr 5: sampling_frequency value: 30720000 voltage2: (input, index: 2, format: le:S12/16>>0) 6 channel-specific attributes found: attr 0: calibbias value: 0 attr 1: calibphase value: 0.000000 attr 2: calibscale value: 1.000000 attr 3: label ERROR: Function not implemented (38) attr 4: samples_pps ERROR: No such device (19) attr 5: sampling_frequency value: 30720000 voltage3: (input, index: 3, format: le:S12/16>>0) 6 channel-specific attributes found: attr 0: calibbias value: 0 attr 1: calibphase value: 0.000000 attr 2: calibscale value: 1.000000 attr 3: label ERROR: Function not implemented (38) attr 4: samples_pps ERROR: No such device (19) attr 5: sampling_frequency value: 30720000 voltage4: (input, index: 4, format: le:S12/16>>0) 3 channel-specific attributes found: attr 0: label ERROR: Function not implemented (38) attr 1: samples_pps ERROR: No such device (19) attr 2: sampling_frequency value: 30720000 voltage5: (input, index: 5, format: le:S12/16>>0) 3 channel-specific attributes found: attr 0: label ERROR: Function not implemented (38) attr 1: samples_pps ERROR: No such device (19) attr 2: sampling_frequency value: 30720000 voltage6: (input, index: 6, format: le:S12/16>>0) 3 channel-specific attributes found: attr 0: label ERROR: Function not implemented (38) attr 1: samples_pps ERROR: No such device (19) attr 2: sampling_frequency value: 30720000 voltage7: (input, index: 7, format: le:S12/16>>0) 3 channel-specific attributes found: attr 0: label ERROR: Function not implemented (38) attr 1: samples_pps ERROR: No such device (19) attr 2: sampling_frequency value: 30720000 2 device-specific attributes found: attr 0: sync_start_enable value: disarm attr 1: sync_start_enable_available value: arm 2 buffer-specific attributes found: attr 0: data_available value: 0 attr 1: length_align_bytes value: 16 2 debug attributes found: debug attr 0: pseudorandom_err_check value: CH0 : PN9 : Out of Sync : PN Error CH1 : PN9 : Out of Sync : PN Error CH2 : PN9 : Out of Sync : PN Error CH3 : PN9 : Out of Sync : PN Error debug attr 1: direct_reg_access value: 0x0 No trigger on this device iio:device7: cf-ad9361-B 4 channels found: voltage0: (input) 6 channel-specific attributes found: attr 0: calibbias value: 0 attr 1: calibphase value: 0.000000 attr 2: calibscale value: 1.000000 attr 3: label ERROR: Function not implemented (38) attr 4: samples_pps ERROR: No such device (19) attr 5: sampling_frequency value: 30720000 voltage3: (input) 6 channel-specific attributes found: attr 0: calibbias value: 0 attr 1: calibphase value: 0.000000 attr 2: calibscale value: 1.000000 attr 3: label ERROR: Function not implemented (38) attr 4: samples_pps ERROR: No such device (19) attr 5: sampling_frequency value: 30720000 voltage1: (input) 6 channel-specific attributes found: attr 0: calibbias value: 0 attr 1: calibphase value: 0.000000 attr 2: calibscale value: 1.000000 attr 3: label ERROR: Function not implemented (38) attr 4: samples_pps ERROR: No such device (19) attr 5: sampling_frequency value: 30720000 voltage2: (input) 6 channel-specific attributes found: attr 0: calibbias value: 0 attr 1: calibphase value: 0.000000 attr 2: calibscale value: 1.000000 attr 3: label ERROR: Function not implemented (38) attr 4: samples_pps ERROR: No such device (19) attr 5: sampling_frequency value: 30720000 2 device-specific attributes found: attr 0: sync_start_enable value: disarm attr 1: sync_start_enable_available value: arm 2 debug attributes found: debug attr 0: pseudorandom_err_check value: CH0 : PN9 : Out of Sync : PN Error CH1 : PN9 : Out of Sync : PN Error CH2 : PN9 : Out of Sync : PN Error CH3 : PN9 : Out of Sync : PN Error debug attr 1: direct_reg_access value: 0x0 No trigger on this device iio_sysfs_trigger: 0 channels found: 2 device-specific attributes found: attr 0: add_trigger ERROR: Permission denied (13) attr 1: remove_trigger ERROR: Permission denied (13) No trigger on this device
